View Full Version : Teensyduino 1.54 Beta #1
Paul
10-22-2020, 06:24 PM
Here is a first beta test for Teensyduino 1.54.
Update: Teensy 4.1 is not working with this beta. ... published 1.54-beta2 to fix this problem (https://forum.pjrc.com/threads/64023-Teensyduino-1-54-Beta-2).
Edit: Links removed. Please use 1.54-beta2
Changes since Teensyduino 1.53: (rough draft... will fill in details soon)
Support for MicroMod
Fix SPI with DAM to cached memory on Teensy 4.x
Support alternate Wire3 pins on Teensy 4.1
Improve map() function
Show Serial.printf format warnings
Fixes for HAB secure boot
Update imxrt.h comments for RT1060 Reference Manual, Rev 2
AsyncAudioInputSPDIF3 bugs fixed
synth_tonesweep update?
NativeEthernet & FNET update
ILI9341_t3
QuadEncoder
RadioHead
ST7735_t3
USBHost_t36
XPT2046_Touchscreen
Wait up to 6.2 seconds for Teensy to reboot (was 5 seconds)
KurtE
10-22-2020, 07:29 PM
Good Morning Paul,
I installed the beta Windows 10 64 bit on a clean install of Arduino 1.8.13 (renamed old, and unzipped the arduino zip file...) I installed the beta....
Then first attempt, I tried to reprogram a T4.1 with blink...
And the Blink compiled correctly then tried to download to T4.1, looks like it did, but it is not blinking. And System does not see the Teensy...
Verbose Info
11:15:42.609 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
11:15:42.610 (ports 5): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#000bb967#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
11:15:42.610 (ports 5): found_usb_device, loc=usb:0/140000/0/1/1/2 Port_#0002.Hub_#0007
11:15:42.610 (ports 5): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0105
11:15:42.610 (ports 5): found_usb_device, devinst=00000011
11:15:42.610 (ports 5): add: loc=usb:0/140000/0/1/1/2, class=HID, vid=16C0, pid=0478, ver=0105, serial=000bb967, dev=\\?\usb#vid_16c0&pid_0478#000bb967#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
11:15:42.610 (ports 5): hiddev_from_devinst_list: iface=0
11:15:42.610 (ports 5): found_usb_device complete
11:15:42.611 (ports 5): usb_add: usb:0/140000/0/1/1/2 [no_device] (Teensy) Bootloader
11:15:42.623 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
11:15:42.624 (ports 5): update_usb_device, devinst list change, old had 1, new has 2
11:15:42.624 (ports 5): hiddev_from_devinst_list: iface=0
11:15:42.625 (ports 5): hid, found devinst=00000012
11:15:42.625 (ports 5): hid, path=\\?\hid#vid_16c0&pid_0478#6&32e5b844&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
11:15:42.625 (ports 5): hid, opened handle
11:15:42.625 (ports 5): devinst=00000012, location=usb:0/140000/0/1/1/2
11:15:42.625 (ports 5): vid=16C0, pid=0478, ver=0105, usepage=FF9C, use=0025
11:15:42.625 (ports 5): devpath=\\?\hid#vid_16c0&pid_0478#6&32e5b844&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
11:15:42.625 (ports 5): usb_add: usb:0/140000/0/1/1/2 hid#vid_16c0&pid_0478 (Teensy 4.1) Bootloader
11:15:42.673 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
11:15:42.674 (ports 5): nothing new, skipping HID & Ports enum
11:15:46.294 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
11:15:46.295 (ports 5): remove: loc=usb:0/140000/0/1/1/2
11:15:46.295 (ports 5): usb_remove: usb:0/140000/0/1/1/2
11:15:46.295 (ports 5): nothing new, skipping HID & Ports enum
11:15:46.316 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
11:15:46.317 (ports 5): nothing new, skipping HID & Ports enum
11:15:47.933 (ports 5): purge, name=hid#vid_16c0&pid_0478 (Teensy 4.1) Bootloader, loc=usb:0/140000/0/1/1/2, age=1.638 sec
11:16:29.549 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
11:16:29.550 (ports 5): found_usb_device, id=\\?\usb#vid_16c0&pid_0486#7683590#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
11:16:29.550 (ports 5): found_usb_device, loc=usb:0/140000/0/1/1/2 Port_#0002.Hub_#0007
11:16:29.550 (ports 5): found_usb_device, hwid=USB\VID_16C0&PID_0486&REV_0280
11:16:29.550 (ports 5): found_usb_device, devinst=00000017
11:16:29.550 (ports 5): add: loc=usb:0/140000/0/1/1/2, class=USB, vid=16C0, pid=0486, ver=0280, serial=7683590, dev=\\?\usb#vid_16c0&pid_0486#7683590#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
11:16:29.550 (ports 5): hiddev_from_devinst_list: iface=1
11:16:29.551 (ports 5): found_usb_device complete
11:16:29.552 (ports 5): usb_add: usb:0/140000/0/1/1/2 [no_device] (Teensy 4.1) RawHID
11:16:29.598 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
11:16:29.599 (ports 5): update_usb_device, devinst list change, old had 2, new has 5
11:16:29.599 (ports 5): hiddev_from_devinst_list: iface=1
11:16:29.599 (ports 5): 0000001B: path=\\?\hid#vid_16c0&pid_0486&mi_01#7&bf2fae6&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
11:16:29.600 (ports 5): hid, found devinst=00000019
11:16:29.600 (ports 5): hid, found devinst=0000001B
11:16:29.600 (ports 5): usb_add: usb:0/140000/0/1/1/2 hid#vid_16c0&pid_0486 (Teensy 4.1) RawHID
11:16:50.739 (post_compile 1): Begin, version=1.54-beta1, high-res time
11:16:50.960 (loader): Teensy Loader 1.54-beta1, begin program
11:16:51.070 (loader): File "Blink.ino.hex". 17352 bytes, 0% used
11:16:51.085 (loader): Listening for remote control on port 3149
11:16:51.086 (loader): initialized, showing main window
11:16:51.180 (loader): remote connection 1352 opened
11:16:51.181 (loader): remote cmd from 1352: "comment: Teensyduino 1.54-beta1 - WINDOWS (teensy_post_compile)"
11:16:51.181 (loader): remote cmd from 1352: "status"
11:16:51.181 (post_compile 1): Sending command: comment: Teensyduino 1.54-beta1 - WINDOWS (teensy_post_compile)
11:16:51.316 (loader): HID/win32: vid:16C0 pid:0486 ver:0280
11:16:51.317 (loader): HID/win32: vid:0A5C pid:8502 ver:0000
11:16:51.318 (loader): HID/win32: vid:0A5C pid:8502 ver:0000
11:16:51.319 (loader): remote cmd from 1352: "dir:C:\Users\kurte\AppData\Local\Temp\arduino_buil d_323971\"
11:16:51.320 (post_compile 1): Status: 1, 0, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_32 3971\, Blink.ino.hex
11:16:51.320 (post_compile 1): Sending command: dir:C:\Users\kurte\AppData\Local\Temp\arduino_buil d_323971\
11:16:51.321 (post_compile 1): Sending command: file:Blink.ino.hex
11:16:51.321 (loader): remote cmd from 1352: "file:Blink.ino.hex"
11:16:51.331 (loader): File "Blink.ino.hex". 17352 bytes, 0% used
11:16:51.336 (loader): remote cmd from 1352: "status"
11:16:51.338 (loader): remote cmd from 1352: "auto:on"
11:16:51.338 (post_compile 1): Status: 1, 0, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_32 3971\, Blink.ino.hex
11:16:51.338 (post_compile 1): Sending command: auto:on
11:16:51.339 (post_compile 1): Disconnect
11:16:51.350 (loader): remote connection 1352 closed
11:16:51.544 (post_compile 2): Begin, version=1.54-beta1, high-res time
11:16:51.546 (loader): remote connection 1136 opened
11:16:51.547 (post_compile 2): Sending command: comment: Teensyduino 1.54-beta1 - WINDOWS (teensy_post_compile)
11:16:51.547 (loader): remote cmd from 1136: "comment: Teensyduino 1.54-beta1 - WINDOWS (teensy_post_compile)"
11:16:51.547 (loader): remote cmd from 1136: "status"
11:16:51.549 (loader): remote cmd from 1136: "dir:C:\Users\kurte\AppData\Local\Temp\arduino_buil d_323971\"
11:16:51.549 (loader): remote cmd from 1136: "file:Blink.ino.hex"
11:16:51.549 (post_compile 2): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_32 3971\, Blink.ino.hex
11:16:51.549 (post_compile 2): Sending command: dir:C:\Users\kurte\AppData\Local\Temp\arduino_buil d_323971\
11:16:51.550 (post_compile 2): Sending command: file:Blink.ino.hex
11:16:51.559 (loader): File "Blink.ino.hex". 17352 bytes, 0% used
11:16:51.565 (loader): remote cmd from 1136: "status"
11:16:51.567 (post_compile 2): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_32 3971\, Blink.ino.hex
11:16:51.567 (post_compile 2): Disconnect
11:16:51.579 (loader): remote connection 1136 closed
11:16:51.579 (loader): remote connection 1424 opened
11:16:51.579 (post_compile 3): Running teensy_reboot: "C:\arduino-1.8.13\hardware\teensy\..\tools\teensy_reboot.exe" teensy_reboot.exe "-board=TEENSY41" "-port=usb:0/140000/0/1/1/2" "-portlabel=hid#vid_16c0&pid_0478 Bootloader" "-portprotocol=Teensy"
11:16:51.600 (reboot 4): Begin, version=1.54-beta1, high-res time
11:16:51.600 (reboot 4): location = usb:0/140000/0/1/1/2
11:16:51.600 (reboot 4): portlabel = hid#vid_16c0&pid_0478 Bootloader
11:16:51.600 (reboot 4): Only location usb:0/140000/0/1/1/2 will be tried
11:16:51.600 (reboot 4): portprotocol = Teensy
11:16:51.600 (reboot 4): LoadLibrary cfgmgr32 ok
11:16:51.600 (reboot 4): LoadLibrary ntdll ok
11:16:51.601 (reboot 4): found_usb_device, id=\\?\usb#vid_16c0&pid_0486#7683590#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
11:16:51.601 (reboot 4): found_usb_device, loc=usb:0/140000/0/1/1/2 Port_#0002.Hub_#0007
11:16:51.601 (reboot 4): found_usb_device, hwid=USB\VID_16C0&PID_0486&REV_0280
11:16:51.601 (reboot 4): found_usb_device, devinst=00000001
11:16:51.601 (reboot 4): add: loc=usb:0/140000/0/1/1/2, class=USB, vid=16C0, pid=0486, ver=0280, serial=7683590, dev=\\?\usb#vid_16c0&pid_0486#7683590#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
11:16:51.601 (reboot 4): hiddev_from_devinst_list: iface=1
11:16:51.602 (reboot 4): 0000000C: path=\\?\hid#vid_16c0&pid_0486&mi_01#7&bf2fae6&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
11:16:51.603 (reboot 4): found_usb_device complete
11:16:51.603 (reboot 4): hid, found devinst=0000000A
11:16:51.603 (reboot 4): hid, found devinst=0000000C
11:16:51.606 (loader): remote connection 1352 opened
11:16:51.606 (loader): remote cmd from 1352: "show:arduino_attempt_reboot"
11:16:51.606 (loader): got request to show arduino rebooting message
11:16:51.606 (reboot 4): found Teensy Loader, version 1.54
11:16:51.606 (reboot 4): Sending command: show:arduino_attempt_reboot
11:16:51.608 (loader): remote cmd from 1352: "comment: Teensyduino 1.54-beta1 - WINDOWS (teensy_reboot)"
11:16:51.608 (loader): remote cmd from 1352: "status"
11:16:51.608 (reboot 4): Sending command: comment: Teensyduino 1.54-beta1 - WINDOWS (teensy_reboot)
11:16:51.610 (loader): remote cmd from 1352: "status"
11:16:51.610 (reboot 4): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_32 3971\, Blink.ino.hex
11:16:51.610 (reboot 4): hid_send_feature
11:16:51.612 (reboot 4): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_32 3971\, Blink.ino.hex
11:16:51.612 (reboot 4): status read, retry 0
11:16:51.619 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
11:16:51.620 (loader): remote connection 1428 opened
11:16:51.626 (ports 5): remove: loc=usb:0/140000/0/1/1/2
11:16:51.626 (ports 5): usb_remove: usb:0/140000/0/1/1/2
11:16:51.626 (ports 5): nothing new, skipping HID & Ports enum
11:16:51.630 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
11:16:51.631 (ports 5): nothing new, skipping HID & Ports enum
11:16:51.688 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
11:16:51.689 (ports 5): nothing new, skipping HID & Ports enum
11:16:51.713 (loader): remote cmd from 1352: "status"
11:16:51.715 (reboot 4): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_32 3971\, Blink.ino.hex
11:16:51.715 (reboot 4): status read, retry 1
11:16:51.816 (loader): remote cmd from 1352: "status"
11:16:51.818 (reboot 4): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_32 3971\, Blink.ino.hex
11:16:51.818 (reboot 4): status read, retry 2
11:16:51.883 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
11:16:51.884 (ports 5): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#000bb967#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
11:16:51.884 (ports 5): found_usb_device, loc=usb:0/140000/0/1/1/2 Port_#0002.Hub_#0007
11:16:51.884 (ports 5): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0105
11:16:51.884 (ports 5): found_usb_device, devinst=00000011
11:16:51.884 (ports 5): add: loc=usb:0/140000/0/1/1/2, class=HID, vid=16C0, pid=0478, ver=0105, serial=000bb967, dev=\\?\usb#vid_16c0&pid_0478#000bb967#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
11:16:51.885 (ports 5): hiddev_from_devinst_list: iface=0
11:16:51.885 (ports 5): found_usb_device complete
11:16:51.886 (ports 5): hid, found devinst=00000012
11:16:51.886 (ports 5): hid, path=\\?\hid#vid_16c0&pid_0478#6&32e5b844&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
11:16:51.886 (ports 5): hid, opened handle
11:16:51.886 (ports 5): devinst=00000012, location=usb:0/140000/0/1/1/2
11:16:51.886 (ports 5): vid=16C0, pid=0478, ver=0105, usepage=FF9C, use=0025
11:16:51.886 (ports 5): devpath=\\?\hid#vid_16c0&pid_0478#6&32e5b844&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
11:16:51.886 (ports 5): usb_add: usb:0/140000/0/1/1/2 hid#vid_16c0&pid_0478 (Teensy 4.1) Bootloader
11:16:51.894 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
11:16:51.895 (ports 5): nothing new, skipping HID & Ports enum
11:16:51.918 (loader): remote cmd from 1352: "status"
11:16:51.919 (loader): Device came online, code_size = 8126464
11:16:51.919 (loader): Board is: Teensy 4.1 (IMXRT1062), version 1.05
11:16:51.930 (loader): File "Blink.ino.hex". 17352 bytes, 0% used
11:16:51.933 (loader): set background IMG_ONLINE
11:16:51.949 (loader): File "Blink.ino.hex". 17352 bytes, 0% used
11:16:51.950 (loader): elf appears to be for Teensy 4.1 (IMXRT1062) (8126464 bytes)
11:16:51.950 (loader): elf binary data matches hex file
11:16:51.951 (loader): elf file is for Teensy 4.1 (IMXRT1062)
11:16:51.951 (loader): begin operation
11:16:51.963 (reboot 4): Status: 1, 1, 1, 1, 0, 1, C:\Users\kurte\AppData\Local\Temp\arduino_build_32 3971\, Blink.ino.hex
11:16:51.969 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
11:16:51.970 (ports 5): nothing new, skipping HID & Ports enum
11:16:51.972 (loader): flash, block=0, bs=1024, auto=1
11:16:51.972 (loader): gauge old value = 0
11:16:51.972 (loader): flash, block=1, bs=1024, auto=1
11:16:52.186 (loader): gauge old value = 1
11:16:52.187 (loader): remote cmd from 1352: "status"
11:16:52.189 (loader): flash, block=2, bs=1024, auto=1
11:16:52.189 (loader): gauge old value = 2
11:16:52.189 (loader): flash, block=3, bs=1024, auto=1
11:16:52.189 (reboot 4): Status: 1, 1, 1, 1, 0, 1, C:\Users\kurte\AppData\Local\Temp\arduino_build_32 3971\, Blink.ino.hex
11:16:52.190 (loader): gauge old value = 3
11:16:52.190 (loader): flash, block=4, bs=1024, auto=1
11:16:52.190 (loader): gauge old value = 4
11:16:52.209 (loader): flash, block=5, bs=1024, auto=1
11:16:52.209 (loader): gauge old value = 5
11:16:52.212 (loader): flash, block=6, bs=1024, auto=1
11:16:52.213 (loader): gauge old value = 6
11:16:52.219 (loader): flash, block=7, bs=1024, auto=1
11:16:52.219 (loader): gauge old value = 7
11:16:52.222 (loader): flash, block=8, bs=1024, auto=1
11:16:52.222 (loader): gauge old value = 8
11:16:52.224 (loader): flash, block=9, bs=1024, auto=1
11:16:52.224 (loader): gauge old value = 9
11:16:52.226 (loader): flash, block=10, bs=1024, auto=1
11:16:52.226 (loader): gauge old value = 10
11:16:52.228 (loader): flash, block=11, bs=1024, auto=1
11:16:52.228 (loader): gauge old value = 11
11:16:52.230 (loader): flash, block=12, bs=1024, auto=1
11:16:52.230 (loader): gauge old value = 12
11:16:52.232 (loader): flash, block=13, bs=1024, auto=1
11:16:52.233 (loader): gauge old value = 13
11:16:52.234 (loader): flash, block=14, bs=1024, auto=1
11:16:52.235 (loader): gauge old value = 14
11:16:52.236 (loader): flash, block=15, bs=1024, auto=1
11:16:52.236 (loader): gauge old value = 15
11:16:52.238 (loader): flash, block=16, bs=1024, auto=1
11:16:52.238 (loader): gauge old value = 16
11:16:52.252 (loader): sending reboot
11:16:52.252 (loader): begin wait_until_offline
11:16:52.258 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
11:16:52.259 (ports 5): remove: loc=usb:0/140000/0/1/1/2
11:16:52.259 (ports 5): usb_remove: usb:0/140000/0/1/1/2
11:16:52.259 (ports 5): nothing new, skipping HID & Ports enum
11:16:52.303 (loader): offline, waited 1
11:16:52.303 (loader): end operation, total time = 0.352 seconds
11:16:52.304 (loader): set background IMG_REBOOT_OK
11:16:52.307 (loader): redraw timer set, image 14 to show for 1200 ms
11:16:52.307 (loader): remote cmd from 1352: "status"
11:16:52.308 (loader): HID/win32: vid:0A5C pid:8502 ver:0000
11:16:52.309 (reboot 4): Status: 1, 1, 0, 1, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_32 3971\, Blink.ino.hex
11:16:52.309 (reboot 4): status read, retry 3
11:16:52.309 (reboot 4): Disconnect
11:16:52.309 (reboot 4): Success
11:16:52.313 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
11:16:52.313 (ports 5): nothing new, skipping HID & Ports enum
11:16:52.324 (loader): remote connection 1352 closed
11:16:52.326 (loader): remote connection 1424 closed
11:16:53.498 (loader): redraw, image 9
11:16:53.928 (ports 5): purge, name=hid#vid_16c0&pid_0478 (Teensy 4.1) Bootloader, loc=usb:0/140000/0/1/1/2, age=1.670 sec
11:20:07.838 (loader): Verbose Info event
I can unplug it and plug it back and it still does not see it... I can do the hold the program button down and get it to go back to default program.
T4 appeared to program fine.
Note: T4.1 with issue has two PSRAM chips on it.
Tried again with fresh just out of the bag T4.1 same issue. Will try again
defragster
10-22-2020, 07:48 PM
@Paul - did you pull the WIN EXE? My machine cannot get it. First attempt started and halted? ... waited ... Now I can see folder and the exe - but download won't start?
Other WWW stuff works - amybe AT&T is mising something ?
KurtE
10-22-2020, 07:56 PM
Paul quick update,
Tried also on Ubuntu 20.04 64 bit,
Again tried T4.1 with blink (slightly edited 1000->250 as to see difference in blink. Again it programmed a T4.1 (dual PSRAM), After I did the hold program button until it reflashed...
Then Teensy programmed the board and then no blink... Also Ubuntu put up an Error screen:
Sorry, Ubuntu 20.04 has experienced an internal error.
Send problem report to the developers? ...
Not sure if it would help but it does not look like I can select the text to send...
So here is some dmesg stuff
kurt@kurt-XPS-8300:~$ dmesg | tail -40
[ 197.127467] audit: type=1400 audit(1603392216.426:102): apparmor="DENIED" operation="open" profile="snap.snap-store.ubuntu-software" name="/var/lib/snapd/hostfs/usr/share/mime/mime.cache" pid=2493 comm="pool-org.gnome." requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 249.461684] kauditd_printk_skb: 6 callbacks suppressed
[ 249.461688] audit: type=1400 audit(1603392268.761:109): apparmor="DENIED" operation="open" profile="snap.snap-store.ubuntu-software" name="/var/lib/snapd/hostfs/usr/share/mime/mime.cache" pid=2493 comm="pool-org.gnome." requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 249.461696] audit: type=1400 audit(1603392268.761:110): apparmor="DENIED" operation="open" profile="snap.snap-store.ubuntu-software" name="/var/lib/snapd/hostfs/usr/share/mime/globs2" pid=2493 comm="pool-org.gnome." requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 249.461722] audit: type=1400 audit(1603392268.761:111): apparmor="DENIED" operation="open" profile="snap.snap-store.ubuntu-software" name="/var/lib/snapd/hostfs/usr/share/mime/magic" pid=2493 comm="pool-org.gnome." requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 249.461742] audit: type=1400 audit(1603392268.761:112): apparmor="DENIED" operation="open" profile="snap.snap-store.ubuntu-software" name="/var/lib/snapd/hostfs/usr/share/mime/aliases" pid=2493 comm="pool-org.gnome." requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 249.461760] audit: type=1400 audit(1603392268.761:113): apparmor="DENIED" operation="open" profile="snap.snap-store.ubuntu-software" name="/var/lib/snapd/hostfs/usr/share/mime/subclasses" pid=2493 comm="pool-org.gnome." requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 249.461779] audit: type=1400 audit(1603392268.761:114): apparmor="DENIED" operation="open" profile="snap.snap-store.ubuntu-software" name="/var/lib/snapd/hostfs/usr/share/mime/icons" pid=2493 comm="pool-org.gnome." requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 249.461797] audit: type=1400 audit(1603392268.761:115): apparmor="DENIED" operation="open" profile="snap.snap-store.ubuntu-software" name="/var/lib/snapd/hostfs/usr/share/mime/generic-icons" pid=2493 comm="pool-org.gnome." requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 250.591944] audit: type=1400 audit(1603392269.893:116): apparmor="DENIED" operation="open" profile="snap.snap-store.ubuntu-software" name="/var/lib/snapd/hostfs/usr/share/icons/Yaru/icon-theme.cache" pid=2493 comm="pool-org.gnome." requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 250.591951] audit: type=1400 audit(1603392269.893:117): apparmor="DENIED" operation="open" profile="snap.snap-store.ubuntu-software" name="/var/lib/snapd/hostfs/usr/share/icons/Yaru/8x8/emblems/" pid=2493 comm="pool-org.gnome." requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 250.594077] audit: type=1400 audit(1603392269.893:118): apparmor="DENIED" operation="open" profile="snap.snap-store.ubuntu-software" name="/var/lib/snapd/hostfs/usr/share/icons/Yaru/icon-theme.cache" pid=2493 comm="pool-org.gnome." requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 271.493528] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211: txop exceeded phylen 153/256 dur 1730/1504
[ 388.548810] usb 1-1.4.3: new high-speed USB device number 7 using ehci-pci
[ 388.657693] usb 1-1.4.3: New USB device found, idVendor=16c0, idProduct=0483, bcdDevice= 2.80
[ 388.657694] usb 1-1.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 388.657695] usb 1-1.4.3: Product: USB Serial
[ 388.657696] usb 1-1.4.3: Manufacturer: Teensyduino
[ 388.657697] usb 1-1.4.3: SerialNumber: 7683590
[ 388.728717] cdc_acm 1-1.4.3:1.0: ttyACM0: USB ACM device
[ 388.728913] usbcore: registered new interface driver cdc_acm
[ 388.728914] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 394.724650] usb 1-1.4.3: USB disconnect, device number 7
[ 438.211731] usb 1-1.4.3: new high-speed USB device number 8 using ehci-pci
[ 438.320582] usb 1-1.4.3: New USB device found, idVendor=16c0, idProduct=0486, bcdDevice= 2.80
[ 438.320584] usb 1-1.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 438.320585] usb 1-1.4.3: Product: Teensyduino RawHID
[ 438.320585] usb 1-1.4.3: Manufacturer: Teensyduino
[ 438.320586] usb 1-1.4.3: SerialNumber: 7683590
[ 438.321453] hid-generic 0003:16C0:0486.0006: hiddev0,hidraw5: USB HID v1.11 Device [Teensyduino Teensyduino RawHID] on usb-0000:00:1a.0-1.4.3/input0
[ 438.322078] hid-generic 0003:16C0:0486.0007: hidraw6: USB HID v1.11 Device [Teensyduino Teensyduino RawHID] on usb-0000:00:1a.0-1.4.3/input1
[ 497.380003] usb 1-1.4.3: USB disconnect, device number 8
[ 497.722314] usb 1-1.4.3: new high-speed USB device number 9 using ehci-pci
[ 497.830909] usb 1-1.4.3: New USB device found, idVendor=16c0, idProduct=0478, bcdDevice= 1.05
[ 497.830921] usb 1-1.4.3: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 497.830923] usb 1-1.4.3: SerialNumber: 000BB967
[ 497.832218] hid-generic 0003:16C0:0478.0008: hidraw5: USB HID v1.11 Device [HID 16c0:0478] on usb-0000:00:1a.0-1.4.3/input0
[ 498.404007] usb 1-1.4.3: USB disconnect, device number 9
[ 501.432956] show_signal: 3153 callbacks suppressed
[ 501.432960] traps: tracker-extract[5316] general protection fault ip:7f9440dc446d sp:7ffc2f03e170 error:0 in libglib-2.0.so.0.6400.3[7f9440d70000+84000]
defragster
10-22-2020, 08:33 PM
... restarted ... downloading now ...
defragster
10-22-2020, 09:14 PM
Into Fresh 1.8.13 folder TD 1.54b1 installed. Using IDE tools.
T_4.0 no problem with blink and blinkWithoutDelay upload and edit Upload.
T_4.1 online to start - then never programs - even button.
Repowering the T_4.1 does not start or show online at all.
Here is a verbose log:
13:08:47.525 (ports 2): callback C11E
13:08:49.549 (ports 2): callback C11E
13:08:51.565 (ports 2): callback C11E
13:08:53.581 (ports 2): callback C11E
13:08:55.597 (ports 2): callback C11E
13:08:57.618 (ports 2): callback C11E
13:08:59.278 (loader): file changed
13:08:59.648 (ports 2): callback C11E
13:09:00.275 (loader): file changed
13:09:00.297 (loader): File "BlinkWithoutDelay.ino.hex". 17364 bytes, 0% used
13:09:00.329 (post_compile 27): Begin, version=1.54-beta1, high-res time
13:09:00.333 (loader): remote connection 1656 opened
13:09:00.335 (loader): remote cmd from 1656: "comment: Teensyduino 1.54-beta1 - WINDOWS (teensy_post_compile)"
13:09:00.336 (post_compile 27): Sending command: comment: Teensyduino 1.54-beta1 - WINDOWS (teensy_post_compile)
13:09:00.338 (loader): remote cmd from 1656: "status"
13:09:00.341 (post_compile 27): Status: 1, 0, 1, 6, 0, 0, T:\TEMP\arduino_build_624832\, BlinkWithoutDelay.ino.hex
13:09:00.341 (post_compile 27): Sending command: dir:T:\TEMP\arduino_build_624832\
13:09:00.341 (loader): remote cmd from 1656: "dir:T:\TEMP\arduino_build_624832\"
13:09:00.343 (post_compile 27): Sending command: file:BlinkWithoutDelay.ino.hex
13:09:00.343 (loader): remote cmd from 1656: "file:BlinkWithoutDelay.ino.hex"
13:09:00.354 (loader): File "BlinkWithoutDelay.ino.hex". 17364 bytes, 0% used
13:09:00.358 (loader): remote cmd from 1656: "status"
13:09:00.360 (post_compile 27): Status: 1, 0, 1, 6, 0, 0, T:\TEMP\arduino_build_624832\, BlinkWithoutDelay.ino.hex
13:09:00.360 (post_compile 27): Disconnect
13:09:00.388 (loader): remote connection 1656 closed
13:09:00.580 (loader): remote connection 1636 opened
13:09:00.580 (loader): remote cmd from 1636: "comment: Teensyduino 1.54-beta1 - WINDOWS (teensy_post_compile)"
13:09:00.580 (loader): remote cmd from 1636: "status"
13:09:00.586 (post_compile 28): Begin, version=1.54-beta1, high-res time
13:09:00.592 (post_compile 28): Sending command: comment: Teensyduino 1.54-beta1 - WINDOWS (teensy_post_compile)
13:09:00.596 (post_compile 28): Status: 1, 0, 1, 6, 0, 0, T:\TEMP\arduino_build_624832\, BlinkWithoutDelay.ino.hex
13:09:00.596 (post_compile 28): Sending command: dir:T:\TEMP\arduino_build_624832\
13:09:00.596 (loader): remote cmd from 1636: "dir:T:\TEMP\arduino_build_624832\"
13:09:00.596 (loader): remote cmd from 1636: "file:BlinkWithoutDelay.ino.hex"
13:09:00.596 (loader): File "BlinkWithoutDelay.ino.hex". 17364 bytes, 0% used
13:09:00.598 (post_compile 28): Sending command: file:BlinkWithoutDelay.ino.hex
13:09:00.612 (loader): remote cmd from 1636: "status"
13:09:00.615 (post_compile 28): Status: 1, 0, 1, 6, 0, 0, T:\TEMP\arduino_build_624832\, BlinkWithoutDelay.ino.hex
13:09:00.615 (post_compile 28): Disconnect
13:09:00.627 (loader): remote connection 1636 closed
13:09:00.627 (loader): remote connection 1636 opened
13:09:00.628 (post_compile 29): Running teensy_reboot: "T:\arduino-1.8.13_t54\hardware\teensy\..\tools\teensy_reboot. exe" teensy_reboot.exe "-board=TEENSY41" "-port=usb:0/140000/0/5/4" "-portlabel=hid#vid_16c0&pid_0478 Bootloader" "-portprotocol=Teensy"
13:09:00.651 (reboot 30): Begin, version=1.54-beta1, high-res time
13:09:00.651 (reboot 30): location = usb:0/140000/0/5/4
13:09:00.651 (reboot 30): portprotocol = Teensy
13:09:00.651 (reboot 30): portlabel = hid#vid_16c0&pid_0478 Bootloader
13:09:00.651 (reboot 30): Only location usb:0/140000/0/5/4 will be tried
13:09:00.651 (reboot 30): LoadLibrary cfgmgr32 ok
13:09:00.651 (reboot 30): LoadLibrary ntdll ok
13:09:00.654 (reboot 30): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#000bb99e#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
13:09:00.654 (reboot 30): found_usb_device, loc=usb:0/140000/0/5/4 Port_#0004.Hub_#0006
13:09:00.654 (reboot 30): found_usb_device, devinst=00000003
13:09:00.654 (reboot 30): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0105
13:09:00.654 (reboot 30): add: loc=usb:0/140000/0/5/4, class=HID, vid=16C0, pid=0478, ver=0105, serial=000bb99e, dev=\\?\usb#vid_16c0&pid_0478#000bb99e#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
13:09:00.654 (reboot 30): hiddev_from_devinst_list: iface=0
13:09:00.657 (reboot 30): found_usb_device complete
13:09:00.657 (reboot 30): hid, found devinst=0000000B
13:09:00.658 (loader): remote connection 1632 opened
13:09:00.658 (loader): remote cmd from 1632: "show:arduino_attempt_reboot"
13:09:00.658 (loader): got request to show arduino rebooting message
13:09:00.658 (loader): remote cmd from 1632: "comment: Teensyduino 1.54-beta1 - WINDOWS (teensy_reboot)"
13:09:00.658 (loader): remote cmd from 1632: "status"
13:09:00.658 (loader): remote cmd from 1632: "auto:on"
13:09:00.664 (reboot 30): found Teensy Loader, version 1.54
13:09:00.664 (reboot 30): Sending command: show:arduino_attempt_reboot
13:09:00.669 (reboot 30): Sending command: comment: Teensyduino 1.54-beta1 - WINDOWS (teensy_reboot)
13:09:00.673 (reboot 30): Status: 1, 0, 1, 6, 0, 0, T:\TEMP\arduino_build_624832\, BlinkWithoutDelay.ino.hex
13:09:00.673 (reboot 30): send: auto:on
13:09:00.673 (reboot 30): Sending command: auto:on
13:09:00.674 (loader): File "BlinkWithoutDelay.ino.hex". 17364 bytes, 0% used
13:09:00.674 (loader): elf appears to be for Teensy 4.1 (IMXRT1062) (8126464 bytes)
13:09:00.674 (loader): elf binary data matches hex file
13:09:00.674 (loader): elf file is for Teensy 4.1 (IMXRT1062)
13:09:00.675 (reboot 30): Disconnect
13:09:00.692 (loader): begin operation
13:09:00.708 (loader): remote connection 1632 closed
13:09:00.708 (loader): remote connection 1636 closed
13:09:00.725 (loader): flash, block=0, bs=1024, auto=1
13:09:00.728 (loader): gauge old value = 0
13:09:00.730 (loader): flash, block=1, bs=1024, auto=1
13:09:00.946 (loader): gauge old value = 1
13:09:00.962 (loader): flash, block=2, bs=1024, auto=1
13:09:00.962 (loader): gauge old value = 2
13:09:00.962 (loader): flash, block=3, bs=1024, auto=1
13:09:00.962 (loader): gauge old value = 3
13:09:00.962 (loader): flash, block=4, bs=1024, auto=1
13:09:00.962 (loader): gauge old value = 4
13:09:00.962 (loader): flash, block=5, bs=1024, auto=1
13:09:00.977 (loader): gauge old value = 5
13:09:00.977 (loader): flash, block=6, bs=1024, auto=1
13:09:00.977 (loader): gauge old value = 6
13:09:00.977 (loader): flash, block=7, bs=1024, auto=1
13:09:00.977 (loader): gauge old value = 7
13:09:00.977 (loader): flash, block=8, bs=1024, auto=1
13:09:00.993 (loader): gauge old value = 8
13:09:00.993 (loader): flash, block=9, bs=1024, auto=1
13:09:00.993 (loader): gauge old value = 9
13:09:00.993 (loader): flash, block=10, bs=1024, auto=1
13:09:00.993 (loader): gauge old value = 10
13:09:00.993 (loader): flash, block=11, bs=1024, auto=1
13:09:00.993 (loader): gauge old value = 11
13:09:01.008 (loader): flash, block=12, bs=1024, auto=1
13:09:01.008 (loader): gauge old value = 12
13:09:01.008 (loader): flash, block=13, bs=1024, auto=1
13:09:01.008 (loader): gauge old value = 13
13:09:01.008 (loader): flash, block=14, bs=1024, auto=1
13:09:01.008 (loader): gauge old value = 14
13:09:01.008 (loader): flash, block=15, bs=1024, auto=1
13:09:01.024 (loader): gauge old value = 15
13:09:01.024 (loader): flash, block=16, bs=1024, auto=1
13:09:01.024 (loader): gauge old value = 16
13:09:01.040 (loader): sending reboot
13:09:01.040 (loader): begin wait_until_offline
13:09:01.047 (ports 2): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
13:09:01.048 (ports 2): remove: loc=usb:0/140000/0/5/4
13:09:01.048 (ports 2): usb_remove: usb:0/140000/0/5/4
13:09:01.048 (ports 2): nothing new, skipping HID & Ports enum
13:09:01.102 (loader): offline, waited 1
13:09:01.102 (loader): end operation, total time = 0.407 seconds
13:09:01.102 (loader): set background IMG_REBOOT_OK
13:09:01.102 (loader): redraw timer set, image 14 to show for 1200 ms
13:09:01.203 (ports 2): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
13:09:01.204 (ports 2): nothing new, skipping HID & Ports enum
13:09:01.230 (ports 2): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
13:09:01.231 (ports 2): nothing new, skipping HID & Ports enum
13:09:01.278 (loader): HID/win32: vid:1B80 pid:B406 ver:0100
13:09:01.283 (loader): HID/win32: vid:1B80 pid:B406 ver:0100
13:09:01.285 (loader): HID/win32: vid:1B80 pid:B406 ver:0100
13:09:01.287 (loader): HID/win32: vid:046D pid:C534 ver:2901
13:09:01.289 (loader): HID/win32: vid:046D pid:C534 ver:2901
13:09:01.290 (loader): HID/win32: vid:046D pid:C534 ver:2901
13:09:01.292 (loader): HID/win32: vid:046D pid:C534 ver:2901
13:09:01.294 (loader): HID/win32: vid:0764 pid:0501 ver:0001
13:09:01.665 (ports 2): callback C11E
13:09:02.309 (loader): redraw, image 9
13:09:02.673 (ports 2): purge, name=hid#vid_16c0&pid_0478 (Teensy 4.1) Bootloader, loc=usb:0/140000/0/5/4, age=1.624 sec
13:09:03.680 (ports 2): callback C11E
13:09:05.697 (ports 2): callback C11E
13:09:07.713 (ports 2): callback C11E
13:09:09.729 (ports 2): callback C11E
13:09:11.745 (ports 2): callback C11E
13:09:13.761 (ports 2): callback C11E
13:09:15.777 (ports 2): callback C11E
13:09:16.141 (ports 2): WM_DEVICECHANGE DBT_DEVICEARRIVAL
13:09:16.143 (ports 2): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#000bb99e#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
13:09:16.143 (ports 2): found_usb_device, loc=usb:0/140000/0/5/4 Port_#0004.Hub_#0006
13:09:16.143 (ports 2): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0105
13:09:16.143 (ports 2): found_usb_device, devinst=00000020
13:09:16.143 (ports 2): add: loc=usb:0/140000/0/5/4, class=HID, vid=16C0, pid=0478, ver=0105, serial=000bb99e, dev=\\?\usb#vid_16c0&pid_0478#000bb99e#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
13:09:16.143 (ports 2): hiddev_from_devinst_list: iface=0
13:09:16.144 (ports 2): found_usb_device complete
13:09:16.145 (ports 2): usb_add: usb:0/140000/0/5/4 [no_device] (Teensy) Bootloader
13:09:16.167 (ports 2): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
13:09:16.168 (ports 2): hid, found devinst=00000021
13:09:16.168 (ports 2): hid, path=\\?\hid#vid_16c0&pid_0478#8&e3a77b3&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
13:09:16.168 (ports 2): hid, opened handle
13:09:16.168 (ports 2): devinst=00000021, location=usb:0/140000/0/5/4
13:09:16.168 (ports 2): vid=16C0, pid=0478, ver=0105, usepage=FF9C, use=0025
13:09:16.168 (ports 2): devpath=\\?\hid#vid_16c0&pid_0478#8&e3a77b3&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
13:09:16.169 (ports 2): usb_add: usb:0/140000/0/5/4 hid#vid_16c0&pid_0478 (Teensy 4.1) Bootloader
13:09:16.195 (ports 2): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
13:09:16.196 (ports 2): nothing new, skipping HID & Ports enum
13:09:16.303 (loader): Device came online, code_size = 8126464
13:09:16.303 (loader): Board is: Teensy 4.1 (IMXRT1062), version 1.05
13:09:16.303 (loader): File "BlinkWithoutDelay.ino.hex". 17364 bytes, 0% used
13:09:16.319 (loader): set background IMG_ONLINE
13:09:16.319 (loader): File "BlinkWithoutDelay.ino.hex". 17364 bytes, 0% used
13:09:16.334 (loader): elf appears to be for Teensy 4.1 (IMXRT1062) (8126464 bytes)
13:09:16.334 (loader): elf binary data matches hex file
13:09:16.334 (loader): elf file is for Teensy 4.1 (IMXRT1062)
13:09:16.334 (loader): begin operation
13:09:16.350 (loader): flash, block=0, bs=1024, auto=1
13:09:16.366 (loader): gauge old value = 0
13:09:16.366 (loader): flash, block=1, bs=1024, auto=1
13:09:16.605 (loader): gauge old value = 1
13:09:16.605 (loader): flash, block=2, bs=1024, auto=1
13:09:16.605 (loader): gauge old value = 2
13:09:16.605 (loader): flash, block=3, bs=1024, auto=1
13:09:16.614 (loader): gauge old value = 3
13:09:16.614 (loader): flash, block=4, bs=1024, auto=1
13:09:16.614 (loader): gauge old value = 4
13:09:16.625 (loader): flash, block=5, bs=1024, auto=1
13:09:16.630 (loader): gauge old value = 5
13:09:16.631 (loader): flash, block=6, bs=1024, auto=1
13:09:16.634 (loader): gauge old value = 6
13:09:16.634 (loader): flash, block=7, bs=1024, auto=1
13:09:16.634 (loader): gauge old value = 7
13:09:16.634 (loader): flash, block=8, bs=1024, auto=1
13:09:16.634 (loader): gauge old value = 8
13:09:16.644 (loader): flash, block=9, bs=1024, auto=1
13:09:16.648 (loader): gauge old value = 9
13:09:16.664 (loader): flash, block=10, bs=1024, auto=1
13:09:16.674 (loader): gauge old value = 10
13:09:16.674 (loader): flash, block=11, bs=1024, auto=1
13:09:16.674 (loader): gauge old value = 11
13:09:16.684 (loader): flash, block=12, bs=1024, auto=1
13:09:16.684 (loader): gauge old value = 12
13:09:16.684 (loader): flash, block=13, bs=1024, auto=1
13:09:16.694 (loader): gauge old value = 13
13:09:16.694 (loader): flash, block=14, bs=1024, auto=1
13:09:16.694 (loader): gauge old value = 14
13:09:16.694 (loader): flash, block=15, bs=1024, auto=1
13:09:16.704 (loader): gauge old value = 15
13:09:16.709 (loader): flash, block=16, bs=1024, auto=1
13:09:16.709 (loader): gauge old value = 16
13:09:16.720 (loader): sending reboot
13:09:16.720 (loader): begin wait_until_offline
13:09:16.750 (ports 2): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
13:09:16.754 (ports 2): remove: loc=usb:0/140000/0/5/4
13:09:16.754 (ports 2): usb_remove: usb:0/140000/0/5/4
13:09:16.754 (ports 2): nothing new, skipping HID & Ports enum
13:09:16.780 (loader): offline, waited 1
13:09:16.780 (loader): end operation, total time = 0.446 seconds
13:09:16.780 (loader): set background IMG_REBOOT_OK
13:09:16.780 (loader): redraw timer set, image 14 to show for 1200 ms
13:09:16.863 (loader): HID/win32: vid:1B80 pid:B406 ver:0100
13:09:16.864 (ports 2): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
13:09:16.869 (ports 2): nothing new, skipping HID & Ports enum
13:09:16.878 (loader): HID/win32: vid:1B80 pid:B406 ver:0100
13:09:16.878 (loader): HID/win32: vid:046D pid:C534 ver:2901
13:09:16.894 (loader): HID/win32: vid:0764 pid:0501 ver:0001
13:09:17.804 (ports 2): callback C11E
13:09:17.978 (loader): redraw, image 9
13:09:18.374 (ports 2): purge, name=hid#vid_16c0&pid_0478 (Teensy 4.1) Bootloader, loc=usb:0/140000/0/5/4, age=1.620 sec
13:09:19.831 (ports 2): callback C11E
13:09:21.846 (ports 2): callback C11E
13:09:23.863 (ports 2): callback C11E
13:09:25.879 (ports 2): callback C11E
13:09:27.893 (ports 2): callback C11E
13:09:29.895 (ports 2): callback C11E
13:09:31.912 (ports 2): callback C11E
13:09:33.928 (ports 2): callback C11E
13:09:35.945 (ports 2): callback C11E
13:09:37.960 (ports 2): callback C11E
13:09:38.894 (post_compile 31): Begin, version=1.54-beta1, high-res time
13:09:38.898 (loader): remote connection 1596 opened
13:09:38.901 (post_compile 31): Sending command: comment: Teensyduino 1.54-beta1 - WINDOWS (teensy_post_compile)
13:09:38.901 (loader): remote cmd from 1596: "comment: Teensyduino 1.54-beta1 - WINDOWS (teensy_post_compile)"
13:09:38.903 (loader): remote cmd from 1596: "status"
13:09:38.906 (loader): remote cmd from 1596: "dir:T:\TEMP\arduino_build_483495\"
13:09:38.906 (post_compile 31): Status: 1, 1, 0, 7, 0, 0, T:\TEMP\arduino_build_624832\, BlinkWithoutDelay.ino.hex
13:09:38.906 (post_compile 31): Sending command: dir:T:\TEMP\arduino_build_483495\
13:09:38.908 (loader): remote cmd from 1596: "file:Blink.ino.hex"
13:09:38.908 (post_compile 31): Sending command: file:Blink.ino.hex
13:09:38.921 (loader): File "Blink.ino.hex". 17352 bytes, 0% used
13:09:38.929 (loader): remote cmd from 1596: "status"
13:09:38.933 (post_compile 31): Status: 1, 1, 0, 7, 0, 0, T:\TEMP\arduino_build_483495\, Blink.ino.hex
13:09:38.933 (post_compile 31): Disconnect
13:09:38.944 (loader): remote connection 1596 closed
13:09:39.126 (loader): remote connection 1664 opened
13:09:39.126 (loader): remote cmd from 1664: "comment: Teensyduino 1.54-beta1 - WINDOWS (teensy_post_compile)"
13:09:39.126 (loader): remote cmd from 1664: "status"
13:09:39.130 (post_compile 32): Begin, version=1.54-beta1, high-res time
13:09:39.137 (post_compile 32): Sending command: comment: Teensyduino 1.54-beta1 - WINDOWS (teensy_post_compile)
13:09:39.142 (loader): remote cmd from 1664: "dir:T:\TEMP\arduino_build_483495\"
13:09:39.142 (loader): remote cmd from 1664: "file:Blink.ino.hex"
13:09:39.144 (post_compile 32): Status: 1, 1, 0, 7, 0, 0, T:\TEMP\arduino_build_483495\, Blink.ino.hex
13:09:39.144 (post_compile 32): Sending command: dir:T:\TEMP\arduino_build_483495\
13:09:39.146 (post_compile 32): Sending command: file:Blink.ino.hex
13:09:39.157 (loader): File "Blink.ino.hex". 17352 bytes, 0% used
13:09:39.166 (loader): remote cmd from 1664: "status"
13:09:39.176 (post_compile 32): Status: 1, 1, 0, 7, 0, 0, T:\TEMP\arduino_build_483495\, Blink.ino.hex
13:09:39.176 (post_compile 32): Disconnect
13:09:39.198 (loader): remote connection 1664 closed
13:09:39.198 (post_compile 33): Running teensy_reboot: "T:\arduino-1.8.13_t54\hardware\teensy\..\tools\teensy_reboot. exe" teensy_reboot.exe "-board=TEENSY41" "-port=usb:0/140000/0/5/4" "-portlabel=hid#vid_16c0&pid_0478 Bootloader" "-portprotocol=Teensy"
13:09:39.199 (loader): remote connection 1664 opened
13:09:39.215 (loader): remote connection 1656 opened
13:09:39.223 (reboot 34): Begin, version=1.54-beta1, high-res time
13:09:39.223 (reboot 34): location = usb:0/140000/0/5/4
13:09:39.223 (reboot 34): Only location usb:0/140000/0/5/4 will be tried
13:09:39.223 (reboot 34): portlabel = hid#vid_16c0&pid_0478 Bootloader
13:09:39.223 (reboot 34): portprotocol = Teensy
13:09:39.223 (reboot 34): LoadLibrary cfgmgr32 ok
13:09:39.223 (reboot 34): LoadLibrary ntdll ok
13:09:39.227 (reboot 34): nothing new, skipping HID & Ports enum
13:09:39.232 (reboot 34): Disconnect
13:09:39.246 (loader): remote connection 1656 closed
13:09:39.246 (loader): remote connection 1664 closed
13:09:39.989 (ports 2): callback C11E
13:09:42.005 (ports 2): callback C11E
13:09:44.021 (ports 2): callback C11E
13:09:44.512 (ports 2): WM_DEVICECHANGE DBT_DEVICEARRIVAL
13:09:44.513 (ports 2): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#000bb99e#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
13:09:44.513 (ports 2): found_usb_device, loc=usb:0/140000/0/5/4 Port_#0004.Hub_#0006
13:09:44.513 (ports 2): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0105
13:09:44.513 (ports 2): found_usb_device, devinst=00000020
13:09:44.513 (ports 2): add: loc=usb:0/140000/0/5/4, class=HID, vid=16C0, pid=0478, ver=0105, serial=000bb99e, dev=\\?\usb#vid_16c0&pid_0478#000bb99e#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
13:09:44.514 (ports 2): hiddev_from_devinst_list: iface=0
13:09:44.515 (ports 2): found_usb_device complete
13:09:44.516 (ports 2): usb_add: usb:0/140000/0/5/4 [no_device] (Teensy) Bootloader
13:09:44.516 (ports 2): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
13:09:44.518 (ports 2): hid, found devinst=00000021
13:09:44.518 (ports 2): hid, path=\\?\hid#vid_16c0&pid_0478#8&e3a77b3&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
13:09:44.518 (ports 2): hid, opened handle
13:09:44.518 (ports 2): devinst=00000021, location=usb:0/140000/0/5/4
13:09:44.518 (ports 2): vid=16C0, pid=0478, ver=0105, usepage=FF9C, use=0025
13:09:44.518 (ports 2): devpath=\\?\hid#vid_16c0&pid_0478#8&e3a77b3&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
13:09:44.519 (ports 2): usb_add: usb:0/140000/0/5/4 hid#vid_16c0&pid_0478 (Teensy 4.1) Bootloader
13:09:44.567 (ports 2): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
13:09:44.568 (ports 2): nothing new, skipping HID & Ports enum
13:09:44.596 (loader): Device came online, code_size = 8126464
13:09:44.596 (loader): Board is: Teensy 4.1 (IMXRT1062), version 1.05
13:09:44.596 (loader): File "Blink.ino.hex". 17352 bytes, 0% used
13:09:44.612 (loader): set background IMG_ONLINE
13:09:44.628 (loader): File "Blink.ino.hex". 17352 bytes, 0% used
13:09:44.628 (loader): elf appears to be for Teensy 4.1 (IMXRT1062) (8126464 bytes)
13:09:44.628 (loader): elf binary data matches hex file
13:09:44.643 (loader): elf file is for Teensy 4.1 (IMXRT1062)
13:09:44.643 (loader): begin operation
13:09:44.659 (loader): flash, block=0, bs=1024, auto=1
13:09:44.659 (loader): gauge old value = 0
13:09:44.674 (loader): flash, block=1, bs=1024, auto=1
13:09:44.922 (loader): gauge old value = 1
13:09:44.922 (loader): flash, block=2, bs=1024, auto=1
13:09:44.922 (loader): gauge old value = 2
13:09:44.922 (loader): flash, block=3, bs=1024, auto=1
13:09:44.922 (loader): gauge old value = 3
13:09:44.932 (loader): flash, block=4, bs=1024, auto=1
13:09:44.932 (loader): gauge old value = 4
13:09:44.937 (loader): flash, block=5, bs=1024, auto=1
13:09:44.942 (loader): gauge old value = 5
13:09:44.942 (loader): flash, block=6, bs=1024, auto=1
13:09:44.942 (loader): gauge old value = 6
13:09:44.952 (loader): flash, block=7, bs=1024, auto=1
13:09:44.952 (loader): gauge old value = 7
13:09:44.957 (loader): flash, block=8, bs=1024, auto=1
13:09:44.957 (loader): gauge old value = 8
13:09:44.957 (loader): flash, block=9, bs=1024, auto=1
13:09:44.962 (loader): gauge old value = 9
13:09:44.962 (loader): flash, block=10, bs=1024, auto=1
13:09:44.962 (loader): gauge old value = 10
13:09:44.962 (loader): flash, block=11, bs=1024, auto=1
13:09:44.962 (loader): gauge old value = 11
13:09:44.972 (loader): flash, block=12, bs=1024, auto=1
13:09:44.972 (loader): gauge old value = 12
13:09:44.977 (loader): flash, block=13, bs=1024, auto=1
13:09:44.977 (loader): gauge old value = 13
13:09:44.982 (loader): flash, block=14, bs=1024, auto=1
13:09:44.982 (loader): gauge old value = 14
13:09:44.987 (loader): flash, block=15, bs=1024, auto=1
13:09:44.987 (loader): gauge old value = 15
13:09:44.987 (loader): flash, block=16, bs=1024, auto=1
13:09:44.992 (loader): gauge old value = 16
13:09:45.002 (loader): sending reboot
13:09:45.002 (loader): begin wait_until_offline
13:09:45.011 (ports 2): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
13:09:45.011 (ports 2): remove: loc=usb:0/140000/0/5/4
13:09:45.011 (ports 2): usb_remove: usb:0/140000/0/5/4
13:09:45.011 (ports 2): nothing new, skipping HID & Ports enum
13:09:45.062 (loader): offline, waited 1
13:09:45.062 (loader): end operation, total time = 0.419 seconds
13:09:45.062 (loader): set background IMG_REBOOT_OK
13:09:45.072 (loader): redraw timer set, image 14 to show for 1200 ms
13:09:45.139 (loader): HID/win32: vid:1B80 pid:B406 ver:0100
13:09:45.142 (loader): HID/win32: vid:1B80 pid:B406 ver:0100
13:09:45.143 (loader): HID/win32: vid:1B80 pid:B406 ver:0100
13:09:45.147 (loader): HID/win32: vid:1B80 pid:B406 ver:0100
13:09:45.150 (loader): HID/win32: vid:046D pid:C534 ver:2901
13:09:45.152 (loader): HID/win32: vid:046D pid:C534 ver:2901
13:09:45.152 (loader): HID/win32: vid:0764 pid:0501 ver:0001
13:09:45.161 (ports 2): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
13:09:45.161 (ports 2): nothing new, skipping HID & Ports enum
13:09:46.154 (ports 2): callback C11E
13:09:46.282 (loader): redraw, image 9
13:09:46.700 (ports 2): purge, name=hid#vid_16c0&pid_0478 (Teensy 4.1) Bootloader, loc=usb:0/140000/0/5/4, age=1.689 sec
13:09:48.209 (ports 2): callback C11E
13:09:50.228 (ports 2): callback C11E
13:09:52.240 (ports 2): callback C11E
13:09:54.256 (ports 2): callback C11E
13:09:56.263 (ports 2): callback C11E
13:09:58.285 (ports 2): callback C11E
13:10:00.319 (ports 2): callback C11E
13:10:02.346 (ports 2): callback C11E
13:10:04.368 (ports 2): callback C11E
13:10:06.393 (ports 2): callback C11E
13:10:08.421 (ports 2): callback C11E
13:10:10.430 (ports 2): callback C11E
13:10:12.434 (ports 2): callback C11E
13:10:14.463 (ports 2): callback C11E
Change back to T_4.0 and program no problem:
13:13:17.613 (ports 2): callback C11E
13:13:19.628 (ports 2): callback C11E
13:13:21.629 (ports 2): callback C11E
13:13:23.629 (ports 2): callback C11E
13:13:25.630 (ports 2): callback C11E
13:13:27.629 (ports 2): callback C11E
13:13:29.652 (ports 2): callback C11E
13:13:31.680 (ports 2): callback C11E
13:13:33.706 (ports 2): callback C11E
13:13:35.725 (ports 2): callback C11E
13:13:37.754 (ports 2): callback C11E
13:13:39.766 (ports 2): callback C11E
13:13:41.773 (ports 2): callback C11E
13:13:43.796 (ports 2): callback C11E
13:13:45.816 (ports 2): callback C11E
13:13:47.819 (ports 2): callback C11E
13:13:49.839 (ports 2): callback C11E
13:13:51.867 (ports 2): callback C11E
13:13:53.885 (ports 2): callback C11E
13:13:55.886 (ports 2): callback C11E
13:13:57.916 (ports 2): callback C11E
13:13:59.942 (ports 2): callback C11E
13:14:01.967 (ports 2): callback C11E
13:14:03.989 (ports 2): callback C11E
13:14:06.015 (ports 2): callback C11E
13:14:08.015 (ports 2): callback C11E
13:14:10.017 (ports 2): callback C11E
13:14:12.033 (ports 2): callback C11E
13:14:14.049 (ports 2): callback C11E
13:14:16.065 (ports 2): callback C11E
13:14:18.080 (ports 2): callback C11E
13:14:20.082 (ports 2): callback C11E
13:14:22.098 (ports 2): callback C11E
13:14:24.113 (ports 2): callback C11E
13:14:26.130 (ports 2): callback C11E
13:14:28.146 (ports 2): callback C11E
13:14:30.147 (ports 2): callback C11E
13:14:32.165 (ports 2): callback C11E
13:14:34.181 (ports 2): callback C11E
13:14:36.197 (ports 2): callback C11E
13:14:38.215 (ports 2): callback C11E
13:14:40.231 (ports 2): callback C11E
13:14:42.247 (ports 2): callback C11E
13:14:44.264 (ports 2): callback C11E
13:14:46.280 (ports 2): callback C11E
13:14:48.281 (ports 2): callback C11E
13:14:50.297 (ports 2): callback C11E
13:14:52.314 (ports 2): callback C11E
13:14:54.332 (ports 2): callback C11E
13:14:56.348 (ports 2): callback C11E
13:14:58.364 (ports 2): callback C11E
13:15:00.382 (ports 2): callback C11E
13:15:02.399 (ports 2): callback C11E
13:15:04.415 (ports 2): callback C11E
13:15:06.431 (ports 2): callback C11E
13:15:08.449 (ports 2): callback C11E
13:15:10.465 (ports 2): callback C11E
13:15:12.481 (ports 2): callback C11E
13:15:14.499 (ports 2): callback C11E
13:15:16.515 (ports 2): callback C11E
13:15:18.532 (ports 2): callback C11E
13:15:20.549 (ports 2): callback C11E
13:15:22.565 (ports 2): callback C11E
13:15:24.584 (ports 2): callback C11E
13:15:26.599 (ports 2): callback C11E
13:15:28.615 (ports 2): callback C11E
13:15:30.632 (ports 2): callback C11E
13:15:32.649 (ports 2): callback C11E
13:15:34.665 (ports 2): callback C11E
13:15:36.683 (ports 2): callback C11E
13:15:38.699 (ports 2): callback C11E
13:15:40.715 (ports 2): callback C11E
13:15:42.731 (ports 2): callback C11E
13:15:44.750 (ports 2): callback C11E
13:15:46.765 (ports 2): callback C11E
13:15:48.781 (ports 2): callback C11E
13:15:50.800 (ports 2): callback C11E
13:15:52.815 (ports 2): callback C11E
13:15:54.815 (ports 2): callback C11E
13:15:56.816 (ports 2): callback C11E
13:15:58.831 (ports 2): callback C11E
13:16:00.834 (ports 2): callback C11E
13:16:02.850 (ports 2): callback C11E
13:16:04.866 (ports 2): callback C11E
13:16:06.882 (ports 2): callback C11E
13:16:08.899 (ports 2): callback C11E
13:16:10.916 (ports 2): callback C11E
13:16:12.941 (ports 2): callback C11E
13:16:14.966 (ports 2): callback C11E
13:16:16.993 (ports 2): callback C11E
13:16:19.014 (ports 2): callback C11E
13:16:21.015 (ports 2): callback C11E
13:16:23.016 (ports 2): callback C11E
13:16:23.853 (ports 2): WM_DEVICECHANGE DBT_DEVICEARRIVAL
13:16:23.854 (ports 2): found_usb_device, id=\\?\usb#vid_16c0&pid_0483#6362860#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
13:16:23.854 (ports 2): found_usb_device, loc=usb:0/140000/0/5/3 Port_#0003.Hub_#0006
13:16:23.854 (ports 2): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0279
13:16:23.854 (ports 2): found_usb_device, devinst=00000003
13:16:23.854 (ports 2): add: loc=usb:0/140000/0/5/3, class=Ports, vid=16C0, pid=0483, ver=0279, serial=6362860, dev=\\?\usb#vid_16c0&pid_0483#6362860#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
13:16:23.854 (ports 2): comport_from_devinst_list attempt
13:16:23.854 (ports 2): found Ports in classguid_list at index=0
13:16:23.854 (ports 2): port COM8 found from devnode
13:16:23.854 (ports 2): found_usb_device complete
13:16:23.856 (ports 2): usb_add: usb:0/140000/0/5/3 COM8 (Teensy 4.0) Serial
13:16:23.856 (ports 2): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
13:16:23.857 (ports 2): nothing new, skipping HID & Ports enum
13:16:23.945 (ports 2): WM_DEVICECHANGE DBT_DEVICEARRIVAL
13:16:23.946 (ports 2): nothing new, skipping HID & Ports enum
13:16:23.946 (ports 2): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
13:16:23.947 (ports 2): nothing new, skipping HID & Ports enum
13:16:25.033 (ports 2): callback C11E
13:16:27.061 (ports 2): callback C11E
13:16:29.082 (ports 2): callback C11E
13:16:31.083 (ports 2): callback C11E
13:16:33.083 (ports 2): callback C11E
13:16:35.084 (ports 2): callback C11E
13:16:37.105 (ports 2): callback C11E
13:16:39.106 (ports 2): callback C11E
13:16:41.106 (ports 2): callback C11E
13:16:43.122 (ports 2): callback C11E
13:16:45.124 (ports 2): callback C11E
13:16:47.148 (ports 2): callback C11E
13:16:49.164 (ports 2): callback C11E
13:16:51.167 (ports 2): callback C11E
13:16:53.183 (ports 2): callback C11E
13:16:55.198 (ports 2): callback C11E
13:16:57.222 (ports 2): callback C11E
13:16:59.239 (ports 2): callback C11E
13:17:00.057 (loader): file changed
13:17:01.049 (loader): file changed
13:17:01.071 (loader): File "Blink.ino.hex". 16216 bytes, 0% used
13:17:01.108 (post_compile 35): Begin, version=1.54-beta1, high-res time
13:17:01.111 (loader): remote connection 2656 opened
13:17:01.120 (loader): remote cmd from 2656: "comment: Teensyduino 1.54-beta1 - WINDOWS (teensy_post_compile)"
13:17:01.121 (post_compile 35): Sending command: comment: Teensyduino 1.54-beta1 - WINDOWS (teensy_post_compile)
13:17:01.136 (loader): remote cmd from 2656: "status"
13:17:01.152 (loader): remote cmd from 2656: "dir:T:\TEMP\arduino_build_483495\"
13:17:01.153 (post_compile 35): Status: 1, 1, 0, 8, 0, 0, T:\TEMP\arduino_build_483495\, Blink.ino.hex
13:17:01.153 (post_compile 35): Sending command: dir:T:\TEMP\arduino_build_483495\
13:17:01.166 (loader): remote cmd from 2656: "file:Blink.ino.hex"
13:17:01.167 (post_compile 35): Sending command: file:Blink.ino.hex
13:17:01.192 (loader): File "Blink.ino.hex". 16216 bytes, 0% used
13:17:01.213 (loader): remote cmd from 2656: "status"
13:17:01.223 (post_compile 35): Status: 1, 1, 0, 8, 0, 0, T:\TEMP\arduino_build_483495\, Blink.ino.hex
13:17:01.223 (post_compile 35): Disconnect
13:17:01.238 (loader): remote connection 2656 closed
13:17:01.266 (ports 2): callback C11E
13:17:01.419 (loader): remote connection 2656 opened
13:17:01.419 (loader): remote cmd from 2656: "comment: Teensyduino 1.54-beta1 - WINDOWS (teensy_post_compile)"
13:17:01.421 (post_compile 36): Begin, version=1.54-beta1, high-res time
13:17:01.433 (post_compile 36): Sending command: comment: Teensyduino 1.54-beta1 - WINDOWS (teensy_post_compile)
13:17:01.435 (loader): remote cmd from 2656: "status"
13:17:01.457 (loader): remote cmd from 2656: "dir:T:\TEMP\arduino_build_483495\"
13:17:01.457 (loader): remote cmd from 2656: "file:Blink.ino.hex"
13:17:01.461 (post_compile 36): Status: 1, 1, 0, 8, 0, 0, T:\TEMP\arduino_build_483495\, Blink.ino.hex
13:17:01.461 (post_compile 36): Sending command: dir:T:\TEMP\arduino_build_483495\
13:17:01.468 (post_compile 36): Sending command: file:Blink.ino.hex
13:17:01.489 (loader): File "Blink.ino.hex". 16216 bytes, 0% used
13:17:01.506 (loader): remote cmd from 2656: "status"
13:17:01.522 (post_compile 36): Status: 1, 1, 0, 8, 0, 0, T:\TEMP\arduino_build_483495\, Blink.ino.hex
13:17:01.522 (post_compile 36): Disconnect
13:17:01.539 (post_compile 37): Running teensy_reboot: "T:\arduino-1.8.13_t54\hardware\teensy\..\tools\teensy_reboot. exe" teensy_reboot.exe "-board=TEENSY40" "-port=usb:0/140000/0/5/3" "-portlabel=COM8 Serial" "-portprotocol=Teensy"
13:17:01.542 (loader): remote connection 2656 closed
13:17:01.542 (loader): remote connection 2656 opened
13:17:01.588 (loader): remote connection 3748 opened
13:17:01.592 (reboot 38): Begin, version=1.54-beta1, high-res time
13:17:01.592 (reboot 38): location = usb:0/140000/0/5/3
13:17:01.592 (reboot 38): portprotocol = Teensy
13:17:01.592 (reboot 38): portlabel = COM8 Serial
13:17:01.592 (reboot 38): Only location usb:0/140000/0/5/3 will be tried
13:17:01.592 (reboot 38): LoadLibrary cfgmgr32 ok
13:17:01.592 (reboot 38): LoadLibrary ntdll ok
13:17:01.594 (reboot 38): found_usb_device, id=\\?\usb#vid_16c0&pid_0483#6362860#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
13:17:01.594 (reboot 38): found_usb_device, loc=usb:0/140000/0/5/3 Port_#0003.Hub_#0006
13:17:01.594 (reboot 38): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0279
13:17:01.594 (reboot 38): found_usb_device, devinst=00000002
13:17:01.594 (reboot 38): add: loc=usb:0/140000/0/5/3, class=Ports, vid=16C0, pid=0483, ver=0279, serial=6362860, dev=\\?\usb#vid_16c0&pid_0483#6362860#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
13:17:01.594 (reboot 38): comport_from_devinst_list attempt
13:17:01.594 (reboot 38): found Ports in classguid_list at index=0
13:17:01.594 (reboot 38): port COM8 found from devnode
13:17:01.594 (reboot 38): found_usb_device complete
13:17:01.608 (loader): remote cmd from 3748: "show:arduino_attempt_reboot"
13:17:01.618 (reboot 38): found Teensy Loader, version 1.54
13:17:01.618 (reboot 38): Sending command: show:arduino_attempt_reboot
13:17:01.624 (loader): got request to show arduino rebooting message
13:17:01.641 (loader): remote cmd from 3748: "comment: Teensyduino 1.54-beta1 - WINDOWS (teensy_reboot)"
13:17:01.653 (reboot 38): Sending command: comment: Teensyduino 1.54-beta1 - WINDOWS (teensy_reboot)
13:17:01.657 (loader): remote cmd from 3748: "status"
13:17:01.686 (reboot 38): Status: 1, 1, 0, 8, 0, 0, T:\TEMP\arduino_build_483495\, Blink.ino.hex
13:17:01.686 (reboot 38): do_reset (serial) COM8
13:17:01.688 (loader): remote cmd from 3748: "status"
13:17:01.699 (reboot 38): Status: 1, 1, 0, 8, 0, 0, T:\TEMP\arduino_build_483495\, Blink.ino.hex
13:17:01.699 (reboot 38): status read, retry 0
13:17:01.703 (ports 2): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
13:17:01.704 (ports 2): remove: loc=usb:0/140000/0/5/3
13:17:01.704 (ports 2): usb_remove: usb:0/140000/0/5/3
13:17:01.704 (ports 2): nothing new, skipping HID & Ports enum
13:17:01.768 (ports 2): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
13:17:01.769 (ports 2): nothing new, skipping HID & Ports enum
13:17:01.769 (ports 2): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
13:17:01.770 (ports 2): nothing new, skipping HID & Ports enum
13:17:01.829 (loader): remote cmd from 3748: "status"
13:17:01.859 (reboot 38): Status: 1, 1, 0, 8, 0, 0, T:\TEMP\arduino_build_483495\, Blink.ino.hex
13:17:01.859 (reboot 38): status read, retry 1
13:17:01.911 (ports 2): WM_DEVICECHANGE DBT_DEVICEARRIVAL
13:17:01.912 (ports 2): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#0009b57e#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
13:17:01.912 (ports 2): found_usb_device, loc=usb:0/140000/0/5/3 Port_#0003.Hub_#0006
13:17:01.912 (ports 2): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0105
13:17:01.912 (ports 2): found_usb_device, devinst=0000001e
13:17:01.912 (ports 2): add: loc=usb:0/140000/0/5/3, class=HID, vid=16C0, pid=0478, ver=0105, serial=0009b57e, dev=\\?\usb#vid_16c0&pid_0478#0009b57e#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
13:17:01.912 (ports 2): hiddev_from_devinst_list: iface=0
13:17:01.913 (ports 2): found_usb_device complete
13:17:01.915 (ports 2): usb_add: usb:0/140000/0/5/3 [no_device] (Teensy 4.0) Bootloader
13:17:02.002 (loader): remote cmd from 3748: "status"
13:17:02.020 (loader): Device came online, code_size = 2031616
13:17:02.023 (loader): Board is: Teensy 4.0 (IMXRT1062), version 1.05
13:17:02.042 (loader): File "Blink.ino.hex". 16216 bytes, 1% used
13:17:02.052 (loader): set background IMG_ONLINE
13:17:02.077 (loader): File "Blink.ino.hex". 16216 bytes, 1% used
13:17:02.092 (loader): elf appears to be for Teensy 4.0 (IMXRT1062) (2031616 bytes)
13:17:02.102 (loader): elf binary data matches hex file
13:17:02.103 (loader): elf file is for Teensy 4.0 (IMXRT1062)
13:17:02.112 (loader): begin operation
13:17:02.144 (reboot 38): Status: 1, 1, 1, 9, 0, 1, T:\TEMP\arduino_build_483495\, Blink.ino.hex
13:17:02.148 (ports 2): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
13:17:02.150 (ports 2): hid, found devinst=0000001F
13:17:02.150 (ports 2): hid, path=\\?\hid#vid_16c0&pid_0478#7&113038dd&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
13:17:02.150 (ports 2): hid, opened handle
13:17:02.150 (ports 2): devinst=0000001F, location=usb:0/140000/0/5/3
13:17:02.150 (ports 2): vid=16C0, pid=0478, ver=0105, usepage=FF9C, use=0024
13:17:02.150 (ports 2): devpath=\\?\hid#vid_16c0&pid_0478#7&113038dd&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
13:17:02.150 (ports 2): usb_add: usb:0/140000/0/5/3 hid#vid_16c0&pid_0478 (Teensy 4.0) Bootloader
13:17:02.232 (loader): remote cmd from 3748: "status"
13:17:02.252 (loader): flash, block=0, bs=1024, auto=1
13:17:02.252 (loader): gauge old value = 0
13:17:02.252 (reboot 38): Status: 1, 1, 1, 9, 0, 1, T:\TEMP\arduino_build_483495\, Blink.ino.hex
13:17:02.267 (loader): flash, block=1, bs=1024, auto=1
13:17:02.482 (loader): gauge old value = 1
13:17:02.492 (loader): remote cmd from 3748: "status"
13:17:02.507 (loader): flash, block=2, bs=1024, auto=1
13:17:02.509 (reboot 38): Status: 1, 1, 1, 9, 0, 1, T:\TEMP\arduino_build_483495\, Blink.ino.hex
13:17:02.517 (loader): gauge old value = 2
13:17:02.532 (loader): flash, block=3, bs=1024, auto=1
13:17:02.542 (loader): gauge old value = 3
13:17:02.552 (loader): flash, block=4, bs=1024, auto=1
13:17:02.567 (loader): gauge old value = 4
13:17:02.577 (loader): remote cmd from 3748: "status"
13:17:02.587 (loader): flash, block=5, bs=1024, auto=1
13:17:02.591 (reboot 38): Status: 1, 1, 1, 9, 0, 1, T:\TEMP\arduino_build_483495\, Blink.ino.hex
13:17:02.597 (loader): gauge old value = 5
13:17:02.612 (loader): flash, block=6, bs=1024, auto=1
13:17:02.622 (loader): gauge old value = 6
13:17:02.632 (loader): flash, block=7, bs=1024, auto=1
13:17:02.642 (loader): gauge old value = 7
13:17:02.652 (loader): remote cmd from 3748: "status"
13:17:02.671 (reboot 38): Status: 1, 1, 1, 9, 0, 1, T:\TEMP\arduino_build_483495\, Blink.ino.hex
13:17:02.672 (loader): flash, block=8, bs=1024, auto=1
13:17:02.687 (loader): gauge old value = 8
13:17:02.707 (loader): flash, block=9, bs=1024, auto=1
13:17:02.727 (loader): gauge old value = 9
13:17:02.742 (loader): remote cmd from 3748: "status"
13:17:02.752 (loader): flash, block=10, bs=1024, auto=1
13:17:02.756 (reboot 38): Status: 1, 1, 1, 9, 0, 1, T:\TEMP\arduino_build_483495\, Blink.ino.hex
13:17:02.767 (loader): gauge old value = 10
13:17:02.782 (loader): flash, block=11, bs=1024, auto=1
13:17:02.797 (loader): gauge old value = 11
13:17:02.807 (reboot 38): status read, retry 2
13:17:02.807 (reboot 38): Success
13:17:02.807 (reboot 38): Disconnect
13:17:02.867 (loader): remote connection 3748 closed
13:17:02.902 (loader): remote connection 2656 closed
13:17:02.917 (loader): flash, block=12, bs=1024, auto=1
13:17:02.933 (loader): gauge old value = 12
13:17:02.947 (loader): flash, block=13, bs=1024, auto=1
13:17:02.962 (loader): gauge old value = 13
13:17:02.972 (loader): flash, block=14, bs=1024, auto=1
13:17:02.987 (loader): gauge old value = 14
13:17:03.007 (loader): flash, block=15, bs=1024, auto=1
13:17:03.027 (loader): gauge old value = 15
13:17:03.052 (loader): sending reboot
13:17:03.077 (loader): begin wait_until_offline
13:17:03.083 (ports 2): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
13:17:03.084 (ports 2): remove: loc=usb:0/140000/0/5/3
13:17:03.084 (ports 2): usb_remove: usb:0/140000/0/5/3
13:17:03.085 (ports 2): nothing new, skipping HID & Ports enum
13:17:03.097 (loader): offline, waited 0
13:17:03.132 (loader): end operation, total time = 1.010 seconds
13:17:03.148 (loader): set background IMG_REBOOT_OK
13:17:03.156 (loader): redraw timer set, image 14 to show for 1200 ms
13:17:03.221 (loader): HID/win32: vid:1B80 pid:B406 ver:0100
13:17:03.230 (ports 2): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
13:17:03.231 (ports 2): nothing new, skipping HID & Ports enum
13:17:03.239 (loader): HID/win32: vid:1B80 pid:B406 ver:0100
13:17:03.255 (loader): HID/win32: vid:1B80 pid:B406 ver:0100
13:17:03.272 (loader): HID/win32: vid:046D pid:C534 ver:2901
13:17:03.287 (loader): HID/win32: vid:046D pid:C534 ver:2901
13:17:03.303 (loader): HID/win32: vid:046D pid:C534 ver:2901
13:17:03.320 (loader): HID/win32: vid:046D pid:C534 ver:2901
13:17:03.335 (loader): HID/win32: vid:0764 pid:0501 ver:0001
13:17:03.422 (ports 2): WM_DEVICECHANGE DBT_DEVICEARRIVAL
13:17:03.423 (ports 2): found_usb_device, id=\\?\usb#vid_16c0&pid_0483#6362860#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
13:17:03.423 (ports 2): found_usb_device, loc=usb:0/140000/0/5/3 Port_#0003.Hub_#0006
13:17:03.423 (ports 2): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0279
13:17:03.423 (ports 2): found_usb_device, devinst=00000003
13:17:03.423 (ports 2): add: loc=usb:0/140000/0/5/3, class=Ports, vid=16C0, pid=0483, ver=0279, serial=6362860, dev=\\?\usb#vid_16c0&pid_0483#6362860#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
13:17:03.423 (ports 2): comport_from_devinst_list attempt
13:17:03.423 (ports 2): found Ports in classguid_list at index=0
13:17:03.424 (ports 2): port COM8 found from devnode
13:17:03.424 (ports 2): found_usb_device complete
13:17:03.425 (ports 2): usb_add: usb:0/140000/0/5/3 COM8 (Teensy 4.0) Serial
13:17:03.561 (ports 2): callback C11E
13:17:03.561 (ports 2): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
13:17:03.562 (ports 2): nothing new, skipping HID & Ports enum
13:17:03.562 (ports 2): WM_DEVICECHANGE DBT_DEVICEARRIVAL
13:17:03.563 (ports 2): nothing new, skipping HID & Ports enum
13:17:03.653 (ports 2): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
13:17:03.654 (ports 2): nothing new, skipping HID & Ports enum
13:17:04.354 (loader): redraw, image 9
13:17:05.581 (ports 2): callback C11E
13:17:07.601 (ports 2): callback C11E
13:17:09.618 (ports 2): callback C11E
13:17:11.643 (ports 2): callback C11E
13:17:13.654 (ports 2): callback C11E
13:17:15.670 (ports 2): callback C11E
13:17:17.670 (ports 2): callback C11E
13:17:19.670 (ports 2): callback C11E
13:17:21.148 (ports 2): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
13:17:21.149 (ports 2): remove: loc=usb:0/140000/0/5/3
13:17:21.149 (ports 2): usb_remove: usb:0/140000/0/5/3
13:17:21.149 (ports 2): nothing new, skipping HID & Ports enum
13:17:21.223 (ports 2): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
13:17:21.223 (ports 2): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
13:17:21.224 (ports 2): nothing new, skipping HID & Ports enum
13:17:21.683 (ports 2): callback C11E
13:17:22.776 (ports 2): purge, name=COM8 (Teensy 4.0) Serial, loc=usb:0/140000/0/5/3, age=1.627 sec
13:17:23.694 (ports 2): callback C11E
13:17:25.708 (ports 2): callback C11E
13:17:27.733 (ports 2): callback C11E
13:17:29.755 (ports 2): callback C11E
13:17:31.757 (ports 2): callback C11E
13:17:33.788 (ports 2): callback C11E
13:17:35.807 (ports 2): callback C11E
13:17:37.820 (ports 2): callback C11E
13:17:39.829 (ports 2): callback C11E
13:17:41.854 (ports 2): callback C11E
13:17:43.854 (ports 2): callback C11E
13:17:45.856 (ports 2): callback C11E
13:17:47.871 (ports 2): callback C11E
13:17:49.872 (ports 2): callback C11E
13:17:51.872 (ports 2): callback C11E
13:17:53.883 (ports 2): callback C11E
13:17:55.901 (ports 2): callback C11E
13:17:57.919 (ports 2): callback C11E
13:17:59.932 (ports 2): callback C11E
13:18:01.942 (ports 2): callback C11E
13:18:03.952 (ports 2): callback C11E
13:18:05.967 (ports 2): callback C11E
13:18:07.968 (ports 2): callback C11E
13:18:09.969 (ports 2): callback C11E
13:18:11.985 (ports 2): callback C11E
13:18:13.993 (ports 2): callback C11E
defragster
10-22-2020, 09:35 PM
Above T_4.1 had some QPSI chip(s).
Unpacked a Fresh T_4.1 - it was blinking and connected - Upload fail and button push fail - though TeensyLoader goes through the motions.
To check used TyCommander with same T:\\TEMP\\arduino_build_483495/Blink.ino.hex. It also goes through programming - but device never comes up running.
Did 15sec Restore - TyCommander upload ... no device on reset or power on.
OPEN IDE 1.8.13 with TD_1.53 and upload BlinkWithoutDelay.ino.TEENSY41.hex using TyCommander and it works no problem.
KurtE
10-22-2020, 10:01 PM
Side Note: I ran into issues yesterday or the day before where my builds were not working before this release, but that was because I had my Cores project directory linked into the Teensyduino release (and I renamed cores to different name... It started working again when I removed that link and renamed back...
I also was seeing some screwy stuff when I was building using the Sublimetext with my app that displays information about the build... It is screwy again with the release.
Sketch uses 73720 bytes (0%) of program storage space. Maximum is 8126464 bytes.
Global variables use 246452 bytes (47%) of dynamic memory, leaving 277836 bytes for local variables. Maximum is 524288 bytes.
FlexRAM section ITCM+DTCM = 512 KB
Config : aaaaaaaf (DDDDDDDDDDDDDDII)
ITCM : 55544 B (84.75% of 64 KB)
DTCM : 180928 B (39.44% of 448 KB)
>>>>> Error FlexRAM Filled no room for Stack: -537051840 <<<<<
OCRAM: 512KB
DMAMEM: 12384 B ( 2.36% of 512 KB)
Available for Heap: 511904 B (97.64% of 512 KB)
Flash: 76800 B ( 0.95% of 7936 KB)
The code is pretty simple:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
int printnumbers(unsigned flexram_config, unsigned itcm, unsigned dtcm, unsigned ocram, unsigned flash, int stack,
unsigned ocramm, unsigned flashm)
int retval = 0;
unsigned dtcm_allocated = 0;
unsigned itcm_allocated = 0;
char dtcm_itcm_config[17] = "DDDDDDDDDDDDDDDD";
char* psz = &dtcm_itcm_config[15]; // Crud code...
printf("\nFlexRAM section ITCM+DTCM = 512 KB\n");
printf(" Config : %08lx (", flexram_config);
for (; flexram_config; flexram_config >>= 2) {
if ((flexram_config & 3) == 2) {
*psz-- = 'D';
dtcm_allocated += 32; // 32K per bank;
else if ((flexram_config & 3) == 3) {
*psz-- = 'I';
itcm_allocated += 32; // 32K per bank;
else psz--;
printf("%s)\n ITCM : %6d B\t(%5.2f%% of %4d KB)\n", dtcm_itcm_config, itcm, itcm / (itcm_allocated * 1024.0) * 100, itcm_allocated);
printf(" DTCM : %6d B\t(%5.2f%% of %4d KB)\n", dtcm, dtcm / (dtcm_allocated * 1024.0) * 100, dtcm_allocated);
if (stack <= 0) {
retval = -1;
printf(">>>>> Error FlexRAM Filled no room for Stack: %d <<<<<\n", stack);
else {
printf(" Available for Stack: %6d\n", stack);
printf("OCRAM: 512KB\n");
printf(" DMAMEM: %6d B\t(%5.2f%% of %4d KB)\n", ocram, ocram / (ocramm * 1024.0) * 100, ocramm);
ocram = ocramm*1024 - ocram;
printf(" Available for Heap: %6d B\t(%5.2f%% of %4d KB)\n", ocram, ocram / (ocramm * 1024.0) * 100, ocramm);
printf("Flash: %6d B\t(%5.2f%% of %4d KB)\n", flash, flash / (flashm * 1024.0) * 100, flashm);
return retval;
int main() {
const int bl = 200;
int retval = 0;
char str[bl + 1];
char* s;
unsigned teensy_model_identifier = 0;
unsigned stext = 0;
unsigned etext = 0;
unsigned sdata = 0;
unsigned ebss = 0;
unsigned flashimagelen = 0;
unsigned heap_start = 0;
unsigned flexram_bank_config = 0;
unsigned estack = 0;
do {
s = fgets(str, sizeof(str), stdin);
if (s) {
str[bl] = 0;
if (strstr(str, "_teensy_model_identifier")) teensy_model_identifier = strtol(str, NULL, 16);
if (strstr(str, "T _stext")) stext = strtol(str, NULL, 16);
if (strstr(str, "T _etext")) etext = strtol(str, NULL, 16);
if (strstr(str, "D _sdata")) sdata = strtol(str, NULL, 16);
if (strstr(str, "B _ebss")) ebss = strtol(str, NULL, 16);
if (strstr(str, " _heap_start")) heap_start = strtol(str, NULL, 16);
if (strstr(str, " _flashimagelen")) flashimagelen = strtol(str, NULL, 16);
if (strstr(str, "B _estack")) estack = strtoul(str, NULL, 16);
if (strstr(str, " _flexram_bank_config")) flexram_bank_config = strtoul(str, NULL, 16);
//puts( str );
} while (s);
if (teensy_model_identifier == 0x24) {
retval = printnumbers(flexram_bank_config, etext - stext, ebss - sdata, heap_start - 0x20200000, flashimagelen, estack-ebss, 512, 1984);
else if (teensy_model_identifier == 0x25) {
retval = printnumbers(flexram_bank_config, etext - stext, ebss - sdata, heap_start - 0x20200000, flashimagelen, estack - ebss, 512, 7936);
return retval;
It is simply subtracting what it found for the symbol ebss from the symbol estack...
defragster
10-22-2020, 10:06 PM
I had github updated my cores but beta 1 released before I swapped so I didn't see anything. And today's testing was IDE only - except TyCommander is integrated on the TD1.53 version - but it worked.
I stared at the .ld changes and didn't see anything obvious between the two 1062's - diff flash size, and add in for the extmem.
@KurtE - does the USBHost lib update include your 512B Serial changes?
<edit> : on td1.53 IDE did restore to teensyLoader for upload, instead of TyCommander
Opened TeensyLoader 1.54b1 which then uploaded to T_4.1 no problem the blink sketch. Just to confirm problem is the HEX not the loader.
KurtE
10-22-2020, 10:18 PM
Well I had my code print out what it had for estack and ebss and it prints:
estack:0 ebss:2002c2c0
But that is also true for T4 now as well... So next up to see why?
Figured out the tool issue:
2002c28c B errno
2002c2c0 B _ebss
20070000 T _estack
The code before was looking for B _estack
So just duplicated....
if (strstr(str, "T _estack")) estack = strtoul(str, NULL, 16);
mjs513
10-22-2020, 10:21 PM
Just joined the fun here. Loaded a clean copy of Arduino 1.8.13 along with 1.54-beta1 and am seeing the same issues on a Windows 10 64 bit as @KurtE and @degragster while loading Blink.ino. As a second test I went back the 1.8.13/1.53 combo and tried loading blink and got the following error:
C:\Users\Merli\AppData\Local\Temp\arduino_build_91 1470/core\core.a(bootdata.c.o):(.ivt+0x18): undefined reference to `_scsf'
C:\Users\Merli\AppData\Local\Temp\arduino_build_91 1470/core\core.a(bootdata.c.o):(.bootdata+0x4): undefined reference to `__image_size'
Error compiling for board Teensy 4.1.
Here's the verbose output:
F:\arduino-1.8.13\arduino-builder -dump-prefs -logger=machine -hardware F:\arduino-1.8.13\hardware -hardware C:\Users\Merli\AppData\Local\Arduino15\packages -tools F:\arduino-1.8.13\tools-builder -tools F:\arduino-1.8.13\hardware\tools\avr -tools C:\Users\Merli\AppData\Local\Arduino15\packages -built-in-libraries F:\arduino-1.8.13\libraries -libraries D:\Users\Merli\Documents\Arduino\libraries -fqbn=teensy:avr:teensy41:usb=serial,speed=600,opt= o2std,keys=en-us -ide-version=10813 -build-path C:\Users\Merli\AppData\Local\Temp\arduino_build_91 1470 -warnings=none -build-cache C:\Users\Merli\AppData\Local\Temp\arduino_cache_53 7696 -verbose F:\arduino-1.8.13\examples\Teensy\Tutorial1\Blink\Blink.pde
F:\arduino-1.8.13\arduino-builder -compile -logger=machine -hardware F:\arduino-1.8.13\hardware -hardware C:\Users\Merli\AppData\Local\Arduino15\packages -tools F:\arduino-1.8.13\tools-builder -tools F:\arduino-1.8.13\hardware\tools\avr -tools C:\Users\Merli\AppData\Local\Arduino15\packages -built-in-libraries F:\arduino-1.8.13\libraries -libraries D:\Users\Merli\Documents\Arduino\libraries -fqbn=teensy:avr:teensy41:usb=serial,speed=600,opt= o2std,keys=en-us -ide-version=10813 -build-path C:\Users\Merli\AppData\Local\Temp\arduino_build_91 1470 -warnings=none -build-cache C:\Users\Merli\AppData\Local\Temp\arduino_cache_53 7696 -verbose F:\arduino-1.8.13\examples\Teensy\Tutorial1\Blink\Blink.pde
Using board 'teensy41' from platform in folder: F:\arduino-1.8.13\hardware\teensy\avr
Using core 'teensy4' from platform in folder: F:\arduino-1.8.13\hardware\teensy\avr
Detecting libraries used...
"F:\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_911470\\sketch\\Blink.pde.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"F:\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_911470\\sketch\\Blink.pde.cpp" -o "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_911470\\preproc\\ctags_target_for_gcc_minus_e. cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"F:\\arduino-1.8.13\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_911470\\preproc\\ctags_target_for_gcc_minus_e. cpp"
Compiling sketch...
"F:\\arduino-1.8.13\\hardware\\teensy/../tools/precompile_helper" "F:\\arduino-1.8.13\\hardware\\teensy\\avr/cores/teensy4" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_911470" "F:\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IF:\\arduino-1.8.13\\hardware\\teensy\\avr/cores/teensy4" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_911470/pch/Arduino.h" -o "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_911470/pch/Arduino.h.gch"
Using previously compiled file: C:\Users\Merli\AppData\Local\Temp\arduino_build_91 1470\pch\Arduino.h.gch
"F:\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_b uild_911470/pch" "-IF:\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_911470\\sketch\\Blink.pde.cpp" -o "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_911470\\sketch\\Blink.pde.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\Merli\AppData\Local\Temp\arduino_cache_53 7696\core\core_190600ebdde382f4be53b25cb0d0291e.a
"F:\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax "-TF:\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy4/imxrt1062_t41.ld" -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_911470/Blink.pde.elf" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_911470\\sketch\\Blink.pde.cpp.o" "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_bu ild_911470/..\\arduino_cache_537696\\core\\core_190600ebdde38 2f4be53b25cb0d0291e.a" "-LC:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_b uild_911470" -larm_cortexM7lfsp_math -lm -lstdc++
C:\Users\Merli\AppData\Local\Temp\arduino_build_91 1470/..\arduino_cache_537696\core\core_190600ebdde382f4 be53b25cb0d0291e.a(bootdata.c.o):(.ivt+0x18): undefined reference to `_scsf'
C:\Users\Merli\AppData\Local\Temp\arduino_build_91 1470/..\arduino_cache_537696\core\core_190600ebdde382f4 be53b25cb0d0291e.a(bootdata.c.o):(.bootdata+0x4): undefined reference to `__image_size'
Oh - have to fix something - downloaded the core the core a couple of days ago let me put it back and retest - this was with only the changes for HAB from what i remember.
Ok put it fully back to 1.53 and Blink works like a charm - so may be HAB changes?
Update>Tried a T4.0 and loading blink worked no issue. The T4.1 issue was the initial beta t4.1 with flash and a psram chip.
KurtE
10-23-2020, 12:38 AM
I am trying to look at the differences in the code between the two releases and wondering about why the .vectors was removed in both the .ld files as well as bootdata.c
What I am curious about, is in previous build we have a
__attribute__ ((section(".vectors"), used))
const uint32_t vector_table[2] = {
#if defined(__IMXRT1062__)
0x20010000, // 64K DTCM for boot, ResetHandler configures stack after ITCM/DTCM setup
(uint32_t)&ResetHandler
And we pass that in to:
But the new stuff:
__attribute__ ((section(".ivt"), used))
const uint32_t ImageVectorTable[8] = {
0x402000D1, // header
(uint32_t)&ResetHandler,// program entry
0, // reserved
We have pointer directly to the ResetHandler, so who sets up the ResetHandler stack?
I do not see any differences in startup.c
jonr
I'm hoping that USB Type: Serial+Midi+Audio on T4 with Linux can get fixed. Same exact program works fine with Audio only.
PaulStoffregen
10-23-2020, 12:45 AM
Can you give me a link to the forum thread with that exact same program? And clear / quick way to test (ideally with Linux)?
Looks like I messed with Teensy 4.1 with the last minute HAB changes, so I'm probably going to make some quick fixes and package up beta2 tomorrow. If I can reproduce this problem in only a minute or two, I'll spend a little time trying to get a fix into beta2. But no clear way to quickly test means I definitely won't look at this until after beta2.
KurtE
10-23-2020, 12:50 AM
I did some hacking and my T4.1 programs now... More or less reverted some of it...
my imxrt1062_t41.ld right now looks like:
MEMORY
ITCM (rwx): ORIGIN = 0x00000000, LENGTH = 512K
DTCM (rwx): ORIGIN = 0x20000000, LENGTH = 512K
RAM (rwx): ORIGIN = 0x20200000, LENGTH = 512K
FLASH (rwx): ORIGIN = 0x60000000, LENGTH = 7936K
ERAM (rwx): ORIGIN = 0x70000000, LENGTH = 16384K
ENTRY(ImageVectorTable)
SECTIONS
.text.progmem : {
KEEP(*(.flashconfig))
FILL(0xFF)
. = ORIGIN(FLASH) + 0x1000;
KEEP(*(.ivt))
KEEP(*(.bootdata))
KEEP(*(.vectors))
KEEP(*(.startup))
*(.flashmem*)
*(.progmem*)
. = ALIGN(4);
KEEP(*(.init))
__preinit_array_start = .;
KEEP (*(.preinit_array))
__preinit_array_end = .;
__init_array_start = .;
KEEP (*(.init_array))
__init_array_end = .;
. = ALIGN(16);
} > FLASH
.text.itcm : {
. = . + 32; /* MPU to trap NULL pointer deref */
*(.fastrun)
*(.text*)
. = ALIGN(16);
} > ITCM AT> FLASH
.ARM.exidx : {
__exidx_start = .;
*(.ARM.exidx* .gnu.linkonce.armexidx.*)
__exidx_end = .;
} > ITCM AT> FLASH
.text.itcm.padding (NOLOAD) : {
. = ALIGN(32768);
} > ITCM
.data : {
*(.rodata*)
*(.data*)
. = ALIGN(16);
} > DTCM AT> FLASH
.bss ALIGN(4) : {
*(.bss*)
*(COMMON)
. = ALIGN(32);
. = . + 32; /* MPU to trap stack overflow */
} > DTCM
.bss.dma (NOLOAD) : {
*(.hab_log)
*(.dmabuffers)
. = ALIGN(32);
} > RAM
.bss.extram (NOLOAD) : {
*(.externalram)
} > ERAM
.text.csf : {
FILL(0xFF)
. = ALIGN(4);
KEEP(*(.csf))
} > FLASH
_stext = ADDR(.text.itcm);
_etext = ADDR(.text.itcm) + SIZEOF(.text.itcm) + SIZEOF(.ARM.exidx);
_stextload = LOADADDR(.text.itcm);
_sdata = ADDR(.data);
_edata = ADDR(.data) + SIZEOF(.data);
_sdataload = LOADADDR(.data);
_sbss = ADDR(.bss);
_ebss = ADDR(.bss) + SIZEOF(.bss);
_heap_start = ADDR(.bss.dma) + SIZEOF(.bss.dma);
_heap_end = ORIGIN(RAM) + LENGTH(RAM);
_itcm_block_count = (SIZEOF(.text.itcm) + SIZEOF(.ARM.exidx) + 0x7FFF) >> 15;
_flexram_bank_config = 0xAAAAAAAA | ((1 << (_itcm_block_count * 2)) - 1);
_estack = ORIGIN(DTCM) + ((16 - _itcm_block_count) << 15);
_flashimagelen = SIZEOF(.text.progmem) + SIZEOF(.text.itcm) + SIZEOF(.ARM.exidx) + SIZEOF(.data) + SIZEOF(.text.csf);
_teensy_model_identifier = 0x25;
.debug_info 0 : { *(.debug_info) }
.debug_abbrev 0 : { *(.debug_abbrev) }
.debug_line 0 : { *(.debug_line) }
.debug_frame 0 : { *(.debug_frame) }
.debug_str 0 : { *(.debug_str) }
.debug_loc 0 : { *(.debug_loc) }
My bootdata.c looks like:
//#include "imxrt.h"
#include <stdint.h>
extern void ResetHandler(void);
extern unsigned long _estack;
extern unsigned long _flashimagelen;
__attribute__ ((section(".bootdata"), used))
const uint32_t BootData[3] = {
0x60000000,
(uint32_t)&_flashimagelen,
0
__attribute__ ((section(".csf"), used))
const uint32_t hab_csf[768]; // placeholder for HAB signature
(uint32_t)vector_table, // docs are wrong, needs to be vec table, not start addr
0, // reserved
0, // dcd
(uint32_t)BootData, // abs address of boot data
(uint32_t)ImageVectorTable, // self
(uint32_t)hab_csf, // command sequence file
0 // reserved
__attribute__ ((section(".flashconfig"), used))
uint32_t FlexSPI_NOR_Config[128] = {
// 448 byte common FlexSPI configuration block, 8.6.3.1 page 223 (RT1060 rev 0)
// MCU_Flashloader_Reference_Manual.pdf, 8.2.1, Table 8-2, page 72-75
0x42464346, // Tag 0x00
0x56010000, // Version
0, // reserved
0x00020101, // columnAdressWidth,dataSetupTime,dataHoldTime,readS ampleClkSrc
0x00000000, // waitTimeCfgCommands,-,deviceModeCfgEnable
0, // deviceModeSeq
0, // deviceModeArg
0x00000000, // -,-,-,configCmdEnable
0, // configCmdSeqs 0x20
0,
0,
0,
0, // cfgCmdArgs 0x30
0,
0,
0,
0x00000000, // controllerMiscOption 0x40
0x00030401, // lutCustomSeqEnable,serialClkFreq,sflashPadType,dev iceType
0, // reserved
0, // reserved
#if defined(ARDUINO_TEENSY40)
0x00200000, // sflashA1Size 0x50
#elif defined(ARDUINO_TEENSY41)
0x00800000, // sflashA1Size 0x50
#elif defined(ARDUINO_TEENSY_MICROMOD)
0x01000000, // sflashA1Size 0x50
#else
#error "Unknow flash chip size";
0, // sflashA2Size
0, // sflashB1Size
0, // sflashB2Size
0, // csPadSettingOverride 0x60
0, // sclkPadSettingOverride
0, // dataPadSettingOverride
0, // dqsPadSettingOverride
0, // timeoutInMs 0x70
0, // commandInterval
0, // dataValidTime
0x00000000, // busyBitPolarity,busyOffset
0x0A1804EB, // lookupTable[0] 0x80
0x26043206, // lookupTable[1]
0, // lookupTable[2]
0, // lookupTable[3]
0x24040405, // lookupTable[4] 0x90
0, // lookupTable[5]
0, // lookupTable[6]
0, // lookupTable[7]
0, // lookupTable[8] 0xA0
0, // lookupTable[9]
0, // lookupTable[10]
0, // lookupTable[11]
0x00000406, // lookupTable[12] 0xB0
0, // lookupTable[13]
0, // lookupTable[14]
0, // lookupTable[15]
0, // lookupTable[16] 0xC0
0, // lookupTable[17]
0, // lookupTable[18]
0, // lookupTable[19]
0x08180420, // lookupTable[20] 0xD0
0, // lookupTable[21]
0, // lookupTable[22]
0, // lookupTable[23]
0, // lookupTable[24] 0xE0
0, // lookupTable[25]
0, // lookupTable[26]
0, // lookupTable[27]
0, // lookupTable[28] 0xF0
0, // lookupTable[29]
0, // lookupTable[30]
0, // lookupTable[31]
0x081804D8, // lookupTable[32] 0x100
0, // lookupTable[33]
0, // lookupTable[34]
0, // lookupTable[35]
0x08180402, // lookupTable[36] 0x110
0x00002004, // lookupTable[37]
0, // lookupTable[38]
0, // lookupTable[39]
0, // lookupTable[40] 0x120
0, // lookupTable[41]
0, // lookupTable[42]
0, // lookupTable[43]
0x00000460, // lookupTable[44] 0x130
0, // lookupTable[45]
0, // lookupTable[46]
0, // lookupTable[47]
0, // lookupTable[48] 0x140
0, // lookupTable[49]
0, // lookupTable[50]
0, // lookupTable[51]
0, // lookupTable[52] 0x150
0, // lookupTable[53]
0, // lookupTable[54]
0, // lookupTable[55]
0, // lookupTable[56] 0x160
0, // lookupTable[57]
0, // lookupTable[58]
0, // lookupTable[59]
0, // lookupTable[60] 0x170
0, // lookupTable[61]
0, // lookupTable[62]
0, // lookupTable[63]
0, // LUT 0: Read 0x180
0, // LUT 1: ReadStatus
0, // LUT 3: WriteEnable
0, // LUT 5: EraseSector
0, // LUT 9: PageProgram 0x190
0, // LUT 11: ChipErase
0, // LUT 15: Dummy
0, // LUT unused?
0, // LUT unused? 0x1A0
0, // LUT unused?
0, // LUT unused?
0, // LUT unused?
0, // reserved 0x1B0
0, // reserved
0, // reserved
0, // reserved
// 64 byte Serial NOR configuration block, 8.6.3.2, page 346
256, // pageSize 0x1C0
4096, // sectorSize
1, // ipCmdSerialClkFreq
0, // reserved
0x00010000, // block size 0x1D0
0, // reserved
0, // reserved
0, // reserved
0, // reserved 0x1E0
0, // reserved
0, // reserved
0, // reserved
0, // reserved 0x1F0
0, // reserved
0, // reserved
0 // reserved
Again not sure how much of these changes made the difference. Like the differences in address nor the align statement
Edit: the lines in red are the ones I changed (edit or added)
PaulStoffregen
10-23-2020, 12:52 AM
Likewise, NOW is the moment to bring up any issue you believe I might be able to fix quickly, like tonight only.
If I can't reproduce a problem within 5 minutes, I definitely will not work on it right now. But if I can, and if it's not a major rewrite or tough design trade-off to solve it, odds are good I might get a quick fix in tonight.
jonr
10-23-2020, 01:19 AM
Thanks. Link to audio issue:
https://forum.pjrc.com/threads/63733-Linux-audio-device-bug-toslink-on-T4?highlight=linux+audio
defragster
10-23-2020, 01:25 AM
SECTIONS
.text.progmem : {
FILL(0xFF)
KEEP(*(.ivt))
KEEP(*(.bootdata))
KEEP(*(.vectors))
KEEP(*(.startup))
*(.flashmem*)
#include <stdint.h>
Have running BLINK and no delay - can edit and upload to work.
I made just the edits shown above ( bootdata.c color coding was on existing code - it was the block above that was needed )
PaulStoffregen
10-23-2020, 01:37 AM
Ugh, this makes no sense to me....
But adding a single nop instruction at the beginning of ResetHandler (without the vector_table array in bootdata.c) also fixes the problem with Teensy 4.1.
PaulStoffregen
10-23-2020, 01:43 AM
Even stranger, adding a single nop instruction *later* in ResetHandler also makes Teensy 4.1 work!
Very mysterious......
defragster
10-23-2020, 03:07 AM
Nice to be in good company ... err - well not really ...
Can confirm both blinks work with this in startup.c:
unsigned int i;
asm volatile("nop": : :"memory"); // why oh why?
IOMUXC_GPR_GPR17 = (uint32_t)&_flexram_bank_config;
Also confirm the only changes made before are as in p#18 - and they were undone to see the nop work.
defragster
10-23-2020, 04:08 AM
@Paul - for this post using T_1.54b1 : Schematic-error-in-T4-0-or-T4-1-on-SD-pins (https://forum.pjrc.com/threads/63958-Schematic-error-in-T4-0-or-T4-1-on-SD-pins?p=256882&viewfull=1#post256882)
I put a 16GB SD card on a T_4.0 breakout ( the FRDM4236 ) and it worked to sdFat-Beta build and run Formatter and SdInfo.
Then with above 'nop' edit place both sketches ran and built for T_4.1 as well.
And for added fun - I restored startup.c to no added "nop"
And put back the p#18 edited files, both sketches ran and built for T_4.1 as well.
// why oh why?
// why oh why?
// why oh why?
Indeed ...
Then to complete the TriFecta of confusion: Restored the td1.54b1 sources
sdFormatter - builds and fails to show on reset after upload, and on program push programs again and won't come up
sdInfo - builds and fails to show on reset after upload, and on program push programs again and comes up running, but won't come up when unplugged/replugged to USB.
mjs513
10-23-2020, 01:25 PM
Morning all
Going to add to the confusion this morning. I retested BLINK on a T4.1 with compile options from smallest to fastest with the even stranger result that at all compile options BLINK WORKED!!!!!! Compiled and loaded. Also ran the sm_alloc simple sketch and worked as well. Note: This is with absolutely no changes to bootdata.c!
PaulStoffregen
10-23-2020, 01:50 PM
I'm pretty sure these problems are due to not-so-robust parsing of symbol table data, and lack of error detection. I'd recommend adding a boolean for each item which defaults to false. Set each boolean to true as your parser finds each number. Or maybe use a bitmask and set a particular bit as you find each item. Or if you don't want to add extra variables, at least initialize all of these with a highly unlikely non-zero number.
unsigned stext = 0;
unsigned etext = 0;
unsigned sdata = 0;
unsigned ebss = 0;
Then after you're done parsing, check the booleans / bits / numbers to detect if your parser didn't find any of the required info. Probably best to print an error message about which info wasn't found and quit. If you go on to call printnumbers() when some info is missing, you'll get wrong results.
KurtE
10-23-2020, 02:10 PM
unsigned stext = 0;
unsigned etext = 0;
unsigned sdata = 0;
unsigned ebss = 0;
Yep - it was a quick and dirty (originally from Frank :D ), that I have played with and find useful. I probably should cleaned up some. Especially how it depends on exact strings...
Also maybe look to extend it's output some to maybe print out additional information (if we have it) of if the code has variables defined up in PSRAM...
Besides may have to add section for MICROMOD ;)
EDIT: - I mentioned this app more because I noticed the change a couple of days ago and builds had stopped working with the github CORES linked into my builds and so I removed the link and went back to released version of cores and things worked again. I just assumed I must have screwed up something locally. Probably should have mentioned it then and debugged.
defragster
10-23-2020, 03:17 PM
tidbit ... processor state ... you know how cell phone near speakers makes them chatter?
So this T_4.1 sitting here in fail state - my wife and I hear this odd noise through speakers mild cyclic chatter/squeal. Fifth and final thing to resolve was turn off the non-blinking Teensy - though it was running SdInfo in a no run state IIRC.
Not sure if that might indicate anything unusual/specific about processor state.
PaulStoffregen
10-23-2020, 04:14 PM
I'm pretty sure this will be the official fix.
https://github.com/PaulStoffregen/cores/commit/a2246a5a0278a93877219e219907b79b34ecfc39
Any chance you could edit your copy of startup.c to delete the naked attribute, and then retry the SdFat info?
defragster
10-23-2020, 04:16 PM
Yes, in about 40 minutes ...
KurtE
10-23-2020, 04:35 PM
Good morning Paul,
I tried blink with T4.1 and as well my camera sketch run from sublimetext build and both compiled and programmed two differnt T4.1s
defragster
10-23-2020, 05:03 PM
td1.54b1 - reinstall - edits overwrite - default build for T_4.1 new from pack yesterday::
> sdInfo worked once? then failed, Blink failed.
Made edits startups.c : no naked @46, no NOPS @108:
> 4X blink edit and upload
> SdInfo, SdFormatter, SdInfo, SdFormatter, SdInfo
> 4X blinkWithoutDelay edit and upload
All compiles>Uploads restart to running.
<edit>: repeating SAME above on T_4.0 : no problems
defragster
10-23-2020, 06:59 PM
Another T_4.1 sketch edited/written and tested to run with repeat compile/upload fine with p#30/#27 "official fix".
Uses 8MB of PSRAM for analog time and data storage:
Sketch : Using-PSRAM-Buffer-for-saving-arrays-before-serial-printing (https://forum.pjrc.com/threads/63973-Using-PSRAM-Buffer-for-saving-arrays-before-serial-printing?p=256945&viewfull=1#post256945)
Going to go edit to use 15MB ... <edit> : That worked as expected
BTW: That cyclic Speaker tone happens with Teensy running properly? Not sure why I'm just now hearing it? Not sure I moved/changed anything ... it is sort of subtle low volume.
mjs513
10-23-2020, 07:27 PM
Been uploading and reuploading graphicstest9488 on a T4.1 with 8mb PSRAM with upload or compile issues with the change in post #27. Same results with Demosauce. Both times used SPI1 for the test.
Tried BLINK several times as well with no issues.
Also tried my OpenGL 3d model sketch with a ILI9488 on SPI - loading and reloading - no issues on compile or upload and runs fine. Using Frank's flexraminfo dump:
ILI9488_t3::begin - End
OpenGL Test!
FLASH: 112448 1.38% of 7936kB (8014016 Bytes free) FLASHMEM, PROGMEM
ITCM: 70680 0.00% of 96kB ( 27624 Bytes free) (RAM1) FASTRUN
OCRAM:
524288 Bytes (512 kB)
- 12384 Bytes (12 kB) DMAMEM
- 80040 Bytes (78 kB) Heap
431864 Bytes heap free (421 kB), 92424 Bytes OCRAM in use (90 kB).
DTCM:
425984 Bytes (416 kB)
- 168640 Bytes (164 kB) global variables
- 1324 Bytes (1 kB) max. stack so far
256020 Bytes free (250 kB), 169964 Bytes in use (165 kB).
Ran 2 of the w25n01g flash chip examples as well with no issues. Same process - at least 4x loads.
KurtE
10-23-2020, 07:37 PM
I have continued to play with the update and so far I think this takes care of it...
Note: Maybe for next (after this fix) wish we had something like this in the imxrt1062_t41.ld file:
_extram_end = ADDR(.bss.extram) + SIZEOF(.bss.extram);
I verified with the command line:
C:\Users\kurte\AppData\Local\Temp\arduino_build_Ca meraDisplay_ili9341_t3n.ino>\arduino-1.8.13\hardware\tools\arm\bin\arm-none-eabi-gcc-nm -n *.elf > foo
And my test sketch had the line: uint16_t ext_pixel[320*240] EXTMEM;
And the above command did give me the data:
70000000 B ext_pixel
70025800 B _extram_end
So if we then can add in a heap allocater for this area we can know where the sketch allocations ended...
Awhile ago we were playing with a simple allocate only function, that at the time either started at the end of EXTMEM and worked back toward the start. Or with this we could start at this memory location and work up till we get up to the end of this memory.
But again not expecting any of this is this upcoming build.
luni
10-23-2020, 07:38 PM
Would it be possible to update Bounce2 to the current version? The one packed with Teensyduino is quite outdated and misses some useful functions.
luni
10-23-2020, 07:42 PM
Here a PR for the EEPROM library which implements a check for 'non usable' types and specializes the template to enable String storage https://github.com/PaulStoffregen/EEPROM/pull/5 See also here: https://forum.pjrc.com/threads/62533-Storing-strings-in-EEPROM-and-data-changing-after-power-cycle?p=250005&viewfull=1#post250005
defragster
10-23-2020, 07:51 PM
Thanks for the reminder @KurtE - my td1.53 still has the _t41.ld edit in for this 9/15 post/edit/sketch (https://forum.pjrc.com/threads/63058-T4-1-using-PSRAM-chip-as-RAM?p=252867&viewfull=1#post252867)
That was when I tested against your malloc(EXTRAM) code.
BTW: There is the new sm_malloc library too ... Tested to work :: malloc-free-for-EXTMEM-and-DTCM (https://forum.pjrc.com/threads/63695-malloc-free-for-EXTMEM-and-DTCM?highlight=sm_malloc)
It or anything like it would need extent of pre-alloc EXTMEM to work safely.
PaulStoffregen
10-23-2020, 10:41 PM
Added.
https://github.com/PaulStoffregen/cores/commit/ea276ee57a364306562452fef42d3815fb2fbb59
Updated Bounce2.
Thanks! Merged.
defragster
10-23-2020, 11:36 PM
And I see this went in so a common base for other mem alloc can get tested:
_extram_start = ADDR(.bss.extram);
In conjunction with :: external_psram_size
KurtE
10-23-2020, 11:57 PM
Thanks Paul,
Wondering about comments in startup.c
// TODO: zero uninitialized EXTMEM variables
// TODO: copy from flash to initialize EXTMEM variables
// TODO: set up for malloc_extmem()
Do you still see this has something that you would like to get done? I for sure would like to get some heap code in, but wondering if you still wanted the initialized... Obviously interesting question on what it should do if it does not find memory...
Also wonder if it also would make sense for initialized DMAMEM variables? Obviously not for Beta2...
PaulStoffregen
10-24-2020, 01:31 AM
Yes, so much to do. But right now I'm packaging up 1.54-beta2, so we can have a much better starting point.
I considered bringing the static malloc stuff into the core library, and will probably do so this weekend. I'd really like to get a malloc_extmem() working for beta3.
Previously I tried to find a way to initialize DMAMEM variables, but ran into compiler limitations with "bss" segments which I couldn't solve.
PaulStoffregen
10-24-2020, 02:18 AM
I'm uploading 1.54-beta2 right now, but it's going very slowly. Looks like my ISP is severely throttling. ETA is looking like 2 hours to get it all uploaded.
defragster
10-24-2020, 03:42 AM
TeensyDuino 1.54 Beta 2 Published (https://forum.pjrc.com/threads/64023-Teensyduino-1-54-Beta-2)
