teensy 3.6 works great with glediator ( jinx )
buyed a teensy4.0 but having troubles to upload ( arduino 1.8.10 )
but i cant upload , anyone can help ???
Arduino:1.8.11 Hourly Build 2019/09/19 01:33 (Windows 10), Board:"Teensy 4.0, Serial, Faster, US English"
java.io.IOException: Toegang geweigerd
at java.io.WinNTFileSystem.createFileExclusively(Native Method)
at java.io.File.createTempFile(File.java:2024)
at processing.app.BaseNoGui.saveFile(BaseNoGui.java:886)
at processing.app.SketchFile.save(SketchFile.java:287)
at processing.app.Sketch.save(Sketch.java:138)
at processing.app.SketchController.save(SketchController.java:352)
at processing.app.Editor.handleSave2(Editor.java:1928)
at processing.app.Editor.handleSave(Editor.java:1903)
at processing.app.Editor.handleExport(Editor.java:2043)
at processing.app.EditorToolbar.handleSelectionPressed(EditorToolbar.java:498)
at processing.app.EditorToolbar.mousePressed(EditorToolbar.java:448)
at java.awt.Component.processMouseEvent(Component.java:6536)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at java.awt.Component.processEvent(Component.java:6304)
at java.awt.Container.processEvent(Container.java:2239)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2297)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4532)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476)
at java.awt.Container.dispatchEventImpl(Container.java:2283)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
at java.awt.EventQueue$4.run(EventQueue.java:733)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Toegang geweigerd
C:\Users\maus\Documents\Arduino\libraries\OctoWS2811\OctoWS2811.cpp: In member function 'void OctoWS2811::begin()':
C:\Users\maus\Documents\Arduino\libraries\OctoWS2811\OctoWS2811.cpp:85:2: error: 'GPIOD_PCOR' was not declared in this scope
GPIOD_PCOR = 0xFF;
C:\Users\maus\Documents\Arduino\libraries\OctoWS2811\OctoWS2811.cpp:168:19: error: 'GPIOD_PSOR' was not declared in this scope
dma1.destination(GPIOD_PSOR);
C:\Users\maus\Documents\Arduino\libraries\OctoWS2811\OctoWS2811.cpp:175:19: error: 'GPIOD_PDOR' was not declared in this scope
dma2.destination(GPIOD_PDOR);
Meerdere bibliotheken gevonden voor "OctoWS2811.h"
Gebruikt: C:\Users\maus\Documents\Arduino\libraries\OctoWS2811
Niet gebruikt: C:\Program
exit status 1
Fout bij het compileren voor board Teensy 4.0
Dit rapport zou meer informatie bevatten met
"Uitgebreide uitvoer weergeven tijden compilatie"
optie aan in Bestand -> Voorkeuren.
Toegang geweigerd
GPIOD_PCOR = 0xFF;
exit status 1
// Glediator example with OctoWS2811, by mortonkopf
// https://forum.pjrc.com/threads/33012-Gladiator-with-OctoWS2811-working-example
// You can also use Jinx to record Glediator format data to a SD card.
// To play the data from your SD card, use this modified program:
// https://forum.pjrc.com/threads/46229&viewfull=1#post153927
#include <OctoWS2811.h>
const int ledsPerStrip = 34;
const int NUM_LEDS = 272;
DMAMEM int displayMemory[ledsPerStrip*6];
int drawingMemory[ledsPerStrip*6];
const int config = WS2811_GRB | WS2811_800kHz;
OctoWS2811 leds(ledsPerStrip, displayMemory, drawingMemory, config);
leds.begin();
leds.show();
int serialGlediator() {
while (!Serial.available()) {}
return Serial.read();
byte r,g,b;
int i;
while (serialGlediator() != 1) {}
for (i=0; i < NUM_LEDS; i++) {
b = serialGlediator();
r = serialGlediator();
g = serialGlediator();
leds.setPixel(i, Color(r,g,b));
leds.show();
/* Helper functions */
// Create a 24 bit color value from R,G,B
unsigned int Color(byte r, byte g, byte b)
return (((unsigned int)b << 16) | ((unsigned int)r << 8) | (unsigned int)g);
