View Full Version : ChibiOS/RTand FreeRTOS for Teensy 3.0
Bill Greiman
11-16-2012, 03:05 PM
I have posted a first beta of two Real Time Operating System kernels for Teensy 3.0 as Teensy3-RTOSbeta20121116.zip http://code.google.com/p/beta-lib/downloads/list.
These systems are packaged as Arduino libraries so they can be used with other Arduino software. Since these are preemptive kernels, careful design is required to avoid problems with normally single-threaded Arduino software.
These RTOSs must be used with the beta8 version of the Teensy 3.0 software.
ChibiOS/RT is version 2.4.2 http://www.chibios.org/dokuwiki/doku.php?.
FreeRTOS is version 7.3.0 http://www.freertos.org/.
Warning: If this is your first use of a RTOS, you will likely experience the pain of my bugs and problems that are inherent to preemptive RTOSs. Please read the warnings in the included html documentation.
Four examples are included with each system. These example are described in the html included with the libraries.
t3andy
11-16-2012, 04:22 PM
Do you have a preference that a newbee can use easily? (Chibios or Freertos)
PaulStoffregen
11-16-2012, 06:14 PM
Eventually I believe there will be 3 options. I've been communicating with the Arduino developers are cooperatively scheduled approaches. They've published a cooperative scheduler library (developed by google as part of the ADK), and work is underway to make it integrate better with Arduino libraries. I'm also planning something similar to Bill Roy's "Run" library, but based on those new APIs. This stuff is all under development now, but hopefully in a few weeks there will be more options.
Bill Greiman
11-16-2012, 07:39 PM
Both ChibOS and FreeRTOS can be run in cooperative mode.
With ChibiOS you edit chconf.h and set CH_TIME_QUANTUM to zero. Setting this value to zero disables the preemption for threads with equal priority and the round robin becomes cooperative. Note that higher priority threads can still preempt, the kernel is always preemptive.
For FreeRTOS, the configUSE_PREEMPTION flag prevents the system tick from performing a task context switch. Therefore, Tasks have to explicitly yield. When you call any of the queue functionality, semaphores, or task delay or specifically taskYIELD(), then your task will yield and the scheduler can select the next task.
These modes simplify things in terms of threadsafe/reentrancy issues.
As far as a choice between ChibiOS and FreeRTOS, they are both first class systems so you need to look at the examples, read the documentation, and try them then decide.
t3andy
11-17-2012, 03:54 AM
Bill - Just curious ...
ChFastLogger fails SD
I ran the ReadWriteSDFat test with SPI chip select 10 at SPI_Half_Speed.
This test passes.
On the chFastlogger there is no place to select SPI_half_Speed and the chip select.
So I did this
const int chipSelect = 10;
// initialize SD card
if (!sd.init(chipSelect, SPI_HALF_SPEED)) sd.initErrorHalt();
it fails with
Type any character to start
Can't access SD card. Do not reformat.
No card, wrong chip select pin, or SPI problem?
SD errorCode: 0X1,0XFF
Question:
1. what spi chip select are you using for ChFastLogger?
2. what SD electronics vendor (Adafruit/sparkfun/pjrc) are you using for ChFastLogger?
3. what do you consider a "quality" micro SD card?
BTW ... great RTOS port !!!!
Bill Greiman
11-17-2012, 12:40 PM
The best way to use an SD card on Teensy 3.0 is to directly connect the card to these pins with very short wires.
CS - pin 10 (short white wire)
MOSI - pin 11 (violet wire)
MISO - pin 12 (orange wire)
SCK - pin 13 (long white wire)
red and black are vcc and gnd.
I use breakouts like these:
https://www.sparkfun.com/products/544
https://www.sparkfun.com/products/11403
Here is the actual setup with a cheap ebay breakout:
43
Note: the light made some areas shine like solder, pins are not shorted.
The version of SdFat included with the library is highly optimized for Teensy and uses a clock rate of 24 MHz at full speed.
You can test this version of SdFat independently of the RTOS by running examples in the SdFat/examples folder.
Try SdInfo.ino and QuickStart.ino. I don't think speed is the problem since SdFat slows the clock for initialization and your card fails on the first SD command.
You could try changing the SPI mode slightly by editing Sd2Card.cpp at line 81 and select 8-bit SPI frames. This introduces a slight delay between bytes.
// use 16-bit frame if SPI_USE_8BIT_FRAME is zero
#define SPI_USE_8BIT_FRAME 1
You don't need a super card. I use mostly SanDisk class 4 or better cards for this test. The card should not cause a problem in initialization. I had an old class 2 card suffer one data overrun due to one long write latency. It just took too long on one write, more than 200 msec. The SD spec allows a card to take up to 250 msec and some older class 2 cards do massive erases of flash occasionally.
For very high speed writes I use industrial SD cards like these http://www.newegg.com/Product/Product.aspx?Item=9SIA12K0CT6829. They use SLC flash which works better than consumer MLC/TLC flash for large fast writes.
Bill Greiman
11-17-2012, 03:24 PM
t3andy,
Here is one more thing you can try to get your SD to work. You can edit SdFatConfig.h and use Paul's SPI that simulates AVR.
Change line 52 of SdFatConfig.h from
#define USE_NATIVE_MK20DX128 1
To:
#define USE_NATIVE_MK20DX128 0
t3andy
11-17-2012, 07:06 PM
Ok Bill
Using the Adafruit micro SD (NOT full size SD) breakout board
Under sdFat library examples (only at SPI half speed @ SS 10) <-------<<<<<<<
The following examples passed
SDinfo works <----------- OK
ReadWriteSdFat works OK <-------- OK
QuickStart works OK <------------ OK
PrintBenchmark <------------ OK
I "assumed" that both RTOS fast logger examples would default to SPI full speed?
Since the above examples only worked at SPI half speed with my micro SD then
what I did was to insert into the function sd.init(CHIP_SELECT, SPI_FULL_SPEED) which made both fast loggers fail.
Both fast loggers must already default to chip select 10 and SPI half speed because running them without any changes whatsoever they both work.
How to you alter the fastloggers chip select and SPI speed for the SD?
Bill Greiman
11-17-2012, 07:27 PM
t3andy,
Sorry, I didn't catch the problem earlier. Here's what happened. I started with an old sketch from the AVR version of ChibiOS that used sd.init() instead of sd.begin(). The difference between the two is that the parameters are swapped. Here are the definitions of the two:
bool begin(uint8_t chipSelectPin = SD_CHIP_SELECT_PIN, uint8_t sckRateID = SPI_FULL_SPEED);
bool init(uint8_t sckRateID = SPI_FULL_SPEED, uint8_t chipSelectPin = SD_CHIP_SELECT_PIN);
init() was the original call to initialize the system, then the Arduino company used SdFat as the base for their SD.h library and introduced begin(chipSelect) so I added begin().
Guess I should retire init() to prevent this type of confusion.
At a minimum, I will fix these examples.
steve918
11-27-2012, 02:59 AM
Does either of these RTOS systems have usb wifi drivers for common dongles like Ralink?
PanMillenium
11-27-2012, 03:21 PM
I ve been looking into the chibi source code, and this is a bunch of things, a real OS :)
cool. Well same for freeRTOS.
on the other end this makes the choice difficult, because if you go that route , you need to invest time to deep dive and get the whole benefit of it.
looking at the vast arduino library landscape, I feel that preemptive capability is not for the everyone hobbyst due to non-re-entering stuff;
I m more voting for the cooperative approach, which chibi and freertos does support as well of course.
But then, I went trough the google world and didnt find too much of good and light library for the simple multitasking or event purpose !
also Paul, I ve read the thread in the arduino dev forum about the "yield" and I think thats going to be the future simple way of doing things. right?
then I d like just to share with you guys, that I m impressed by the library writen by "komisar" in the arduino forum, called ados.h ados.cpp here : http://arduino.cc/forum/index.php/topic,38030.0.html
look at it and its very light and does the job. not fully very self explaining for a noob, but if we make it simpler and if we package it with the right object classes, it could be a killer;
Paul, Bill and other, your opinion welcome, as I havent make a choice myself for the panSTamps and for my upcoming teensy3.0
cheers
PanMillenium
12-09-2012, 08:24 PM
Bill,
I ve been playing with ChibiOS and I feel like there is a missing push R3 in the port_switch.
in some case I was not able to get the "this" pointer when coming back into the task.
seems R3 holds the this ptr at the entry of a method;
on my side, I ve made strong progress on a Cooperative scheduler, leveraging the Java Thread libraries and it seems to work pretty well on Teensy 3 and Teensy 2 !
I ll post soon a lib and a subject in the forum :)
Paul, I think your dream for a light library looking like the Java Thread/timer and using the famous yield() is almost ready, stay tuned;
Bill Greiman
12-10-2012, 03:41 PM
http://mazsola.iit.uni-miskolc.hu/DATA/segedletek/arm/cmsis/CMSIS/Documentation/RTOS/html/index.htmlOn a context switch with ChibiOS, the registers R0–R3, R12 should be saved and restored by the NVIC. The SVC interrupt is used. Do you have an example where R3 is clobbered?
I am beginning to think that the multitude of schedulers and RTOSs for Arduino is a mistake. I keep reading of yet another effort in the forums. It's too easy to throw together another multithread solution.
One idea that I bumped into recently was an approach by ARM to make it easier to handle all the Cortex RTOSs.
The idea is to have a basic API that can provide functionality needed by libraries. This is a very thin layer that provides a common API for third party RTOSs.
This would allow libraries to be more multithread friendly in a standard way. It would require agreement on this API, probably not likely.
Since almost all RTOSs have a Cooperative scheduler mode they would both would have the simplest API functions.
The standard is CMSIS V3.0 RTOS API. Several RTOS vendors are providing this API already. Here is a bit from the announcement:
ARM today announced the availability of Version 3.0 of the ARM® Cortex™ Microcontroller Software Interface Standard (CMSIS). CMSIS 3.0 is expanded with a standardized API for Real-Time Operating System (RTOS) kernels and support for System View Description (SVD) XML files.
The RTOS API is designed to expand existing RTOS kernels with a standardized function set that supports multiple threads, resource control, time management, and data exchange. The RTOS API allows programmers to rely on standard RTOS features that are required in source code templates, middleware libraries, and other software components.
You can still access unique functionality for a third party RTOS but common things have a standard API.
Details are in the CMSIS Version 3.0 http://www.onarm.com/cmsis/download/21/version-3-0-of-the-cortex-microcontroller-software-interface-standard-cmsis/
Edit: here it is on the web http://mazsola.iit.uni-miskolc.hu/DATA/segedletek/arm/cmsis/CMSIS/Documentation/RTOS/html/index.html
benwynne
06-27-2013, 01:25 AM
Hey Guys,
First post here, was wondering if you have any more information on getting started with ChibiOS on teensy 3.0?
I downloaded the latest chibios version but can't find anything related to teensy.
Help much appreciated.
-Ben
stevech
06-28-2013, 06:53 AM
I've got the FreeRTOS port running on the Teensy 3. Not too hard, starting with the user contributed library.
I've used FreeRTOS on other processors, so I know its concepts.
keithg
10-29-2013, 03:23 PM
Can anyone post a simple recipe to get this going on a teensy 3.0? I am not savvy enough to figure this out, but want to see if it may be a solution for a simple/small ethernet connected device. If not chibi, then some sort of an OS...
KeithG
stevech
10-29-2013, 05:56 PM
Because I've used FreeRTOS in the past due to it's proliferation, I chose to use it, and easily adapted from the example posted here by the OP. That adaptation uses the T3's libraries whereas often, FreeRTOS runs as a bare metal OS.
I can send what I'm using - via a post or somehow send a zip file.
swarfrat
12-05-2013, 03:47 AM
I can build frBlink inside the arduino IDE. I can build a simple arduino blink from a makefile. But I can't seem to build frBlink from a makefile. It builds if I insert a main, but it doesn't run. What's puzzling is that I would expect behavior to be more similar since my makefile can build and run an arduino based blink.
mk20dx128.c contains the same call to main no matter how it's compiled, but I'm not sure where this phantom main gets supplied when building frBlink via the IDE.
milhead
04-18-2014, 09:53 PM
Using the blog I was able to get FreeRTOS running on my Teensy3.1. (http://rishifranklin.blogspot.com/2014/03/freertos-on-teensy-31.html)
The only additional nugget is that once you disable the 1KHz tick in mk20dx128.c you can no longer call delay().
The delay at the end of the Reset() function was blocking causing my main() to never be called.
Mil
stevech
04-21-2014, 09:38 PM
I didn't disable the 1KHz systick interrupt. FreeRTOS for Teensy, as I recall, used it for the scheduler. As I recall, the only hardware-ish thing in the FreeRTOS port to teensyduino was the software interrupt (trap), used to do a context switch.
The FreeRTOS delay / wait function is used as is, from the user program tasks.
milhead
04-23-2014, 05:37 PM
The recipe I followed replaced entries 11, 14 and 15 in the vector table.
Below is a snippet of mk20dx128.c where some of my defines are shown...
fault_isr, // 9 --
fault_isr, // 10 --
#ifdef TEENSY_USE_FREERTOS
vPortSVCHandler, // 11 ARM: Supervisor call (SVCall)
#else
svcall_isr, // 11 ARM: Supervisor call (SVCall)
debugmonitor_isr, // 12 ARM: Debug Monitor
fault_isr, // 13 --
xPortPendSVHandler, // 14 ARM: Pendable req serv(PendableSrvReq)
#else
pendablesrvreq_isr, // 14 ARM: Pendable req serv(PendableSrvReq)
xPortSysTickHandler, // 15 ARM: System tick timer (SysTick)
#else
systick_isr, // 15 ARM: System tick timer (SysTick)
#if defined(__MK20DX128__)
dma_ch0_isr, // 16 DMA channel 0 transfer complete
dma_ch1_isr, // 17 DMA channel 1 transfer complete
Mevon
05-16-2014, 05:00 AM
Hi milhead,
I tried the "recipe" on the other blog and didn't work for me. Somehow the changes in the vector table give me these errors:
Arduino: 1.0.5-r2 (Windows 7), Board: "Teensy 3.0"
C:\Program Files (x86)\Arduino\hardware\teensy\cores\teensy3\mk20dx 128.c:182:2: error: 'vPortSVCHandler' undeclared here (not in a function)
C:\Program Files (x86)\Arduino\hardware\teensy\cores\teensy3\mk20dx 128.c:185:2: error: 'xPortPendSVHandler' undeclared here (not in a function)
C:\Program Files (x86)\Arduino\hardware\teensy\cores\teensy3\mk20dx 128.c:186:2: error: 'xPortSysTickHandler' undeclared here (not in a function)
I tried with the FreeRTOS 8.0.1 source code and a FreeRTOSConfig.h from another port I had (somehow this file is nowhere to be found and no explanation in the blog on its provenance). I have included the "FreeRTOS.h" and "task.h" in the "mk20dx128.c" but somehow the linker or inclusion scheme can't find the "port.c" object at compile time, which makes me hate arduino even more... grrrrrrr
I'm curious also if you disabled the systick ini in the ResetHandler and how is it really done later, as stated in the blog. Also, seems the file "portable.h" is used to point on a "portmacro.h" but I would like to know if you added defines for that because it hasn't been defined for the teensy. I tried many other self proclaimed working examples (like this thread: http://forum.pjrc.com/threads/9481-New-version-of-FreeRTOS-for-Teensy-3-0-Due-and-AVR-boards) and other ports with no success. PLEASE HELP!! :)
Mevon
Mevon
05-16-2014, 05:33 AM
somehow adding these lines :
extern void xPortPendSVHandler( void ) __attribute__ (( naked ));
extern void xPortSysTickHandler( void );
extern void vPortSVCHandler( void ) __attribute__ (( naked ));
made compiling possible but nothing is happening.. must be that elusive delay() at the end of the ResetHandler that I don't seem to find that is sausing this.. :( more grrrrr
Mevon
milhead
05-16-2014, 02:00 PM
Hi Mevon,
Two commands to the reset handler to enable and light a LED, I used the onboard Teensy LED
as you resolve issues just move it down. I just moved the LED-ON as my debugging tool until I got into my tasks. There is a call to the delay() function at the end of the reset code that will definatly block until you do something to implement delay() without using the counter in the systick() handler.
The default delay() function was a hard spin delay that would run until the millisecond timer (incremented
by the default systick() function) incremented past the required milliseconds.
I've (I'll probably get blasted here) replaced it with the following function
// Uber-cheesy Brute Force ms delay... Requires 96MHz clock
// should probably put a bomb here in case it's run at a lower speed
// not terribly accurate but within a percent or so..
void spinDelayMs(uint32_t ms)
volatile double x;
int i;
int j;
for( j=0; j<ms; j++)
for(i=0; i<77; i++)
x = sqrt(2000);
x = sqrt(x);
I've since Changed the default delay function to call this one the libraries I've tried work again. I realize that they are not designed to be threadsafe, lets not have that discussion here.
In my last effort I was trying to get another timer on the Teensy to fire the 1Khz sysTick function, I haven't looked where else the libraries rely in the millisecond count value generated by the default delay function.
There is a 1KHz clock always running in the Freescale part as part of the low-power stuff but I haven't yet figured out (or if it's possible) how to route it to an interrupt. I hate to burn a timer and will probably keep looking for another way to do it.
Good Luck!
Miller
Mevon
06-04-2014, 03:19 PM
Hi milhead,
I guess we are the last one standing (like in the movie Highlander, let's not chop each others head off :P) I think there's a delay called in the init usb function inside the usb_dev.cpp but not sure, let me check for that. Also, I am really interested in NOT hijacking the systick function and maybe have work nicely togheter with the all the other functions or com stacks used by arduino. Do you have any inputs on that?
I found that one could make some defines inside the freertos header to hook up on existing code like so:
#define xPortPendSVHandler svcall_isr
#define xPortSysTickHandler pendablesrvreq_isr
#define vPortSVCHandler systick_isr
But I can seem to find the link to that now, think it was for some other platform on the FreeRTOS wiki/doc maybe in some readme. I think it's just sad to cripple the teensy to add some functionality that is maybe not needed after all. What is also sad is that the info on ChibiOS on arduino is rare. I have worked with Chibi and liked it very much. I had it running on the teensy 2 and on some sanguino clone but the code I had is lost or hard to find, since it was on my old laptop and reformated since. I don't know if I backed it up and have no time to look for that now.
And looking at this problem maybe we are trying to solve it in a wrong way. Maybe we could hook up the systick for the rtos directly on a "user created" timer interrupt (as I recall I think that's how it was done with chibi). Or maybe we could make a call in the existing systick function to call that other rtos systick function so both would be executed. My point is we don't know the repercussion of unhooking the original systick on others libraries that could be using it like maybe Time/Date libs with the RTC batt on, or maybe even just com libs or audio lib.
Anyways, I'll keep reporting here, thanks for reading.
Mevon
EDIT: no delay in usb_init(), but I think there is one other somewhere. I'll keep checking and post here..
Mevon
06-04-2014, 03:48 PM
For starters, here is my step one to get FreeRTOS on the Teensy3.1 : Getting and configuring the code. I took something already made by Erich Styger famous for is work MCU on Eclipse. I like the guy very much, he takes the time to reply on every comment or question post ed on the site : http://mcuoneclipse.com/.
All the golden stuff is on the github and has lots of exemples for the real deal K20DX50VLH5 or K20DX72VLH7 setup with CodeWarrior, etc. check it out if you want to get serious with coding on a freescale platform : https://github.com/ErichStyger/mcuoneclipse
If you download the ZIP youo can browse into the exemples because work as already been done to port FreeRTOS to ProcessorExpert (kinda GUI for the CodeWarrior that auto-magically generates code for the processor) and it was done with the version 8 of the RTOS. You can find it in the folder "\Examples\FreeRTOS_Ports\CodeWarrior\CW_FreeRTOS_F RDM-K20D50M\Sources". So the config file is mostly done but if anyone has some comments on configuring it for the Teensy, that would be much appreciated.
Next step is to follow the "recipe" on this blog : http://rishifranklin.blogspot.ca/2014/03/freertos-on-teensy-31.html and not fall into the many lurking pits... TBC
Mevon
EDIT : learning the hard way makes for better lessons :S Well turns out adding this library to arduino gives me success with the given exemples, for now the blinky print one works. Try this : https://code.google.com/p/rtoslibs/downloads/list?q=label:Arduino and get the FreeRTOS 7.4.2 update RTOS Arduino. Works just fine for a 1yo code. :D Happy FreeRTOSing!
stevech
06-04-2014, 04:20 PM
Are you guys still struggling to get FreeRTOS running - more than just using the contributed port that uses Teensyduino + one software interrupt for task state saving?
I've used that - works OK.
Mevon
06-04-2014, 04:36 PM
stevech no I think i got it under control now, but yeah maybe it would be nice to have to the latest and greatest version 8.0.1.... To be continued.
Mevon
MacroMachines
01-13-2015, 08:00 AM
I'm really curious about this, are the advantages in scheduling and "multitasking" / "multithreading"?
Does it work?
I guess I am curious what is the objective of using rtos on a small micro controller,
would the advantages gained outweigh the memory cost?
milhead
01-13-2015, 01:35 PM
In my opinion, It is completely about what you are trying to do and how you want your application to scale.
In a single threaded 'SuperLoop' style application the simple timing and rapid coding are great for simple things.. As soon as you have multiple independent operations being taken care of by the processor you will need to develop infrastructure that helps isolate and insulate the independent operations from each other. As this get's larger you get closer and closer to writing your own buggy RTOS...
The packaged RTOS is reasonably small and generally can be tailored down to a more minimal size.. It's already debugged and allows you to work on your programs purpose and not building and debugging infrastructure... One of the other benefits is that it allows you to write separate tasks for logically separate operations. Keeping a task bug free and reliable once written is easier than function n of a set or array of function pointers that all are called in turn.
I'm sure other folks have more valid opinions.. I've targeted 15 or 20 applications on Teensy processors and have yet to run out of memory, These days I always start out getting the OS up first.
Mil
stevech
01-13-2015, 03:54 PM
Does it work?
Does it work? Yes, millions of small embedded systems are in use with an RTOS.
Two kinds of RTOSes: preemptive scheduling and cooperative scheduling. For a beginner, the latter should be used to avoid races, deadlocks, etc.
A finite state machine can be used for most "tasking" and "threading", and is simpler.
The answer to your questions have to come from reading a book or on-line summary of RTOSes 101, then look at examples, then try it yourself.
FreeRTOS is very popular among many.
Read about finite state machine software too.
kalinowski
05-24-2015, 10:08 PM
Hello Bill,
First of all, thanks for a huge work on porting those RTOSses to teensy! I wrote a small program using your port of ChiBios and it works great when I build it in Arduino IDE. However, my needs are exceeding capabilities of this small IDE so I tired moving to building and deploying my project using makefile and this template:
https://github.com/apmorton/teensy-template
Here is where I have a problem with ChiBios. When I copy your library to libraries folder it gets compiled when I run make. I get following error that I can't seem to work out:
<path_to_project>build/libraries/ChibiOS_ARM/ChibiOS_ARM.o: In function `chBegin':
<path_to_project>libraries/ChibiOS_ARM/ChibiOS_ARM.c:110: undefined reference to `halInit'
<path_to_project>libraries/ChibiOS_ARM/ChibiOS_ARM.c:111: undefined reference to `chSysInit'
<path_to_project>libraries/ChibiOS_ARM/ChibiOS_ARM.c:114: undefined reference to `loop'
<path_to_project>libraries/ChibiOS_ARM/ChibiOS_ARM.c:114: undefined reference to `sysTickEnabled'
Looks like something is not included, but being a beginner cpp developer I can not figure out what is going south. Again, when I try to build the project using Arduino IDE everything works OK.
Thanks in advance for any help on this
Regards,
Michal
stevech
05-24-2015, 10:38 PM
Hello Bill,
Regards,
Michal
Not based on Makefiles, but a better IDE for some users, and all free:
http://www.visualmicro.com/
the $29 debugger is an option. Visual Micro itself is free. It uses MS Visual Studio, and the 2013/community edition of that is free.
Works with AVR, Teensy 3, and other AVR/ARM micros.
jonr
05-28-2015, 01:17 AM
If you just want multiple, cooperative co-routines that make for clean looking code, consider http://www.cocoos.net/. Trivial to port and there are no changes to existing libraries, no interrupts needed, no playing with the stack. It uses Duff's device.
stevech
05-28-2015, 01:57 AM
Indeed, don't use any RTOS if a cooperative scheduler will do, and use multiple state machines.
venusdharan
09-06-2015, 07:00 AM
I have exported the RTOS google code link to github
github.com/venusdharan/beta-lib.
stevech
09-06-2015, 07:05 AM
is this legitimate?
Bill Greiman
11-21-2015, 09:39 PM
I posted version 8.2.8 of FreeRTOS here https://github.com/greiman/FreeRTOS-Arduino.
Version 3.0.3 of ChibiOS/RT is here https://github.com/greiman/ChibiOS-Arduino.
These ports are designed to work with the Arduino IDE and allow use of Arduino style libraries.
If you want to use the HAL with ChibiOS or extra features of FreeRTOS, you should use the full distribution and skip the Arduino IDE and Arduino style libraries.
helle
12-12-2015, 05:27 PM
Bill Greiman, thanks for your work to port FreeRTOS to Arduino.
Today I tested the following setup and get an error on every example.
Arduino 1.6.6 + Teensyduino 1.26 + FreeRTOS from your git (8.2.3)
Compile the example: "frBlink" gives the following error:
./arduino-1.6.6/libraries/FreeRTOS_ARM/examples/frBlink/frBlink.ino: In function 'void Thread1(void*)':
frBlink:16: error: 'void Thread1(void*)' was declared 'extern' and later 'static' [-fpermissive]
static void Thread1(void* arg) {
frBlink:16: error: previous declaration of 'void Thread1(void*)' [-fpermissive]
Sounds logically? You have any idea?
stevech
12-12-2015, 05:31 PM
isn't this the normal C limitation that a static is local to the file - cannot be a global/extern.
Just remove the "static" attribute in the function definition if you want it to be used with extern
helle
12-12-2015, 07:51 PM
Yes, in C correct. I was confused by the C++ Code in Arduino, this would be another story with static functions.
I tried this before and it compiles. But I don't understand the intention of the author, because every example has this static functions.
In the end I try to understand the reasons.
stevech
12-12-2015, 07:59 PM
I took a look at the frblink example... the function that is the task code is in the same file as where it is launched: within startup(). So no extern was used and the task's function is simply local to the file/module.
In C, I don't see a need to declare a function as static unless you are concerned about name conflicts in a multi-file project.
I have seen static functions used to try to restrict what is/isn'/t callable externally - for an embedded system, this (and C++ private) seems silly.
npashine
04-06-2016, 09:20 AM
Hi all,
How to achieve multithreading in teensy 3.2.
As i have run speaker and ESP8266 both.
stevech
04-07-2016, 05:33 AM
easiest is to use 2+ finite state machines rather than going with a full RTOS.
defragster
04-07-2016, 06:09 AM
What do you have to do to 'Run ESP8266'? If you give details it might help get a better solution . . .
I'm bolting ESP8266 units from onehorse to my Teensy and they are pretty self sufficient - I transfer Serial data into T_3.2 with serialEvent#() for the serial port # - so that just happens under interrupt control. Are you using Arduino for the ESP8266, as I am, that allows the ESP8266 to run a webserver and be self sufficient - with chatter over serial and some shared I/O?
npashine
04-07-2016, 07:26 AM
I have to run esp8266 as mode 3 which is a station as well as access point mode.
After that, I have to take the request from N number of mobiles.
At the same time, my speaker is emitting 1.2s tone continuously.
2+ finite state machines????
defragster
04-07-2016, 07:57 AM
I can't offer any help - that didn't tell me much about what the Teensy needs to respond for the ESP8266? Or how this Mode3 ESP module is programmed are you using AT commands or other and not the native processor on the ESP? All Feedback over Serial?
It is interesting to know the ESP can be an AP and a Station (http://esp8266.github.io/Arduino/versions/2.1.0/doc/libraries.html) though.
