KurtE
05-18-2018, 07:12 PM
I installed the version, tried some hacking which I think I have logically removed.
But am having issues uploading. That is the board is not going into program mode... Windows 10, current update...
Verbose Info:
11:08:39.869 (ports 2): nothing new, skipping HID & Ports enum
11:09:16.041 (ports 2): got command: "list"
11:09:16.042 (ports 2): nothing new, skipping HID & Ports enum
11:09:23.078 (post_compile 1): Begin, version=1.42-beta5, high-res time
11:09:23.215 (loader): Teensy Loader 1.42-beta5, begin program
11:09:23.259 (loader): File "Blink.ino.hex". 9984 bytes, 1% used
11:09:23.269 (loader): Listening for remote control on port 3149
11:09:23.269 (loader): initialized, showing main window
11:09:23.366 (loader): remote connection 1192 opened
11:09:23.366 (loader): remote cmd from 1192: "comment: Teensyduino 1.42-beta5 - WINDOWS (teensy_post_compile)"
11:09:23.366 (post_compile 1): Sending command: comment: Teensyduino 1.42-beta5 - WINDOWS (teensy_post_compile)
11:09:23.367 (loader): remote cmd from 1192: "status"
11:09:23.369 (loader): HID/win32: vid:045E pid:07A5 ver:0797
11:09:23.370 (post_compile 1): Status: 1, 0, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:23.370 (post_compile 1): Sending command: dir:C:\Users\kurte\AppData\Local\Temp\arduino_buil d_286696\
11:09:23.370 (loader): remote cmd from 1192: "dir:C:\Users\kurte\AppData\Local\Temp\arduino_buil d_286696\"
11:09:23.370 (loader): remote cmd from 1192: "file:Blink.ino.hex"
11:09:23.370 (post_compile 1): Sending command: file:Blink.ino.hex
11:09:23.373 (loader): File "Blink.ino.hex". 9984 bytes, 1% used
11:09:23.376 (loader): remote cmd from 1192: "status"
11:09:23.378 (post_compile 1): Status: 1, 0, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:23.378 (post_compile 1): Sending command: auto:on
11:09:23.378 (loader): remote cmd from 1192: "auto:on"
11:09:23.378 (post_compile 1): Disconnect
11:09:23.389 (loader): remote connection 1192 closed
11:09:23.538 (loader): remote connection 1284 opened
11:09:23.542 (ports 2): got command: "list"
11:09:23.543 (ports 2): nothing new, skipping HID & Ports enum
11:09:23.544 (ports 2): got command: "list"
11:09:23.544 (ports 2): nothing new, skipping HID & Ports enum
11:09:23.554 (loader): remote connection 1324 opened
11:09:23.554 (loader): remote cmd from 1324: "comment: Teensyduino 1.42-beta5 - WINDOWS (teensy_post_compile)"
11:09:23.568 (post_compile 3): Begin, version=1.42-beta5, high-res time
11:09:23.569 (post_compile 3): Sending command: comment: Teensyduino 1.42-beta5 - WINDOWS (teensy_post_compile)
11:09:23.569 (loader): remote cmd from 1324: "status"
11:09:23.569 (loader): remote cmd from 1324: "dir:C:\Users\kurte\AppData\Local\Temp\arduino_buil d_286696\"
11:09:23.569 (loader): remote cmd from 1324: "file:Blink.ino.hex"
11:09:23.569 (loader): File "Blink.ino.hex". 9984 bytes, 1% used
11:09:23.571 (post_compile 3): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:23.571 (post_compile 3): Sending command: dir:C:\Users\kurte\AppData\Local\Temp\arduino_buil d_286696\
11:09:23.571 (post_compile 3): Sending command: file:Blink.ino.hex
11:09:23.578 (post_compile 3): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:23.578 (post_compile 3): Disconnect
11:09:23.601 (loader): remote connection 1324 closed
11:09:23.601 (loader): remote connection 1324 opened
11:09:23.601 (post_compile 4): Running teensy_reboot: "D:\arduino-1.8.5\hardware\teensy\..\tools\teensy_reboot.exe" teensy_reboot.exe "-board=TEENSY36" "-port=usb:0/140000/0/2/1" "-portlabel=COM15 (Teensy 3.6) Serial" "-portprotocol=Teensy"
11:09:23.609 (reboot 5): Begin, version=1.42-beta5, high-res time
11:09:23.609 (reboot 5): location = usb:0/140000/0/2/1
11:09:23.609 (reboot 5): portlabel = COM15 (Teensy 3.6) Serial
11:09:23.609 (reboot 5): portprotocol = Teensy
11:09:23.609 (reboot 5): Only location usb:0/140000/0/2/1 will be tried
11:09:23.609 (reboot 5): LoadLibrary cfgmgr32 ok
11:09:23.609 (reboot 5): LoadLibrary ntdll ok
11:09:23.610 (reboot 5): found_usb_device, id=\\?\usb#vid_16c0&pid_0483#2272310#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
11:09:23.610 (reboot 5): found_usb_device, loc=usb:0/140000/0/2/1 Port_#0001.Hub_#0003
11:09:23.610 (reboot 5): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0277
11:09:23.610 (reboot 5): found_usb_device, devinst=00000005
11:09:23.610 (reboot 5): add: loc=usb:0/140000/0/2/1, class=Ports, vid=16C0, pid=0483, ver=0277, serial=227, dev=\\?\usb#vid_16c0&pid_0483#2272310#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
11:09:23.610 (reboot 5): comport_from_devinst_list attempt
11:09:23.610 (reboot 5): found Ports in classguid_list at index=0
11:09:23.610 (reboot 5): port COM15 found from devnode
11:09:23.610 (reboot 5): found_usb_device complete
11:09:23.612 (loader): remote connection 1348 opened
11:09:23.612 (loader): remote cmd from 1348: "show:arduino_attempt_reboot"
11:09:23.612 (loader): got request to show arduino rebooting message
11:09:23.612 (loader): remote cmd from 1348: "comment: Teensyduino 1.42-beta5 - WINDOWS (teensy_reboot)"
11:09:23.612 (loader): remote cmd from 1348: "status"
11:09:23.612 (reboot 5): found Teensy Loader, version 1.42
11:09:23.612 (reboot 5): Sending command: show:arduino_attempt_reboot
11:09:23.614 (reboot 5): Sending command: comment: Teensyduino 1.42-beta5 - WINDOWS (teensy_reboot)
11:09:23.615 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:23.615 (reboot 5): do_reset (serial) COM15
11:09:23.616 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:23.616 (reboot 5): status read, retry 0
11:09:23.717 (loader): remote cmd from 1348: "status"
11:09:23.720 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:23.720 (reboot 5): status read, retry 1
11:09:23.833 (loader): remote cmd from 1348: "status"
11:09:23.837 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:23.837 (reboot 5): status read, retry 2
11:09:23.949 (loader): remote cmd from 1348: "status"
11:09:23.950 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:23.950 (reboot 5): status read, retry 3
11:09:24.064 (loader): remote cmd from 1348: "status"
11:09:24.069 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:24.069 (reboot 5): status read, retry 4
11:09:24.180 (loader): remote cmd from 1348: "status"
11:09:24.184 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:24.184 (reboot 5): status read, retry 5
11:09:24.295 (loader): remote cmd from 1348: "status"
11:09:24.297 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:24.297 (reboot 5): status read, retry 6
11:09:24.411 (loader): remote cmd from 1348: "status"
11:09:24.415 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:24.415 (reboot 5): status read, retry 7
11:09:24.533 (loader): remote cmd from 1348: "status"
11:09:24.537 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:24.537 (reboot 5): status read, retry 8
11:09:24.649 (loader): remote cmd from 1348: "status"
11:09:24.653 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:24.653 (reboot 5): status read, retry 9
11:09:24.765 (loader): remote cmd from 1348: "status"
11:09:24.770 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:24.770 (reboot 5): status read, retry 10
11:09:24.881 (loader): remote cmd from 1348: "status"
11:09:24.884 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:24.884 (reboot 5): status read, retry 11
11:09:24.997 (loader): remote cmd from 1348: "status"
11:09:25.000 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:25.000 (reboot 5): status read, retry 12
11:09:25.112 (loader): remote cmd from 1348: "status"
11:09:25.115 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:25.115 (reboot 5): status read, retry 13
11:09:25.234 (loader): remote cmd from 1348: "status"
11:09:25.238 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:25.238 (reboot 5): status read, retry 14
11:09:25.350 (loader): remote cmd from 1348: "status"
11:09:25.351 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:25.351 (reboot 5): status read, retry 15
11:09:25.465 (loader): remote cmd from 1348: "status"
11:09:25.469 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:25.469 (reboot 5): status read, retry 16
11:09:25.581 (loader): remote cmd from 1348: "status"
11:09:25.585 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:25.585 (reboot 5): status read, retry 17
11:09:25.697 (loader): remote cmd from 1348: "status"
11:09:25.700 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:25.700 (reboot 5): status read, retry 18
11:09:25.812 (loader): remote cmd from 1348: "status"
11:09:25.816 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:25.816 (reboot 5): status read, retry 19
11:09:25.935 (loader): remote cmd from 1348: "status"
11:09:25.939 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:25.939 (reboot 5): status read, retry 20
11:09:26.048 (loader): remote cmd from 1348: "status"
11:09:26.052 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:26.052 (reboot 5): status read, retry 21
11:09:26.164 (loader): remote cmd from 1348: "status"
11:09:26.167 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:26.167 (reboot 5): status read, retry 22
11:09:26.279 (loader): remote cmd from 1348: "status"
11:09:26.283 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:26.283 (reboot 5): status read, retry 23
11:09:26.395 (loader): remote cmd from 1348: "status"
11:09:26.397 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:26.397 (reboot 5): status read, retry 24
11:09:26.511 (loader): remote cmd from 1348: "status"
11:09:26.517 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:26.517 (reboot 5): status read, retry 25
11:09:26.627 (loader): remote cmd from 1348: "status"
11:09:26.630 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:26.630 (reboot 5): status read, retry 26
11:09:26.749 (loader): remote cmd from 1348: "status"
11:09:26.752 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:26.752 (reboot 5): status read, retry 27
11:09:26.864 (loader): remote cmd from 1348: "status"
11:09:26.868 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:26.868 (reboot 5): status read, retry 28
11:09:26.980 (loader): remote cmd from 1348: "status"
11:09:26.984 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:26.984 (reboot 5): status read, retry 29
11:09:27.096 (loader): remote cmd from 1348: "status"
11:09:27.100 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:27.100 (reboot 5): status read, retry 30
11:09:27.211 (loader): remote cmd from 1348: "status"
11:09:27.216 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:27.216 (reboot 5): status read, retry 31
11:09:27.327 (loader): remote cmd from 1348: "status"
11:09:27.331 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:27.331 (reboot 5): status read, retry 32
11:09:27.449 (loader): remote cmd from 1348: "status"
11:09:27.451 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:27.451 (reboot 5): status read, retry 33
11:09:27.565 (loader): remote cmd from 1348: "status"
11:09:27.569 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:27.569 (reboot 5): status read, retry 34
11:09:27.681 (loader): remote cmd from 1348: "status"
11:09:27.685 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:27.685 (reboot 5): status read, retry 35
11:09:27.797 (loader): remote cmd from 1348: "status"
11:09:27.800 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:27.800 (reboot 5): status read, retry 36
11:09:27.913 (loader): remote cmd from 1348: "status"
11:09:27.916 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:27.916 (reboot 5): status read, retry 37
11:09:28.028 (loader): remote cmd from 1348: "status"
11:09:28.032 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:28.032 (reboot 5): status read, retry 38
11:09:28.132 (loader): remote cmd from 1348: "status"
11:09:28.136 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:28.136 (reboot 5): status read, retry 39
11:09:28.236 (loader): remote cmd from 1348: "status"
11:09:28.240 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:28.240 (reboot 5): status read, retry 40
11:09:28.341 (loader): remote cmd from 1348: "status"
11:09:28.344 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:28.344 (reboot 5): status read, retry 41
11:09:28.452 (loader): remote cmd from 1348: "status"
11:09:28.456 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:28.456 (reboot 5): status read, retry 42
11:09:28.568 (loader): remote cmd from 1348: "status"
11:09:28.569 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:28.569 (reboot 5): status read, retry 43
11:09:28.684 (loader): remote cmd from 1348: "status"
11:09:28.688 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:28.688 (reboot 5): status read, retry 44
11:09:28.800 (loader): remote cmd from 1348: "status"
11:09:28.804 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:28.804 (reboot 5): status read, retry 45
11:09:28.904 (loader): remote cmd from 1348: "status"
11:09:28.908 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:28.908 (reboot 5): status read, retry 46
11:09:29.020 (loader): remote cmd from 1348: "status"
11:09:29.023 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:29.023 (reboot 5): status read, retry 47
11:09:29.135 (loader): remote cmd from 1348: "status"
11:09:29.138 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:29.138 (reboot 5): status read, retry 48
11:09:29.257 (loader): remote cmd from 1348: "status"
11:09:29.263 (reboot 5): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_28 6696\, Blink.ino.hex
11:09:29.263 (reboot 5): status read, retry 49
11:09:29.373 (loader): remote connection 1348 closed
11:09:29.373 (loader): remote connection 1324 closed
11:09:29.374 (reboot 5): Teensy did not respond to a USB-based request to automatically reboot.
11:09:29.383 (ports 2): got command: "list"
11:09:29.384 (ports 2): nothing new, skipping HID & Ports enum
11:09:29.384 (ports 2): got command: "list"
11:09:47.081 (loader): Verbose Info event
Got to run...
