Dear friends i made led matrix project with Teensy 4.0 ,SD card and ws2812 led strips.
Led matrix:
X = 66
Y = 32
Number of leds per strip 66.
Number of leds 2112.
Wiring of strips : ZIK-ZAK (serpentine,snake line).
I am using JINX software for led matrix animation control and everything working perfectly with serial connection.
I am using this code:
Output patch in Jinx is HS_TL (horisontal snake_top left).
This is the video:
https://www.youtube.com/watch?v=xCiRyM-FU_w
When i use SD card and myanim.dat file saved from Jinx glediator file recorder i have problem with patch its always oriented HL_TL (horisontal line_top left).
Problem is in recorded myanim.dat file
This is the code:
This is the video:
https://www.youtube.com/watch?v=P9BLpaFbk3k
Is there any way to solve this problem with new code exept to rewire my led matrix to HL_TL (horisontal line_top left ) led strips ?
Led matrix:
X = 66
Y = 32
#include <OctoWS2811.h>
//const int ledsPerStrip = 66;
//const int NUM_LEDS = 528;
#define LED_WIDTH 66 // number of LEDs horizontally
#define LED_HEIGHT 32 // number of LEDs vertically (must be multiple of
#define LED_LAYOUT 0
const int ledsPerStrip = LED_WIDTH * LED_HEIGHT / 8;
const int NUM_LEDS = 2112; //number of leds in matrix 2112
DMAMEM int displayMemory[ledsPerStrip*6];
int drawingMemory[ledsPerStrip*6];
const int config = WS2811_GRB | WS2811_800kHz;
OctoWS2811 leds(ledsPerStrip, displayMemory, drawingMemory, config);
leds.begin();
leds.show();
int serialGlediator() {
while (!Serial.available()) {}
return Serial.read();
byte r,g,b;
int i;
void loop(){
while (serialGlediator() != 1) {}
for (i=0; i < NUM_LEDS; i++){
b = serialGlediator();
r = serialGlediator();
g = serialGlediator();
leds.setPixel(i, Color(r,g,b));
leds.show();
/* Helper functions */ // Create a 24 bit color value from R,G,B
unsigned int Color(byte r, byte g, byte b) {
//Take the lowest 8 bits of each value and append them end to end
return( ((unsigned int)b & 0xFF )<<16 | ((unsigned int)r & 0xFF)<<8 | (unsigned int)g & 0xFF);}
This is the video:
This is the code:
// Glediator example with OctoWS2811, by mortonkopf
// [url]https://forum.pjrc.com/threads/33012-Gladiator-with-OctoWS2811-working-example[/url]
#define LED_WIDTH 66 // number of LEDs horizontally 65
#define LED_HEIGHT 32 // number of LEDs vertically (must be multiple of 32
#define LED_LAYOUT 0 //led rows left-right-left
//const int ledsPerStrip = 11;
const int NUM_LEDS = 2112; //number of leds in matrix 2080
File myfile;
// Use these for the SD+Wiz820 or other adaptors
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 11
#define SDCARD_SCK_PIN 13
// Use these with the Teensy 3.5 & 3.6 SD card
//#define SDCARD_CS_PIN BUILTIN_SDCARD
//#define SDCARD_MOSI_PIN 11 // not actually used
//#define SDCARD_SCK_PIN 13 // not actually used
// Use these with the Teensy Audio Shield
//#define SDCARD_CS_PIN 10
//#define SDCARD_MOSI_PIN 7
//#define SDCARD_SCK_PIN 14
leds.begin();
leds.show();
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
// stop here, but print a message repetitively
return;
Serial.println("sdcard initialization done.");
// test file open
myfile = SD.open("myanim.dat"); // read only
if (myfile) {
Serial.println("file open ok");
myfile.close();
int fileGlediator() {
return myfile.read();
byte r,g,b;
int i;
if (myfile) {
}else {
Serial.println("could not open the file! :(");
//SCB_AIRCR = 0x05FA0004; //command for restar teensy
while (myfile.available()) {
for (i=0; i < NUM_LEDS; i++) {
b = fileGlediator();
r = fileGlediator();
g = fileGlediator();
leds.show();
delay(50);
myfile.close();
This is the video:
