Hello, I'm new here. I work in audio post-production, so I'm very interested in Teensy's audio features. Recently, I've been researching Teensy's adat output. I referred to alex6679's tutorial: https://github.com/alex6679/teensy-4-usbAudio/tree/main, but it failed to compile. Am I missing something? I've searched the forums but haven't found a solution.Is it that the compiler can't find the implementation of the AudioOutputADAT class?
Arduino IDE Version: 2.3.8
/Users/anpingyao/Library/Arduino15/packages/teensy/tools/teensy-compile/11.3.1/arm/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld: /Users/anpingyao/Library/Caches/arduino/sketches/1819E54C2346E803D744DDD9EAB3FE5F/sketch/ADAT_DrumSamplePlayer.ino.cpp.o: in function `AudioOutputADAT::AudioOutputADAT()':
/Users/anpingyao/Library/Arduino15/packages/teensy/hardware/avr/1.60.0/libraries/Audio/output_adat.h:34: undefined reference to `AudioOutputADAT::begin()'
/Users/anpingyao/Library/Arduino15/packages/teensy/tools/teensy-compile/11.3.1/arm/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld: /Users/anpingyao/Library/Caches/arduino/sketches/1819E54C2346E803D744DDD9EAB3FE5F/sketch/ADAT_DrumSamplePlayer.ino.cpp.o: in function `AudioStream::AudioStream(unsigned char, audio_block_struct**)':
/Users/anpingyao/Library/Arduino15/packages/teensy/hardware/avr/1.60.0/cores/teensy4/AudioStream.h:152: undefined reference to `vtable for AudioOutputADAT'
exit status 1
exit status 1
