Serial Monitor not showing any updates
missaghi
I'm running on windows with the update 6 from the kickstarter page.
I'm able to run sketches and it auto-reboots but I need a way to debug and the serial monitor is always blank. Testing with this sketch:
Serial.begin(38400);
Serial.println("Hello World");
Under the "tools" menu in the IDE, it allows you to select the serial port. Sometimes your comport might get un-checked cause no serial monitor output.
Try what pixelk suggests (9600 baud) and also see if there are other com ports available. I had a similar issue that was resolved by switching to COM4, even though the program uploaded and the Teensy rebooted on COM3 just fine, somehow...
