View Full Version : Teensyduino 1.52 Beta #1
Paul
03-11-2020, 12:40 PM
Here is a first beta test for Teensyduino 1.52.
Edit: links removed, please use 1.52-beta5 (https://forum.pjrc.com/threads/60864-Teensyduino-1-52-Beta-5).
Changes since Teensyduino 1.51:
USB Audio support for Teensy 4.0
OctoWS2811 ported to Teensy 4.0
WS2812Serial support for RGBW SK6812 LEDs
FreqMeasureMulti ported to Teensy 4.0 (KurtE)
Dual & Triple USB Serial (Geert Uytterhoeven)
Audio support for 4,6,8 channel I2S on Teensy 4.0
Audio support for SPDIF input on Teensy 4.0 (FrankB)
Audio DAC support for Teensy LC (Ben Kurtz)
Audio PWM output for Teensy 4.0 (FrankB)
Fix Serial.print() conflict with USB Touchscreen
Fix contact count on USB Touchscreen (purple-ben)
Defined FLASHMEM on Teensy 3.x, for compatibility with Teensy 4 code (FrankB)
Fix cache handling in I2S audio input on Teensy 4.0 (Frank B)
Fix numerous iMXRT register field defines
MTP USB descriptors on Teensy 4.0 - actual MTP support still WIP
Libraries updated: FlexCAN_t4, ST7735_t3, RA8875
Frank B
03-11-2020, 12:48 PM
The Teensy 4 -Audio PWM output is _not_ ready to use.
Use MQS instead.
PaulStoffregen
03-11-2020, 01:04 PM
Ok. I'll make a point to not document it when I (soon) go through the design tool docs and update most of the others for Teensy 4.0 pins & details.
If you want it removed from the library before a final 1.52, just send another pull request.
Frank B
03-11-2020, 01:14 PM
I don't care. - it is a stub.
There are simply too many unknowns for me to continue working on it. I give that "job" to you or others.
The two generated PWMs respond to the audio - not more, not less. I just hope it is somehow a useful start.
hbit
03-11-2020, 02:29 PM
Hi Paul,
will I²C Slave-Mode for Teensy 4 be part of Teensyduino 1.52?
Regards,
Helmut
PE4WJ
03-11-2020, 02:46 PM
Thanks a lot Paul, I have been eagerly awaiting USB audio support for Teensy 4. Just tried the Linux 64-bit install, and USB audio support works fine.
Wouter Jan PE4WJ
Stendall
03-11-2020, 03:43 PM
Thanks Paul.
I hope you live long and prosper. :)
defragster
03-11-2020, 06:38 PM
1.52b1 install worked no issues over prior IDE 1.8.12.
For some reason my Win 10 system again taking 8+ seconds for TeensyLoader to show - after that message - again?
Opening Teensy Loader...
Unable find Teensy Loader. (p) Is the Teensy Loader application running?
Is a firewall (eg, ZoneAlarm) blocking localhost communication?
<edit>:: Restarted PC after installing Monthly Update:
IDE opens/starts faster and TeensyLoader comes up QUICKLY as it should.
Compile and upload from IDE w/Teensy.exe no problem.
prnthp
03-11-2020, 08:46 PM
I'm getting random crashes on macOS 10.15, presumably after checking the Tools -> Port menu. Is there a log file somewhere I can submit?
Also, I'd like to bring up the RawHID issue ever since TD 1.49 on Teensy 4.0: RawHID-recv()-hangs-after-updating-to-Teensyduino-1-4-9-or-higher-for-Teensy-4-0 (https://forum.pjrc.com/threads/59881-RawHID-recv()-hangs-after-updating-to-Teensyduino-1-4-9-or-higher-for-Teensy-4-0?p=232504&viewfull=1#post232504)
And #include "usb_rawhid.h" seems to be missing in usb.c for Teensy 4.0.
Frank B
03-11-2020, 09:50 PM
Here is a tip on how to use Audio Shield Rev-D and S/PDIF-IN at the same time:
https://github.com/TeensyUser/doc/wiki/Teensy-40-SPDIF-in-and-Audioshield
qenops
03-12-2020, 11:33 PM
I am unable to install on an Nvidia Jetson Nano. This is originally reported in this thread (https://forum.pjrc.com/threads/58332-Jetson-Nano-Teensyduino-1-48-install-fails).
With Arduino 1.8.12 installed and working, I get the following when attempting to install:
david@capture-01:~/Downloads$ ./TeensyduinoInstall.linuxaarch64
Illegal instruction (core dumped)
david@capture-01:~/Downloads$ sudo ./TeensyduinoInstall.linuxaarch64
[sudo] password for david:
Illegal instruction
I haven't ever had it work, but another user reported it to be working with the TD 1.48 Beta 1 release. Is there any way I could get access to that release to verify?
PaulStoffregen
03-13-2020, 03:11 AM
Sure. Use this link to get it.
https://www.pjrc.com/teensy/td_148-beta1/TeensyduinoInstall.linuxaarch64
Please remember to follow up here, to let us know whether this solves the problem for you?
qenops
03-13-2020, 08:05 PM
Thanks. Is that compatible with 1.8.12 or should I go back to 1.8.10?
defragster
03-13-2020, 09:36 PM
1.8.12 support came with 1.51 - so that won't work
Frank B
03-13-2020, 10:27 PM
@Paul, please take care of this:
RawHID.recv() hangs after updating to Teensyduino 1.4.9 or higher for Teensy 4.0 (https://forum.pjrc.com/threads/59881-RawHID-recv()-hangs-after-updating-to-Teensyduino-1-4-9-or-higher-for-Teensy-4-0)
defragster
03-13-2020, 10:46 PM
Indeed - hopefully that made the list when noted on the thread:: Starting-1-52-Beta-Soon (https://forum.pjrc.com/threads/59767-Starting-1-52-Beta-Soon)
Paul: This thread shows details on failures with Teensy 4.0 RawHID:
Two users - at least one suggested client/Teensy code set for repro - on MAC OS. 2nd is pending posting
I just posted there looking for the second set of repro code - hopefully the one there will point to a solution.
qenops
03-14-2020, 03:23 AM
I tried the provided TD 1.48 Beta 1 and it works great. I won't be able to do anything more until Monday, but if you want me to test things then, just let me know.
Saibot
03-14-2020, 10:28 AM
19363
USB Audio working great now with a Teensy 4 and a PCM5102A - thank you very much - as shown in left front of attached workspace picture.
I have noticed that unlike with the Teensy 3.x I cannot select both a USB keyboard and Audio at the same time when the board selection is for a Teensy 4
Is this something that will be added in the future?
I would like to add a USB Volume control to the DAC
Forgive me if I should rather start a new thread somewhere else but our local Teensy supplier here (Micro-robotics South Africa) only has revision B audio boards - therefore the 100 ohm resistor between the Teensy 3.6 and the audioboard in the font right of the picture.
They told me they cannot get stock of the newer rev C boards?
Frank B
03-15-2020, 11:08 AM
For Teensy 4 you want Rev D (https://www.pjrc.com/store/teensy3_audio.html)
WMXZ
03-15-2020, 11:29 AM
But only if you wanted to mount directly.
Using RevB and 100 Ohm in MCLK line should work.
Saibot
03-15-2020, 11:35 AM
Thank you both - yes I have one Rev D audioboard and it works well with the Teensy 4
I am a little bit suspicious of the local supplier who "only" stocks the rev b audioboards - I suspect they want to move their old inventory first...
(Although they ARE selling the rev B boards for 30% cheaper than the rev D boards)
PaulStoffregen
03-15-2020, 02:46 PM
Yup, sounds like they want to get rid of those older shields. 30% off is a pretty good deal if you have Teensy 3.x boards to use. All Teensy 3.x boards work when mounted directly above or below the Rev B audio shields. If you use a few inches of wire between them, Teensy 3.2 and 3.5 work fine, but Teensy 3.6 has higher speed edges on its clock signals which means you need the resistor when using a "long" wire.
Rev B does work with Teensy 4.0 if you add a resistor and of course route the I2S signals to the proper pins with wires. All the Teensy 4 beta testing was done with Rev B boards plugged into the breakout board which has the 100 ohm resistor (https://www.pjrc.com/breakout-board-for-teensy-4-0/). The earliest versions of the breakout board had analog switch chips for I2S1 vs I2S2. They acted as resistors when "on", which is why we didn't discover the 100 ohm resistor issue until about half way through the beta test last year. That led to more testing, which is when we discovered Teensy 3.6 only works with Rev B if the wires are kept short.
I can confirm PJRC currently has plenty of both Rev C and Rev D audio shields in stock.
Rev B is exactly the same as Rev C, except for the extra 100 ohm resistor. 30% off is a pretty nice discount, if you can use those.
Xcoder
03-16-2020, 11:29 AM
Thanks Paul, Will test and give feedback... I was working on a T4 USB Audio implementation whilst waiting on your update, I managed to get IN/OUT/ISOCSYNC working. funny thing is i've only finished it now so I could've just waited.. :D
Frank B
03-20-2020, 08:05 PM
@Paul, can you add the TeensyTimerTool library?
luni
03-20-2020, 08:33 PM
Thanks a lot for the shout out Frank, but unfortunately this is still work in progress. Having it in the core might generate a lot of support requests which I currently can't handle. Meanwhile it is included in the Arduino repository and can be installed from the Arduino library manager.
radias
03-21-2020, 04:35 PM
So i've tested ADAT, SPDIF and USB audio on Teensy 4.0, Windows 10 pro x64 1909 all recent.
Results for type "Audio":
Works only for DirectSound. input output are functional.
Strange behavior in device manager: three endpoints listed under Audio inputs and outputs.
This even after USB oblivion or manual removal of all present and nonpresent entries of teensy.
Soundmapper works input and output, links to DirectSound.
Teensy reports to WASAPI as device, but no input or output channels available at no sample rate or format, no shared, no polled.
Looks like an error in the device descriptor.
WDM streaming fails.
ASIO non existent.
Results for USB type "Serial + MIDI + Audio":
Nothing works.
No trace seen on device manager, no serial port, ni media device, nothing.
To reprogram Teensy4.0 needs pressing the button.
Results for USB type "Serial + MIDIx16 + Audio":
Nothing works.
Same as above.
Audio Library:
PWM Audio not working.
SPDIF output: signal has unstable clock, phase errors >25%. Needs very wide PLL window on input to produce crackle free signal. Nonstandard sample rate.
ADAT output: signal not decodable by E-mu, Motu, Alesis. Unstable word clock, phase lost. Wide window makes no usable channel data.
Sorry to have no good news here.
With older Teensyduino on T3.6 I have the same as the tested projects running in existing hardware, except for ADAT, which I never used with Teensy.
Actually I have no unused T3.6 around to check if things work there, but for T4 :mad:
Frank B
03-21-2020, 05:32 PM
Audio Library:
Yup, that was expected.
Which SPDIF? There are three. Which samplerate did you get?
I'm surprised that it has *any* output. So, someone worked on it?
Edit: Looked at the source. How did you get a signal?
radias
03-21-2020, 05:45 PM
Uh, yes, that may be why. The amplifier of the optical input is running up AGC unil it tries to sync to some noise. But TX LED is on (Edit) or off, shows last state of pin.
SPDIF. Pin 14. Did not check for more.
Actually it changes so fast, the display is not readable. Nominal output should have been 44100.
(Edit) Thought the sound on SPDIF is the sine wave of my test, but actually the output has no relation to the generated data.
Consider not functional.
Frank B
03-21-2020, 05:50 PM
ADAT: I'm still suprised that there is activity on the pin.
Spdif: So, SPDIF3 ? sure?
I test that again, thanks for the Info.
Frank B
03-21-2020, 07:04 PM
SPDIF Question: Are you using a optical connection, or did you build something else?
At the scope it looks ok - have to re-build my hardware first (and find the parts ;) , to do more tests.
radias
03-21-2020, 07:18 PM
Connected a TOTX to Pin 14. It s a used part from a known-good device, as thanx to the C there is nothing else available, except useless time.
It seems to have a schmitt trigger inside which leads to the result of the LED hanging to the last active input, either on or off.
I just did bluntly follow the documentation available on PJRC.com (https://www.pjrc.com/teensy/td_libs_Audio.html), so did not invest more time needed to debug or trace anyting. Actually, like any customer would do.
If Pin 14 is not SPDIF, then it should be noted somewhere.
If ADAT uses a different pin, it should be noted somewhere.
etc...
Frank B
03-21-2020, 07:22 PM
Ok, as I read some days ago that it worked for an other user, I'll do no test and assume your test was wrong. ok?
We all know the documentation is wrong and unusable for T4-Audio.
Not working PWM was noted on the first page of this thread.
There are three SPDIFs, the third is on PIN 14, yes.
Edit: PS: Feel free to fix ADAT for T4* - you seem to have the Hardware. Neither Paul nor I, nor anybody else I know seems to have it. So, we can not work on it.
*or any other problems.
radias
03-21-2020, 07:46 PM
A beta test requires some kind of beta documentation somewhere. If things have to be trailed by testers and there are assumptions on a crystal bowl involved, it is not even an alpha trest. So my test had no chance to be right. Good. And out.
Frank B
03-21-2020, 07:57 PM
Agreed.
I have some time tomorrow. If I feel like it, I'll fork the GUI and create a T4-Variant.
Not sure about that, since it is a lot of work and I have no Idea if that would ever be merged.
(in contrast my PWM-Stub that _not_ should have been merged as I noted on many different places):confused:
Frank B
03-21-2020, 08:52 PM
I've tested it. At least it works with a cheap $10 SPDIF->Analog converter :)
I've attached my Sketch.
#if !SPDIF_NATIVE
AudioOutputSPDIF spdif1; //Pin 7
AudioOutputSPDIF2 spdif2; //Pin 2
#else
AudioOutputSPDIF3 spdif3; //Pin 14
Seems that the SPDIF via I2S (AudioOutputSPDIF, AudioOutputSPDIF2) does not play nice together with the native port, AudioOutputSPDIF3
Not sure why, and I don't know if I can fix that. Any ideas?
19438
radias
03-21-2020, 09:29 PM
I've dug through the source code. Quite cryptic, but doable at least to some extent. So I understand it is no parity generated, no frames marked, actually even not closed.
At the end it may be the reason why it works on a 10 Euro chingchang DAC, but other equipment would reject.
Also, there is a 50/50 chance the channels get swapped without notice and recovery, if for some reason sync gets lost on a single frame.
If the signal contains any kind of noise (broken/pinched fiber, too long, plug not fit), the DAC will produce screaming noise, because parity and validity must not be used to check the data, before producing them to the ear.
AES interoperability not possible, because AES equipment is normally more strict than the chingchang DAC.
Right? Did I miss anything?
Sorry, I have no pure S/PDIF"light" equipment to test the signal.
PE4WJ
03-21-2020, 09:39 PM
Hi Paul,
I seem to be running into a bug related to USB audio, after programming, Teensy loader gives a message "error sending reboot command", and I manually need to press the button on the Teensy to make it reboot every time I program it. After that, USB audio (both input and output) work fine.
The issue does not appear when loading code that does not use USB audio.
Wouter Jan PE4WJ
Frank B
03-21-2020, 09:44 PM
Right?
No, not anything. For SPDIF3, this is all done in hardware, for the others in software. Parity is there, frame markers are there, you can mute the signal (of course not automatically) - uses the valid flag.
yes. all :)
Oh, and it works on my 900€ receiver, too, and never heard of anyone - at least on t3 - who had problems (only with the 41117Hz samplerate on t3). Be sure: you're not the first who uses it :)
For T4 there can be bugs - quite possible. Please report them if they are reproducabl - but no blind guesses, please.
radias
03-21-2020, 09:51 PM
Hi Paul,
Wouter Jan PE4WJ
Same here.
Plus the other issues with USB audio from post233510 (https://forum.pjrc.com/threads/59996-Teensyduino-1-52-Beta-1?p=233510&viewfull=1#post233510)
radias
03-21-2020, 10:01 PM
yes. all :)
I was not writing about SPDIF3 "Hardware", but about the SPDIF and SPDIF2 emulations in software. The hardware part of T4 should be standard if calling itself S/PDIF. Obviously the tool is not usable for this any more. Te crystal ball did not show that.
Frank B
03-21-2020, 10:02 PM
It's not true for the emulations, too. Yes, put your crystal ball away.
If there are any problems, please fix them instead wasting time for blind guesses.
Would be nice if you fix ADAT for T4. You're one of the few users who have ADAT hardware.
radias
03-21-2020, 10:18 PM
As I do not understand anything, I seriously doubt that I am able to make ADAT work. :p
Please, it would be much more needed to have the documentation and the "Audio System Design Tool for Teensy Audio Library" adjusted to avoid any useless guesses.
Frank B
03-21-2020, 10:21 PM
Agreed, the documentation is a known issue.
Frank B
03-22-2020, 02:38 AM
@others:
As we can not help with the website (which does not even mention the Teensy 4 on many places), it would be good to help with the WIKI (https://github.com/TeensyUser/doc/wiki) and add missing information there.
Frank B
03-22-2020, 01:44 PM
Thread: Audio Gui for T4 (https://forum.pjrc.com/threads/60109-Audio-GUI-for-T4?p=233585#post233585)
An Idea how to solve it.
Preview here: https://frankboesing.github.io/T4_Audio_Design_Tool/
radias
03-22-2020, 02:23 PM
So I've figured out the different pins of S/PDIF on T4. And it is working. Thanks @Frank B
Still, ADAT I canot get to work. It compiles, but no usable signal on the new pin, which should be also Pin 7, like at SPDIF, not 22. Still WIP.
Is there the error somewhere?
void AudioOutputADAT::config_ADAT(void)
CCM_CCGR5 |= CCM_CCGR5_SAI1(CCM_CCGR_ON);
//PLL:
int fs = AUDIO_SAMPLE_RATE_EXACT;
// PLL between 27*24 = 648MHz und 54*24=1296MHz
int n1 = 4; //SAI prescaler 4 => (n1*n2) = multiple of 4
int n2 = 1 + (24000000 * 27) / (fs * 256 * n1);
double C = ((double)fs * 256 * n1 * n2) / 24000000;
int c0 = C;
int c2 = 10000;
int c1 = C * c2 - (c0 * c2);
set_audioClock(c0, c1, c2);
CCM_CSCMR1 = (CCM_CSCMR1 & ~(CCM_CSCMR1_SAI1_CLK_SEL_MASK))
| CCM_CSCMR1_SAI1_CLK_SEL(2); // &0x03 // (0,1,2): PLL3PFD0, PLL5, PLL4
n1 = n1 / 2; // speed up x2
| CCM_CS1CDR_SAI1_CLK_PRED(n1-1) // &0x07
| CCM_CS1CDR_SAI1_CLK_PODF(n2-1); // &0x3f
IOMUXC_GPR_GPR1 = (IOMUXC_GPR_GPR1 & ~(IOMUXC_GPR_GPR1_SAI1_MCLK1_SEL_MASK))
| (IOMUXC_GPR_GPR1_SAI1_MCLK_DIR | IOMUXC_GPR_GPR1_SAI1_MCLK1_SEL(0)); //Select MCLK
int rsync = 0;
int tsync = 1;
// configure transmitter
I2S1_TMR = 0;
I2S1_TCR1 = I2S_TCR1_RFW(0); // watermark
I2S1_TCR2 = I2S_TCR2_SYNC(tsync) | I2S_TCR2_MSEL(1) | I2S_TCR2_BCD | I2S_TCR2_DIV(0);
I2S1_TCR3 = I2S_TCR3_TCE;
I2S1_TCR4 = I2S_TCR4_FRSZ(7) | I2S_TCR4_SYWD(0) | I2S_TCR4_MF | I2S_TCR4_FSP | I2S_TCR4_FSD;
I2S1_TCR5 = I2S_TCR5_WNW(31) | I2S_TCR5_W0W(31) | I2S_TCR5_FBT(31);
//I2S1_RCSR = 0;
I2S1_RMR = 0;
//I2S1_RCSR = (1<<25); //Reset
I2S1_RCR1 = I2S_RCR1_RFW(0);
I2S1_RCR2 = I2S_RCR2_SYNC(rsync) | I2S_TCR2_MSEL(1) | I2S_TCR2_BCD | I2S_TCR2_DIV(0);
I2S1_RCR3 = I2S_RCR3_RCE;
I2S1_RCR4 = I2S_TCR4_FRSZ(7) | I2S_TCR4_SYWD(0) | I2S_TCR4_MF | I2S_TCR4_FSP | I2S_TCR4_FSD;
I2S1_RCR5 = I2S_TCR5_WNW(31) | I2S_TCR5_W0W(31) | I2S_TCR5_FBT(31);
#if 0
//debug only:
CORE_PIN23_CONFIG = 3; //1:MCLK 11.43MHz
CORE_PIN21_CONFIG = 3; //1:RX_BCLK 5.6 MHz
CORE_PIN20_CONFIG = 3; //1:RX_SYNC 44.1 KHz
// CORE_PIN6_CONFIG = 3; //1:TX_DATA0
// CORE_PIN7_CONFIG = 3; //1:RX_DATA0
The problem is, I don't have access to my scope, because of the general curfew.
Frank B
03-22-2020, 07:54 PM
Yup, I'm sure the pins were not easy to find in post#35 ;)
Maybe try to add CORE_PIN7_CONFIG = 3; somewhere.
Looks like the comment re: core_pin_7 config in the code fragment above is not 100% OK
radias
03-22-2020, 09:58 PM
Is this code fragment correct by means of selecting the right clock speed, which is twice the SPDIF speed, and frame length, wich is 256 instead of 128 bit.
Is this piece of code correct?
You are the big master of the SPDIF code, on which the code of ADAT is based on, so you should know.
The NRZI frames etc, I've just checked, they are ok, but do not appear on the Pin 7.
As written, without my scope, which I don't have in the house at the moment, and is out of reach for the coming months due to corona restrictions, I can not extensively check the signal on the Pin 7, frequency or the clock itself or packet geometry. I can just see on the Alesis if there is a carrier if it is within limits, but for now it is not, so that may be the first to check.
To exclude the TOTX, I've also substituted a AlGaAs LED connected directly via 330 Ohm. It works for S/PDIF and the LED has plenty of bandwith and power headroom.
And yes, the CORE_PIN7_CONFIG = 3; is set in AudioOutputADAT::begin(void), so like in the SPDIF code.
ED: All righty. Will make other thread once progress happens.
Frank B
03-22-2020, 11:17 PM
yes that looks correct.
Frank B
03-22-2020, 11:22 PM
...please open an other thread for this.
You need to use DMAMEM and add some cache handling like in the SPDIF Code!
Edit: Choosing
means that the input for podf is slightly out of spec - it should be max 300MHz according to datasheet - it is 338MHz with n1/2. But my scope shows that it is OK (measured on enabled MCLK pin 23 -> 22.579 MHz)
The way you did it is good, because it does not change the PLL frequency which is used by other devices (i2s#2, spdif, etc), too
radias
03-23-2020, 12:12 AM
Again, thanks a lot. So that should work like expected. The frequency is precise to the theroretical 256*44100*2. Now I'm going to find the issue in the rest of the code. I'll open another thread once there is any progress and post the final code to be included in TD.
NuWaveIT
03-25-2020, 09:32 PM
I just downloaded the 1.52 beta and tried to build a simple Audio example using Teensy LC. It gives an error in red within the IDE:
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ input_adc.cpp: In static member function 'static void AudioInputAnalog::isr()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ input_adc.cpp:119:2: warning: 'daddr' is used uninitialized in this function [-Wuninitialized]
if (daddr < (uint32_t)analog_rx_buffer + sizeof(analog_rx_buffer) / 2) {
I can provide the full verbose output if needed. Here is the sketch I was trying to build:
#include <SerialFlash.h>
AudioSynthWaveform waveform1; //xy=456,2172
AudioOutputAnalog dac1; //xy=686,2188
AudioConnection patchCord1(waveform1, dac1);
AudioMemory(20);
waveform1.begin(0.5, 200, WAVEFORM_SAWTOOTH);
I get the same result when building with any of the example sketches. If I try with a Teensy 4.0, it all works OK. Please let me know how I can help.
Thanks,
Steve
Frank B
03-25-2020, 09:34 PM
..and what is your reason to ask this here in this 1.52 beta thread? And, please use the code-tags next time! :)
The Audio Library is not officially supported by the Teensy LC.
NuWaveIT
03-25-2020, 09:38 PM
Actually, there's a lot more red output, so here's the whole thing (sorry if it's too long):
Arduino: 1.8.12 (Windows 10), TD: 1.52-beta1, Board: "Teensy LC, Serial, 48 MHz, Smallest Code, US English"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\steve.corn\AppData\Local\Arduino15\packag es -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\steve.corn\AppData\Local\Arduino15\packag es -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\steve.corn\Documents\Arduino\libraries -fqbn=teensy:avr:teensyLC:usb=serial,speed=48,opt=o sstd,keys=en-us -ide-version=10812 -build-path C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340 -warnings=none -build-cache C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_ca che_54073 -verbose C:\SteveCorn\NuWave-GitLab\arduino\test-LC-audio\test-LC-audio.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\steve.corn\AppData\Local\Arduino15\packag es -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\steve.corn\AppData\Local\Arduino15\packag es -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\steve.corn\Documents\Arduino\libraries -fqbn=teensy:avr:teensyLC:usb=serial,speed=48,opt=o sstd,keys=en-us -ide-version=10812 -build-path C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340 -warnings=none -build-cache C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_ca che_54073 -verbose C:\SteveCorn\NuWave-GitLab\arduino\test-LC-audio\test-LC-audio.ino
Using board 'teensyLC' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Using core 'teensy3' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340\\sketch\\test-LC-audio.ino.cpp" -o nul
Alternatives for Audio.h: [Audio@1.3]
ResolveLibrary(Audio.h)
-> candidates: [Audio@1.3]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340\\sketch\\test-LC-audio.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340\\sketch\\test-LC-audio.ino.cpp" -o nul
Alternatives for SD.h: [SD@1.2.4 SD@1.2.2]
ResolveLibrary(SD.h)
-> candidates: [SD@1.2.4 SD@1.2.2]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340\\sketch\\test-LC-audio.ino.cpp" -o nul
Alternatives for SerialFlash.h: [SerialFlash@0.5]
ResolveLibrary(SerialFlash.h)
-> candidates: [SerialFlash@0.5]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340\\sketch\\test-LC-audio.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340\\sketch\\test-LC-audio.ino.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\analyze_fft1024.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\analyze_fft256.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\analyze_notefreq.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\analyze_peak.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\analyze_print.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\analyze_rms.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\analyze_tonedetect.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\control_ak4558.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\control_cs42448.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\control_cs4272.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\control_sgtl5000.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\control_tlv320aic3206.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\control_wm8731.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\data_spdif.c" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\data_ulaw.c" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\data_waveforms.c" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\data_windows.c" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\effect_bitcrusher.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\effect_chorus.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\effect_combine.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\effect_delay.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\effect_delay_ext.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\effect_envelope.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\effect_fade.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\effect_flange.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\effect_freeverb.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\effect_granular.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\effect_midside.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\effect_multiply.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\effect_reverb.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\effect_waveshaper.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\filter_biquad.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\filter_fir.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\filter_variable.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\input_adc.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\input_adcs.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\input_i2s.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\input_i2s2.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\input_i2s_hex.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\input_i2s_oct.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\input_i2s_quad.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\input_pdm.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\input_spdif3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\input_tdm.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\input_tdm2.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\memcpy_audio.S" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\mixer.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\output_adat.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\output_dac.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\output_dacs.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\output_i2s.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\output_i2s2.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\output_i2s_hex.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\output_i2s_oct.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\output_i2s_quad.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\output_mqs.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\output_pt8211.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\output_pt8211_2.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\output_pwm.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\output_spdif.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\output_spdif2.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\output_spdif3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\output_tdm.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\output_tdm2.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\play_memory.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\play_queue.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\play_sd_raw.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\play_sd_wav.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\play_serialflash_raw.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\record_queue.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\spi_interrupt.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\synth_dc.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\synth_karplusstrong.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\synth_pinknoise.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\synth_pwm.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\synth_simple_drum.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\synth_sine.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\synth_tonesweep.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\synth_waveform.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\synth_wavetable.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\synth_whitenoise.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility\\imxrt_hw.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility\\sqrt_integer.c" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI\\SPI.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\File.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\SD.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\cache_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\card_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\dir_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\fat_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\file_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\init_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility\\NXP_SDHC.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility\\Sd2Card.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility\\SdFile.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility\\SdVolume.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash\\SerialFlashChip.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash\\SerialFlashDirectory.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire\\Wire.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire\\WireIMXRT.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire\\WireKinetis.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire\\utility\\twi.c" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340\\sketch\\test-LC-audio.ino.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340\\preproc\\ctags_target_for_gcc_mi nus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340\\preproc\\ctags_target_for_gcc_mi nus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/precompile_helper" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340/pch/Arduino.h" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340/pch/Arduino.h.gch"
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\pch\Arduino.h.gch
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ard uino_build_598340/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340\\sketch\\test-LC-audio.ino.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340\\sketch\\test-LC-audio.ino.cpp.o"
Compiling libraries...
Compiling library "Audio"
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\memcpy_audio.S.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\data_ulaw.c.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\data_windows.c.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\data_spdif.c.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\data_waveforms.c.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\analyze_print.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\analyze_peak.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\control_ak4558.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\analyze_fft1024.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\analyze_rms.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\analyze_notefreq.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\analyze_tonedetect.cpp. o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\analyze_fft256.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\control_sgtl5000.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\control_cs42448.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\effect_combine.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\control_wm8731.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\control_cs4272.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\effect_delay.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\effect_delay_ext.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\effect_bitcrusher.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\effect_envelope.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\effect_fade.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\effect_granular.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\effect_freeverb.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\effect_chorus.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\effect_multiply.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\effect_flange.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\filter_biquad.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\effect_reverb.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\effect_midside.cpp.o
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ard uino_build_598340/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\input_adc.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340\\libraries\\Audio\\input_adc.cpp. o"
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\effect_waveshaper.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\filter_fir.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\control_tlv320aic3206.c pp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\input_adcs.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\input_i2s.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\filter_variable.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\input_i2s2.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\input_i2s_hex.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\input_i2s_oct.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\input_tdm2.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\input_spdif3.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\input_tdm.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\input_pdm.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\output_dacs.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\input_i2s_quad.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\output_i2s2.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\mixer.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\output_i2s.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\output_dac.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\output_mqs.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\output_i2s_hex.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\output_adat.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\output_i2s_oct.cpp.o
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ard uino_build_598340/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\output_pt8211.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340\\libraries\\Audio\\output_pt8211. cpp.o"
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\output_i2s_quad.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\output_pt8211_2.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\output_pwm.cpp.o
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ard uino_build_598340/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\output_spdif.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340\\libraries\\Audio\\output_spdif.c pp.o"
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\output_spdif3.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_598340\libraries\Audio\output_spdif2.cpp.o
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ard uino_build_598340/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\output_tdm2.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340\\libraries\\Audio\\output_tdm2.cp p.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ard uino_build_598340/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\output_tdm.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340\\libraries\\Audio\\output_tdm.cpp .o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ard uino_build_598340/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\play_memory.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340\\libraries\\Audio\\play_memory.cp p.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ard uino_build_598340/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\play_queue.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340\\libraries\\Audio\\play_queue.cpp .o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ard uino_build_598340/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\play_sd_raw.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340\\libraries\\Audio\\play_sd_raw.cp p.o"
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ input_adc.cpp: In static member function 'static void AudioInputAnalog::isr()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ input_adc.cpp:119:2: warning: 'daddr' is used uninitialized in this function [-Wuninitialized]
if (daddr < (uint32_t)analog_rx_buffer + sizeof(analog_rx_buffer) / 2) {
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_spdif.cpp: In static member function 'static void AudioOutputSPDIF::isr()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_spdif.cpp:141:25: error: 'class DMAChannel' has no member named 'TCD'
saddr = (uint32_t)(dma.TCD->SADDR);
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_spdif.cpp:176:26: error: 'PREAMBLE_B' was not declared in this scope
*(dest+0) = vucp | (PREAMBLE_B << 16 ) | aux; //special preamble for one of 192 frames
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_spdif.cpp:179:25: error: 'PREAMBLE_M' was not declared in this scope
*(dest+0) = vucp | (PREAMBLE_M << 16 ) | aux;
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_spdif.cpp:225:26: error: 'PREAMBLE_W' was not declared in this scope
*(dest+0) = vucp | (PREAMBLE_W << 16 ) | aux;
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_spdif.cpp: In static member function 'static void AudioOutputSPDIF::mute_PCM(bool)':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_spdif.cpp:256:14: error: 'VUCP_INVALID' was not declared in this scope
vucp = mute?VUCP_INVALID:VUCP_VALID;
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_spdif.cpp:256:27: error: 'VUCP_VALID' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_spdif.cpp: At global scope:
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_spdif.cpp:449:6: error: redefinition of 'void AudioOutputSPDIF::update()'
void AudioOutputSPDIF::update(void)
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_spdif.cpp:259:6: note: 'virtual void AudioOutputSPDIF::update()' previously defined here
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_pt8211.cpp: In static member function 'static void AudioOutputPT8211::isr()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_pt8211.cpp:116:25: error: 'class DMAChannel' has no member named 'TCD'
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_tdm.cpp: In static member function 'static void AudioOutputTDM::isr()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_tdm.cpp:132:25: error: 'class DMAChannel' has no member named 'TCD'
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ard uino_build_598340/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\play_sd_wav.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_598340\\libraries\\Audio\\play_sd_wav.cp p.o"
C:\Users\STEVE~1.COR\AppData\Local\Temp\ccLCsLIP.s : Assembler messages:
C:\Users\STEVE~1.COR\AppData\Local\Temp\ccLCsLIP.s :291: Error: selected processor does not support `smull r0,ip,r3,r5' in Thumb mode
C:\Users\STEVE~1.COR\AppData\Local\Temp\ccLCsLIP.s :292: Error: shifts in CMP/MOV instructions are only supported in unified syntax -- `mov ip,ip,asl r6'
C:\Users\STEVE~1.COR\AppData\Local\Temp\ccLCsLIP.s :293: Error: unshifted register required -- `orr r0,ip,r0,lsr r7'
Multiple libraries were found for "SD.h"
Used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
Not used: C:\Program Files (x86)\Arduino\libraries\SD
Using library Audio at version 1.3 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI
Using library SD at version 1.2.2 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
Using library SerialFlash at version 0.5 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Serial Flash
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire
Error compiling for board Teensy LC.
NuWaveIT
03-25-2020, 09:39 PM
I thought a new feature of 1.52 was that it adds support for Teensy LC and Audio/DAC output, according to the first post of the thread from Paul?
Frank B
03-25-2020, 09:40 PM
Looks like we have to add some more #ifdefs to audio.h and the rest of the code.
NuWaveIT
03-25-2020, 09:42 PM
Then I am confused by the post from Paul that clearly states:
Changes since Teensyduino 1.51:
USB Audio support for Teensy 4.0
OctoWS2811 ported to Teensy 4.0
WS2812Serial support for RGBW SK6812 LEDs
FreqMeasureMulti ported to Teensy 4.0 (KurtE)
Dual & Triple USB Serial (Geert Uytterhoeven)
Audio support for 4,6,8 channel I2S on Teensy 4.0
Audio support for SPDIF input on Teensy 4.0 (FrankB)
Audio DAC support for Teensy LC (Ben Kurtz)
Audio PWM output for Teensy 4.0 (FrankB)
Fix Serial.print() conflict with USB Touchscreen
Fix contact count on USB Touchscreen (purple-ben)
Defined FLASHMEM on Teensy 3.x, for compatibility with Teensy 4 code (FrankB)
Fix cache handling in I2S audio input on Teensy 4.0 (Frank B)
Fix numerous iMXRT register field defines
MTP USB descriptors on Teensy 4.0 - actual MTP support still WIP
Libraries updated: FlexCAN_t4, ST7735_t3, RA8875
Frank B
03-25-2020, 09:47 PM
I have no Idea what is supported by the LC, and what not. I'd say 90% of the library will not work on LC.
The errorlog above mentions a ccLCsLIP.s - what is that?
NuWaveIT
03-25-2020, 09:49 PM
No idea, and the file is no longer present, guess it's in the "Temp" folder for a reason...
Frank B
03-25-2020, 09:58 PM
I'll try to fix the warnings and errors.
NuWaveIT
03-25-2020, 10:01 PM
I'll try to fix the warnings and erros.
Cool, thanks
Frank B
03-25-2020, 10:06 PM
The last one (ccLCsLIP.s) comes from dspinst.h
First would be to add the red lines to dspinst.h (in folder "utility")
#if defined (__ARM_ARCH_7EM__)
// Multiply two S.31 fractional integers, and return the 32 most significant
// bits after a shift left by the constant z.
// This comes from rockbox.org
static inline int32_t FRACMUL_SHL(int32_t x, int32_t y, int z)
int32_t t, t2;
asm ("smull %[t], %[t2], %[a], %[b]\n\t"
"mov %[t2], %[t2], asl %[c]\n\t"
"orr %[t], %[t2], %[t], lsr %[d]\n\t"
: [t] "=&r" (t), [t2] "=&r" (t2)
: [a] "r" (x), [b] "r" (y),
[c] "Mr" ((z) + 1), [d] "Mr" (31 - (z)));
return t;
#else
return (int32_t) (((int64_t)x * y) >> (31 - z));
I'll do a pullrequest for this and the other errors tomorrow.
PaulStoffregen
03-25-2020, 10:53 PM
To be honest, I merged this pull request without any testing, other than making sure it didn't break anything on Teensy 3.x and 4.0. Since nothing has worked on LC, it didn't seem like much risk.
Actually trying this on LC, and a conversation on github about 22 vs 44 kHz sample rate are on a long list of things I need to review. But at the rate things are going (employees at home, PJRC down to just Robin & me) and working on a test fixture at this moment, it's unlikely I'll manage to look at this anytime soon. I wish I had a nicer answer for you, but I only have this honest one.
defragster
03-25-2020, 11:02 PM
Paul - has enough changed that you plan to do a Beta #2 on any schedule?
Frank B
03-25-2020, 11:33 PM
@NuWaveIT:
Please test if this compiles:
https://github.com/FrankBoesing/Audio/archive/LC.zip
PaulStoffregen
03-25-2020, 11:39 PM
Does "on hold" or "paused" count as a schedule?
Realistically, that's the situation right now as Robin & I struggle to keep PJRC running without 2 employees.
defragster
03-26-2020, 12:03 AM
Yes, just wondered if it was one of the things seen as a worthy distraction from what else you can do. Good luck with the rest of what is on your plates.
NuWaveIT
03-26-2020, 02:00 PM
I appreciate it Paul. I had no expectation that LC would support Audio, but got excited when I saw the post. I have a T4 with Audio Shield which works great. I'll try to get to trying Frank's code change at some point, possibly this afternoon.
Speaking musically, IMO, if using the Audio library's "analog" synth oscillators, it should be OK to limit the sample rate to 22KHz, since you cannot hear anything above that freq anyway. In the project I am building, using MIDI notes 0 - 127, the full freq range is 8Hz - 16KHz, but the bulk of the notes are within the 4KHz or lower range. I cannot imagine getting an audible difference between 22KHz and 44KHz. That's my 2 cents...
Thanks!
wcalvert
03-27-2020, 06:01 PM
22kHz sample rate means the maximum frequency that can be reconstructed is 11kHz. Google for Nyquist sampling theorem or Nyquist rate for more info.
jensa
03-27-2020, 10:30 PM
On OSX Catalina (versions 10.15.2 - 10.15.4), Teensyduino (1.51 and 1.52 beta) will appear to work until you open a menu. It takes a few seconds and then the program disappears. Starting from command line provided the enclosed error log (ZIP format) and below is the OSX system log dump. I currently cannot use Teensyduino and other software prevent me from downgrading OSX to an older version than Catalina.
Is there anything I can do to help resolve this issue?
Process: Arduino [4023]
Path: /Applications/Arduino.app/Contents/MacOS/Arduino
Identifier: cc.arduino.Arduino
Version: 1.8.12 (1.8.12)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Arduino [4023]
User ID: 502
Date/Time: 2020-03-27 21:52:37.305 +0100
OS Version: Mac OS X 10.15.4 (19E266)
Report Version: 12
Bridge OS Version: 4.4 (17P4263)
Anonymous UUID: DD6841D6-539B-086F-3BA7-D7778AB76291
Sleep/Wake UUID: 032FDDDA-308C-4D8A-9585-5077E01CA2BB
Time Awake Since Boot: 1400 seconds
Time Since Wake: 700 seconds
System Integrity Protection: enabled
Crashed Thread: 25 Java: Java2D Queue Flusher
Exception Type: EXC_BAD_INSTRUCTION (SIGABRT)
Exception Codes: 0x0000000000000001, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
-[NSOpenGLContext setView:] must be called from the main thread.
Thread 0:: AppKit Thread Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff73f06dfa mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff73f07170 mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff39e7e0b5 __CFRunLoopServiceMachPort + 247
3 com.apple.CoreFoundation 0x00007fff39e7cb82 __CFRunLoopRun + 1319
4 com.apple.CoreFoundation 0x00007fff39e7bffe CFRunLoopRunSpecific + 462
5 com.apple.Foundation 0x00007fff3c5102a8 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 212
6 libawt_lwawt.dylib 0x00000001100c2a19 Java_sun_lwawt_macosx_LWCToolkit_doAWTRunLoopImpl + 314
7 ??? 0x000000011398ffad 0 + 4623761325
8 ??? 0x00000001139682bd 0 + 4623598269
9 ??? 0x00000001139682bd 0 + 4623598269
10 ??? 0x00000001139682bd 0 + 4623598269
11 ??? 0x0000000113960671 0 + 4623566449
12 libjvm.dylib 0x0000000108d52127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
13 libjvm.dylib 0x0000000108d6e1ef jni_invoke_nonstatic(JNIEnv_*, JavaValue*, _jobject*, JNICallType, _jmethodID*, JNI_ArgumentPusher*, Thread*) + 1638
14 libjvm.dylib 0x0000000108d76055 jni_CallVoidMethodV + 542
15 JavaNativeFoundation 0x00007fff3e78d9c2 JNFCallVoidMethod + 175
16 libosxui.dylib 0x000000010e6bc4eb -[NativeToJavaDelegate menuWillOpen:] + 120
17 com.apple.AppKit 0x00007fff3777ebce -[NSMenu _sendMenuOpeningNotification:] + 106
18 com.apple.AppKit 0x00007fff374fda11 -[NSCarbonMenuImpl _carbonOpenEvent:handlerCallRef:] + 195
19 com.apple.AppKit 0x00007fff3742ea19 NSSLMMenuEventHandler + 1197
20 com.apple.HIToolbox 0x00007fff38a888ff DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1254
21 com.apple.HIToolbox 0x00007fff38a87d8d SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 329
22 com.apple.HIToolbox 0x00007fff38a87c3d SendEventToEventTargetWithOptions + 45
23 com.apple.HIToolbox 0x00007fff38b0c5db SendMenuOpening(MenuSelectData*, MenuData*, double, unsigned int, unsigned int, __CFDictionary*, unsigned char, unsigned char*) + 482
24 com.apple.HIToolbox 0x00007fff38b24ff6 DrawTheMenu(MenuSelectData*, __CFArray**, unsigned char, unsigned char*) + 286
25 com.apple.HIToolbox 0x00007fff38b24dbe MenuChanged(MenuSelectData*, unsigned char, unsigned char) + 535
26 com.apple.HIToolbox 0x00007fff38c319f4 TrackMenuCommon(MenuSelectData&, unsigned char*, SelectionData*, MenuResult*, MenuResult*) + 992
27 com.apple.HIToolbox 0x00007fff38b247a0 MenuSelectCore(MenuData*, Point, double, unsigned int, OpaqueMenuRef**, unsigned short*) + 365
28 com.apple.HIToolbox 0x00007fff38b24598 _HandleMenuSelection2 + 460
29 com.apple.AppKit 0x00007fff372d186d _NSHandleCarbonMenuEvent + 215
30 com.apple.AppKit 0x00007fff372d16da _DPSEventHandledByCarbon + 54
31 com.apple.AppKit 0x00007fff370f9b2a -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:deque ue:] + 2962
32 libosxapp.dylib 0x000000010e8dfd2e -[NSApplicationAWT nextEventMatchingMask:untilDate:inMode:dequeue:] + 121
33 com.apple.AppKit 0x00007fff370eb1ee -[NSApplication run] + 658
34 libosxapp.dylib 0x000000010e8dfb73 +[NSApplicationAWT runAWTLoopWithApp:] + 219
35 libsplashscreen.dylib 0x000000010e8acb16 __SplashInitPlatform_block_invoke + 70
36 JavaNativeFoundation 0x00007fff3e790ff9 +[JNFRunLoop _performCopiedBlock:] + 15
37 com.apple.Foundation 0x00007fff3c54b1bd __NSThreadPerformPerform + 204
38 com.apple.CoreFoundation 0x00007fff39e7df12 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FU NCTION__ + 17
39 com.apple.CoreFoundation 0x00007fff39e7deb1 __CFRunLoopDoSource0 + 103
40 com.apple.CoreFoundation 0x00007fff39e7dccb __CFRunLoopDoSources0 + 209
41 com.apple.CoreFoundation 0x00007fff39e7c9fa __CFRunLoopRun + 927
42 com.apple.CoreFoundation 0x00007fff39e7bffe CFRunLoopRunSpecific + 462
43 libjli.dylib 0x0000000106c78621 CreateExecutionEnvironment + 875
44 libjli.dylib 0x0000000106c74c1b JLI_Launch + 1878
45 cc.arduino.Arduino 0x0000000106c4a166 launch + 8838
46 cc.arduino.Arduino 0x0000000106c47d9f main + 143
47 cc.arduino.Arduino 0x0000000106c47d04 start + 52
Thread 1:
0 libsystem_kernel.dylib 0x00007fff73f0855e __ulock_wait + 10
1 libsystem_pthread.dylib 0x00007fff73fcb5c2 _pthread_join + 347
2 libjli.dylib 0x0000000106c78d61 ContinueInNewThread0 + 129
3 libjli.dylib 0x0000000106c77453 ContinueInNewThread + 170
4 libjli.dylib 0x0000000106c75881 JLI_Launch + 5052
7 libjli.dylib 0x0000000106c793cc apple_main + 84
8 libsystem_pthread.dylib 0x00007fff73fca109 _pthread_start + 148
9 libsystem_pthread.dylib 0x00007fff73fc5b8b thread_start + 15
Thread 2:
0 libsystem_kernel.dylib 0x00007fff73f09882 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff73fca425 _pthread_cond_wait + 698
2 libjvm.dylib 0x0000000108fc8237 os::PlatformEvent::park() + 297
3 libjvm.dylib 0x0000000108f836a2 ParkCommon(ParkEvent*, long) + 59
4 libjvm.dylib 0x0000000108f83e43 Monitor::IWait(Thread*, long) + 219
5 libjvm.dylib 0x0000000108f84d2c Monitor::wait(bool, long, bool) + 586
6 libjvm.dylib 0x0000000109108b36 Threads::destroy_vm() + 140
7 libjvm.dylib 0x0000000108da1477 jni_DestroyJavaVM + 425
8 libjli.dylib 0x0000000106c762c4 JavaMain + 1746
9 libsystem_pthread.dylib 0x00007fff73fca109 _pthread_start + 148
10 libsystem_pthread.dylib 0x00007fff73fc5b8b thread_start + 15
Thread 3:
5 libjvm.dylib 0x0000000108f84cb5 Monitor::wait(bool, long, bool) + 467
6 libjvm.dylib 0x0000000108c7ccec GCTaskManager::get_task(unsigned int) + 252
7 libjvm.dylib 0x0000000108c7e45e GCTaskThread::run() + 462
8 libjvm.dylib 0x0000000108fc2ee7 java_start(Thread*) + 250
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:: Java: VM Thread
2 libjvm.dylib 0x0000000108fc56b9 os::PlatformEvent::park(long) + 529
3 libjvm.dylib 0x0000000108f83e43 Monitor::IWait(Thread*, long) + 219
4 libjvm.dylib 0x0000000108f84cb5 Monitor::wait(bool, long, bool) + 467
5 libjvm.dylib 0x0000000109188ec9 VMThread::loop() + 1169
6 libjvm.dylib 0x00000001091888f6 VMThread::run() + 202
7 libjvm.dylib 0x0000000108fc2ee7 java_start(Thread*) + 250
Thread 14:: Java: Reference Handler
3 libjvm.dylib 0x0000000108fb55e7 ObjectMonitor::wait(long, bool, Thread*) + 1013
4 libjvm.dylib 0x00000001090ccbc8 ObjectSynchronizer::wait(Handle, long, Thread*) + 562
5 libjvm.dylib 0x0000000108dce715 JVM_MonitorWait + 519
6 ??? 0x000000011398ffad 0 + 4623761325
7 ??? 0x0000000113d8e744 0 + 4627949380
8 ??? 0x0000000113960671 0 + 4623566449
9 libjvm.dylib 0x0000000108d52127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
10 libjvm.dylib 0x0000000108d50966 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 626
11 libjvm.dylib 0x0000000108d50bb3 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 111
12 libjvm.dylib 0x0000000108dea739 thread_entry(JavaThread*, Thread*) + 177
13 libjvm.dylib 0x0000000109101963 JavaThread::thread_main_inner() + 373
14 libjvm.dylib 0x00000001091016ff JavaThread::run() + 847
15 libjvm.dylib 0x0000000108fc2ee7 java_start(Thread*) + 250
16 libsystem_pthread.dylib 0x00007fff73fca109 _pthread_start + 148
17 libsystem_pthread.dylib 0x00007fff73fc5b8b thread_start + 15
Thread 15:: Java: Finalizer
6 ??? 0x0000000113f56ecf 0 + 4629819087
7 ??? 0x0000000113d91ce4 0 + 4627963108
Thread 16:: Java: Signal Dispatcher
0 libsystem_kernel.dylib 0x00007fff73f06e36 semaphore_wait_trap + 10
1 libjvm.dylib 0x0000000108fc458e check_pending_signals(bool) + 200
2 libjvm.dylib 0x0000000108fbe41b signal_thread_entry(JavaThread*, Thread*) + 52
Thread 17:: Java: C2 CompilerThread0
4 libjvm.dylib 0x0000000108f84dd0 Monitor::wait(bool, long, bool) + 750
5 libjvm.dylib 0x0000000108b631d1 CompileQueue::get() + 131
6 libjvm.dylib 0x0000000108b664cd CompileBroker::compiler_thread_loop() + 497
7 libjvm.dylib 0x0000000109101963 JavaThread::thread_main_inner() + 373
8 libjvm.dylib 0x00000001091016ff JavaThread::run() + 847
9 libjvm.dylib 0x0000000108fc2ee7 java_start(Thread*) + 250
10 libsystem_pthread.dylib 0x00007fff73fca109 _pthread_start + 148
11 libsystem_pthread.dylib 0x00007fff73fc5b8b thread_start + 15
Thread 18:: Java: C2 CompilerThread1
Thread 19:: Java: C2 CompilerThread2
Thread 20:: Java: C1 CompilerThread3
Thread 21:: Java: Service Thread
6 libjvm.dylib 0x0000000109061e1e ServiceThread::service_thread_entry(JavaThread*, Thread*) + 258
Thread 22:: Java: VM Periodic Task Thread
5 libjvm.dylib 0x000000010910033e WatcherThread::sleep() const + 110
6 libjvm.dylib 0x00000001091004e2 WatcherThread::run() + 296
Thread 23:: com.apple.NSEventThread
5 com.apple.AppKit 0x00007fff3729c5b4 _NSEventThread + 132
Thread 24:: Java: process reaper
2 libjvm.dylib 0x0000000108fc882c Parker::park(bool, long) + 1186
3 libjvm.dylib 0x000000010913761b Unsafe_Park + 430
4 ??? 0x00000001147b0c51 0 + 4638575697
5 ??? 0x00000001139682bd 0 + 4623598269
6 ??? 0x00000001139682bd 0 + 4623598269
7 ??? 0x0000000113968040 0 + 4623597632
8 ??? 0x0000000113968040 0 + 4623597632
9 ??? 0x0000000113968114 0 + 4623597844
10 ??? 0x0000000113968040 0 + 4623597632
11 ??? 0x00000001139682bd 0 + 4623598269
12 ??? 0x0000000113968302 0 + 4623598338
13 ??? 0x0000000113960671 0 + 4623566449
14 libjvm.dylib 0x0000000108d52127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
15 libjvm.dylib 0x0000000108d50966 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 626
16 libjvm.dylib 0x0000000108d50bb3 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 111
17 libjvm.dylib 0x0000000108dea739 thread_entry(JavaThread*, Thread*) + 177
18 libjvm.dylib 0x0000000109101963 JavaThread::thread_main_inner() + 373
19 libjvm.dylib 0x00000001091016ff JavaThread::run() + 847
20 libjvm.dylib 0x0000000108fc2ee7 java_start(Thread*) + 250
21 libsystem_pthread.dylib 0x00007fff73fca109 _pthread_start + 148
22 libsystem_pthread.dylib 0x00007fff73fc5b8b thread_start + 15
Thread 25 Crashed:: Java: Java2D Queue Flusher
0 libsystem_kernel.dylib 0x00007fff73f0d33a __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fff73fc9e60 pthread_kill + 430
2 libsystem_c.dylib 0x00007fff73e94808 abort + 120
3 libjvm.dylib 0x00000001091a68ca os::abort(bool) (.cold.1) + 125
4 libjvm.dylib 0x0000000108fc355b os::abort(bool) + 33
5 libjvm.dylib 0x000000010915c8a6 VMError::report_and_die() + 2298
6 libjvm.dylib 0x0000000108bb82d3 report_vm_error(char const*, int, char const*, char const*) + 93
7 libjvm.dylib 0x0000000108fc8fa8 os::get_sender_for_C_frame(frame*) + 76
8 libjvm.dylib 0x0000000108bb9524 print_native_stack(outputStream*, frame, Thread*, char*, int) + 336
9 libjvm.dylib 0x000000010915b703 VMError::report(outputStream*) + 2617
10 libjvm.dylib 0x000000010915c387 VMError::report_and_die() + 987
11 libjvm.dylib 0x0000000108fc93b7 JVM_handle_bsd_signal + 802
12 libjvm.dylib 0x0000000108fc5f0f signalHandler(int, __siginfo*, void*) + 88
13 libsystem_platform.dylib 0x00007fff73fbe5fd _sigtramp + 29
14 libobjc.A.dylib 0x00007fff72c12954 lookUpImpOrForward + 63
15 libawt_lwawt.dylib 0x00000001100a8239 CGLSD_MakeCurrentToScratch + 93
16 libawt_lwawt.dylib 0x00000001100a8390 OGLSD_MakeOGLContextCurrent + 166
17 libawt_lwawt.dylib 0x00000001100c5e32 OGLContext_SetSurfaces + 188
18 libawt_lwawt.dylib 0x00000001100ca69f Java_sun_java2d_opengl_OGLRenderQueue_flushBuffer + 1775
19 ??? 0x00000001148190d1 0 + 4639002833
20 ??? 0x000000011489bbe4 0 + 4639538148
21 ??? 0x0000000113960671 0 + 4623566449
22 libjvm.dylib 0x0000000108d52127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
23 libjvm.dylib 0x0000000108d50966 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 626
24 libjvm.dylib 0x0000000108d50bb3 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 111
25 libjvm.dylib 0x0000000108dea739 thread_entry(JavaThread*, Thread*) + 177
26 libjvm.dylib 0x0000000109101963 JavaThread::thread_main_inner() + 373
27 libjvm.dylib 0x00000001091016ff JavaThread::run() + 847
28 libjvm.dylib 0x0000000108fc2ee7 java_start(Thread*) + 250
29 libsystem_pthread.dylib 0x00007fff73fca109 _pthread_start + 148
30 libsystem_pthread.dylib 0x00007fff73fc5b8b thread_start + 15
Thread 26:: Java: Java2D Disposer
8 ??? 0x0000000113968302 0 + 4623598338
9 ??? 0x0000000113960671 0 + 4623566449
10 libjvm.dylib 0x0000000108d52127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
11 libjvm.dylib 0x0000000108d50966 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 626
12 libjvm.dylib 0x0000000108d50bb3 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 111
13 libjvm.dylib 0x0000000108dea739 thread_entry(JavaThread*, Thread*) + 177
14 libjvm.dylib 0x0000000109101963 JavaThread::thread_main_inner() + 373
15 libjvm.dylib 0x00000001091016ff JavaThread::run() + 847
16 libjvm.dylib 0x0000000108fc2ee7 java_start(Thread*) + 250
17 libsystem_pthread.dylib 0x00007fff73fca109 _pthread_start + 148
18 libsystem_pthread.dylib 0x00007fff73fc5b8b thread_start + 15
Thread 27:: Java: cc.arduino.packages.discoverers.serial.SerialDisco very
3 libjvm.dylib 0x0000000108fb5587 ObjectMonitor::wait(long, bool, Thread*) + 917
7 ??? 0x00000001139682bd 0 + 4623598269
Thread 28:: Java: Multihomed mDNS.Timer
Thread 29:: Java: SocketListener(10-0-0-20.local.)
0 libsystem_kernel.dylib 0x00007fff73f0a3a6 __recvfrom + 10
1 libnet.dylib 0x000000010e5d6167 NET_RecvFrom + 135
2 libnet.dylib 0x000000010e5d2457 Java_java_net_PlainDatagramSocketImpl_receive0 + 449
3 ??? 0x0000000113991d3c 0 + 4623768892
4 ??? 0x00000001139682bd 0 + 4623598269
7 ??? 0x0000000113960671 0 + 4623566449
8 libjvm.dylib 0x0000000108d52127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
9 libjvm.dylib 0x0000000108d50966 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 626
10 libjvm.dylib 0x0000000108d50bb3 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 111
11 libjvm.dylib 0x0000000108dea739 thread_entry(JavaThread*, Thread*) + 177
12 libjvm.dylib 0x0000000109101963 JavaThread::thread_main_inner() + 373
13 libjvm.dylib 0x00000001091016ff JavaThread::run() + 847
14 libjvm.dylib 0x0000000108fc2ee7 java_start(Thread*) + 250
15 libsystem_pthread.dylib 0x00007fff73fca109 _pthread_start + 148
16 libsystem_pthread.dylib 0x00007fff73fc5b8b thread_start + 15
Thread 30:: Java: JmDNS(10-0-0-20.local.).Timer
Thread 31:: Java: JmDNS(10-0-0-20.local.).State.Timer
Thread 32:: Java: JmmDNS pool-3-thread-1
4 ??? 0x000000011398ffad 0 + 4623761325
Thread 33:: Java: Batik CleanerThread
Thread 34:: Java: MarlinRenderer Disposer
Thread 35:: Java: AWT-Shutdown
7 ??? 0x0000000113ef46d4 0 + 4629415636
Thread 36:: Java: AWT-EventQueue-0
7 ??? 0x000000011489afa4 0 + 4639535012
8 ??? 0x00000001146dfed4 0 + 4637720276
10 ??? 0x0000000113967a90 0 + 4623596176
12 ??? 0x00000001139682bd 0 + 4623598269
13 ??? 0x00000001139682bd 0 + 4623598269
14 ??? 0x0000000113968040 0 + 4623597632
15 ??? 0x0000000113960671 0 + 4623566449
16 libjvm.dylib 0x0000000108d52127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
17 libjvm.dylib 0x0000000108dd71a4 JVM_DoPrivileged + 2657
18 ??? 0x000000011453a0bc 0 + 4635992252
19 ??? 0x0000000113cf48bc 0 + 4627318972
20 ??? 0x00000001139682bd 0 + 4623598269
21 ??? 0x00000001139682bd 0 + 4623598269
22 ??? 0x00000001139682bd 0 + 4623598269
23 ??? 0x00000001139682bd 0 + 4623598269
24 ??? 0x00000001147af144 0 + 4638568772
25 libjvm.dylib 0x0000000108d52127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
26 libjvm.dylib 0x0000000108dd71a4 JVM_DoPrivileged + 2657
27 ??? 0x000000011453a0bc 0 + 4635992252
28 ??? 0x00000001145d64ac 0 + 4636632236
29 ??? 0x00000001139682bd 0 + 4623598269
30 ??? 0x00000001139682bd 0 + 4623598269
31 ??? 0x00000001139682bd 0 + 4623598269
32 ??? 0x00000001139682bd 0 + 4623598269
33 ??? 0x0000000113960671 0 + 4623566449
34 libjvm.dylib 0x0000000108d52127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
35 libjvm.dylib 0x0000000108d50966 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 626
36 libjvm.dylib 0x0000000108d50bb3 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 111
37 libjvm.dylib 0x0000000108dea739 thread_entry(JavaThread*, Thread*) + 177
38 libjvm.dylib 0x0000000109101963 JavaThread::thread_main_inner() + 373
39 libjvm.dylib 0x00000001091016ff JavaThread::run() + 847
40 libjvm.dylib 0x0000000108fc2ee7 java_start(Thread*) + 250
41 libsystem_pthread.dylib 0x00007fff73fca109 _pthread_start + 148
42 libsystem_pthread.dylib 0x00007fff73fc5b8b thread_start + 15
Thread 37:: Java: TimerQueue
7 ??? 0x0000000113967e15 0 + 4623597077
9 ??? 0x0000000113968302 0 + 4623598338
10 ??? 0x0000000113960671 0 + 4623566449
11 libjvm.dylib 0x0000000108d52127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
12 libjvm.dylib 0x0000000108d50966 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 626
13 libjvm.dylib 0x0000000108d50bb3 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 111
14 libjvm.dylib 0x0000000108dea739 thread_entry(JavaThread*, Thread*) + 177
15 libjvm.dylib 0x0000000109101963 JavaThread::thread_main_inner() + 373
16 libjvm.dylib 0x00000001091016ff JavaThread::run() + 847
17 libjvm.dylib 0x0000000108fc2ee7 java_start(Thread*) + 250
18 libsystem_pthread.dylib 0x00007fff73fca109 _pthread_start + 148
19 libsystem_pthread.dylib 0x00007fff73fc5b8b thread_start + 15
Thread 38:
0 libsystem_pthread.dylib 0x00007fff73fc5b68 start_wqthread + 0
Thread 39:
Thread 40:
Thread 41:
Thread 42:: Java: Image Fetcher 0
Thread 25 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000700002fb3000 rcx: 0x0000700002fb1518 rdx: 0x0000000000000000
rdi: 0x0000000000013d07 rsi: 0x0000000000000006 rbp: 0x0000700002fb1540 rsp: 0x0000700002fb1518
r8: 0x0000000000000010 r9: 0x0000700002fb1550 r10: 0x0000700002fb3000 r11: 0x0000000000000246
r12: 0x0000000000013d07 r13: 0x0000700002fb16c0 r14: 0x0000000000000006 r15: 0x0000000000000016
rip: 0x00007fff73f0d33a rfl: 0x0000000000000246 cr2: 0x00000001091a5644
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
Binary Images:
0x106c47000 - 0x106c4bfff +cc.arduino.Arduino (1.8.12 - 1.8.12) <2AE2040B-3408-3208-B101-5825B8F425F0> /Applications/Arduino.app/Contents/MacOS/Arduino
0x106c73000 - 0x106c7cfff +libjli.dylib (0) <212562B4-111E-35D6-BB2B-A1BFD63A5B64> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/jli/libjli.dylib
0x1088a6000 - 0x10933ffff +libjvm.dylib (0) <31202E71-A956-3765-B4D6-876A7D4FFBD9> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/server/libjvm.dylib
0x109ccc000 - 0x109cd4fff +libverify.dylib (0) <B8F4EBC4-811F-33AD-BB9A-2C4B148C8C6D> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libverify.dylib
0x109cdf000 - 0x109cfdfff +libjava.dylib (0) <32138414-C5B3-3330-8911-97D6CD983944> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libjava.dylib
0x109d2d000 - 0x109d31fff +libzip.dylib (0) <346621C0-4ADF-3E59-A9AA-76CC581A12F0> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libzip.dylib
0x10e5b4000 - 0x10e5bafff +libnio.dylib (0) <1FB68BF9-1173-3A83-A617-15DA017AD812> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libnio.dylib
0x10e5cc000 - 0x10e5d9fff +libnet.dylib (0) <B9072F4C-3145-3661-9DBE-8AECB4DF85DB> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libnet.dylib
0x10e6b9000 - 0x10e6bdfff +libosxui.dylib (0) <298413FC-09E2-3331-8821-E08823132ED9> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libosxui.dylib
0x10e877000 - 0x10e8b3ff3 +libsplashscreen.dylib (0) <F8DFB9AF-1758-3CB3-8ECF-A40AF50AEFE2> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libsplashscreen.dylib
0x10e8dd000 - 0x10e8e2fff +libosxapp.dylib (0) <44AA406A-BF46-3779-8247-5363068551AC> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libosxapp.dylib
0x10fdb6000 - 0x10fe10ff3 +libawt.dylib (0) <F9DD7DEF-AB6A-3718-9314-73F7B227B709> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libawt.dylib
0x10fea3000 - 0x10ff4dff7 +libmlib_image.dylib (0) <9474B2D4-5C83-3AED-A17D-155AC6A1292F> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libmlib_image.dylib
0x11008e000 - 0x1100edff3 +libawt_lwawt.dylib (0) <4D83B9A4-989F-3D85-BA5E-F0208BEB2F86> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libawt_lwawt.dylib
0x11016c000 - 0x11016f047 libobjc-trampolines.dylib (787.1) <CCA8AC98-12A2-3984-ACD6-1D77DAD6C0AD> /usr/lib/libobjc-trampolines.dylib
0x1103c3000 - 0x1103d4ff7 +liblistSerialsj.dylib (0) <9652E9D9-1D2A-37ED-982B-F222108D70FF> /Applications/Arduino.app/Contents/Java/lib/liblistSerialsj.dylib
0x1103dd000 - 0x110415ff3 +libfontmanager.dylib (0) <DF7F570B-A725-35D6-AD41-D00755395693> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libfontmanager.dylib
0x11045e000 - 0x1104f7ff7 +libfreetype.dylib.6 (0) <D7022DC9-4783-3993-97D4-A548688EF098> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libfreetype.dylib.6
0x11067e000 - 0x110684fff +libosx.dylib (0) <65FD3A00-CBF7-3B4C-95AA-041E9A8A0907> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libosx.dylib
0x11086c000 - 0x110932ff7 com.apple.AMDRadeonX4000GLDriver (3.8.24 - 3.0.8) <C8948AD2-CFF9-31A6-95B9-F2E0A8068EF0> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
0x11385b000 - 0x1138eceff dyld (750.5) <1F893B81-89A5-3502-8510-95B97B9F730D> /usr/lib/dyld
0x14f7ff000 - 0x14f819ff3 +libsunec.dylib (0) <43F0DC3E-70CC-3F3C-A260-25C03EAA8E36> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libsunec.dylib
0x14fc31000 - 0x14fc34ffb +libmanagement.dylib (0) <8413F67C-85D3-3B3C-9FC2-75A0B470A96C> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libmanagement.dylib
0x15289a000 - 0x1528d5fff +libastylej.dylib (0) <906AC4F1-6792-3FBA-A552-EF8D40DBEA1B> /Applications/Arduino.app/Contents/Java/lib/libastylej.dylib
0x153c64000 - 0x153c72ff7 +libJTouchBar.dylib4957522234097849858 (0) <E9801EEC-0090-3848-8C4B-8335665DFE26> /var/folders/*/libJTouchBar.dylib4957522234097849858
0x7fff2ce7a000 - 0x7fff2d0c7ff8 com.apple.RawCamera.bundle (9.01.0 - 1340.28) <3249E1E0-D226-3219-BFF2-22F85C39BB6D> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff2d0ca000 - 0x7fff2d1f7ff8 com.apple.AMDMTLBronzeDriver (3.8.24 - 3.0.8) <15983EE9-C22E-3979-BDB1-51682FFE9442> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
0x7fff2d1f8000 - 0x7fff2d22efff ATIRadeonX4000SCLib.dylib (3.8.24) <FC75895C-348F-3C26-B82F-6E17FFF0E63C> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib
0x7fff2e743000 - 0x7fff2f0fbff3 libSC.dylib (3.8.24) <3A787392-149B-3C17-8257-ECB04A04A1B7> /System/Library/Extensions/AMDShared.bundle/Contents/PlugIns/libSC.dylib
0x7fff31800000 - 0x7fff32807fff com.apple.driver.AppleIntelKBLGraphicsGLDriver (14.5.22 - 14.0.5) <4C6C15C9-6C8E-3E84-911D-D000FB94794D> /System/Library/Extensions/AppleIntelKBLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsGLDriver
0x7fff32808000 - 0x7fff32c07ff1 com.apple.driver.AppleIntelKBLGraphicsMTLDriver (14.5.22 - 14.0.5) <0BB14CF6-CA95-34B0-B454-0AB95C5D4CF6> /System/Library/Extensions/AppleIntelKBLGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsMTLDriver
0x7fff35a8e000 - 0x7fff35a8efff com.apple.Accelerate (1.11 - Accelerate 1.11) <8BE0965F-6A6A-35B0-89D0-F0A75835C2CA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff35a8f000 - 0x7fff35aa5fff libCGInterfaces.dylib (524.2) <9092665A-D5C7-3ED8-A7D5-9216B48F8E3E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff35aa6000 - 0x7fff360fcfef com.apple.vImage (8.1 - 524.2) <DAE0E5C5-BA70-325D-8B4C-6B821F009CBF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff360fd000 - 0x7fff36364ff7 libBLAS.dylib (1303.60.1) <4E980D6B-4B3A-33D6-B52C-AFC7D120D11A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff36365000 - 0x7fff36838fef libBNNS.dylib (144.100.2) <C05F9F9D-4498-37BD-9C1C-2F7B920B401D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff36839000 - 0x7fff36bd4fff libLAPACK.dylib (1303.60.1) <F8E9D081-7C60-32EC-A47D-2D30CAD73C5F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff36bd5000 - 0x7fff36beafec libLinearAlgebra.dylib (1303.60.1) <79CB28C5-F811-3EAF-AD8E-7D7D879FE662> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff36beb000 - 0x7fff36bf0ff3 libQuadrature.dylib (7) <EB7C9E98-D1E7-314C-90B4-3EB04428CC7C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff36bf1000 - 0x7fff36c61fff libSparse.dylib (103) <8C55F5F2-6AE3-393C-B2FF-22B8CFCBD7FC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff36c62000 - 0x7fff36c74fef libSparseBLAS.dylib (1303.60.1) <08F6D629-5DAC-3A99-B261-2B6095DD38B4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff36c75000 - 0x7fff36e4cfd7 libvDSP.dylib (735.100.4) <0744F29B-F822-3571-9B4A-B592146D4E03> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff36e4d000 - 0x7fff36f0ffef libvMisc.dylib (735.100.4) <E6C94B52-931B-3858-AF4D-C2EA52ACB7F5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff36f10000 - 0x7fff36f10fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <66282197-81EE-316F-978E-EF1471551DEF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff36f11000 - 0x7fff36f70ff0 com.apple.Accounts (113 - 113) <4B85E422-169E-396D-898A-DD1A7715EC6D> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff370ba000 - 0x7fff37e79ff5 com.apple.AppKit (6.9 - 1894.40.150) <FDDF35FF-4007-3F0B-B59C-03CFF3A0A73B> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff37ec9000 - 0x7fff37ec9fff com.apple.ApplicationServices (48 - 50) <CABCF23C-55E5-35E1-AAF0-EE5DDE3FDB03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff37eca000 - 0x7fff37f35fff com.apple.ApplicationServices.ATS (377 - 493.0.4.1) <6AA4BBCC-43AF-3EBF-8EB5-7916A3B563AA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff37fce000 - 0x7fff3800cff0 libFontRegistry.dylib (274.0.4.2) <FBF6EC26-42C0-334E-B67C-871AD50DB0BC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff38067000 - 0x7fff38096fff com.apple.ATSUI (1.0 - 1) <D8C604E9-D854-3A32-B37B-819197537A63> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
0x7fff38097000 - 0x7fff3809bffb com.apple.ColorSyncLegacy (4.13.0 - 1) <2359E2CD-8FCE-32D7-AF76-F4D9A3D9D9F8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff38135000 - 0x7fff3818cffa com.apple.HIServices (1.22 - 675.1) <B2DEE96F-ED7A-3924-A2E2-44BB7A950BD8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff3818d000 - 0x7fff3819bfff com.apple.LangAnalysis (1.7.0 - 1.7.0) <1603F2CC-DC51-3E15-B6B5-0A9F9AB0C045> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff3819c000 - 0x7fff381e1ffa com.apple.print.framework.PrintCore (15.4 - 516.2) <525E8A4B-297B-3CAC-8A4A-6C7E211D7A21> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff381e2000 - 0x7fff381ecff7 com.apple.QD (4.0 - 413) <1EAEF5BC-D649-3E42-87BC-43CCEE4D5274> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff381ed000 - 0x7fff381faffc com.apple.speech.synthesis.framework (9.0.24 - 9.0.24) <C2E5BBFC-2EF0-3FFE-A1CF-960631DC249C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff381fb000 - 0x7fff382dcffa com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <4222CBDF-D637-30DB-BA45-C6E222BABB24> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff382de000 - 0x7fff382defff com.apple.audio.units.AudioUnit (1.14 - 1.14) <73D89D5E-05D5-3F64-BE02-2B2ED6AD6C03> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff38671000 - 0x7fff389ffffd com.apple.CFNetwork (1125.2 - 1125.2) <1D4D81F7-FC48-3588-87FC-481E2586E345> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff38a7b000 - 0x7fff38a7bfff com.apple.Carbon (160 - 162) <CAA294BD-BC93-384A-8415-B254C89098FC> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff38a7c000 - 0x7fff38a7fff3 com.apple.CommonPanels (1.2.6 - 101) <63261921-DD00-312E-AFD1-C099E1984725> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff38a80000 - 0x7fff38d74ff3 com.apple.HIToolbox (2.1.1 - 994.6) <C03A48FC-1A02-320D-9147-F4687A1BBC6F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff38d75000 - 0x7fff38d78ff3 com.apple.help (1.3.8 - 71) <F5E9EA64-5D5E-346F-98D0-D04A2F805D8D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff38d79000 - 0x7fff38d7eff7 com.apple.ImageCapture (9.0 - 1600.60.4.2) <63FE9A8C-A7C6-3ABD-AA1D-EA1BC6613C39> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff38d7f000 - 0x7fff38d7ffff com.apple.ink.framework (10.15 - 227) <90518F56-AD8A-3627-905A-16E2B8640F87> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff38d80000 - 0x7fff38d9affa com.apple.openscripting (1.7 - 185.1) <718C485A-4167-3A26-B2CD-6C42B5B36D01> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff38dbb000 - 0x7fff38dbbfff com.apple.print.framework.Print (15 - 271) <29384C24-6667-3BAA-992A-DAD809D6387E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff38dbc000 - 0x7fff38dbeff7 com.apple.securityhi (9.0 - 55008) <478C57A9-D5A5-3951-B289-DA5323E9044A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff38dbf000 - 0x7fff38dc5fff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <E6BE4EC1-5C53-38BB-AAFD-E7BF7A8975BC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff38f5f000 - 0x7fff38f5ffff com.apple.Cocoa (6.11 - 23) <37E98F4D-1D78-3F22-BDC0-59DC0B9B3A3E> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff38f6d000 - 0x7fff39063fff com.apple.ColorSync (4.13.0 - 3394.7) <FC6CFACE-CDD8-3811-BAB6-C9F82AC0A594> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff3934e000 - 0x7fff39857ffb com.apple.audio.CoreAudio (5.0 - 5.0) <CF50C6CC-6753-3D64-A76B-21CE211A98E8> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff398aa000 - 0x7fff398e2fff com.apple.CoreBluetooth (1.0 - 1) <D2943204-C3A0-3C09-A7A9-BF75822678B4> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff398e3000 - 0x7fff39ccdfe8 com.apple.CoreData (120 - 977.3) <9A33F390-687F-3EE2-8293-4E564A164469> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff39cce000 - 0x7fff39df9ffe com.apple.CoreDisplay (1.0 - 186.5.25) <53F750C6-947A-39AE-984E-41939B858A68> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff39dfa000 - 0x7fff3a279ffb com.apple.CoreFoundation (6.9 - 1675.129) <9E632A1E-9622-33D6-BCCE-23AC16DAA6B7> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff3a27b000 - 0x7fff3a8effe0 com.apple.CoreGraphics (2.0 - 1355.13) <54528FE3-21A7-3F64-B7AA-F6B95394488D> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff3a8fd000 - 0x7fff3ac58ff0 com.apple.CoreImage (15.0.0 - 940.9) <CA78A35D-E15E-3D98-BDEF-9F3D9039DB78> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff3b019000 - 0x7fff3b0f5ff4 com.apple.CoreMedia (1.0 - 2612.58.4.6) <301A075B-022D-3F28-AE2C-7F280CCF1F51> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff3b1e2000 - 0x7fff3b1e2fff com.apple.CoreServices (1069.22 - 1069.22) <888FE7B9-CE6C-3C7C-BA33-63364462228A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff3b1e3000 - 0x7fff3b268fff com.apple.AE (838.1 - 838.1) <2BAB1B88-C198-3D20-8DA3-056E66510E7A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff3b269000 - 0x7fff3b54aff7 com.apple.CoreServices.CarbonCore (1217 - 1217) <D0FECC17-7E16-308F-98EA-AF311CB77FE6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff3b54b000 - 0x7fff3b598ffd com.apple.DictionaryServices (1.2 - 323.6) <11513ED9-8B4B-39BB-A6B2-AA6AA0A2DF72> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff3b599000 - 0x7fff3b5a1ff7 com.apple.CoreServices.FSEvents (1268.100.1 - 1268.100.1) <CE3D8B13-2583-3527-8532-D5DDAAD7D56B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff3b5a2000 - 0x7fff3b7dbffc com.apple.LaunchServices (1069.22 - 1069.22) <E51EE658-608C-3034-9635-4FDF1E241E62> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff3b7dc000 - 0x7fff3b874ff1 com.apple.Metadata (10.7.0 - 2076.3) <EE42CCA1-FEC2-3F1C-9B62-2E73EFB05FCC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff3b875000 - 0x7fff3b8a2fff com.apple.CoreServices.OSServices (1069.22 - 1069.22) <A0654B4E-3194-3066-911F-FF1FBEE1D2C2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff3b8a3000 - 0x7fff3b90afff com.apple.SearchKit (1.4.1 - 1.4.1) <D4F82BC9-FD9B-3E04-B78E-D9E2A73B0BD7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff3b90b000 - 0x7fff3b92fff5 com.apple.coreservices.SharedFileList (131.4 - 131.4) <AEB4E42C-F5A2-3F63-80B0-4226483AD4F5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff3bc54000 - 0x7fff3be0bffc com.apple.CoreText (643.1.4.4 - 643.1.4.4) <5D4EA236-DC1B-3772-95C5-7F4B6CFEAF84> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff3be0c000 - 0x7fff3be50ffb com.apple.CoreVideo (1.8 - 344.3) <8507ED54-43C3-3E5B-BC74-512FE510BF8D> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff3be51000 - 0x7fff3bedeffc com.apple.framework.CoreWLAN (13.0 - 1601.2) <C1C2BBD4-EA97-3CC1-845D-1F1578E68380> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff3c175000 - 0x7fff3c17bfff com.apple.DiskArbitration (2.7 - 2.7) <D7617B57-B01C-3848-8818-593FB12039E9> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff3c34e000 - 0x7fff3c350ff2 com.apple.ExceptionHandling (1.5 - 13) <988B7AAE-677F-307B-BCF1-1BF2D11176E7> /System/Library/Frameworks/ExceptionHandling.framework/Versions/A/ExceptionHandling
0x7fff3c36d000 - 0x7fff3c498ffa com.apple.FileProvider (276 - 276) <B3EB6E66-807E-3F67-951F-88B8484FB8CD> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
0x7fff3c4b0000 - 0x7fff3c875ff8 com.apple.Foundation (6.9 - 1675.129) <9A74FA97-7F7B-3929-B381-D9514B1E4754> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff3c8e2000 - 0x7fff3c932ff7 com.apple.GSS (4.0 - 2.0) <16DE732E-4A48-3C8A-BD61-8AF810F3A48C> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff3ca6f000 - 0x7fff3cb83ff3 com.apple.Bluetooth (7.0.4 - 7.0.4f6) <9003721F-8543-3A21-BF11-2A981614F481> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff3cbe9000 - 0x7fff3cc8dff3 com.apple.framework.IOKit (2.0.2 - 1726.100.16) <3D8BA34A-AAF7-3AF2-9B5B-189AC4755404> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff3cc8f000 - 0x7fff3cca0ffb com.apple.IOSurface (269.11 - 269.11) <887CD3FD-1BB8-3BB7-B7F8-6A0BA4B3AEAE> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff3cd1f000 - 0x7fff3ce7bfee com.apple.ImageIO.framework (3.3.0 - 1976.3.4.4) <EDAA3E6B-6D65-3807-86C2-91736BC0AF88> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff3ce7c000 - 0x7fff3ce7ffff libGIF.dylib (1976.3.4.4) <A4627958-EB22-3ADA-92BE-16229F9E9767> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff3ce80000 - 0x7fff3cf39fff libJP2.dylib (1976.3.4.4) <43672561-0E75-3A32-B428-697C6DA13BD8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff3cf3a000 - 0x7fff3cf5dfe3 libJPEG.dylib (1976.3.4.4) <52DC775B-CAB5-32B7-AC86-D9AAF7851BE9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff3d1d9000 - 0x7fff3d1f3fef libPng.dylib (1976.3.4.4) <0B79BE68-50CD-3C99-9CF4-2396CD203EF8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff3d1f4000 - 0x7fff3d1f5fff libRadiance.dylib (1976.3.4.4) <E506A652-A423-3170-8032-0B03FF367FE8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff3d1f6000 - 0x7fff3d23fffb libTIFF.dylib (1976.3.4.4) <0419D70A-E156-3B5D-A8B0-33BA29B54A08> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff3e78a000 - 0x7fff3e792ffc JavaNativeFoundation (75) <F45E2FA0-08FF-38FE-8EC2-771B5BFC8581> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.framework/Versions/A/JavaNativeFoundation
0x7fff3e793000 - 0x7fff3e79bffb com.apple.java.JavaRuntimeSupport (15.0.1 - 15.0.1) <163BD8C4-3AA6-3B46-B179-11BBA8556F44> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaRuntimeSupport.framework/Versions/A/JavaRuntimeSupport
0x7fff3e79c000 - 0x7fff3e7a0ffd com.apple.JavaVM (15.0.3 - 15.0.3) <E1B013EF-5C57-390C-A0AC-695FCE4A135D> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
0x7fff3e7a1000 - 0x7fff3e7b3ff3 com.apple.Kerberos (3.0 - 1) <DC673FF3-4DC9-3C23-9718-343AB36B2984> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff3e7b4000 - 0x7fff3e7b4fff libHeimdalProxy.dylib (77) <A970C7A8-7CCD-3701-A459-078BD5E8FE4E> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
0x7fff3eb46000 - 0x7fff3eb50ffb com.apple.MediaAccessibility (1.0 - 125.1) <B2F72AF8-99DC-3613-B618-C588252EEAC2> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff3ec1c000 - 0x7fff3f367ffd com.apple.MediaToolbox (1.0 - 2612.58.4.6) <FEB63B0B-D774-3FEB-B89A-66C2179DAC85> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff3f369000 - 0x7fff3f433fff com.apple.Metal (212.5.15 - 212.5.15) <2CBB178E-434E-31D3-BAE2-ED3EA801D4BC> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff3f450000 - 0x7fff3f48dff7 com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <5DF84B7A-9DD0-36DB-8686-D669CDA93D59> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff3f48e000 - 0x7fff3f518fe2 com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <CDC36001-66DA-3BBD-A9AA-2470B634B9C9> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff3f519000 - 0x7fff3f53eff4 com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <1E4FE6EF-6D42-3439-835C-F4F20B05E0F5> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff3f53f000 - 0x7fff3f554ffb com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <8F8F0C2E-C4EC-3418-A06A-42B8280DDC9D> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
0x7fff3f555000 - 0x7fff3f6b3ffc com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <6BEFB262-2538-3A12-9E9F-A7CF94D2B68A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff3f6b4000 - 0x7fff3f703ff4 com.apple.MetalPerformanceShaders.MPSRayIntersecto r (1.0 - 1) <4D352B8E-97D8-34FA-B2AF-3AB4E3149E2E> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff3f704000 - 0x7fff3f705ff5 com.apple.MetalPerformanceShaders.MetalPerformance Shaders (1.0 - 1) <07F3B58C-F362-35F2-9A79-F38015A78DDA> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff4078c000 - 0x7fff40798ffe com.apple.NetFS (6.0 - 4.0) <7A96A8FE-17F3-3850-8E81-9DDDC5A48DDB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff40799000 - 0x7fff408f0ff3 com.apple.Network (1.0 - 1) <D1C8FDDE-C822-3C40-BB26-18F24CFC8AE2> /System/Library/Frameworks/Network.framework/Versions/A/Network
0x7fff43318000 - 0x7fff43320ff7 libcldcpuengine.dylib (2.14) <BB23A727-5F40-3D27-AD3B-3197A7241F84> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff43321000 - 0x7fff43379fff com.apple.opencl (3.5 - 3.5) <3F0E363C-9380-3226-A4D1-67E740079AAD> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff4337a000 - 0x7fff43396fff com.apple.CFOpenDirectory (10.15 - 220.40.1) <58835104-9E7A-32E8-862B-530CE899C9B4> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff43397000 - 0x7fff433a2ffd com.apple.OpenDirectory (10.15 - 220.40.1) <D846BA35-59A1-3B78-B1C8-7E0EDE972AD2> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff43d08000 - 0x7fff43d0afff libCVMSPluginSupport.dylib (17.10.22) <65052150-BEFD-38D8-A789-560C2FB1644A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff43d0b000 - 0x7fff43d10fff libCoreFSCache.dylib (176.11) <AEAEE894-BA4B-334F-90E1-7374DFB41979> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff43d11000 - 0x7fff43d15fff libCoreVMClient.dylib (176.11) <29D2B5C2-CBFF-308A-ADD8-A559B760C494> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff43d16000 - 0x7fff43d1eff7 libGFXShared.dylib (17.10.22) <7FF5455A-3D5D-33D2-9C41-A51ABE53CE66> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff43d1f000 - 0x7fff43d29fff libGL.dylib (17.10.22) <08450555-3BC8-3457-8F5E-E2BBE895C0C7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff43d2a000 - 0x7fff43d5eff7 libGLImage.dylib (17.10.22) <5182EE22-2914-30E0-A87D-C38F345F695B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff43d5f000 - 0x7fff43ef3ff7 libGLProgrammability.dylib (17.10.22) <942CCB23-9868-3D76-98CC-3430E45590D2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff43ef4000 - 0x7fff43f30fff libGLU.dylib (17.10.22) <2FE69FE7-B60D-3D05-824B-CD4958E2C7B8> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff4496c000 - 0x7fff4497bff7 com.apple.opengl (17.10.22 - 17.10.22) <4E9C4B23-6D44-3804-AFF8-84C3B060E8F5> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff4497c000 - 0x7fff44af5fff GLEngine (17.10.22) <803CEBEC-8BA2-3B48-B6E7-23F080B7EE75> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff44af6000 - 0x7fff44b1efff GLRendererFloat (17.10.22) <EE9FB4C6-8D39-39CC-9A91-7D3EFB16B2DB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff45939000 - 0x7fff45bbbff2 com.apple.QuartzCore (1.11 - 840.18) <16502545-A0F3-3367-929B-DD80A6440226> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff4673c000 - 0x7fff46a85ff1 com.apple.security (7.0 - 59306.101.1) <430E04FE-F068-3476-9CA2-72CB5F040D1F> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff46a86000 - 0x7fff46b0effb com.apple.securityfoundation (6.0 - 55236.60.1) <BC15B825-955D-33CF-B416-A64D69A1D008> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff46b3d000 - 0x7fff46b41ff8 com.apple.xpc.ServiceManagement (1.0 - 1) <C66FC9CF-224B-348C-94A5-ABAC579F5C0A> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff477ec000 - 0x7fff4785aff7 com.apple.SystemConfiguration (1.19 - 1.19) <71AC15DE-7018-3D2B-B599-F2972F0288AE> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff47ad9000 - 0x7fff47e5cff4 com.apple.VideoToolbox (1.0 - 2612.58.4.6) <C488A935-B94F-3F80-88E7-D2743FB1E460> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff4b7b7000 - 0x7fff4b87cff7 com.apple.APFS (1412.101.1 - 1412.101.1) <2F5A48FB-9788-3A24-87FE-C1B7DDBC8A07> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff4c98a000 - 0x7fff4c98bff1 com.apple.AggregateDictionary (1.0 - 1) <FE9B8728-9C37-367E-91A6-2D1321D485A0> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff4cf25000 - 0x7fff4cf42ff4 com.apple.AppContainer (4.0 - 448.100.6) <FBA274DA-2172-31C8-9759-AFB227E0E7E7> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff4cf97000 - 0x7fff4cfa5ff7 com.apple.AppSandbox (4.0 - 448.100.6) <B38CE066-5303-3FBF-B0D3-A0D3889E2005> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff4d420000 - 0x7fff4d444ffb com.apple.framework.Apple80211 (13.0 - 1602.3) <7D1A08A0-27B0-3F53-BFC4-A2A482B055A0> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff4d702000 - 0x7fff4d711fd7 com.apple.AppleFSCompression (119.100.1 - 1.0) <E1B024EB-DAB1-30A1-A43D-01D9E9357F2B> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff4d810000 - 0x7fff4d81bff7 com.apple.AppleIDAuthSupport (1.0 - 1) <BE6A7C6D-060E-38E9-A010-61975ECE5E43> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff4d85d000 - 0x7fff4d8a5ff7 com.apple.AppleJPEG (1.0 - 1) <C163D80A-6818-3C36-B9A9-7CC8777FE593> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff4dc93000 - 0x7fff4dcb5fff com.apple.applesauce (1.0 - 16.25) <A6C6D37B-9AA5-3137-A02E-F61798A908B0> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff4dd74000 - 0x7fff4dd77ffb com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <52444963-7A5E-36C8-BAAA-FFF8A0D14612> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff4dd78000 - 0x7fff4ddc8ff7 com.apple.AppleVAFramework (6.1.2 - 6.1.2) <A46D4D00-6251-302B-9A4A-3A930855BC1F> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff4de11000 - 0x7fff4de20ff9 com.apple.AssertionServices (1.0 - 223.100.31) <2DA45CD2-C755-397C-977C-F4C6435A1272> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff4e362000 - 0x7fff4e75dff8 com.apple.audio.AudioResourceArbitration (1.0 - 1) <B7E163FF-F028-32A5-9AD3-DB7022E99DE7> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
0x7fff4e9b3000 - 0x7fff4ebf3ff0 com.apple.audio.AudioToolboxCore (1.0 - 1104.80) <EE6A2BD9-843C-3CC3-AEFC-6D7855DBB331> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
0x7fff4ebf7000 - 0x7fff4ed13ff3 com.apple.AuthKit (1.0 - 1) <0A3A05D4-0795-35B8-8729-4BF252D52E60> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff4eed0000 - 0x7fff4eed9ff7 com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <2088BC70-5329-3390-A851-C4ECF654047C> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff4eeda000 - 0x7fff4ef7bff5 com.apple.backup.framework (1.11.4 - 1298.4.19) <1F848C06-11E3-3D85-8358-7E37AD2BE9D7> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff4ef7c000 - 0x7fff4f008ff6 com.apple.BaseBoard (466.3 - 466.3) <1EFE4339-9393-3B15-8DC9-2BE9B03F3062> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff4f10a000 - 0x7fff4f146ff7 com.apple.bom (14.0 - 219.2) <4B7C18B2-1E51-376E-9D6A-CE3F58D2AE53> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff4fcc2000 - 0x7fff4fd11fff com.apple.ChunkingLibrary (307 - 307) <4A5C3E8E-1E95-3363-8A78-CCD55770F064> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff50b82000 - 0x7fff50b92ffb com.apple.CommonAuth (4.0 - 2.0) <E09BBBBE-ECDD-3442-8D4E-27A12F5E2347> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff50ba6000 - 0x7fff50bbdfff com.apple.commonutilities (8.0 - 900) <1E6CE910-4B06-3704-A47D-06337A6F0992> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fff512c3000 - 0x7fff51698fc8 com.apple.CoreAUC (283.0.0 - 283.0.0) <5BF7FDC2-E106-3E73-B950-2A0DDE2CA11F> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff51699000 - 0x7fff516c6ff7 com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <4BD22FB9-F5F7-35E5-AAD6-CF92706C9816> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff516e9000 - 0x7fff51708ffc com.apple.analyticsd (1.0 - 1) <F33987F5-A14A-3A55-8D26-FDE9A57B9269> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
0x7fff51c8f000 - 0x7fff51c9fff3 com.apple.CoreEmoji (1.0 - 107) <AC83B860-61BD-384E-81BF-CA3CBE655968> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff522df000 - 0x7fff52349ff0 com.apple.CoreNLP (1.0 - 213) <687A4C31-A307-3255-83BE-9B123971FF62> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff52777000 - 0x7fff5277fff8 com.apple.CorePhoneNumbers (1.0 - 1) <17E6A3B0-A181-3295-8B19-E139EDF12E4B> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff5316c000 - 0x7fff5318ffff com.apple.CoreSVG (1.0 - 129) <53213F48-F888-3EBE-AE30-E9303E9B712C> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
0x7fff53190000 - 0x7fff531c3fff com.apple.CoreServicesInternal (446.7 - 446.7) <4C4834E0-EA46-36DE-BA11-16B8826DD754> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff531c4000 - 0x7fff531f2ffd com.apple.CSStore (1069.22 - 1069.22) <39E431F9-3584-34DF-A64D-C5895AA72068> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
0x7fff53716000 - 0x7fff537acff7 com.apple.CoreSymbolication (11.4 - 64535.33.1) <DCA00787-D285-3944-AAFA-CAF78775B8D3> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff53844000 - 0x7fff53970ff6 com.apple.coreui (2.1 - 609.4) <55EACF17-86EA-3F6E-A2CF-AF2F08C5F295> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff53971000 - 0x7fff53b27ff5 com.apple.CoreUtils (6.2 - 620.34) <172FC306-619F-3451-9BCA-F0B0D0B58EFD> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff53c61000 - 0x7fff53c74ff1 com.apple.CrashReporterSupport (10.13 - 15016) <8AB4A416-A174-386B-8A96-5F16EAA3FCDE> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff53d2d000 - 0x7fff53d3fff8 com.apple.framework.DFRFoundation (1.0 - 252.40.1) <852E7EE8-EC39-3CFF-9605-9F971F7BCED5> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff53d40000 - 0x7fff53d45fff com.apple.DSExternalDisplay (3.1 - 380) <61597AB3-7E66-339D-A709-50D4F9B3D8E9> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff53dcf000 - 0x7fff53e49ff0 com.apple.datadetectorscore (8.0 - 659) <F7BA8B28-FD51-34A7-A423-63878638D00E> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff53e95000 - 0x7fff53ed2ff8 com.apple.DebugSymbols (194 - 194) <0406F803-6865-370E-9D32-01EF177B5E7A> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff53ed3000 - 0x7fff5405aff2 com.apple.desktopservices (1.14.4 - 1281.4.19) <82777143-A900-33D0-BCFA-2511C89C9EAD> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff559f3000 - 0x7fff55e0eff1 com.apple.vision.FaceCore (4.3.0 - 4.3.0) <E081D201-B82C-3AE3-8B58-1E909CE053B3> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff5649f000 - 0x7fff565d6ffc libFontParser.dylib (277.2.4.2) <B59E080A-9FC3-3511-9024-E6D5461E60D1> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
0x7fff565d7000 - 0x7fff5660bfff libTrueTypeScaler.dylib (277.2.4.2) <3A485687-23E8-3C53-83B0-1AA9625DCD37> /System/Library/PrivateFrameworks/FontServices.framework/libTrueTypeScaler.dylib
0x7fff56670000 - 0x7fff56680ff6 libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <5A0F87CA-81C0-3444-B958-AAC7BD4319BC> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
0x7fff59b61000 - 0x7fff59b62fff libmetal_timestamp.dylib (902.14.9) <E675DA7E-A99D-3351-94D1-3485CD86808B> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib
0x7fff5b206000 - 0x7fff5b211ff7 libGPUSupportMercury.dylib (17.10.22) <FE3E328E-F2AC-3FE3-BE4C-31592ABB168B> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff5b212000 - 0x7fff5b218fff com.apple.GPUWrangler (5.1.16 - 5.1.16) <F91AD6D6-8242-348C-8296-AF1DD8DBA2EF> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff5b537000 - 0x7fff5b55dff1 com.apple.GenerationalStorage (2.0 - 314) <54182052-9E17-3A2A-8943-8915E6D319CE> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff5c68c000 - 0x7fff5c69affb com.apple.GraphVisualizer (1.0 - 100.1) <7289AEE6-C577-3D89-A99E-98551218EB7D> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff5c83a000 - 0x7fff5c8f8ff4 com.apple.Heimdal (4.0 - 2.0) <C4838DCE-48FB-3828-9FB2-097BA2848C99> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff5d2f5000 - 0x7fff5d324ff8 com.apple.HelpData (2.3 - 199) <2539BB59-73A2-33C1-9BA2-8DC4A1AF9155> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff5ea6f000 - 0x7fff5ea78ffe com.apple.IOAccelMemoryInfo (1.0 - 1) <8626B839-52BD-3BE1-BD83-B5C72D7B586D> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fff5ea79000 - 0x7fff5ea81ff5 com.apple.IOAccelerator (438.4.5 - 438.4.5) <4B2F1D11-C36B-3C48-9934-8A973348A966> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff5ea8e000 - 0x7fff5eaa4fff com.apple.IOPresentment (1.0 - 37) <2FE66352-4CF9-3F79-944D-053E2AD451D6> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff5ee2c000 - 0x7fff5ee77ff1 com.apple.IconServices (438.3 - 438.3) <2431AD46-37B8-367F-A1DC-119C781B1453> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff5f035000 - 0x7fff5f03cffa com.apple.InternationalSupport (1.0 - 45.2) <296B6979-342E-35B8-A58B-B0797DFBA789> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff5f0e0000 - 0x7fff5f0e4ff4 JavaLaunching (43) <0F441229-1FBB-3B50-B727-F4A219B2F4EA> /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/JavaLaunching
0x7fff5f2c9000 - 0x7fff5f2e8ffd com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <D0F59C6D-F069-3F0D-81C2-CBFC2E6B7101> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff5f41d000 - 0x7fff5f4ebffd com.apple.LanguageModeling (1.0 - 215.1) <3FAF1700-F7D4-3F92-88AA-A3920702B8BB> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff5f4ec000 - 0x7fff5f534fff com.apple.Lexicon-framework (1.0 - 72) <212D02CE-11BC-3C7F-BDFD-DF1A0C4017EE> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff5f53b000 - 0x7fff5f540ff3 com.apple.LinguisticData (1.0 - 353.18) <BA3869B7-9C39-32DA-A4BA-12F1BC4B04CF> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff5fdd8000 - 0x7fff5fddbfff com.apple.Mangrove (1.0 - 25) <9490A0D4-5EF9-3FDA-B048-A71BE3A17096> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff60044000 - 0x7fff600ceff8 com.apple.MediaExperience (1.0 - 1) <F86763CC-6791-390E-8BCF-512B04C931BA> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
0x7fff608a7000 - 0x7fff608f3fff com.apple.spotlight.metadata.utilities (1.0 - 2076.3) <EF8AC054-B15F-375F-AACB-018DC73CD16E> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff608f4000 - 0x7fff609c5ffa com.apple.gpusw.MetalTools (1.0 - 1) <BA343D96-58EA-374A-818C-E42968101EA8> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff60a22000 - 0x7fff60a3bff4 com.apple.MobileAssets (1.0 - 619.100.2) <4EAA222A-2128-3A7D-9270-C4878C8AD1AA> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff60bf8000 - 0x7fff60c16fff com.apple.MobileKeyBag (2.0 - 1.0) <0837C5C4-A860-387C-8F31-9A4627A3132F> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff60e79000 - 0x7fff60ea9ff7 com.apple.MultitouchSupport.framework (3440.1 - 3440.1) <0AA68A0D-23F6-3628-A93F-8F8018B84920> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff613a8000 - 0x7fff613b2fff com.apple.NetAuth (6.2 - 6.2) <D324C7CC-E614-35F6-8619-DECBE90ECAEB> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff61dbd000 - 0x7fff61e08ffb com.apple.OTSVG (1.0 - 643.1.4.4) <DCCAD72C-ED3E-3FB9-80C8-4DB36362C28A> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff63010000 - 0x7fff6301bff2 com.apple.PerformanceAnalysis (1.243.2 - 243.2) <FFE831BE-C133-38BE-A6B4-BEEB9FD6BF37> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff6301c000 - 0x7fff63044ffb com.apple.persistentconnection (1.0 - 1.0) <F16D4768-61F2-3298-8E37-0EAF612A55C0> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
0x7fff65a02000 - 0x7fff65a1bffb com.apple.ProtocolBuffer (1 - 274.24.9.16.3) <05BE7640-A9FD-3963-8199-E60DE3C37A7E> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff65e7a000 - 0x7fff65ea3ff1 com.apple.RemoteViewServices (2.0 - 148) <680F9F89-C44B-3AB3-B9EA-155B41B7295A> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff66008000 - 0x7fff66043ff0 com.apple.RunningBoardServices (1.0 - 223.100.31) <28C26D68-F1F5-3ADC-832B-AF63336F35FB> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
0x7fff67920000 - 0x7fff67923ff5 com.apple.SecCodeWrapper (4.0 - 448.100.6) <87710569-BCB4-37C1-B56D-F0EB89863A78> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff67a96000 - 0x7fff67bbdff1 com.apple.Sharing (1526.14 - 1526.14) <8D0C1BC4-5133-399B-9EFC-74CAEF4FA389> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff67c16000 - 0x7fff67c34ff2 com.apple.shortcut (2.16 - 106) <5C74A85D-4208-3AD8-958B-DBE676ECB209> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff68fd0000 - 0x7fff692c6fff com.apple.SkyLight (1.600.0 - 450.9) <C6AF6A79-C673-3B9E-95E0-993F43AE7EED> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff69b13000 - 0x7fff69b21ffb com.apple.SpeechRecognitionCore (6.0.91 - 6.0.91) <4678A6DB-D56E-393F-90BD-5AF4F3664440> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff6a1fb000 - 0x7fff6a23cff9 com.apple.StreamingZip (1.0 - 1) <67F0ED7B-0912-3151-BEB1-9D5FBAE0D46B> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff6a353000 - 0x7fff6a35cff7 com.apple.SymptomDiagnosticReporter (1.0 - 1238.100.26) <A2197A8A-796E-321C-8EBB-075AED9995B0> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
0x7fff6a612000 - 0x7fff6a622ff3 com.apple.TCC (1.0 - 1) <AEE98D6E-03FD-3C80-90AC-5B45B4AE7A2E> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff6ab45000 - 0x7fff6ac0bff0 com.apple.TextureIO (3.10.9 - 3.10.9) <362C5815-6A2B-3CA8-B577-C5D4978EF981> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff6adcc000 - 0x7fff6b024ff0 com.apple.UIFoundation (1.0 - 661.2) <27837A1C-A833-3F99-B8D8-84A583EEA523> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff6bc97000 - 0x7fff6bcb7ffc com.apple.UserManagement (1.0 - 1) <6F223C62-641C-3F7E-BE20-B0C9F19709C7> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
0x7fff6ca63000 - 0x7fff6cb4dff8 com.apple.ViewBridge (464.1 - 464.1) <E1DB0984-8B31-36E4-9854-A3345F67BED3> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff6ccf3000 - 0x7fff6ccf4fff com.apple.WatchdogClient.framework (1.0 - 67.101.1) <1D6C2858-0A09-380E-8718-14131D9A0FE1> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
0x7fff6d920000 - 0x7fff6d923ffa com.apple.dt.XCTTargetBootstrap (1.0 - 16091) <B40E4B60-2DB5-30ED-A210-3ED708862162> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x7fff6d99d000 - 0x7fff6d9abff5 com.apple.audio.caulk (1.0 - 32.3) <DFE1EBB6-9A42-3227-8601-5CFCB1F665CD> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x7fff6dced000 - 0x7fff6dcefff3 com.apple.loginsupport (1.0 - 1) <B84ABC31-431B-3F99-BABE-44ED0A7DB3C0> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff6dcf0000 - 0x7fff6dd03ffd com.apple.login (3.0 - 3.0) <8FAC178E-0C61-3E48-844A-CB4446CC7BC6> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
0x7fff707ce000 - 0x7fff70801ffa libAudioToolboxUtility.dylib (1104.80) <C34C8FCE-54DE-3884-8074-057B06807D22> /usr/lib/libAudioToolboxUtility.dylib
0x7fff70808000 - 0x7fff7083cfff libCRFSuite.dylib (48) <E52BECF7-1819-3998-ACC4-8D1A332CE4EB> /usr/lib/libCRFSuite.dylib
0x7fff7083f000 - 0x7fff70849fff libChineseTokenizer.dylib (34) <EE842A48-3D30-34B0-B9D2-F045DE582650> /usr/lib/libChineseTokenizer.dylib
0x7fff708d5000 - 0x7fff708d7ff7 libDiagnosticMessagesClient.dylib (112) <BE749883-9400-334A-8FBF-F3321CF205F5> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff7091d000 - 0x7fff70ad4ffb libFosl_dynamic.dylib (100.4) <68038226-8CAA-36B5-B5D6-510F900B318D> /usr/lib/libFosl_dynamic.dylib
0x7fff70afb000 - 0x7fff70b01ff3 libIOReport.dylib (54) <FA47D01E-E02C-3178-9C10-DF4E7F6351B0> /usr/lib/libIOReport.dylib
0x7fff70be3000 - 0x7fff70beafff libMatch.1.dylib (36) <815A4553-4763-369F-A77C-62663A586D60> /usr/lib/libMatch.1.dylib
0x7fff70c19000 - 0x7fff70c39fff libMobileGestalt.dylib (826.100.27) <4B771C86-0CB7-3B06-8F41-5A40DDF66D72> /usr/lib/libMobileGestalt.dylib
0x7fff70dab000 - 0x7fff70dacfff libSystem.B.dylib (1281.100.1) <DB8310F1-272D-3533-A840-3B390AF55C26> /usr/lib/libSystem.B.dylib
0x7fff70e39000 - 0x7fff70e3afff libThaiTokenizer.dylib (3) <DC582222-7C1F-3C27-8C3A-BAF696A2197D> /usr/lib/libThaiTokenizer.dylib
0x7fff70e52000 - 0x7fff70e68fff libapple_nghttp2.dylib (1.39.2) <268F4E3E-95DC-35FB-82DC-5B0D1855A676> /usr/lib/libapple_nghttp2.dylib
0x7fff70e9d000 - 0x7fff70f0fff7 libarchive.2.dylib (72.100.1) <65E0870E-02AB-365D-84F9-5800B5BB69FC> /usr/lib/libarchive.2.dylib
0x7fff70f10000 - 0x7fff70fa9fe5 libate.dylib (3.0.1) <4477640F-CC1B-3825-B877-69508F367E3D> /usr/lib/libate.dylib
0x7fff70fad000 - 0x7fff70fadff3 libauto.dylib (187) <FD0E5750-7004-36A7-B9C2-D6B6B4EF559B> /usr/lib/libauto.dylib
0x7fff71073000 - 0x7fff71083ffb libbsm.0.dylib (60.100.1) <B0373A39-DBC6-3A84-879B-BA46E30D04BF> /usr/lib/libbsm.0.dylib
0x7fff71084000 - 0x7fff71090fff libbz2.1.0.dylib (44) <FFCD4427-AF87-36D2-8097-8870FDC75A1B> /usr/lib/libbz2.1.0.dylib
0x7fff71091000 - 0x7fff710e3fff libc++.1.dylib (902.1) <08199809-33CA-321E-9B9D-FD5B2BC64580> /usr/lib/libc++.1.dylib
0x7fff710e4000 - 0x7fff710f9ffb libc++abi.dylib (902) <1C880020-396D-3F91-BE27-5A09A9239F68> /usr/lib/libc++abi.dylib
0x7fff710fa000 - 0x7fff710fafff libcharset.1.dylib (59) <4E63BA25-04A3-329A-923D-251155C03F30> /usr/lib/libcharset.1.dylib
0x7fff710fb000 - 0x7fff7110cfff libcmph.dylib (8) <D4C5E0A8-92D9-33D5-9F83-6F4742FFBE29> /usr/lib/libcmph.dylib
0x7fff7110d000 - 0x7fff71124fd7 libcompression.dylib (87) <7F258A06-E01D-32D2-9CD2-6B2931DA5DA7> /usr/lib/libcompression.dylib
0x7fff713fe000 - 0x7fff71414ff7 libcoretls.dylib (167) <EFC237BB-78F7-33C6-BFF9-53860062DD99> /usr/lib/libcoretls.dylib
0x7fff71415000 - 0x7fff71416fff libcoretls_cfhelpers.dylib (167) <2E542A2B-7730-33EE-9B3B-154B08608AA6> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff719d3000 - 0x7fff71a32ff7 libcups.2.dylib (483.6) <F446DEF0-66C0-31AD-88E1-919B05F06C90> /usr/lib/libcups.2.dylib
0x7fff71b3e000 - 0x7fff71b3efff libenergytrace.dylib (21) <FFB9FB70-8DBD-3025-BC92-51F02481A489> /usr/lib/libenergytrace.dylib
0x7fff71b3f000 - 0x7fff71b57fff libexpat.1.dylib (19.60.2) <1ED53818-578C-3D17-8761-68792CCAD685> /usr/lib/libexpat.1.dylib
0x7fff71b65000 - 0x7fff71b67fff libfakelink.dylib (149.1) <B04F9A05-7E52-3382-9186-F603BE4BFBB2> /usr/lib/libfakelink.dylib
0x7fff71b76000 - 0x7fff71b7bfff libgermantok.dylib (24) <8091F952-B592-38E3-982B-7DEA0A44E211> /usr/lib/libgermantok.dylib
0x7fff71b7c000 - 0x7fff71b85ff7 libheimdal-asn1.dylib (564.100.1) <2D639331-43CF-331F-98F4-CDF41990A468> /usr/lib/libheimdal-asn1.dylib
0x7fff71b86000 - 0x7fff71c76fff libiconv.2.dylib (59) <9458704B-A702-37CB-9707-66ABBB5DB71E> /usr/lib/libiconv.2.dylib
0x7fff71c77000 - 0x7fff71ecefff libicucore.A.dylib (64260.0.1) <DCC4A4EE-32FD-350F-84D8-E857F2F29855> /usr/lib/libicucore.A.dylib
0x7fff71ee8000 - 0x7fff71ee9fff liblangid.dylib (133) <E9595222-602B-38F0-8572-0F1872A00527> /usr/lib/liblangid.dylib
0x7fff71eea000 - 0x7fff71f02ff3 liblzma.5.dylib (16) <0AA1EB11-A433-327E-B8DB-7395CFF06554> /usr/lib/liblzma.5.dylib
0x7fff71f1a000 - 0x7fff71fc1ff7 libmecab.dylib (883.10) <13136C11-8763-37BA-AEB2-676092798DAA> /usr/lib/libmecab.dylib
0x7fff71fc2000 - 0x7fff72224fe1 libmecabra.dylib (883.10) <6AC22857-F528-35CE-94A9-D70F6F766C15> /usr/lib/libmecabra.dylib
0x7fff72591000 - 0x7fff725c0fff libncurses.5.4.dylib (57) <6BD6F430-C8B3-39D8-87B5-2C16E6578FD5> /usr/lib/libncurses.5.4.dylib
0x7fff726f0000 - 0x7fff72b6bff5 libnetwork.dylib (1880.100.30) <9519B6F8-44E2-3F53-B995-1527C5333240> /usr/lib/libnetwork.dylib
0x7fff72c0b000 - 0x7fff72c3efde libobjc.A.dylib (787.1) <20AC082F-2DB7-3974-A2D4-8C5E01787584> /usr/lib/libobjc.A.dylib
0x7fff72c51000 - 0x7fff72c55fff libpam.2.dylib (25.100.1) <D5CEC1AD-A2EC-362C-B71A-22FD521917F1> /usr/lib/libpam.2.dylib
0x7fff72c58000 - 0x7fff72c8eff7 libpcap.A.dylib (89.100.1) <171BAAB0-A5C8-32C5-878E-83D46073BF8C> /usr/lib/libpcap.A.dylib
0x7fff72d12000 - 0x7fff72d2afff libresolv.9.dylib (67.40.1) <92A522F9-95E2-35EE-A8AD-FC8DEE6B2C1F> /usr/lib/libresolv.9.dylib
0x7fff72d2c000 - 0x7fff72d70ff7 libsandbox.1.dylib (1217.101.2) <5E362637-203E-3170-B988-1C470A6B0642> /usr/lib/libsandbox.1.dylib
0x7fff72d84000 - 0x7fff72d85ff7 libspindump.dylib (281.3) <16F53AD2-1839-37BF-A2F5-92253FE4AF1A> /usr/lib/libspindump.dylib
0x7fff72d86000 - 0x7fff72f70ff7 libsqlite3.dylib (308.4) <BBC375B7-AF20-3D2C-8826-78D3BDC8A004> /usr/lib/libsqlite3.dylib
0x7fff731c1000 - 0x7fff731c4ffb libutil.dylib (57) <07ED7CF0-1744-3386-B8B2-0DDBD446999E> /usr/lib/libutil.dylib
0x7fff731c5000 - 0x7fff731d2ff7 libxar.1.dylib (425.2) <625F24E1-1A0F-3301-9F99-F0F3DADE0287> /usr/lib/libxar.1.dylib
0x7fff731d8000 - 0x7fff732baff7 libxml2.2.dylib (33.3) <24147A90-E3EB-3926-BFB0-5F0FC9F706E2> /usr/lib/libxml2.2.dylib
0x7fff732be000 - 0x7fff732e6fff libxslt.1.dylib (16.9) <8C8648B1-F2CA-38EA-A409-D6F19715C6E6> /usr/lib/libxslt.1.dylib
0x7fff732e7000 - 0x7fff732f9ff3 libz.1.dylib (76) <6A449C6A-DF88-36C1-8F2D-DB9A808263B5> /usr/lib/libz.1.dylib
0x7fff73ba7000 - 0x7fff73bacff3 libcache.dylib (83) <5F90FFCE-403B-3724-991D-BA32401D99C5> /usr/lib/system/libcache.dylib
0x7fff73bad000 - 0x7fff73bb8fff libcommonCrypto.dylib (60165) <C7A5E3F7-1E5A-3785-875A-B6647082B614> /usr/lib/system/libcommonCrypto.dylib
0x7fff73bb9000 - 0x7fff73bc0fff libcompiler_rt.dylib (101.2) <A517E149-2D25-3C04-BCEF-F69149C85B18> /usr/lib/system/libcompiler_rt.dylib
0x7fff73bc1000 - 0x7fff73bcaff7 libcopyfile.dylib (166.40.1) <1A5270B5-0D97-35DA-9296-4F4A428BC6A2> /usr/lib/system/libcopyfile.dylib
0x7fff73bcb000 - 0x7fff73c5dfe3 libcorecrypto.dylib (866.100.30) <FCDEC0D1-8C30-3989-BDD1-996BBC715C29> /usr/lib/system/libcorecrypto.dylib
0x7fff73d6a000 - 0x7fff73daaff0 libdispatch.dylib (1173.100.2) <EB592997-B11C-3AB3-85B1-F725F3D0B412> /usr/lib/system/libdispatch.dylib
0x7fff73dab000 - 0x7fff73de1fff libdyld.dylib (750.5) <D2A07EF5-A64B-3692-BE13-89DAA2EC5E80> /usr/lib/system/libdyld.dylib
0x7fff73de2000 - 0x7fff73de2ffb libkeymgr.dylib (30) <CC5A2B43-770B-3C6C-BA10-AA3A6B4A142D> /usr/lib/system/libkeymgr.dylib
0x7fff73de3000 - 0x7fff73defff3 libkxld.dylib (6153.101.6) <77282DCB-83D6-3199-874E-9A4A0FD7D4F3> /usr/lib/system/libkxld.dylib
0x7fff73df0000 - 0x7fff73df0ff7 liblaunch.dylib (1738.100.39) <A7FF7357-600F-3014-8C28-A4F367717E8D> /usr/lib/system/liblaunch.dylib
0x7fff73df1000 - 0x7fff73df6ff7 libmacho.dylib (959.0.1) <D8FED478-25A2-3844-AE4B-A5C9F9827615> /usr/lib/system/libmacho.dylib
0x7fff73df7000 - 0x7fff73df9ff3 libquarantine.dylib (110.40.3) <51E0304F-AB11-3BF7-99DC-BB916CC9088B> /usr/lib/system/libquarantine.dylib
0x7fff73dfa000 - 0x7fff73dfbff7 libremovefile.dylib (48) <078F29AB-26BA-3493-BCAA-E1E75A187521> /usr/lib/system/libremovefile.dylib
0x7fff73dfc000 - 0x7fff73e13ff3 libsystem_asl.dylib (377.60.2) <0F1BAC19-2AE0-3F8E-9B90-AACF819B2BF7> /usr/lib/system/libsystem_asl.dylib
0x7fff73e14000 - 0x7fff73e14ff7 libsystem_blocks.dylib (74) <32224AFF-C06F-3279-B753-097194EDEF49> /usr/lib/system/libsystem_blocks.dylib
0x7fff73e15000 - 0x7fff73e9cfff libsystem_c.dylib (1353.100.2) <4F5EED22-4D46-3F04-8C64-C492CDAD70EB> /usr/lib/system/libsystem_c.dylib
0x7fff73e9d000 - 0x7fff73ea0ffb libsystem_configuration.dylib (1061.101.1) <2A2C778D-07EB-35C7-A954-8BF8FD74BD75> /usr/lib/system/libsystem_configuration.dylib
0x7fff73ea1000 - 0x7fff73ea4fff libsystem_coreservices.dylib (114) <FDA41CC4-170A-3D93-85BD-838A563B03C4> /usr/lib/system/libsystem_coreservices.dylib
0x7fff73ea5000 - 0x7fff73eadfff libsystem_darwin.dylib (1353.100.2) <B567B86D-8818-38A4-A861-03EB83B55867> /usr/lib/system/libsystem_darwin.dylib
0x7fff73eae000 - 0x7fff73eb5fff libsystem_dnssd.dylib (1096.100.3) <7C690DF5-E119-33FB-85CD-9EFC67A36E40> /usr/lib/system/libsystem_dnssd.dylib
0x7fff73eb6000 - 0x7fff73eb7ffb libsystem_featureflags.dylib (17) <415D83EF-084C-3485-B757-53001870EA94> /usr/lib/system/libsystem_featureflags.dylib
0x7fff73eb8000 - 0x7fff73f05ff7 libsystem_info.dylib (538) <17049D3F-C798-3651-B391-1551FC699D3E> /usr/lib/system/libsystem_info.dylib
0x7fff73f06000 - 0x7fff73f32ff7 libsystem_kernel.dylib (6153.101.6) <E76440E1-D1E8-3D9A-8B47-D01F554FF1C4> /usr/lib/system/libsystem_kernel.dylib
0x7fff73f33000 - 0x7fff73f7afff libsystem_m.dylib (3178) <74741FA8-5C29-3241-9046-4FC91C6A6D4A> /usr/lib/system/libsystem_m.dylib
0x7fff73f7b000 - 0x7fff73fa2fff libsystem_malloc.dylib (283.100.5) <97833239-2F83-3AEB-A426-0593997C8A54> /usr/lib/system/libsystem_malloc.dylib
0x7fff73fa3000 - 0x7fff73fb0ffb libsystem_networkextension.dylib (1095.100.29) <C9E988B2-6A18-35C0-9577-63201E9D6018> /usr/lib/system/libsystem_networkextension.dylib
0x7fff73fb1000 - 0x7fff73fbaff7 libsystem_notify.dylib (241.100.2) <E405F84B-BD4F-3874-9755-CB3EC86E18D5> /usr/lib/system/libsystem_notify.dylib
0x7fff73fbb000 - 0x7fff73fc3fef libsystem_platform.dylib (220.100.1) <6EF12F34-C33F-36BF-9A9A-2A35EA19EFE0> /usr/lib/system/libsystem_platform.dylib
0x7fff73fc4000 - 0x7fff73fcefff libsystem_pthread.dylib (416.100.3) <A8514582-E000-3854-911A-0A73D2C79600> /usr/lib/system/libsystem_pthread.dylib
0x7fff73fcf000 - 0x7fff73fd3ff3 libsystem_sandbox.dylib (1217.101.2) <E9D78CDE-FB67-32E7-BABC-9EFC23AA0DC6> /usr/lib/system/libsystem_sandbox.dylib
0x7fff73fd4000 - 0x7fff73fd6fff libsystem_secinit.dylib (62.100.2) <AAC639E5-7103-3366-A602-8FC6944E2C13> /usr/lib/system/libsystem_secinit.dylib
0x7fff73fd7000 - 0x7fff73fdeffb libsystem_symptoms.dylib (1238.100.26) <487B92DE-45F9-39F9-A478-89BBD478157D> /usr/lib/system/libsystem_symptoms.dylib
0x7fff73fdf000 - 0x7fff73ff5ff2 libsystem_trace.dylib (1147.100.8) <BB90B1FD-8C09-3DF4-BD8B-9E4AEADFEA2B> /usr/lib/system/libsystem_trace.dylib
0x7fff73ff7000 - 0x7fff73ffcff7 libunwind.dylib (35.4) <CC87C836-BE9D-334E-A0E6-0297D52E9D73> /usr/lib/system/libunwind.dylib
0x7fff73ffd000 - 0x7fff74032ffe libxpc.dylib (1738.100.39) <32B0E31E-9DA3-328B-A962-BC9591B93537> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 1018
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=631.0M resident=0K(0%) swapped_out_or_unallocated=631.0M(100%)
Writable regions: Total=1.2G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.2G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 768K 6
Activity Tracing 256K 1
CG backing stores 6340K 11
CG image 4772K 16
CoreAnimation 5792K 34
CoreGraphics 8K 1
CoreImage 56K 7
CoreUI image data 1160K 17
Foundation 4K 1
Image IO 224K 14
Kernel Alloc Once 8K 1
MALLOC 522.4M 1249
MALLOC guard page 32K 8
MALLOC_LARGE (reserved) 256K 1 reserved VM address space (unallocated)
MALLOC_NANO (reserved) 256.0M 1 reserved VM address space (unallocated)
Memory Tag 242 12K 1
STACK GUARD 372K 43
Stack 46.2M 44
Stack Guard 56.1M 25
VM_ALLOCATE 1.8G 485
__DATA 45.0M 326
__DATA_CONST 104K 4
__FONT_DATA 4K 1
__GLSLBUILTINS 5176K 1
__LINKEDIT 398.6M 27
__OBJC_RO 32.2M 1
__OBJC_RW 1892K 2
__TEXT 232.4M 321
__UNICODE 564K 1
mapped file 822.6M 448
shared memory 692K 24
TOTAL 4.2G 3122
TOTAL, minus reserved VM space 3.9G 3122
Frank B
03-28-2020, 10:57 AM
I'll try to get to trying Frank's code change at some point, possibly this afternoon.
So, any news?
NuWaveIT
03-28-2020, 02:36 PM
So, any news?
Sorry, I couldn't test yesterday. But I just tried it now, get a new error:
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ synth_simple_drum.cpp: In member function 'virtual void AudioSynthSimpleDrum::update()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ synth_simple_drum.cpp:143:74: error: 'multiply_16tx16t' was not declared in this scope
env_sqr_current = multiply_16tx16t(env_lin_current, env_lin_current) ;
Here is the full dump (again sorry for the length):
Arduino: 1.8.12 (Windows 10), TD: 1.52-beta1, Board: "Teensy LC, Serial, 48 MHz, Smallest Code, US English"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\steve.corn\AppData\Local\Arduino15\packag es -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\steve.corn\AppData\Local\Arduino15\packag es -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\steve.corn\Documents\Arduino\libraries -fqbn=teensy:avr:teensyLC:usb=serial,speed=48,opt=o sstd,keys=en-us -ide-version=10812 -build-path C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800 -warnings=none -build-cache C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_ca che_15264 -verbose C:\SteveCorn\NuWave-GitLab\arduino\test-LC-audio\test-LC-audio.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\steve.corn\AppData\Local\Arduino15\packag es -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\steve.corn\AppData\Local\Arduino15\packag es -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\steve.corn\Documents\Arduino\libraries -fqbn=teensy:avr:teensyLC:usb=serial,speed=48,opt=o sstd,keys=en-us -ide-version=10812 -build-path C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800 -warnings=none -build-cache C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_ca che_15264 -verbose C:\SteveCorn\NuWave-GitLab\arduino\test-LC-audio\test-LC-audio.ino
Using board 'teensyLC' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Using core 'teensy3' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_146800\\sketch\\test-LC-audio.ino.cpp" -o nul
Alternatives for Audio.h: [Audio@1.3 Audio.sav@1.3]
ResolveLibrary(Audio.h)
-> candidates: [Audio@1.3 Audio.sav@1.3]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_146800\\sketch\\test-LC-audio.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_146800\\sketch\\test-LC-audio.ino.cpp" -o nul
Alternatives for SD.h: [SD@1.2.4 SD@1.2.2]
ResolveLibrary(SD.h)
-> candidates: [SD@1.2.4 SD@1.2.2]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_146800\\sketch\\test-LC-audio.ino.cpp" -o nul
Alternatives for SerialFlash.h: [SerialFlash@0.5]
ResolveLibrary(SerialFlash.h)
-> candidates: [SerialFlash@0.5]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_146800\\sketch\\test-LC-audio.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_146800\\sketch\\test-LC-audio.ino.cpp" -o nul
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ analyze_fft1024.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ analyze_fft256.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ analyze_notefreq.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ analyze_peak.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ analyze_print.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ analyze_rms.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ analyze_tonedetect.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ control_ak4558.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ control_cs42448.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ control_cs4272.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ control_sgtl5000.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ control_tlv320aic3206.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ control_wm8731.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ data_spdif.c
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ data_ulaw.c
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ data_waveforms.c
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ data_windows.c
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ effect_bitcrusher.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ effect_chorus.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ effect_combine.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ effect_delay.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ effect_delay_ext.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ effect_envelope.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ effect_fade.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ effect_flange.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ effect_freeverb.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ effect_granular.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ effect_midside.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ effect_multiply.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ effect_reverb.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ effect_waveshaper.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ filter_biquad.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ filter_fir.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ filter_variable.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ input_adc.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ input_adcs.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ input_i2s.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ input_i2s2.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ input_i2s_hex.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ input_i2s_oct.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ input_i2s_quad.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ input_pdm.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ input_spdif3.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ input_tdm.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ input_tdm2.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ memcpy_audio.S
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ mixer.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_adat.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_dac.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_dacs.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_i2s.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_i2s2.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_i2s_hex.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_i2s_oct.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_i2s_quad.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_mqs.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_pt8211.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_pt8211_2.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_pwm.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_spdif.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_spdif2.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_spdif3.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_tdm.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ output_tdm2.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ play_memory.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ play_queue.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ play_sd_raw.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ play_sd_wav.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ play_serialflash_raw.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ record_queue.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ spi_interrupt.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ synth_dc.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ synth_karplusstrong.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ synth_pinknoise.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ synth_pwm.cpp
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\synth_simple_drum.cpp" -o nul
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ synth_sine.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ synth_tonesweep.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ synth_waveform.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ synth_wavetable.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ synth_whitenoise.cpp
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility\\imxrt_hw.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility\\sqrt_integer.c" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI\\SPI.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\File.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\SD.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\cache_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\card_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\dir_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\fat_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\file_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\init_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility\\NXP_SDHC.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility\\Sd2Card.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility\\SdFile.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\utility\\SdVolume.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash\\SerialFlashChip.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash\\SerialFlashDirectory.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire\\Wire.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire\\WireIMXRT.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire\\WireKinetis.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire\\utility\\twi.c" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_146800\\sketch\\test-LC-audio.ino.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_146800\\preproc\\ctags_target_for_gcc_mi nus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_146800\\preproc\\ctags_target_for_gcc_mi nus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/precompile_helper" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_146800" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_146800/pch/Arduino.h" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_146800/pch/Arduino.h.gch"
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\pch\Arduino.h.gch
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ard uino_build_146800/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_146800\\sketch\\test-LC-audio.ino.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_146800\\sketch\\test-LC-audio.ino.cpp.o"
Compiling libraries...
Compiling library "Audio"
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\memcpy_audio.S.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\data_spdif.c.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\data_ulaw.c.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\data_windows.c.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\data_waveforms.c.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\analyze_peak.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\control_ak4558.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\analyze_print.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\analyze_fft256.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\analyze_notefreq.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\analyze_tonedetect.cpp. o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\analyze_fft1024.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\analyze_rms.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\control_cs42448.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\effect_bitcrusher.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\control_wm8731.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\control_cs4272.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\control_sgtl5000.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\effect_chorus.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\effect_delay.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\effect_combine.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\effect_delay_ext.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\effect_envelope.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\effect_fade.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\effect_flange.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\effect_freeverb.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\control_tlv320aic3206.c pp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\effect_granular.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\effect_reverb.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\effect_multiply.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\effect_midside.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\effect_waveshaper.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\filter_biquad.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\filter_fir.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\input_adc.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\filter_variable.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\input_i2s2.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\input_adcs.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\input_i2s.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\input_spdif3.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\input_i2s_oct.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\input_i2s_quad.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\input_tdm2.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\input_pdm.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\input_tdm.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\mixer.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\input_i2s_hex.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\output_adat.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\output_dacs.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\output_i2s2.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\output_dac.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\output_mqs.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\output_i2s_hex.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\output_pt8211.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\output_i2s_oct.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\output_pt8211_2.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\output_spdif2.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\output_i2s.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\output_spdif3.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\output_i2s_quad.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\output_spdif.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\output_pwm.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\output_tdm.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\output_tdm2.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\play_memory.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\play_queue.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\record_queue.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\play_sd_raw.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\synth_pinknoise.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\synth_karplusstrong.cpp .o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\spi_interrupt.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\synth_dc.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\play_serialflash_raw.cp p.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\synth_pwm.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\synth_wavetable.cpp.o
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ard uino_build_146800/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\synth_simple_drum.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\ardu ino_build_146800\\libraries\\Audio\\synth_simple_d rum.cpp.o"
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\synth_sine.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\synth_waveform.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\synth_tonesweep.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\synth_whitenoise.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_bu ild_146800\libraries\Audio\play_sd_wav.cpp.o
Multiple libraries were found for "Audio.h"
Used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio
Not used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio. sav
Multiple libraries were found for "SD.h"
Used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
Not used: C:\Program Files (x86)\Arduino\libraries\SD
Using library Audio at version 1.3 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI
Using library SD at version 1.2.2 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
Using library SerialFlash at version 0.5 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Serial Flash
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire
Error compiling for board Teensy LC.
Frank B
03-28-2020, 02:39 PM
Ok, i'll deactivate simpledrum, too.
NuWaveIT
03-28-2020, 03:11 PM
22kHz sample rate means the maximum frequency that can be reconstructed is 11kHz. Google for Nyquist sampling theorem or Nyquist rate for more info.
True, I am familiar with Nyquist, but in the context of Teensy LC...it doesn't have the power to run the full Audio library, but [as we are trying to test] if we can enable basic functionality, like generate a simple Square wave and output via the DAC pin, I don't see 22KHz sample rate as a hindrance all things considering, and still considering "audible" frequencies.
tobzoska
03-30-2020, 10:22 AM
AudioOutputUSB works fine on both Mac OS 10.12.6 and iOS 12, but I'm running into issues with the AudioInputUSB, getting periodic clicks and pops on the audio stream.
I also tried to adapt the USB code to work at 48kHz as described in various threads around here and it appears to work fine, the clicks are getting less frequent but they are still present. At 48kHz they happen at approx. 13 second intervals, at 44.1kHz they are more frequent. Apart from that, the audio quality is perfect as far as I can tell.
I added a bit of code to toggle a LED at usb_audio.cpp line 195 and it will flicker with each 'click' on the output, so I assume it must be buffer overruns.
I don't know if this is the appropriate time and place to ask for troubleshooting advice, but I wanted to report the bug anyway.
Piachnp
04-02-2020, 08:20 PM
I'm sorry if this is not the right place for this, but I've found this problem with our SD library that has already been fixed in the Arduino version of the SD library.
The main problem is that SD.begin(BUILTIN_SDCARD) returns false when run a second time.
The obvious solution is to potentially check if SD has already been running before calling SD.begin, but there doesn't seem to be an elegant way to do this.
While investigating this I noticed that this problem has been fixed in the arduino version of the SD library (https://github.com/arduino-libraries/SD/pull/38) such that you can call SD.begin as many times as you want. This fix is not present in the Teensyduino version of the SD library. I have tested the fix and it works fine:
boolean SDClass::begin(uint8_t csPin) {
Performs the initialisation required by the sdfatlib library.
Return true if initialization succeeds, false otherwise.
if(root.isOpen()) root.close();
return card.init(SPI_HALF_SPEED, csPin) &&
volume.init(card) &&
root.openRoot(volume);
NuWaveIT
04-03-2020, 12:50 AM
Let me know if you have a new build to test.
Frank B
04-05-2020, 10:32 PM
@Paul: https://forum.pjrc.com/threads/60344-sin-sinf-cos-cosf-strange-timing-results-on-teensy-4
@NuWaveIT: Oh, forgot ... I'll do that in the next days.
xavier.seingard
04-06-2020, 01:38 PM
Hello
First of all I hope everyone here is ok.
I know it's not the best time to ask for a feature, but is there any plan to support RGBW pixels in OctoWS2811 in 1.52 ?
As mentionned here: https://twitter.com/PaulStoffregen/status/1237327583965925376 ?
Best regards,
And be safe!
PaulStoffregen
04-06-2020, 02:47 PM
For Teensy 4, yes, planned. But not coming in beta2.
For Teensy 3, probably not.
PaulStoffregen
04-06-2020, 03:05 PM
On OSX Catalina (versions 10.15.2 - 10.15.4), Teensyduino (1.51 and 1.52 beta) will appear to work until you open a menu. It takes a few seconds and then the program disappears.
I can not reproduce this problem on my Macbook Air running Catalina 10.15.4.
19597
PaulStoffregen
04-06-2020, 03:12 PM
I've added this to my list of issues to fix in beta3.
Paul
04-06-2020, 03:17 PM
Please use 1.52-beta2.
https://forum.pjrc.com/threads/60354-Teensyduino-1-52-Beta-2
Closing this thread.
