View Full Version : Teensyduino 1.43 Beta #2
Paul
08-26-2018, 01:04 PM
Here is a second beta test for Teensyduino 1.43.
Changes since Teensyduino 1.43-beta1 (https://forum.pjrc.com/threads/53549-Teensyduino-1-43-Beta-1)
Fix for Arduino 1.8.6 startup (Arduino issue #7917)
Fix SerialPlotter for Ports(Teensy)
USBHost_t36 fix for Gigabyte keyboard (thanks KurtE)
OctoWS2811 update movie2serial.pde
Remove BYTE define, previously for pre-1.0 Arduino compatibility
Update WS2812Serial documentation
Improve installer help dialog on Windows
PaulStoffregen
08-26-2018, 01:44 PM
Is anyone running MacOS Mojave beta?
Diodac
08-26-2018, 03:45 PM
Yeah I canít wait for testing. Downloading now.. 1.43#1 give me pains and mess. Couple libraries broken and no chance to compile any sketch with Teensy 3.2/3.1 on MacBook Pro ElCapitan 10.11.06
Unfortunately I overwritten 1.43#1 and now I cannot get back to 1.42
I had same problems with WS2812Serial and so on
mjs513
08-26-2018, 04:38 PM
I did a simple test with SerialPlotter and it does work as long as u have some sort of delay in the delay in the loop (I used a delay(1) for test. If you don't have a delay it works and eventually hangs the sketch to the point I have to go into task manager and kill the whole java process.
Serial.print(1); Serial.print(",");
Serial.print(2); Serial.print(",");
Serial.print(3); Serial.print(",");
Serial.println(4);
//delay(1);
One other thing I just noticed (I am assuming by design) though. If I use COMx(teensy 3.x) I can see data streaming on the serial monitor and the plotter. However, if I use COMx(teensy) not it printed to the serial monitor or plotter. Just a note.
Mike
el_supremo
08-26-2018, 05:10 PM
I moved the offending libraries back into the libraries directory and arduino-1.8.6_1.43_b2 starts up without any problems, although it is a bit slower.
When I run arduino_debug, it prints out some, but not all, of those plus a few more that it didn't complain about before. Then it prints them all out another 3 times. But under normal startup I don't see that anyway so no biggie.
Pete
PaulStoffregen
08-26-2018, 06:31 PM
You can always just download a fresh copy of Arduino 1.8.5 and install 1.42 into that copy.
The installers don't support downgrading, because each installer has no way to know which files need to be deleted because they were added by future version installers.
Diodac
Pete
Teensy 3.2, 1.43.2 on 1.8.6 on OSX El Capitan 10.11.06
Exploration menu
slowly.. slowly like turtle, huge lags, once even close down when I try go through menu.
Compilation
Now all libs is ok, I was able compiled my very complex code witch interrupts, and deep level setting, DMA, Timers, ADC and so on. Couple of Tabs.
I was surprised, because any errors and compilation was around 50% faster than on 1.8.5!!!! :cool:
Much better than 1.43.1 but the lags is weird during menu exploration.
It was the same thing with 1.42 when was beta 7 or so, I don't remember now, exactly but after installation proper 1.42 lagging problem disappear.
I hope get soon beta 3 ;) without lags. But Im happy that now I get it to work.
Thank you Paul, for your hard work for better stuff.
PaulStoffregen
08-26-2018, 07:18 PM
Can you help me with a little more info, so I can try to figure out what's causing the lag?
First, if your Mac isn't displaying the time with seconds in the menu bar, click the time and choose "Open Date & Time Preferences". The click the "Clock" tab and check the "Display time with seconds" box. Then you should see the time in your menu bar showing seconds.
When the lag happens again, please write down the time to the nearest second. Or if it happens multiple times, get the time to the nearest second for each lag. Just a few recorded is plenty, and even 1 would tremendously help, with the corresponding verbose info.
A minute or two later, ideally after another upload to Teensy, go into the Teensy Loader's Help > Verbose Info. Please copy all the log from around those times (maybe a minute before and after each) and post it here. Of course, also tell me those times you wrote down, since the verbose info won't actually tell me when the Arduino GUI lagged.
To figure out what's going wrong and causing those lags, I really need you to capture that verbose info so I can see the detailed log of what really was done. The answer is probably buried in all that info, but I can't see what really happened until you capture this verbose info during one the lags.
Diodac
08-26-2018, 07:51 PM
Okay Paul not a problem, I will keep records when happens and what I done in this time.
I remember that the same things happened on 1.42 and when lags get Arduino hang, mac restating itself with kernel panic, it happens also by Java but Iím not 100% sure now. At this time situation looking almost the same. Okay I will collect issues and writing it here.
PaulStoffregen
08-26-2018, 08:05 PM
Yikes, there should *never* be a kernel panic! Everything Teensyduino does is user-mode stuff using Apple's published APIs. No kernel driver stuff is ever installed.
Diodac
08-26-2018, 08:54 PM
I know that should be, but after reset I got, well know mac users , welcome screen inform me about that.
I also keep attention on others programs, but they working fine
just in case first now I will do some refreshments on my machine, and again installing fresh java and other configuration things.
Because we need be sure that my machine running without any problems. Tracking issues will be more accuracy.
PaulStoffregen
08-26-2018, 09:50 PM
Similar issue reported on Arduino's bug tracker (presumably not using Teensy)
https://github.com/arduino/Arduino/issues/7924
hudson
08-26-2018, 10:11 PM
I haven't tested this with 1.43 yet, but it appears that teensy 3.2 hardware with the teensyduino 1.42 and arduino 1.8.5 has a USB buffering issue.
static uint8_t buf[4096];
for(unsigned i = 0 ; i < sizeof(buf) ; i++)
while(1)
int c = Serial.read();
if (c == -1)
continue;
buf[i] = c;
// and check for proper pattern
// every 4 bytes should increment
uint32_t x = ((uint32_t*) buf)[0];
unsigned fail = 0;
for(unsigned i = 0 ; i < sizeof(buf) ; i+=4, x += 1)
uint32_t y = ((uint32_t*) buf)[i/4];
if (y == x)
continue;
Serial.print(i, HEX);
Serial.print(" ");
Serial.print(x, HEX);
Serial.print("!=");
Serial.print(y, HEX);
fail++;
if (fail != 0)
Serial.print("FAIL ");
Serial.println(fail);
// and simulate a flash write delay to force USB buffering
delay(10);
Feed this with serial data from:
#!/usr/bin/perl
use warnings;
use strict;
for(my $x = 0 ; $x < 8*1024*1024 ; $x+=1)
print pack("V", $x);
After a few megabytes it gets an failure when the previous 64 bytes are replayed:
......22C FD88B!=FD8AB
230 FD88C!=FD8AC
234 FD88D!=FD8AD
238 FD88E!=FD8AE
23C FD88F!=FD8AF
240 FD890!=FD8B0
244 FD891!=FD8B1
248 FD892!=FD8B2
24C FD893!=FD8B3
250 FD894!=FD8B4
254 FD895!=FD8B5
258 FD896!=FD8B6
25C FD897!=FD8B7
260 FD898!=FD8B8
264 FD899!=FD8B9
268 FD89A!=FD8BA
2A8 FD8AA!=FD7AA
2AC FD8AB!=FD7FB
2B0 FD8AC!=FD7FC
2B4 FD8AD!=FD7FD
2B8 FD8AE!=FD7FE
2BC FD......
With 1.6.8 and an ancient teensyduino this error never occurs. What's interesting is only that 64 byte block is in error; the stream re-synchronizes afterwards.
PaulStoffregen
08-27-2018, 12:24 AM
Just to confirm, I run this and did manage to reproduce the error. Will investigate soon...
14566
defragster
08-27-2018, 06:07 AM
Paul - about your text in :: https://forum.pjrc.com/threads/53380-Issue-w-Teensyduino-1-42-install?p=186104&viewfull=1#post186104
How does ADMIN versus "non-admin ZIP" install on Windows relate? i.e. 'non-admin' seems to be extra verbiage.
PaulStoffregen
08-27-2018, 10:36 AM
The regression definitely started with version 1.36.
1.36 didn't change anything significant in the USB serial code, but we did jump from gcc 4.8 to 5.4.
The other thing I've discovered is the bug only happens (using 1.43-beta2) with -O2 optimization, which is "Faster" in Tools > Optimize. With -O1, -O3, -Os or -Og, the bug doesn't happen.
I've tracked it down to usb_dev.c. Putting a pragma at the top to force that file compiled with different optimization "solves" the problem. But I've put hours into trying to compile individual functions with different optimize attributes, with very little success learning which function is responsible. When almost any of the functions use -O2, the bug happens.
I'm not ready to conclude this is a bona-fide compiler bug. It may be some very subtle bug in the code which just hasn't mattered.
At this point, I'm still undecided on what best thing to do for a 1.43 release. Maybe just put a pragma in the file? Or maybe change the default optimization to -O3, just in case this really is a subtle compiler bug with -O2?
defragster
08-27-2018, 10:52 AM
Paul: post #13 shows T_3.2 - did you confirm with that … on any other T_LC or 3.5, 3.6 at -O2?
PaulStoffregen
08-27-2018, 05:49 PM
I briefly confirmed it happens on 3.6, but otherwise I've done all my testing on 3.2.
This test takes quite some time to send as 32 megs of data, due to the inefficient receive code and the 10 ms delay for buffering, plus 12 Mbit/sec USB bandwidth limit. When the problem is present, I found a single run usually but not always reproduces the problem. Doing 2 or 3 runs per test makes this a very slow process. I ran it hundreds of times last night...
PaulStoffregen
08-27-2018, 06:48 PM
As a first quick fix, I've added this to usb_dev.c
https://github.com/PaulStoffregen/cores/commit/cb6289fd8539453107cbfe9f68511f5b6f72e373
dkryder
08-27-2018, 07:37 PM
Paul, not sure if you have run across this yet but out of curiosity i installed arduino as a windows app and as a result teensyduino was, for me, impossible to install. there was no suitable path listed in the teensyduino installer. as a matter of fact arduino as an app was not even listed in windows "programs and features" as uninstallable. i guess this is the next phase as i had never seen arduino as an app before. anyway, by right clicking on arduino as listed in the windows menu i was able to uninstall and then just download arduino and install the old way.
defragster
08-27-2018, 07:40 PM
@dkryder - follow link in the post above - this is a known issue and attempt to detect and provide notice is underway. What installer was used and what was shown on failure?
defragster
08-27-2018, 07:48 PM
Better to hide the symptom than let it show up. Not a single MCU does point to compile issue. That is a lot of code/time to search and run repro.
PaulStoffregen
08-27-2018, 11:19 PM
Did you run this 1.43-beta2 installer? Or were you using 1.42 or any prior version?
I ask because the help dialog (which shows when you click the "?" button beside the "Next" button that won't enable) was redesigned. Still a big unanswered question is whether this new design is effective at informing people about the Windows App version. So I'm asking if you ran this beta, or any prior version before the help dialog redesign.
dkryder
08-28-2018, 12:40 AM
yes, i was using 1.43-beta2 linked at the top of this page. and i had just fresh installed the arduino as a windows app which was installed by the windows app store. additionally, it was the only arduino copy installed on this machine.
PaulStoffregen
08-28-2018, 12:45 AM
Maybe we need to find another way to make this info more visible to Windows users? Any ideas? (and don't say to document on the first screen.... experience has shown *nobody* using Windows reads anything on the first screen)
defragster
08-28-2018, 01:04 AM
installer starts:: user hits NEXT for driver install
{win10 or not win 10 page}:: User hits NEXT
if ( user has 'Windows App version' ) show a notice page ???
Diodac
08-28-2018, 01:29 AM
Here is just 12s compilation verbose info, between this time I go quickly to menu system and of course get lags but i didn't see in verbose nothing to indicate that problem. Any way, compilation was successful. If i not touch menu all working nice, much faster compile than 1.8.5/1.42
Time lags 00:37:18 to the end of compilation, but compile in the background.
00:37:14.918 (ports 5): got command: "list"
00:37:20.537 (loader): file changed
00:37:20.554 (loader): File "Digidoo___pixel_FastLed_lib.ino.hex". 27260 bytes, 10% used
00:37:20.730 (post_compile 19): Begin, version=1.43-beta2
00:37:20.731 (loader): remote connection 19 opened
00:37:20.746 (post_compile 19): Sending command: comment: Teensyduino 1.43-beta2 - MACOSX (teensy_post_compile)
00:37:20.746 (loader): remote cmd from 19: "comment: Teensyduino 1.43-beta2 - MACOSX (teensy_post_compile)"
00:37:20.758 (loader): remote cmd from 19: "status"
00:37:20.777 (post_compile 19): Status: 1, 1, 0, 4, 0, 0, /var/folders/t1/dsfnhz7j74zgcd17ng12p0c00000gn/T/arduino_build_923298/, Digidoo___pixel_FastLed_lib.ino.hex
00:37:20.777 (post_compile 19): Disconnect
00:37:20.848 (ports 5): got command: "list"
00:37:20.859 (post_compile 20): Begin, version=1.43-beta2
00:37:20.995 (loader): remote connection 19 closed
00:37:21.009 (loader): remote connection 19 opened
00:37:21.016 (post_compile 20): Sending command: comment: Teensyduino 1.43-beta2 - MACOSX (teensy_post_compile)
00:37:21.025 (loader): remote cmd from 19: "comment: Teensyduino 1.43-beta2 - MACOSX (teensy_post_compile)"
00:37:21.042 (loader): remote cmd from 19: "status"
00:37:21.061 (post_compile 20): Status: 1, 1, 0, 4, 0, 0, /var/folders/t1/dsfnhz7j74zgcd17ng12p0c00000gn/T/arduino_build_923298/, Digidoo___pixel_FastLed_lib.ino.hex
00:37:21.061 (post_compile 20): Disconnect
00:37:21.124 (post_compile 21): Running teensy_reboot: /Users/user/Desktop/Arduino 1.8.6 TeensyDuino/Arduino.app/Contents/Java/hardware/teensy/../tools/teensy_reboot
00:37:21.373 (loader): remote connection 19 closed
00:37:21.389 (loader): remote connection 19 opened
00:37:21.404 (reboot 22): Begin, version=1.43-beta2
00:37:21.404 (reboot 22): location = /dev/cu.usbmodem4275401
00:37:21.404 (reboot 22): portlabel = /dev/cu.usbmodem4275401 (Teensy)
00:37:21.404 (reboot 22): portprotocol = serial
00:37:21.404 (reboot 22): Serial device /dev/cu.usbmodem4275401 will be tried first
00:37:21.404 (reboot 22): USB device add callback
00:37:21.405 (reboot 22): loc=4100000, vid=16C0, pid=0489, ver=0275, ser=4275400
00:37:21.405 (reboot 22): actual serailnum=427540
00:37:21.623 (loader): remote connection 19 closed
00:37:21.638 (loader): remote connection 19 opened
00:37:21.645 (reboot 22): USB device remove callback
00:37:21.645 (reboot 22): Serial add callback
00:37:21.646 (reboot 22): name=/dev/cu.usbmodem4275401, loc=4100000, vid=16c0, pid=0489, ver=0275
00:37:21.674 (reboot 22): Serial remove callback
00:37:21.692 (reboot 22): HID Manager started
00:37:21.693 (reboot 22): found Teensy Loader, version 1.43
00:37:21.693 (reboot 22): Sending command: show:arduino_attempt_reboot
00:37:21.868 (loader): remote cmd from 19: "show:arduino_attempt_reboot"
00:37:21.877 (loader): got request to show arduino rebooting message
00:37:21.888 (reboot 22): Sending command: comment: Teensyduino 1.43-beta2 - MACOSX (teensy_reboot)
00:37:21.898 (loader): remote cmd from 19: "comment: Teensyduino 1.43-beta2 - MACOSX (teensy_reboot)"
00:37:21.912 (loader): remote cmd from 19: "status"
00:37:21.926 (reboot 22): Status: 1, 1, 0, 4, 0, 0, /var/folders/t1/dsfnhz7j74zgcd17ng12p0c00000gn/T/arduino_build_923298/, Digidoo___pixel_FastLed_lib.ino.hex
00:37:21.926 (reboot 22): do_reset (serial) /dev/cu.usbmodem4275401
00:37:21.949 (loader): remote cmd from 19: "status"
00:37:21.967 (reboot 22): Status: 1, 1, 0, 4, 0, 0, /var/folders/t1/dsfnhz7j74zgcd17ng12p0c00000gn/T/arduino_build_923298/, Digidoo___pixel_FastLed_lib.ino.hex
00:37:21.967 (reboot 22): status read, retry 0
00:37:22.069 (loader): remote cmd from 19: "status"
00:37:22.086 (reboot 22): Status: 1, 1, 0, 4, 0, 0, /var/folders/t1/dsfnhz7j74zgcd17ng12p0c00000gn/T/arduino_build_923298/, Digidoo___pixel_FastLed_lib.ino.hex
00:37:22.086 (reboot 22): status read, retry 1
00:37:22.137 (ports 5): Serial remove callback
00:37:22.137 (ports 5): USB device remove callback
00:37:22.137 (ports 5): remove, loc=4100000
00:37:22.137 (ports 5): usb_remove: usb:4100000
00:37:22.137 (ports 5): del device: location=4100000
00:37:22.345 (loader): remote cmd from 19: "status"
00:37:22.373 (reboot 22): Status: 1, 1, 0, 4, 0, 0, /var/folders/t1/dsfnhz7j74zgcd17ng12p0c00000gn/T/arduino_build_923298/, Digidoo___pixel_FastLed_lib.ino.hex
00:37:22.373 (reboot 22): status read, retry 2
00:37:22.465 (ports 5): USB device add callback
00:37:22.466 (ports 5): loc=4100000, vid=16C0, pid=0478, ver=0103, ser=00068614
00:37:22.466 (ports 5): actual serailnum=427540
00:37:22.466 (ports 5): found prior teensy at this loc, age=0.328
00:37:22.466 (ports 5): name: [no_device] (Teensy 3.2) Bootloader
00:37:22.628 (loader): remote cmd from 19: "status"
00:37:22.654 (reboot 22): Status: 1, 1, 0, 4, 0, 0, /var/folders/t1/dsfnhz7j74zgcd17ng12p0c00000gn/T/arduino_build_923298/, Digidoo___pixel_FastLed_lib.ino.hex
00:37:22.654 (reboot 22): status read, retry 3
00:37:22.755 (loader): remote cmd from 19: "status"
00:37:22.772 (reboot 22): Status: 1, 1, 0, 4, 0, 0, /var/folders/t1/dsfnhz7j74zgcd17ng12p0c00000gn/T/arduino_build_923298/, Digidoo___pixel_FastLed_lib.ino.hex
00:37:22.772 (reboot 22): status read, retry 4
00:37:22.873 (loader): remote cmd from 19: "status"
00:37:22.888 (reboot 22): Status: 1, 1, 0, 4, 0, 0, /var/folders/t1/dsfnhz7j74zgcd17ng12p0c00000gn/T/arduino_build_923298/, Digidoo___pixel_FastLed_lib.ino.hex
00:37:22.888 (reboot 22): status read, retry 5
00:37:22.990 (loader): remote cmd from 19: "status"
00:37:23.006 (reboot 22): Status: 1, 1, 0, 4, 0, 0, /var/folders/t1/dsfnhz7j74zgcd17ng12p0c00000gn/T/arduino_build_923298/, Digidoo___pixel_FastLed_lib.ino.hex
00:37:23.006 (reboot 22): status read, retry 6
00:37:23.112 (loader): remote cmd from 19: "status"
00:37:23.134 (reboot 22): Status: 1, 1, 0, 4, 0, 0, /var/folders/t1/dsfnhz7j74zgcd17ng12p0c00000gn/T/arduino_build_923298/, Digidoo___pixel_FastLed_lib.ino.hex
00:37:23.134 (reboot 22): status read, retry 7
00:37:23.235 (loader): remote cmd from 19: "status"
00:37:23.247 (reboot 22): Status: 1, 1, 0, 4, 0, 0, /var/folders/t1/dsfnhz7j74zgcd17ng12p0c00000gn/T/arduino_build_923298/, Digidoo___pixel_FastLed_lib.ino.hex
00:37:23.247 (reboot 22): status read, retry 8
00:37:23.350 (loader): remote cmd from 19: "status"
00:37:23.362 (reboot 22): Status: 1, 1, 0, 4, 0, 0, /var/folders/t1/dsfnhz7j74zgcd17ng12p0c00000gn/T/arduino_build_923298/, Digidoo___pixel_FastLed_lib.ino.hex
00:37:23.362 (reboot 22): status read, retry 9
00:37:23.463 (loader): remote cmd from 19: "status"
00:37:23.475 (reboot 22): Status: 1, 1, 0, 4, 0, 0, /var/folders/t1/dsfnhz7j74zgcd17ng12p0c00000gn/T/arduino_build_923298/, Digidoo___pixel_FastLed_lib.ino.hex
00:37:23.475 (reboot 22): status read, retry 10
00:37:23.499 (loader): HID/macos: attach callback
00:37:23.505 (ports 5): HID add callback, vid=16c0, pid=0478, ver=0103, loc=4100000, use=ff9c:21
00:37:23.505 (ports 5): found prior teensy at this loc, age=1.040
00:37:23.505 (ports 5): name: HID=16c0:0478.ff9c.21 (Teensy 3.2) Bootloader
00:37:23.537 (loader): Device came online, code_size = 262144
00:37:23.544 (loader): Board is: Teensy 3.2 (MK20DX256), version 1.03
00:37:23.562 (loader): File "Digidoo___pixel_FastLed_lib.ino.hex". 27260 bytes, 10% used
00:37:23.571 (loader): set background IMG_ONLINE
00:37:23.590 (loader): File "Digidoo___pixel_FastLed_lib.ino.hex". 27260 bytes, 10% used
00:37:23.601 (loader): elf size appears to be 262144
00:37:23.608 (loader): elf binary data matches hex file
00:37:23.615 (loader): Code size from .elf file = 262144
00:37:23.623 (loader): begin operation
00:37:23.663 (loader): remote cmd from 19: "status"
00:37:23.686 (loader): flash, block=0, bs=1024, auto=1
00:37:23.708 (loader): flash, block=1, bs=1024, auto=1
00:37:23.729 (loader): flash, block=2, bs=1024, auto=1
00:37:23.744 (reboot 22): Status: 1, 1, 1, 5, 0, 1, /var/folders/t1/dsfnhz7j74zgcd17ng12p0c00000gn/T/arduino_build_923298/, Digidoo___pixel_FastLed_lib.ino.hex
00:37:23.747 (loader): flash, block=3, bs=1024, auto=1
00:37:23.798 (loader): flash, block=4, bs=1024, auto=1
00:37:23.816 (loader): remote cmd from 19: "status"
00:37:23.830 (loader): flash, block=5, bs=1024, auto=1
00:37:23.838 (reboot 22): Status: 1, 1, 1, 5, 0, 1, /var/folders/t1/dsfnhz7j74zgcd17ng12p0c00000gn/T/arduino_build_923298/, Digidoo___pixel_FastLed_lib.ino.hex
00:37:23.846 (loader): flash, block=6, bs=1024, auto=1
00:37:23.865 (loader): flash, block=7, bs=1024, auto=1
00:37:23.881 (loader): flash, block=8, bs=1024, auto=1
00:37:23.895 (loader): remote cmd from 19: "status"
00:37:23.903 (reboot 22): Status: 1, 1, 1, 5, 0, 1, /var/folders/t1/dsfnhz7j74zgcd17ng12p0c00000gn/T/arduino_build_923298/, Digidoo___pixel_FastLed_lib.ino.hex
00:37:23.915 (loader): flash, block=9, bs=1024, auto=1
00:37:23.932 (loader): flash, block=10, bs=1024, auto=1
00:37:23.951 (loader): flash, block=11, bs=1024, auto=1
00:37:23.967 (loader): flash, block=12, bs=1024, auto=1
00:37:23.987 (loader): flash, block=13, bs=1024, auto=1
00:37:24.016 (loader): flash, block=14, bs=1024, auto=1
00:37:24.033 (loader): flash, block=15, bs=1024, auto=1
00:37:24.054 (loader): remote cmd from 19: "status"
00:37:24.069 (loader): flash, block=16, bs=1024, auto=1
00:37:24.070 (reboot 22): Status: 1, 1, 1, 5, 0, 1, /var/folders/t1/dsfnhz7j74zgcd17ng12p0c00000gn/T/arduino_build_923298/, Digidoo___pixel_FastLed_lib.ino.hex
00:37:24.087 (loader): flash, block=17, bs=1024, auto=1
00:37:24.105 (loader): flash, block=18, bs=1024, auto=1
00:37:24.128 (loader): flash, block=19, bs=1024, auto=1
00:37:24.145 (loader): remote cmd from 19: "status"
00:37:24.156 (reboot 22): Status: 1, 1, 1, 5, 0, 1, /var/folders/t1/dsfnhz7j74zgcd17ng12p0c00000gn/T/arduino_build_923298/, Digidoo___pixel_FastLed_lib.ino.hex
00:37:24.181 (loader): flash, block=20, bs=1024, auto=1
00:37:24.216 (loader): remote cmd from 19: "status"
00:37:24.229 (reboot 22): Status: 1, 1, 1, 5, 0, 1, /var/folders/t1/dsfnhz7j74zgcd17ng12p0c00000gn/T/arduino_build_923298/, Digidoo___pixel_FastLed_lib.ino.hex
00:37:24.236 (loader): flash, block=21, bs=1024, auto=1
00:37:24.268 (loader): flash, block=22, bs=1024, auto=1
00:37:24.280 (reboot 22): status read, retry 11
00:37:24.280 (reboot 22): Success
00:37:24.280 (reboot 22): Disconnect
00:37:24.296 (ports 5): got command: "list"
00:37:24.491 (loader): remote connection 19 closed
00:37:24.511 (loader): flash, block=23, bs=1024, auto=1
00:37:24.531 (loader): flash, block=24, bs=1024, auto=1
00:37:24.548 (loader): flash, block=25, bs=1024, auto=1
00:37:24.567 (loader): flash, block=26, bs=1024, auto=1
00:37:24.624 (loader): sending reboot
00:37:24.633 (loader): begin wait_until_offline
00:37:24.648 (loader): HID/macos: status: ok
00:37:24.792 (ports 5): HID remove callback
00:37:24.792 (ports 5): HID add callback, vid=16c0, pid=0478, ver=0103, loc=4100000
00:37:24.792 (ports 5): USB device remove callback
00:37:24.792 (ports 5): remove, loc=4100000
00:37:24.792 (ports 5): usb_remove: usb:4100000
00:37:24.792 (ports 5): del device: location=4100000
00:37:24.816 (loader): HID/macos: detach callback: is currently open device
00:37:24.830 (loader): offline, waited 3
00:37:24.842 (loader): end operation, total time = 1.212 seconds
00:37:24.851 (loader): set background IMG_REBOOT_OK
00:37:24.861 (loader): redraw timer set, image 14 to show for 1200 ms
00:37:25.062 (ports 5): USB device add callback
00:37:25.063 (ports 5): loc=4100000, vid=16C0, pid=0489, ver=0275, ser=4275400
00:37:25.063 (ports 5): actual serailnum=427540
00:37:25.063 (ports 5): found prior teensy at this loc, age=0.271
00:37:25.063 (ports 5): name: [no_device] (Teensy 3.2) Serial+MIDI
00:37:25.215 (loader): HID/macos: number of devices found = 0
00:37:25.227 (loader): HID/macos: no devices found (empty set)
00:37:26.062 (loader): redraw, image 9
I spend all night for testing other configuration.
beta 143.2 with Arduino 1.8.5 any problem I found. Compilation faster around 15-20% than 1.42 version. Any lags and slow down, all working nice.
An alternative for now - use 1.43 with A1.8.5
A1.8.6 solo without Tensyduino - even like that, lags when menu exploration :D
Of course I use only T3.2 for test.
That is a GUI Arduino problem and Java regarding to the lags and slow down during exploration, I hope that we get soon patch for that bug.
Any way I will looking for solution with guys from GitHub #7935 maybe we manage fix up Ardu, I think that is a not big deal todo. Please test links below.
Paul I will track my work, if I find bugs or so, bounding with Teensy I let you know.
Sory for my English ;) that is my second language.
code using one of the following:
⬇️ http://downloads.arduino.cc/javaide/pull_requests/arduino-PR-7935-BUILD-760-linux32.tar.xz
⬇️ http://downloads.arduino.cc/javaide/pull_requests/arduino-PR-7935-BUILD-760-linux64.tar.xz
⬇️ http://downloads.arduino.cc/javaide/pull_requests/arduino-PR-7935-BUILD-760-windows.zip
⬇️ http://downloads.arduino.cc/javaide/pull_requests/arduino-PR-7935-BUILD-760-macosx.zip
⬇️ http://downloads.arduino.cc/javaide/pull_requests/arduino-PR-7935-BUILD-760-linuxarm.tar.xz
ℹ️ The linuxarm build is still experimental and may not be always available.
PaulStoffregen
08-29-2018, 11:24 AM
I see Arduino has committed the fix for #7935. I'll bring it in here and publish a 1.43-beta3 installer, so we can see if it solves this for Teensy too.
PaulStoffregen
08-29-2018, 12:24 PM
I've added beta3 with Arduino's fix for the Mac menu slowness.
https://forum.pjrc.com/threads/53602-Teensyduino-1-43-Beta-3
I believe we may also *still* have occasional issues where teensy_ports is causing lag... so really need to know if this beta3 fixes the slowness, or if I need to start digging into the port detection again.
Diodac
08-29-2018, 12:51 PM
Yeah I will do testing and let you know. But Arduino downloaded from official website still has slowness. We need use fixed version from links from my last post.
PaulStoffregen
08-29-2018, 12:54 PM
I put that #7935 fix into the beta3 installer. When you run it on an original copy of 1.8.6, that fix will be installed.
Diodac
08-30-2018, 12:54 AM
Paul I had done testing, and Arduino with beta3 working fine, I tested it just with T3.2 but in many scenarios and I donít have any problems with compilations,all was nice and smooth, moreover faster than 1.8.5 with 1.42
Menu slowness seems like fixed, no dramatic lag like before, just 2 times during 5h test I got 2-3 secons lags when I exploring menu Edit and when I try to go from Sketch to Tools menu.
Also I tested beta3 with A1.8.5 and in this case all working nice, any problem any lags.
Tomorrow I will try 1.8.6 beta3 on Mac after clean installation El Capitan 10.11.6 and SSD drive.
By the way I tested also what happens if I install java higher than 8. I chose JDK 10 and A1.8.6beta3 worked without any affecting.
