Cannot compile a simple example with "attachInterrupt" if optimizations are disabled
Hello. Recently I've bumped into an interesting issue. When I'm trying to completely disable all possible optimizations using -O0 flag, the linker complains that "getPinIndex" is missing. Looks like all teensy 3.x boards are affected even in Teensyduino 1.49.
To reproduce the issue, you can add a new menu option, e.g. for teensy31 board:
And try to compile the following sketch:
You'll see the following error message:
A good blog post about this problem.
Any hints are appreciated. Thanks in advance.
teensy31.menu.opt.odebug.build.flags.optimize=-O0
void dummy_cb(){}
attachInterrupt(13, dummy_cb, RISING);
void loop() {}
C:\Users\User\AppData\Local\Temp\arduino_build_969538/core\core.a(pins_teensy.c.o): In function `attachInterrupt':
E:\IDEs\arduino\hardware\teensy\avr\cores\teensy3/pins_teensy.c:225: undefined reference to `getPinIndex'
