chuckinteensy
Hi in there !
I work on a MIDI Controller based on Teensy and USBMIDI and I try to find out how to switch in between a Class Compliant Device and a Serial Device. Indeed, my goal is here to be able to switch my controller between a recognised Class Compliant MIDI Device and a generic serial device that communicates with a driver i write.
When i flash the Teensy with the Serial + MIDI option enabled, I get a feature I want : my computer gets the ability to communicate either with serial or MIDI at the same time but what if I would like to get only one of this option at a time..
I don't find any option to enable/disable at setup. The purpose here is to avoid any audio software to detect my board as a MIDI Device when i'm using it with other dedicated functions.
Thanks for your help !!
