View Full Version : Teensyduino 1.52 Released
Paul
05-16-2020, 12:24 PM
Teensyduino 1.52 has been released.
1.52 brings support for Teensy 4.1, USB audio on Teensy 4.x, OctoWS2811 support for Teensy 4.x with LEDs on any number of pins, USB dual & triple serial, 4/6/8 channel I2S on Teensy 4.x, RGBW support in WS2812Serial, and many small improvements and bug fixes.
Changes since Teensyduino 1.52-beta6:
Workaround for USB memory bandwidth at very slow CPU speeds
Fix import bug in Audio Design Tool (Frank B)
OctoWS2811 fix memory use with fewer than 8 pins
Clean up compiler warnings in USBHost_t36 ADK driver
The full list of changes since Teensyduino 1.51:
Support for Teensy 4.1 USB Audio support for Teensy 4.0
OctoWS2811 ported to Teensy 4.0
WS2812Serial support for RGBW SK6812 LEDs
FreqMeasureMulti ported to Teensy 4.0 (KurtE)
Dual & Triple USB Serial (Geert Uytterhoeven)
Audio support for 4,6,8 channel I2S on Teensy 4.0
Audio support for SPDIF input on Teensy 4.0 (FrankB)
Audio DAC support for Teensy LC (Ben Kurtz)
Fix Serial.print() conflict with USB Touchscreen
Fix contact count on USB Touchscreen (purple-ben)
Defined FLASHMEM on Teensy 3.x, for compatibility with Teensy 4 code (FrankB)
Fix cache handling in I2S audio input on Teensy 4.0 (Frank B)
Fix numerous iMXRT register field defines
MTP USB descriptors on Teensy 4.0 - actual MTP support still experimental
Libraries updated: FlexCAN_t4, ST7735_t3, RA8875
Fix USB RawHID on Teensy 4.0 (KurtE)
Fix USB audio+midi+serial descriptor on Teensy 4.0 (widdly)
Add ADK to USBHost_t36 (Matt Bergman)
Fix USB Host MIDI transmit race condition (essej)
Optimize USB interrupt on Teensy 4.0 (Frank B)
Arduino compatibility of digitalWrite control pullups (FrankB)
Add missing MPU traps on Teensy 4.0 (FrankB)
Fix SGTL5000 clock ratio setting (FrankB)
Fix I2S slave on Teensy 4.0 (widdly)
Add DMAMEM & fix warnings in I2S on Teensy 4.0 (FrankB)
Improve SPI use by SD on Teensy LC (rutmarti)
Support alternate SPI pins on Teensy 4.1 (KurtE)
Support alternate Teensy 4.1 CS pins on ILI9341_t3 (KurtE)
Fix Teensy Loader on MacOS 10.13 with Catalina version
Fix teensy_serialmon 100% CPU on Linux if Arduino process killed
Workaround for rare Windows Defender flase positive when installing Java classes
Allow SD.begin() to be called more than once
Support hardware serial CTS pins on Teensy 4.1 (KurtE)
Fix double float promotion (Frank B)
Fix I2S input use of cache (Frank B)
Fix installer crash on Jetson Nano
Update libs: RA8875, ILI9844_t3, QuadEncoder, ST7735_t3
Fix RTC auto-set on Teensy 4.x with daylight savings time
Fix RTC set on Teensy 4.0 (Silverlock)
Audio ADC input on Teensy 4.0 - experimental
Hardware serial pin fixes for Teensy 4.1 (KurtE)
Add dummy Keyboard.h on Teensy 4, for Arduino compatibility
Use standard (not low power) ADC mode
Align DMA buffers to 32 bytes (Frank B)
Fix ADC_ETC defines
Use recommended analog bias current on Teensy 4.x (Frank B)
Update Snooze library
Fix Audio ADC input on Teensy 3.x
Initialize PSRAM chips at startup on Teensy 4.1
Increase PSRAM clock to 88 MHz & fix error in writing clock setting
Use strong drive & hysteresis for FlexSPI2 pins
Minor improvement in OctoWS2811 for Teensy 4.x
OctoWS2811 support for any group of pins on Teensy 4.x
mjs513
05-16-2020, 01:17 PM
Downloaded and installed 1.52 over existing betas with 1.8.12 IDE. Install - no problems with Win10x64 pc.
Ran a couple of quick tests: PSRAMmemoryTest and one of my 3dModels on the RA8876, and ILI9488 graphics test sketches no problems. Testing done on T4.1 with 2 PSRAM chips installed.
insolace
05-16-2020, 05:09 PM
Thanks for the update. Where is the source code for the updated RA8875 library located?
jpk
05-16-2020, 08:40 PM
Actual Debian with actual Arduino: usb audio out and analog in / i2c in both on T3.6 and T4 work well. I now get much cleaner signals! Thanks for the enhancements.
defragster
05-16-2020, 10:09 PM
Ran a couple of quick tests: PSRAMmemoryTest ... Testing done on T4.1 with 2 PSRAM chips installed.
Same here - PSRAM test on 1 and 2 chip T_4.1's, TimeTeeny3 sample works on T_4.1, Logger to SD (sdfat-beta) using 14+MB of PSRAM for buffer space working.
Frank B
05-17-2020, 08:20 PM
@Paul: this is the effect I mentioned:
20172
You see different numbers: 10002/0/0/B/3 vs 10002/0/0/B/4
The serial monitor does not open now - but if I select the usual COM11 again (this is the number for this teensy) it will work normally.
neroroxxx
05-18-2020, 12:14 AM
Will Serial8 be available with WS2812Serial library on T4.1?
bicycleguy
05-18-2020, 05:41 PM
No problems on Mac Catalina install.
Also installed on Raspberry Pi4 with Debian Buster 4.19. Had issue with libusb-0.1.so.4 similar to but not exactly like https://forum.pjrc.com/threads/40965-Linux-64bit-Arduino-1-6-13-Issues-starting-Teensy-Loader-and-libusb-0-1-so-4-error?p=127854&viewfull=1#post127854
Solved with "sudo apt-get install libusb-dev". Then realized forgot to do apt-get update, apt-get upgrade before Arduino-Teensyduino install and after I did that it had a different issue seeing the T4 until Pi was re-booted then all worked well again.
Just for info 1st compile of 'Examples/Audio/WaveFilePlayer' took 45 seconds. Subsequent compiles about 4 seconds.
Etienne
05-18-2020, 11:59 PM
Hi, there's something I don't understand, that might be a copy/paste bug:
in usb_raw_hid.c, line 140 :
arm_dcache_flush_delete(txdata, SEREMU_TX_SIZE);
I would rather have expected :
arm_dcache_flush_delete(txdata, RAWHID_TX_SIZE);
Since SEREMU_TX_SIZE and RAWHID_TX_SIZE are both 64 in usb_desc.h this won't change the final result, but I thought it should be corrected.
WMXZ
05-19-2020, 10:39 AM
I get now warnings on not to include "Time.h" but "TimeLib.h"
This is 'interfering' with plain system routines.
IMHO, TimeLib should be redesigned to NOT use Time.h
IMHO, capitalizing the T is NOT, repeat NOT the proper way to avoid compilation conflicts, (It only indicates a Linux centric mind)
defragster
05-19-2020, 11:21 AM
Indeed this message is recurrent and confusing:
T:\arduino-1.8.12\hardware\teensy\avr\libraries\Time/time.h:1:2: warning: #warning "Please include TimeLib.h, not Time.h. Future versions will remove Time.h" [-Wcpp]
When the header has this code:
//#include <time.h>
#include <TimeLib.h>
... this is in the new dataLogger library from @MBorgerson
it seems like it chains in from somewhere else a few layers up:
"T:\\arduino-1.8.12\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IT:\\TEMP\\arduino_build_989179/pch" "-IT:\\arduino-1.8.12\\hardware\\teensy\\avr\\cores\\teensy4" "-IT:\\tCode\\libraries\\DataLogger" "-IT:\\tCode\\libraries\\SdFat\\src" "-IT:\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\SPI" "-IT:\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\Time" "T:\\TEMP\\arduino_build_989179\\sketch\\Fast_Logge rT4_1.ino.cpp" -o "T:\\TEMP\\arduino_build_989179\\sketch\\Fast_Logge rT4_1.ino.cpp.o"
In file included from t:\arduino-1.8.12\hardware\tools\arm\arm-none-eabi\include\sys\stat.h:9:0,
from t:\arduino-1.8.12\hardware\tools\arm\arm-none-eabi\include\sys\_default_fcntl.h:188,
from t:\arduino-1.8.12\hardware\tools\arm\arm-none-eabi\include\sys\fcntl.h:4,
from t:\arduino-1.8.12\hardware\tools\arm\arm-none-eabi\include\fcntl.h:1,
from t:\tcode\libraries\sdfat\src\common\fsapiconstants .h:30,
from T:\tCode\libraries\SdFat\src/ExFatLib/ExFatFile.h:36,
from T:\tCode\libraries\SdFat\src/ExFatLib/ExFatVolume.h:28,
from T:\tCode\libraries\SdFat\src/ExFatLib/ExFatLib.h:27,
from T:\tCode\libraries\SdFat\src/SdFat.h:33,
from T:\tCode\libraries\DataLogger/DataLogger.h:12,
from T:\tCode\sd\Fast_LoggerT4_1\Fast_LoggerT4_1.ino:1:
immortalSpirit
05-23-2020, 09:43 PM
Teensyduino 1.52 (and 1.51 before it) is crashing often and consistently.
All I have to do is upload cmd-U and open serial monitor cmd-shift-m about 5 or 6 times and it will crash. The program I am uploading is 3000+ lines of code, and once the serial monitor is open it prints about 20 short lines in an instant and then terminates.
If I just upload, open serial monitor, let it execute, then close serial monitor, about 3 times in a row, on the 4th time I will see a spinning beach ball for a few seconds, and by the 5th or 6th time it's more like 10-15 seconds of spinning beach ball, and around the 7th time I crash with the attached OutOfMemory message.
The work-around is to simple quit and restart about every 5 uploads. I am currently working very actively on my program, so 5 uploads can be 5 minutes. Quite a PITA. Also, restart is *very* slow, always, but that is not the issue here.
I'm on a 2018 MacBook Pro, 13", running OS-X 10.15.5 Beta. The USB is going thru a short Apple usb-c to usb-3 conversion cable and then a short usb to usb-mini cable to the Teensy board.
I have tried this on a Teensy 3.2 and a new 4.0, same results. I've set the cpu speeds to min, same. I have deleted and re-downloaded the Teensyduino app several times, and used the 1.51 and now the latest 1.52 versions, same.
Any thoughts?
20240
defragster
05-23-2020, 10:07 PM
@immortalSpirit - one thought ... given no idea of sketch behavior WRT to the following ...
How does setup() start before printing - is there a 'no print' before connect like below? On Windows this hasn't happened directly recently - maybe code like this helps prevent a series of prints that can get lost and confuse the system during the completion of USB_init:
// don't Serial.print() yet - other prep okay
while (!Serial && millis()<1000) ; // wait
Serial.print("Hello World! @ ms = ");
Serial.println(millis());
Teensy enters setup() at 300 ms - but fastest ready on Windows measured when SerMon ready is like 345 ms and 400 ms is closer to typical and 500+ms happens not sure about mac? But unrestrained print in that time could be problematic depending on how it resolves.
immortalSpirit
05-23-2020, 11:09 PM
Thanks for quick reply. Yes, actually I had something very similar. But just "while (!serial) {};" without the millis(). (And instead of "Hello World" I print out "Welcome, O Great and Mighty Master!"). So I changed it to exactly your suggested code, same results.
This led me to thinking... (always a dangerous thing to do)...
I loaded "Blink" from the examples! It's setup is: void setup() { pinMode(led, OUTPUT); } and it does no Serial i/o.
10 times in a row: cmd-U, wait for "Done uploading.", wait 1 second, repeat. No unusual action. Teensy blinking away.
Next, restart Teensyduino, load blink, cmd-u just once. Then:
5 times in a row: cmd-shift-M, wait 1 second, cmd-W
SPINNING BALL ON SECOND TIME, CRASH ON FOURTH TIME!!!
OMG! Something is terribly wrong. I'm just opening and closing the serial monitor. No other keystrokes and no serial i/o from the program! OMG!
Just for grins, I changed the Blink setup to include your example code, print out "hello world". No change to loop(). Same, crash on merely opening and closing the serial monitor 4 times!
For more fun, I got out an old Arduino Uno and loaded blink. cmd-u once, repeat { cmd-shift-m, wait 1 sec, cmd-w) at least 10 times, no problem, instant open and close.
There u go.
Serial monitor open and close with Teensy 3.2 or 4.0 connected seems to be leaking memory like crazy. Is it me or can u reproduce this???
Frank B
05-23-2020, 11:35 PM
Oh, I've seen the Serial Monitor printing its own sourcecode, on windows, so ...
These are the first signs of the coming improbability drive on Teensy 5. For sure.
Make sure you have your towel handy.
pjkdeveloper
05-23-2020, 11:37 PM
Probably losing my mind, but I'm on Manjaro with Arduino 1.8.12 and 1.52 TeensyDuino. I am recording snippets of audio and writing .raw SD files. When I play them back using playSdRaw, they sound fine, but when I import a raw file into audacity, it seems that the bitrate is 22050? The previous TeensyDuino I was testing with was 1.52beta4, where these raw files were indeed 44100.
Could there possibly be something in the release version of 1.52 that changed the bitrate I'm seeing in my recorded raw files?
Thanks!
immortalSpirit
05-23-2020, 11:46 PM
Thanks Frank B. Laughing out loud! There is a small but finite probability I'll be laughing about this all week!
Frank B
05-23-2020, 11:55 PM
Yes, most instructions on the T4 require only one cycle. Two of them can be executed simultaneously (->0.5)
The next teensy has a second CPU... ...so we subtract one cycle, and we have -0.5.
That means the program is finished before you run it! Or , if you wait some time longer.. before you write it!
No, but seriously, something's wrong with the serial monitor.
Frank B
05-24-2020, 12:16 AM
@ pjkdeveloper (https://forum.pjrc.com/members/65771-pjkdeveloper)
Sure you use the correct import settings?
16 Bit.
pjkdeveloper
05-24-2020, 01:09 AM
Thank you for responding Frank. Yes I'm sure. When I get home tonight I'm going to do a fresh install of Arduino and 1.52....i don't remember if I installed 1.52 release over the top of the beta, although it seems unlikely this could be a side effect, no? Dumbfounded right now but will test again tonight.
immortalSpirit
05-24-2020, 02:11 AM
I have stumbled upon a "fix"!
When I click the "Tools" pulldown and select the Port, I have a choice at the top called "/dev/cu..... Serial (Teensy 3.2)"
And below, there is another choice, "/dev/cu... (Teensy)"
I always assumed they were identical, and I always picked the top one.
20242
When I started choosing the bottom one (today), the *bug* goes away!!!!!
I can open and close the serial window now any number of times and see no spinning beach ball and no crash. Who wudda thunk it?
Still seems like a bad bug, or at least a UI unclarity, but I'm relatively satisfied now with the "fix".
Thanks for listening,
Steve.
pjkdeveloper
05-24-2020, 06:40 AM
Hello Frank et al.
So, yes, I'm an idiot. Here is what I didn't realize about importing into audacity. I thought that when the "import" dialog appears after choosing the file to import, it is populated with default values not related to the raw file being imported. My problem was that when importing a raw file from my program compiled with 1.52 release, my audacity import dialog defaults to "stereo".....I didn't catch that. So the file indeed is 44100, but I *still* don't know why importing my raw files created with 1.52 release default to "stereo" in the audacity import dialog, and raw files from my same code compiled with 1.52beta 3 & 4 result in audacity's import dialog correctly defaulting to mono. I didn't think there was any header or other info in the raw file that would indicate *anything* to audacity about the raw audio data. It all doesn't matter at this point, as the matter is solved for my purposes, but does it make sense that audacity's import dialog would default to mono for pre-1.52 release and stereo for raw files created with the release version of 1.52?
Sorry for my dumb posts and thank you for reading!
pjkdeveloper
05-24-2020, 10:15 AM
realize now its probably got nothing to do with beta vs release 1.52. When I've been importing, it seems random as to whether the default import dialog is at 'mono' or 'stereo'. Possibly audacity is looking at some bit for a clue as to whether its mono or stereo, but since the raw is pure audio data, that bit will randomly be a 1 or a 0...?
paynterf
05-25-2020, 04:14 PM
When you mention the 'Tools' menu - is this in the Aduino IDE or something else. I'm running Win 10 and don't see the same layout, so any help would be appreciated
TIA,
Frank
analog&RFmodels
05-27-2020, 07:33 AM
Frank B - I am chomping at the bit to play with Duff's snooze lib included in 1.52 for Teensy 4. Do you think that the
serial monitor is so broken that someone with only medium Teensy experience (2.5 year) and medium programming
skills (amateur for 44 year) could get anything done with 1.52 or should I wait ? running 1.48 now. thanks
defragster
05-27-2020, 08:53 AM
Serial Monitor generally not any problem - at least on Windows. It only gets freaked out with output too fast too read.
General debug output - even heavy output works perfectly fine. Just the T_4.x running without restraint can wig out the computer.
If anything it is as good or better than what was shipped in TD_1.48
Arctic_Eddie
05-28-2020, 02:23 PM
Hardware/software: Acer desktop, Win7, IDE 1.8.12, TD 1.52.
You're right. With my T4x boards, I get all kinds of problems. Port not found, port busy, no upload, upload but no printout, partial printout, always have to push the reset button on the board to get it to run and print. With my T3 boards, upload always works followed by run and full debug printout.
Tried lowering the CPU clock to 150MHz and 396MHz and it always works correctly. At 450MHz, it starts to fail with partial prints and gets worse when faster. Surprisingly, after using it at the lower speeds, it does not fail as often at 600MHz but that can change later this morning. Running at lower speeds may not be an option for me. My sonar project transmits a chirp output to a DAC then collects dual channel echo data. It uses the nanos() function for timing. If I have to live with the lower speed, 396MHz, then I'll have to run all the timing test again. Initial test shows that 600MHz is close to cutoff.
Frank B
05-28-2020, 02:47 PM
Tried to use a slow USB Hub(12MB/s) ?
Upgrading from Win7 might be an option, too.
Arctic_Eddie
05-28-2020, 04:21 PM
The Win7 box is about 15 yrs old and already sluggish. Going to Win10 is not an option at this point. It will eventually run as dual boot with Mint Mate or LMDE. I see the same problem on a new Win10 laptop but will duplicate the CPU speed test on it later today. We had a power outage earlier this morning so getting stuff back on line.
I have a V3.1 hub that was needed to get an SDR-Kits VNMA running correctly, same kind of USB problem. I'll try that on Win7 and see what happens.
Thanks for the hub suggestion. I had not thought of that.
WMXZ
05-28-2020, 07:46 PM
Try the suggestion posted on MTP-responder thread to improve USB communication, by changing the status function in usb.c
Arctic_Eddie
05-28-2020, 08:21 PM
I find numerous usb.c files but none contain the mentioned function, usb_transfer_status. Do you have a location for this file? What will happen if running a lower speed device with the file change still in effect?
Arctic_Eddie
05-28-2020, 08:45 PM
Tried a USB3.1 hub and a USB2 active extender. Neither solved the problem and now the board will not work correctly at 396MHz.
defragster
05-28-2020, 09:16 PM
Perhaps this noted here: MTP-Responder-for-SPIFFS (https://forum.pjrc.com/threads/61101-MTP-Responder-for-SPIFFS?p=241196&viewfull=1#post241196)
Found here with TD 1.52 there is a copy as : ...\hardware\teensy\avr\cores\teensy4\usb.c
In addition to use MTPspiffs above 450MHz it requires a change to the core file usb.c per @WMXZ:
modify usb.c:
function: usb_transfer_status
changed #if 0 to #if 1
Arctic_Eddie
05-28-2020, 10:42 PM
Found and fixed. It helps as I now get a run and print after upload. The first time the print is chopped off before the end but the reset button on the board gives a complete print. This problem is so irregular that I can't tell if it's really fixed, but definitely better.
Thanks all for the help.
analog&RFmodels
05-29-2020, 07:40 PM
the code below is a small excerpt from a program that compiled fine under 1.48 but not under 1.52
i am hoping i am doing something wrong and that it is not a problem with backward compat because
there is a lot of sweat in some T36 programs i have done
done with Ard 1.8.5, TD 1.48 and 1.52
i noticed that after installing 1.52 on top of 1.48 i had to delete a folder in snooze lib
to eliminate a compile error on a T4 program that used snooze which made me believe
that there should be a TD uninstall
notes in top of code describe lines that are choked on.
any help appreciated
// 1.52 chokes on the pinMode lines and if you
// comment them out
// then it chokes on all of the adc->set...
// lines
// this was fine under 1.48
#include <ADC.h>
unsigned short int i,j,n;
ADC *adc = new ADC(); // adc object;
int main() {
pinMode(readPin, INPUT);
pinMode(readPin2, INPUT);
pinMode(A10, INPUT); //Diff Channel 0 Positive
pinMode(A11, INPUT); //Diff Channel 0 Negative
loop:
adc->setAveraging(1);
adc->setResolution(12);
adc->setConversionSpeed(ADC_CONVERSION_SPEED::VERY_HIGH _SPEED);
adc->setSamplingSpeed(ADC_SAMPLING_SPEED::VERY_HIGH_SPE ED);
adc->setAveraging(1, ADC_1);
adc->setResolution(12, ADC_1);
adc->setConversionSpeed(ADC_CONVERSION_SPEED::VERY_HIGH _SPEED, ADC_1);
adc->setSamplingSpeed(ADC_SAMPLING_SPEED::VERY_HIGH_SPE ED, ADC_1);
goto loop;
defragster
05-29-2020, 08:17 PM
// comment them out
// lines
Is this trouble recompiling for same T_3.6?
ADC is included from outside github - there were changes made to support T_4.x ... Check that for - issues - this link ? github.com/pedvide/ADC (https://github.com/pedvide/ADC)
Have seen postings that somethings got altered but not followed ... may be a thread here with that discussion as well
Silverlock
05-29-2020, 08:18 PM
I tried compiling your program for both a T3.6 and a T4.0.
After declaring some values for readPin and readPin2, it sailed through both pinMode lines, and then errored out on setAveraging, setResolution, setConversionSpeed, et al., not being declared.
A quick look inside the ADC library verified that those functions did indeed not exist.
Looking through the history for ADC.h, the author of that library has done some reorganization in the past few months, and that library no longer looks like it did when you originally wrote your code.
The following modified snippet compiled w/o error for both T3.6 and T4.0 under Teensyduino 1.52. Whether or not it does what you want it to do is another question!
// comment them out
// lines
#include <ADC.h>
int readPin = A10;
int readPin2 = A11;
int main() {
loop:
adc->adc0->setAveraging(1);
adc->adc0->setResolution(12);
adc->adc0->setConversionSpeed(ADC_CONVERSION_SPEED::VERY_HIGH _SPEED);
adc->adc0->setSamplingSpeed(ADC_SAMPLING_SPEED::VERY_HIGH_SPE ED);
adc->adc1->setAveraging(1);
adc->adc1->setResolution(12);
adc->adc1->setConversionSpeed(ADC_CONVERSION_SPEED::VERY_HIGH _SPEED);
adc->adc1->setSamplingSpeed(ADC_SAMPLING_SPEED::VERY_HIGH_SPE ED);
goto loop;
Arctic_Eddie
05-29-2020, 08:30 PM
After a day of working with the "fix", I'm going back to the original version of usb.c. During the morning, the fix would give me some serial printout after an upload but generally not all of it. The reset button would work after that. As the day went by, it slowly reverted back to the original problem. I tried TyTools 0.9.0 and the upload fails but no reason given. Uninstalled TyTools and put usb.c back in it's original form. Ran some timing tests and I need at least 450MHz to make the sonar program work correctly. However, debug only works at 396MHz and below. Will just live with it until someone discovers the source of the problem and it's cure. It's very irregular and no fixed pattern.
analog&RFmodels
05-29-2020, 08:59 PM
Silverlock,
that did it - i had looked thru the documentation and lib files but overlooked that - amateur programmer who does
not know CPP - only C - so i think whenever i see -> or : or :: my brain goes into a very confused state.
thank you for taking the time to look at that.
defragster,
yes, that prob was with T36 and TD1.52 - Silverlock found my problem - backward compat is not 100% but is close
enuf that repair time will not be bad. i will yet test some TLC and T4 ADC code similarly with this fix.
analog&RFmodels
05-29-2020, 11:38 PM
the fixes for T36 to do ADC setup also worked for T4. almost work for TLC.
in the code below the disableDMA call was my feeble attemp at a fix - did not work. code below is an excerpt
from larger code that does fft w windowing ,sinc filtering,decimation,then fft. error message has to do with
DMA - looking in the header and cpp files in the lib and the html doc files there i cannot figure out who is
calling for enableDMA - it is not me - at least not directly. but the compiler chokes when somebody calls
enableDMA.
any help appreciated.
below is the code and the compile log w error shown.
this is the code
// TLC
#include <ADC.h>
const int readPin = A10; // ADC0
const int readPin2 = A11; // ADC1
float acc,acc2;
volatile int count,c2,md,dmy;
IntervalTimer it1;
short unsigned int value;
int led = 13;
#define pi 3.14159265
union u {
short unsigned int adin[1100];
float d2[256];
union u ary;
float d1[256];
float q,x,xa,y,nng,xp;
float t1,t2,s,c,a,m,fi,nnf,nnfr,jlf,jrf;
unsigned short int n1,n2,n3,n4,n5,n6,n7,n8,n9,nn,il,jl;
signed short int yi;
volatile unsigned short int flag,flagg;
void getad() {
cli();
value = adc->analogRead(readPin);
ary.adin[count] = value;
count = count + 1;
if(count > 1100) flagg = 1;
sei();
return;
int main() {
adc->adc0->disableDMA();
count = 0;
md = 0;
pinMode(LED_BUILTIN, OUTPUT);
mloop:
count = 0;
md = 0;
flagg = 0;
it1.begin (getad,25);
cloop:
if (flagg == 0) goto cloop;;
it1.end();
nn=256;
nnf=256.0;
nng=1024.0;
n5=1100;
fi=1.0;
if (flag == 0) {flag=1; digitalWrite(led, HIGH); goto mloop;}
if (flag == 1) {flag=0; digitalWrite(led, LOW); goto mloop;}
and this is the compile log
Arduino: 1.8.5 (Windows 7), TD: 1.52, Board: "Teensy LC, Serial, 48 MHz, Smallest Code, US English"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Dell\Documents\Arduino\libraries -fqbn=teensy:avr:teensyLC:usb=serial,speed=48,opt=o sstd,keys=en-us -ide-version=10805 -build-path C:\Users\Dell\AppData\Local\Temp\arduino_build_493 692 -warnings=none -build-cache C:\Users\Dell\AppData\Local\Temp\arduino_cache_283 853 -verbose C:\Users\Dell\Documents\Arduino\libraries\arf1\arf 1.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Dell\Documents\Arduino\libraries -fqbn=teensy:avr:teensyLC:usb=serial,speed=48,opt=o sstd,keys=en-us -ide-version=10805 -build-path C:\Users\Dell\AppData\Local\Temp\arduino_build_493 692 -warnings=none -build-cache C:\Users\Dell\AppData\Local\Temp\arduino_cache_283 853 -verbose C:\Users\Dell\Documents\Arduino\libraries\arf1\arf 1.ino
Using board 'teensyLC' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Using core 'teensy3' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10805 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Users\Dell\AppData\Local\Temp\arduino_build_493 692\sketch\arf1.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10805 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ADC" "C:\Users\Dell\AppData\Local\Temp\arduino_build_493 692\sketch\arf1.ino.cpp" -o "nul"
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ADC\AD C.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ADC\AD C_Module.cpp
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10805 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ADC" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ADC\An alogBufferDMA.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10805 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ADC" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ADC\Ri ngBuffer.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10805 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ADC" "C:\Users\Dell\AppData\Local\Temp\arduino_build_493 692\sketch\arf1.ino.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_493 692\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Dell\AppData\Local\Temp\arduino_build_493 692\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/precompile_helper" "C:\Program Files (x86)\Arduino\hardware\teensy\avr/cores/teensy3" "C:\Users\Dell\AppData\Local\Temp\arduino_build_493 692" "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10805 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr/cores/teensy3" "C:\Users\Dell\AppData\Local\Temp\arduino_build_493 692/pch/Arduino.h" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_493 692/pch/Arduino.h.gch"
Using previously compiled file: C:\Users\Dell\AppData\Local\Temp\arduino_build_493 692\pch\Arduino.h.gch
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10805 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_49 3692/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ADC" "C:\Users\Dell\AppData\Local\Temp\arduino_build_493 692\sketch\arf1.ino.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_493 692\sketch\arf1.ino.cpp.o"
Compiling libraries...
Compiling library "ADC"
Using previously compiled file: C:\Users\Dell\AppData\Local\Temp\arduino_build_493 692\libraries\ADC\ADC.cpp.o
Using previously compiled file: C:\Users\Dell\AppData\Local\Temp\arduino_build_493 692\libraries\ADC\ADC_Module.cpp.o
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10805 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_49 3692/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ADC" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ADC\An alogBufferDMA.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_493 692\libraries\ADC\AnalogBufferDMA.cpp.o"
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ADC\An alogBufferDMA.cpp: In member function 'void AnalogBufferDMA::init(ADC*, int8_t)':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ADC\An alogBufferDMA.cpp:163:8: error: 'class ADC' has no member named 'enableDMA'
adc->enableDMA(adc_num);
Using library ADC at version 8.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ADC
Error compiling for board Teensy LC.
KurtE
05-30-2020, 12:27 AM
Yes, it is another place where the code changed that no longer had those methods on the top level class, but instead had to call the modules...
Now I thought that @pedvide was going to add most/all of these back in for compatibility. So a couple of choices. Try to fix that line (and others like it in the AnalogBufferDMA.cpp file.
Check out to see if maybe he already has a fix in hit github for this. If not could raise an issue against his library.
Silverlock
05-30-2020, 12:41 AM
There have been some changes in the ADC library since the snapshot taken when 1.52 was put together. I noticed that at one stage the original methods were put in, but marked deprecated (so they'd work but give warnings), but the latest version has them marked with error pragmas so they error out and give the suggested replacements.
KurtE
05-30-2020, 01:12 AM
Personally I wish they were just left in... But as they say it is not my library.
Silverlock
05-30-2020, 01:27 AM
I'm in full agreement with that. And at one time, that was the way things were done; upgrades didn't break existing functionality. But, like it or not, things are viewed differently now by a lot of folk and throwing the baby out with the bathwater seems quite commonplace.
analog&RFmodels
05-30-2020, 01:30 AM
thanks for all of the feedback KurtE and Silverlock. looked at github - none of the files have changed for 2 months but i do
not know how that might relate to the freeze date for 1.52. not sure what "raise an issue against his library" means. as far
as fixing that line i guess i can try - nothing to loose. how would i private message the author to point him to this thread
- send a pm to pevide ? and last but not least does anyone have the previous set of files (adc.cpp etc) or the previous
zip from github ? if anyone has and there is a way to send to me i could try them and see if this goes away re first they
were depreciated and now they cause errors ? thanks
analog&RFmodels
05-30-2020, 08:17 AM
ADC problem TD 1.52 with TLC is resolved kind of, KurtE - i took your advice and tried to fix AnalogBufferDMA.cpp,
commented out line 163 which is in a TLC only if. just for completeness tested back again to T36 and T4 and all
is well. i don't know if the TLC even has DMA. if it does this "fix" might ruin your day in some high falootin kind of
ADC servicing but i always just ask for a reading when i want it - often inside of an interval timer call. if you were
trying to do any ADC at all i think that line would ruin your day anyway. below is a few lines out of the file showing
context. the problematic ...enableDMA... is commented out.
#else
// Kinetisl (TLC)
// setup a DMA Channel.
// Now lets see the different things that RingbufferDMA setup for us before
_dmachannel_adc.source((volatile uint16_t&)(SOURCE_ADC_0));;
_dmachannel_adc.destinationBuffer((uint16_t*)_buff er1, _buffer1_count * 2); // 2*b_size is necessary for some reason
_dmachannel_adc.disableOnCompletion(); // ISR will hae to restart with other buffer
_dmachannel_adc.interruptAtCompletion(); //interruptAtHalf or interruptAtCompletion
_activeObjectPerADC[0] = this;
_dmachannel_adc.attachInterrupt(&adc_0_dmaISR);
_dmachannel_adc.triggerAtHardwareEvent(DMAMUX_ADC_ 0); // start DMA channel when ADC finishes a conversion
_dmachannel_adc.enable();
adc->startContinuous(adc_num);
// adc->enableDMA(adc_num);
#ifdef DEBUG_DUMP_DATA
dumpDMA_TCD(&_dmachannel_adc);
Arctic_Eddie
05-30-2020, 03:46 PM
More info. The T4x has the same problem in Win10 directly or through a USB3.1 hub. However, dropping the serial baud from 115200 to 19200 seems to have fixed the problem. Also, setting CPU speed to the first two overclock values causes an ADC sync capture to take longer than normal. That may be caused by the nanos() function not running correctly as it uses F_CPU. As long as I stay at 600MHz and baud 19200, it works OK.
Frank B
05-30-2020, 03:49 PM
The USB Baudrate setting is a empty function. It just does nothing.F_CPU is the current speed.
You can expect issues from Overclocking.
That's why it is OVERclocking.
Arctic_Eddie
05-30-2020, 04:20 PM
Just found that out as there's not difference in output speed for settings from 1200 to 4M. If I set the rate in the device manager it keeps jumping back to 9600. Where is the rate set?
Frank B
05-30-2020, 07:23 PM
It is always the highest possible speed. Independent of any settings anywhere. They are all ignored. On any Teensy 3.x or 4.x.
Of course, the 4.x is much faster than the 3.x
That's why I suggestest a SLOW hub for your old laptop.
Arctic_Eddie
05-31-2020, 05:44 PM
The problem has been very irregular. Sometimes a change seems to work then several hours later, the problem returns. USB adapter speed does not seem to be the answer as it's the same on a Win7 desktop with USB2 ports and a Win10 laptop with both USB2 and USB3. Hubs and active extensions have no effect. Also, the same sonar sketch uploads, runs, and prints consistently on a T3.2 and T3.6. Those two boards have always worked correctly. The problem occurs on both T4.0 and T4.1 boards. One clue that shows up occasionally is an error message that "Windows reports the port is ready when it's not ready". The next time I see it I'll copy and paste the entire message on this thread.
defragster
06-05-2020, 09:41 PM
Just did fresh (re)install of T_1.52 and seeing this?
> I did have github bits - so I re0-installed - maybe a holdover file from a change???
INDEED: Wiped AVR\CORES folder and installed again and this went away
T:\arduino-1.8.12\hardware\teensy\avr\cores\teensy3\HardwareS erial.cpp:36:63: error: 'CNT_HARDWARE_SERIAL' was not declared in this scope
HardwareSerial *HardwareSerial::s_serials_with_serial_events[CNT_HARDWARE_SERIAL];
T:\arduino-1.8.12\hardware\teensy\avr\cores\teensy3\HardwareS erial.cpp:37:27: error: 'uint8_t HardwareSerial::s_count_serials_with_serial_events ' is not a static data member of 'class HardwareSerial'
uint8_t HardwareSerial::s_count_serials_with_serial_events = 0;
T:\arduino-1.8.12\hardware\teensy\avr\cores\teensy3\HardwareS erial.cpp:41:44: error: no 'void HardwareSerial::addToSerialEventsList()' member function declared in class 'HardwareSerial'
void HardwareSerial::addToSerialEventsList() {
Rezo
06-07-2020, 05:40 PM
I installed TD1.52 yesterday, running the latest OS on a MacBook Pro late 2016.
It seems to unexpectedly quit sometimes. Today it did so while scrolling through a 1k line sketch.
Here's the error log I got from Mac OS:
Process: Arduino [1541]
Path: /Applications/Teensyduino.app/Contents/MacOS/Arduino
Identifier: cc.arduino.Arduino.teensyduino
Version: 1.8.12 (1.8.12)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Arduino [1541]
User ID: 501
Date/Time: 2020-06-07 19:37:33.400 +0300
OS Version: Mac OS X 10.15.5 (19F101)
Report Version: 12
Anonymous UUID: 4D7CF90E-9098-A777-E78F-0269C16FD269
Sleep/Wake UUID: EC523694-5222-43EE-88E1-2D3243848E40
Time Awake Since Boot: 8900 seconds
Time Since Wake: 1000 seconds
System Integrity Protection: enabled
Crashed Thread: 18 Java: Java2D Queue Flusher
Exception Type: EXC_BAD_INSTRUCTION (SIGABRT)
Exception Codes: 0x0000000000000001, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
-[NSOpenGLContext setView:] must be called from the main thread.
Thread 0:: AppKit Thread Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff70778dfa mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff70779170 mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff3663cf85 __CFRunLoopServiceMachPort + 247
3 com.apple.CoreFoundation 0x00007fff3663ba52 __CFRunLoopRun + 1319
4 com.apple.CoreFoundation 0x00007fff3663aece CFRunLoopRunSpecific + 462
5 com.apple.HIToolbox 0x00007fff35269abd RunCurrentEventLoopInMode + 292
6 com.apple.HIToolbox 0x00007fff352697d5 ReceiveNextEventCommon + 584
7 com.apple.HIToolbox 0x00007fff35269579 _BlockUntilNextEventMatchingListInModeWithFilter + 64
8 com.apple.AppKit 0x00007fff338b1829 _DPSNextEvent + 883
9 com.apple.AppKit 0x00007fff338b0070 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:deque ue:] + 1352
10 libosxapp.dylib 0x000000011578fd2e -[NSApplicationAWT nextEventMatchingMask:untilDate:inMode:dequeue:] + 121
11 com.apple.AppKit 0x00007fff338a1d7e -[NSApplication run] + 658
12 libosxapp.dylib 0x000000011578fb73 +[NSApplicationAWT runAWTLoopWithApp:] + 219
13 libsplashscreen.dylib 0x000000011575cb16 __SplashInitPlatform_block_invoke + 70
14 JavaNativeFoundation 0x00007fff3af54ff9 +[JNFRunLoop _performCopiedBlock:] + 15
15 com.apple.Foundation 0x00007fff38d0e0dd __NSThreadPerformPerform + 204
16 com.apple.CoreFoundation 0x00007fff3663cde2 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FU NCTION__ + 17
17 com.apple.CoreFoundation 0x00007fff3663cd81 __CFRunLoopDoSource0 + 103
18 com.apple.CoreFoundation 0x00007fff3663cb9b __CFRunLoopDoSources0 + 209
19 com.apple.CoreFoundation 0x00007fff3663b8ca __CFRunLoopRun + 927
20 com.apple.CoreFoundation 0x00007fff3663aece CFRunLoopRunSpecific + 462
21 libjli.dylib 0x000000010139d621 CreateExecutionEnvironment + 875
22 libjli.dylib 0x0000000101399c1b JLI_Launch + 1878
23 cc.arduino.Arduino.teensyduino 0x0000000101379166 launch + 8838
24 cc.arduino.Arduino.teensyduino 0x0000000101376d9f main + 143
25 cc.arduino.Arduino.teensyduino 0x0000000101376d04 start + 52
Thread 1:
0 libsystem_kernel.dylib 0x00007fff7077a55e __ulock_wait + 10
1 libsystem_pthread.dylib 0x00007fff7083d5c2 _pthread_join + 347
2 libjli.dylib 0x000000010139dd61 ContinueInNewThread0 + 129
3 libjli.dylib 0x000000010139c453 ContinueInNewThread + 170
4 libjli.dylib 0x000000010139a881 JLI_Launch + 5052
5 cc.arduino.Arduino.teensyduino 0x0000000101379166 launch + 8838
6 cc.arduino.Arduino.teensyduino 0x0000000101376d9f main + 143
7 libjli.dylib 0x000000010139e3cc apple_main + 84
8 libsystem_pthread.dylib 0x00007fff7083c109 _pthread_start + 148
9 libsystem_pthread.dylib 0x00007fff70837b8b thread_start + 15
Thread 2:
0 libsystem_kernel.dylib 0x00007fff7077b882 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff7083c425 _pthread_cond_wait + 698
2 libjvm.dylib 0x0000000103e1c237 os::PlatformEvent::park() + 297
3 libjvm.dylib 0x0000000103dd76a2 ParkCommon(ParkEvent*, long) + 59
4 libjvm.dylib 0x0000000103dd7e43 Monitor::IWait(Thread*, long) + 219
5 libjvm.dylib 0x0000000103dd8d2c Monitor::wait(bool, long, bool) + 586
6 libjvm.dylib 0x0000000103f5cb36 Threads::destroy_vm() + 140
7 libjvm.dylib 0x0000000103bf5477 jni_DestroyJavaVM + 425
8 libjli.dylib 0x000000010139b2c4 JavaMain + 1746
9 libsystem_pthread.dylib 0x00007fff7083c109 _pthread_start + 148
10 libsystem_pthread.dylib 0x00007fff70837b8b thread_start + 15
Thread 3:
5 libjvm.dylib 0x0000000103dd8cb5 Monitor::wait(bool, long, bool) + 467
6 libjvm.dylib 0x0000000103ad0cec GCTaskManager::get_task(unsigned int) + 252
7 libjvm.dylib 0x0000000103ad245e GCTaskThread::run() + 462
8 libjvm.dylib 0x0000000103e16ee7 java_start(Thread*) + 250
Thread 4:
Thread 5:
Thread 6:
Thread 7:: Java: VM Thread
2 libjvm.dylib 0x0000000103e196b9 os::PlatformEvent::park(long) + 529
3 libjvm.dylib 0x0000000103dd7e43 Monitor::IWait(Thread*, long) + 219
4 libjvm.dylib 0x0000000103dd8cb5 Monitor::wait(bool, long, bool) + 467
5 libjvm.dylib 0x0000000103fdcec9 VMThread::loop() + 1169
6 libjvm.dylib 0x0000000103fdc8f6 VMThread::run() + 202
7 libjvm.dylib 0x0000000103e16ee7 java_start(Thread*) + 250
Thread 8:: Java: Reference Handler
3 libjvm.dylib 0x0000000103e095e7 ObjectMonitor::wait(long, bool, Thread*) + 1013
4 libjvm.dylib 0x0000000103f20bc8 ObjectSynchronizer::wait(Handle, long, Thread*) + 562
5 libjvm.dylib 0x0000000103c22715 JVM_MonitorWait + 519
6 ??? 0x0000000104fbd60f 0 + 4378580495
7 ??? 0x0000000106096ea4 0 + 4396248740
Thread 9:: Java: Finalizer
7 ??? 0x00000001053c23b8 0 + 4382794680
Thread 10:: Java: Signal Dispatcher
0 libsystem_kernel.dylib 0x00007fff70778e36 semaphore_wait_trap + 10
1 libjvm.dylib 0x0000000103e1858e check_pending_signals(bool) + 200
2 libjvm.dylib 0x0000000103e1241b signal_thread_entry(JavaThread*, Thread*) + 52
3 libjvm.dylib 0x0000000103f55963 JavaThread::thread_main_inner() + 373
4 libjvm.dylib 0x0000000103f556ff JavaThread::run() + 847
5 libjvm.dylib 0x0000000103e16ee7 java_start(Thread*) + 250
6 libsystem_pthread.dylib 0x00007fff7083c109 _pthread_start + 148
7 libsystem_pthread.dylib 0x00007fff70837b8b thread_start + 15
Thread 11:: Java: C2 CompilerThread0
0 libjvm.dylib 0x0000000103903433 Node::in(unsigned int) const + 87
1 libjvm.dylib 0x0000000103d2047e PhaseIdealLoop::idom_no_update(Node*) const + 134
2 libjvm.dylib 0x0000000103d21f94 PhaseIdealLoop::is_dominator(Node*, Node*) + 132
3 libjvm.dylib 0x0000000103d2d6ce PhaseIdealLoop::get_late_ctrl(Node*, Node*) + 790
4 libjvm.dylib 0x0000000103d2dc98 PhaseIdealLoop::build_loop_late_post(Node*) + 408
5 libjvm.dylib 0x0000000103d2ab74 PhaseIdealLoop::build_loop_late(VectorSet&, Node_List&, Node_Stack&) + 616
6 libjvm.dylib 0x0000000103d29ad9 PhaseIdealLoop::build_and_optimize(bool, bool) + 1479
7 libjvm.dylib 0x00000001039ab92c Compile::Optimize() + 3722
8 libjvm.dylib 0x00000001039a9b03 Compile::Compile(ciEnv*, C2Compiler*, ciMethod*, int, bool, bool, bool) + 2959
9 libjvm.dylib 0x00000001038fe629 C2Compiler::compile_method(ciEnv*, ciMethod*, int) + 199
10 libjvm.dylib 0x00000001039bb336 CompileBroker::invoke_compiler_on_method(CompileTa sk*) + 1720
11 libjvm.dylib 0x00000001039ba61e CompileBroker::compiler_thread_loop() + 834
12 libjvm.dylib 0x0000000103f55963 JavaThread::thread_main_inner() + 373
13 libjvm.dylib 0x0000000103f556ff JavaThread::run() + 847
14 libjvm.dylib 0x0000000103e16ee7 java_start(Thread*) + 250
15 libsystem_pthread.dylib 0x00007fff7083c109 _pthread_start + 148
16 libsystem_pthread.dylib 0x00007fff70837b8b thread_start + 15
Thread 12:: Java: C2 CompilerThread1
4 libjvm.dylib 0x0000000103dd8dd0 Monitor::wait(bool, long, bool) + 750
5 libjvm.dylib 0x00000001039b71d1 CompileQueue::get() + 131
6 libjvm.dylib 0x00000001039ba4cd CompileBroker::compiler_thread_loop() + 497
7 libjvm.dylib 0x0000000103f55963 JavaThread::thread_main_inner() + 373
8 libjvm.dylib 0x0000000103f556ff JavaThread::run() + 847
9 libjvm.dylib 0x0000000103e16ee7 java_start(Thread*) + 250
10 libsystem_pthread.dylib 0x00007fff7083c109 _pthread_start + 148
11 libsystem_pthread.dylib 0x00007fff70837b8b thread_start + 15
Thread 13:: Java: C1 CompilerThread2
0 libjvm.dylib 0x00000001038610fa IntervalArray::operator[](int) const + 70
1 libjvm.dylib 0x00000001038c6f21 LinearScan::is_sorted(IntervalArray*) + 161
2 libjvm.dylib 0x00000001038c7502 LinearScan::sort_intervals_after_allocation() + 548
3 libjvm.dylib 0x00000001038ccf02 LinearScan::do_linear_scan() + 308
4 libjvm.dylib 0x0000000103866d27 Compilation::emit_lir() + 171
5 libjvm.dylib 0x000000010386752b Compilation::compile_java_method() + 335
6 libjvm.dylib 0x0000000103867720 Compilation::compile_method() + 110
7 libjvm.dylib 0x0000000103867ab2 Compilation::Compilation(AbstractCompiler*, ciEnv*, ciMethod*, int, BufferBlob*) + 468
8 libjvm.dylib 0x0000000103868ef8 Compiler::compile_method(ciEnv*, ciMethod*, int) + 314
9 libjvm.dylib 0x00000001039bb336 CompileBroker::invoke_compiler_on_method(CompileTa sk*) + 1720
10 libjvm.dylib 0x00000001039ba61e CompileBroker::compiler_thread_loop() + 834
11 libjvm.dylib 0x0000000103f55963 JavaThread::thread_main_inner() + 373
12 libjvm.dylib 0x0000000103f556ff JavaThread::run() + 847
13 libjvm.dylib 0x0000000103e16ee7 java_start(Thread*) + 250
14 libsystem_pthread.dylib 0x00007fff7083c109 _pthread_start + 148
15 libsystem_pthread.dylib 0x00007fff70837b8b thread_start + 15
Thread 14:: Java: Service Thread
6 libjvm.dylib 0x0000000103eb5e1e ServiceThread::service_thread_entry(JavaThread*, Thread*) + 258
Thread 15:: Java: VM Periodic Task Thread
3 libjvm.dylib 0x0000000103e193a6 os::sleep(Thread*, long, bool) + 686
4 libjvm.dylib 0x0000000103f545c6 WatcherThread::run() + 524
Thread 16:: com.apple.NSEventThread
5 com.apple.AppKit 0x00007fff33a53144 _NSEventThread + 132
Thread 17:: Java: process reaper
0 libsystem_kernel.dylib 0x00007fff7077e482 __wait4 + 10
1 libjava.dylib 0x0000000102fd9044 Java_java_lang_UNIXProcess_waitForProcessExit + 29
2 ??? 0x0000000104b4ffad 0 + 4373938093
3 ??? 0x0000000104b27d00 0 + 4373773568
4 ??? 0x0000000104b282bd 0 + 4373775037
5 ??? 0x0000000104b28302 0 + 4373775106
6 ??? 0x0000000104b282bd 0 + 4373775037
7 ??? 0x0000000104b28302 0 + 4373775106
8 ??? 0x0000000104b20671 0 + 4373743217
9 libjvm.dylib 0x0000000103ba6127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
10 libjvm.dylib 0x0000000103ba4966 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 626
11 libjvm.dylib 0x0000000103ba4bb3 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 111
12 libjvm.dylib 0x0000000103c3e739 thread_entry(JavaThread*, Thread*) + 177
13 libjvm.dylib 0x0000000103f55963 JavaThread::thread_main_inner() + 373
14 libjvm.dylib 0x0000000103f556ff JavaThread::run() + 847
15 libjvm.dylib 0x0000000103e16ee7 java_start(Thread*) + 250
16 libsystem_pthread.dylib 0x00007fff7083c109 _pthread_start + 148
17 libsystem_pthread.dylib 0x00007fff70837b8b thread_start + 15
Thread 18 Crashed:: Java: Java2D Queue Flusher
0 libsystem_kernel.dylib 0x00007fff7077f33a __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fff7083be60 pthread_kill + 430
2 libsystem_c.dylib 0x00007fff70706808 abort + 120
3 libjvm.dylib 0x0000000103ffa8ca os::abort(bool) (.cold.1) + 125
4 libjvm.dylib 0x0000000103e1755b os::abort(bool) + 33
5 libjvm.dylib 0x0000000103fb08a6 VMError::report_and_die() + 2298
6 libjvm.dylib 0x0000000103a0c2d3 report_vm_error(char const*, int, char const*, char const*) + 93
7 libjvm.dylib 0x0000000103e1cfa8 os::get_sender_for_C_frame(frame*) + 76
8 libjvm.dylib 0x0000000103a0d524 print_native_stack(outputStream*, frame, Thread*, char*, int) + 336
9 libjvm.dylib 0x0000000103faf703 VMError::report(outputStream*) + 2617
10 libjvm.dylib 0x0000000103fb0387 VMError::report_and_die() + 987
11 libjvm.dylib 0x0000000103e1d3b7 JVM_handle_bsd_signal + 802
12 libjvm.dylib 0x0000000103e19f0f signalHandler(int, __siginfo*, void*) + 88
13 libsystem_platform.dylib 0x00007fff708305fd _sigtramp + 29
14 libobjc.A.dylib 0x00007fff6f484954 lookUpImpOrForward + 63
15 libawt_lwawt.dylib 0x00000001176b8239 CGLSD_MakeCurrentToScratch + 93
16 libawt_lwawt.dylib 0x00000001176b8390 OGLSD_MakeOGLContextCurrent + 166
17 libawt_lwawt.dylib 0x00000001176d5e32 OGLContext_SetSurfaces + 188
18 libawt_lwawt.dylib 0x00000001176da69f Java_sun_java2d_opengl_OGLRenderQueue_flushBuffer + 1775
19 ??? 0x0000000105784d51 0 + 4386737489
20 ??? 0x00000001059dcd40 0 + 4389195072
Thread 19:: Java: Java2D Disposer
7 ??? 0x0000000105f8b8a8 0 + 4395153576
Thread 20:: Java: Thread-5
0 libsystem_kernel.dylib 0x00007fff7077981e read + 10
1 libjava.dylib 0x0000000102fdc76c handleRead + 34
2 libjava.dylib 0x0000000102fdbfc3 readBytes + 351
3 ??? 0x0000000105117ee9 0 + 4379999977
4 ??? 0x000000010510b4fc 0 + 4379948284
Thread 21:: Java: cc.arduino.packages.discoverers.serial.SerialDisco very
3 libjvm.dylib 0x0000000103e09587 ObjectMonitor::wait(long, bool, Thread*) + 917
7 ??? 0x0000000104b282bd 0 + 4373775037
8 ??? 0x0000000104b282bd 0 + 4373775037
9 ??? 0x0000000104b20671 0 + 4373743217
10 libjvm.dylib 0x0000000103ba6127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
11 libjvm.dylib 0x0000000103ba4966 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 626
12 libjvm.dylib 0x0000000103ba4bb3 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 111
13 libjvm.dylib 0x0000000103c3e739 thread_entry(JavaThread*, Thread*) + 177
14 libjvm.dylib 0x0000000103f55963 JavaThread::thread_main_inner() + 373
15 libjvm.dylib 0x0000000103f556ff JavaThread::run() + 847
16 libjvm.dylib 0x0000000103e16ee7 java_start(Thread*) + 250
17 libsystem_pthread.dylib 0x00007fff7083c109 _pthread_start + 148
18 libsystem_pthread.dylib 0x00007fff70837b8b thread_start + 15
Thread 22:: Java: Multihomed mDNS.Timer
Thread 23:: Java: Batik CleanerThread
6 ??? 0x0000000104b4ffad 0 + 4373938093
7 ??? 0x0000000104f7dee4 0 + 4378320612
Thread 24:: Java: AWT-Shutdown
7 ??? 0x00000001051a3654 0 + 4380571220
8 ??? 0x0000000104b28302 0 + 4373775106
Thread 25:: Java: MarlinRenderer Disposer
Thread 26:: Java: AWT-EventQueue-0
2 libjvm.dylib 0x0000000103e1c861 Parker::park(bool, long) + 1239
3 libjvm.dylib 0x0000000103f8b61b Unsafe_Park + 430
4 ??? 0x000000010593d7d1 0 + 4388542417
5 ??? 0x000000010633db5c 0 + 4399029084
Thread 27:: Java: TimerQueue
2 libjvm.dylib 0x0000000103e1c82c Parker::park(bool, long) + 1186
5 ??? 0x0000000106126394 0 + 4396835732
Thread 28:: Java: JmDNS(davids-mbp-3-018-co-il.local.).Timer
Thread 29:: Java: JmDNS(davids-mbp-3-018-co-il.local.).State.Timer
Thread 30:: Java: JmDNS(davids-mbp-3-018-co-il.local.).Timer
Thread 31:: Java: JmDNS(davids-mbp-3-018-co-il.local.).State.Timer
Thread 32:: Java: JmDNS(davids-mbp-3-018-co-il.local.).Timer
Thread 33:: Java: JmDNS(davids-mbp-3-018-co-il.local.).State.Timer
Thread 34:: Java: SocketListener(davids-mbp-3-018-co-il.local.)
0 libsystem_kernel.dylib 0x00007fff7077c3a6 __recvfrom + 10
1 libnet.dylib 0x0000000115711167 NET_RecvFrom + 135
2 libnet.dylib 0x000000011570d457 Java_java_net_PlainDatagramSocketImpl_receive0 + 449
3 ??? 0x0000000105779311 0 + 4386689809
4 ??? 0x0000000106003d44 0 + 4395646276
5 ??? 0x0000000104b20671 0 + 4373743217
6 libjvm.dylib 0x0000000103ba6127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
7 libjvm.dylib 0x0000000103ba4966 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 626
8 libjvm.dylib 0x0000000103ba4bb3 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 111
9 libjvm.dylib 0x0000000103c3e739 thread_entry(JavaThread*, Thread*) + 177
10 libjvm.dylib 0x0000000103f55963 JavaThread::thread_main_inner() + 373
11 libjvm.dylib 0x0000000103f556ff JavaThread::run() + 847
12 libjvm.dylib 0x0000000103e16ee7 java_start(Thread*) + 250
13 libsystem_pthread.dylib 0x00007fff7083c109 _pthread_start + 148
14 libsystem_pthread.dylib 0x00007fff70837b8b thread_start + 15
Thread 35:: Java: JmDNS(davids-mbp-3-018-co-il.local.).Timer
Thread 36:: Java: JmDNS(davids-mbp-3-018-co-il.local.).State.Timer
Thread 37:: Java: SocketListener(davids-macbook-pro-3.local.)
Thread 38:: Java: JmDNS(davids-macbook-pro-3.local.).Timer
Thread 39:: Java: JmDNS(davids-macbook-pro-3.local.).State.Timer
Thread 40:
0 libsystem_pthread.dylib 0x00007fff70837b68 start_wqthread + 0
Thread 41:
Thread 42:
Thread 43:
Thread 18 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x00007000077c0000 rcx: 0x00007000077be5f8 rdx: 0x0000000000000000
rdi: 0x0000000000012907 rsi: 0x0000000000000006 rbp: 0x00007000077be620 rsp: 0x00007000077be5f8
r8: 0x0000000000000010 r9: 0x00007000077be630 r10: 0x00007000077c0000 r11: 0x0000000000000246
r12: 0x0000000000012907 r13: 0x00007000077be7a0 r14: 0x0000000000000006 r15: 0x0000000000000016
rip: 0x00007fff7077f33a rfl: 0x0000000000000246 cr2: 0x0000000103ff9644
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
Binary Images:
0x101376000 - 0x10137afff +cc.arduino.Arduino.teensyduino (1.8.12 - 1.8.12) <2AE2040B-3408-3208-B101-5825B8F425F0> /Applications/Teensyduino.app/Contents/MacOS/Arduino
0x101398000 - 0x1013a1fff +libjli.dylib (0) <212562B4-111E-35D6-BB2B-A1BFD63A5B64> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/jli/libjli.dylib
0x102fbd000 - 0x102fc5fff +libverify.dylib (0) <B8F4EBC4-811F-33AD-BB9A-2C4B148C8C6D> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libverify.dylib
0x102fd0000 - 0x102feefff +libjava.dylib (0) <32138414-C5B3-3330-8911-97D6CD983944> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libjava.dylib
0x10301e000 - 0x103022fff +libzip.dylib (0) <346621C0-4ADF-3E59-A9AA-76CC581A12F0> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libzip.dylib
0x1035f5000 - 0x103686eff dyld (750.5) <E4698FBD-806A-3396-B279-E685BA37430B> /usr/lib/dyld
0x1036fa000 - 0x104193fff +libjvm.dylib (0) <31202E71-A956-3765-B4D6-876A7D4FFBD9> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/server/libjvm.dylib
0x1156ef000 - 0x1156f5fff +libnio.dylib (0) <1FB68BF9-1173-3A83-A617-15DA017AD812> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libnio.dylib
0x115707000 - 0x115714fff +libnet.dylib (0) <B9072F4C-3145-3661-9DBE-8AECB4DF85DB> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libnet.dylib
0x115727000 - 0x115763ff3 +libsplashscreen.dylib (0) <F8DFB9AF-1758-3CB3-8ECF-A40AF50AEFE2> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libsplashscreen.dylib
0x11578d000 - 0x115792fff +libosxapp.dylib (0) <44AA406A-BF46-3779-8247-5363068551AC> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libosxapp.dylib
0x115fc6000 - 0x115fc7fe7 +libjSSC-2.8_x86_64.jnilib (0) <42816ADC-83A4-F3FF-6E2F-422A583B0174> /Users/USER/*/libjSSC-2.8_x86_64.jnilib
0x116f9f000 - 0x116ff9ff3 +libawt.dylib (0) <F9DD7DEF-AB6A-3718-9314-73F7B227B709> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libawt.dylib
0x11708c000 - 0x117136ff7 +libmlib_image.dylib (0) <9474B2D4-5C83-3AED-A17D-155AC6A1292F> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libmlib_image.dylib
0x11769e000 - 0x1176fdff3 +libawt_lwawt.dylib (0) <4D83B9A4-989F-3D85-BA5E-F0208BEB2F86> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libawt_lwawt.dylib
0x117ff7000 - 0x117ffa047 libobjc-trampolines.dylib (787.1) <8212B354-A106-3806-A022-A60F2B2FA5C9> /usr/lib/libobjc-trampolines.dylib
0x1180ee000 - 0x1180ffff7 +liblistSerialsj.dylib (0) <9652E9D9-1D2A-37ED-982B-F222108D70FF> /Applications/Teensyduino.app/Contents/Java/lib/liblistSerialsj.dylib
0x118108000 - 0x118140ff3 +libfontmanager.dylib (0) <DF7F570B-A725-35D6-AD41-D00755395693> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libfontmanager.dylib
0x118189000 - 0x118222ff7 +libfreetype.dylib.6 (0) <D7022DC9-4783-3993-97D4-A548688EF098> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libfreetype.dylib.6
0x11825c000 - 0x118262fff +libosx.dylib (0) <65FD3A00-CBF7-3B4C-95AA-041E9A8A0907> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libosx.dylib
0x14874d000 - 0x148750ffb +libmanagement.dylib (0) <8413F67C-85D3-3B3C-9FC2-75A0B470A96C> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libmanagement.dylib
0x148eaf000 - 0x148eb3fff +libosxui.dylib (0) <298413FC-09E2-3331-8821-E08823132ED9> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libosxui.dylib
0x1493f7000 - 0x149432fff +libastylej.dylib (0) <906AC4F1-6792-3FBA-A552-EF8D40DBEA1B> /Applications/Teensyduino.app/Contents/Java/lib/libastylej.dylib
0x14a281000 - 0x14a28fff7 +libJTouchBar.dylib5545651800035006961 (0) <E9801EEC-0090-3848-8C4B-8335665DFE26> /var/folders/*/libJTouchBar.dylib5545651800035006961
0x7fff296ab000 - 0x7fff298f8ff8 com.apple.RawCamera.bundle (9.02.0 - 1350.29) <0CC24FF1-0754-3A75-BA2D-212CF70ADDC1> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff2f3bd000 - 0x7fff303c5ff7 com.apple.driver.AppleIntelSKLGraphicsGLDriver (14.6.18 - 14.0.6) <99F84715-F7B1-39DF-85E9-B3CEE6ACBD10> /System/Library/Extensions/AppleIntelSKLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelSKLGraphicsGLDriver
0x7fff303c6000 - 0x7fff307c5ff3 com.apple.driver.AppleIntelSKLGraphicsMTLDriver (14.6.18 - 14.0.6) <9737C6FD-3998-3354-A4F6-FBF8E37792DB> /System/Library/Extensions/AppleIntelSKLGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelSKLGraphicsMTLDriver
0x7fff32244000 - 0x7fff32244fff com.apple.Accelerate (1.11 - Accelerate 1.11) <56DFF715-6A4E-3231-BDCC-A348BCB05047> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff32245000 - 0x7fff3225bfef libCGInterfaces.dylib (524.2.1) <A423F932-C044-3CEB-BF20-BF4CB323361E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff3225c000 - 0x7fff328b2fff com.apple.vImage (8.1 - 524.2.1) <17C93AB9-1625-3FDB-9851-C5E77BBE3428> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff328b3000 - 0x7fff32b1aff7 libBLAS.dylib (1303.60.1) <CBC28BE4-3C78-3AED-9565-0D625251D121> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff32b1b000 - 0x7fff32feefef libBNNS.dylib (144.100.2) <8D653678-1F9B-3670-AAE2-46DFB8D37643> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff32fef000 - 0x7fff3338afff libLAPACK.dylib (1303.60.1) <F8E9D081-7C60-32EC-A47D-2D30CAD73C5F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff3338b000 - 0x7fff333a0fec libLinearAlgebra.dylib (1303.60.1) <D2C1ACEA-2B6A-339A-9EEB-62A76CC92CBE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff333a1000 - 0x7fff333a6ff3 libQuadrature.dylib (7) <3112C977-8306-3190-8313-01A952B7F3CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff333a7000 - 0x7fff33417fff libSparse.dylib (103) <40510BF9-99A7-3155-A81D-6DE5A0C73EDC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff33418000 - 0x7fff3342afef libSparseBLAS.dylib (1303.60.1) <3C1066AB-20D5-38D2-B1F2-70A03DE76D0B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff3342b000 - 0x7fff33602fd7 libvDSP.dylib (735.121.1) <74702E2E-ED05-3765-B18C-64BEFF62B517> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff33603000 - 0x7fff336c5fef libvMisc.dylib (735.121.1) <137558BF-503D-3A6E-96DC-A181E3FB31FF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff336c6000 - 0x7fff336c6fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <D7E8E400-35C8-3174-9956-8D1B483620DA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff336c7000 - 0x7fff33726ff0 com.apple.Accounts (113 - 113) <0510C893-F1F2-38B2-B3AA-A30DB2F5B688> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff33870000 - 0x7fff34630ffd com.apple.AppKit (6.9 - 1894.50.103) <61269B8C-C432-335F-8894-B95C235A41A5> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff34680000 - 0x7fff34680fff com.apple.ApplicationServices (48 - 50) <EEC73694-1A37-3C14-A839-6991E2BD8655> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff34681000 - 0x7fff346ecfff com.apple.ApplicationServices.ATS (377 - 493.0.4.1) <A6912C4A-55CC-3701-BACA-E63423B99481> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff34785000 - 0x7fff347c3ff0 libFontRegistry.dylib (274.0.5.1) <A78A7869-C96C-3AD6-A038-DE541639BB60> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff3481e000 - 0x7fff3484dfff com.apple.ATSUI (1.0 - 1) <4B3C2201-DBB3-352C-936B-9C423122EFF6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
0x7fff3484e000 - 0x7fff34852ffb com.apple.ColorSyncLegacy (4.13.0 - 1) <47D42CDE-2E9A-3AF6-9365-1BFD1189196B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff348ec000 - 0x7fff34943ffa com.apple.HIServices (1.22 - 675.1) <273492E3-FF0F-3A8A-A83F-0F11F99B5F26> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff34944000 - 0x7fff34952fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <DA175323-5BE3-3C54-92D4-A171A4A067E6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff34953000 - 0x7fff34998ffa com.apple.print.framework.PrintCore (15.4 - 516.2) <99AEBCDB-2DCA-3A13-906F-7F0D7962B002> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff34999000 - 0x7fff349a3ff7 com.apple.QD (4.0 - 413) <D2E1DC80-D26F-3508-BBA5-B8AE7ED6CB0E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff349a4000 - 0x7fff349b1ffc com.apple.speech.synthesis.framework (9.0.24 - 9.0.24) <823C0DE7-1351-3B39-8F06-AB5FCAD2C874> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff349b2000 - 0x7fff34a93ffa com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <75651F0A-F2CE-3F68-B86A-E66B8815DCF4> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff34a95000 - 0x7fff34a95fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <E51DCB3C-CF4F-320B-AC86-D445E30C0891> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff34e2b000 - 0x7fff351b9ffd com.apple.CFNetwork (1126 - 1126) <BB8F4C63-10B8-3ACD-84CF-D4DCFA9245DD> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff35235000 - 0x7fff35235fff com.apple.Carbon (160 - 162) <4F1F60CB-6C1E-3D79-832E-8D606601F282> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff35236000 - 0x7fff35239ff3 com.apple.CommonPanels (1.2.6 - 101) <333BBF55-AF23-3B99-A9FF-7906175B9406> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff3523a000 - 0x7fff3552eff3 com.apple.HIToolbox (2.1.1 - 994.6) <5C44ACA7-D158-3F9B-8F88-0477510D44FA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff3552f000 - 0x7fff35532ff3 com.apple.help (1.3.8 - 71) <4B2701A0-8813-35F8-82F8-676B184D15C4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff35533000 - 0x7fff35538ff7 com.apple.ImageCapture (9.0 - 1600.60.4.2) <20872A2D-CBF9-38E6-BD16-C1D387120651> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff35539000 - 0x7fff35539fff com.apple.ink.framework (10.15 - 227) <5B60FDDE-D60E-326B-BD3D-6EA5FA1CBB76> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff3553a000 - 0x7fff35554ffa com.apple.openscripting (1.7 - 185.1) <E59F893B-1A73-3098-8924-79227EC9787E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff35575000 - 0x7fff35575fff com.apple.print.framework.Print (15 - 271) <07C50BF6-2222-3769-A5B8-79D7F996183F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff35576000 - 0x7fff35578ff7 com.apple.securityhi (9.0 - 55008) <D7017D5A-4206-3E2F-9F8E-0F932422CA87> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff35579000 - 0x7fff3557ffff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <1188E643-967C-334E-BC1A-60A0F82C67E5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff35719000 - 0x7fff35719fff com.apple.Cocoa (6.11 - 23) <87426C3A-7C6C-39D0-905C-C591B997029E> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff35727000 - 0x7fff3581dfff com.apple.ColorSync (4.13.0 - 3394.9) <61698A7B-BB8C-3891-9547-703FF84671A8> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff35b08000 - 0x7fff36011ffb com.apple.audio.CoreAudio (5.0 - 5.0) <62BEE4B7-8A26-3951-9D78-4E193617AF7A> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff36064000 - 0x7fff3609cfff com.apple.CoreBluetooth (1.0 - 1) <6BC7F863-4495-371F-BC54-543E5CFE1665> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff3609d000 - 0x7fff36487fe8 com.apple.CoreData (120 - 977.3) <D902A2E3-1D0A-3995-974E-A526976E5735> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff36488000 - 0x7fff365b8ffe com.apple.CoreDisplay (1.0 - 186.6.12) <EA74CC46-8715-3B90-95E8-4594D2F0CC8A> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff365b9000 - 0x7fff36a38ffb com.apple.CoreFoundation (6.9 - 1676.105) <6AF8B3CC-BC3F-3869-B9FB-1D881422364E> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff36a3a000 - 0x7fff370aeff8 com.apple.CoreGraphics (2.0 - 1355.17) <E1CE3919-F36B-309F-89BA-79F36DC8125E> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff370bc000 - 0x7fff37417ff0 com.apple.CoreImage (15.0.0 - 940.9) <44F68E8C-315A-32A6-BB19-7F24C00AB347> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff377d8000 - 0x7fff378b3ffc com.apple.CoreMedia (1.0 - 2620.11.40.2) <0F490101-ED30-3189-B099-E247B6361A0B> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff379a0000 - 0x7fff379a0fff com.apple.CoreServices (1069.24 - 1069.24) <D9F6AB40-10EC-3682-A969-85560E2E4768> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff379a1000 - 0x7fff37a26fff com.apple.AE (838.1 - 838.1) <5F26DA9B-FB2E-3AF8-964B-63BD6671CF12> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff37a27000 - 0x7fff37d08ff7 com.apple.CoreServices.CarbonCore (1217 - 1217) <8022AF47-AA99-3786-B086-141D84F00387> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff37d09000 - 0x7fff37d56ffd com.apple.DictionaryServices (1.2 - 323.6) <C0F3830C-A4C6-3046-9A6A-DE1B5D448C2C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff37d57000 - 0x7fff37d5fff7 com.apple.CoreServices.FSEvents (1268.100.1 - 1268.100.1) <E4B2CAF2-1203-335F-9971-1278CB6E2AE0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff37d60000 - 0x7fff37f9aff6 com.apple.LaunchServices (1069.24 - 1069.24) <2E0AD228-B1CC-3645-91EE-EB7F46F2147B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff37f9b000 - 0x7fff38033ff1 com.apple.Metadata (10.7.0 - 2076.6) <C8034E84-7DD4-34B9-9CDF-16A05032FF39> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff38034000 - 0x7fff38061fff com.apple.CoreServices.OSServices (1069.24 - 1069.24) <72FDEA52-7607-3745-AC43-630D80962099> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff38062000 - 0x7fff380c9fff com.apple.SearchKit (1.4.1 - 1.4.1) <086EB5DF-A2EC-3342-8028-CA7996BE5CB2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff380ca000 - 0x7fff380eeff5 com.apple.coreservices.SharedFileList (131.4 - 131.4) <AE333DA2-C279-3751-8C15-B963E58EE61E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff38413000 - 0x7fff385caffc com.apple.CoreText (643.1.5.1 - 643.1.5.1) <715FE3F7-E8FB-3997-85A0-3AB2839F6C30> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff385cb000 - 0x7fff3860fffb com.apple.CoreVideo (1.8 - 344.3) <A200AFC7-2CB2-30CD-8B2A-1269CA64A29B> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff38610000 - 0x7fff3869dffc com.apple.framework.CoreWLAN (13.0 - 1601.2) <855E51AA-DF3A-3BB9-A4F0-6880D42B8762> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff38859000 - 0x7fff38864ff7 com.apple.DirectoryService.Framework (10.15 - 220.40.1) <06D98FD0-796F-356F-B492-A6D8F3D5BEC0> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff38865000 - 0x7fff3890fff0 com.apple.DiscRecording (9.0.3 - 9030.4.5) <D9033DDA-E4C8-36FB-AE60-4EF66F4F1F9E> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff38934000 - 0x7fff3893afff com.apple.DiskArbitration (2.7 - 2.7) <52E7D181-2A18-37CD-B24F-AA32E93F7A69> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff38b0e000 - 0x7fff38b10ff2 com.apple.ExceptionHandling (1.5 - 13) <62FDDF8D-2DD1-3812-A28F-80A273F6C0F6> /System/Library/Frameworks/ExceptionHandling.framework/Versions/A/ExceptionHandling
0x7fff38b2d000 - 0x7fff38c5bff6 com.apple.FileProvider (304.1 - 304.1) <58D64236-947E-3E6A-85E6-C66AEF9E0EE0> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
0x7fff38c73000 - 0x7fff39038fff com.apple.Foundation (6.9 - 1676.105) <1FA28BAB-7296-3A09-8E1E-E62A7D233DB8> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff390a5000 - 0x7fff390f5ff7 com.apple.GSS (4.0 - 2.0) <4E241C00-42A5-3572-9430-D950FBB7A4A0> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff39232000 - 0x7fff39346ff3 com.apple.Bluetooth (7.0.5 - 7.0.5f6) <5897C368-9674-3E34-B144-FFB06A2DF37B> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff393ac000 - 0x7fff39450ff3 com.apple.framework.IOKit (2.0.2 - 1726.121.1) <A0F54725-036F-3279-A46E-C2ABDBFD479B> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff39452000 - 0x7fff39463ffb com.apple.IOSurface (269.11 - 269.11) <D3CC2AA1-4AE2-30EE-A9DB-C04CCAA88ADE> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff394e2000 - 0x7fff3963effe com.apple.ImageIO.framework (3.3.0 - 1976.6) <5B4C2E04-9161-3C82-A7FB-F4D51E3C1E10> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff3963f000 - 0x7fff39642fff libGIF.dylib (1976.6) <3B26EE1C-C570-305C-A9A3-EA62D2F2E7B8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff39643000 - 0x7fff396fcfff libJP2.dylib (1976.6) <EB4E4E09-DD81-3E6B-A513-3667E810AEF3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff396fd000 - 0x7fff39720fe3 libJPEG.dylib (1976.6) <9D7FAC55-85A6-34AB-9F26-0BCA381E8CE7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff3999c000 - 0x7fff399b6fef libPng.dylib (1976.6) <4886A1F8-E9CA-38F2-BF2F-1FCA1DFDD1C9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff399b7000 - 0x7fff399b8fff libRadiance.dylib (1976.6) <FA759D33-131A-33B8-943E-32409F162738> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff399b9000 - 0x7fff39a02fff libTIFF.dylib (1976.6) <E9994BF8-6CF5-3422-B4FD-A14DC390EF12> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff3af4e000 - 0x7fff3af56ffc JavaNativeFoundation (75) <8BCA18FD-514F-3B7D-9C7A-2988B38F3E7B> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.framework/Versions/A/JavaNativeFoundation
0x7fff3af57000 - 0x7fff3af5effa com.apple.java.JavaRuntimeSupport (15.0.1 - 15.0.1) <73034041-5247-34ED-96C2-97C5AD2C554E> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaRuntimeSupport.framework/Versions/A/JavaRuntimeSupport
0x7fff3af5f000 - 0x7fff3af63ffd com.apple.JavaVM (15.0.3 - 15.0.3) <8D6E6E58-21A6-325B-97C0-0CB065C6AEC5> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
0x7fff3af64000 - 0x7fff3af76ff3 com.apple.Kerberos (3.0 - 1) <AE0E56CA-D924-3CC8-BBAA-8C6EEC3038BE> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff3af77000 - 0x7fff3af77fff libHeimdalProxy.dylib (77) <A970C7A8-7CCD-3701-A459-078BD5E8FE4E> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
0x7fff3af78000 - 0x7fff3afaeff7 com.apple.LDAPFramework (2.4.28 - 194.5) <4CFB6351-53B9-36AF-B654-AE636BBC361A> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff3b309000 - 0x7fff3b313ffb com.apple.MediaAccessibility (1.0 - 125.1) <DBF40A12-65A6-33E4-839C-292600B7D910> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff3b3df000 - 0x7fff3bb2cff5 com.apple.MediaToolbox (1.0 - 2620.11.40.2) <40F16AF6-79D1-3C2E-976C-E7E7870A4EF9> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff3bb2e000 - 0x7fff3bbf8ff7 com.apple.Metal (212.7 - 212.7) <CC7BF715-142B-3C2A-81AD-0E35693230F2> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff3bc15000 - 0x7fff3bc52ff7 com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <52089325-EC97-3EED-ABB3-9B39EC0BD429> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff3bc53000 - 0x7fff3bcddfe2 com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <9E434EA0-6BCA-3903-B882-CEB69730A63B> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff3bcde000 - 0x7fff3bd03ff4 com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <EDD6C3A5-E231-3FB1-B4D4-45742AFB9A4E> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff3bd04000 - 0x7fff3bd19ffb com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <C5A2B865-5CE2-3E5D-8452-54639FCB0954> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
0x7fff3bd1a000 - 0x7fff3be78ffc com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <47CCDBAC-5843-366A-A68C-6E8851D0865D> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff3be79000 - 0x7fff3bec8ff4 com.apple.MetalPerformanceShaders.MPSRayIntersecto r (1.0 - 1) <302BDF8E-B00A-3123-A6C4-E262B7513CF6> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff3bec9000 - 0x7fff3becaff5 com.apple.MetalPerformanceShaders.MetalPerformance Shaders (1.0 - 1) <14F84B42-9DA2-39A1-81B4-666B8020520C> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff3cf51000 - 0x7fff3cf5dffe com.apple.NetFS (6.0 - 4.0) <AC74E6A4-6E9B-3AB1-9577-8277F8A3EDE0> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff3cf5e000 - 0x7fff3d0b5ff3 com.apple.Network (1.0 - 1) <B5B8E999-BBCC-3DEF-8881-8FFF69F8EC4B> /System/Library/Frameworks/Network.framework/Versions/A/Network
0x7fff3fadd000 - 0x7fff3fae5ff7 libcldcpuengine.dylib (2.14) <D8583B54-FE2A-33FD-A702-ABF307D99FD1> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff3fae6000 - 0x7fff3fb3efff com.apple.opencl (3.5 - 3.5) <9B101D40-EA79-3C0D-B7AE-A3F18094B2D7> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff3fb3f000 - 0x7fff3fb5bfff com.apple.CFOpenDirectory (10.15 - 220.40.1) <BFC32EBE-D95C-3267-B95C-5CEEFD189EA6> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff3fb5c000 - 0x7fff3fb67ffd com.apple.OpenDirectory (10.15 - 220.40.1) <76A20BBA-775F-3E17-AB0F-FEDFCDCE0716> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff404cd000 - 0x7fff404cffff libCVMSPluginSupport.dylib (17.10.22) <AAE07E0C-4B28-364B-A7D9-028C7CD14954> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff404d0000 - 0x7fff404d5fff libCoreFSCache.dylib (176.15) <609C5DFC-9A97-344D-BBC7-E0B08D862C63> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff404d6000 - 0x7fff404dafff libCoreVMClient.dylib (176.15) <8F8DD27F-AC7C-398D-A8E3-396F1528E317> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff404db000 - 0x7fff404e3ff7 libGFXShared.dylib (17.10.22) <D0649AB5-5331-328D-8141-E5A6F06D4AD7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff404e4000 - 0x7fff404eefff libGL.dylib (17.10.22) <116DDBF7-D725-3B8C-BD0B-A21B758FE421> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff404ef000 - 0x7fff40523ff7 libGLImage.dylib (17.10.22) <2B314C76-C7E6-3AC5-9157-70B0529C1F9B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff40524000 - 0x7fff406b8ff7 libGLProgrammability.dylib (17.10.22) <757192B3-4509-3C26-B3B3-C10165F97661> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff406b9000 - 0x7fff406f5fff libGLU.dylib (17.10.22) <B29F73B2-B5A9-3C38-AF77-351173D2E3DB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff41131000 - 0x7fff41140ff7 com.apple.opengl (17.10.22 - 17.10.22) <D5BF32A8-2E0A-345D-80A3-7CA7C2CF748D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff41141000 - 0x7fff412bafff GLEngine (17.10.22) <0B6AF0FD-DBF3-3D91-B0EA-80402E9E1484> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff412bb000 - 0x7fff412e3fff GLRendererFloat (17.10.22) <A3D159EB-39BB-3F7C-8C1E-005D81788963> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff420fe000 - 0x7fff42380ff9 com.apple.QuartzCore (1.11 - 841.2) <444E6F22-DFA6-391B-B51F-A96AE69E524D> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff42f01000 - 0x7fff4324aff1 com.apple.security (7.0 - 59306.120.7) <AEA33464-1507-36F1-8CAE-A86EB787F9B5> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff4324b000 - 0x7fff432d3ffb com.apple.securityfoundation (6.0 - 55236.60.1) <79289FE1-CB5F-3BEF-A33F-11A29A93A681> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff43302000 - 0x7fff43306ff8 com.apple.xpc.ServiceManagement (1.0 - 1) <4194D29D-F0D4-33F8-839A-D03C6C62D8DB> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff43fb2000 - 0x7fff44020ff7 com.apple.SystemConfiguration (1.19 - 1.19) <0CF8726A-BE41-3E07-B895-FBC44B75450E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff4429f000 - 0x7fff44622ff4 com.apple.VideoToolbox (1.0 - 2620.11.40.2) <53E0D852-61CA-34FE-9A9B-788708ADE495> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff47f81000 - 0x7fff48046ff7 com.apple.APFS (1412.120.2 - 1412.120.2) <1E8FD511-FDC4-31A2-ACDE-EB5192032BC6> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff49156000 - 0x7fff49157ff1 com.apple.AggregateDictionary (1.0 - 1) <B907CE7A-0122-3E63-BF39-0A242B0DD7C4> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff496f1000 - 0x7fff4970eff4 com.apple.AppContainer (4.0 - 448.100.6) <9C2D0065-9B38-3D1C-A090-46F129A1B3CA> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff49763000 - 0x7fff49771ff7 com.apple.AppSandbox (4.0 - 448.100.6) <7DAB58B1-8176-3FB0-A7B0-8A38E118E90B> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff49bec000 - 0x7fff49c10ffb com.apple.framework.Apple80211 (13.0 - 1610.1) <B4B80CD6-B38E-3748-B30B-5088CCE9A7A8> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff49ece000 - 0x7fff49eddfd7 com.apple.AppleFSCompression (119.100.1 - 1.0) <2E75CF51-B693-3275-9A4F-40571D48745E> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff49fdc000 - 0x7fff49fe7ff7 com.apple.AppleIDAuthSupport (1.0 - 1) <F4651654-E24F-3BF4-8DDF-8F91E5219BA4> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff4a029000 - 0x7fff4a071ff7 com.apple.AppleJPEG (1.0 - 1) <4655FF70-9772-3D7C-8159-5A5E56C9F84B> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff4a45b000 - 0x7fff4a45fff7 com.apple.AppleSRP (5.0 - 1) <B683AD55-A121-31DD-9A87-3A31C35FEABF> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff4a460000 - 0x7fff4a482fff com.apple.applesauce (1.0 - 16.25) <33B66B71-64A4-365D-9953-E0545E69A5E7> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff4a541000 - 0x7fff4a544ffb com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <92580EE3-74BF-3488-90ED-C8EBD7A1B4C3> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff4a545000 - 0x7fff4a595ff7 com.apple.AppleVAFramework (6.1.2 - 6.1.2) <39C3583D-C824-3168-B67A-498487FD03D9> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff4a5de000 - 0x7fff4a5edff9 com.apple.AssertionServices (1.0 - 223.100.31) <478D2004-9B84-3AE9-9A0B-0A0B68ED028F> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff4ab2f000 - 0x7fff4af2aff8 com.apple.audio.AudioResourceArbitration (1.0 - 1) <9ABFE41A-FD01-3111-BA73-D2DD1BF96525> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
0x7fff4b180000 - 0x7fff4b3c0fe0 com.apple.audio.AudioToolboxCore (1.0 - 1104.84) <FA17E892-6A1A-309D-95C7-30ACFC44319C> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
0x7fff4b3c4000 - 0x7fff4b4e0ff0 com.apple.AuthKit (1.0 - 1) <375C3886-5430-3C02-BD2C-4244BF490ABA> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff4b69d000 - 0x7fff4b6a6ff7 com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <F070F440-27AB-3FCF-9602-F278C332CA01> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff4b6a7000 - 0x7fff4b748ff5 com.apple.backup.framework (1.11.5 - 1298.5.10) <637CA389-627A-365C-98C2-D297C47D6EE3> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff4b749000 - 0x7fff4b7d5ff6 com.apple.BaseBoard (466.3 - 466.3) <1718A41A-9923-3FD0-96B8-82376E153D27> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff4b8d7000 - 0x7fff4b913ff7 com.apple.bom (14.0 - 219.2) <586F1D9C-23B0-3F38-9C5B-728E9DD8B953> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff4c492000 - 0x7fff4c4e1fff com.apple.ChunkingLibrary (307 - 307) <32E0F1A1-9DD6-3B52-91C2-93643041AA60> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff4c63b000 - 0x7fff4c6c6ff8 com.apple.CloudDocs (1.0 - 698.14) <4CFF0DF0-8A89-3DAD-8A07-A208FDDD163B> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff4d388000 - 0x7fff4d398ffb com.apple.CommonAuth (4.0 - 2.0) <91EC83B5-857D-3D4F-93B1-AAD7E0E029D8> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff4d3ac000 - 0x7fff4d3c3fff com.apple.commonutilities (8.0 - 900) <12C6DEE5-1740-39A5-9711-6F815C6D77BD> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fff4dac7000 - 0x7fff4de9cfc8 com.apple.CoreAUC (283.0.0 - 283.0.0) <BA9522E5-95D0-30D0-BEF4-691CEB51035B> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff4de9d000 - 0x7fff4decaff7 com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <14FC549B-86BD-396A-B03E-6F5219482943> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff4deed000 - 0x7fff4df0cffc com.apple.analyticsd (1.0 - 1) <A4F653CA-2FD6-348B-B7B3-48D91A67508A> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
0x7fff4e217000 - 0x7fff4e222ff7 com.apple.frameworks.CoreDaemon (1.3 - 1.3) <8F8E586D-C153-3ABA-88B7-6CEC7F476F0E> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff4e4a3000 - 0x7fff4e4b3ff3 com.apple.CoreEmoji (1.0 - 107.1) <CDCCB4B0-B98F-38E8-9568-C81320E756EB> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff4eaf3000 - 0x7fff4eb5dff0 com.apple.CoreNLP (1.0 - 213) <40FC46D2-844C-3282-A8E4-69DD827F05C5> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff4ef8b000 - 0x7fff4ef93ff8 com.apple.CorePhoneNumbers (1.0 - 1) <B2CE100D-B82F-3481-86F6-7F85FF8BFAFB> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff4f980000 - 0x7fff4f9a3fff com.apple.CoreSVG (1.0 - 129) <3141D198-0507-3F72-A2C9-752EAFE3EEB3> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
0x7fff4f9a4000 - 0x7fff4f9d7fff com.apple.CoreServicesInternal (446.7 - 446.7) <B2CEC515-2225-3CB1-B34A-904AAEA54FDF> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff4f9d8000 - 0x7fff4fa06ffd com.apple.CSStore (1069.24 - 1069.24) <C96E5CE8-D604-3F13-B079-B2BA33B90081> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
0x7fff4ff2b000 - 0x7fff4ffc1ff7 com.apple.CoreSymbolication (11.4 - 64535.33.2) <0E7A1529-C737-33FD-AA7D-A32EB8B192DA> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff50059000 - 0x7fff50185ff6 com.apple.coreui (2.1 - 609.4) <9B93CC42-804B-305A-8FCE-5F06821B544C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff50186000 - 0x7fff5033cff5 com.apple.CoreUtils (6.2.1 - 621.5) <CD4B58E5-1494-3457-84FF-3869378E2DC9> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff50476000 - 0x7fff50489ff1 com.apple.CrashReporterSupport (10.13 - 15016) <827F4E31-9F23-3683-AC5A-59CCA90F2359> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff50542000 - 0x7fff50554ff8 com.apple.framework.DFRFoundation (1.0 - 252.50.1) <19F79D32-71D3-3A87-98C9-B5C6C96076C4> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff50555000 - 0x7fff5055afff com.apple.DSExternalDisplay (3.1 - 380) <971F24F1-B1FC-3674-9C00-F88EEF94DC05> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff505e4000 - 0x7fff5065eff0 com.apple.datadetectorscore (8.0 - 659) <9FD9BDFA-3724-3BEA-946C-0473447196A3> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff506aa000 - 0x7fff506e7ff8 com.apple.DebugSymbols (194 - 194) <9BCE6685-6C45-3DF9-98EB-FCF8196160F0> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff506e8000 - 0x7fff50870ff6 com.apple.desktopservices (1.14.5 - 1281.5.3) <79972B8B-7B60-3AD5-9A5F-17976DE8080B> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff50b0d000 - 0x7fff50bd5ffe com.apple.DiskImagesFramework (559.100.2 - 559.100.2) <DE281E96-21D0-3BE3-BEE0-D901B24D71EE> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff50bd6000 - 0x7fff50ca9ff1 com.apple.DiskManagement (13.0 - 1648.120.5) <650DBBE4-6624-3064-A26D-6BCAA0FE41F9> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
0x7fff50d8c000 - 0x7fff50d90ff9 com.apple.EFILogin (2.0 - 2) <B95015BC-5BC2-33D9-AD94-01905DD56193> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff5221e000 - 0x7fff52639ff1 com.apple.vision.FaceCore (4.3.0 - 4.3.0) <1B5D7DD6-718E-3111-A702-EB04B8903662> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff52cd7000 - 0x7fff52e0fffc libFontParser.dylib (277.2.5.3) <DEB18756-082F-359B-AE93-F9C3B5EC7AF4> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
0x7fff52e10000 - 0x7fff52e44fff libTrueTypeScaler.dylib (277.2.5.3) <B16255A6-C51A-328B-B679-8FBF64495770> /System/Library/PrivateFrameworks/FontServices.framework/libTrueTypeScaler.dylib
0x7fff52ea9000 - 0x7fff52eb9ff6 libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <6396BC1F-13C1-37D7-91B9-1FF60910C7FA> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
0x7fff5639a000 - 0x7fff5639bfff libmetal_timestamp.dylib (902.14.11) <BE88F259-0A3C-3910-8983-FB5E2C905E87> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib
0x7fff57a4c000 - 0x7fff57a57ff7 libGPUSupportMercury.dylib (17.10.22) <B2E086E1-6E50-3A3D-B014-FCDAACBACE90> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff57a58000 - 0x7fff57a5efff com.apple.GPUWrangler (5.2.4 - 5.2.4) <5B819701-9F0C-374B-8925-A22DFC16514F> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff57d7d000 - 0x7fff57da3ff1 com.apple.GenerationalStorage (2.0 - 314) <5613706F-710A-39E0-8B25-BA103A768613> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff58ed2000 - 0x7fff58ee0ffb com.apple.GraphVisualizer (1.0 - 100.1) <0A86C9FF-4484-3C7F-BC71-3D23BDBE81CE> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff5907f000 - 0x7fff5913dff4 com.apple.Heimdal (4.0 - 2.0) <F2C504F6-E211-3AB0-9754-D96D2F96634B> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff59b3a000 - 0x7fff59b69ff8 com.apple.HelpData (2.3 - 199) <31ECA355-3529-3FD8-961A-5E5F70DAE1A8> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff5b2c1000 - 0x7fff5b2c9ff5 com.apple.IOAccelerator (438.5.4 - 438.5.4) <A3CF45E0-4D88-33BF-BAEC-690D5664CDA0> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff5b2d6000 - 0x7fff5b2edfff com.apple.IOPresentment (1.0 - 37) <3EDBB454-D248-394B-A026-9717CD8535C3> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff5b675000 - 0x7fff5b6c0ff1 com.apple.IconServices (438.3 - 438.3) <2AE74790-64F1-3B0A-9534-DEEEE307E562> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff5b87e000 - 0x7fff5b885ff9 com.apple.InternationalSupport (1.0 - 45.4) <C22AA77A-EDA6-3626-8816-521A8CD43C4A> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff5b929000 - 0x7fff5b92dff4 JavaLaunching (43) <9427F093-E8E7-3AFE-8B35-77EFFAE37B47> /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/JavaLaunching
0x7fff5bb12000 - 0x7fff5bb31ffd com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <76DB5326-BE5D-3339-975C-D9FCF39A341E> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff5bc66000 - 0x7fff5bd34ffd com.apple.LanguageModeling (1.0 - 215.1) <A6FAA215-9A01-3EE1-B304-2238801C5883> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff5bd35000 - 0x7fff5bd7dfff com.apple.Lexicon-framework (1.0 - 72) <6AE1872C-0352-36FE-90CC-7303F13A5BEF> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff5bd84000 - 0x7fff5bd89ff3 com.apple.LinguisticData (1.0 - 353.18) <686E7B7C-640F-3D7B-A9C1-31E2DFACD457> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff5be2d000 - 0x7fff5be32ff7 com.apple.LoginUICore (4.0 - 4.0) <5D60C7D1-9DB7-30A3-9209-7E13644D3E9D> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fff5c621000 - 0x7fff5c624fff com.apple.Mangrove (1.0 - 25) <11A30F47-B1C1-375E-9FE7-0A196E92A52C> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff5c88d000 - 0x7fff5c917ff8 com.apple.MediaExperience (1.0 - 1) <34E15DA2-02AA-32FA-99E1-9A139521E226> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
0x7fff5c918000 - 0x7fff5c94bfff com.apple.MediaKit (16 - 923) <14E38848-C9BD-37F1-AE44-FC4CC839E8A1> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff5d0f0000 - 0x7fff5d13cfff com.apple.spotlight.metadata.utilities (1.0 - 2076.6) <C3AEA22D-1FEB-3E38-9821-1FA447C8AF9D> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff5d13d000 - 0x7fff5d20effa com.apple.gpusw.MetalTools (1.0 - 1) <A23FFAB6-437C-303C-A3E8-99F323F8E734> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff5d26c000 - 0x7fff5d285ff4 com.apple.MobileAssets (1.0 - 619.120.1) <5AF95641-68C7-351A-A317-3C7B793502D6> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff5d442000 - 0x7fff5d460fff com.apple.MobileKeyBag (2.0 - 1.0) <B564179F-A5E9-3BD8-892D-CEF2BE0DA0D7> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff5d6c3000 - 0x7fff5d6f3ff7 com.apple.MultitouchSupport.framework (3440.1 - 3440.1) <4E7CB188-382E-3128-8671-4A3EF6E06622> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff5dbf3000 - 0x7fff5dbfdfff com.apple.NetAuth (6.2 - 6.2) <D660F2CB-5A49-3DD0-9DB3-86EF0797828C> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff5e613000 - 0x7fff5e65effb com.apple.OTSVG (1.0 - 643.1.5.1) <CD494F00-9AA4-3A48-916B-EA8661F9772D> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff5f872000 - 0x7fff5f87dff2 com.apple.PerformanceAnalysis (1.243.2 - 243.2) <941698D6-EF00-3D59-8560-F160BC04B412> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff5f87e000 - 0x7fff5f8a6ffb com.apple.persistentconnection (1.0 - 1.0) <FFC20BB6-9CF3-39F2-AE5C-8DEE348FE0C1> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
0x7fff6137a000 - 0x7fff6138dffc com.apple.PowerLog (1.0 - 1) <63A89A9B-2ACC-3378-9BD0-7FA971E07C2A> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
0x7fff62209000 - 0x7fff62263ff6 com.apple.ProtectedCloudStorage (1.0 - 1) <969BF7A2-E989-3A22-BC1B-72B72E107229> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff62264000 - 0x7fff6227dffb com.apple.ProtocolBuffer (1 - 274.24.9.16.3) <A2E34123-7CED-378B-A43D-1B98B5B85F5C> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff626dc000 - 0x7fff62705ff1 com.apple.RemoteViewServices (2.0 - 148) <1C61CFC2-F76F-31E5-BA13-EFD5DC69C8D5> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff6286a000 - 0x7fff628a5ff0 com.apple.RunningBoardServices (1.0 - 223.100.31) <9FD1FC53-186A-3327-A359-B0BC7F4360EF> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
0x7fff64185000 - 0x7fff64188ff5 com.apple.SecCodeWrapper (4.0 - 448.100.6) <813B3E57-6A95-3D7B-9094-C65D687A72B8> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff642fb000 - 0x7fff64422ff0 com.apple.Sharing (1526.31 - 1526.31) <2CB07F08-7794-3BF2-9ED5-BAB5C55C9D2C> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff6447b000 - 0x7fff64499ff2 com.apple.shortcut (2.16 - 106) <51323823-C5EB-3EE0-AA81-8D633A3F75BD> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff65835000 - 0x7fff65b2bff7 com.apple.SkyLight (1.600.0 - 451.4) <F5B9065A-E975-36D1-8D53-9FBF02171FAB> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff66378000 - 0x7fff66386ffb com.apple.SpeechRecognitionCore (6.0.91.2 - 6.0.91.2) <820602AB-117B-3C3E-B20B-819CBC97B7A4> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff66448000 - 0x7fff666d2ffe com.apple.spotlight.index (10.7.0 - 2076.6) <38E208FE-A4E5-3B6C-9937-97CA152F1BB2> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
0x7fff66a60000 - 0x7fff66aa1ff9 com.apple.StreamingZip (1.0 - 1) <EFCDDC94-28EE-3BCA-A105-0A928D15ED8C> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff66bb8000 - 0x7fff66bc1ff7 com.apple.SymptomDiagnosticReporter (1.0 - 1238.120.1) <581F31D6-94CB-38AA-BD56-1A63606E516E> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
0x7fff66c32000 - 0x7fff66c5cffa com.apple.framework.SystemAdministration (1.0 - 1.0) <926BB2F5-E02C-30B7-949A-20EFE57CF242> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fff66e78000 - 0x7fff66e88ff3 com.apple.TCC (1.0 - 1) <FD146B21-6DC0-3B66-BB95-57A5016B1365> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff673ad000 - 0x7fff67473ff0 com.apple.TextureIO (3.10.9 - 3.10.9) <E23E05ED-8190-3564-985E-446F15CB0709> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff675ff000 - 0x7fff67600fff com.apple.TrustEvaluationAgent (2.0 - 33) <11DF5A28-4410-36A8-B3B8-BF1094BE1544> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff67638000 - 0x7fff67890ff0 com.apple.UIFoundation (1.0 - 662) <DFD3DD4A-E661-3A12-BB02-06898949617D> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff68503000 - 0x7fff68523ffc com.apple.UserManagement (1.0 - 1) <E168206A-9DC1-3C67-A9A6-52D816DBD5B1> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
0x7fff692cf000 - 0x7fff693b9ff8 com.apple.ViewBridge (464.1 - 464.1) <C698BAC9-26C8-39F1-BBC0-F57EBD2EFD7B> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff6955f000 - 0x7fff69560fff com.apple.WatchdogClient.framework (1.0 - 67.120.2) <3B8EBB6B-77D0-317C-A3DB-D0D2E294B18D> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
0x7fff6a18d000 - 0x7fff6a190ffa com.apple.dt.XCTTargetBootstrap (1.0 - 16091) <D4F09EC7-C63F-3861-B5DA-3F7C0DFF153D> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x7fff6a20a000 - 0x7fff6a218ff5 com.apple.audio.caulk (1.0 - 32.3) <7D3D2F91-8B1D-3558-B324-45BDF11306DB> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x7fff6a55a000 - 0x7fff6a55cff3 com.apple.loginsupport (1.0 - 1) <31F02734-1ECF-37D9-9DF6-7C3BC3A324FE> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff6a55d000 - 0x7fff6a570ffd com.apple.login (3.0 - 3.0) <1DC570FD-29EC-3AE8-BD34-D44C00E4621B> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
0x7fff6d040000 - 0x7fff6d073ffa libAudioToolboxUtility.dylib (1104.84) <BB234563-F952-3E7F-B630-4140DB5E0380> /usr/lib/libAudioToolboxUtility.dylib
0x7fff6d07a000 - 0x7fff6d0aefff libCRFSuite.dylib (48) <02C52318-C537-3FD8-BBC4-E5BD25430652> /usr/lib/libCRFSuite.dylib
0x7fff6d0b1000 - 0x7fff6d0bbfff libChineseTokenizer.dylib (34) <04A7CB5A-FD68-398A-A206-33A510C115E7> /usr/lib/libChineseTokenizer.dylib
0x7fff6d0bc000 - 0x7fff6d144fff libCoreStorage.dylib (551) <BBD3B3DC-270D-35F2-8C67-4595A257EEBB> /usr/lib/libCoreStorage.dylib
0x7fff6d147000 - 0x7fff6d149ff7 libDiagnosticMessagesClient.dylib (112) <27220E98-6CE2-33E3-BD48-3CC3CE4AA036> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff6d18f000 - 0x7fff6d346ffb libFosl_dynamic.dylib (100.4) <68038226-8CAA-36B5-B5D6-510F900B318D> /usr/lib/libFosl_dynamic.dylib
0x7fff6d36d000 - 0x7fff6d373ff3 libIOReport.dylib (54) <E3A2148E-C5B2-30A8-ACD3-E081DD02BE90> /usr/lib/libIOReport.dylib
0x7fff6d455000 - 0x7fff6d45cfff libMatch.1.dylib (36) <081FB6A9-0482-3697-A98B-6821FF476C6E> /usr/lib/libMatch.1.dylib
0x7fff6d48b000 - 0x7fff6d4abfff libMobileGestalt.dylib (826.120.5) <1977AD00-533A-31AA-8D74-EA6CB962F668> /usr/lib/libMobileGestalt.dylib
0x7fff6d61d000 - 0x7fff6d61efff libSystem.B.dylib (1281.100.1) <B6FDA8A9-3D2B-3BD5-B5B0-57D311C0FF3D> /usr/lib/libSystem.B.dylib
0x7fff6d6ab000 - 0x7fff6d6acfff libThaiTokenizer.dylib (3) <97DC10ED-3C11-3C89-B366-299A644035E7> /usr/lib/libThaiTokenizer.dylib
0x7fff6d6c4000 - 0x7fff6d6dafff libapple_nghttp2.dylib (1.39.2) <B99D7150-D4E2-31A2-A594-36DA4B90D558> /usr/lib/libapple_nghttp2.dylib
0x7fff6d70f000 - 0x7fff6d781ff7 libarchive.2.dylib (72.100.1) <20B70252-0C4B-3AFD-8C8D-F51921E9D324> /usr/lib/libarchive.2.dylib
0x7fff6d782000 - 0x7fff6d81bfe5 libate.dylib (3.0.1) <C4A5AE88-4E44-36FA-AD3E-0629AF9B94E0> /usr/lib/libate.dylib
0x7fff6d81f000 - 0x7fff6d81fff3 libauto.dylib (187) <85383E24-1592-36BC-BB39-308B7F1C826E> /usr/lib/libauto.dylib
0x7fff6d8e5000 - 0x7fff6d8f5ffb libbsm.0.dylib (60.100.1) <B2331E11-3CBB-3BCF-93A6-12627AE444D0> /usr/lib/libbsm.0.dylib
0x7fff6d8f6000 - 0x7fff6d902fff libbz2.1.0.dylib (44) <BF40E193-8856-39B7-98F8-7A17B328B1E9> /usr/lib/libbz2.1.0.dylib
0x7fff6d903000 - 0x7fff6d955fff libc++.1.dylib (902.1) <AD0805FE-F98B-3E2F-B072-83782B22DAC9> /usr/lib/libc++.1.dylib
0x7fff6d956000 - 0x7fff6d96bffb libc++abi.dylib (902) <771E9263-E832-3985-9477-8F1B2D73B771> /usr/lib/libc++abi.dylib
0x7fff6d96c000 - 0x7fff6d96cfff libcharset.1.dylib (59) <FF23D4ED-A5AD-3592-9574-48486C7DF85B> /usr/lib/libcharset.1.dylib
0x7fff6d96d000 - 0x7fff6d97efff libcmph.dylib (8) <296A51E6-9661-3AC2-A1C9-F1E3510F91AA> /usr/lib/libcmph.dylib
0x7fff6d97f000 - 0x7fff6d996fd7 libcompression.dylib (87) <21F37C2E-B9AA-38CE-9023-B763C8828AC6> /usr/lib/libcompression.dylib
0x7fff6dc70000 - 0x7fff6dc86ff7 libcoretls.dylib (167) <9E5D1E0C-03F8-37B6-82A1-0D0597021CB8> /usr/lib/libcoretls.dylib
0x7fff6dc87000 - 0x7fff6dc88fff libcoretls_cfhelpers.dylib (167) <C23BE09B-85D1-3744-9E7B-E2B11ACD5442> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff6e12b000 - 0x7fff6e22ffef libcrypto.44.dylib (47.120.1) <B48C0D1A-CDCB-34E4-921E-00EBFF1208DE> /usr/lib/libcrypto.44.dylib
0x7fff6e232000 - 0x7fff6e23dfff libcsfde.dylib (551) <8FBB94EC-712C-3C0F-A8A9-88EE5F4679EF> /usr/lib/libcsfde.dylib
0x7fff6e245000 - 0x7fff6e2a4ff7 libcups.2.dylib (483.6) <FFE8FE67-A6CC-3C38-A9D7-D411D7B562F1> /usr/lib/libcups.2.dylib
0x7fff6e2a6000 - 0x7fff6e30bff7 libcurl.4.dylib (118.120.2) <F2C246F3-460E-31A7-B900-2A9560533730> /usr/lib/libcurl.4.dylib
0x7fff6e3ae000 - 0x7fff6e3aefff libenergytrace.dylib (21) <DBF8BDEE-7229-3F06-AC10-A28DCC4243C0> /usr/lib/libenergytrace.dylib
0x7fff6e3af000 - 0x7fff6e3c7fff libexpat.1.dylib (19.60.2) <C9163264-BA81-3CC6-9B8C-48A9A0709DD5> /usr/lib/libexpat.1.dylib
0x7fff6e3d5000 - 0x7fff6e3d7fff libfakelink.dylib (149.1) <122F530F-F10E-3DD5-BBEA-91796BE583F3> /usr/lib/libfakelink.dylib
0x7fff6e3e6000 - 0x7fff6e3ebfff libgermantok.dylib (24) <DD279BF6-E906-30D3-A69E-DC797E95F147> /usr/lib/libgermantok.dylib
0x7fff6e3ec000 - 0x7fff6e3f5ff7 libheimdal-asn1.dylib (564.100.1) <68FA1BE5-8FFC-3345-8980-8D8629EBA451> /usr/lib/libheimdal-asn1.dylib
0x7fff6e3f6000 - 0x7fff6e4e6fff libiconv.2.dylib (59) <F58FED71-6CCA-30E8-9A51-13E9B46E568D> /usr/lib/libiconv.2.dylib
0x7fff6e4e7000 - 0x7fff6e73efff libicucore.A.dylib (64260.0.1) <7B9204AC-EA14-3FF3-B6B9-4C85B37EED79> /usr/lib/libicucore.A.dylib
0x7fff6e758000 - 0x7fff6e759fff liblangid.dylib (133) <36581D30-1C7B-3A58-AA07-36237BD75E0E> /usr/lib/liblangid.dylib
0x7fff6e75a000 - 0x7fff6e772ff3 liblzma.5.dylib (16) <4DB30730-DBD1-3503-957A-D604049B98F9> /usr/lib/liblzma.5.dylib
0x7fff6e78a000 - 0x7fff6e831ff7 libmecab.dylib (883.11) <66AD729B-2BCC-3347-B9B3-FD88570E884D> /usr/lib/libmecab.dylib
0x7fff6e832000 - 0x7fff6ea94ff1 libmecabra.dylib (883.11) <2AE744D2-AC95-3720-8E66-4F9C7A79384C> /usr/lib/libmecabra.dylib
0x7fff6ee01000 - 0x7fff6ee30fff libncurses.5.4.dylib (57) <B0B09D08-A7C9-38E9-8BF4-E4F4882F93A6> /usr/lib/libncurses.5.4.dylib
0x7fff6ef60000 - 0x7fff6f3dcff5 libnetwork.dylib (1880.120.4) <715FB943-BA01-351C-BEA6-121970472985> /usr/lib/libnetwork.dylib
0x7fff6f47d000 - 0x7fff6f4b0fde libobjc.A.dylib (787.1) <CA836D3E-4595-33F1-B70C-7E39A3FBBE16> /usr/lib/libobjc.A.dylib
0x7fff6f4b1000 - 0x7fff6f4b2ff7 libodfde.dylib (26) <2DDA61BF-E92A-3463-B1C4-D59E40D34D34> /usr/lib/libodfde.dylib
0x7fff6f4c3000 - 0x7fff6f4c7fff libpam.2.dylib (25.100.1) <732E8D8E-C630-3EC2-B6C3-A1564E3B68B8> /usr/lib/libpam.2.dylib
0x7fff6f4ca000 - 0x7fff6f500ff7 libpcap.A.dylib (89.120.1) <CF2ADF15-2D44-3A35-94B4-DD24052F9B23> /usr/lib/libpcap.A.dylib
0x7fff6f584000 - 0x7fff6f59cfff libresolv.9.dylib (67.40.1) <B0F5D204-7EF2-3B0B-90EF-BB4D196FCC62> /usr/lib/libresolv.9.dylib
0x7fff6f59e000 - 0x7fff6f5e2ff7 libsandbox.1.dylib (1217.120.7) <728BC15F-9A6C-3634-9427-60C01CB5A5D6> /usr/lib/libsandbox.1.dylib
0x7fff6f5e3000 - 0x7fff6f5f5ff7 libsasl2.2.dylib (213.120.1) <E6375405-168D-3B75-8042-C8B329D01AB9> /usr/lib/libsasl2.2.dylib
0x7fff6f5f6000 - 0x7fff6f5f7ff7 libspindump.dylib (281.3) <0C3A8B48-DC31-3F61-B4CC-746157042D0E> /usr/lib/libspindump.dylib
0x7fff6f5f8000 - 0x7fff6f7e2ff7 libsqlite3.dylib (308.5) <AF518115-4AD1-39F2-9B82-E2640E2221E1> /usr/lib/libsqlite3.dylib
0x7fff6f8d6000 - 0x7fff6f903ffb libssl.46.dylib (47.120.1) <6209494A-4AAD-344E-992C-03ACD2D4C402> /usr/lib/libssl.46.dylib
0x7fff6f906000 - 0x7fff6f950ff7 libstdc++.6.dylib (104.1) <26211C4C-8B34-3A63-8B38-61B195B586C8> /usr/lib/libstdc++.6.dylib
0x7fff6fa33000 - 0x7fff6fa36ffb libutil.dylib (57) <D33B63D2-ADC2-38BD-B8F2-24056C41E07B> /usr/lib/libutil.dylib
0x7fff6fa37000 - 0x7fff6fa44ff7 libxar.1.dylib (425.2) <943A4CBB-331B-3A04-A11F-A2301189D40B> /usr/lib/libxar.1.dylib
0x7fff6fa4a000 - 0x7fff6fb2cff7 libxml2.2.dylib (33.3) <262EF7C6-7D83-3C01-863F-36E97F5ACD34> /usr/lib/libxml2.2.dylib
0x7fff6fb30000 - 0x7fff6fb58fff libxslt.1.dylib (16.9) <86FE4382-BD77-3C19-A678-11EBCD70685A> /usr/lib/libxslt.1.dylib
0x7fff6fb59000 - 0x7fff6fb6bff3 libz.1.dylib (76) <DB120508-3BED-37A8-B439-5235EAB4618A> /usr/lib/libz.1.dylib
0x7fff70419000 - 0x7fff7041eff3 libcache.dylib (83) <A5ECC751-A681-30D8-B33C-D192C15D25C8> /usr/lib/system/libcache.dylib
0x7fff7041f000 - 0x7fff7042afff libcommonCrypto.dylib (60165.120.1) <C321A74A-AA91-3785-BEBF-BEDC6975026C> /usr/lib/system/libcommonCrypto.dylib
0x7fff7042b000 - 0x7fff70432fff libcompiler_rt.dylib (101.2) <652A6012-7E5C-3F4F-9438-86BC094526F3> /usr/lib/system/libcompiler_rt.dylib
0x7fff70433000 - 0x7fff7043cff7 libcopyfile.dylib (166.40.1) <40113A69-A81C-3397-ADC6-1D16B9A22C3E> /usr/lib/system/libcopyfile.dylib
0x7fff7043d000 - 0x7fff704cffe3 libcorecrypto.dylib (866.120.3) <5E4B0E50-24DD-3E04-9374-EDA9FFD6257B> /usr/lib/system/libcorecrypto.dylib
0x7fff705dc000 - 0x7fff7061cff0 libdispatch.dylib (1173.100.2) <201EDBF3-0B36-31BA-A7CB-443CE35C05D4> /usr/lib/system/libdispatch.dylib
0x7fff7061d000 - 0x7fff70653fff libdyld.dylib (750.5) <7E711A46-5E4D-393C-AEA6-440E2A5CCD0C> /usr/lib/system/libdyld.dylib
0x7fff70654000 - 0x7fff70654ffb libkeymgr.dylib (30) <52662CAA-DB1F-30A3-BE13-D6274B1A6D7B> /usr/lib/system/libkeymgr.dylib
0x7fff70655000 - 0x7fff70661ff3 libkxld.dylib (6153.121.2) <5EBB4886-C7B6-31D6-AA63-D861B2D58FCE> /usr/lib/system/libkxld.dylib
0x7fff70662000 - 0x7fff70662ff7 liblaunch.dylib (1738.120.8) <07CF647B-F9DC-3907-AD98-2F85FCB34A72> /usr/lib/system/liblaunch.dylib
0x7fff70663000 - 0x7fff70668ff7 libmacho.dylib (959.0.1) <D91DFF00-E22F-3796-8A1C-4C1F5F8FA03C> /usr/lib/system/libmacho.dylib
0x7fff70669000 - 0x7fff7066bff3 libquarantine.dylib (110.40.3) <D3B7D02C-7646-3FB4-8529-B36DCC2419EA> /usr/lib/system/libquarantine.dylib
0x7fff7066c000 - 0x7fff7066dff7 libremovefile.dylib (48) <B5E88D9B-C2BE-3496-BBB2-C996317E18A3> /usr/lib/system/libremovefile.dylib
0x7fff7066e000 - 0x7fff70685ff3 libsystem_asl.dylib (377.60.2) <1170348D-2491-33F1-AA79-E2A05B4A287C> /usr/lib/system/libsystem_asl.dylib
0x7fff70686000 - 0x7fff70686ff7 libsystem_blocks.dylib (74) <7AFBCAA6-81BE-36C3-8DB0-AAE0A4ACE4C5> /usr/lib/system/libsystem_blocks.dylib
0x7fff70687000 - 0x7fff7070efff libsystem_c.dylib (1353.100.2) <935DDCE9-4ED0-3F79-A05A-A123DDE399CC> /usr/lib/system/libsystem_c.dylib
0x7fff7070f000 - 0x7fff70712ffb libsystem_configuration.dylib (1061.120.2) <EA9BC2B1-5001-3463-9FAF-39FF61CAC87C> /usr/lib/system/libsystem_configuration.dylib
0x7fff70713000 - 0x7fff70716fff libsystem_coreservices.dylib (114) <3D0A3AA8-8415-37B2-AAE3-66C03BCE8B55> /usr/lib/system/libsystem_coreservices.dylib
0x7fff70717000 - 0x7fff7071ffff libsystem_darwin.dylib (1353.100.2) <6EEC9975-EE3B-3C95-AA5B-030FD10587BC> /usr/lib/system/libsystem_darwin.dylib
0x7fff70720000 - 0x7fff70727fff libsystem_dnssd.dylib (1096.100.3) <0115092A-E61B-317D-8670-41C7C34B1A82> /usr/lib/system/libsystem_dnssd.dylib
0x7fff70728000 - 0x7fff70729ffb libsystem_featureflags.dylib (17) <AFDB5095-0472-34AC-BA7E-497921BF030A> /usr/lib/system/libsystem_featureflags.dylib
0x7fff7072a000 - 0x7fff70777ff7 libsystem_info.dylib (538) <851693E9-C079-3547-AD41-353F8C248BE8> /usr/lib/system/libsystem_info.dylib
0x7fff70778000 - 0x7fff707a4ff7 libsystem_kernel.dylib (6153.121.2) <9F9902C9-A46F-3CA9-B7F9-5CCFE98FBF75> /usr/lib/system/libsystem_kernel.dylib
0x7fff707a5000 - 0x7fff707ecfff libsystem_m.dylib (3178) <436CFF76-6A99-36F2-A3B6-8D017396A050> /usr/lib/system/libsystem_m.dylib
0x7fff707ed000 - 0x7fff70814fff libsystem_malloc.dylib (283.100.6) <D4BA7DF2-57AC-33B0-B948-A688EE43C799> /usr/lib/system/libsystem_malloc.dylib
0x7fff70815000 - 0x7fff70822ffb libsystem_networkextension.dylib (1095.120.6) <6DE86DB0-8CD2-361E-BD6A-A34282B47847> /usr/lib/system/libsystem_networkextension.dylib
0x7fff70823000 - 0x7fff7082cff7 libsystem_notify.dylib (241.100.2) <7E9E2FC8-DF26-340C-B196-B81B11850C46> /usr/lib/system/libsystem_notify.dylib
0x7fff7082d000 - 0x7fff70835fef libsystem_platform.dylib (220.100.1) <736920EA-6AE0-3B1B-BBDA-7DCDF0C229DF> /usr/lib/system/libsystem_platform.dylib
0x7fff70836000 - 0x7fff70840fff libsystem_pthread.dylib (416.100.3) <77488669-19A3-3993-AD65-CA5377E2475A> /usr/lib/system/libsystem_pthread.dylib
0x7fff70841000 - 0x7fff70845ff3 libsystem_sandbox.dylib (1217.120.7) <20C93D69-6452-3C82-9521-8AE54345C66F> /usr/lib/system/libsystem_sandbox.dylib
0x7fff70846000 - 0x7fff70848fff libsystem_secinit.dylib (62.100.2) <E851113D-D5B1-3FB0-9D29-9C7647A71961> /usr/lib/system/libsystem_secinit.dylib
0x7fff70849000 - 0x7fff70850ffb libsystem_symptoms.dylib (1238.120.1) <25C3866B-004E-3621-9CD3-B1E9C4D887EB> /usr/lib/system/libsystem_symptoms.dylib
0x7fff70851000 - 0x7fff70867ff2 libsystem_trace.dylib (1147.120) <A1ED1D3A-5FAD-3559-A1D6-1BE4E1C5756A> /usr/lib/system/libsystem_trace.dylib
0x7fff70869000 - 0x7fff7086eff7 libunwind.dylib (35.4) <253A12E2-F88F-3838-A666-C5306F833CB8> /usr/lib/system/libunwind.dylib
0x7fff7086f000 - 0x7fff708a4ffe libxpc.dylib (1738.120.8) <68D433B6-DCFF-385D-8620-F847FB7D4A5A> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 14
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 4799
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=628.2M resident=0K(0%) swapped_out_or_unallocated=628.2M(100%)
Writable regions: Total=971.6M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=971.6M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 1024K 8
Activity Tracing 256K 1
CG backing stores 1328K 4
CG image 284K 18
CoreAnimation 6400K 33
CoreGraphics 8K 1
CoreImage 52K 6
CoreUI image data 2576K 27
Foundation 24K 2
Kernel Alloc Once 8K 1
MALLOC 632.8M 1119
MALLOC guard page 32K 8
MALLOC_LARGE (reserved) 7424K 3 reserved VM address space (unallocated)
Memory Tag 242 12K 1
STACK GUARD 432K 44
Stack 47.1M 45
Stack Guard 56.1M 32
VM_ALLOCATE 1.8G 663
__DATA 30.1M 349
__DATA_CONST 48K 3
__FONT_DATA 4K 1
__GLSLBUILTINS 5176K 1
__LINKEDIT 398.6M 26
__OBJC_RO 32.2M 1
__OBJC_RW 1892K 2
__TEXT 229.6M 340
__UNICODE 564K 1
mapped file 805.0M 310
shared memory 656K 19
TOTAL 4.0G 3069
TOTAL, minus reserved VM space 4.0G 3069
Model: MacBookPro13,1, BootROM 245.0.0.0.0, 2 processors, Dual-Core Intel Core i5, 2 GHz, 8 GB, SMC 2.36f101
Graphics: kHW_IntelIrisGraphics540Item, Intel Iris Graphics 540, spdisplays_builtin
Memory Module: BANK 0/DIMM0, 4 GB, LPDDR3, 1867 MHz, 0x802C, 0x4D5435324C3531324D3332443250462D3130
Memory Module: BANK 1/DIMM0, 4 GB, LPDDR3, 1867 MHz, 0x802C, 0x4D5435324C3531324D3332443250462D3130
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x159), Broadcom BCM43xx 1.0 (7.77.111.1 AirPortDriverBrcmNIC-1610.1)
Bluetooth: Version 7.0.5f6, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Network Service: iPhone, Ethernet, en4
USB Device: USB3.0 Hub
USB Device: USB5537B
USB Device: USB 3.0 Bus
USB Device: USB2.0 Hub
USB Device: USB2137B
USB Device: iPhone
USB Device: USB-C Digital AV Multiport Adapter
Thunderbolt Bus: MacBook Pro, Apple Inc., 41.2
Dr.Mariano1980
06-10-2020, 01:23 PM
The new release of the Teensyduino is very good, but I found a bug and the bug is reproducable on different computers/ Notebooks, under Windows 8.1 and Windows 10, as well as on the Arduino IDE 1.8.5 up to 1.8.12:
If you used a TEENSY 4.0 board and want to change the MCU clock speed to 450 Hz (debug mode), the TEENSY 4.0 will not be uploaded with the compiled code (for example blink). Instead, the board is not longer detected on the USB-Port, until you change from TEENSY 4.0 to e.g. TEENSY 4.1 or TEENSY 3.2 and try to upload. Than you can reset the board.
Please check it.
Best regards: Mariano
KurtE
06-10-2020, 01:43 PM
Please check it.
I confirmed there appears to be an issue with compiling a T4 with the Debug optimize option. I tried it at both 450 and 600mhz and in both cases the blink program did not blink and did not show up on USB port list.
I could easily recover, by choosing a different option, do a build and press the program button on the T4
