hi all,
This is driving me crazy, when compiling I get this error:
openvfo_lcd_nextion:46: error: expected initializer before '.' token
void HWSerial.begin(long baud);
This look like Serial1 is not declared but it is in the HardwareSerial.h. What am I missing?
Thanks for looking.
OPENVFO-Consortium's OpenVFO Display Routine for Nextion LCD
Uses the default protocol of Nextion LCD.
Do not assign a 2 byte address to Nextion LCD.
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
//#include "Arduino.h"
#include "openvfo.h"
#include "openvfo_lcd.h"
// set this to the hardware serial port you wish to use
#define HWSerial Serial1
#define HWSerial_TX_BUFFER_SIZE 64
#define HWSerial_RX_BUFFER_SIZE 64
#define _SS_MAX_RX_BUFF 35 // RX buffer size
#define PRINT_MAX_LENGTH 30
unsigned long baud = 19200;
//Configure serial
void serial_setup()
Serial.begin(baud); // USB, communication to PC or Mac
HWSerial.begin(9600, SERIAL_8N1); // communication to hardware serial
//Begin of Nextion LCD Library by OPENVFO-Consortium
#ifdef OPENVFO_DISPLAY_NEXTION
Nextion Library for OPENVFO
void HWSerial.write(uint16_t b);
int HWSerial.available(void);
int HWSerial.read(void);
void HWSerial.print(uint16_t *b);
static uint16_t swr_receive_buffer[_SS_MAX_RX_BUFF];
#define TEXT_LINE_LENGTH 20
char softBuffLines[2][TEXT_LINE_LENGTH + 1];
char softBuffSended[2][TEXT_LINE_LENGTH + 1];
char softBuffTemp[TEXT_LINE_LENGTH + 1]; //for STR Command
char c[30], b[30];
char softBuff[20];
char softTemp[20];
void LCDNextion_Init()
memset(softBuffLines[0], ' ', TEXT_LINE_LENGTH);
softBuffLines[0][TEXT_LINE_LENGTH + 1] = 0x00;
memset(softBuffLines[1], ' ', TEXT_LINE_LENGTH);
softBuffLines[1][TEXT_LINE_LENGTH + 1] = 0x00;
void LCD_Init(void)
LCDNextion_Init();
//Begin of Nextion LCD Protocol
// v0~v9, va~vz : Numeric (Transceiver -> Nextion LCD)
// s0~s9 : String (Text) (Transceiver -> Nextion LCD)
// vlSendxxx, vloxxx: Reserve for Nextion (Nextion LCD -> Transceiver)
#define CMD_NOW_DISP '0' //c0
char L_nowdisp = -1; //Sended nowdisp
#define CMD_VFO_TYPE 'v' //cv
char L_vfoActive; //vfoActive
#define CMD_CURR_FREQ 'c' //vc
unsigned long L_vfoCurr; //vfoA
#define CMD_CURR_MODE 'c' //cc
byte L_vfoCurr_mode; //vfoA_mode
#define CMD_VFOA_FREQ 'a' //va
unsigned long L_vfoA; //vfoA
#define CMD_VFOA_MODE 'a' //ca
byte L_vfoA_mode; //vfoA_mode
#define CMD_VFOB_FREQ 'b' //vb
unsigned long L_vfoB; //vfoB
#define CMD_VFOB_MODE 'b' //cb
byte L_vfoB_mode; //vfoB_mode
#define CMD_IS_RIT 'r' //cr
char L_ritOn;
#define CMD_RIT_FREQ 'r' //vr
unsigned long L_ritTxFrequency; //ritTxFrequency
#define CMD_IS_TX 't' //ct
char L_inTx;
#define CMD_IS_DIALLOCK 'l' //cl
byte L_isDialLock; //byte isDialLock
#define CMD_IS_SPLIT 's' //cs
byte L_Split; //isTxType
#define CMD_IS_TXSTOP 'x' //cx
byte L_TXStop; //isTxType
#define CMD_TUNEINDEX 'n' //cn
byte L_tuneStepIndex; //byte tuneStepIndex
#define CMD_SMETER 'p' //cs
byte L_scaledSMeter; //scaledSMeter
#define CMD_SIDE_TONE 't' //vt
unsigned long L_sideTone; //sideTone
#define CMD_KEY_TYPE 'k' //ck
byte L_cwKeyType = -1; //L_cwKeyType 0: straight, 1 : iambica, 2: iambicb
#define CMD_CW_SPEED 's' //vs
unsigned int L_cwSpeed; //cwSpeed
#define CMD_CW_DELAY 'y' //vy
byte L_cwDelayTime = -1; //cwDelayTime
#define CMD_CW_STARTDELAY 'e' //ve
byte L_delayBeforeCWStartTime = -1; //byte delayBeforeCWStartTime
#define CMD_ATT_LEVEL 'f' //vf
byte L_attLevel;
byte L_isIFShift; //1 = ifShift, 2 extend
#define CMD_IS_IFSHIFT 'i' //ci
int L_ifShiftValue;
#define CMD_IFSHIFT_VALUE 'i' //vi
byte L_sdrModeOn;
#define CMD_SDR_MODE 'j' //cj
#define CMD_OPENVFO_INFO 'm' //cm Complete Send OpenVFO Information
//Once Send Data, When boot
//arTuneStep, When boot, once send
//long arTuneStep[5];
#define CMD_AR_TUNE1 '1' //v1
#define CMD_AR_TUNE2 '2' //v2
#define CMD_AR_TUNE3 '3' //v3
#define CMD_AR_TUNE4 '4' //v4
#define CMD_AR_TUNE5 '5' //v5
#define CMD_IS_CW_SHIFT_DISPLAY 'h' //ch
byte L_isShiftDisplayCWFreq; //byte isShiftDisplayCWFreq
#define CMD_CW_SHIFT_ADJUST 'h' //vh
int L_shiftDisplayAdjustVal; //int shiftDisplayAdjustVal
//0:CW Display Shift Confirm, 1 : IFshift save
#define CMD_COMM_OPTION 'o' //vo
byte L_commonOption0; //byte commonOption0
//0:Line Toggle, 1 : Always display Callsign, 2 : scroll display, 3 : s.meter
#define CMD_DISP_OPTION1 'p' //vp
byte L_displayOption1; //byte displayOption1
#define CMD_DISP_OPTION2 'q' //vq
byte L_displayOption2; //byte displayOption2 (Reserve)
#define CMD_TEXT_LINE0 '0' //s0
#define CMD_TEXT_LINE1 '1' //s1
#define CMD_CW_TEXT 'a' //sa
#define CMD_CALLSIGN 'c' //sc
#define CMD_VERSION 'v' //sv
#define TS_CMD_MODE 1
#define TS_CMD_FREQ 2
#define TS_CMD_BAND 3
#define TS_CMD_VFO 4
#define TS_CMD_SPLIT 5
#define TS_CMD_RIT 6
#define TS_CMD_TXSTOP 7
#define TS_CMD_SDR 8
#define TS_CMD_LOCK 9 //Dial Lock
#define TS_CMD_ATT 10 //ATT
#define TS_CMD_IFS 11 //IFS Enabled
#define TS_CMD_IFSVALUE 12 //IFS VALUE
#define TS_CMD_STARTADC 13
#define TS_CMD_STOPADC 14
#define TS_CMD_SPECTRUMOPT 15 //Option for Spectrum
#define TS_CMD_SPECTRUM 16 //Get Spectrum Value
#define TS_CMD_TUNESTEP 17 //Get Spectrum Value
#define TS_CMD_WPM 18 //Set WPM
#define TS_CMD_KEYTYPE 19 //Set KeyType
#define TS_CMD_SWTRIG 21 //SW Action Trigger for WSPR and more
#define TS_CMD_READMEM 31 //Read EEProm
#define TS_CMD_WRITEMEM 32 //Write EEProm
#define TS_CMD_LOOPBACK0 74 //Loopback1 (Response to Loopback channel)
#define TS_CMD_LOOPBACK1 75 //Loopback2 (Response to Loopback channel)
#define TS_CMD_LOOPBACK2 76 //Loopback3 (Response to Loopback channel)
#define TS_CMD_LOOPBACK3 77 //Loopback4 (Response to Loopback channel)
#define TS_CMD_LOOPBACK4 78 //Loopback5 (Response to Loopback channel)
#define TS_CMD_LOOPBACK5 79 //Loopback6 (Response to Loopback channel)
#define TS_CMD_FACTORYRESET 85 //Factory Reset
#define TS_CMD_OPENVFO_REBOOT 95 //Reboot
char nowdisp = 0;
#define HWS_HEADER_CHAR_TYPE 'c' //1Byte Protocol Prefix
#define HWS_HEADER_INT_TYPE 'v' //Numeric Protocol Prefex
#define HWS_HEADER_STR_TYPE 's' //for TEXT Line compatiable Character LCD Control
//Control must have prefix 'v' or 's'
char softSTRHeader[11] = {'p', 'm', '.', 's', '0', '.', 't', 'x', 't', '=', '\"'};
char softINTHeader[10] = {'p', 'm', '.', 'v', '0', '.', 'v', 'a', 'l', '='};
const byte ADCIndex[6] = {A0, A1, A2, A3, A6, A7};
//send data for Nextion LCD
void SendHeader(char varType, char varIndex)
if (varType == HWS_HEADER_STR_TYPE)
softSTRHeader[4] = varIndex;
for (int i = 0; i < 11; i++)
HWSerial.write(softSTRHeader[i]);
softINTHeader[4] = varIndex;
for (int i = 0; i < 10; i++)
HWSerial.write(softINTHeader[i]);
#define INT_ETX 0
#define STR_ETX 1
#define TMP_ETX 2
//Send 0xFF, 0xFF, 0xFF
//etxType : INT_ETX = 0xFF, 0xFF, 0xFF
// STR_ETX = ", 0xFF, 0xFF, 0xFF
// TEMP_ETX = softTemp, 0xFF, 0xFF, 0xff
void SendCommandETX(char etxType)
if (etxType == 2)
HWSerial.print(softTemp);
else if (etxType == 1)
HWSerial.print("\"");
HWSerial.write(0xff);
void SendCommandUL(char varIndex, unsigned long sendValue)
SendHeader(HWS_HEADER_INT_TYPE, varIndex);
memset(softTemp, 0, 20);
ultoa(sendValue, softTemp, DEC);
SendCommandETX(TMP_ETX);
void SendCommandL(char varIndex, long sendValue)
void SendCommandStr(char varIndex, char* sendValue)
SendHeader(HWS_HEADER_STR_TYPE, varIndex);
HWSerial.print(sendValue);
SendCommandETX(STR_ETX);
//Send String data with duplicate check
void SendTextLineBuff(char lineNumber)
//Check Duplicated data
if (strcmp(softBuffLines[lineNumber], softBuffSended[lineNumber]))
SendHeader(HWS_HEADER_STR_TYPE, lineNumber + 0x30); //s0.txt, s1.txt
HWSerial.print(softBuffLines[lineNumber]);
strcpy(softBuffSended[lineNumber], softBuffLines[lineNumber]);
void SendTextLineStr(char lineNumber, char* sendValue)
int i = 0;
for (i = 0; i < 16; i++)
if (sendValue[i] == 0x00)
softBuffLines[lineNumber][i] = sendValue[i];
for (; i < 20; i++)
softBuffLines[lineNumber][i] = ' ';
softBuffLines[lineNumber][TEXT_LINE_LENGTH + 1] = 0x00;
SendTextLineBuff(lineNumber);
void SendEEPromData(char varIndex, int eepromStartIndex, int eepromEndIndex, char offsetTtype)
for (int i = eepromStartIndex; i <= eepromEndIndex; i++)
HWSerial.write(EEPROM.read((offsetTtype == 0 ? USER_CALLSIGN_DAT : WSPR_MESSAGE1) + i));
uint16_t softBuff1Num[14] = {'p', 'm', '.', 'c', '0', '.', 'v', 'a', 'l', '=', 0, 0xFF, 0xFF, 0xFF};
void SendCommand1Num(char varType, char sendValue) //0~9 : Mode, nowDisp, ActiveVFO, IsDialLock, IsTxtType, IsSplitType
softBuff1Num[4] = varType;
softBuff1Num[10] = sendValue + 0x30;
for (int i = 0; i < 14; i++)
HWSerial.write(softBuff1Num[i]);
void SetActivePage(char newPageIndex)
if (L_nowdisp != newPageIndex)
L_nowdisp = newPageIndex;
SendCommand1Num(CMD_NOW_DISP, L_nowdisp);
//End of Nextion LCD Protocol
// The generic routine to display one line on the LCD
void printLine(unsigned char linenmbr, const char *c) {
SendTextLineStr(linenmbr, c);
void printLineF(char linenmbr, const __FlashStringHelper *c)
int i;
char tmpBuff[21];
PGM_P p = reinterpret_cast<PGM_P>(c);
for (i = 0; i < 21; i++) {
unsigned char fChar = pgm_read_byte(p++);
tmpBuff[i] = fChar;
if (fChar == 0)
printLine(linenmbr, tmpBuff);
#define LCD_MAX_COLUMN 20
void printLineFromEEPRom(char linenmbr, char lcdColumn, byte eepromStartIndex, byte eepromEndIndex, char offsetTtype)
int colIndex = lcdColumn;
for (byte i = eepromStartIndex; i <= eepromEndIndex; i++)
if (++lcdColumn <= LCD_MAX_COLUMN)
softBuffLines[linenmbr][colIndex++] = EEPROM.read((offsetTtype == 0 ? USER_CALLSIGN_DAT : WSPR_MESSAGE1) + i);
SendTextLineBuff(linenmbr);
// short cut to print to the first line
void printLine1(const char *c)
printLine(1, c);
void printLine2(const char *c)
printLine(0, c);
void clearLine2()
printLine2("");
line2DisplayStatus = 0;
void printLine1Clear() {
printLine(1, "");
void printLine2Clear() {
printLine(0, "");
void printLine2ClearAndUpdate() {
printLine(0, "");
updateDisplay();
//End of Display Base Routines
//Begin of User Interface Routines
//Main Display for Nextion LCD
//unsigned long
byte nowPageIndex = 0;
//sendType == 1 not check different
void sendUIData(int sendType)
char nowActiveVFO = vfoActive == VFO_A ? 0 : 1;
//#define CMD_VFO_TYPE 'v' //cv
if (L_vfoActive != nowActiveVFO)
L_vfoActive = nowActiveVFO;
SendCommand1Num(CMD_VFO_TYPE, L_vfoActive);
//#define CMD_CURR_FREQ 'c' //vc
if (L_vfoCurr != frequency)
L_vfoCurr = frequency;
SendCommandUL(CMD_CURR_FREQ, frequency);
//#define CMD_CURR_MODE 'c' //cc
byte vfoCurr_mode = modeToByte();
if (L_vfoCurr_mode != vfoCurr_mode)
L_vfoCurr_mode = vfoCurr_mode;
SendCommand1Num(CMD_CURR_MODE, L_vfoCurr_mode);
//if auto cw key mode, exit
//if (isCWAutoMode != 0 || menuOn != 0)
if (isCWAutoMode != 0)
return;
//nowPageIndex = 0;
if (menuOn == 0)
if (sendType == 0)
SetActivePage(0);
SetActivePage(0);
//Text Line Mode
SetActivePage(1);
//#define CMD_VFOA_FREQ 'a' //va
//VFOA
if (L_vfoA != vfoA)
L_vfoA = vfoA;
SendCommandUL(CMD_VFOA_FREQ, L_vfoA);
//#define CMD_VFOA_MODE 'a' //ca
if (L_vfoA_mode != vfoA_mode)
L_vfoA_mode = vfoA_mode;
SendCommand1Num(CMD_VFOA_MODE, L_vfoA_mode);
//#define CMD_VFOB_FREQ 'b' //vb
//VFOB
if (L_vfoB != vfoB)
L_vfoB = vfoB;
SendCommandUL(CMD_VFOB_FREQ, L_vfoB);
//#define CMD_VFOB_MODE 'b' //cb
if (L_vfoB_mode != vfoB_mode)
L_vfoB_mode = vfoB_mode;
SendCommand1Num(CMD_VFOB_MODE, L_vfoB_mode);
//byte isDialLock = ((isTxType & 0x01) == 0x01) ? 1 : 0;
if (L_isDialLock != isDialLock)
L_isDialLock = isDialLock;
SendCommand1Num(CMD_IS_DIALLOCK, L_isDialLock);
//#define CMD_IS_RIT 'r' //cr
if (L_ritOn != ritOn)
L_ritOn = ritOn;
SendCommand1Num(CMD_IS_RIT, L_ritOn);
//#define CMD_RIT_FREQ 'r' //vr
//unsigned long L_ritTxFrequency; //ritTxFrequency
if (L_ritTxFrequency != ritTxFrequency)
L_ritTxFrequency = ritTxFrequency;
SendCommandUL(CMD_RIT_FREQ, L_ritTxFrequency);
//#define CMD_IS_TX 't' //ct
//char L_inTx;
if (L_inTx != inTx)
L_inTx = inTx;
SendCommand1Num(CMD_IS_TX, L_inTx);
//#define CMD_IS_DIALLOCK 'l' //cl
//byte L_isDialLock; //byte isDialLock
//#define CMD_IS_SPLIT 's' //cs
//byte L_Split; //isTxType
if (L_Split != splitOn)
L_Split = splitOn;
SendCommand1Num(CMD_IS_SPLIT, L_Split);
//#define CMD_IS_TXSTOP 'x' //cx
byte isTXStop = ((isTxType & 0x01) == 0x01);
if (L_TXStop != isTXStop)
L_TXStop = isTXStop;
SendCommand1Num(CMD_IS_TXSTOP, L_TXStop);
//#define CMD_TUNEINDEX 'n' //cn
if (L_tuneStepIndex != tuneStepIndex)
L_tuneStepIndex = tuneStepIndex;
SendCommand1Num(CMD_TUNEINDEX, L_tuneStepIndex);
//#define CMD_SMETER 'p' //cp
if (L_scaledSMeter != scaledSMeter)
L_scaledSMeter = scaledSMeter;
SendCommand1Num(CMD_SMETER, L_scaledSMeter);
//#define CMD_SIDE_TONE 't' //vt
if (L_sideTone != sideTone)
L_sideTone = sideTone;
SendCommandL(CMD_SIDE_TONE, L_sideTone);
//#define CMD_KEY_TYPE 'k' //ck
if (L_cwKeyType != cwKeyType)
L_cwKeyType = cwKeyType;
SendCommand1Num(CMD_KEY_TYPE, L_cwKeyType);
//#define CMD_CW_SPEED 's' //vs
if (L_cwSpeed != cwSpeed)
L_cwSpeed = cwSpeed;
SendCommandL(CMD_CW_SPEED, L_cwSpeed);
//#define CMD_CW_DELAY 'y' //vy
if (L_cwDelayTime != cwDelayTime)
L_cwDelayTime = cwDelayTime;
SendCommandL(CMD_CW_DELAY, L_cwDelayTime);
//#define CMD_CW_STARTDELAY 'e' //ve
if (L_delayBeforeCWStartTime != delayBeforeCWStartTime)
L_delayBeforeCWStartTime = delayBeforeCWStartTime;
SendCommandL(CMD_CW_STARTDELAY, L_delayBeforeCWStartTime);
//#define CMD_ATT_LEVEL 'f' //vf
if (L_attLevel != attLevel)
L_attLevel = attLevel;
SendCommandL(CMD_ATT_LEVEL, L_attLevel);
//#define CMD_IS_IFSHIFT 'i'
if (L_isIFShift != isIFShift)
L_isIFShift = isIFShift;
SendCommand1Num(CMD_IS_IFSHIFT, L_isIFShift);
//#define CMD_IFSHIFT_VALUE 'i'
if (L_ifShiftValue != ifShiftValue)
L_ifShiftValue = ifShiftValue;
SendCommandL(CMD_IFSHIFT_VALUE, L_ifShiftValue);
//#define CMD_SDR_MODE 'j' //cj
if (L_sdrModeOn != sdrModeOn)
L_sdrModeOn = sdrModeOn;
SendCommand1Num(CMD_SDR_MODE, L_sdrModeOn);
void updateDisplay() {
sendUIData(0); //UI
// Spectrum for Range scan and Band Scan
#define RESPONSE_SPECTRUM 0
#define RESPONSE_EEPROM 1
#define RESPONSE_EEPROM_HEX_F 89 //C Language order
#define RESPONSE_EEPROM_HEX_R 72 //Nextion order (Reverse)
#define RESPONSE_EEPROM_STR 87 //String
const uint16_t ResponseHeader[11] = {'p', 'm', '.', 's', 'h', '.', 't', 'x', 't', '=', '"'};
const char HexCodes[16] = {'0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'a', 'b', 'c', 'd', 'e', 'f', };
//void sendSpectrumData(unsigned long startFreq, unsigned long incStep, int scanCount, int delayTime, int sendCount)
//sendResponseData(RESPONSE_EEPROM, 0, eepromIndex, eepromReadLength, eepromDataType, 1);
//protocol Type : 0 - Spectrum, 1 : EEProm
//startFreq : Spectrum - Frequency, EEProm - 0
//sendOption1 : Spectrum - 1 Step Frequency, EEProm - EEProm Start Address
//scanCount : Spectrum - 1 Set Length, EEProm - Read Length
//sendOption2 : Spectrum - Value offset (because support various S-Meter), EEProm - EEProm Response DataType (0:HEX, 1:String)
//sendCount : Spectrum - All scan set count, EEProm - always 1
void sendResponseData(int protocolType, unsigned long startFreq, unsigned int sendOption1, int readCount, int sendOption2, int sendCount) //Spectrum and EEProm Data
unsigned long beforFreq = frequency;
unsigned long k;
uint16_t adcBytes[200]; //Maximum 200 Step
//Voltage drop
//scanResult[0] = analogRead(ANALOG_SMETER);
//adcBytes[0] = analogRead(ANALOG_SMETER);
//delay(10);
int readedValue = 0;
for (int si = 0; si < sendCount; si++)
HWSerial.write(ResponseHeader[i]);
for (k = 0; k < readCount; k ++)
if (protocolType == RESPONSE_SPECTRUM)
//Spectrum Data
//Sampling Range
setFrequency(startFreq + (k * sendOption1));
//Wait time for charging
//delay(10);
#ifdef USE_I2C_SMETER
readedValue = GetI2CSmeterValue(I2CMETER_UNCALCS);
#else
//ADC
readedValue = analogRead(ANALOG_SMETER);
readedValue -= (sendOption2 * 3); //0 ~ 765
//Down Scale
readedValue /= 2;
if (readedValue < 0)
readedValue = 0;
else if (readedValue > 255)
readedValue = 255;
readedValue = EEPROM.read(((sendOption2 == RESPONSE_EEPROM_HEX_R) ? (readCount - k - 1) : k) + sendOption1);
if (protocolType == RESPONSE_EEPROM && sendOption2 == RESPONSE_EEPROM_STR) //None HEX
HWSerial.write(readedValue);
HWSerial.write(HexCodes[readedValue >> 4]);
HWSerial.write(HexCodes[readedValue & 0xf]);
} //end of for
//Receive command and processing from External device (LCD or MCU)
int spectrumSendCount = 10; //count of full scan and Send
int spectrumOffset = 0; //offset position
int spectrumScanCount = 100; //Maximum 200
unsigned int spectrumIncStep = 1000; //Increaase Step
extern uint16_t receivedCommandLength;
extern void HWSerial.read(uint16_t * receive_cmdBuffer);
uint16_t swr_buffer[20];
//HardwareSerial_Process
void HWS_Process(void)
//Received Command from touch screen
if (receivedCommandLength > 0)
HWSerial.read(swr_buffer);
int8_t comandLength = receivedCommandLength;
int8_t commandStartIndex = -1;
receivedCommandLength = 0;
//Data Process
//comandLength //Find start Length
for (int i = 0; i < comandLength - 3; i++)
if (swr_buffer[i] == 0x59 && swr_buffer[i + 1] == 0x58 && swr_buffer[i + 2] == 0x68)
commandStartIndex = i;
} //end of for
if (commandStartIndex != -1)
//Complete received command from touch screen
uint16_t commandType = swr_buffer[commandStartIndex + 3];
if (commandType == TS_CMD_MODE)
byteToMode(swr_buffer[commandStartIndex + 4], 1);
else if (commandType == TS_CMD_FREQ)
unsigned long *tempFreq;
tempFreq = (unsigned long *)(&swr_buffer[commandStartIndex + 4]);
//if (*tempFreq > 3000) //for loss protcol
frequency = *tempFreq;
else if (commandType == TS_CMD_BAND)
char currentBandIndex = -1;
if (tuneTXType == 2 || tuneTXType == 3 || tuneTXType == 102 || tuneTXType == 103)
{ //only ham band move
currentBandIndex = getIndexHambanBbyFreq(frequency);
if (currentBandIndex >= 0)
saveBandFreqByIndex(frequency, modeToByte(), currentBandIndex);
setNextHamBandFreq(frequency, swr_buffer[commandStartIndex + 4] == 1 ? -1 : 1); //Prior Band
else if (commandType == TS_CMD_VFO)
menuVfoToggle(1); //Vfo Toggle
else if (commandType == TS_CMD_SPLIT)
menuSplitOnOff(10);
else if (commandType == TS_CMD_RIT)
menuRitToggle(1);
else if (commandType == TS_CMD_TXSTOP)
menuTxOnOff(1, 0x01);
else if (commandType == TS_CMD_SDR)
menuSDROnOff(1);
else if (commandType == TS_CMD_LOCK)
if (vfoActive == VFO_A)
setDialLock((isDialLock & 0x01) == 0x01 ? 0 : 1, 0); //Reverse Dial lock
setDialLock((isDialLock & 0x02) == 0x02 ? 0 : 1, 0); //Reverse Dial lock
else if (commandType == TS_CMD_ATT)
attLevel = swr_buffer[commandStartIndex + 4];
else if (commandType == TS_CMD_IFS)
isIFShift = isIFShift ? 0 : 1; //Toggle
else if (commandType == TS_CMD_IFSVALUE)
ifShiftValue = *(long *)(&swr_buffer[commandStartIndex + 4]);
else if (commandType == TS_CMD_STARTADC)
int startIndex = swr_buffer[commandStartIndex + 4];
int endIndex = swr_buffer[commandStartIndex + 5];
int adcCheckInterval = swr_buffer[commandStartIndex + 6] * 10;
int nowCheckIndex = startIndex;
while (1 == 1)
SendCommandL('n', nowCheckIndex); //Index Input
SendCommandL('x', analogRead(ADCIndex[nowCheckIndex++]));
if (nowCheckIndex > endIndex)
delay(adcCheckInterval);
} //end of while
else if (commandType == TS_CMD_STOPADC)
//None Action
return;
else if (commandType == TS_CMD_SPECTRUM)
//sendSpectrumData(unsigned long startFreq, unsigned int incStep, int scanCount, int delayTime, int sendCount)
//sendSpectrumData(frequency - (1000L * 50), 1000, 100, 0, 10);
//sendSpectrumData(*(long *)(&swr_buffer[commandStartIndex + 4]), spectrumIncStep, spectrumScanCount, spectrumDelayTime, spectrumSendCount);
unsigned long beforeFreq = frequency;
sendResponseData(RESPONSE_SPECTRUM, *(long *)(&swr_buffer[commandStartIndex + 4]), spectrumIncStep, spectrumScanCount, spectrumOffset, spectrumSendCount);
frequency = beforeFreq;
else if (commandType == TS_CMD_SPECTRUMOPT)
spectrumSendCount = swr_buffer[commandStartIndex + 4]; //count of full scan and Send
spectrumOffset = swr_buffer[commandStartIndex + 5]; //Scan interval time
spectrumScanCount = swr_buffer[commandStartIndex + 6]; //Maximum 120
spectrumIncStep = swr_buffer[commandStartIndex + 7] * 20; //Increaase Step
else if (commandType == TS_CMD_TUNESTEP) //Set Tune Step
tuneStepIndex = swr_buffer[commandStartIndex + 4]; //Tune Step Index
else if (commandType == TS_CMD_WPM) //Set WPM
cwSpeed = swr_buffer[commandStartIndex + 4]; //
else if (commandType == TS_CMD_KEYTYPE) //Set Key Type
cwKeyType = swr_buffer[commandStartIndex + 4];
//for reduce program memory
Iambic_Key = cwKeyType != 0;
//if (cwKeyType == 0)
// Iambic_Key = false;
//else
//Iambic_Key = true;
if (cwKeyType == 1)
keyerControl &= ~IAMBICB;
keyerControl |= IAMBICB;
else if (commandType == TS_CMD_SWTRIG)
TriggerBySW = 1; //Action Trigger by Software
else if (commandType == TS_CMD_READMEM ) //Read Mem
uint16_t eepromIndex = *(uint16_t *)(&swr_buffer[commandStartIndex + 4]);
byte eepromReadLength = swr_buffer[commandStartIndex + 6];
byte eepromDataType = swr_buffer[commandStartIndex + 7]; //0 : Hex, 1 : String
else if (commandType == TS_CMD_WRITEMEM) //Write Mem
Address : 2 byte int
Length : Data Length
Checksum : (Addr0+Addr1+Len) %256
Data : Variable (Max 23)
byte writeLength = swr_buffer[commandStartIndex + 6];
byte writeCheckSum = swr_buffer[commandStartIndex + 7];
//Check Checksum
if (writeCheckSum == (swr_buffer[commandStartIndex + 4] + swr_buffer[commandStartIndex + 5] + swr_buffer[commandStartIndex + 6]))
//if (writeCheckSum == (swr_buffer[commandStartIndex + 4] + swr_buffer[commandStartIndex + 5] + writeLength))
//if (eepromIndex > 64) //Safe #1
#ifdef OPENVFO_DISPLAY_NEXTION_SAFE
//Safe #2
if (eepromIndex < 770 || eepromIndex > 775 )
eepromIndex = -2;
#else
if (1 == 1)
for (int i = 0; i < writeLength; i++)
EEPROM.write(eepromIndex + i , swr_buffer[commandStartIndex + 8 + i]);
eepromIndex = -2;
SendCommandL('n', eepromIndex); //Index Input
//else if (TS_CMD_LOOPBACK0 <= commandType && commandType <= TS_CMD_LOOPBACK5) //Loop back Channel 0 ~ 5 Loop back Channel 1~5 : Reserve
else if (TS_CMD_LOOPBACK0 == commandType) //Loop back Channel 0 ~ 5
SendCommandUL('v', *(unsigned long *)&swr_buffer[commandStartIndex + 4]); //Return data
SendCommandUL('g', commandType); //Index Input
//return;
else if (commandType == TS_CMD_FACTORYRESET || commandType == TS_CMD_OPENVFO_REBOOT)
if (*(unsigned long *)&swr_buffer[commandStartIndex + 4] == 1497712748)
if (commandType == TS_CMD_OPENVFO_REBOOT)
FrequencyToVFO(1); //Save current Frequency and Mode to eeprom
SCB_AIRCR = 0x05FA0004;
for (unsigned int i = 0; i < 32; i++) //factory setting range
EEPROM.write(i, EEPROM.read(FACTORY_VALUES + i)); //65~96 => 0~31
setFrequency(frequency);
SetCarrierFreq();
updateDisplay();
char checkCount = 0;
char checkCountSMeter = 0;
//execute interval : 0.25sec
void idle_process()
//S-Meter Display
if (((displayOption1 & 0x08) == 0x08 && (sdrModeOn == 0)) && (++checkCountSMeter > SMeterLatency))
scaledSMeter = GetI2CSmeterValue(I2CMETER_CALCS);
#else
int newSMeter;
newSMeter = analogRead(ANALOG_SMETER) / 4;
currentSMeter = newSMeter;
scaledSMeter = 0;
for (byte s = 8; s >= 1; s--) {
if (currentSMeter > sMeterLevels[s]) {
scaledSMeter = s;
checkCountSMeter = 0; //Reset Latency time
} //end of S-Meter
sendUIData(1);
//When boot time, send data
void SendUbitxData(void)
//Wait for ready other device (LCD, DSP and more)
//delay(500);
delay_background(500, 2);
SendCommandL(CMD_AR_TUNE1, arTuneStep[0]);
SendCommandL(CMD_AR_TUNE2, arTuneStep[1]);
SendCommandL(CMD_AR_TUNE3, arTuneStep[2]);
SendCommandL(CMD_AR_TUNE4, arTuneStep[3]);
SendCommandL(CMD_AR_TUNE5, arTuneStep[4]);
SendCommand1Num(CMD_IS_CW_SHIFT_DISPLAY, isShiftDisplayCWFreq);
SendCommandL(CMD_CW_SHIFT_ADJUST, shiftDisplayAdjustVal);
SendCommandL(CMD_COMM_OPTION, commonOption0);
SendCommandL(CMD_DISP_OPTION1, displayOption1);
unsigned long nextionDisplayOption;
EEPROM.get(EXTERNAL_DEVICE_OPT1, nextionDisplayOption);
SendCommandUL(CMD_DISP_OPTION2, nextionDisplayOption);
SendCommandStr(CMD_VERSION, (char *)("+v1.200")); //Version
SendEEPromData(CMD_CALLSIGN, 0, userCallsignLength - 1, 0);
//Frequency of Bands
HWSerial.write(SpectrumHeader[i]);
byte *tmpByte;
tmpByte = (byte *)hamBandRange;
for (byte i = 0; i < (useHamBandCount -1) * 4; i++)
HWSerial.write(HexCodes[*tmpByte >> 4]);
HWSerial.write(HexCodes[*tmpByte & 0xf]);
tmpByte++;
for (int i = 0; i < 4; i++)
HWSerial.write(SpectrumFooter[i]);
//Complte Send Info
SendCommand1Num(CMD_OPENVFO_INFO, 1);
//Page Init
L_nowdisp = 0;
//AutoKey LCD Display Routine
void Display_AutoKeyTextIndex(byte textIndex)
byte diplayAutoCWLine = 0;
if ((displayOption1 & 0x01) == 0x01)
diplayAutoCWLine = 1;
//LCD_SetCursor(0, diplayAutoCWLine);
softBuffLines[diplayAutoCWLine][0] = byteToChar(textIndex);
softBuffLines[diplayAutoCWLine][1] = ':';
SendTextLineBuff(diplayAutoCWLine);
void LCD_CreateChar(uint16_t location, uint16_t charmap[])
void updateLine2Buffer(char displayType)
//not use with Nextion LCD
void DisplayCallsign(byte callSignLength)
//Not use with Nextion LCD
void DisplayVersionInfo(const __FlashStringHelper * fwVersionInfo)
Thanks for looking.
