I just got my new Teensy 4 (yay!), installed Teensyduino v1.47-beta7 onto a fresh copy of Arduino 1.8.9 (MacOS X), and then went to compile in Arduino one of my sketches that previously compile for the Teensy 3.2 with no changes. Unfortunately I go a number of compilations problems, and they all look to be in the libraries, See error output below.
A few notes/questions:
Any thoughts on how to address these issues?
Thanks!
Michael
- Most of the compilation problems are in the TimerThree header. My code does use TimerThree
- My have a branch of Adafruit_GFX that I have installed in my Arduino libraries folder. For sum reason when I did this it didn't conflict with the Teensy version of Adafruit_GFX, but now it apparently does. How do I fix that?
- I also seem to be getting errors in imxrt.h
- Everything compiles fine when Teensy 3.6 or 3.2 is the target.
Thanks!
Michael
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h: In member function 'void TimerThree::setPeriod(long unsigned int)':
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:186:32: error: 'F_TIMER' was not declared in this scope
const unsigned long cycles = (F_TIMER / 2000000) * microseconds;
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:265:16: error: 'FTM2_SC' was not declared in this scope
uint32_t sc = FTM2_SC;
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:267:2: error: 'FTM2_MOD' was not declared in this scope
FTM2_MOD = pwmPeriod;
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:268:25: error: 'FTM_SC_CLKS' was not declared in this scope
FTM2_SC = FTM_SC_CLKS(1) | FTM_SC_CPWMS | clockSelectBits | (sc & FTM_SC_TOIE);
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:268:29: error: 'FTM_SC_CPWMS' was not declared in this scope
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:268:68: error: 'FTM_SC_TOIE' was not declared in this scope
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h: In member function 'void TimerThree::start()':
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:276:2: error: 'FTM2_CNT' was not declared in this scope
FTM2_CNT = 0;
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h: In member function 'void TimerThree::stop()':
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:280:2: error: 'FTM2_SC' was not declared in this scope
FTM2_SC = FTM2_SC & (FTM_SC_TOIE | FTM_SC_CPWMS | FTM_SC_PS(7));
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:280:23: error: 'FTM_SC_TOIE' was not declared in this scope
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:280:37: error: 'FTM_SC_CPWMS' was not declared in this scope
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:280:63: error: 'FTM_SC_PS' was not declared in this scope
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h: In member function 'void TimerThree::resume()':
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:286:2: error: 'FTM2_SC' was not declared in this scope
FTM2_SC = (FTM2_SC & (FTM_SC_TOIE | FTM_SC_PS(7))) | FTM_SC_CPWMS | FTM_SC_CLKS(1);
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:286:24: error: 'FTM_SC_TOIE' was not declared in this scope
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:286:49: error: 'FTM_SC_PS' was not declared in this scope
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:286:55: error: 'FTM_SC_CPWMS' was not declared in this scope
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:286:83: error: 'FTM_SC_CLKS' was not declared in this scope
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h: In member function 'void TimerThree::setPwmDuty(char, unsigned int)':
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:296:13: error: 'TIMER3_A_PIN' was not declared in this scope
if (pin == TIMER3_A_PIN) {
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:297:3: error: 'FTM2_C0V' was not declared in this scope
FTM2_C0V = dutyCycle;
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:298:20: error: 'TIMER3_B_PIN' was not declared in this scope
} else if (pin == TIMER3_B_PIN) {
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:299:3: error: 'FTM2_C1V' was not declared in this scope
FTM2_C1V = dutyCycle;
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h: In member function 'void TimerThree::pwm(char, unsigned int)':
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:304:13: error: 'TIMER3_A_PIN' was not declared in this scope
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:305:53: error: 'PORT_PCR_MUX' was not declared in this scope
*portConfigRegister(TIMER3_A_PIN) = PORT_PCR_MUX(3) | PORT_PCR_DSE | PORT_PCR_SRE;
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:305:57: error: 'PORT_PCR_DSE' was not declared in this scope
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:305:72: error: 'PORT_PCR_SRE' was not declared in this scope
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:306:20: error: 'TIMER3_B_PIN' was not declared in this scope
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:307:53: error: 'PORT_PCR_MUX' was not declared in this scope
*portConfigRegister(TIMER3_B_PIN) = PORT_PCR_MUX(3) | PORT_PCR_DSE | PORT_PCR_SRE;
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:307:57: error: 'PORT_PCR_DSE' was not declared in this scope
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:307:72: error: 'PORT_PCR_SRE' was not declared in this scope
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h: In member function 'void TimerThree::disablePwm(char)':
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:315:13: error: 'TIMER3_A_PIN' was not declared in this scope
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:317:20: error: 'TIMER3_B_PIN' was not declared in this scope
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h: In member function 'void TimerThree::attachInterrupt(void (*)())':
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:327:2: error: 'FTM2_SC' was not declared in this scope
FTM2_SC |= FTM_SC_TOIE;
Multiple libraries were found for "Adafruit_GFX.h"
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:327:13: error: 'FTM_SC_TOIE' was not declared in this scope
Used: /Users/michael/Documents/Arduino/libraries/Adafruit_GFX
Not used: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Adafruit_GFX
In file included from /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4/core_pins.h:32:0,
from /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4/wiring.h:38,
from /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4/WProgram.h:45,
from /var/folders/jf/2f6rf7pd15l89639dl1ddl_80000gn/T/arduino_build_519018/pch/Arduino.h:6,
from /Users/michael/Documents/Arduino/libraries/ShiftRegisterLEDMatrixLib/src/BaseLEDMatrix.h:21,
from /Users/michael/Documents/Arduino/libraries/ShiftRegisterLEDMatrixLib/src/BaseLEDMatrix.cpp:19:
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:328:18: error: 'IRQ_FTM2' was not declared in this scope
NVIC_ENABLE_IRQ(IRQ_FTM2);
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4/imxrt.h:8292:52: note: in definition of macro 'NVIC_ENABLE_IRQ'
#define NVIC_ENABLE_IRQ(n) (*(&NVIC_ISER0 + ((n) >> 5)) = (1 << ((n) & 31)))
In file included from /Users/michael/Documents/Arduino/libraries/ShiftRegisterLEDMatrixLib/src/BaseLEDMatrix.cpp:247:0:
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h: In member function 'void TimerThree::detachInterrupt()':
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:335:2: error: 'FTM2_SC' was not declared in this scope
FTM2_SC &= ~FTM_SC_TOIE;
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:335:14: error: 'FTM_SC_TOIE' was not declared in this scope
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/TimerThree/TimerThree.h:336:19: error: 'IRQ_FTM2' was not declared in this scope
NVIC_DISABLE_IRQ(IRQ_FTM2);
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4/imxrt.h:8293:52: note: in definition of macro 'NVIC_DISABLE_IRQ'
#define NVIC_DISABLE_IRQ(n) (*(&NVIC_ICER0 + ((n) >> 5)) = (1 << ((n) & 31)))
Error compiling for board Teensy 4.0.
