colorado_hick
I am running a fresh install of Ubuntu studio. I
1) downloaded an installed the arduino IDE for Linux 64
2) downloaded the udev rules file and copied it to the rules.d directory
3) Downloaded the teensy installer and ran it in the same directory as my ardunio install. it appeared to work
4) started the ardunio IDE.
See JAVA errors below. I also am showing my version
jon@T430u:~/Downloads/arduino-1.8.8$ uname -r
4.18.0-13-lowlatency
jon@T430u:~/Downloads/arduino-1.8.8$ ./arduino
Picked up JAVA_TOOL_OPTIONS:
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at processing.app.EditorLineStatus.setSerialPort(EditorLineStatus.java:136)
at processing.app.EditorLineStatus.paintComponent(EditorLineStatus.java:101)
at javax.swing.JComponent.paint(JComponent.java:1056)
at javax.swing.JComponent.paintChildren(JComponent.java:889)
at javax.swing.JComponent.paint(JComponent.java:1065)
at javax.swing.JSplitPane.paintChildren(JSplitPane.java:1047)
at javax.swing.JLayeredPane.paint(JLayeredPane.java:586)
at javax.swing.JComponent.paintToOffscreen(JComponent.java:5217)
at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(RepaintManager.java:1579)
at javax.swing.RepaintManager$PaintManager.paint(RepaintManager.java:1502)
at javax.swing.BufferStrategyPaintManager.paint(BufferStrategyPaintManager.java:306)
at javax.swing.RepaintManager.paint(RepaintManager.java:1272)
at javax.swing.JComponent.paint(JComponent.java:1042)
at java.awt.GraphicsCallback$PaintCallback.run(GraphicsCallback.java:39)
at sun.awt.SunGraphicsCallback.runOneComponent(SunGraphicsCallback.java:79)
at sun.awt.SunGraphicsCallback.runComponents(SunGraphicsCallback.java:116)
at java.awt.Container.paint(Container.java:1978)
at java.awt.Window.paint(Window.java:3906)
at javax.swing.RepaintManager$4.run(RepaintManager.java:842)
at javax.swing.RepaintManager$4.run(RepaintManager.java:814)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:814)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:789)
at javax.swing.RepaintManager.prePaintDirtyRegions(RepaintManager.java:738)
at javax.swing.RepaintManager.access$1200(RepaintManager.java:64)
at javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1732)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
^Cjon@T430u:~/Downloads/arduino-1.8.8$
