View Full Version : Teensyduino 1.53 Beta #3
Here is a third beta test for Teensyduino 1.53.
Linux 32 bit:
https://www.pjrc.com/teensy/td_153-beta3/TeensyduinoInstall.linux32
Linux 64 bit:
https://www.pjrc.com/teensy/td_153-beta3/TeensyduinoInstall.linux64
Linux ARM:
https://www.pjrc.com/teensy/td_153-beta3/TeensyduinoInstall.linuxarm
Linux ARM64:
https://www.pjrc.com/teensy/td_153-beta3/TeensyduinoInstall.linuxaarch64
MacOS 10.10 to 10.15:
https://www.pjrc.com/teensy/td_153-beta3/Teensyduino_MacOS_Catalina.zip
MacOS 10.8 to 10.14:
https://www.pjrc.com/teensy/td_153-beta3/TeensyduinoInstall.dmg
Windows:
https://www.pjrc.com/teensy/td_153-beta3/TeensyduinoInstall.exe
Changes since Teensyduino 1.53-beta2 (https://forum.pjrc.com/threads/61451-Teensyduino-1-53-Beta-2):
Add SPI.end() on Teensy 4.x (KurtE)
Fix PT8211 output on Teensy 4.x
Fix USB BDT clear at startup on Teensy 3.x (Memotech-Bill)
Add digitalToggle(pin)
Fix numerical overflow in Audio CPU usage on Teensy 4.x
Remane addStorage to addMemory
Add Teensy 3.5/3.6 hardware random to Entropy (Manitou)
Fix ILI9341_r4 readcommand() & add readScanLine() on Teensy 4.x
Installer will delete old/stale libraries
Linux installer checks udev rules
Libraries updated: ADC, ILI9488_t3, RA8875
defragster
06-27-2020, 08:09 PM
Download Windows - for Win 10 current
Close IDE/TD
Install TD 1.53b3
Open IDE 1.8.13
Compile/upload/T_SerMon simple T_3.2 sketch
Change to T_4.1
Compile/upload/T_SerMon same simple sketch
ALL GOOD
Silverlock
06-27-2020, 09:08 PM
Linux ARM on Raspbian Stretch
The installer picked up on the fact that I'd modified the udev rule file to add a symlink. And it allowed me to skip the check, which was a nice touch and appreciated.
No troubles with my usual T4.x compiles and links. So far, so good.
wwatson
06-27-2020, 09:35 PM
Linux Ubuntu 18.04.1
Installed on Ardunio 1.8.13. So far everything is working well. The only thing I have trouble with is running teensy41_psram_memtest.ino. It still fails unless I modify startup.c as per this post:
https://forum.pjrc.com/threads/60532-Teensy-4-1-Beta-Test?p=241081&viewfull=1#post241081
Am I missing something? Has anybody else had this problem?
Thanks
defragster
06-27-2020, 09:49 PM
Thanks
Running current TD.153b3 on Windows per p#2
On T_4.1 with 1 8MB PSRAM and 1 16MB FLASH on underside { pre beta T_4.1 } running github.com/PaulStoffregen/teensy41_psram_memtest/blob/master/teensy41_psram_memtest.ino (https://github.com/PaulStoffregen/teensy41_psram_memtest/blob/master/teensy41_psram_memtest.ino)
Have run it twice to good effect:
EXTMEM Memory Test, 8 Mbyte
CCM_CBCMR=B5AE8304 (88.0 MHz)
testing with fixed pattern 5A698421
testing with pseudo-random sequence, seed=2976674124
testing with fixed pattern 00000000
test ran for 36.65 seconds
All memory tests passed :-)
... update pending - will go get twin 8MB PSRAM T_4.1 ...
wwatson
06-27-2020, 09:56 PM
Thanks for checking. Will wait for results.
Silverlock
06-27-2020, 10:08 PM
...The only thing I have trouble with is running teensy41_psram_memtest.ino...
Compiled, loaded and ran teensy41_psram_memtest.ino (https://github.com/PaulStoffregen/teensy41_psram_memtest/blob/master/teensy41_psram_memtest.ino) w/o modifications or problems with the following setup and settings (some of which I'm sure don't matter but are included for completeness):
Arduino 1.8.13, Teensyduino 1.53b3
Teensy 4.1, USB type: Serial, CPU speed: 600MHz, Optimize: Faster, Keyboard layout: US English, Port: /dev/ttyACM0 Serial (Teensy 4.1)
The PSRAM chip being used is an ESP32-PSRAM64H scavenged from an ESP32 board.
defragster
06-27-2020, 10:09 PM
Can't find production T_4.1 with the Dual PSRAM's just now ... Note - also ran with no PSRAM and it just saw no PSRAM and quit as expected.
wwatson
06-27-2020, 10:31 PM
@defragster, @Silverlock,
I am running a 600MHz, Optimize Fast, psram purchased directly from PJRC. I have done further testing and found some interesting results.
Instead of this modification:
// look for the first PSRAM chip
flexspi2_command(0, 0); // exit quad mode
flexspi2_command(1, 0); // reset enable
flexspi2_command(2, 0); // reset (is this really necessary?)
delayMicroseconds(50);
if (flexspi2_psram_id(0) == 0x5D0D) {
// first PSRAM chip is present, look for a second PSRAM chip
flexspi2_command(4, 0);
flexspi2_command(0, 0x800000); // exit quad mode
flexspi2_command(1, 0x800000); // reset enable
flexspi2_command(2, 0x800000); // reset (is this really necessary?)
if (flexspi2_psram_id(0x800000) == 0x5D0D) {
flexspi2_command(4, 0x800000);
// Two PSRAM chips are present, 16 MByte
external_psram_size = 16;
// One PSRAM chip is present, 8 MByte
external_psram_size = 8;
// TODO: zero uninitialized EXTMEM variables
// TODO: copy from flash to initialize EXTMEM variables
// TODO: set up for malloc_extmem()
// No PSRAM
I kept moving the delayMicroseconds(50); up through the code until the memtest failed. This was just a single delay line.
The point where it fails is here:
// initialize pins
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_22 = 0x1B0F9; // 100K pullup, strong drive, max speed, hyst
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_23 = 0x110F9; // keeper, strong drive, max speed, hyst
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_24 = 0x1B0F9; // 100K pullup, strong drive, max speed, hyst
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_25 = 0x100F9; // strong drive, max speed, hyst
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_26 = 0x170F9; // 47K pullup, strong drive, max speed, hyst
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_27 = 0x170F9; // 47K pullup, strong drive, max speed, hyst
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_28 = 0x170F9; // 47K pullup, strong drive, max speed, hyst
IOMUXC_SW_PAD_CTL_PAD_GPIO_EMC_29 = 0x170F9; // 47K pullup, strong drive, max speed, hyst
delayMicroseconds(43); // psram memtest fails with delay at this point.
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_22 = 8 | 0x10; // ALT1 = FLEXSPI2_A_SS1_B (Flash)
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_23 = 8 | 0x10; // ALT1 = FLEXSPI2_A_DQS
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_24 = 8 | 0x10; // ALT1 = FLEXSPI2_A_SS0_B (RAM)
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_25 = 8 | 0x10; // ALT1 = FLEXSPI2_A_SCLK
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_26 = 8 | 0x10; // ALT1 = FLEXSPI2_A_DATA0
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_27 = 8 | 0x10; // ALT1 = FLEXSPI2_A_DATA1
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_28 = 8 | 0x10; // ALT1 = FLEXSPI2_A_DATA2
IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_29 = 8 | 0x10; // ALT1 = FLEXSPI2_A_DATA3
IOMUXC_FLEXSPI2_IPP_IND_DQS_FA_SELECT_INPUT = 1; // GPIO_EMC_23 for Mode: ALT8, pg 986
IOMUXC_FLEXSPI2_IPP_IND_IO_FA_BIT0_SELECT_INPUT = 1; // GPIO_EMC_26 for Mode: ALT8
IOMUXC_FLEXSPI2_IPP_IND_IO_FA_BIT1_SELECT_INPUT = 1; // GPIO_EMC_27 for Mode: ALT8
IOMUXC_FLEXSPI2_IPP_IND_IO_FA_BIT2_SELECT_INPUT = 1; // GPIO_EMC_28 for Mode: ALT8
IOMUXC_FLEXSPI2_IPP_IND_IO_FA_BIT3_SELECT_INPUT = 1; // GPIO_EMC_29 for Mode: ALT8
IOMUXC_FLEXSPI2_IPP_IND_SCK_FA_SELECT_INPUT = 1; // GPIO_EMC_25 for Mode: ALT8
But with the delay here the memtest works:
// initialize pins
delayMicroseconds(43); // psram memtest works with delay at this point.
Curious:)
mjs513
06-27-2020, 10:56 PM
Just saw b3 was released, right on schedule :)
Noticed Adafruit GFX was not auto installed with Teensyduino so remember to install it from library manager. It will auto install Adafruit BusIO as well which it now needs to run.
As a check ran SPIFFS_T4 Flashtest6 and extRAM_t4 structuredReadWrite sketches without issue. All tests passed.
Since I just installed GDB gave that a try as well with using simple_breakpoint, again no issue.
Using a T4.0 ran the ILI9488_FontTest4 without no conflicts with the new Adafruit_GFX library.
Silverlock
06-27-2020, 11:00 PM
Reran the test with Optimize Fast, Optimize Fastest and Smallest Code. All three worked. The only oddity I noticed was that under "Smallest Code" that the result line that usually reads something like " test ran for 36.65 seconds" read " test ran for seconds"; the number disappeared.
Just for the halibut, on the off, remote chance that the problem exists in the Linux x86 toolchain (I'm on ARM, defragster's on Windows), here's the HEX file produced on the rPi for 600MHz, Optimize Fast. If you unzip it and load the HEX file into the Teensy Loader and upload it and the same thing happens, at least you know you're not dealing with a toolchain issue.
defragster
06-27-2020, 11:17 PM
Curious:)
Indeed - where does the error show in running? - just changed to FAST from default FASTER.
No CORE mods to TD 1.53b3 install ... it works with twin PSRAMS as above with single and an IDLE QSPI Flash.
Found the production dual PSRAM T_4.1 as FAST:
EXTMEM Memory Test, 16 Mbyte
test ran for 72.51 seconds
same: dual PSRAM T_4.1 as FASTER - just a 0.9 sec slower:
test ran for 73.31 seconds
<EDIT>: The p#11 gave passed result with the ARM compiled HEX on the 16MB PSRAM T_4.1 with TLoader upload on Windows.
wwatson
06-27-2020, 11:47 PM
@Silverlock,
Thanks for the the download. I will upload and test without my mod's to startup.c. I do not have a windows machine so this will help verify the validity of the Linux compiler.
@defragster,
The error is this:
EXTMEM Memory Test, 0 Mbyte
Nothing else except the fast blinking LED on the T4.1 which I believe is an indication of an error.
I played with it some more and narrowed it down to this:
FLASHMEM void configure_external_ram()
// initialize pins
//delayMicroseconds(50); // psram memtest fails with delay at this point.
delayMicroseconds(50); // psram memtest works with delay at this point.
Works.
This does not work:
// initialize pins
//delayMicroseconds(50); // psram memtest works with delay at this point.
Got to make dinner for the grand kid now but will test (@Silverlock) the windows version after.
defragster
06-28-2020, 12:12 AM
@Silverlock,
@defragster,
The error is this:
The FAST BLINK is what shows here on T_4.1 with NO PSRAM.
That just says it failed to detect PSRAM?
uint8_t size = external_psram_size;
Serial.printf("EXTMEM Memory Test, %d Mbyte\n", size);
if (size == 0) return;
So it entered loop() before setting :: memory_ok = true;
Somehow your attached chip not passing the 'present' test as coded. Wonder if a quick reflow/clean of the PSRAM pins would change it and show the code wasn't needing tweaked - but rather 'a failure to communicate' properly that may cause trouble later?
Unless of course the provided ARM built HEX works ...
Silverlock
06-28-2020, 12:23 AM
And I'll be fairly surprised if that happens. My hunch is a marginal solder joint or a bit of flux where it oughtn't to be.
wwatson
06-28-2020, 12:57 AM
@Silverlock - The other build did not work.
I think you both are right. I will touch up the soldering and see what happens. I have two more T41's and more psram chips to solder up and test. Will probably just do one psram chip as I want to order flash chips and install those.
Thanks guys for your help:)
Edit: I will take a picture of the current soldering and post that for inspection.
The solder I am using is a 60/40 rosin core 18 gauge solder I got when I worked for Radio Shack years ago.
PaulStoffregen
06-28-2020, 05:10 AM
I loaded this hex file (from msg #11 (https://forum.pjrc.com/threads/61570-Teensyduino-1-53-Beta-3?p=244534&viewfull=1#post244534)) onto 4 different Teensy 4.1 boards. On every board it properly detected the external memory and all tests passed. One board had 2 memory chips. One had just 1 chip with the larger pads unused, and two had 1 RAM chip and 1 flash chip.
20777
PaulStoffregen
06-28-2020, 05:17 AM
This is normal. "Smallest Code" causes a smaller no-float printf() to be used from the C library. Omitting floating point support from printf() saves about 20K of code size. That's a really good trade-off when you need smaller code, especially on Teensy LC where there's only 62K of flash available. But it does mean you get nothing printed where %f is used with printf().
Ideally these sorts of example programs should use Arduino's Serial.print() only, which does support float printing in all optimization levels. But to be honest, I didn't even think of that when I wrote it. I was so focused at the time on checking whether the RAM chips were really working and giving people who've just soldered their chip a pretty through test program.
analog&RFmodels
06-28-2020, 09:11 AM
under win7pro64: uninstall arduino 1.8.5 (and teensyduino 1.52), install arduino 1.8.13, install teensyduino 1.53 beta 3,
compiled and ran just fine several programs each for TLC, T36, T4. some TLC and T36 pgms date back 2-2.5 years,
T4 from about time of intro. all compiles fine, all uploads fine, all runs fine, serial monitor working well and very snappy.
see no problems here.
PaulStoffregen
06-28-2020, 12:06 PM
Has anyone tried using the updated ADC library yet? It got a large number of lines edited, though much of it appears to be cleaning up white space.
Work fine for me, although synchronous ADC reads went from .78 usec to .79 usec per sample.
analog&RFmodels
06-28-2020, 06:33 PM
compiles using ADC library worked ok TLC, T35, T4. (of course using the new settings syntax i had to do for 1.52)
ala
adc->adc0->setAveraging(1);
etc
have not timed any ADC yet
analog&RFmodels
06-28-2020, 10:08 PM
did closer inspection of compile reports re ADC under 1.53 beta 3 and found something that is not an error,
not a warning, but i don't remember it from past releases. as per previous post TLC T36 T4 all compile and
run fine. all have this little funny in the compile listing - i have no idea if it is of any significance.
boiled down code for T4 is:
#include <ADC.h>
unsigned short int i,j,n;
unsigned int value1,value2;
ADC *adc = new ADC(); // adc object;
const int readPin = A0; // ADC0
const int readPin2 = A1; // ADC1
int main() {
Serial.begin(38400);
pinMode(readPin, INPUT);
pinMode(readPin2, INPUT);
pinMode(A10, INPUT); //Diff Channel 0 Positive
pinMode(A11, INPUT); //Diff Channel 0 Negative
adc->adc0->setResolution(12);
adc->adc0->setConversionSpeed(ADC_CONVERSION_SPEED::VERY_HIGH _SPEED);
adc->adc0->setSamplingSpeed(ADC_SAMPLING_SPEED::VERY_HIGH_SPE ED);
// comment next 4 lines for TLC
adc->adc1->setAveraging(1);
adc->adc1->setResolution(12);
adc->adc1->setConversionSpeed(ADC_CONVERSION_SPEED::VERY_HIGH _SPEED);
adc->adc1->setSamplingSpeed(ADC_SAMPLING_SPEED::VERY_HIGH_SPE ED);
loop:
value1 = adc->analogRead(readPin);
value2 = adc->analogRead(readPin2);
Serial.println(value1);
Serial.println(value2);
Serial.println(" ");
delay(2000);
goto loop;
part of compile listing that seems new is:
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/.............
Alternatives for ADC.h: [ADC@8.0]
ResolveLibrary(ADC.h)
-> candidates: [ADC@8.0]
entire compile listing is:
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Dell\Documents\Arduino\libraries -fqbn=teensy:avr:teensy40:usb=serial,speed=600,opt= o2std,keys=en-us -ide-version=10813 -build-path C:\Users\Dell\AppData\Local\Temp\arduino_build_518 865 -warnings=none -build-cache C:\Users\Dell\AppData\Local\Temp\arduino_cache_273 839 -verbose C:\Users\Dell\Documents\Arduino\libraries\arf1\arf 1.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Dell\Documents\Arduino\libraries -fqbn=teensy:avr:teensy40:usb=serial,speed=600,opt= o2std,keys=en-us -ide-version=10813 -build-path C:\Users\Dell\AppData\Local\Temp\arduino_build_518 865 -warnings=none -build-cache C:\Users\Dell\AppData\Local\Temp\arduino_cache_273 839 -verbose C:\Users\Dell\Documents\Arduino\libraries\arf1\arf 1.ino
Using board 'teensy40' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Using core 'teensy4' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy4" "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865\\sketch\\arf1.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ ADC" "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865\\sketch\\arf1.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ADC\AD C.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ADC\AD C_Module.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ADC\An alogBufferDMA.cpp
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ ADC" "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865\\sketch\\arf1.ino.cpp" -o "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865\\preproc\\ctags_target_for_gcc_minus_e.c pp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865\\preproc\\ctags_target_for_gcc_minus_e.c pp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/precompile_helper" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy4" "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy4" "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865/pch/Arduino.h" -o "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865/pch/Arduino.h.gch"
Using previously compiled file: C:\Users\Dell\AppData\Local\Temp\arduino_build_518 865\pch\Arduino.h.gch
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bu ild_518865/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ ADC" "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865\\sketch\\arf1.ino.cpp" -o "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865\\sketch\\arf1.ino.cpp.o"
Compiling libraries...
Compiling library "ADC"
Using previously compiled file: C:\Users\Dell\AppData\Local\Temp\arduino_build_518 865\libraries\ADC\AnalogBufferDMA.cpp.o
Using previously compiled file: C:\Users\Dell\AppData\Local\Temp\arduino_build_518 865\libraries\ADC\ADC_Module.cpp.o
Using previously compiled file: C:\Users\Dell\AppData\Local\Temp\arduino_build_518 865\libraries\ADC\ADC.cpp.o
Compiling core...
Using precompiled core: C:\Users\Dell\AppData\Local\Temp\arduino_cache_273 839\core\core_88a2d4dfef9509c3677628f3762a6fb0.a
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax "-TC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy4/imxrt1062.ld" -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865/arf1.ino.elf" "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865\\sketch\\arf1.ino.cpp.o" "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865\\libraries\\ADC\\ADC.cpp.o" "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865\\libraries\\ADC\\ADC_Module.cpp.o" "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865\\libraries\\ADC\\AnalogBufferDMA.cpp.o" "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865/..\\arduino_cache_273839\\core\\core_88a2d4dfef950 9c3677628f3762a6fb0.a" "-LC:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bu ild_518865" -larm_cortexM7lfsp_math -lm -lstdc++
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865/arf1.ino.elf" "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865/arf1.ino.eep"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865/arf1.ino.elf" "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865/arf1.ino.hex"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/stdout_redirect" "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865/arf1.ino.lst" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objdump" -d -S -C "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865/arf1.ino.elf"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/stdout_redirect" "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865/arf1.ino.sym" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objdump" -t -C "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865/arf1.ino.elf"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/teensy_post_compile" -file=arf1.ino "-path=C:\\Users\\Dell\\AppData\\Local\\Temp\\arduin o_build_518865" "-tools=C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/" -board=TEENSY40
Using library ADC at version 8.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ADC
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-size" -A "C:\\Users\\Dell\\AppData\\Local\\Temp\\arduino_bui ld_518865/arf1.ino.elf"
Sketch uses 50528 bytes (2%) of program storage space. Maximum is 2031616 bytes.
Global variables use 86708 bytes (16%) of dynamic memory, leaving 437580 bytes for local variables. Maximum is 524288 bytes.
PaulStoffregen
06-28-2020, 10:15 PM
Maybe you also upgraded Arduino to 1.8.13? This looks like some of the new stuff 1.8.13 prints as it tries to figure out which library you really meant to use.
analog&RFmodels
06-28-2020, 11:41 PM
thanks for the feedback
that is right - arduino 1.8.13 - since there is only one adc library in the teensy stuff i wonder why it had to think so hard
very annoying item 1.8.13 - the engineering computers here have never been nor ever will be connected to to the world -
and arduino often puts a warning in red in the bottom of the window that it failed to be able to go get some json file
at their website - when the day comes that arduino will not run unless it can connect home i will back up one version
and take what comes. Arduino says "have a nice day" i say "what if i don't want to have a nice day?"
is there wisdom in staying with 1.8.13 or is it wiser to go back to 1.8.5 ?
analog&RFmodels
06-29-2020, 12:13 AM
more on 1.8.13
maybe the guys at Arduino are ok after all - if you go into preferences and turn off
"check for updates on start", get out of Arduino, shut down windows, reboot
windows then that pesky message seems to go away - i hope forever. maybe
previous versions did not not default that to "on".
but i still wonder if it is better to use 1.8.5 which is very tried and true or to use
1.8.13 because it may have better features? any opinions?
defragster
06-29-2020, 12:46 AM
Check for updates at start was annoying and turned off here long ago.
I keep moving with the newest as TeensyDuino updates - seems to improve - especially the version after they screw something up :)
PaulStoffregen
06-29-2020, 01:33 AM
For use with Teensy on Linux & Windows & older MacOS, all the supported versions of Arduino are about the same. Use whichever you like. On the new MacOS Catalina, we're providing an all-in-one download where Arduino 1.8.13 is the only option.
On this thread, I'm really hoping to stay focused on 1 question: are there any remaining problems in 1.53-beta3 which need to be fixed before a final non-beta 1.53 release?
We can also chat at length about the Arduino software. But unless it's a bug in need of fixing for the 1.53 release, let's have that conversation on another thread.
defragster
06-29-2020, 06:04 AM
opps ... Meant to add on another thread ... I opened an ADC example and modified to read 8 pins fast and that worked on T_4.0 and T_4.1
Since then I plugged a (known to work before) Bluetooth dongle onto T_4.1 with USBHost and paired a mouse to work.
So not seeing any troubles in those things as far as build and run with new TD 1.53
mjs513
06-29-2020, 01:06 PM
more on 1.8.13
A simple solution to not checking the json is to go to "File => Preferences" and un-check the box that says "Check for updates on startup". That should prevent it from going to the internet to check the JSON.
phildubach
07-01-2020, 05:02 PM
I've been testing 1.53 beta 3 and have only found one issue related to Arduino 1.8.13:
One of the fixes in Arduino 1.8.13 is to once again allow libraries marked as 'precompiled' in the library properties
to contain a pre-compiled static library as well as wrapper source code to interface with that library. The
pre-compiled static library is an archive (*.a placed in a subfolder named after the target architecture). I'll call
it 'archive' to avoid confusion with the Arduino use of 'library'.
As it stands with Teensyduino 1.53 beta 3, those fixes made in Arduino builder do not take effect. The builder
finds the archives inside pre-compiled libraries and adds them to the {compiler.libraries.ldflags} property, but
that property is not used in the link pattern for Teensyduino. The result is that the wrapper source gets compiled,
but the archive does not get linked, hence the wrapper code contains calls to unknown symbols and linking fails.
The fix is a simple one: Add {compiler.libraries.ldflags} to the link (combine) pattern. Also, to avoid any issues
when there are no archives to be linked in, initialize {compiler.libraries.ldflags} to an empty string. This matches
the changes made to Arduino's own platform.txt.
Here is the corresponding change for AVR:
https://github.com/arduino/ArduinoCore-avr/commit/bca2493a5c68ba5c0a2c6963b462d917794bfb2d
And also for SAMD:
https://github.com/arduino/ArduinoCore-samd/commit/37c8d4f36a86824def2e16a6e3701a4b41ea0078
I have confirmed that changing platform.txt in teensyduino accordingly allows Arduino libraries with mixed
source and pre-compiled code to link.
Here's my diff:
--- hardware/teensy/avr/platform.txt 2020-07-01 08:53:42.503934820 -0700
+++ hardware/teensy/avr/platform.txt.orig 2020-07-01 08:43:42.707939006 -0700
@@ -6,7 +6,6 @@
compiler.path={runtime.hardware.path}/../tools/
compiler.objcopy.eep.flags=-O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0
compiler.elf2hex.flags=-O ihex -R .eeprom
-compiler.libraries.ldflags=
## Preprocessor Includes
recipe.preproc.includes="{compiler.path}{build.toolchain}{build.command.g++ }" -M -MG -MP -x c++ -w {build.flags.cpp} {build.flags.cpu} {build.flags.defs} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DF_CPU={build.fcpu} -D{build.usbtype} -DLAYOUT_{build.keylayout} {includes} "{source_file}"
@@ -35,7 +34,7 @@
recipe.ar.pattern="{compiler.path}{build.toolchain}{build.command.ar}" rcs "{archive_file_path}" "{object_file}"
## Link
-recipe.c.combine.pattern="{compiler.path}{build.toolchain}{build.command.lin ker}" {build.flags.optimize} {build.flags.ld} {build.flags.ldspecs} {build.flags.cpu} -o "{build.path}/{build.project_name}.elf" {object_files} {compiler.libraries.ldflags} "{build.path}/{archive_file}" "-L{build.path}" {build.flags.libs}
+recipe.c.combine.pattern="{compiler.path}{build.toolchain}{build.command.lin ker}" {build.flags.optimize} {build.flags.ld} {build.flags.ldspecs} {build.flags.cpu} -o "{build.path}/{build.project_name}.elf" {object_files} "{build.path}/{archive_file}" "-L{build.path}" {build.flags.libs}
## Patch ELF - TODO: not supported by Arduino 1.6.6 builder
recipe.elfpatch.pattern="{compiler.path}/hardware/tools/{build.elfpatch}" -mmcu={build.mcu} "{build.path}/{build.project_name}.elf" "{sketch_path}/disk"
bogdanabosaia
07-06-2020, 02:57 PM
I also tried TeensyDuino now, and they really corrected their mistakes.:rolleyes:
