Using DMA to drive PWM signal on Teensy 4.0
Setanko
Hello,
I am currently working on a project in which I would like to use DMA to update PWM pulse length on the Teensy 4 board. More specifically, I would like to use the PWM counter reset as a trigger for DMA to move data from an array in my code to one of the VALx registers of the PWM peripheral (in my case, VAL3 register of Submodule 0 of FlexPWM2). After reading through the manual (https://www.pjrc.com/teensy/IMXRT1060RM_rev2.pdf), Paul's PWM.c code (https://github.com/PaulStoffregen/cores/blob/master/teensy4/pwm.c), and some other forum posts, I realized that I should 1. use Paul's DMAChannel library and 2. also need to set a LDOK bit in addition to updating the VALx register in order to get the PWM pulse length to actually change. However, after working on this for a few days, I'm still not getting anywhere code-wise. Are there any examples of DMA being used in combination with PWM that I can take a look at, or alternatively, can anyone suggest a general layout for how my code might look?
Many thanks.
Driving FLEXPWM with DMA
Hello,
Many thanks.
Looks like you are close. From your description, the following should vary the duty cycle.
  FLEXPWM2_SM0VAL3 = val3;
  FLEXPWM2_MCTRL |= FLEXPWM_MCTRL_LDOK(??);
  val3 = (val3+1)%30000;
  delay(1);
If that works, remove FLEXPWM2 stuff from the loop and add the following in your setup:
void dmaSetup() {
  FLEXPWM2_SM0DMAEN = FLEXPWM_SMDMAEN_VALDE;  // Enable DMA  FLEXPWM2 submodule 0
  dma.destination((uint16_t&) FLEXPWM2_SM0VAL3);   // Load the pulse width register
  dma.sourceBuffer(dma_source.data(), sizeof(dma_source));
  dma.triggerAtHardwareEvent(DMAMUX_SOURCE_FLEXPWM2_WRITE0);   // Trigger the DMA from PWM2 write on SM0
  dma.enable();
