// QTIMER4 timer 0 xbar 36 to EXT_CLK flexpwm via XBAR 34
// pin 8 FLEXPWM1_A3 XBAR1_OUT34
#define MMASK (1<<3) // module mask 3 for PWM1_A3
#define PRREG(x) Serial.print(#x" 0x"); Serial.println(x,HEX)
void flexpwm_init(int scale) {
// flexpwm pin 8 external clock
FLEXPWM1_OUTEN |= FLEXPWM_OUTEN_PWMA_EN(MMASK); //A3
IOMUXC_SW_MUX_CTL_PAD_GPIO_B1_00 = 6 ; // ALT6
FLEXPWM1_FCTRL0 |= FLEXPWM_FCTRL0_FLVL(MMASK); // clear
FLEXPWM1_FSTS0 = FLEXPWM_FSTS0_FFLAG(MMASK); // clear
FLEXPWM1_MCTRL |= FLEXPWM_MCTRL_CLDOK(MMASK);
FLEXPWM1_SM3CTRL2 = FLEXPWM_SMCTRL2_INDEP | FLEXPWM_SMCTRL2_CLK_SEL(1); // ext clk
FLEXPWM1_SM3CTRL = FLEXPWM_SMCTRL_FULL | FLEXPWM_SMCTRL_PRSC(0);
FLEXPWM1_SM3INIT = 0;
FLEXPWM1_SM3VAL0 = 0;
FLEXPWM1_SM3VAL1 = scale - 1; // period ticks
FLEXPWM1_SM3VAL2 = 0;
FLEXPWM1_SM3VAL3 = scale / 2;
FLEXPWM1_SM3VAL4 = 0;
FLEXPWM1_SM3VAL5 = 0;
FLEXPWM1_MCTRL |= FLEXPWM_MCTRL_LDOK(MMASK) | FLEXPWM_MCTRL_RUN(MMASK);
void xbar_connect(unsigned int input, unsigned int output)
if (input >= 88) return;
if (output >= 132) return;
volatile uint16_t *xbar = &XBARA1_SEL0 + (output / 2);
uint16_t val = *xbar;
if (!(output & 1)) {
val = (val & 0xFF00) | input;
val = (val & 0x00FF) | (input << 8);
*xbar = val;
void xbar_init() {
CCM_CCGR2 |= CCM_CCGR2_XBAR1(CCM_CCGR_ON); //turn clock on for xbara1
xbar_connect(XBARA1_IN_QTIMER4_TIMER0, XBARA1_OUT_FLEXPWM1_EXT_CLK); // 36,34
void qtmr40_init(int hz) {
int cnt, pcs = 0;
cnt = 150000000 / hz;
while (cnt > 65536) {
pcs++;
hz *= 2;
CCM_CCGR6 |= CCM_CCGR6_QTIMER4(CCM_CCGR_ON); // enable qtmr4
TMR4_CTRL0 = 0; // stop
TMR4_SCTRL0 = TMR_SCTRL_OPS | TMR_SCTRL_OEN ;
TMR4_LOAD0 = 0; // start val after compare
TMR4_COMP10 = cnt - 1; // count up to this val, interrupt, and start again
TMR4_CMPLD10 = cnt - 1;
TMR4_CTRL0 = TMR_CTRL_CM(1) | TMR_CTRL_PCS(8 + pcs) | TMR_CTRL_LENGTH | TMR_CTRL_OUTMODE(4) ; // prescale
xbar_init();
flexpwm_init(10); //divisor
qtmr40_init(10000); // 10 khz
