I know AI info is suspect when I see it quoting stuff I wrote ;~)
The thread that @h4yn0nnym0u5e linked to has lots of good info buried in it about this issue.
Rapidly drawing larger filled rectangles like for audio amplitude bars, tended to...
Yes, anything you can do to reduce the time taken for a single display change will help. Assuming a SPI bus speed of 16MHz, keeping operations to fewer than 1000 pixels will make them take less than 1ms, very roughly. To draw a large amplitude...
Yup, AI fails again...
As noted by @jmarsh, not applicable since the SDIO slot is already in use
...so this isn't applicable either
Not stated by OP, but almost certainly already true
Entirely irrelevant, SD card streaming is not affected by...
