Error Compiling for Arduino/Genuino
kaylen
When trying to verify this code in Arduino, I keep getting this error message "Error Compiling for Arduino/Genuino exit status 1" the code is shown below
#include <VirtualWire.h>
#include <Servo.h>
// Declare Sevor Objects
Servo string1;
Servo string2;
Servo string3;
Servo string4;
Servo string5;
// Declare signal inputs
int pressure_signal1;
int pressure_signal2;
int pressure_signal3;
int pressure_signal4;
int pressure_signal5;
// Callibrated MIN MAX valuse for the flex resistors
int P1MIN=0;
int P1MAX=1000;
int P2MIN=0;
int P2MAX=1000;
int P3MIN=0;
int P3MAX=1000;
int P4MIN=0;
int P4MAX=1000;
int P5MIN=0;
int P5MAX=1000;
//Setup
string1.attach(9);
string2.attach(10);
string3.attach(11);
string4.attach(12);
string5.attach(13);
vw_set_ptt_inverted(true); // Required for RF Link module
vw_setup(400); // 400 Bits per sec
vw_set_tx_pin(12); // pin 12 is used as the transmit data out into the TX Link module
vw_set_rx_pin(11); // pin 11 is used as the transmit data out into the TX Link
vw_rx_start(); // Start the receiver
// Buffer that holds the data received
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
// check to see if anything has been received
if (vw_get_message(buf, &buflen)) {
// Data trimming
pressure_signal1 = constrain(buf[0], P1MIN, P1MAX);
pressure_signal2 = constrain(buf[2], P2MIN, P2MAX);
pressure_signal3 = constrain(buf[4], P3MIN, P3MAX);
pressure_signal4 = constrain(buf[6], P4MIN, P4MAX);
pressure_signal5 = constrain(buf[8], P5MIN, P5MAX);
// Maps the values from the flex resistor to control signals of the motor
int pullFinger1 = map(pressure_signal1, P1MIN, P1MAX, 0, 180);
int pullFinger2 = map(pressure_signal2, P2MIN, P2MAX, 180, 0);
int pullFinger3 = map(pressure_signal3, P3MIN, P3MAX, 0, 180);
int pullFinger4 = map(pressure_signal4, P4MIN, P4MAX, 180, 0);
int pullFinger5 = map(pressure_signal5, P5MIN, P5MAX, 0, 180);
string1.write(pullFinger1);
string2.write(pullFinger2);
string3.write(pullFinger3);
string4.write(pullFinger4);
string5.write(pullFinger5);
//Monitor values through serial monitos
Serial.print("pressure1: ");
Serial.print(pressure_signal1);
Serial.print(" pressure2: ");
Serial.print(pressure_signal2);
Serial.print("pressure3: ");
Serial.print(pressure_signal3);
Serial.print(" pressure4: ");
Serial.print(pressure_signal4);
Serial.print("pressure5: ");
Serial.print(pressure_signal5);
Serial.print(" motor1: ");
Serial.print(pullFinger1);
Serial.print(" motor2: ");
Serial.println(pullFinger2);
Serial.print(" motor3: ");
Serial.print(pullFinger3);
Serial.print(" motor4: ");
Serial.println(pullFinger4);
Serial.print(" motor5: ");
Serial.print(pullFinger5);
