Indeed it would!
Ah, different question then. 1.6Mbytes/s or 25.6Mbits/s. 12s duration gives 19.2Mbytes.
So … SD storage is pretty much trivial, apart from the high memory prices at the moment … Streaming over USB is doable, as long as you use...
Eh?
16 bytes x 8 channels x 100,000Hz = 12.8Mbytes/s. For 12s that’s 153.6Mbytes.
Your best bet is a fast SD card with a pre-allocated file - there are many threads here about this. SD on the built-in SDIO socket can reach about 20Mbytes/s; you...
Hi I'm new to the Teensy eco-system FTR
I have a Teensy 4.1 interfaced with an EVAL-AD7606SDZ DAQ board.
I'm using Joshua Austill's AD7606 library and will be targeting a sampling rate of 100KHz.
So 16 bits x 8 channels x 100,000 = 1,600,000
I...
