I apologize if this question has been asked before and I have not found the associated thread.
I cannot seem to get Arduino + TeensyDuino to work with my Teensy 3.6 board.
I am running on an HP Pavilion, Linux Mint 18.1 (Ubuntu Xenial), Oracle JDK 1.8.
Steps I took (following instructions in the PRJC Teensyduino area as best as I could):
* Downloaded 1.8.8 Arduino IDE code for 64-bit Linux.
* Installed Arduino IDE (install.sh)
* Ran the arduino-linux-setup.sh script.
* Rebooted (as it requested)
* Copied the 49-teensy.rules to /etc/udev/rules.d
* Installed TeensyDuino
* Installed the new pde.jar file (to get rid of the Java exceptions ... found that tid-bit via Google)
* Selections on the Tools menu show:
Board: Teensy 3.6
USB Type: Serial
CPU Speed: 180 MHz
Optimize: Faster
Keyboard Layout: US English
* I note that "Port" is greyed out at all times
I bring up the "Blink" sketch. I click the "Verify" button. The Teensy Loader window opens with "Press Button on Teensy to manually enter Program Mode". I note that "Auto" is highlighted.
If I push the button on the Teensy, the LED turns off, and that's it. There is no indication that the sketch was uploaded.
I would have thought that I would see a /dev/ttyUSB0 entry with the Teensy plugged in ... but I do not. I have a USB-to-TTL serial adaptor that I've used to communicate with my Raspberry Pi Zero, and when I plug that in, I do see a /dev/ttyUSB0 device (and 'Port' in the Arduino IDE is no longer greyed out). I don't know if that's meaningful or not.
Have I missed a step? I am happy to entertain any ideas.
--rg
Board: Teensy 3.6
USB Type: Serial
CPU Speed: 180 MHz
Optimize: Faster
--rg
