Hey all
Got a 4.1 Teensy.
Trial connected it to a 2.8" TFT screen I had kicking around. Seemed to be all good, but the screen was a bit beaten.
So I grabbed 2x more of what I assumed was the same screen:
https://www.amazon.co.uk/dp/B07YTWRZGR/ref=pe_27063361_487055811_TE_dp_1
So connected one up....
TFT Pins:
CS = 10
RST = N/C -1
DC = 9
MOSI = 11
SCK = 13
MISO = 12
Touchscreen Pins:
T_CLK = 13
T_CS = 8
T_DIN = 11
T_DO = 12
T_IRQ = 2
Usual pins.
Nothing. I had VCC at 5v (as my last one) but comms are at 3.3v. On the back there is a jumper (J1) that was open. This is correct.
The VCC pin feeds an onboard 3.3v regulator and the jumper shorts than out so you can run the VCC at 3.3v if you wish. So open = 5v supply.
Tested the output of the regulator. Yep, 3.3v
So.... nothing for about 2 hours. Finally, I switch the VCC to 3.3v..... still nothing (the damage is done).
Got the other screen and plugged it in and it fired up. GREAT.... the other one is a dead screen then.....
Nope. Connected the VCC to 5v (after checking J1 was open) and now nothing.
So. J1 makes no difference. You kill it with anything over 3.3v from what I can see. Technically, through no fault of mine.
Assume I have killed the driver. I hate this hobby sometimes.
So unless anyone has any ideas, that is 2x screens for the landfill (and my goddam PCB that is on the way will be wrong)
Got a 4.1 Teensy.
TFT Pins:
CS = 10
RST = N/C -1
DC = 9
MOSI = 11
SCK = 13
MISO = 12
Touchscreen Pins:
T_CLK = 13
T_CS = 8
T_DIN = 11
T_DO = 12
T_IRQ = 2
Usual pins.
