View Full Version : Teensyduino 1.52 Beta #5
Paul
05-13-2020, 05:35 PM
Here is a fifth beta test for Teensyduino 1.52.
Linux 32 bit:
https://www.pjrc.com/teensy/td_152-beta5/TeensyduinoInstall.linux32
Linux 64 bit:
https://www.pjrc.com/teensy/td_152-beta5/TeensyduinoInstall.linux64
Linux ARM:
https://www.pjrc.com/teensy/td_152-beta5/TeensyduinoInstall.linuxarm
Linux ARM64:
https://www.pjrc.com/teensy/td_152-beta5/TeensyduinoInstall.linuxaarch64
MacOS 10.10 to 10.15:
https://www.pjrc.com/teensy/td_152-beta5/Teensyduino_MacOS_Catalina.zip
MacOS 10.8 to 10.14:
https://www.pjrc.com/teensy/td_152-beta5/TeensyduinoInstall.dmg
Windows:
https://www.pjrc.com/teensy/td_152-beta5/TeensyduinoInstall.exe
Changes since Teensyduino 1.52-beta4 (https://forum.pjrc.com/threads/60746-Teensyduino-1-52-Beta-4):
Fix Audio ADC input on Teensy 3.x
Initialize PSRAM chips at startup on Teensy 4.1
defragster
05-13-2020, 07:51 PM
Win 10 :: installed TD 1.52 B5 - that went well. I deleted ALL of Teensy\AVR first to overwrite that in exisiting IDE 1.8.12.
bicycleguy
05-13-2020, 09:05 PM
Mac 10.15.4 Catalina, this B5, Teensy4.1 no Xtra chips, installed no problems.
Even inexplicably solves most issues I was having with Franks memory info program https://forum.pjrc.com/threads/57326-T4-0-Memory-trying-to-make-sense-of-the-different-regions?p=239115&viewfull=1#post239115
It still makes the T4.1 unresponsive and blinking when I set optimization to 'debug' with the flexRamInfo program.
DD4WH
05-13-2020, 09:17 PM
Win10, Teensy 4.0, Teensy Convolution SDR, works well!
Win10, Teensy 4.1, 2 PSRAM chips, tried several example sketches, including PSRAM memory display ("16MB"), works well so far, however the T4.1 does only program after pressing the program button
Frank B
05-13-2020, 10:14 PM
Might be the stack-info...
Not sure.
defragster
05-13-2020, 10:18 PM
@DD4WH: with T_4.1 fresh from the mail and IDE 1.8.12 w/TD1.52 B5 it does an AUTO Upload from IDE.
Wondering if you have an alternate USB cable? Is TyComm or other 'external' SerMon in use holding the USB port open preventing Auto Upload?
I did the PSRAM init test with no chips yet soldered and it works to not find them and see them not work. And from the IDE that works with Ctrl+U to t_SerMon and IDE_SerMon.
<edit>: TimeRTC.pde :: Working from Windows to pass the current PC time to T_4.1 on upload.
> Note::
>> t_SerMon restarts properly after upload
>> IDE_SerMon does not restart after IDE upload with this sketch? It stays "Offline"
<edit> Fresh T_4.1 - did 15s Restore with no problem and returned to work for AUTO upload of the TimeRTC.pde sketch as above
Frank B
05-13-2020, 10:23 PM
I'm having the same issue since ages - any teensy.
Incomprehensible.
Sometimes it works for days without me having to press the button - then - with the same sketch - it doesn't work anymore.
Sometimes Arduino forgets the serial port - and I have to select exactly the same one again.
This happens with all cables.
I suspect windows is the problem. Or, more likely, a bug in the (patched?) Arduino or associated tools.
Then, the PJRC-patched Ardunio has still the problem, that with very fast prints - the Serial monitor prints random pc-memory contents (a pointer going wild). Race condition.. After while it hangs completely (no suprise, then.. (pointer))
KurtE
05-13-2020, 11:11 PM
I am wondering, I was trying T4.1 (without memory) in my Lynxmotion Servo board for first time and it would not program using my updated TyCommander... Tried a few different things.
I undid the TyCommander and I reinstalled the new beta to make sure.
I then did the N second reset of the board to make sure back to default and now I can program it... At least with one simple case.
Now try the next one.
PaulStoffregen
05-14-2020, 01:22 AM
It could be a bug. Maybe open a command prompt window and run the "teensy_ports.exe". It should be in C:\Program Files (x86)\Arduino\hardware\tools. If you just leave it running, you'll see it prints JSON about each USB connect and disconnect event, or updates as Windows makes more info available.
I can't do much about those Windows problems.
Deleted User
05-14-2020, 11:54 AM
This would need to be fixed for 1.52
https://forum.pjrc.com/threads/45216-Two-GUI-related-bugs
Unfortunately I am not able to repair it.
So please, coders, this is yours.
Frank B
05-14-2020, 07:25 PM
@flashburn:
Please, user, it's yours (means: Test it)
https://forum.pjrc.com/threads/45216-Two-GUI-related-bugs?p=239299&viewfull=1#post239299
Deleted User
05-14-2020, 08:23 PM
:eek: Do you believe in the Users?
Thank you Frank B.
Catching the NULL cures the symptom, but there has to be a reason why this error evolves.
Anyway, I've tried several imports that failed before and work now, so I think it is important to merge this to 1.52, so the audio tool can be used for more complex projects.
I remember you've made some important adjustments forTeensy 4.x to the tool. Do you plan to commit them, too? Or what about a second index.html for Teensy 4.x?
manitou
05-14-2020, 08:28 PM
I think this is wrong in teensy4/startup.c
CCM_CBCMR = (CCM_CBCMR & (CCM_CBCMR_FLEXSPI2_PODF_MASK | CCM_CBCMR_FLEXSPI2_CLK_SEL_MASK))
| CCM_CBCMR_FLEXSPI2_PODF(7) | CCM_CBCMR_FLEXSPI2_CLK_SEL(0); // 49.5 MHz
needs "~"
CCM_CBCMR = (CCM_CBCMR & ~(CCM_CBCMR_FLEXSPI2_PODF_MASK | CCM_CBCMR_FLEXSPI2_CLK_SEL_MASK))
i was having a heck of time figuring out why PSRAM clock was running at 90mhz when code said 49.5 !
EDIT:
hmm, looks like that was fixed on github 18 hours ago with
| CCM_CBCMR_FLEXSPI2_PODF(5) | CCM_CBCMR_FLEXSPI2_CLK_SEL(3); // 88 MHz
Frank B
05-14-2020, 10:29 PM
Well, it fixes the problem - does it not?
Nope.
