Hi there!
So I was uploading a pretty basic program (AnalogReadSerial example I believe). Not the first program I have uploaded, as I've been using the board for about a week now. But just wanted to play around with some analog input stuff.
Halfway through uploading, I made the mistake of opening the serial monitor. I've noticed in the past you can't have the serial monitor open while you program, so I'm guessing some conflict must have happened in this case, as once the upload would have "finished", I couldn't see anything on the serial monitor.
Now, I cannot upload anything to the board even the blink program won't upload succesfuly. The Arduino IDE keeps prompting that "Teensy did not respond...please press the PROGRAM MODE BUTTON on your Teensy to upload your sketch", as it usually does the first time you upload. However it keeps doing this again, and again, and the teensy loader program does not have any change once I press the program button. I have tried with my Teensy 3.2 and the blink program uploads fine, (and yes I am changing the right Teensy board back and forth in Tools > Board).
Any help? I'm in Australia and so the 3.6 costed me nearly $55 to get here in my hands, so would be a shame if I have properly bricked it and there's nothing I could do.
I see on the schematic, the USB programming lines are routed directly to the processor - so I'm hoping there may be a way to reset the chip. I could be wrong but
