Hello,
I'm work on a project using a Teensy 3.2. With this project 4 MAX31855 are used. Each MAX chip use the same spi bus with a different CS pin. All is fine, except the very first spiread.
I use a part of adafruit max38155 library. My current The code is :
Here what happen :
As you can notice, the first spiread is false. How can I solve this ? I think I need to initialise spi before the first read, but I'm unsure how to do it.
Thank you fao any advice.
Manu
void lectureMAX (uint8_t TKtoRead) {
uint32_t TKFrame = infoTK[TKtoRead].instance->spiread32();
uint32_t temp = TKFrame;
Serial.println(temp);
uint32_t MAX31855::spiread32(void) {
uint32_t d = 0;
pinMode(cs, OUTPUT);
digitalWrite(cs, LOW);
delay(2);
SPI.beginTransaction(SPISettings(4000000, MSBFIRST, SPI_MODE0));
d = SPI.transfer(0);
d <<= 8;
d |= SPI.transfer(0);
d <<= 8;
d <<= 8;
SPI.endTransaction();
digitalWrite(cs, HIGH);
return d;
Here what happen :
First spiread result => 54540960
Calculated Value => 52.00
Average[0] : 52.00
28057072
26.75
[1] : 26.75
27532688
26.25
[2] : 26.25
26745936
25.50
[3] : 25.50
27270496
26.00
[0] : 39.00
Manu
