Hello,
I'm currently try to use an Adafruit GPS with tinyGPS++. The sketch run on Arduino 1.8.3 / Teensyduino 1.5.3b2, a Teensy 4.0. I use Serial3 for the GPS.
The problem I have is that if I do anything else than pooling Serial3 in the loop, I miss many GPS frames and it make it unreliable. If I add a simple [delay (100);] in the loop the problem appear. Here is the relevant part of my code :
Capteurs.h :
Capteurs.cpp
In Capteurs.cpp, I currently only write on serial (console) what is received on Serial3 (GPS). I get all frames OK if there is nothing else in the loop. If I do anything else in the loop I have bad frames.
I think it's a buffer size problem. Can someone point me to the right direction to solve this problem. I have many more to do in the loop than just parse GPS data ;-)
Thank to any one who will answer.
Manu
#include <EEPROM.h>
#include <RA8875.h>
#include <FlexCAN_T4.h>
#include <ADC.h>
#include <Encoder.h>
#include <Bounce2.h>
#include <WS2812Serial.h>
#define USE_WS2812SERIAL
#include <FastLED.h>
#include "Pins.h"
#include "Variables_Globales.h"
#include "Signal.h"
#include "Signaux.h"
#include "Capteurs.h"
#include "TeensyTimerTool.h"
using namespace TeensyTimerTool;
// Les instances
Capteurs capteurs;
while ((!Serial) && (millis() < 750) );
Serial.println("Serial OK");
capteurs.refreshGPSData();
//delay (100);
Capteurs.h :
#ifndef Capteurs_h
#define Capteurs_h
#include "Reglages_Generaux.h"
#include "TinyGPS++.h"
#include "Time.h"
#define SECONDS_IN_ONE_HOUR 3600
class Capteurs {
public:
void begin();
void startGPS();
void refreshGPSData();
void syncRtcWithGps();
float getGPSSpeed();
bool isDaylightSavingTime();
TinyGPSPlus getGPS();
private:
bool rtcSyncWithGps;
Capteurs.cpp
TinyGPSPlus gps;
bool rtcSyncWithGps = false;
void Capteurs::begin() {
startGPS();
void Capteurs::startGPS() {
Serial3.begin(9600); // Le GPS est en mode 9600 au démarrage
delay(10);
// GPS COM = 38400 baud
//Serial3.write("$PMTK251,9600*17\r\n"); //set baud rate to 9600
//Serial3.write("$PMTK251,19200*22\r\n"); //set baud rate to 19200
Serial3.write("$PMTK251,38400*27\r\n"); //set baud rate to 38400
//Serial3.write("$PMTK251,57600*2C\r\n"); //set baud rate to 57600
Serial3.flush();
delay(10);
Serial3.end();
delay(10);
Serial3.begin(38400);
// Désactive tous les messages NMEA à l'exception de RMC, VTG, GGA and GSA. GSA est envoyé toutes les 5 transmission.
Serial3.write("$PMTK314,0,1,1,1,5,0,0,0,0,0,0,0,0,0,0,0,0,0,0*2C\r\n");
Serial3.flush();
// Passe le GPS en mode 10Hz.
Serial3.write("$PMTK220,100*2F\r\n");
Serial3.flush();
void Capteurs::refreshGPSData() {
//Serial.println ("refresh");
bool nmeaReceived = false;
while (!nmeaReceived && (Serial3.available() > 0)) {
char c = Serial3.read();
Serial.print(c);
//nmeaReceived = gps.encode(Serial3.read());
//if (nmeaReceived == true) Serial.println ("1");
// If a sentence is received, we can check the checksum, parse it...
if (gps.location.isUpdated() && gps.time.age() < 500) {
Signal objet = Signaux::trouveObjetParNom("LAT");
objet.valeur = gps.location.lat();
//item.value = ObjetsAffichables::litValeurUtilisateurAPartirValeurBrute(item);
Signaux::ecritObjet(objet);
objet = Signaux::trouveObjetParNom("LONG");
objet.valeur = gps.location.lng();
objet = Signaux::trouveObjetParNom("ALT");
objet.valeur = gps.altitude.kilometers();
objet = Signaux::trouveObjetParNom("VIT");
objet.valeur = gps.speed.mps();
objet = Signaux::trouveObjetParNom("SAT");
objet.valeur = gps.satellites.value();
//syncRtcWithGps();
Manu
