For my stepper motor project , i use teensy 3.6 board and program needs to understand power failure and should save the data to flash. I need to use also serial communication between teensy and PC, further teensy is powered by PC.
I decided to use a voltage supervisor but have some concerns about how to implement it.
For a solution, I am planning to design a pcb which have micro usb connector, voltage supervisor and headers that sit on teensy Usbhost pins and all other pins.
My question is can i use usbhost pins as a usb port instead of using actual micro usb port which integrated on teensy? (Can PC communicates with teensy via Usbhost pins? )
Thanks in advance.
Thanks in advance.
