View Full Version : Teensyduino 1.48 Beta #1
Paul
09-14-2019, 04:19 AM
Here is a first beta test for Teensyduino 1.48.
Linux 32 bit:
https://www.pjrc.com/teensy/td_148-beta1/TeensyduinoInstall.linux32
Linux 64 bit:
https://www.pjrc.com/teensy/td_148-beta1/TeensyduinoInstall.linux64
Linux ARM:
https://www.pjrc.com/teensy/td_148-beta1/TeensyduinoInstall.linuxarm
Linux ARM64:
https://www.pjrc.com/teensy/td_148-beta1/TeensyduinoInstall.linuxaarch64
Mac OS-X:
https://www.pjrc.com/teensy/td_148-beta1/TeensyduinoInstall.dmg
Windows:
https://www.pjrc.com/teensy/td_148-beta1/TeensyduinoInstall.exe
Changes since Teensyduino 1.47:
Support for Arduino 1.8.10
Drop support for old Arduino versions 1.0.6, 1.6.5 and 1.8.1
Improve Serial Monitor efficiency, Arduino 1.8.9 & 1.8.10 only
Update FastLED to 3.3.1, fixes compile error on Teensy LC (Daniel Garcia)
Fix more than 2 IntervalTimer instances on Teensy 4.0
Fix Teensy 4.0 low power mode for 24 MHz (Defragster)
Teensy 4.0 SPI signal drive strength changed on Teensy 4.0 (KurtE)
Fix I2S output on Teensy 3.0
The Serial Monitor improvement still has debug printing to Arduino's console. You'll see messages there as you open and close the serial monitor, or connect and disconnect Teensy. If you get any messages in red, especially any Java exceptions, please report them on this thread.
Theremingenieur
09-14-2019, 07:03 AM
Installs on macOS 10.15 Catalina beta 19A558d. Didn't compile the Blink example for T4.0 in a first attempt, got an error message telling that Arduino could not access the hardware directory which is buried inside the Arduino.app by Teensyduino.
Had to go into System Preferences - Privacy and to grant full disk access to the Arduino.app manually. Now, it works like a charm!
PaulStoffregen
09-14-2019, 07:35 AM
@Theremingenieur - Do you have a Teensy 4.0 handy? Any chance you could run the USB print speed test (https://github.com/PaulStoffregen/USB-Serial-Print-Speed-Test/blob/master/usb_serial_print_speed.ino) and let me know how 10.15 does?
On 10.14 Mojave it still uses a lot more CPU than Windows or Linux, but at least the Arduino IDE doesn't seem to give out of memory exceptions.
Theremingenieur
09-14-2019, 08:15 AM
I have (naturally) a Teensy 4.0 handy! :)
USB print speed test does between 240,000 and 248,000 lines per second. CPU usage is rather high :
17591
PaulStoffregen
09-14-2019, 08:25 AM
I guess lower CPU use was a long shot. Pretty sure Apple hasn't changed much about that part of the OS in quite a long time.
If you leave it running, does the serial monitor ever stop or freeze up, or Java start throwing exceptions about running out of memory?
Theremingenieur
09-14-2019, 08:31 AM
Relaunched it. Keeping an eye on it and will tell later.
Theremingenieur
09-14-2019, 08:45 AM
It did run for about 10 minutes until serial output simply stopped without any error message in the Arduino console :
17593
Arduino does not longer eat CPU (2%) but kernel remains on about 70% from which I guess that the Teensy keeps sending.
Theremingenieur
09-14-2019, 09:23 AM
Closing and re-opening the Serial Monitor shows that the brave Teensy 4.0 continues working. But the serial monitor stalls in arbitrary intervals.
defragster
09-14-2019, 09:27 AM
17593
Thierry - when it stops - add another Teensy or plug in or remove some other USB device - mouse - flash drive. Any chance that makes it restart?
257K is a good speed - a shame it dies and eats so much of the CPU.
Theremingenieur
09-14-2019, 10:24 AM
Ok. Had to find an USB hub first... Restarted everything then, with the T4 connected through a passive USB-Hub and an USB-C adapter to the MacBook. Waited for the serial monitor stalling. Then unpacked and connected a brand new T3.2. This made the serial monitor run again. Observations continue...
But I must say that I personally do not see that serial monitor stalling as an important issue. None of my projects is made to flood the Serial monitor with so much data and I’d guess that most other real world projects do neither. To me, it looks rather like an academic thing...
defragster
09-14-2019, 10:42 AM
Thanks for that … it was just a TEST - I get stalling on Win 10 when I resize a BUSY window - it was happening intermittently, though I stopped waiting for that when I spend a couple seconds resizing a busy window it stalls. Then any USB device arriving or departing would wake the T_SerMon code and it would start again.
When Paul gets to look at it - it will be interesting for him to know it acts the same on both platforms to help him reproduce - and perhaps resolve - the issue especially since his Win 10 system hardware is less plentiful. Also interesting you noted the MAC core was still eating lots of cycles - on Windows it drops off over 50% of a lesser number when that happens.
Theremingenieur
09-14-2019, 10:44 AM
After reanimating it by plugging the T3.2 (blinking in factory/hid mode) it ran until stalling again. Then, un-plugging and re-plugging the T3.2 makes no more effect, but un-plugging and re-plugging the T4.0 restarts the counting and re-animates the serial monitor window which I had left open.
defragster
09-14-2019, 11:18 AM
@Paul: Did UNZIP of 1.8.10 on Windows 10. TeensyInstaller ran well - no issues. IDE 1.8.10 must not be on KNOWN list yet as I had to tell Windows to RUN ANYWAY. Had to Approve JAVA as usual - then upload worked to a T4.
Second sketch uploaded was my long line LPS test - resize for a MINUTE and it never stalled. Did again across both monitors and back to the big one and no issue from smallest size with lots of line shifting.
The LPS reported in that sketch is about what it was at 220K+ and CPU is 6% to 8%.
Running 8+ minutes and 3rd and 4th set of resize - No Problem - more than I could ever do before. And nothing of note in the console:
Sketch uses 13968 bytes (0%) of program storage space. Maximum is 2031616 bytes.
Global variables use 20240 bytes (1%) of dynamic memory, leaving 1028336 bytes for local variables. Maximum is 1048576 bytes.
T:\arduino_1.8.10\hardware\teensy/../tools/teensy_post_compile -file=lps_test.ino -path=T:\TEMP\arduino_build_888535 -tools=T:\arduino_1.8.10\hardware\teensy/../tools -board=TEENSY40 -reboot -port=usb:0/140000/0/8/7 -portlabel=hid#vid_16c0&pid_0478 Bootloader -portprotocol=Teensy
TeensyPipeMonitor open usb:0/140000/0/8/7
opened, dev=COM37, name=Serial
>> 1500 seconds still running fine with resize. Started 2nd T4 - using TyComm as Sermon. TyComm 85K to 112 lps and using 27% of CPU for 2nd T4.
Will be running the next few hours ...
wwatson
09-14-2019, 03:35 PM
@Paul -
I just setup Arduino 1.8.10 and TD 1.48 B1 on one my Linux computers. I was playing with HelloSerialMonitor. I selected the 'Show Timestamp' checkbox and nothing happened.
Tried Arduino 1.8.9 Serial Monitor which is setup with TD 1.47 and the time stamps were showing.
Has this been disabled in Arduino 1.8.10?
mjs513
09-14-2019, 06:28 PM
@wwatson and @Paul
I am using IDE 1.8.9 with TD1.47-beta1 and timestamp is available with that combination either.
defragster
09-14-2019, 07:03 PM
just a guess: the missing timestamp is part of recent speed rework work in progress?
t_sermon running here since last post now beyond this 27778 seconds - but running fine and no amount of resizing causes issues having only uploaded 2 sketches a couple of times - still hold lps speed and CPU ~7% and RAM 438MB in use is good!:
>count=2156887153, lines/s=224071 >count=2156887154, lines/s=224071 >count=2156887155, lines/s=224071 >count=2156887156, lines/s=224071 27778
>count=2156887157, lines/s=224071 >count=2156887158, lines/s=224071 >count=2156887159, lines/s=224071 >count=2156887160, lines/s=224071 27778
>count=2311357145, lines/s=233671 >count=2311357146, lines/s=233671 >count=2311357147, lines/s=233671 >count=2311357148, lines/s=233671 28455
>count=2311357149, lines/s=233671 >count=2311357150, lines/s=233671 >count=2311357151, lines/s=233671 >count=2311357152, lines/s=233671 28455
bicycleguy
iMac 10.14.6, Arduino 1.8.10, TD 1.48 B1, on T4
After loading certain sketches the serial port goes away and won't come back until I compile something like blink and press the button. T4 crashes?
Haven't narrowed it down but a sketch like Part_1_04_Blink_While_Playing in the tutorials crashes the T4.
Perhaps anything with Audio.h or SerialFlash.h?
ralphrmartin
09-14-2019, 07:54 PM
I have just bought a Teensy 4.0 board, but when I try to select the USB type, it only shows Serial. Is there something wrong with my setup? Or is this a bug in 1.48?
(This is on Mac OS 10.14.6, with Arduino 1.8.10)
bicycleguy
09-14-2019, 08:05 PM
ralphrmartin
That is what's available now with Teensy 4.0.
FYI, 1.48 is Beta software, ie not ready for prime time. If your just starting with this you may want to go back to Arduino 1.8.9 and Teensyduino 1.47. Typically Beta software takes 8 to 9 revisions to become stable.
ralphrmartin
09-14-2019, 08:07 PM
Oh? Where's that documented? I bought this device for its USB capabilities. :(
bicycleguy
09-14-2019, 08:12 PM
That 'Serial' means serial over USB I think. You still use the serial port. Perhaps you need to press the button on the Teensy to get it to show up in the ports for the 1st time per the instructions.
ralphrmartin
09-14-2019, 08:19 PM
That's not quite what I meant. I want to use USB for other things than serial...
defragster
09-14-2019, 08:47 PM
Using a Teensy 3.2, 3.5, 3.6 to prototype you can start working immediately - Teensy 4.0 support will arrive ASAP and should be expected to be compatible when complete.
At this time Teensy 4.0 hardware is 'Serial Only' just out of Beta and into production and given the choice of 'Perfect function' or 'Usable Hardware' - Usable hardware has to come first or the software can't be perfected. Hardware was great in Beta and refined to be production ready - at which point getting them made and out to a general audience took precedence - along with resolving critical support issues. Also dealing with external changes like New builds and changes to Arduino IDE itself.
So at this time 'Serial' for USB connect is the only supported T4 interface - and it runs at 480 Mbps - up from 12 Mbps and that causes IDE faults and issues already that are being addressed to minimize IDE Crashes and code loss or system instability.
Paul has noted as fast as the T4 presents to the PC now - it has significant room to speed up when the USB stack is updated to be faster and when support for the other interfaces will be presented. So building and extending the current system on an unstable base doesn't make sense.
ralphrmartin
09-14-2019, 08:51 PM
It would have been helpful for this to be made clear somewhere in the sales / announcement pages (with a statement of what is ready now and full support for the rest will be coming later etc .) I feel I have been a bit misled. The earlier Teensy models don't have enough CPU power for my project (processing ultrasonics). Fortunately, my project is not time critical...
DaQue
09-14-2019, 09:17 PM
17593
10 minutes? does the screen/power saver kick in then?
Theremingenieur
09-14-2019, 09:27 PM
No, it was running on external power supply and the mouse pointer in the top left corner to prevent the power saver to kick in. I know how to do a software test setup.
DaQue
09-14-2019, 09:47 PM
That's cool, I don't. I should have added something about me being newebish...
wwatson
09-15-2019, 02:55 AM
@Paul @mjs513 @defragster
I don't know if this is relevant but when I hover the mouse pointer outside of the Arduino IDE or serial monitor the output of the serial monitor slows down and is erratic.
If I hover the mouse pointer over the Arduino IDE window or serial monitor window the output smooths out and is fairly steady.
Here is the modified HelloWorld.pde sketch I am using with T36:
/* Serial Monitor Example, Teensyduino Tutorial #3
http://www.pjrc.com/teensy/tutorial3.html
After uploading this to your board, use Serial Monitor
to view the message. When Serial is selected from the
Tools > USB Type menu, the correct serial port must be
selected from the Tools > Serial Port AFTER Teensy is
running this code. Teensy only becomes a serial device
while this code is running! For non-Serial types,
the Serial port is emulated, so no port needs to be
selected.
uint32_t i=0;
while(!Serial);
Serial.print(i++, DEC);
Serial.println(" - Hello World");
delay(1);
Here is the modified HelloWorld.pde sketch I am using with T4:
selected.
uint32_t i=0;
while(!Serial);
delay(2);
This is with Arduino 1.8.9 TD 1.48 B1 running under Ubuntu 18.04 64Bit and Mate 1.20.1.
The effects change with changing the delay speeds. It seems worse with Arduino 1.8.10.
I can't test this on Windows or a MAC.
This is just a curious observation:)
rew
09-17-2019, 08:32 PM
None of my projects is made to flood the Serial monitor with so much data and Id guess that most other real world projects do neither. To me, it looks rather like an academic thing...
I don't agree. Sometimes you have a "hard" problem that requires printing a lot of debug info. It would be very annoying if the debugging sometimes "broke" making finding the real problem even more difficult. Such bugs should be squashed whenever possible.
PaulStoffregen
09-17-2019, 08:53 PM
This is a Linux thing. Or maybe just Ubuntu? I'm not sure, but I can tell you I also see it on Ubuntu 18.04, I didn't notice on older Ubuntu, and it does not happen on Windows and Macintosh.
On at least Ubuntu 18 this seems to be a "feature" that windows without keyboard focus aren't updated as often. Maybe it's meant to save power on laptops? I did some testing on this quite a while back. Teensy is definitely still sending at the same speed and Arduino is still doing everything the same way. Something on the Linux (maybe X11 or its window manager) is changing the updates.
wwatson
09-18-2019, 02:21 AM
@Paul
I was not trying to complain:) As far as I am concerned it is not a problem at least for me. I was making an observation hoping that it would contribute. Then I read your blog. Very humbling to see the effort that you put into Arduino and all of the the components we use as I admire the talent of all the the members of this forum and there contributions. I primarly use the Serial Monitor to find my programming mess up's NOT speedy data printing. So for me it does not matter.
Thanks Paul.
defragster
09-18-2019, 05:36 AM
I hadn't read the BLOG - @wwatson - thanks for hinting to look for this :: pjrc.com/improving-arduino-serial-monitor-performance/ (https://www.pjrc.com/improving-arduino-serial-monitor-performance/)
And also that is an interesting observation - Indeed I haven't seen such behavior from Windows from SerMon. I know one thing I wrote when the mouse wasn't in the same place between messages the code backed off, and the same codebase another disk tool author made wiggling the mouse in the window have it run more intensely.
dukeblue219
09-19-2019, 01:34 AM
But I must say that I personally do not see that serial monitor stalling as an important issue. None of my projects is made to flood the Serial monitor with so much data and Id guess that most other real world projects do neither. To me, it looks rather like an academic thing...
For many people it is, but even then, the program should still work without crashing. I, however, could easily generate 50MB/s of serial data to a PC, though I'm not able to get that on the USBHS implementation. I recall that I'm seeing around 7MB/s right now on T4. I use a Python GUI to log it all at that speed using multiple threads (uses like 2% CPU). But from time to time I need to use the Arduino monitor to quickly debug and I hate that it will quickly crash the thing if I turn on a data stream. Fixing it will be very appreciated.
PaulStoffregen
09-19-2019, 07:08 AM
The serial monitor stopping after several minutes on Macintosh definitely is a bug. I will eventually fix it. The important question right now is whether to hold off releasing 1.48. My feeling is even with this unfortunate bug, overall the serial monitor speed & stability is a huge improvement compared to 1.47 where Java quickly runs out of memory.
Yup, that sounds about right. So far I've not put a lot of optimization into the Teensy side, since the serial monitor was causing Java to run out of memory at even this speed.
I'm just 1 guy. I have to prioritize my engineering time. My decision to improve the Arduino side first doesn't mean we're forever going to be stuck with 15% of the theoretical maximum speed. I can and I will optimize it to be able to run much faster.
Whether it will ever get to 50 Mbyte/sec is unknown. That pretty close to the theoretical maximum bulk endpoint maximum with 480 Mbit/sec USB.
For comparison, with Teensy 3.2 we get about 1.0 to 1.1 Mbyte/sec. The theoretical max is 1.2 Mbyte/sec.
Any chance you might share this Python GUI (or a stripped down version) for the sake of performance testing?
Well yeah, that's what this new beta version is about, improving the serial monitor so Java does run out of memory and crash. And also Arduino 1.8.10 support.
PaulStoffregen
09-19-2019, 07:19 AM
Yup, I broke the show timestamp feature.
Yes. The speedup work required replacing the normal serial monitor code structure with something that avoids making several copies of the high speed data passing between abstraction layers. One of those layers implemented the timestamp.
To get the timestamps working again, I basically have to reimplement it all over again inside Teensy's optimized version...
defragster
09-19-2019, 07:45 AM
Paul - reading the SerMon blogpost - good notes - lots of good work - glad I could help that progress.
One more thing from reading that: I don't suppose it would be trivial to create and make active a second background "10,000,000 character buffer, and a maximum of 1,000,000 lines" when the user sets Autoscroll to off and that free bufferspace fills?
Having the buffer Freeze for review copy/paste is awesome - especially when the incoming spew is so fast but important enough to stop and look.
This could somewhat but not perfectly emulate current SerMon behavior when that buffer over flows - and would result in total discard of the 'frozen' data when the 'Autoscroll' resumed if the FIFO buffer filled - and temporarily could cost 10 MB - but might make someone's day.
dukeblue219
09-19-2019, 01:32 PM
Understood. I have no complaints as it is right now. Certainly if I needed a fixed high-bandwidth solution an FPGA would be a more logical choice, with more headaches for me. I really appreciate the several-x increase in Teensy-to-PC throughput from 3.6 to 4.0.
That pretty much matches my experience as well.
Sure. It's just a little Python3 with QT5. I probably can't share it publicly today, though. It's not proprietary by any means, but the work was done while working for the US Govt, which means I need to clear it for release (but it also means the taxpayers are entitled to it). Can I share it with you (and select others) directly?
bicycleguy
09-20-2019, 04:52 AM
Aside from the monitor speed stuff, on Mac 10.14.6 I've had several issues with programs compiling and or running differently between Arduino 1.8.10-TD1.48B1 and 1.8.9-TD1.47, on both T4 and T3.6. I got tired of trying to figure it out and just assumed you and others would move on to 1.48beta 2 so I went back to 1.8.9 & TD1.47. If your really looking to release 1.48 I can try to post something. My problems did seem to be more Arduino 1.8.10 or library related.
defragster
09-20-2019, 05:14 AM
Anything you can show as a problem is important.
The update to 1.48 was presented in short order to support IDE 1.8.10. Some few changes expected to be good had been introduced since the release of 1.47. Paul spent free time not getting boards built/tested/packed/shipped trying to assure the SerMon would not choke and crash the IDE given 7X higher speed Teensy USB output.
So any indications of bad or broken behavior can only be fixed given details and perhaps repro steps. What things are involved in not working the same? Even knowing if it is with a particular device or library could identify changes from the 1.47 release.
bicycleguy
09-20-2019, 04:21 PM
Here's an example of an issue. In the screenshot you can see I have selected T4 and yet it has used Arduino libraries instead of Teensy. This results in T4 crash. This code works fine with 1.8.9-TD1.47
17649
the code:
#define MYVERSION_STUFF "myT4WavDisplay, 2019/9/14"
/* Simple WAV file player example from WaveFilePlayer
* mdr20190902 After installing 100 ohm resistor from T4 pin13 to audio board pin14 this will play but only after having played
* 'myT4_DemoSauce' first, and then load and run. Won't work from just plugging in. fixed, just have to add tft.begin(); to
* make it work. Don't need all the IOMUX stuff.
#include "ILI9341_t3.h"
#include "font_Arial.h"
//#include <Wire.h>
#include <SerialFlash.h>
// Use these with the Teensy Audio Shield and Teesny 4.0 mdr20190823
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 11
#define SDCARD_SCK_PIN 13
// TFT pins
const uint8_t TFT_DC = 5;
const uint8_t TFT_CS = 9;
AudioPlaySdWav playWav1;
// Use one of these 3 output types: Digital I2S, Digital S/PDIF, or Analog DAC
AudioOutputI2S audioOutput;
//AudioOutputSPDIF audioOutput;
//AudioOutputAnalog audioOutput;
AudioConnection patchCord1(playWav1, 0, audioOutput, 0);
AudioConnection patchCord2(playWav1, 1, audioOutput, 1);
tft.begin(); //this seems to make the audio work
tft.setRotation( 1 );
// Serial
if( true ) {
Serial.begin( 9600 );
tft.setTextColor(ILI9341_YELLOW);
tft.setFont(Arial_18);
tft.setCursor(10, 42);
tft.print(MYVERSION_STUFF);
tft.setTextColor(ILI9341_GREEN);
while (!Serial && millis() < 5000) { // wait for Arduino Serial Monitor
tft.fillRect(118, 182, 42, 18, ILI9341_BLACK);
tft.setCursor(118, 182);
tft.print((5000.0 - (float)millis()) / 1000.0, 1);
tft.print(" sec");
Serial.println(MYVERSION_STUFF);
//Serial.begin(9600);
// Audio connections require memory to work. For more
AudioMemory(8);
// Comment these out if not using the audio adaptor board.
// This may wait forever if the SDA & SCL pins lack
// pullup resistors
sgtl5000_1.enable();
sgtl5000_1.volume(0.4);
//mdr20190828
//from: https://forum.pjrc.com/threads/57167-Teensy-4-0-I2S-Support?p=213128&viewfull=1#post213128
// defaults were all 0x10B0 which is keeper, Medium speed (100 Mhz), drive strength = R0/6 = 150/6 = 25 ohms (the second strongest drive strength available) // My changes were:
//page 658 if nanual
IOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_00 = 0x1F808; // SCL, pullup at 22K, open drain enable, low speed, drive strength at R0 (150 ohm)
IOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_01 = 0x1F808; // SDA
IOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_09 = 0x8; // MCLK, low speed, drive strength at R0 (150 ohm).
IOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_10 = 0x8; // BCLK
IOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_11 = 0x8; // LRCLK
IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_01 = 0x8; // OUT1A
IOMUXC_SW_PAD_CTL_PAD_GPIO_B0_02 = 0x8; // MOSI mdr20190828 helped get to SDTEST1.WAV & SDTEST2.WAV test
IOMUXC_SW_PAD_CTL_PAD_GPIO_B0_03 = 0x8; // SCK mdr20190828 reqd in myT4_SdCardTest
IOMUXC_SW_PAD_CTL_PAD_GPIO_B0_01 = 0x10000; //MISO mdr20190831 hysterisus+default for WavFilePlayer
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
// stop here, but print a message repetitively
while (1) {
void playFile(const char *filename)
Serial.print("Playing file: ");
Serial.print(filename);
Serial.print(" ");
//* this stuff was to find file length to count down time, better way below
String s = String(filename);
String s2 = String('/' + s);
char buf[20];
s2.toCharArray(buf, s2.length()+1);
File thefile = SD.open(buf);
long crap=thefile.size();
thefile.close();
Serial.print(" size=");
Serial.print(crap);
Serial.print(" ");
tft.setFont(Arial_24);
tft.setCursor(10, 80);
tft.print(filename);
// Start playing the file. This sketch continues to
// run while the file plays.
playWav1.play(filename);
// A brief delay for the library read WAV info
delay(5);
long thelength=playWav1.lengthMillis();
Serial.print((float)(thelength/1000.0), 1);
Serial.println(" seconds");
// Simply wait for the file to finish playing.
while (playWav1.isPlaying()) {
tft.fillRect(118, 182, 62, 18, ILI9341_BLACK);
tft.print((float)(thelength-playWav1.positionMillis()) / 1000.0, 1);
tft.print(" sec");
// uncomment these lines if you audio shield
// has the optional volume pot soldered
//float vol = analogRead(15);
//vol = vol / 1024;
// sgtl5000_1.volume(vol);
playFile("SDTEST1.WAV"); // filenames are always uppercase 8.3 format
playFile("SDTEST2.WAV");
playFile("SDTEST3.WAV");
playFile("SDTEST4.WAV");
delay(1500);
/* output:
myT4WavDisplay, 2019/9/2
11:08:05.035 -> Playing file: SDTEST1.WAV size=16787550 95.2
11:09:40.847 -> Playing file: SDTEST2.WAV size=16425698 93.2
11:11:14.623 -> Playing file: SDTEST3.WAV size=13617358 77.2
11:12:32.401 -> Playing file: SDTEST4.WAV size=17173152 97.4
11:14:11.342 -> Playing file: SDTEST1.WAV size=16787550 95.2
11:15:47.128 -> Playing file: SDTEST2.WAV size=16425698
Playing file: SDTEST1.WAV 95.2 seconds
Playing file: SDTEST2.WAV 93.1 seconds
Playing file: SDTEST3.WAV 77.2 seconds
Playing file: SDTEST4.WAV 97.4 seconds
mjs513
09-20-2019, 05:26 PM
@bicycleguy
I just checked my install of IDE 1.8.10 and TD1.48B1. Teensy libraries do show for me when I have the T4 selected. Know this is an obvious one but you did install the Teensy Libraries when you installed 1.8.10/1.48B1. I am on a windows10x64 machine
bicycleguy
09-20-2019, 05:41 PM
here's the console output from blink.ini which works:
/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware -hardware /Users/michaelrunyan/Library/Arduino15/packages -tools /Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/tools-builder -tools /Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/tools/avr -tools /Users/michaelrunyan/Library/Arduino15/packages -built-in-libraries /Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/libraries -libraries /Users/michaelrunyan/Documents/Arduino/libraries -fqbn=teensy:avr:teensy40:usb=serial,opt=o2std,keys =en-us -ide-version=10810 -build-path /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684 -warnings=default -build-cache /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_cache_770757 -verbose /Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/examples/01.Basics/Blink/Blink.ino
/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware -hardware /Users/michaelrunyan/Library/Arduino15/packages -tools /Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/tools-builder -tools /Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/tools/avr -tools /Users/michaelrunyan/Library/Arduino15/packages -built-in-libraries /Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/libraries -libraries /Users/michaelrunyan/Documents/Arduino/libraries -fqbn=teensy:avr:teensy40:usb=serial,opt=o2std,keys =en-us -ide-version=10810 -build-path /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684 -warnings=default -build-cache /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_cache_770757 -verbose /Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/examples/01.Basics/Blink/Blink.ino
Using board 'teensy40' from platform in folder: /Applications/Arduino
Using core 'teensy4' from platform in folder: /Applications/Arduino
Detecting libraries used...
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684/sketch/Blink.ino.cpp -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684/sketch/Blink.ino.cpp -o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684/preproc/ctags_target_for_gcc_minus_e.cpp
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/precompile_helper" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684 "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684/pch/Arduino.h -o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684/pch/Arduino.h.gch
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684/pch/Arduino.h.gch
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684/pch "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684/sketch/Blink.ino.cpp -o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684/sketch/Blink.ino.cpp.o
Compiling libraries...
Compiling core...
Using precompiled core: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_cache_770757/core/core_teensy_avr_teensy40_usb_serial,opt_o2std,keys _en-us_43d7487000cdf9b723b9ed9d5bc4d576.a
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax "-T/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4/imxrt1062.ld" -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684/Blink.ino.elf /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684/sketch/Blink.ino.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684/../arduino_cache_770757/core/core_teensy_avr_teensy40_usb_serial,opt_o2std,keys _en-us_43d7487000cdf9b723b9ed9d5bc4d576.a -L/var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684 -larm_cortexM7lfsp_math -lm -lstdc++
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684/Blink.ino.elf /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684/Blink.ino.eep
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684/Blink.ino.elf /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684/Blink.ino.hex
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/stdout_redirect" /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684/Blink.ino.lst "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objdump" -d -S -C /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684/Blink.ino.elf
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/stdout_redirect" /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684/Blink.ino.sym "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objdump" -t -C /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684/Blink.ino.elf
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/teensy_post_compile" -file=Blink.ino -path=/var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684 "-tools=/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/" -board=TEENSY40
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-size" -A /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_335684/Blink.ino.elf
Sketch uses 12160 bytes (0%) of program storage space. Maximum is 2031616 bytes.
Global variables use 18528 bytes (1%) of dynamic memory, leaving 1030048 bytes for local variables. Maximum is 1048576 bytes.
bicycleguy
09-20-2019, 05:42 PM
and here's the output from above in same setup which crashes the T4:
/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware -hardware /Users/michaelrunyan/Library/Arduino15/packages -tools /Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/tools-builder -tools /Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/tools/avr -tools /Users/michaelrunyan/Library/Arduino15/packages -built-in-libraries /Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/libraries -libraries /Users/michaelrunyan/Documents/Arduino/libraries -fqbn=teensy:avr:teensy40:usb=serial,opt=o2std,keys =en-us -ide-version=10810 -build-path /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491 -warnings=default -build-cache /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_cache_770757 -verbose /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_modified_sketch_927305/myT4WavDisplay.ino
/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware -hardware /Users/michaelrunyan/Library/Arduino15/packages -tools /Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/tools-builder -tools /Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/tools/avr -tools /Users/michaelrunyan/Library/Arduino15/packages -built-in-libraries /Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/libraries -libraries /Users/michaelrunyan/Documents/Arduino/libraries -fqbn=teensy:avr:teensy40:usb=serial,opt=o2std,keys =en-us -ide-version=10810 -build-path /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491 -warnings=default -build-cache /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_cache_770757 -verbose /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_modified_sketch_927305/myT4WavDisplay.ino
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/sketch/myT4WavDisplay.ino.cpp -o /dev/null
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/sketch/myT4WavDisplay.ino.cpp -o /dev/null
Alternatives for SD.h: [SD@1.2.3 SD@1.2.2]
ResolveLibrary(SD.h)
-> candidates: [SD@1.2.3 SD@1.2.2]
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/sketch/myT4WavDisplay.ino.cpp -o /dev/null
Alternatives for ILI9341_t3.h: [ILI9341_t3@1.0]
ResolveLibrary(ILI9341_t3.h)
-> candidates: [ILI9341_t3@1.0]
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/sketch/myT4WavDisplay.ino.cpp -o /dev/null
Alternatives for SerialFlash.h: [SerialFlash@0.5]
ResolveLibrary(SerialFlash.h)
-> candidates: [SerialFlash@0.5]
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/sketch/myT4WavDisplay.ino.cpp -o /dev/null
Alternatives for Audio.h: [Audio@1.3]
ResolveLibrary(Audio.h)
-> candidates: [Audio@1.3]
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/sketch/myT4WavDisplay.ino.cpp -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI/SPI.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/File.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/SD.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/cache_t3.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/card_t3.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/dir_t3.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/fat_t3.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/file_t3.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/init_t3.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility/NXP_SDHC.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility/Sd2Card.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility/SdFile.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility/SdVolume.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3/ILI9341_t3.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3/font_Arial.c" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3/font_ArialBold.c" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3/glcdfont.c" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash/SerialFlashChip.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash/SerialFlashDirectory.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_fft1024.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_fft256.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_notefreq.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_peak.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_print.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_rms.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_tonedetect.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_ak4558.cpp" -o /dev/null
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_ak4558.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_cs42448.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_cs4272.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_sgtl5000.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_tlv320aic3206.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_wm8731.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/data_spdif.c" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/data_ulaw.c" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/data_waveforms.c" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/data_windows.c" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_bitcrusher.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_chorus.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_combine.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_delay.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_delay_ext.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_envelope.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_fade.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_flange.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_freeverb.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_granular.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_midside.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_multiply.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_reverb.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_waveshaper.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/filter_biquad.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/filter_fir.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/filter_variable.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_adc.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_adcs.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_i2s.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_i2s2.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_i2s_quad.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_pdm.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_tdm.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_tdm2.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/memcpy_audio.S" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/mixer.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_adat.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_dac.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_dacs.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_i2s.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_i2s2.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_i2s_quad.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_mqs.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_pt8211.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_pt8211_2.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_pwm.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_spdif.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_spdif2.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_spdif3.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_tdm.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_tdm2.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/play_memory.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/play_queue.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/play_sd_raw.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/play_sd_wav.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/play_serialflash_raw.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/record_queue.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/spi_interrupt.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_dc.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_karplusstrong.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_pinknoise.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_pwm.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_simple_drum.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_sine.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_tonesweep.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_waveform.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_wavetable.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_whitenoise.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility/imxrt_hw.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility/sqrt_integer.c" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire/Wire.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireKinetis.cpp" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire/utility" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire/utility/twi.c" -o /dev/null
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/sketch/myT4WavDisplay.ino.cpp -o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/preproc/ctags_target_for_gcc_minus_e.cpp
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/precompile_helper" "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491 "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/pch/Arduino.h -o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/pch/Arduino.h.gch
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/pch/Arduino.h.gch
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/pch "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/libraries/Wire" /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/sketch/myT4WavDisplay.ino.cpp -o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/sketch/myT4WavDisplay.ino.cpp.o
Compiling libraries...
Compiling library "SPI"
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SPI/SPI.cpp.o
Compiling library "SD"
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/card_t3.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/cache_t3.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/dir_t3.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/fat_t3.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/File.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/file_t3.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/SD.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/init_t3.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/utility/Sd2Card.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/utility/NXP_SDHC.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/utility/SdFile.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/utility/SdVolume.cpp.o
Compiling library "ILI9341_t3"
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/ILI9341_t3/font_ArialBold.c.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/ILI9341_t3/font_Arial.c.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/ILI9341_t3/glcdfont.c.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/ILI9341_t3/ILI9341_t3.cpp.o
Compiling library "SerialFlash"
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SerialFlash/SerialFlashChip.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SerialFlash/SerialFlashDirectory.cpp.o
Compiling library "Audio"
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/memcpy_audio.S.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/data_spdif.c.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/data_ulaw.c.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/data_windows.c.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/data_waveforms.c.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/analyze_fft1024.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/analyze_fft256.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/analyze_notefreq.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/analyze_peak.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/analyze_rms.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/analyze_print.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/analyze_tonedetect.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/control_ak4558.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/control_cs42448.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/control_cs4272.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/control_sgtl5000.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/control_wm8731.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_bitcrusher.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_chorus.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/control_tlv320aic3206.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_combine.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_delay.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_delay_ext.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_envelope.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_fade.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_flange.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_freeverb.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_granular.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_midside.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_multiply.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_waveshaper.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_reverb.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/filter_biquad.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/filter_fir.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/filter_variable.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/input_adc.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/input_adcs.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/input_i2s.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/input_i2s_quad.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/input_pdm.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/input_i2s2.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/input_tdm2.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/input_tdm.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/mixer.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_adat.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_dac.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_dacs.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_i2s.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_i2s2.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_mqs.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_i2s_quad.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_pt8211.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_pt8211_2.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_pwm.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_spdif.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_spdif2.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_spdif3.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_tdm.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_tdm2.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/play_memory.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/play_queue.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/record_queue.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/play_serialflash_raw.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/play_sd_raw.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/play_sd_wav.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/synth_dc.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/spi_interrupt.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/synth_karplusstrong.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/synth_pinknoise.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/synth_simple_drum.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/synth_pwm.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/synth_sine.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/synth_tonesweep.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/synth_waveform.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/synth_whitenoise.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/synth_wavetable.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/utility/sqrt_integer.c.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/utility/imxrt_hw.cpp.o
Compiling library "Wire"
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Wire/WireKinetis.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Wire/Wire.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Wire/WireIMXRT.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Wire/utility/twi.c.o
Compiling core...
Using precompiled core: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_cache_770757/core/core_teensy_avr_teensy40_usb_serial,opt_o2std,keys _en-us_43d7487000cdf9b723b9ed9d5bc4d576.a
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax "-T/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/avr/cores/teensy4/imxrt1062.ld" -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/myT4WavDisplay.ino.elf /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/sketch/myT4WavDisplay.ino.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SPI/SPI.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/File.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/SD.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/cache_t3.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/card_t3.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/dir_t3.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/fat_t3.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/file_t3.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/init_t3.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/utility/NXP_SDHC.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/utility/Sd2Card.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/utility/SdFile.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SD/utility/SdVolume.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/ILI9341_t3/font_Arial.c.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/ILI9341_t3/font_ArialBold.c.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/ILI9341_t3/glcdfont.c.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/ILI9341_t3/ILI9341_t3.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SerialFlash/SerialFlashChip.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/SerialFlash/SerialFlashDirectory.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/memcpy_audio.S.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/data_spdif.c.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/data_ulaw.c.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/data_waveforms.c.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/data_windows.c.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/analyze_fft1024.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/analyze_fft256.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/analyze_notefreq.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/analyze_peak.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/analyze_print.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/analyze_rms.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/analyze_tonedetect.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/control_ak4558.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/control_cs42448.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/control_cs4272.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/control_sgtl5000.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/control_tlv320aic3206.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/control_wm8731.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_bitcrusher.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_chorus.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_combine.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_delay.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_delay_ext.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_envelope.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_fade.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_flange.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_freeverb.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_granular.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_midside.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_multiply.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_reverb.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/effect_waveshaper.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/filter_biquad.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/filter_fir.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/filter_variable.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/input_adc.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/input_adcs.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/input_i2s.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/input_i2s2.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/input_i2s_quad.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/input_pdm.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/input_tdm.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/input_tdm2.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/mixer.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_adat.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_dac.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_dacs.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_i2s.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_i2s2.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_i2s_quad.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_mqs.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_pt8211.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_pt8211_2.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_pwm.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_spdif.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_spdif2.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_spdif3.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_tdm.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/output_tdm2.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/play_memory.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/play_queue.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/play_sd_raw.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/play_sd_wav.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/play_serialflash_raw.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/record_queue.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/spi_interrupt.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/synth_dc.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/synth_karplusstrong.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/synth_pinknoise.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/synth_pwm.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/synth_simple_drum.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/synth_sine.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/synth_tonesweep.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/synth_waveform.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/synth_wavetable.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/synth_whitenoise.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/utility/sqrt_integer.c.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Audio/utility/imxrt_hw.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Wire/Wire.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Wire/WireIMXRT.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Wire/WireKinetis.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/libraries/Wire/utility/twi.c.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/../arduino_cache_770757/core/core_teensy_avr_teensy40_usb_serial,opt_o2std,keys _en-us_43d7487000cdf9b723b9ed9d5bc4d576.a -L/var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491 -larm_cortexM7lfsp_math -lm -lstdc++
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/myT4WavDisplay.ino.elf /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/myT4WavDisplay.ino.eep
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/myT4WavDisplay.ino.elf /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/myT4WavDisplay.ino.hex
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/stdout_redirect" /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/myT4WavDisplay.ino.lst "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objdump" -d -S -C /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/myT4WavDisplay.ino.elf
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/stdout_redirect" /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/myT4WavDisplay.ino.sym "/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objdump" -t -C /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/myT4WavDisplay.ino.elf
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/teensy_post_compile" -file=myT4WavDisplay.ino -path=/var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491 "-tools=/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/" -board=TEENSY40
Multiple libraries were found for "SD.h"
Used: /Applications/Arduino
Not used: /Applications/Arduino
Multiple libraries were found for "ILI9341_t3.h"
Multiple libraries were found for "SerialFlash.h"
Multiple libraries were found for "Audio.h"
Multiple libraries were found for "Wire.h"
Multiple libraries were found for "SPI.h"
Using library SPI at version 1.0 in folder: /Applications/Arduino other
Using library SD at version 1.2.2 in folder: /Applications/Arduino other
Using library ILI9341_t3 at version 1.0 in folder: /Applications/Arduino other
Using library SerialFlash at version 0.5 in folder: /Applications/Arduino other
Using library Audio at version 1.3 in folder: /Applications/Arduino other
Using library Wire at version 1.0 in folder: /Applications/Arduino other
"/Applications/Arduino other versions/Arduino_1_8_10.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-size" -A /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_676491/myT4WavDisplay.ino.elf
Sketch uses 52976 bytes (2%) of program storage space. Maximum is 2031616 bytes.
Global variables use 60240 bytes (5%) of dynamic memory, leaving 988336 bytes for local variables. Maximum is 1048576 bytes.
bicycleguy
09-20-2019, 05:50 PM
@bicycleguy
I just checked my install of IDE 1.8.10 and TD1.48B1. Teensy libraries do show for me when I have the T4 selected. Know this is an obvious one but you did install the Teensy Libraries when you installed 1.8.10/1.48B1. I am on a windows10x64 machine
Yes, I installed all the libraries. However, looking at the Arduino file size its only 599MB where 1.8.9 is 785.6MB.
Did you try to compile myT4WavDisplay.ino or some other sketch?
mjs513
09-20-2019, 06:27 PM
Something doesn't make sense - know you don't want to here this but how about reinstalling 1.8.10 and 1.48B1?
here is the results of the your sketch with that config:
F:\arduino-1.8.10\arduino-builder -dump-prefs -logger=machine -hardware F:\arduino-1.8.10\hardware -hardware C:\Users\Merli\AppData\Local\Arduino15\packages -tools F:\arduino-1.8.10\tools-builder -tools F:\arduino-1.8.10\hardware\tools\avr -tools C:\Users\Merli\AppData\Local\Arduino15\packages -built-in-libraries F:\arduino-1.8.10\libraries -libraries D:\Users\Merli\Documents\Arduino\libraries -fqbn=teensy:avr:teensy40:usb=serial,opt=o2std,keys =en-us -ide-version=10810 -build-path C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371 -warnings=none -build-cache C:\Users\Merli\AppData\Local\Temp\arduino_cache_43 0563 -verbose D:\Users\Merli\Documents\Arduino\BycleGuytest\Bycl eGuytest.ino
F:\arduino-1.8.10\arduino-builder -compile -logger=machine -hardware F:\arduino-1.8.10\hardware -hardware C:\Users\Merli\AppData\Local\Arduino15\packages -tools F:\arduino-1.8.10\tools-builder -tools F:\arduino-1.8.10\hardware\tools\avr -tools C:\Users\Merli\AppData\Local\Arduino15\packages -built-in-libraries F:\arduino-1.8.10\libraries -libraries D:\Users\Merli\Documents\Arduino\libraries -fqbn=teensy:avr:teensy40:usb=serial,opt=o2std,keys =en-us -ide-version=10810 -build-path C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371 -warnings=none -build-cache C:\Users\Merli\AppData\Local\Temp\arduino_cache_43 0563 -verbose D:\Users\Merli\Documents\Arduino\BycleGuytest\Bycl eGuytest.ino
Using board 'teensy40' from platform in folder: F:\arduino-1.8.10\hardware\teensy\avr
Using core 'teensy4' from platform in folder: F:\arduino-1.8.10\hardware\teensy\avr
Detecting libraries used...
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\sketch\\BycleGuytest.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\sketch\\BycleGuytest.ino.cpp" -o nul
Alternatives for SD.h: [SD@1.2.3 SD@1.2.2]
ResolveLibrary(SD.h)
-> candidates: [SD@1.2.3 SD@1.2.2]
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\sketch\\BycleGuytest.ino.cpp" -o nul
Alternatives for ILI9341_t3.h: [ILI9341_t3@1.0]
ResolveLibrary(ILI9341_t3.h)
-> candidates: [ILI9341_t3@1.0]
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\sketch\\BycleGuytest.ino.cpp" -o nul
Alternatives for SerialFlash.h: [SerialFlash-master@0.5 SerialFlash@0.5]
ResolveLibrary(SerialFlash.h)
-> candidates: [SerialFlash-master@0.5 SerialFlash@0.5]
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\sketch\\BycleGuytest.ino.cpp" -o nul
Alternatives for Audio.h: [Audio@1.3]
ResolveLibrary(Audio.h)
-> candidates: [Audio@1.3]
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\sketch\\BycleGuytest.ino.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI\\SPI .cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\util ity" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\File .cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\util ity" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\SD.c pp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\util ity" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\cach e_t3.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\util ity" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\card _t3.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\util ity" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\dir_ t3.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\util ity" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\fat_ t3.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\util ity" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\file _t3.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\util ity" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\init _t3.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\util ity" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\util ity\\NXP_SDHC.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\util ity" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\util ity\\Sd2Card.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\util ity" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\util ity\\SdFile.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\util ity" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD\\util ity\\SdVolume.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3\\ILI9341_t3.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3\\font_Arial.c" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3\\font_ArialBold.c" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3\\glcdfont.c" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash\\SerialFlashChip.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash\\SerialFlashDirectory.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\a nalyze_fft1024.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\a nalyze_fft256.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\a nalyze_notefreq.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\a nalyze_peak.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\a nalyze_print.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\a nalyze_rms.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\a nalyze_tonedetect.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\c ontrol_ak4558.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\c ontrol_ak4558.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\c ontrol_cs42448.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\c ontrol_cs4272.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\c ontrol_sgtl5000.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\c ontrol_tlv320aic3206.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\c ontrol_wm8731.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\d ata_spdif.c" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\d ata_ulaw.c" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\d ata_waveforms.c" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\d ata_windows.c" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\e ffect_bitcrusher.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\e ffect_chorus.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\e ffect_combine.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\e ffect_delay.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\e ffect_delay_ext.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\e ffect_envelope.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\e ffect_fade.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\e ffect_flange.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\e ffect_freeverb.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\e ffect_granular.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\e ffect_midside.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\e ffect_multiply.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\e ffect_reverb.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\e ffect_waveshaper.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\f ilter_biquad.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\f ilter_fir.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\f ilter_variable.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\i nput_adc.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\i nput_adcs.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\i nput_i2s.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\i nput_i2s2.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\i nput_i2s_quad.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\i nput_pdm.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\i nput_tdm.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\i nput_tdm2.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\m emcpy_audio.S" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\m ixer.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\o utput_adat.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\o utput_dac.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\o utput_dacs.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\o utput_i2s.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\o utput_i2s2.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\o utput_i2s_quad.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\o utput_mqs.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\o utput_pt8211.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\o utput_pt8211_2.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\o utput_pwm.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\o utput_spdif.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\o utput_spdif2.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\o utput_spdif3.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\o utput_tdm.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\o utput_tdm2.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\p lay_memory.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\p lay_queue.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\p lay_sd_raw.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\p lay_sd_wav.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\p lay_serialflash_raw.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\r ecord_queue.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\s pi_interrupt.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\s ynth_dc.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\s ynth_karplusstrong.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\s ynth_pinknoise.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\s ynth_pwm.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\s ynth_simple_drum.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\s ynth_sine.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\s ynth_tonesweep.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\s ynth_waveform.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\s ynth_wavetable.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\s ynth_whitenoise.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility\\imxrt_hw.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio\\u tility\\sqrt_integer.c" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire\\ut ility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire\\Wi re.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire\\ut ility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire\\Wi reIMXRT.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire\\ut ility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire\\Wi reKinetis.cpp" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire\\ut ility" "F:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire\\ut ility\\twi.c" -o nul
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\sketch\\BycleGuytest.ino.cpp" -o "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\preproc\\ctags_target_for_gcc_minus_e. cpp"
"F:\\arduino-1.8.10\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\preproc\\ctags_target_for_gcc_minus_e. cpp"
Compiling sketch...
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/precompile_helper" "F:\\arduino-1.8.10\\hardware\\teensy\\avr/cores/teensy4" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371" "F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr/cores/teensy4" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371/pch/Arduino.h" -o "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371/pch/Arduino.h.gch"
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\pch\Arduino.h.gch
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_b uild_815371/pch" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SPI" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SD" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\ILI9341_ t3" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\SerialFl ash" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Audio" "-IF:\\arduino-1.8.10\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\sketch\\BycleGuytest.ino.cpp" -o "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\sketch\\BycleGuytest.ino.cpp.o"
Compiling libraries...
Compiling library "SPI"
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\SPI\SPI.cpp.o
Compiling library "SD"
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\SD\init_t3.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\SD\cache_t3.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\SD\file_t3.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\SD\fat_t3.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\SD\card_t3.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\SD\dir_t3.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\SD\File.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\SD\SD.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\SD\utility\NXP_SDHC.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\SD\utility\Sd2Card.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\SD\utility\SdFile.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\SD\utility\SdVolume.cpp.o
Compiling library "ILI9341_t3"
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\ILI9341_t3\glcdfont.c.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\ILI9341_t3\font_Arial.c.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\ILI9341_t3\font_ArialBold.c.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\ILI9341_t3\ILI9341_t3.cpp.o
Compiling library "SerialFlash"
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\SerialFlash\SerialFlashChip.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\SerialFlash\SerialFlashDirectory.cp p.o
Compiling library "Audio"
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\memcpy_audio.S.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\data_spdif.c.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\data_ulaw.c.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\data_windows.c.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\data_waveforms.c.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\analyze_peak.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\analyze_print.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\control_cs4272.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\control_sgtl5000.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\analyze_fft256.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\analyze_notefreq.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\control_ak4558.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\analyze_rms.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\control_tlv320aic3206.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\analyze_tonedetect.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\effect_bitcrusher.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\control_cs42448.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\effect_chorus.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\control_wm8731.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\effect_combine.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\analyze_fft1024.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\effect_fade.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\effect_envelope.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\effect_delay.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\effect_flange.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\effect_waveshaper.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\effect_granular.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\effect_midside.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\effect_multiply.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\effect_delay_ext.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\effect_freeverb.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\filter_variable.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\filter_biquad.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\filter_fir.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\input_adc.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\effect_reverb.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\input_adcs.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\input_pdm.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\input_i2s2.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\input_i2s_quad.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\mixer.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\input_i2s.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\input_tdm.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\output_dacs.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\output_adat.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\output_i2s.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\input_tdm2.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\output_dac.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\output_spdif.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\output_i2s_quad.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\output_pwm.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\output_spdif2.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\output_i2s2.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\output_mqs.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\output_pt8211_2.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\output_pt8211.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\output_spdif3.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\play_memory.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\output_tdm2.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\output_tdm.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\play_queue.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\spi_interrupt.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\record_queue.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\play_sd_raw.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\synth_pwm.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\synth_dc.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\play_sd_wav.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\synth_karplusstrong.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\synth_sine.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\play_serialflash_raw.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\synth_simple_drum.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\synth_tonesweep.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\synth_pinknoise.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\synth_whitenoise.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\synth_waveform.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\synth_wavetable.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\utility\sqrt_integer.c.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Audio\utility\imxrt_hw.cpp.o
Compiling library "Wire"
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Wire\Wire.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Wire\WireKinetis.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Wire\WireIMXRT.cpp.o
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_81 5371\libraries\Wire\utility\twi.c.o
Compiling core...
Using precompiled core: C:\Users\Merli\AppData\Local\Temp\arduino_cache_43 0563\core\core_teensy_avr_teensy40_usb_serial,opt_ o2std,keys_en-us_fb7005aa833c1e73caa59a2a6148fc9a.a
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax "-TF:\\arduino-1.8.10\\hardware\\teensy\\avr\\cores\\teensy4/imxrt1062.ld" -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371/BycleGuytest.ino.elf" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\sketch\\BycleGuytest.ino.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\SD\\File.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\SD\\SD.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\SD\\cache_t3.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\SD\\card_t3.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\SD\\dir_t3.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\SD\\fat_t3.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\SD\\file_t3.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\SD\\init_t3.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\SD\\utility\\NXP_SDHC.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\SD\\utility\\Sd2Card.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\SD\\utility\\SdFile.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\SD\\utility\\SdVolume.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\ILI9341_t3\\font_Arial.c.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\ILI9341_t3\\font_ArialBold. c.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\ILI9341_t3\\glcdfont.c.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\ILI9341_t3\\ILI9341_t3.cpp. o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\SerialFlash\\SerialFlashChi p.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\SerialFlash\\SerialFlashDir ectory.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\memcpy_audio.S.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\data_spdif.c.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\data_ulaw.c.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\data_waveforms.c.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\data_windows.c.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\analyze_fft1024.cpp. o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\analyze_fft256.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\analyze_notefreq.cpp .o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\analyze_peak.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\analyze_print.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\analyze_rms.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\analyze_tonedetect.c pp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\control_ak4558.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\control_cs42448.cpp. o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\control_cs4272.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\control_sgtl5000.cpp .o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\control_tlv320aic320 6.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\control_wm8731.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\effect_bitcrusher.cp p.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\effect_chorus.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\effect_combine.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\effect_delay.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\effect_delay_ext.cpp .o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\effect_envelope.cpp. o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\effect_fade.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\effect_flange.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\effect_freeverb.cpp. o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\effect_granular.cpp. o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\effect_midside.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\effect_multiply.cpp. o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\effect_reverb.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\effect_waveshaper.cp p.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\filter_biquad.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\filter_fir.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\filter_variable.cpp. o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\input_adc.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\input_adcs.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\input_i2s.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\input_i2s2.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\input_i2s_quad.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\input_pdm.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\input_tdm.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\input_tdm2.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\mixer.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\output_adat.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\output_dac.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\output_dacs.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\output_i2s.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\output_i2s2.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\output_i2s_quad.cpp. o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\output_mqs.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\output_pt8211.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\output_pt8211_2.cpp. o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\output_pwm.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\output_spdif.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\output_spdif2.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\output_spdif3.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\output_tdm.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\output_tdm2.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\play_memory.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\play_queue.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\play_sd_raw.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\play_sd_wav.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\play_serialflash_raw .cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\record_queue.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\spi_interrupt.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\synth_dc.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\synth_karplusstrong. cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\synth_pinknoise.cpp. o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\synth_pwm.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\synth_simple_drum.cp p.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\synth_sine.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\synth_tonesweep.cpp. o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\synth_waveform.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\synth_wavetable.cpp. o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\synth_whitenoise.cpp .o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\utility\\sqrt_intege r.c.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Audio\\utility\\imxrt_hw.cp p.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Wire\\WireIMXRT.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Wire\\WireKinetis.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371/..\\arduino_cache_430563\\core\\core_teensy_avr_te ensy40_usb_serial,opt_o2std,keys_en-us_fb7005aa833c1e73caa59a2a6148fc9a.a" "-LC:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_b uild_815371" -larm_cortexM7lfsp_math -lm -lstdc++
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371/BycleGuytest.ino.elf" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371/BycleGuytest.ino.eep"
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371/BycleGuytest.ino.elf" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371/BycleGuytest.ino.hex"
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/stdout_redirect" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371/BycleGuytest.ino.lst" "F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objdump" -d -S -C "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371/BycleGuytest.ino.elf"
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/stdout_redirect" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371/BycleGuytest.ino.sym" "F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objdump" -t -C "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371/BycleGuytest.ino.elf"
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/teensy_post_compile" -file=BycleGuytest.ino "-path=C:\\Users\\Merli\\AppData\\Local\\Temp\\ardui no_build_815371" "-tools=F:\\arduino-1.8.10\\hardware\\teensy/../tools/" -board=TEENSY40
Multiple libraries were found for "Audio.h"
Used: F:\arduino-1.8.10\hardware\teensy\avr\libraries\Audio
Multiple libraries were found for "Wire.h"
Used: F:\arduino-1.8.10\hardware\teensy\avr\libraries\Wire
Multiple libraries were found for "SPI.h"
Used: F:\arduino-1.8.10\hardware\teensy\avr\libraries\SPI
Multiple libraries were found for "SD.h"
Used: F:\arduino-1.8.10\hardware\teensy\avr\libraries\SD
Not used: F:\arduino-1.8.10\libraries\SD
Multiple libraries were found for "ILI9341_t3.h"
Used: F:\arduino-1.8.10\hardware\teensy\avr\libraries\ILI9341_t3
Multiple libraries were found for "SerialFlash.h"
Used: F:\arduino-1.8.10\hardware\teensy\avr\libraries\SerialFlash
Not used: D:\Users\Merli\Documents\Arduino\libraries\SerialF lash-master
Using library SPI at version 1.0 in folder: F:\arduino-1.8.10\hardware\teensy\avr\libraries\SPI
Using library SD at version 1.2.2 in folder: F:\arduino-1.8.10\hardware\teensy\avr\libraries\SD
Using library ILI9341_t3 at version 1.0 in folder: F:\arduino-1.8.10\hardware\teensy\avr\libraries\ILI9341_t3
Using library SerialFlash at version 0.5 in folder: F:\arduino-1.8.10\hardware\teensy\avr\libraries\SerialFlash
Using library Audio at version 1.3 in folder: F:\arduino-1.8.10\hardware\teensy\avr\libraries\Audio
Using library Wire at version 1.0 in folder: F:\arduino-1.8.10\hardware\teensy\avr\libraries\Wire
"F:\\arduino-1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-size" -A "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_815371/BycleGuytest.ino.elf"
Sketch uses 54976 bytes (2%) of program storage space. Maximum is 2031616 bytes.
Global variables use 62224 bytes (5%) of dynamic memory, leaving 986352 bytes for local variables. Maximum is 1048576 bytes.
mjs513
09-20-2019, 06:34 PM
The other thing you can do for sanity is going into the 1.8.10 director navigate to hardware/teensy/avr/libraries and see if there it any in that directory.
bicycleguy
09-20-2019, 06:35 PM
Just re-downloaded and re-installed both. Now Arduino1.8.10 shows a more reasonable 855MB and the library callouts look better
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/michaelrunyan/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/michaelrunyan/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/michaelrunyan/Documents/Arduino/libraries -fqbn=teensy:avr:teensy40:usb=serial,opt=o2std,keys =en-us -vid-pid=0X16C0_0X0483 -ide-version=10810 -build-path /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312 -warnings=default -build-cache /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_cache_542889 -verbose /Users/michaelrunyan/Documents/Arduino/myT4WavDisplay/myT4WavDisplay.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/michaelrunyan/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/michaelrunyan/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/michaelrunyan/Documents/Arduino/libraries -fqbn=teensy:avr:teensy40:usb=serial,opt=o2std,keys =en-us -vid-pid=0X16C0_0X0483 -ide-version=10810 -build-path /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312 -warnings=default -build-cache /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_cache_542889 -verbose /Users/michaelrunyan/Documents/Arduino/myT4WavDisplay/myT4WavDisplay.ino
Using board 'teensy40' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr
Using core 'teensy4' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr
Detecting libraries used...
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/sketch/myT4WavDisplay.ino.cpp -o /dev/null
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/sketch/myT4WavDisplay.ino.cpp -o /dev/null
Alternatives for SD.h: [SD@1.2.3 SD@1.2.2]
ResolveLibrary(SD.h)
-> candidates: [SD@1.2.3 SD@1.2.2]
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/sketch/myT4WavDisplay.ino.cpp -o /dev/null
Alternatives for ILI9341_t3.h: [ILI9341_t3@1.0]
ResolveLibrary(ILI9341_t3.h)
-> candidates: [ILI9341_t3@1.0]
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/sketch/myT4WavDisplay.ino.cpp -o /dev/null
Alternatives for SerialFlash.h: [SerialFlash@0.5]
ResolveLibrary(SerialFlash.h)
-> candidates: [SerialFlash@0.5]
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/sketch/myT4WavDisplay.ino.cpp -o /dev/null
Alternatives for Audio.h: [Audio@1.3]
ResolveLibrary(Audio.h)
-> candidates: [Audio@1.3]
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/sketch/myT4WavDisplay.ino.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI/SPI.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/File.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/SD.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/cache_t3.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/card_t3.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/dir_t3.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/fat_t3.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/file_t3.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/init_t3.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility/NXP_SDHC.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility/Sd2Card.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility/SdFile.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility/SdVolume.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3/ILI9341_t3.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3/font_Arial.c -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3/font_ArialBold.c -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3/glcdfont.c -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash/SerialFlashChip.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash/SerialFlashDirectory.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_fft1024.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_fft256.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_notefreq.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_peak.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_print.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_rms.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_tonedetect.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_ak4558.cpp -o /dev/null
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_ak4558.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_cs42448.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_cs4272.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_sgtl5000.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_tlv320aic3206.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_wm8731.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/data_spdif.c -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/data_ulaw.c -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/data_waveforms.c -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/data_windows.c -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_bitcrusher.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_chorus.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_combine.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_delay.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_delay_ext.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_envelope.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_fade.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_flange.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_freeverb.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_granular.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_midside.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_multiply.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_reverb.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_waveshaper.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/filter_biquad.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/filter_fir.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/filter_variable.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_adc.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_adcs.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_i2s.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_i2s2.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_i2s_quad.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_pdm.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_tdm.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_tdm2.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/memcpy_audio.S -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/mixer.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_adat.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_dac.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_dacs.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_i2s.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_i2s2.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_i2s_quad.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_mqs.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_pt8211.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_pt8211_2.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_pwm.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_spdif.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_spdif2.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_spdif3.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_tdm.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_tdm2.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/play_memory.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/play_queue.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/play_sd_raw.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/play_sd_wav.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/play_serialflash_raw.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/record_queue.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/spi_interrupt.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_dc.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_karplusstrong.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_pinknoise.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_pwm.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_simple_drum.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_sine.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_tonesweep.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_waveform.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_wavetable.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_whitenoise.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility/imxrt_hw.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility/sqrt_integer.c -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/Wire.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireKinetis.cpp -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/utility /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/utility/twi.c -o /dev/null
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/sketch/myT4WavDisplay.ino.cpp -o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/preproc/ctags_target_for_gcc_minus_e.cpp
/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/precompile_helper /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312 /Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/pch/Arduino.h -o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/pch/Arduino.h.gch
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/pch/Arduino.h.gch
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/pch -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3 -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio -I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/sketch/myT4WavDisplay.ino.cpp -o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/sketch/myT4WavDisplay.ino.cpp.o
Compiling libraries...
Compiling library "SPI"
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SPI/SPI.cpp.o
Compiling library "SD"
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/card_t3.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/cache_t3.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/dir_t3.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/fat_t3.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/File.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/SD.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/init_t3.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/file_t3.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/utility/NXP_SDHC.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/utility/Sd2Card.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/utility/SdVolume.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/utility/SdFile.cpp.o
Compiling library "ILI9341_t3"
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/ILI9341_t3/font_Arial.c.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/ILI9341_t3/font_ArialBold.c.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/ILI9341_t3/glcdfont.c.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/ILI9341_t3/ILI9341_t3.cpp.o
Compiling library "SerialFlash"
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SerialFlash/SerialFlashDirectory.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SerialFlash/SerialFlashChip.cpp.o
Compiling library "Audio"
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/memcpy_audio.S.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/data_spdif.c.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/data_windows.c.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/data_waveforms.c.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/data_ulaw.c.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/analyze_fft1024.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/analyze_peak.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/analyze_print.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/analyze_rms.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/analyze_notefreq.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/analyze_fft256.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/analyze_tonedetect.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/control_ak4558.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/control_cs42448.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/control_cs4272.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/control_sgtl5000.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/control_wm8731.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_bitcrusher.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_chorus.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_combine.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_delay.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/control_tlv320aic3206.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_delay_ext.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_envelope.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_fade.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_flange.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_freeverb.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_granular.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_midside.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_multiply.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_reverb.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_waveshaper.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/filter_biquad.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/input_adc.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/filter_variable.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/input_adcs.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/filter_fir.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/input_i2s2.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/input_i2s.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/input_pdm.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/input_i2s_quad.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/input_tdm.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/input_tdm2.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/mixer.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_adat.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_dac.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_dacs.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_i2s.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_i2s_quad.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_mqs.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_i2s2.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_pt8211.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_pwm.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_pt8211_2.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_spdif.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_spdif2.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_tdm.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_spdif3.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_tdm2.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/play_queue.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/play_memory.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/play_sd_raw.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/play_sd_wav.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/play_serialflash_raw.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/record_queue.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/spi_interrupt.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/synth_karplusstrong.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/synth_pinknoise.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/synth_dc.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/synth_pwm.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/synth_simple_drum.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/synth_tonesweep.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/synth_sine.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/synth_waveform.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/synth_wavetable.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/synth_whitenoise.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/utility/sqrt_integer.c.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/utility/imxrt_hw.cpp.o
Compiling library "Wire"
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Wire/Wire.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Wire/WireKinetis.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Wire/WireIMXRT.cpp.o
Using previously compiled file: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Wire/utility/twi.c.o
Compiling core...
Using precompiled core: /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_cache_542889/core/core_teensy_avr_teensy40_usb_serial,opt_o2std,keys _en-us_cee3a1d70ca5f7f18ab44a012a95ee10.a
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc -O2 -Wl,--gc-sections,--relax -T/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4/imxrt1062.ld -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/myT4WavDisplay.ino.elf /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/sketch/myT4WavDisplay.ino.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SPI/SPI.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/File.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/SD.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/cache_t3.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/card_t3.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/dir_t3.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/fat_t3.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/file_t3.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/init_t3.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/utility/NXP_SDHC.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/utility/Sd2Card.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/utility/SdFile.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SD/utility/SdVolume.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/ILI9341_t3/font_Arial.c.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/ILI9341_t3/font_ArialBold.c.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/ILI9341_t3/glcdfont.c.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/ILI9341_t3/ILI9341_t3.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SerialFlash/SerialFlashChip.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/SerialFlash/SerialFlashDirectory.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/memcpy_audio.S.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/data_spdif.c.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/data_ulaw.c.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/data_waveforms.c.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/data_windows.c.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/analyze_fft1024.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/analyze_fft256.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/analyze_notefreq.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/analyze_peak.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/analyze_print.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/analyze_rms.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/analyze_tonedetect.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/control_ak4558.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/control_cs42448.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/control_cs4272.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/control_sgtl5000.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/control_tlv320aic3206.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/control_wm8731.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_bitcrusher.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_chorus.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_combine.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_delay.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_delay_ext.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_envelope.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_fade.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_flange.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_freeverb.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_granular.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_midside.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_multiply.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_reverb.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/effect_waveshaper.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/filter_biquad.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/filter_fir.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/filter_variable.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/input_adc.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/input_adcs.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/input_i2s.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/input_i2s2.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/input_i2s_quad.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/input_pdm.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/input_tdm.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/input_tdm2.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/mixer.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_adat.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_dac.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_dacs.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_i2s.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_i2s2.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_i2s_quad.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_mqs.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_pt8211.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_pt8211_2.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_pwm.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_spdif.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_spdif2.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_spdif3.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_tdm.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/output_tdm2.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/play_memory.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/play_queue.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/play_sd_raw.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/play_sd_wav.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/play_serialflash_raw.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/record_queue.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/spi_interrupt.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/synth_dc.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/synth_karplusstrong.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/synth_pinknoise.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/synth_pwm.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/synth_simple_drum.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/synth_sine.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/synth_tonesweep.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/synth_waveform.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/synth_wavetable.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/synth_whitenoise.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/utility/sqrt_integer.c.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Audio/utility/imxrt_hw.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Wire/Wire.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Wire/WireIMXRT.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Wire/WireKinetis.cpp.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/libraries/Wire/utility/twi.c.o /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/../arduino_cache_542889/core/core_teensy_avr_teensy40_usb_serial,opt_o2std,keys _en-us_cee3a1d70ca5f7f18ab44a012a95ee10.a -L/var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312 -larm_cortexM7lfsp_math -lm -lstdc++
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/myT4WavDisplay.ino.elf /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/myT4WavDisplay.ino.eep
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objcopy -O ihex -R .eeprom /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/myT4WavDisplay.ino.elf /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/myT4WavDisplay.ino.hex
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/stdout_redirect /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/myT4WavDisplay.ino.lst /Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objdump -d -S -C /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/myT4WavDisplay.ino.elf
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/stdout_redirect /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/myT4WavDisplay.ino.sym /Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objdump -t -C /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/myT4WavDisplay.ino.elf
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/teensy_post_compile -file=myT4WavDisplay.ino -path=/var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312 -tools=/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/ -board=TEENSY40
Multiple libraries were found for "SerialFlash.h"
Used: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash
Multiple libraries were found for "Audio.h"
Used: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio
Multiple libraries were found for "Wire.h"
Used: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire
Multiple libraries were found for "SPI.h"
Used: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI
Multiple libraries were found for "SD.h"
Used: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD
Not used: /Applications/Arduino.app/Contents/Java/libraries/SD
Multiple libraries were found for "ILI9341_t3.h"
Used: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3
Using library SPI at version 1.0 in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI
Using library SD at version 1.2.2 in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD
Using library ILI9341_t3 at version 1.0 in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3
Using library SerialFlash at version 0.5 in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash
Using library Audio at version 1.3 in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio
Using library Wire at version 1.0 in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire
/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-size -A /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/myT4WavDisplay.ino.elf
Sketch uses 52912 bytes (2%) of program storage space. Maximum is 2031616 bytes.
Global variables use 60176 bytes (5%) of dynamic memory, leaving 988400 bytes for local variables. Maximum is 1048576 bytes.
But the program still crashes the T4 (no sign of life and terminal can't be found). Also checked and TD1.48B1 works on 1.8.9.
bicycleguy
09-20-2019, 06:37 PM
Here's the Teensy verbose output showing the port closing at the very end:(edit, or I guess never opening)
11:23:37.378 (ports 2): Begin, version=1.48-beta1
11:23:37.378 (ports 2): USB device add callback
11:23:37.380 (ports 2): USB device remove callback
11:23:37.380 (ports 2): Serial add callback
11:23:37.387 (ports 2): Serial remove callback
11:23:37.392 (ports 2): HID Manager started
11:24:24.283 (post_compile 1): Begin, version=1.48-beta1
11:24:24.669 (loader): Teensy Loader 1.48-beta1, begin program
11:24:24.702 (loader): Listening for remote control on port 3149
11:24:24.703 (loader): initialized, showing main window
11:24:24.821 (loader): remote connection 18 opened
11:24:24.822 (post_compile 1): Sending command: comment: Teensyduino 1.48-beta1 - MACOSX (teensy_post_compile)
11:24:24.826 (loader): remote cmd from 18: "comment: Teensyduino 1.48-beta1 - MACOSX (teensy_post_compile)"
11:24:24.827 (loader): remote cmd from 18: "status"
11:24:24.829 (loader): HID/macos: no devices found
11:24:24.829 (post_compile 1): Status: 0, 0, 0, 0, 0, 0, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_871214/, myT4WavDisplay.ino.hex
11:24:24.829 (post_compile 1): Sending command: dir:/var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/
11:24:24.830 (loader): remote cmd from 18: "dir:/var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/"
11:24:24.830 (post_compile 1): Sending command: file:myT4WavDisplay.ino.hex
11:24:24.830 (loader): remote cmd from 18: "file:myT4WavDisplay.ino.hex"
11:24:24.839 (loader): File "myT4WavDisplay.ino.hex". 52924 bytes, 3% used
11:24:24.844 (loader): remote cmd from 18: "status"
11:24:24.845 (post_compile 1): Status: 1, 0, 0, 0, 0, 0, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/, myT4WavDisplay.ino.hex
11:24:24.845 (post_compile 1): Sending command: auto:on
11:24:24.845 (loader): remote cmd from 18: "auto:on"
11:24:24.846 (post_compile 1): Disconnect
11:24:24.857 (loader): remote connection 18 closed
11:24:34.725 (ports 2): USB device add callback
11:24:34.725 (ports 2): loc=14340000, vid=16C0, pid=0478, ver=0105, ser=0009649E
11:24:34.725 (ports 2): actual serailnum=615582
11:24:34.725 (ports 2): name: [no_device] (Teensy) Bootloader
11:24:34.725 (loader): remote connection 18 opened
11:24:35.448 (ports 2): HID add callback, vid=16c0, pid=0478, ver=0105, loc=14340000, use=ff9c:24
11:24:35.448 (ports 2): found prior teensy at this loc, age=0.723
11:24:35.448 (ports 2): name: HID=16c0:0478.ff9c.24 (Teensy 4.0) Bootloader
11:24:35.449 (loader): HID/macos: attach callback
11:24:35.453 (loader): Device came online, code_size = 2031616
11:24:35.453 (loader): Board is: Teensy 4.0 (IMXRT1062), version 1.05
11:24:35.459 (loader): File "myT4WavDisplay.ino.hex". 52924 bytes, 3% used
11:24:35.460 (loader): set background IMG_ONLINE
11:24:35.468 (loader): File "myT4WavDisplay.ino.hex". 52924 bytes, 3% used
11:24:35.469 (loader): elf appears to be for Teensy 4.0 (IMXRT1062) (2031616 bytes)
11:24:35.470 (loader): elf binary data matches hex file
11:24:35.470 (loader): elf file is for Teensy 4.0 (IMXRT1062)
11:24:35.470 (loader): begin operation
11:24:35.499 (loader): flash, block=0, bs=1024, auto=1
11:24:35.499 (loader): gauge old value = 0
11:24:35.500 (loader): flash, block=1, bs=1024, auto=1
11:24:35.672 (loader): gauge old value = 1
11:24:35.679 (loader): flash, block=2, bs=1024, auto=1
11:24:35.680 (loader): gauge old value = 2
11:24:35.680 (loader): flash, block=3, bs=1024, auto=1
11:24:35.680 (loader): gauge old value = 3
11:24:35.680 (loader): flash, block=4, bs=1024, auto=1
11:24:35.681 (loader): gauge old value = 4
11:24:35.681 (loader): flash, block=5, bs=1024, auto=1
11:24:35.682 (loader): gauge old value = 5
11:24:35.683 (loader): flash, block=6, bs=1024, auto=1
11:24:35.684 (loader): gauge old value = 6
11:24:35.684 (loader): flash, block=7, bs=1024, auto=1
11:24:35.685 (loader): gauge old value = 7
11:24:35.686 (loader): flash, block=8, bs=1024, auto=1
11:24:35.687 (loader): gauge old value = 8
11:24:35.687 (loader): flash, block=9, bs=1024, auto=1
11:24:35.688 (loader): gauge old value = 9
11:24:35.689 (loader): flash, block=10, bs=1024, auto=1
11:24:35.690 (loader): gauge old value = 10
11:24:35.690 (loader): flash, block=11, bs=1024, auto=1
11:24:35.692 (loader): gauge old value = 11
11:24:35.692 (loader): flash, block=12, bs=1024, auto=1
11:24:35.693 (loader): gauge old value = 12
11:24:35.700 (loader): flash, block=13, bs=1024, auto=1
11:24:35.700 (loader): gauge old value = 13
11:24:35.700 (loader): flash, block=14, bs=1024, auto=1
11:24:35.702 (loader): gauge old value = 14
11:24:35.702 (loader): flash, block=15, bs=1024, auto=1
11:24:35.703 (loader): gauge old value = 15
11:24:35.704 (loader): flash, block=16, bs=1024, auto=1
11:24:35.705 (loader): gauge old value = 16
11:24:35.705 (loader): flash, block=17, bs=1024, auto=1
11:24:35.706 (loader): gauge old value = 17
11:24:35.707 (loader): flash, block=18, bs=1024, auto=1
11:24:35.708 (loader): gauge old value = 18
11:24:35.708 (loader): flash, block=19, bs=1024, auto=1
11:24:35.710 (loader): gauge old value = 19
11:24:35.716 (loader): flash, block=20, bs=1024, auto=1
11:24:35.716 (loader): gauge old value = 20
11:24:35.716 (loader): flash, block=21, bs=1024, auto=1
11:24:35.718 (loader): gauge old value = 21
11:24:35.718 (loader): flash, block=22, bs=1024, auto=1
11:24:35.719 (loader): gauge old value = 22
11:24:35.719 (loader): flash, block=23, bs=1024, auto=1
11:24:35.721 (loader): gauge old value = 23
11:24:35.721 (loader): flash, block=24, bs=1024, auto=1
11:24:35.722 (loader): gauge old value = 24
11:24:35.723 (loader): flash, block=25, bs=1024, auto=1
11:24:35.724 (loader): gauge old value = 25
11:24:35.724 (loader): flash, block=26, bs=1024, auto=1
11:24:35.725 (loader): gauge old value = 26
11:24:35.732 (loader): flash, block=27, bs=1024, auto=1
11:24:35.732 (loader): gauge old value = 27
11:24:35.733 (loader): flash, block=28, bs=1024, auto=1
11:24:35.734 (loader): gauge old value = 28
11:24:35.734 (loader): flash, block=29, bs=1024, auto=1
11:24:35.736 (loader): gauge old value = 29
11:24:35.736 (loader): flash, block=30, bs=1024, auto=1
11:24:35.737 (loader): gauge old value = 30
11:24:35.737 (loader): flash, block=31, bs=1024, auto=1
11:24:35.739 (loader): gauge old value = 31
11:24:35.739 (loader): flash, block=32, bs=1024, auto=1
11:24:35.740 (loader): gauge old value = 32
11:24:35.741 (loader): flash, block=33, bs=1024, auto=1
11:24:35.742 (loader): gauge old value = 33
11:24:35.742 (loader): flash, block=34, bs=1024, auto=1
11:24:35.743 (loader): gauge old value = 34
11:24:35.749 (loader): flash, block=35, bs=1024, auto=1
11:24:35.750 (loader): gauge old value = 35
11:24:35.756 (loader): flash, block=36, bs=1024, auto=1
11:24:35.756 (loader): gauge old value = 36
11:24:35.756 (loader): flash, block=37, bs=1024, auto=1
11:24:35.757 (loader): gauge old value = 37
11:24:35.757 (loader): flash, block=38, bs=1024, auto=1
11:24:35.759 (loader): gauge old value = 38
11:24:35.766 (loader): flash, block=39, bs=1024, auto=1
11:24:35.766 (loader): gauge old value = 39
11:24:35.766 (loader): flash, block=40, bs=1024, auto=1
11:24:35.768 (loader): gauge old value = 40
11:24:35.768 (loader): flash, block=41, bs=1024, auto=1
11:24:35.769 (loader): gauge old value = 41
11:24:35.769 (loader): flash, block=42, bs=1024, auto=1
11:24:35.771 (loader): gauge old value = 42
11:24:35.771 (loader): flash, block=43, bs=1024, auto=1
11:24:35.772 (loader): gauge old value = 43
11:24:35.772 (loader): flash, block=44, bs=1024, auto=1
11:24:35.774 (loader): gauge old value = 44
11:24:35.774 (loader): flash, block=45, bs=1024, auto=1
11:24:35.775 (loader): gauge old value = 45
11:24:35.782 (loader): flash, block=46, bs=1024, auto=1
11:24:35.782 (loader): gauge old value = 46
11:24:35.783 (loader): flash, block=47, bs=1024, auto=1
11:24:35.784 (loader): gauge old value = 47
11:24:35.784 (loader): flash, block=48, bs=1024, auto=1
11:24:35.786 (loader): gauge old value = 48
11:24:35.786 (loader): flash, block=49, bs=1024, auto=1
11:24:35.787 (loader): gauge old value = 49
11:24:35.787 (loader): flash, block=50, bs=1024, auto=1
11:24:35.789 (loader): gauge old value = 50
11:24:35.789 (loader): flash, block=51, bs=1024, auto=1
11:24:35.790 (loader): gauge old value = 51
11:24:35.806 (loader): sending reboot
11:24:35.806 (loader): begin wait_until_offline
11:24:35.806 (loader): HID/macos: status: ok
11:24:35.857 (ports 2): HID remove callback
11:24:35.857 (ports 2): HID add callback, vid=16c0, pid=0478, ver=0105, loc=14340000
11:24:35.857 (ports 2): USB device remove callback
11:24:35.857 (ports 2): remove, loc=14340000
11:24:35.857 (ports 2): usb_remove: usb:14340000
11:24:35.857 (ports 2): del device: location=14340000
11:24:35.907 (loader): HID/macos: detach callback: is currently open device
11:24:35.908 (loader): offline, waited 2
11:24:35.908 (loader): end operation, total time = 0.439 seconds
11:24:35.909 (loader): set background IMG_REBOOT_OK
11:24:35.910 (loader): redraw timer set, image 14 to show for 1200 ms
11:24:35.952 (loader): HID/macos: number of devices found = 0
11:24:35.952 (loader): HID/macos: no devices found (empty set)
11:24:37.111 (loader): redraw, image 9
11:24:37.661 (ports 2): purge, name=HID=16c0:0478.ff9c.24 (Teensy 4.0) Bootloader, loc=usb:14340000, age=1.804 sec
11:25:12.776 (post_compile 3): Begin, version=1.48-beta1
11:25:12.776 (loader): remote connection 22 opened
11:25:12.776 (post_compile 3): Sending command: comment: Teensyduino 1.48-beta1 - MACOSX (teensy_post_compile)
11:25:12.776 (loader): remote cmd from 22: "comment: Teensyduino 1.48-beta1 - MACOSX (teensy_post_compile)"
11:25:12.777 (loader): remote cmd from 22: "status"
11:25:12.777 (post_compile 3): Status: 1, 1, 0, 1, 0, 0, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/, myT4WavDisplay.ino.hex
11:25:12.777 (post_compile 3): Sending command: dir:/var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_748221/
11:25:12.777 (loader): remote cmd from 22: "dir:/var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_748221/"
11:25:12.777 (post_compile 3): Sending command: file:Blink.ino.hex
11:25:12.777 (loader): remote cmd from 22: "file:Blink.ino.hex"
11:25:12.780 (loader): File "Blink.ino.hex". 12164 bytes, 1% used
11:25:12.787 (loader): remote cmd from 22: "status"
11:25:12.788 (post_compile 3): Status: 1, 1, 0, 1, 0, 0, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_748221/, Blink.ino.hex
11:25:12.788 (post_compile 3): Disconnect
11:25:12.799 (loader): remote connection 22 closed
11:25:19.525 (ports 2): USB device add callback
11:25:19.525 (ports 2): loc=14340000, vid=16C0, pid=0478, ver=0105, ser=0009649E
11:25:19.525 (ports 2): actual serailnum=615582
11:25:19.525 (ports 2): name: [no_device] (Teensy) Bootloader
11:25:20.249 (loader): HID/macos: attach callback
11:25:20.249 (ports 2): HID add callback, vid=16c0, pid=0478, ver=0105, loc=14340000, use=ff9c:24
11:25:20.249 (ports 2): found prior teensy at this loc, age=0.724
11:25:20.249 (ports 2): name: HID=16c0:0478.ff9c.24 (Teensy 4.0) Bootloader
11:25:20.451 (loader): Device came online, code_size = 2031616
11:25:20.451 (loader): Board is: Teensy 4.0 (IMXRT1062), version 1.05
11:25:20.454 (loader): File "Blink.ino.hex". 12164 bytes, 1% used
11:25:20.455 (loader): set background IMG_ONLINE
11:25:20.459 (loader): File "Blink.ino.hex". 12164 bytes, 1% used
11:25:20.459 (loader): elf appears to be for Teensy 4.0 (IMXRT1062) (2031616 bytes)
11:25:20.459 (loader): elf binary data matches hex file
11:25:20.459 (loader): elf file is for Teensy 4.0 (IMXRT1062)
11:25:20.459 (loader): begin operation
11:25:20.486 (loader): flash, block=0, bs=1024, auto=1
11:25:20.486 (loader): gauge old value = 0
11:25:20.488 (loader): flash, block=1, bs=1024, auto=1
11:25:20.652 (loader): gauge old value = 1
11:25:20.654 (loader): flash, block=2, bs=1024, auto=1
11:25:20.654 (loader): gauge old value = 2
11:25:20.654 (loader): flash, block=3, bs=1024, auto=1
11:25:20.655 (loader): gauge old value = 3
11:25:20.655 (loader): flash, block=4, bs=1024, auto=1
11:25:20.655 (loader): gauge old value = 4
11:25:20.655 (loader): flash, block=5, bs=1024, auto=1
11:25:20.657 (loader): gauge old value = 5
11:25:20.657 (loader): flash, block=6, bs=1024, auto=1
11:25:20.658 (loader): gauge old value = 6
11:25:20.659 (loader): flash, block=7, bs=1024, auto=1
11:25:20.660 (loader): gauge old value = 7
11:25:20.660 (loader): flash, block=8, bs=1024, auto=1
11:25:20.661 (loader): gauge old value = 8
11:25:20.669 (loader): flash, block=9, bs=1024, auto=1
11:25:20.669 (loader): gauge old value = 9
11:25:20.669 (loader): flash, block=10, bs=1024, auto=1
11:25:20.671 (loader): gauge old value = 10
11:25:20.671 (loader): flash, block=11, bs=1024, auto=1
11:25:20.673 (loader): gauge old value = 11
11:25:20.674 (loader): sending reboot
11:25:20.674 (loader): begin wait_until_offline
11:25:20.674 (loader): HID/macos: status: ok
11:25:21.061 (ports 2): HID remove callback
11:25:21.061 (ports 2): HID add callback, vid=16c0, pid=0478, ver=0105, loc=14340000
11:25:21.061 (ports 2): USB device remove callback
11:25:21.061 (ports 2): remove, loc=14340000
11:25:21.061 (ports 2): usb_remove: usb:14340000
11:25:21.061 (ports 2): del device: location=14340000
11:25:21.062 (ports 2): USB device add callback
11:25:21.062 (ports 2): loc=14340000, vid=16C0, pid=0483, ver=0279, ser=6155820
11:25:21.062 (ports 2): actual serailnum=615582
11:25:21.062 (ports 2): found prior teensy at this loc, age=0.001
11:25:21.062 (ports 2): name: [no_device] (Teensy 4.0) Serial
11:25:21.085 (loader): HID/macos: detach callback: is currently open device
11:25:21.087 (loader): offline, waited 8
11:25:21.087 (loader): end operation, total time = 0.627 seconds
11:25:21.087 (loader): set background IMG_REBOOT_OK
11:25:21.089 (loader): redraw timer set, image 14 to show for 1200 ms
11:25:21.200 (loader): HID/macos: number of devices found = 0
11:25:21.200 (loader): HID/macos: no devices found (empty set)
11:25:21.292 (ports 2): Serial add callback
11:25:21.293 (ports 2): name=/dev/cu.usbmodem61558201, loc=14340000, vid=16c0, pid=0483, ver=0279
11:25:21.293 (ports 2): found prior teensy at this loc, age=0.231
11:25:21.293 (ports 2): name: /dev/cu.usbmodem61558201 (Teensy 4.0) Serial
11:25:22.290 (loader): redraw, image 9
11:25:49.989 (post_compile 4): Begin, version=1.48-beta1
11:25:49.989 (loader): remote connection 22 opened
11:25:49.989 (post_compile 4): Sending command: comment: Teensyduino 1.48-beta1 - MACOSX (teensy_post_compile)
11:25:49.989 (loader): remote cmd from 22: "comment: Teensyduino 1.48-beta1 - MACOSX (teensy_post_compile)"
11:25:49.990 (loader): remote cmd from 22: "status"
11:25:49.990 (post_compile 4): Status: 1, 1, 0, 2, 0, 0, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_748221/, Blink.ino.hex
11:25:49.990 (post_compile 4): Sending command: dir:/var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/
11:25:49.990 (loader): remote cmd from 22: "dir:/var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/"
11:25:49.990 (post_compile 4): Sending command: file:myT4WavDisplay.ino.hex
11:25:49.990 (loader): remote cmd from 22: "file:myT4WavDisplay.ino.hex"
11:25:49.998 (loader): File "myT4WavDisplay.ino.hex". 52924 bytes, 3% used
11:25:50.008 (loader): remote cmd from 22: "status"
11:25:50.008 (post_compile 4): Status: 1, 1, 0, 2, 0, 0, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/, myT4WavDisplay.ino.hex
11:25:50.008 (post_compile 4): Disconnect
11:25:50.019 (loader): remote connection 22 closed
11:25:50.240 (post_compile 5): Begin, version=1.48-beta1
11:25:50.241 (loader): remote connection 22 opened
11:25:50.241 (post_compile 5): Sending command: comment: Teensyduino 1.48-beta1 - MACOSX (teensy_post_compile)
11:25:50.241 (loader): remote cmd from 22: "comment: Teensyduino 1.48-beta1 - MACOSX (teensy_post_compile)"
11:25:50.241 (loader): remote cmd from 22: "status"
11:25:50.241 (post_compile 5): Status: 1, 1, 0, 2, 0, 0, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/, myT4WavDisplay.ino.hex
11:25:50.241 (post_compile 5): Disconnect
11:25:50.253 (post_compile 6): Running teensy_reboot: /Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/teensy_reboot
11:25:50.253 (loader): remote connection 22 closed
11:25:50.253 (loader): remote connection 22 opened
11:25:50.254 (loader): remote connection 22 closed
11:25:50.264 (reboot 7): Begin, version=1.48-beta1
11:25:50.264 (reboot 7): location = /dev/cu.usbmodem61558201
11:25:50.264 (reboot 7): portlabel = /dev/cu.usbmodem61558201
11:25:50.264 (reboot 7): portprotocol = serial
11:25:50.264 (reboot 7): Serial device /dev/cu.usbmodem61558201 will be tried first
11:25:50.264 (reboot 7): USB device add callback
11:25:50.265 (reboot 7): loc=14340000, vid=16C0, pid=0483, ver=0279, ser=6155820
11:25:50.265 (reboot 7): actual serailnum=615582
11:25:50.266 (loader): remote connection 22 opened
11:25:50.266 (reboot 7): USB device remove callback
11:25:50.266 (reboot 7): Serial add callback
11:25:50.266 (reboot 7): name=/dev/cu.usbmodem61558201, loc=14340000, vid=16c0, pid=0483, ver=0279
11:25:50.273 (reboot 7): Serial remove callback
11:25:50.302 (reboot 7): HID Manager started
11:25:50.303 (reboot 7): found Teensy Loader, version 1.48
11:25:50.303 (reboot 7): Sending command: show:arduino_attempt_reboot
11:25:50.303 (loader): remote cmd from 22: "show:arduino_attempt_reboot"
11:25:50.303 (loader): got request to show arduino rebooting message
11:25:50.305 (reboot 7): Sending command: comment: Teensyduino 1.48-beta1 - MACOSX (teensy_reboot)
11:25:50.306 (loader): remote cmd from 22: "comment: Teensyduino 1.48-beta1 - MACOSX (teensy_reboot)"
11:25:50.306 (loader): remote cmd from 22: "status"
11:25:50.306 (reboot 7): Status: 1, 1, 0, 2, 0, 0, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/, myT4WavDisplay.ino.hex
11:25:50.306 (reboot 7): do_reset (serial) /dev/cu.usbmodem61558201
11:25:50.310 (loader): remote cmd from 22: "status"
11:25:50.310 (reboot 7): Status: 1, 1, 0, 2, 0, 0, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/, myT4WavDisplay.ino.hex
11:25:50.310 (reboot 7): status read, retry 0
11:25:50.351 (ports 2): Serial remove callback
11:25:50.352 (ports 2): USB device remove callback
11:25:50.352 (ports 2): remove, loc=14340000
11:25:50.352 (ports 2): usb_remove: usb:14340000
11:25:50.352 (ports 2): del device: location=14340000
11:25:50.411 (loader): remote cmd from 22: "status"
11:25:50.411 (reboot 7): Status: 1, 1, 0, 2, 0, 0, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/, myT4WavDisplay.ino.hex
11:25:50.411 (reboot 7): status read, retry 1
11:25:50.512 (loader): remote cmd from 22: "status"
11:25:50.512 (reboot 7): Status: 1, 1, 0, 2, 0, 0, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/, myT4WavDisplay.ino.hex
11:25:50.512 (reboot 7): status read, retry 2
11:25:50.617 (loader): remote cmd from 22: "status"
11:25:50.618 (reboot 7): Status: 1, 1, 0, 2, 0, 0, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/, myT4WavDisplay.ino.hex
11:25:50.618 (reboot 7): status read, retry 3
11:25:50.723 (loader): remote cmd from 22: "status"
11:25:50.723 (reboot 7): Status: 1, 1, 0, 2, 0, 0, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/, myT4WavDisplay.ino.hex
11:25:50.723 (reboot 7): status read, retry 4
11:25:50.755 (ports 2): USB device add callback
11:25:50.755 (ports 2): loc=14340000, vid=16C0, pid=0478, ver=0105, ser=0009649E
11:25:50.756 (ports 2): actual serailnum=615582
11:25:50.756 (ports 2): found prior teensy at this loc, age=0.404
11:25:50.756 (ports 2): name: [no_device] (Teensy 4.0) Bootloader
11:25:50.829 (loader): remote cmd from 22: "status"
11:25:50.829 (reboot 7): Status: 1, 1, 0, 2, 0, 0, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/, myT4WavDisplay.ino.hex
11:25:50.829 (reboot 7): status read, retry 5
11:25:50.934 (loader): remote cmd from 22: "status"
11:25:50.934 (reboot 7): Status: 1, 1, 0, 2, 0, 0, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/, myT4WavDisplay.ino.hex
11:25:50.934 (reboot 7): status read, retry 6
11:25:51.038 (loader): remote cmd from 22: "status"
11:25:51.038 (reboot 7): Status: 1, 1, 0, 2, 0, 0, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/, myT4WavDisplay.ino.hex
11:25:51.038 (reboot 7): status read, retry 7
11:25:51.140 (loader): remote cmd from 22: "status"
11:25:51.141 (reboot 7): Status: 1, 1, 0, 2, 0, 0, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/, myT4WavDisplay.ino.hex
11:25:51.141 (reboot 7): status read, retry 8
11:25:51.245 (loader): remote cmd from 22: "status"
11:25:51.245 (reboot 7): Status: 1, 1, 0, 2, 0, 0, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/, myT4WavDisplay.ino.hex
11:25:51.245 (reboot 7): status read, retry 9
11:25:51.351 (loader): remote cmd from 22: "status"
11:25:51.351 (reboot 7): Status: 1, 1, 0, 2, 0, 0, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/, myT4WavDisplay.ino.hex
11:25:51.351 (reboot 7): status read, retry 10
11:25:51.455 (loader): remote cmd from 22: "status"
11:25:51.455 (reboot 7): Status: 1, 1, 0, 2, 0, 0, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/, myT4WavDisplay.ino.hex
11:25:51.455 (reboot 7): status read, retry 11
11:25:51.479 (loader): HID/macos: attach callback
11:25:51.479 (ports 2): HID add callback, vid=16c0, pid=0478, ver=0105, loc=14340000, use=ff9c:24
11:25:51.479 (ports 2): found prior teensy at this loc, age=0.724
11:25:51.479 (ports 2): name: HID=16c0:0478.ff9c.24 (Teensy 4.0) Bootloader
11:25:51.560 (loader): remote cmd from 22: "status"
11:25:51.560 (loader): Device came online, code_size = 2031616
11:25:51.560 (loader): Board is: Teensy 4.0 (IMXRT1062), version 1.05
11:25:51.567 (loader): File "myT4WavDisplay.ino.hex". 52924 bytes, 3% used
11:25:51.568 (loader): set background IMG_ONLINE
11:25:51.576 (loader): File "myT4WavDisplay.ino.hex". 52924 bytes, 3% used
11:25:51.577 (loader): elf appears to be for Teensy 4.0 (IMXRT1062) (2031616 bytes)
11:25:51.577 (loader): elf binary data matches hex file
11:25:51.577 (loader): elf file is for Teensy 4.0 (IMXRT1062)
11:25:51.577 (loader): begin operation
11:25:51.580 (reboot 7): Status: 1, 1, 1, 3, 0, 1, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/, myT4WavDisplay.ino.hex
11:25:51.598 (loader): flash, block=0, bs=1024, auto=1
11:25:51.598 (loader): gauge old value = 0
11:25:51.598 (loader): flash, block=1, bs=1024, auto=1
11:25:51.767 (loader): gauge old value = 1
11:25:51.769 (loader): remote cmd from 22: "status"
11:25:51.769 (reboot 7): Status: 1, 1, 1, 3, 0, 1, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/, myT4WavDisplay.ino.hex
11:25:51.770 (loader): flash, block=2, bs=1024, auto=1
11:25:51.770 (loader): gauge old value = 2
11:25:51.770 (loader): flash, block=3, bs=1024, auto=1
11:25:51.770 (loader): gauge old value = 3
11:25:51.771 (loader): flash, block=4, bs=1024, auto=1
11:25:51.771 (loader): gauge old value = 4
11:25:51.771 (loader): flash, block=5, bs=1024, auto=1
11:25:51.773 (loader): gauge old value = 5
11:25:51.773 (loader): flash, block=6, bs=1024, auto=1
11:25:51.774 (loader): gauge old value = 6
11:25:51.774 (loader): flash, block=7, bs=1024, auto=1
11:25:51.776 (loader): gauge old value = 7
11:25:51.776 (loader): flash, block=8, bs=1024, auto=1
11:25:51.777 (loader): gauge old value = 8
11:25:51.778 (loader): flash, block=9, bs=1024, auto=1
11:25:51.779 (loader): gauge old value = 9
11:25:51.779 (loader): flash, block=10, bs=1024, auto=1
11:25:51.780 (loader): gauge old value = 10
11:25:51.781 (loader): flash, block=11, bs=1024, auto=1
11:25:51.782 (loader): gauge old value = 11
11:25:51.782 (loader): flash, block=12, bs=1024, auto=1
11:25:51.784 (loader): gauge old value = 12
11:25:51.784 (loader): flash, block=13, bs=1024, auto=1
11:25:51.785 (loader): gauge old value = 13
11:25:51.785 (loader): flash, block=14, bs=1024, auto=1
11:25:51.787 (loader): gauge old value = 14
11:25:51.788 (loader): flash, block=15, bs=1024, auto=1
11:25:51.788 (loader): gauge old value = 15
11:25:51.789 (loader): flash, block=16, bs=1024, auto=1
11:25:51.790 (loader): gauge old value = 16
11:25:51.790 (loader): flash, block=17, bs=1024, auto=1
11:25:51.791 (loader): gauge old value = 17
11:25:51.792 (loader): flash, block=18, bs=1024, auto=1
11:25:51.793 (loader): gauge old value = 18
11:25:51.793 (loader): flash, block=19, bs=1024, auto=1
11:25:51.795 (loader): gauge old value = 19
11:25:51.795 (loader): flash, block=20, bs=1024, auto=1
11:25:51.796 (loader): gauge old value = 20
11:25:51.797 (loader): flash, block=21, bs=1024, auto=1
11:25:51.798 (loader): gauge old value = 21
11:25:51.798 (loader): flash, block=22, bs=1024, auto=1
11:25:51.799 (loader): gauge old value = 22
11:25:51.800 (loader): flash, block=23, bs=1024, auto=1
11:25:51.801 (loader): gauge old value = 23
11:25:51.801 (loader): flash, block=24, bs=1024, auto=1
11:25:51.803 (loader): gauge old value = 24
11:25:51.805 (loader): flash, block=25, bs=1024, auto=1
11:25:51.805 (loader): gauge old value = 25
11:25:51.805 (loader): flash, block=26, bs=1024, auto=1
11:25:51.807 (loader): gauge old value = 26
11:25:51.807 (loader): flash, block=27, bs=1024, auto=1
11:25:51.808 (loader): gauge old value = 27
11:25:51.808 (loader): flash, block=28, bs=1024, auto=1
11:25:51.810 (loader): gauge old value = 28
11:25:51.810 (loader): flash, block=29, bs=1024, auto=1
11:25:51.811 (loader): gauge old value = 29
11:25:51.812 (loader): flash, block=30, bs=1024, auto=1
11:25:51.813 (loader): gauge old value = 30
11:25:51.813 (loader): flash, block=31, bs=1024, auto=1
11:25:51.814 (loader): gauge old value = 31
11:25:51.815 (loader): flash, block=32, bs=1024, auto=1
11:25:51.816 (loader): gauge old value = 32
11:25:51.816 (loader): flash, block=33, bs=1024, auto=1
11:25:51.818 (loader): gauge old value = 33
11:25:51.818 (loader): flash, block=34, bs=1024, auto=1
11:25:51.819 (loader): gauge old value = 34
11:25:51.826 (loader): remote cmd from 22: "status"
11:25:51.826 (reboot 7): Status: 1, 1, 1, 3, 0, 1, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/, myT4WavDisplay.ino.hex
11:25:51.826 (loader): flash, block=35, bs=1024, auto=1
11:25:51.827 (loader): gauge old value = 35
11:25:51.827 (loader): flash, block=36, bs=1024, auto=1
11:25:51.828 (loader): gauge old value = 36
11:25:51.829 (loader): flash, block=37, bs=1024, auto=1
11:25:51.830 (loader): gauge old value = 37
11:25:51.830 (loader): flash, block=38, bs=1024, auto=1
11:25:51.831 (loader): gauge old value = 38
11:25:51.832 (loader): flash, block=39, bs=1024, auto=1
11:25:51.833 (loader): gauge old value = 39
11:25:51.833 (loader): flash, block=40, bs=1024, auto=1
11:25:51.835 (loader): gauge old value = 40
11:25:51.835 (loader): flash, block=41, bs=1024, auto=1
11:25:51.836 (loader): gauge old value = 41
11:25:51.837 (loader): flash, block=42, bs=1024, auto=1
11:25:51.838 (loader): gauge old value = 42
11:25:51.838 (loader): flash, block=43, bs=1024, auto=1
11:25:51.839 (loader): gauge old value = 43
11:25:51.840 (loader): flash, block=44, bs=1024, auto=1
11:25:51.841 (loader): gauge old value = 44
11:25:51.841 (loader): flash, block=45, bs=1024, auto=1
11:25:51.842 (loader): gauge old value = 45
11:25:51.843 (loader): flash, block=46, bs=1024, auto=1
11:25:51.844 (loader): gauge old value = 46
11:25:51.844 (loader): flash, block=47, bs=1024, auto=1
11:25:51.845 (loader): gauge old value = 47
11:25:51.846 (loader): flash, block=48, bs=1024, auto=1
11:25:51.847 (loader): gauge old value = 48
11:25:51.847 (loader): flash, block=49, bs=1024, auto=1
11:25:51.849 (loader): gauge old value = 49
11:25:51.849 (loader): flash, block=50, bs=1024, auto=1
11:25:51.850 (loader): gauge old value = 50
11:25:51.850 (loader): flash, block=51, bs=1024, auto=1
11:25:51.852 (loader): gauge old value = 51
11:25:51.855 (loader): sending reboot
11:25:51.855 (loader): begin wait_until_offline
11:25:51.855 (loader): HID/macos: status: ok
11:25:51.886 (ports 2): HID remove callback
11:25:51.886 (ports 2): HID add callback, vid=16c0, pid=0478, ver=0105, loc=14340000
11:25:51.887 (ports 2): USB device remove callback
11:25:51.887 (ports 2): remove, loc=14340000
11:25:51.887 (ports 2): usb_remove: usb:14340000
11:25:51.887 (ports 2): del device: location=14340000
11:25:51.906 (loader): HID/macos: detach callback: is currently open device
11:25:51.907 (loader): offline, waited 1
11:25:51.907 (loader): end operation, total time = 0.330 seconds
11:25:51.908 (loader): set background IMG_REBOOT_OK
11:25:51.909 (loader): redraw timer set, image 14 to show for 1200 ms
11:25:51.909 (loader): remote cmd from 22: "status"
11:25:51.914 (loader): HID/macos: number of devices found = 0
11:25:51.915 (loader): HID/macos: no devices found (empty set)
11:25:51.915 (reboot 7): Status: 1, 1, 0, 3, 0, 0, /var/folders/b9/m7vp5hr925n_3r73_y07979w0000gn/T/arduino_build_472312/, myT4WavDisplay.ino.hex
11:25:51.915 (reboot 7): status read, retry 12
11:25:51.915 (reboot 7): Success
11:25:51.915 (reboot 7): Disconnect
11:25:51.928 (loader): remote connection 22 closed
11:25:53.109 (loader): redraw, image 9
11:26:14.668 (loader): Verbose Info event
bicycleguy
09-20-2019, 06:44 PM
At message #47 I said 1.8.9 works with 1.48b1. That not quit a correct statement. The 1.8.9 used 1.47 for it's initial TD installation. It works correctly with the 1.48b1 TD not necessarily the 1.48b1 installer.
bicycleguy
09-21-2019, 03:19 AM
I have narrowed down a T4 crash with Arduino1.8.10 TD1.48b1 a little more. After re-installing Arduino1.8.10 and TD1.48b1 the issues I was having in many programs went away (as should be expected if the TD install was faulty). However the program in message #40 above still crashes. That program calls many libraries so is hard to debug (if you can call it that with no debugger).
SD, SPI, and Audio examples from the examples now all work.(as in Arduino 1.8.9-TD1.47)
In the ILI9341_t3 examples folder there is a problem. graphicstest.ino works in 1.8.9 and 1.8.10 but demoSauce.ino only works in 1.8.9.
In graphicstest.ino I change TFT_DC to 5 from 9 and TFT_CS to 9 from 10 and it works great.
In DemoSauce.ino the same changes, no joy.
I'm still looking...
defragster
09-21-2019, 03:24 AM
@Paul:
Did the Arduino folks somehow cause a break in this "Multiple libraries were found for" code in 1.8.10??
It triggers that often and only shows a single library name.
pbgbg
AndyCap
09-21-2019, 07:41 AM
With USB Print Test on ManPro trashcan 12 core, 10.14.5:
Arduino serial monitor
210,000 - 250,000. Mostly down the lower end.
Kernel Task : 185%
teensy_serialmon: 65%
Arduino: 37%
Window Server: 15%
cat /dev/cu.usbmodem61562001
240,000 - 250,000.
Kernel Task: 200%
Terminal : 60%
Hangs after a few secs, Kernel Task stays at 130% until cat stopped
screen /dev/cu.usbmodem61562001
240,000 - 250,000.
Kernel Task: 200%
Terminal : 110%
Screen : 85%
So pretty high CPU here but the Serial monitor and screen command seem to run fine.
Edit: Looking into the hang here I knocked up some FILE* code here and get the hang, breaking into the debugger it is in __read_nocancel, interestingly continuing the debugger "fixes" the issue. Until the next time...
Edit2: Using open(), read() with O_NONBLOCK gets rid of the hang.
KurtE
09-21-2019, 02:02 PM
@bicycleguy - Yep it appears to crash hard...
I mucked up the Setup function to output stuff to Serial port and I get nothing.
// Backlight
#if 0
pinMode( BACKLIGHT_PIN, OUTPUT );
analogWrite( BACKLIGHT_PIN, 1023 );
while(!Serial && millis() < 5000) ;
Serial.println("Start DemoSouce");
// Microphone
pinMode( MIC_PIN, INPUT );
Serial.println("Before TFT begin");
tft.begin();
Serial.println("After TFT begin"); Serial.flush();
tft.setRotation( 3 );
Serial.println("After Set Rotation"); Serial.flush();
Serial.println("After fillScreen"); Serial.flush();
// Serial
if( DO_BENCHMARKS ) {
And as you said it does run on 1.8.9, the only mod I did there, was to add the reset pin for tft on the constructor, in this case pin 8...
@PaulStoffregen - This looks like another case where the setup is not being called. Not sure if it is hanging in some constructors code or even earlier... I may not have time until Monday or Tuesday to take a look.
Kurt
bicycleguy
09-21-2019, 02:52 PM
@Kurt,
Thanks, thought I was being ignored. But wait !! Another clue !!
DemoSauce.ino runs on 1.8.10 if I set optimize to "Smallest Code" !
This also makes the rest of my programs work that use the audioboard & its SD, and ILI9341_t3 together.
Also realized that a bare T4 can be used for testing this issue, the LED flickers(SCK) and the terminal stays connected means it probably works, otherwise no LED and offline.
Maybe not size related as the Teensy_Convolution_SDR works and it uses 242,064 bytes program and 430368 ram.
KurtE
09-21-2019, 03:21 PM
@bicycleguy - Sorry, sometimes hard for us who try to help out for the heck of it to see everything going on... As I mentioned, I don't have much time this weekend...
Also this looks like a long list of things for @PaulStoffregen to look at, as it appears to be another screwy compile or link or load or??? That is if you turn on debug printing.
(printf.h un-comment the #define PRINT_DEBUG_STUFF
Then rebuilt... Not for sure that was enough or not, but I then also uncommented some comments in startup.c and hooked up debug cable to Serial4, and I got all of the debug output and started getting info out over USB... And then hooked up display again and it was working...
mjs513
09-21-2019, 03:28 PM
@KurtE @bicycleguy
Well here is something else. I just tried demosauce with ILI9341_t3n and it crashes the same way. This is reminds me of the problem we were having with uncanny eyes as well.
Can confirm using smallest code also seems to fix the problem using the ILI9341_t3n library as well. Other optimizations hang the code as well. Good catch @bicycleguy
UPDATE: Same occurs with the ILI9488_t3 display
mjs513
09-21-2019, 04:28 PM
@KurtE
Tried to just un-comment the #define PRINT_DEBUG_STUFF and recompiled but demosauce still hung the T4. Maybe something else you un-commented?
KurtE
09-21-2019, 05:05 PM
Some of the ones in startup.c like all the ones up to before and after call to setup
Sorry I am not at my computer so can not give much more info
Edit also remember I added prints in the sketch as I mentioned earlier.
bicycleguy
09-21-2019, 06:18 PM
Commenting out the differences in startup.c between 1.8.9 and 1.8.10 seems to fix the problem.
17665
No idea what it's meant to do or any other effects.
KurtE
09-21-2019, 06:26 PM
@paul did that change 8 days ago to fix some issue of >2 interval timers...
Not sure of its implications
manitou
09-21-2019, 06:30 PM
17665
here is discussion associated with PIT changes in startup.c
https://forum.pjrc.com/threads/57360-Teensy4-IntervalTimer-Channels-Problem
you could try adding line to turn PIT off
CCM_CCGR1 |= CCM_CCGR1_PIT(CCM_CCGR_ON);
PIT_TCTRL0 = 0;
PIT_TCTRL1 = 0;
PIT_TCTRL2 = 0;
PIT_TCTRL3 = 0;
CCM_CCGR1 &= ~CCM_CCGR1_PIT(CCM_CCGR_ON); //optional
mjs513
09-21-2019, 06:48 PM
Interesting --- just commenting out those lines and it still hanging on my T4. I am using pins 9-13, don't have anything else attached.
EDIT: went back to 1.8.9 IDE with 1.47b5 and its still doing the same thing. 1,8.8 with TD1.45 same thing with the ILI9431_t3 lib. Guess maybe try t3n.
manitou
09-21-2019, 08:26 PM
OK, i'm not sure i know how you guys are testing, but here is what i did on my linux64 box. installed 1.8.10 and 1.48-beta1, and ran a T4 intervaltimer sketch to verify i could get all 4 channels. OK. Then ran example DemoSauce from ILI9341_t3 lib ... production T4 froze (no ttyACM0), had to hit program button to load a new sketch.
Went to startup.c and ifdef'd out newly added PIT lines. confirmed intervaltimer now only had 2 channels. DemoSauce now worked. (it printed something on monitor "TwistyText" ... -- i have nothing connectd to T4). I then re-enabled PIT lines in startup.c BUT commented out PIT_MCR =0; and now intervaltimer had 4 channels AND DemoSauce was working. Can someone else try that. PIT_MCR=0 actually enables PIT timer. That wasn't in my suggested fix discussed in
Paul added that in his core update. Setting PIT_MCR to 0 actually enables the PIT timer, which I don't think you want to do. POR reset value is 2 for PIT_MCR.
can someone else try commenting out PIT_MCR = 0;
Not sure why that should make a difference -- i think ROM bootloader had PIT configured as free-running 64-bit timer, but i'm only guessin.
mjs513
09-21-2019, 08:53 PM
@manitou
I just reinstalled TD1.48beta1 and the ILI9341_t3 library. I then commented out PIT_MCR = 0; and it worked without issue. So the fix is exactly as you described to turn off the timer.
Dave47
09-21-2019, 10:16 PM
I've been following this and thread since I was hoping I had a similar problem. Unfortunately, that isn't the case, yet. When I set up the interval timer, I am only getting it to fire once. The code I am trying to use works on T3.2, T3.5, and T3.6 with minor timing tweaks between them, but not yet on the T4. Maybe someone in this thread can help? I can also start a new thread if needed.
My problem occurred when I tried to update my Commodore 6581 (SID) player to use a T4.
https://forum.pjrc.com/threads/42587-David-s-MOS6581-SID-network-player-(Teensy-3-2)?highlight=SID
I need a 1MHz clock and a timed chip select that lines up with the clock's rising edge and doesn't "walk" away from the clock between SID writes. That looks like the following:
17666
The code needed to do this on previous Teensys is this:
#define CLK 4
#define CS1 3
#define NOP __asm__("nop\n\t")
volatile long timetonext;
volatile byte dataavailable;
volatile unsigned long cycles_per_us;
static inline void delayCycles(uint32_t cycles)
{ // MIN return in 7 cycles NEAR 20 cycles it gives wait +/- 2 cycles - with sketch timing overhead
uint32_t begin = ARM_DWT_CYCCNT - 12; // Overhead Factor for execution
while (ARM_DWT_CYCCNT - begin < cycles) ; // wait
IntervalTimer myTimer;
pinMode(CLK, OUTPUT);
digitalWrite(CLK, HIGH);
pinMode(CS1, OUTPUT);
digitalWrite(CS1, HIGH);
analogWriteFrequency(CLK, 1000000); // set clock frequency to 1MHz
analogWriteResolution(5); // PWM resolution
analogWrite(CLK, 15); // PWM dutycycle
myTimer.begin(DATA, 10);
//myTimer.priority(64);
cycles_per_us = F_BUS_ACTUAL / 1000000;
FASTRUN void loop() {
while (1) {
timetonext = 3; //Change this to vary the number of CLK pulses between CS1 pulses
dataavailable = 1;
PIT_LDVAL0 = timetonext * cycles_per_us - 1; // reset the PIT timer in myTimer to the delay until the next write
while (dataavailable == 1) {} // wait for myTimer to fire interrupt
FASTRUN void DATA(void)
if (dataavailable >= 1) {
digitalWriteFast(CS1, LOW);
// 200ns Pulse on Teensy 4 @ 600MHz
delayCycles(45);
dataavailable = 0;
digitalWriteFast(CS1, HIGH);
The variable "timetonext" is the number of microseconds to wait before firing the interrupt and can be any number between 0 and 65535. I used PIT_LDVAL0 to change the start of the timer on the fly and it worked very well. Also, don't worry if the chip select doesn't line up with the clock in the example since that can be fixed with different amounts of delayCycles either in the interrupt routine or the main routine.
Any ideas?
David
manitou
09-21-2019, 10:28 PM
Any ideas?
David
you probably should start a new thread, BUT one problem you have is using F_BUS_ACTUAL. The PIT timer for IntervalTimer runs at 24MHz, not F_BUS_ACTUAL
EDIT:
also if you are not running 1.48-beta1, the first PIT channel you get for IntervalTimer is channel 2, so you need to use PIT_LDVAL2
Dave47
09-21-2019, 10:58 PM
I will make note of that. I was using F_BUS for the previous Teensys, so I just updated when I got an error at compile time.
EDIT:
I am using 1.48-beta1 at the moment. I got the disconnect/lockup behavior in 1.48. That was why I wondered if I should post in this thread or not. Can a mod move these to a new thread?
David
defragster
09-21-2019, 11:02 PM
If you want to create a new thread it can get copied over to there yes
Dave47
09-21-2019, 11:29 PM
Done! new thread is here...
https://forum.pjrc.com/threads/57693-Problems-Synchronizing-an-Interval-Timer-to-a-PWM-on-a-Teensy-4
David
defragster
09-22-2019, 12:11 AM
Seems you got the post copied over.
manitou
09-22-2019, 11:20 AM
@manitou
Another observation: If i move the new PIT init code in startup.c to after the RTC initialization, the DemoSauce example works even with PIT_MCR = 0. I also modified startup.c in 1.8.8 with 1.47. The results were the same -- either remove PIT_MCR = 0, or move the PIT init code to after the RTC init sequence, e.g. after SNVS_HPCR |= SNVS_HPCR_RTC_EN | SNVS_HPCR_HP_TS;
strange
mjs513
09-22-2019, 12:02 PM
strange
I just gave it a try and works even if you move it right after setArmClock and before the SNVS code block. Maybe not so strange to set the sys clocks first then set the PIT?
bicycleguy
09-22-2019, 08:24 PM
works for me on a Mac also.
thanks
defragster
09-22-2019, 08:42 PM
Having the clocks going first makes sense - @mjs513 - can you post the complete few lines to put after setArmClock()? I keep seeing ref to a line I don't see in what was posted … don't see a pull request for the code
mjs513
09-22-2019, 08:45 PM
This is the entire function:
void ResetHandler(void)
unsigned int i;
#if defined(__IMXRT1062__)
IOMUXC_GPR_GPR17 = (uint32_t)&_flexram_bank_config;
IOMUXC_GPR_GPR16 = 0x00000007;
IOMUXC_GPR_GPR14 = 0x00AA0000;
__asm__ volatile("mov sp, %0" : : "r" ((uint32_t)&_estack) : );
// pin 13 - if startup crashes, use this to turn on the LED early for troubleshooting
//IOMUXC_SW_MUX_CTL_PAD_GPIO_B0_03 = 5;
//IOMUXC_SW_PAD_CTL_PAD_GPIO_B0_03 = IOMUXC_PAD_DSE(7);
//IOMUXC_GPR_GPR27 = 0xFFFFFFFF;
//GPIO7_GDIR |= (1<<3);
//GPIO7_DR_SET = (1<<3); // digitalWrite(13, HIGH);
// Initialize memory
memory_copy(&_stext, &_stextload, &_etext);
memory_copy(&_sdata, &_sdataload, &_edata);
memory_clear(&_sbss, &_ebss);
// enable FPU
SCB_CPACR = 0x00F00000;
// set up blank interrupt & exception vector table
for (i=0; i < NVIC_NUM_INTERRUPTS + 16; i++) _VectorsRam[i] = &unused_interrupt_vector;
for (i=0; i < NVIC_NUM_INTERRUPTS; i++) NVIC_SET_PRIORITY(i, 128);
SCB_VTOR = (uint32_t)_VectorsRam;
reset_PFD();
// Configure clocks
// TODO: make sure all affected peripherals are turned off!
// PIT & GPT timers to run from 24 MHz clock (independent of CPU speed)
CCM_CSCMR1 = (CCM_CSCMR1 & ~CCM_CSCMR1_PERCLK_PODF(0x3F)) | CCM_CSCMR1_PERCLK_CLK_SEL;
// UARTs run from 24 MHz clock (works if PLL3 off or bypassed)
CCM_CSCDR1 = (CCM_CSCDR1 & ~CCM_CSCDR1_UART_CLK_PODF(0x3F)) | CCM_CSCDR1_UART_CLK_SEL;
// Use fast GPIO6, GPIO7, GPIO8, GPIO9
IOMUXC_GPR_GPR26 = 0xFFFFFFFF;
IOMUXC_GPR_GPR28 = 0xFFFFFFFF;
IOMUXC_GPR_GPR29 = 0xFFFFFFFF;
// must enable PRINT_DEBUG_STUFF in debug/print.h
printf_debug_init();
printf("\n***********IMXRT Startup**********\n");
printf("test %d %d %d\n", 1, -1234567, 3);
configure_cache();
configure_systick();
usb_pll_start();
reset_PFD(); //TODO: is this really needed?
set_arm_clock(600000000);
//set_arm_clock(984000000); Ludicrous Speed
// Undo PIT timer usage by ROM startup
PIT_MCR = 0;
PIT_TCTRL0 = 0;
PIT_TCTRL1 = 0;
PIT_TCTRL2 = 0;
PIT_TCTRL3 = 0;
// initialize RTC
if (!(SNVS_LPCR & SNVS_LPCR_SRTC_ENV)) {
// if SRTC isn't running, start it with default Jan 1, 2019
SNVS_LPSRTCLR = 1546300800u << 15;
SNVS_LPSRTCMR = 1546300800u >> 17;
SNVS_LPCR |= SNVS_LPCR_SRTC_ENV;
while (millis() < 20) ; // wait at least 20ms before starting USB
usb_init();
analog_init();
pwm_init();
tempmon_init();
while (millis() < 300) ; // wait at least 300ms before calling user code
//printf("before C++ constructors\n");
__libc_init_array();
//printf("after C++ constructors\n");
//printf("before setup\n");
setup();
//printf("after setup\n");
while (1) {
//printf("loop\n");
loop();
yield();
defragster
09-22-2019, 08:51 PM
Thanks - going to give it a go - it was this line :: PIT_MCR = 0;
I didn't see in post #61 that was letting me know the pieces were not all in one place ...
defragster
09-22-2019, 08:59 PM
With this PIT code in place it starts up:
PIT_MCR = 0;
PIT_TCTRL0 = 0;
PIT_TCTRL1 = 0;
PIT_TCTRL2 = 0;
PIT_TCTRL3 = 0;
Indeed the T4 starts up with uncanny eyes sketch now- but I must need pin and SPI mode adjustments ? as one screen white pulsing under black - the other no signs - but SerMon scrolling data.
slomobile
09-24-2019, 01:45 AM
If you get any messages in red, especially any Java exceptions, please report them on this thread.
This was red. Arduino 1.8.10 TD 1.48 B1 on a Jetson Nano Ubuntu 18.04 AARCH64 first compile after install and reboot.
Sketch was the example for XPT2046_Touchscreen. The next compile attempt worked.
Arduino: 1.8.10 (Linux), TD: 1.48-beta1, Board: "Teensy 4.0, Serial, Faster, US English"
Opening Teensy Loader...
Teensy Loader could not find the directory /tmp/arduino_build_278085
Used: /home/slo/arduino-1.8.10/hardware/teensy/avr/libraries/ILI9341_t3
Used: /home/slo/arduino-1.8.10/hardware/teensy/avr/libraries/SPI
Multiple libraries were found for "XPT2046_Touchscreen.h"
Used: /home/slo/Arduino/libraries/XPT2046_Touchscreen
Not used: /home/slo/arduino-1.8.10/hardware/teensy/avr/libraries/XPT2046_Touchscreen
quitexit status 1
Error compiling for board Teensy 4.0.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
mjs513
09-24-2019, 02:32 AM
Created pull request #394 (https://github.com/PaulStoffregen/cores/pull/394) to move PIT timer code block to after set_arm_clock
Hacky
09-24-2019, 10:09 AM
does the Teensy 4.0 not support fast (hardware) CRC calculation like the Teensy 3.x?
With Teensy 3.x I was using Frank Boesings FastCRC implementation ( https://github.com/FrankBoesing/FastCRC ) which makes use of the FastCRC libraries for AVR.
When I try to compile my code, it seems to switch to the code for software CRC calculation but this compilation terminates due to a missing file in teensy/avr/libraries/FastCRC. The console output is:
Arduino: 1.8.9 (Windows 10), TD: 1.48-beta1, Board: "Teensy 4.0, Serial, Faster, US English"
In file included from C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FastCR C\FastCRCsw.cpp:38:0:
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FastCR C\FastCRC_tables.h:38:23: fatal error: pgmspace.h: No such file or directory
compilation terminated.
manitou
09-24-2019, 11:08 AM
Looks like Teensyduino doesn't have the latest FastCRC. Fetch the latest from https://github.com/FrankBoesing/FastCRC
or change FastCRC_tables.h to read
#if defined(__AVR__ ) || defined(__IMXRT1052__) || defined(__IMXRT1062__)
T4 does have hardware CRC, but it is a fixed polynomial, not as fancy as T3*. FastCRC doesn't support the T4 hardware CRC so will use table-driven CRCs. see
https://forum.pjrc.com/threads/54711-Teensy-4-0-First-Beta-Test?p=197722&viewfull=1#post197722
Hacky
09-25-2019, 05:48 PM
Thank you Manitou. After replacing the FastCRC library in Teensyduino with the latest version from FrankBoesing, the code compiles.
But when the library gets loaded and initialized, it freezes my T4. So even the table driven software CRCs seems not usable at the moment.
manitou
09-25-2019, 06:10 PM
Sigh, that must be the 1.48-beta1 PIT initialization problem discussed earlier in this thread. Try commenting out PIT_MCR = 0 in hardware/teensy/avr/cores/teensy4/startup.c
Hacky
09-25-2019, 06:28 PM
Thanks. After commenting out PIT_MCR = 0 in startup.c it does not freeze anymore.
Which side effects may it cause, when it is not set to 0?
manitou
09-25-2019, 06:48 PM
Another strangeness with 1.48-beta1. Exhibited on 1.8.10 on ubuntu 32-bit and 64-bit running FastCRC benchmark example. Sometimes when running the sketch the last few lines are not printed ?? may happen after a rebuild, or after pushing program button, or after unplug/plug USB ???? Adding while(!Serial) after Serial.begin() seems to cure it.
can anyone else reproduce the problem??
Hacky
09-25-2019, 07:50 PM
I also had this effect one time (last three lines missing) - but with Teensy 3.2 connected.
A FastCRC benchmark comparison between Teensy 3.2 (with hardware CRC) and Teensy 4.0 (table based CRC) is quite interesting:
Teensy 3.2:
CRC Benchmark
F_CPU: 96 MHz, length: 57344 Bytes.
Maxim (iButton) FastCRC: Value:0xD2, Time: 1052 us (436.08 mbs)
Maxim (iButton) builtin: Value:0xD2, Time: 43718 us (10.49 mbs)
MODBUS FastCRC: Value:0x25F1, Time: 1053 us (435.66 mbs)
MODBUS builtin: Value:0x25F1, Time: 47308 us (9.70 mbs)
XMODEM FastCRC: Value:0xB217, Time: 1051 us (436.49 mbs)
XMODEM builtin: Value:0xB217, Time: 47311 us (9.70 mbs)
MCRF4XX FastCRC: Value:0x4BE4, Time: 1049 us (437.32 mbs)
MCRF4XX builtin: Value:0x4BE4, Time: 8392 us (54.67 mbs)
KERMIT FastCRC: Value:0x9137, Time: 1050 us (436.91 mbs)
Ethernet FastCRC: Value:0x29C6653B, Time: 1052 us (436.08 mbs)
Teensy 4.0 (with buffersize set to the same size as for T3.2 for better comparison and uncommented PIT_MCR = 0 in the startup.c):
CRC Benchmark
F_CPU: 600 MHz, length: 57344 Bytes.
Maxim (iButton) FastCRC: Value:0xD2, Time: 674 us (680.64 mbs)
Maxim (iButton) builtin: Value:0xD2, Time: 4111 us (111.59 mbs)
MODBUS FastCRC: Value:0x25F1, Time: 487 us (942.00 mbs)
MODBUS builtin: Value:0x25F1, Time: 5791 us (79.22 mbs)
XMODEM FastCRC: Value:0xB217, Time: 527 us (870.50 mbs)
XMODEM builtin: Value:0xB217, Time: 6507 us (70.50 mbs)
MCRF4XX FastCRC: Value:0x4BE4, Time: 463 us (990.83 mbs)
MCRF4XX builtin: Value:0x4BE4, Time: 957 us (479.36 mbs)
KERMIT FastCRC: Value:0x9137, Time: 300 us (1529.17 mbs)
Ethernet FastCRC: Value:0x29C6653B, Time: 727 us (631.02 mbs)
But I recognized another problem:
The Teensy 4.0 is getting VERY hot and seems to shutdown after some time (serial monitor switches into "disconnected"). The benchmark only runs once in the setup() - is the empty loop() of the benchmark a problem for T4?
The Teensy 3.2 stays cool.
manitou
09-25-2019, 08:11 PM
That shouldn't happen, can you print out chip temperature float tmpc = tempmonGetTemp() in a loop ...
defragster
09-25-2019, 08:13 PM
Have made the PIT change locally ...
Not sure which example? I pulled the github fastcrc and ran FastCRC_Benchmark and it works. Reduced delay in setup to 50ms
Then made a function of the benchmark and called from setup and then loop() each 1.5 secs. It runs once and then repeatedly.
manitou
09-25-2019, 08:19 PM
I can confirm missing FastCRC lines problem occurred with T3.2 with 1.48-beta1. Also seems to be fixed with while(!Serial). I turned on LED at end of benchmark tests to confirm sketch wasn't hanging, and LED is on at end, even though last few lines may not be printed. :confused:
manitou
09-25-2019, 08:25 PM
you need to read the earlier posts in this thread to learn more about PIT initialization.
defragster
09-25-2019, 08:27 PM
I do see something of this - it is buffering of some initial USB print before Serial is online - and the test is complete before Serial is online and the last print doesn't get buffered.
IIRC some beta testing - doing that early print without Serial online delays the arrival of Serial - and buffereing is selective and limited.
Did a quick mod and it indeed gets to loop() before Serial prints at the end - the @437ms was called last as setup() ended and the test was complete.
This is typical behavior when doing .print before Serial is online. Test here is on T4
CRC Benchmark
F_CPU: 600 MHz, length: 1024 Bytes.
Maxim (iButton) FastCRC: Value:0x78, Time: 17 us (481.88 mbs)
Maxim (iButton) builtin: Value:0x78, Time: 74 us (110.70 mbs)
MODBUS FastCRC: Value:0x2487, Time: 160 us (51.20 mbs)
MODBUS builtin: Value:0x2487, Time: 105 us (78.02 mbs)
XMODEM FastCRC: Value:0x190E, Time: 192 us (42.67 mbs)
XMODEM builtin: Value:0x190E, Time: 121 us (67.70 mbs)
MCRF4XX FastCRC: Value:0xF5F5, Time: 191 us (42.89 mbs)
MCRF4XX builtin: Value:0xF5F5, Time: 17 us (481.88 mbs)
KERMIT FastCRC: Value:0x318, Time: 5 us (1638.40 mbs)
IN LOOP() Serial online @741
prior Serial NOT online @437
manitou
09-25-2019, 08:40 PM
Ah, a feature. I'm familiar with losing the first few lines when not using while(!Serial), but i don't think i've seen it print the first few lines and then lose later ones. whatever.
thanks
mjs513
09-25-2019, 08:45 PM
Teensy 3.2:
CRC Benchmark
CRC Benchmark
Just ran the benchmark on my T4 and its actually cooler to the touch than most of the sketches I test. The only way you are going to temperature shutdown is if the internal temperature of the T4 goes over 90degC. As @manitou said can you print out the temperatures during the test.
Hacky
09-25-2019, 08:57 PM
I replaced the empty loop() of the benchmark with the following code to get the temperature printed once a second:
long nextTime = millis() + 1000;
if (millis() > nextTime) {
float tmpc = tempmonGetTemp();
Serial.println("Temp.: " + String(tmpc));
It goes up to about 53C (about 127F).
EDIT: Same with "Blink.ino", when I just add printing the temperature in the loop. Room temperature is about 23C (about 73F).
Is there something wrong with my T4 or do you get the same temperatures?
defragster
09-25-2019, 09:26 PM
My room temp is about 70F. Using a call to p#94 loop() code::
>> One T4 on a breakout is now hitting 50.45C and 51.09C seems near the peak.
>>Another bare board started at 38.7C - and now is into 53.79C
With your ambient 3F warmer it seems that seems consistent/normal.
The external won't measure that hot - that is internal where the localized sensor is placed.
Thermal shutdown PANIC is at 90C.
manitou
09-25-2019, 09:31 PM
i get about the same temperatures. all is well.
dirkenstein
09-28-2019, 08:58 PM
Strange behaviour with Teensy 4.0 1.48-beta1 on 1.8.10 MacOS 10.13. I can't get the Adafruit SSD1306 (1.3.0) library to work unless I set optimise to 'Debug' or 'Smallest Code'. This is using the included demo program ssd1306_128x64_i2c.
Any other setting hangs the usb serial console during initialisation of the Adafruit_SSD1306 class, and no display output occurs.
Any ideas? Thought originally it was Wire/i2c related, but the same noname i2c oled display works just fine with u8g2.
Any suggestions on how to debug this?
mjs513
09-28-2019, 11:31 PM
Yeah. this is probably related to an issued discussed here: https://forum.pjrc.com/threads/57609-Teensyduino-1-48-Beta-1?p=216441&viewfull=1#post216441. A PR has been issued but you can fix it yourself by moving this block of code:
PIT_MCR = 0;
PIT_TCTRL0 = 0;
PIT_TCTRL1 = 0;
PIT_TCTRL2 = 0;
PIT_TCTRL3 = 0; to after this
in startup.c in the teensy4 core files.
slomobile
09-29-2019, 08:39 AM
Same machine as prior post, Jetson Nano, reveals java exceptions when run from terminal.
Its long, hope it helps.
First compile failed because default arduino board was selected.
Not shown: at second slo@sloNano:~$ arduino I opened gui and selected Teensy 4
Command 'arduino' not found, but can be installed with:
sudo apt install arduino
slo@sloNano:~$ export PATH="$PATH:/home/slo/bin/arduino-1.8.10"
slo@sloNano:~$ source ~/.profile
Picked up JAVA_TOOL_OPTIONS:
Set log4j store directory /home/slo/.arduino15
[JmDNS(fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local.).Timer] WARN javax.jmdns.impl.tasks.resolver.DNSResolverTask - ServiceResolver(fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local.).run() exception
java.io.IOException: Cannot assign requested address (sendto failed)
at java.net.PlainDatagramSocketImpl.send(Native Method)
at java.net.DatagramSocket.send(DatagramSocket.java:6 93)
at javax.jmdns.impl.JmDNSImpl.send(JmDNSImpl.java:161 8)
at javax.jmdns.impl.tasks.resolver.DNSResolverTask.ru n(DNSResolverTask.java:73)
at java.util.TimerThread.mainLoop(Timer.java:555)
at java.util.TimerThread.run(Timer.java:505)
[fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local..recover()] WARN javax.jmdns.impl.JmDNSImpl - RECOVERING
[JmDNS(fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local.).State.Timer] WARN javax.jmdns.impl.tasks.state.DNSStateTask - Canceler(fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local.).run() exception
at javax.jmdns.impl.tasks.state.DNSStateTask.run(DNSS tateTask.java:131)
[fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local..recover()] WARN javax.jmdns.impl.DNSStatefulObject$DefaultImplemen tation - Wait for canceled timed out: DNS: fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local. [fe80:0:0:0:5de6:8665:7fcd:96fe%wlan0/fe80:0:0:0:5de6:8665:7fcd:96fe%wlan0] state: canceling 1 task: null
[fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local..recover()] WARN javax.jmdns.impl.JmDNSImpl - fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local..recover() Could not recover we are Down!
2019-09-29T07:53:42.383Z INFO c.a.c.p.ContributionInstaller:305 [Timer-0] Start download and signature check of=[https://downloads.arduino.cc/packages/package_index.json]
2019-09-29T07:53:42.444Z INFO c.a.u.n.FileDownloaderCache:92 [Timer-0] Cache folder /home/slo/.arduino15/cache
2019-09-29T07:53:42.609Z INFO c.a.u.n.FileDownloaderCache:112 [Timer-0] Number of file already in the cache 4
2019-09-29T07:53:42.708Z INFO c.a.u.n.FileDownloaderCache:149 [Timer-0] Get file cached is expire false, exist true, info FileCached{eTag='e5333ff208bec8f067589a99b43a1285' , lastETag='null', remoteURL='https://downloads.arduino.cc/packages/package_index.json', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/packages/package_index.json', md5='MD5:e5333ff208bec8f067589a99b43a1285', createdAt='2019-09-29T02:40:21.973', cacheControl=CacheControl{maxAge=3600, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2019-09-29T07:53:42.734Z INFO c.a.u.n.FileDownloader:210 [Timer-0] No need to download using cached file: FileCached{eTag='e5333ff208bec8f067589a99b43a1285' , lastETag='null', remoteURL='https://downloads.arduino.cc/packages/package_index.json', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/packages/package_index.json', md5='MD5:e5333ff208bec8f067589a99b43a1285', createdAt='2019-09-29T02:40:21.973', cacheControl=CacheControl{maxAge=3600, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2019-09-29T07:53:42.737Z INFO c.a.u.n.FileDownloader:174 [Timer-0] The file will be taken from the cache Optional[/home/slo/.arduino15/cache/downloads.arduino.cc/packages/package_index.json]
2019-09-29T07:53:42.742Z INFO c.a.u.n.FileDownloaderCache:149 [Timer-0] Get file cached is expire false, exist true, info FileCached{eTag='330f326540998b47fa4d733ed5f6eef9' , lastETag='null', remoteURL='https://downloads.arduino.cc/packages/package_index.json.sig', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/packages/package_index.json.sig', md5='MD5:330f326540998b47fa4d733ed5f6eef9', createdAt='2019-09-29T02:40:22.49', cacheControl=CacheControl{maxAge=3600, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2019-09-29T07:53:42.748Z INFO c.a.u.n.FileDownloader:210 [Timer-0] No need to download using cached file: FileCached{eTag='330f326540998b47fa4d733ed5f6eef9' , lastETag='null', remoteURL='https://downloads.arduino.cc/packages/package_index.json.sig', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/packages/package_index.json.sig', md5='MD5:330f326540998b47fa4d733ed5f6eef9', createdAt='2019-09-29T02:40:22.49', cacheControl=CacheControl{maxAge=3600, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2019-09-29T07:53:42.750Z INFO c.a.u.n.FileDownloader:174 [Timer-0] The file will be taken from the cache Optional[/home/slo/.arduino15/cache/downloads.arduino.cc/packages/package_index.json.sig]
2019-09-29T07:53:42.774Z INFO c.a.c.DownloadableContributionsDownloader:222 [Timer-0] Signature verified. url=https://downloads.arduino.cc/packages/package_index.json.sig, signature url=https://downloads.arduino.cc/packages/package_index.json.sig, file to verify=/tmp/package_index.json8311399446740338176.tmp, signature file=/tmp/package_index.json.sig4580471798081923638.tmp
2019-09-29T07:53:42.779Z INFO c.a.c.p.ContributionInstaller:314 [Timer-0] Downloaded package index URL=[https://downloads.arduino.cc/packages/package_index.json]
2019-09-29T07:53:42.787Z INFO c.a.u.n.FileDownloaderCache:149 [Timer-0] Get file cached is expire false, exist true, info FileCached{eTag='6cbd521329168ca1a68348286a8c1bb5' , lastETag='null', remoteURL='https://downloads.arduino.cc/libraries/library_index.json.gz', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json.gz', md5='MD5:6cbd521329168ca1a68348286a8c1bb5', createdAt='2019-09-29T02:40:24.296', cacheControl=CacheControl{maxAge=14400, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2019-09-29T07:53:42.809Z INFO c.a.u.n.FileDownloader:210 [Timer-0] No need to download using cached file: FileCached{eTag='6cbd521329168ca1a68348286a8c1bb5' , lastETag='null', remoteURL='https://downloads.arduino.cc/libraries/library_index.json.gz', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json.gz', md5='MD5:6cbd521329168ca1a68348286a8c1bb5', createdAt='2019-09-29T02:40:24.296', cacheControl=CacheControl{maxAge=14400, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2019-09-29T07:53:42.811Z INFO c.a.u.n.FileDownloader:174 [Timer-0] The file will be taken from the cache Optional[/home/slo/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json.gz]
2019-09-29T07:53:42.932Z INFO c.a.u.n.FileDownloaderCache:149 [Timer-0] Get file cached is expire false, exist true, info FileCached{eTag='3e68f102a17273a8c3bab174740c9d9d' , lastETag='null', remoteURL='https://downloads.arduino.cc/libraries/library_index.json.sig', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json.sig', md5='MD5:3e68f102a17273a8c3bab174740c9d9d', createdAt='2019-09-29T02:40:25.449', cacheControl=CacheControl{maxAge=14400, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2019-09-29T07:53:42.944Z INFO c.a.u.n.FileDownloader:210 [Timer-0] No need to download using cached file: FileCached{eTag='3e68f102a17273a8c3bab174740c9d9d' , lastETag='null', remoteURL='https://downloads.arduino.cc/libraries/library_index.json.sig', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json.sig', md5='MD5:3e68f102a17273a8c3bab174740c9d9d', createdAt='2019-09-29T02:40:25.449', cacheControl=CacheControl{maxAge=14400, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2019-09-29T07:53:42.947Z INFO c.a.u.n.FileDownloader:174 [Timer-0] The file will be taken from the cache Optional[/home/slo/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json.sig]
2019-09-29T07:53:43.155Z INFO c.a.c.DownloadableContributionsDownloader:222 [Timer-0] Signature verified. url=https://downloads.arduino.cc/libraries/library_index.json.sig, signature url=https://downloads.arduino.cc/libraries/library_index.json.sig, file to verify=/tmp/library_index.json6198172837891228961.tmp, signature file=/tmp/library_index.json.sig7258483909988041405.tmp
slo@sloNano:~$ arduino --verify '/home/slo/Arduino/touchscreemTest/touchscreemTest.ino'
Loading configuration...
Initializing packages...
Preparing boards...
Verifying...
touchscreemTest:1:10: error: ILI9341_t3.h: No such file or directory
#include <ILI9341_t3.h>
exit status 1
java.io.IOException: Stream closed
at java.io.BufferedInputStream.getBufIfOpen(BufferedI nputStream.java:170)
at java.io.BufferedInputStream.read(BufferedInputStre am.java:336)
at com.fasterxml.jackson.core.json.ByteSourceJsonBoot strapper.ensureLoaded(ByteSourceJsonBootstrapper.j ava:522)
at com.fasterxml.jackson.core.json.ByteSourceJsonBoot strapper.detectEncoding(ByteSourceJsonBootstrapper .java:150)
at com.fasterxml.jackson.core.json.ByteSourceJsonBoot strapper.constructParser(ByteSourceJsonBootstrappe r.java:246)
at com.fasterxml.jackson.core.JsonFactory._createPars er(JsonFactory.java:1315)
at com.fasterxml.jackson.core.JsonFactory.createParse r(JsonFactory.java:820)
at cc.arduino.packages.discoverers.PluggableDiscovery .run(PluggableDiscovery.java:80)
at java.lang.Thread.run(Thread.java:748)
slo@sloNano:~$ arduino --verify touchscreemTest.ino
Preparing boards...
Verifying...
java.io.IOException: No valid code files found
at processing.app.Sketch.listSketchFiles(Sketch.java: 117)
at processing.app.Sketch.<init>(Sketch.java:54)
at processing.app.Base.<init>(Base.java:415)
at processing.app.Base.main(Base.java:150)
Preparing boards...
Verifying...
Preparing boards...
Verifying...
Sketch uses 59488 bytes (2%) of program storage space. Maximum is 2031616 bytes.
Global variables use 66096 bytes (6%) of dynamic memory, leaving 982480 bytes for local variables. Maximum is 1048576 bytes.
slo@sloNano:~$ arduino --get-pref
Preparing boards...
#PREFDUMP#
last.sketch.count=0
update.check=true
platform.auto_file_type_associations=true
gui.scale=auto
editor.window.width.default=500
editor.window.height.default=600
editor.window.width.min=400
editor.window.height.min=290
editor.code_folding=true
editor.font=Monospaced,plain,12
editor.antialias=true
editor.external=false
editor.caret.blink=true
editor.invalid=false
editor.linenumbers=true
editor.keys.alternative_cut_copy_paste=true
editor.keys.shift_backspace_is_delete=true
editor.keys.home_and_end_beginning_end_of_doc=fals e
console=true
console.output.file=stdout.txt
console.error.file=stderr.txt
console.lines=4
console.auto_clear=true
console.length=500
editor.tabs.expand=true
editor.tabs.size=2
editor.indent=true
editor.auto_close_braces=true
editor.divider.size=0
editor.save_on_verify=true
run.options=
run.options.memory=false
run.options.memory.initial=64
run.options.memory.maximum=256
run.display=1
export.application.platform=true
export.application.fullscreen=false
export.application.stop=true
export.applet.separate_jar_files=false
export.delete_target_folder=true
preproc.save_build_files=false
preproc.color_datatype=true
preproc.web_colors=true
preproc.enhanced_casting=true
preproc.substitute_floats=true
preproc.substitute_unicode=true
preproc.output_parse_tree=false
preproc.imports.list=java.applet.*,java.awt.Dimens ion,java.awt.Frame,java.awt.event.MouseEvent,java. awt.event.KeyEvent,java.awt.event.FocusEvent,java. awt.Image,java.io.*,java.net.*,java.text.*,java.ut il.*,java.util.zip.*,java.util.regex.*
browser=mozilla
run.present.bgcolor=#666666
run.present.stop.color=#cccccc
run.present.exclusive=false
target_package=teensy
target_platform=avr
board=teensy40
software=ARDUINO
build.warn_data_percentage=75
programmer=arduino:avrispmkii
upload.using=bootloader
upload.verify=true
serial.databits=8
serial.stopbits=1
serial.parity=N
serial.debug_rate=9600
serial.line_ending=1
editor.languages.current=
preferences.readonly=false
runtime.ide.path=/home/slo/bin/arduino-1.8.10
runtime.ide.version=10810
boardsmanager.additional.urls=
build.verbose=true
cache.enable=true
compiler.cache_core=true
compiler.warning_level=none
custom_keys=teensy40_en-us
custom_opt=teensy40_o2std
custom_usb=teensy40_serial
editor.update_extension=true
ide.accessible=false
last.ide.1.8.10.daterun=1569744468
last.ide.1.8.10.hardwarepath=/home/slo/bin/arduino-1.8.10/hardware
last.screen.height=768
last.screen.width=1366
last.sketch.default.location=433,84,500,600,404,0
last.sketch.default.path=/tmp/untitled183572571.tmp/sketch_sep29a/sketch_sep29a.ino
launcher=xdg-open
proxy.manual.hostname=
proxy.manual.password=
proxy.manual.port=
proxy.manual.type=HTTP
proxy.manual.username=
proxy.pac.url=
proxy.type=auto
sketchbook.path=/home/slo/Arduino
theme.file=
update.id=7771706390682478081
update.last=1569742762268
upload.verbose=true
runtime.os=linux
runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
runtime.tools.arduino-avr-gcc-7.3.0-atmel3.6.1-arduino5.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
runtime.tools.avr-gcc.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
runtime.tools.avrdude-6.3.0-arduino17.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
runtime.tools.arduino-avrdude-6.3.0-arduino17.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
runtime.tools.avrdude.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
runtime.tools.arduinoOTA-1.3.0.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
runtime.tools.arduino-arduinoOTA-1.3.0.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
runtime.tools.arduinoOTA.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
runtime.platform.path=/home/slo/bin/arduino-1.8.10/hardware/teensy/avr
runtime.hardware.path=/home/slo/bin/arduino-1.8.10/hardware/teensy
teensy: Invalid json message
slo@sloNano:~$
defragster
09-30-2019, 07:04 AM
@Paul - others? Re message posted here : pjrc.com/threads/57701-USB-Host-Ethernet-Driver (https://forum.pjrc.com/threads/57701-USB-Host-Ethernet-Driver?p=217218&viewfull=1#post217218)
Anyone seeing extra stuff rebuilding on Rebuild with IDE 1.8.10 and TD 1.48.b1?
Or added new messages or library during build::
Alternatives for USBHost_t36.h: [USBHost_t36@0.1]
ResolveLibrary(USBHost_t36.h)
-> candidates: [USBHost_t36@0.1]
Or indications of "Multiple libraries" where there is only a single present and no 2nd indicated::
Multiple libraries were found for "ASIXEthernet.h"
Used: T:\tCode\libraries\TeensyASIXEthernet
mjs513
09-30-2019, 11:34 AM
@defragster
I have seen the same thing when I do a verbose compile. From reading the IDE release notes I think that is intentional with the latest IDE.
slomobile
09-30-2019, 04:46 PM
In relation to posts #78 and #99 in this thread, I thought I found a bug in the Arduino CLI or possibly the builder, which I reported here (https://github.com/arduino/Arduino/issues/9266)
I don't yet know the ultimate source of that bug. Because I was running Teensyduino 1.48 b1 at the time it may generate a few red herrings. Sorry about that. This post is just an effort to tie all the information together as I am no longer able to edit the previous posts.
defragster
09-30-2019, 06:17 PM
@defragster
Indeed some fuzzy notes in change logs, they meant to do some changes - problem is indications are:
> Paul's "Multiple libraries were found" work is compromised to give annoying FALSE positives.
> No longer doing Fast Rebuild without redoing stable objects on each rebuild as the added logic is perhaps unclear on non-existent "Alternatives for "
BBUK
10-04-2019, 12:42 PM
Hi all.
Just to confirm that T4 SPI is now working much better for me with the changes to the SPI pin drive strength in this beta. I am using a 1.8V SPI device through level translator and was experiencing some problems.
Thanks
KurtE
10-04-2019, 02:05 PM
NOTE: Today it looks like @Paul has/is releasing Beta2 and it should have these changes now built in.
Along with some other changes, like I believe the change to SPI to work with applications that did not use SPI.beginTransaction on T4...
MichaelMeissner
10-04-2019, 02:31 PM
Talking about SPI, I noticed the SPI page needs to be updated for Teensy 4.0:
https://www.pjrc.com/teensy/td_libs_SPI.html
I don't know if spi4teensy3 is still usefu fpr Teensy 3.x (this is listed on the SPI page)l. It was last updated 2+ years ago to support the T3.5/3.6.
jbrodsky
10-06-2019, 05:51 PM
Hey folks!
I got my teensy 4.0 hooked up to a rev C audio board. I followed the directions on the schematic page. I didn't hook up any of the Volume Pot, SD Card or Memory Chip wires, because I don't have any of those in use.
I am using arduino 1.8.10, with the teensyloader 1.48-beta1.
Things are working fine (not experiencing any audio clock jitter as far as I can tell) - however, I cannot get any audio code to work _unless_ I run analogRead during the setup function:
#include <SerialFlash.h>
AudioSynthWaveform waveform1; //xy=294,323
AudioEffectFreeverbStereo freeverbs1; //xy=592,499
AudioOutputI2S i2s1; //xy=756,481
AudioConnection patchCord1(waveform1, freeverbs1);
AudioConnection patchCord2(freeverbs1, 0, i2s1, 0);
AudioConnection patchCord3(freeverbs1, 1, i2s1, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=805,363
int count=1;
int a1history=0;
// this is the offending line, and I'm not sure why it is necessary
// it can be placed anywhere within setup, it doesn't seem to matter
a1history = analogRead(A1);
AudioMemory(10);
sgtl5000_1.enable();
sgtl5000_1.volume(0.3);
Serial.print("Beep #");
Serial.println(count);
Serial.println(AudioProcessorUsageMax());
AudioProcessorUsageMaxReset();
count = count + 1;
waveform1.frequency(440);
waveform1.amplitude(0.9);
wait(250);
waveform1.amplitude(0);
wait(1750);
void wait(unsigned int milliseconds)
delay(milliseconds);
I tested this with the guitar sample as well, and got the same results (no functioning unless I added analogRead).
When I don't include the analogRead line, and the audio isn't working, the serial monitor fails to work as well, and I can't write new programs without pressing the reset button.
attached shows my setup, which is admittedly a little rough, but just as long as everything is seated right, these results are reproducible.
17823
17824
manitou
10-06-2019, 06:10 PM
1.48-beta1 is haunted by evil spirits. upgrade to 1.48-beta2 or beta3
https://forum.pjrc.com/threads/57894-Teensyduino-1-48-Beta-3
jbrodsky
10-06-2019, 06:52 PM
Issue resolved in beta3! thanks for the quick response.
Maziac
10-12-2019, 11:14 AM
Moved to beta 3 thread.
