I'm trying to use 2 mono mics for a binaural signal. I have these going into a preamp and then into the line inputs on the teensy audio board. No signal is coming through. Am I mistaken in thinking the preamp will bring the mic level up to line level? If I avoid feeding the mics to the audio board and just go to the teensy, do I need the preamp? Ultimately I want be able to analyze the binaural signals so the device knows where it is relative to other sound making objects--a form of listening. Mics are on the sides of the gray cubes, ultrasonic sensor is on the front.
