I have a project where I need a subject to wear a teensy while they walk. There are already a few threads that mention this, by applying 5v or 3.3v., however I am still confused exactly how to connect to the 3.3V. I am also using the ADC, therefore would like the cleanest signal possible. If I get a 3.3 LDO regulator (any recommendations?), can I just cut the pad and apply the 3.3v to the 3.3v on the teensy, or do I only cut the pad when bypassing the usb power? Can I also keep the usb function and get power from that if needed during programing etc? I am still learning all of this, and I learn best by seeing pictures or schematics, since I get so confused by all the jargon some times and therefore can't follow some of the threads that already exist on this subject. I am wondering if anyone has done something similar, and if so if they might have a picture of this set up or a schematic. My ideal setup would be when I need to collect data from a subject I would hook up the battery pack and flip a switch and start collecting data. If I ever need to change code, I can then just unplug the batteries and plug in the usb.
