philipTheTech
each Peltier draws 6 amps and I need to go from a 90% PWM to 5%. 3 Peltier's will draw from on 15V PS and i do not want the PDMs from the Teency to be in phase. I would like a 30% phase shift to distribute the current draw. for example if the PDMs are at 30% then the PS would be 6 Amp conscious. PWM rate is to be around 30KHz. the test code would have a POT that would set the PWMs from 5 to 95%. How do I fix the phase at 30%?
Philip
Philip
