add ethernet to a micromod format teensy
I'd like to chime in here as I'm working on gettin ENET2 to work on a MicroMod. I wrote a driver for QNEthernet and FNET that uses ENET2 and I can get some packets in (and out?) but it's far from reliable. This is with a LAN8720A PHY. Clock is generated on ENET2_REF_CLK2 and I see a 50 MHz signal on my scope. Even without any load the signal is very "slow" - so bad in integrity that I think the PHY continuously restarts or looses sync. Also Vpp is around 2V only (because of the clock module rails?). DSE and Speed on the pad is set to max of course - playing around with the settings don't change anything - it's either off or on but bad.
Seeing that on the MM the only physical available pin is SD_B0_01/ pin36 that can be routed from ENET2_REF_CLK2 using ALT9 (and using SION). Somewhere on a NXP thread I read that this GPIO bank is considered to be "slow" and that nobody successfully did ENET2 without external clock because of the driving and speed characteristics on this pin/pad. I can't find the URL to this thread but I remember it even mentioned the Errata. ENET_REF_CLK (ENET1) is actually not available on the MicroMod - I was thinking to use that signal as on the T41 this pin can drive the onboard PHY. I was also thinkig about using the XBAR to send the REF2 clock to a pad that is "stronger", but it seems it can't be cross barred. I also remember that another i.MX6 chip had introduced a feature to route this CLK2 to a GPIO16 for such reasons. I'm confused as you can see.
I don't need the SD card pins, so that conflict is not an issue, I also think all the other signals are fine and something is weird on the REF_CLK2.
Do you have some ideas what to do before switching to a prototype PCB with an external clock generator? can I cascade something? Can you confirm that this is a "hard-coded" problem or should this pad/pin easily drive 50 MHz with 3V swing? Or is my teensy broken?!
Are you saying you wrote two drivers, one for FNET and one for QNEthernet? Or are you saying you’re trying to get FNET working with QNEthernet? QNEthernet uses lwIP under the covers for its TCP/IP stack, not FNET, which is a different stack.
yes two drivers one for each library - but I stick the QNEthernet until I get all the settings right and might only then continue with FNET. The library is not the problem nor is it my driver (I guess) - it's either a weird hardware problem or conceptually REF_CLK2 is hard to get right on ENET2 of the MUX simply conflicts with the MM pinout. I think with an external clock this would work much better but this requires a new prototype pcb.
This seems very unlikely. SD_B0_01 is normally used for SD card where the clock is usually 48 MHz, unless the card says it's limited to only 25 MHz. SD cards work quite well, so I seriously doubt that particular pin is somehow "slow".
As a quick test, I wrote this small program to turn on the 50 MHz ethernet clock on MicroMod pin 36.
#define CLRSET(reg, clear, set) ((reg) = ((reg) & ~(clear)) | (set))
#define RMII_PAD_CLOCK          0x00E9
  Serial.print("Ethernet Testing");
  Serial.print("----------------\n");
#if 0
  pinMode(36, OUTPUT);
  while (1) {
    digitalWriteFast(36, HIGH);
    delayNanoseconds(100);
    digitalWriteFast(36, LOW);
  CCM_CCGR7 |= CCM_CCGR7_ENET2(CCM_CCGR_ON);
  // configure PLL6 for 50 MHz, pg 1173
  CCM_ANALOG_PLL_ENET_CLR = CCM_ANALOG_PLL_ENET_POWERDOWN
                            | CCM_ANALOG_PLL_ENET_BYPASS | 0x0F;
  CCM_ANALOG_PLL_ENET_SET = CCM_ANALOG_PLL_ENET_ENABLE | CCM_ANALOG_PLL_ENET_BYPASS
                            | CCM_ANALOG_PLL_ENET_ENET2_REF_EN | CCM_ANALOG_PLL_ENET_ENET_25M_REF_EN
                            | CCM_ANALOG_PLL_ENET_ENET2_DIV_SELECT(1) | CCM_ANALOG_PLL_ENET_DIV_SELECT(1);
  while (!(CCM_ANALOG_PLL_ENET & CCM_ANALOG_PLL_ENET_LOCK)) ; // wait for PLL lock
  CCM_ANALOG_PLL_ENET_CLR = CCM_ANALOG_PLL_ENET_BYPASS;
  Serial.printf("PLL6 = %08X (should be 80202001)\n", CCM_ANALOG_PLL_ENET);
  // configure REFCLK to be driven as output by PLL6, pg 326
  CLRSET(IOMUXC_GPR_GPR1, IOMUXC_GPR_GPR1_ENET2_CLK_SEL,
         IOMUXC_GPR_GPR1_ENET2_TX_CLK_DIR | IOMUXC_GPR_GPR1_ENET_IPG_CLK_S_EN);
  Serial.printf("GPR1 = %08X\n", IOMUXC_GPR_GPR1);
  // configure pin to output clock
  IOMUXC_SW_PAD_CTL_PAD_GPIO_SD_B0_01 = RMII_PAD_CLOCK;
  IOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_01 = 9 | 0x10; // ENET2_REF_CLK2  SD_B0_01 Alt9, pg 537
  Serial.println("done");
Here is the waveform my oscilloscope sees on pin 36.
My scope is also only rated for 200 MHz bandwidth, so it's a bit challenged to really measure 50 MHz. Still, you can see the waveform is pretty solidly over 3 volts (scales is 2 volts/division) for the logic high time and near 0 volts for logic low. Looks like a plenty strong enough digital signal.
Measuring high frequency signals is always a bit tricky. Even a relatively short ground wire causes quite a bit of ringing and distortion. Here's a photo of my attempt to minimize ground lead length. There's still some overshoot and ringing, but this is the best I'm going to do for a quick test. Hopefully it's good enough.
If you try this code, you might adjust the RMII_PAD_CLOCK setting. 3 of the bits control the pin's drive strength. You also want to make sure you have fast slew rate configured.
#if 0
  while (1) {
ok that's very helpful. Thanks a lot! I will try that tomorrow and see the clock on my scope. I'm aware of the probing, grounding etc. issues and still can improve my setup in this regard. The thing is, RXD0, RXD1, TXD0, TXD1 and the other signals look much better - it's only the clock that worries me... shouldn't they also be near 50 MHz?
If the data pins are changing at maximum possible rate, that is alternating 0s and 1s on every clock cycle, you'd expect to see 25 MHz square waves because the date changes once for each full cycle of the 50 MHz clock.
You can also see in the screenshot that my scope measured 49.998 MHz for the clock signal. But my scope isn't connected to a high accurate time base, so I wouldn't necessarily take that to mean the clock is off by 2 kHz.
However, I do have a frequency counter which is connected to a high accuracy GPS disciplined over oscillator.
Turns out my scope's frequency reference is probably pretty good afterall.
In other news, MicroMod pin 36 is able to drive about 6 feet of coax cable to reach the frequency counter...
[SOLVED SEE BELOW]
Many thanks for your valuable information. I have now a solid clock and packets going in. It was a combination of ground bounce and probing (forgot to switch to 1:10). The code was fine. My lab setup was improved and yes the clock is good enough now.
However, and I think I might need Shawn, I don’t get an IP. DHCP Client is running and sending raw frames (enabled in the options) at least toggles the TX lines and TX enable. PHY LED is even dancing to my sending rhythm. Upon starting the program I see (on the TXEN) two frames being sent that are not from me, so I guess that could be arp with dhcp. But I don’t get an IP and I‘m not sure if what I send is correctly placed on the media (kinda hard to measure). Using QN’s Frame Loopback I don’t see my own frames neither.
Could this be a skew dataline in regards to phase lock to the clock? That would explain that my scope sees TX activity but it’s simply not a well formed TX frame. Or my ENET2 port misses something for TX but why do I then see TX-EN/D0/D1 activity.
If you can think of anything that I should try to circle in to the problem, that would be great before I will share the code.
Thanks!
EDIT:
using direct connection to my laptop running WireShark it turns out my raw frames are correctly transmitted. It's as soon as I go Layer 3 no packets are sent as if lwip wouldn't be registered to form a packet. Do I have to do anything else to QN and lwip to register my driver? Again, Layer 2 is working.
EDIT2:
I forgot to set the administrative link up/down in my driver towards the upper layer (lwip) and was only setting it in my driver - therefore raw frames were working but no L3. It's running now! Will consolidate everything and post again.
While I have finished my work with great success. One last thing bugs me:
I need to use:
C:
ENET2_MSCR = ENET_MSCR_MII_SPEED(0x33);  // gives around 1.4 MHz
while the original divider sets a clock way too high too around 7.5MHz
C:
ENET2_MSCR = ENET_MSCR_MII_SPEED(9);  // gives around 7.5 MHz why?!?!? - maximum is 2.5 MHz
why?!
anyway, I wrote this message in the discussion threat on github of ssilverman/QNEthernet:
success! I managed to get ENET2 working on MicroMod with a LAN8720A PHY. I will also design a custom board with a DP83825IRMQR PHY (the same as on the Teensy 4.1) which needs less external components (the mdi is voltage driven and it doesn't need external resistors) and it also needs other register and strap config.
For the LAN8720A an additional RESET line is needed that the main program should set towards QNEthernet. For the DP83825 two additional lines are needed. This is because on the teensy 4.1 onboard PHY these lines are predefines whereas on MircoMod the user can pick any two GPIO pins that are available on his project. The pins used on the 4.1 board are not brought out on the MicroMod so a value of the pins must be set and we can't assume defaults. For the LAN8720 with 1 RESET line I was tempted to use driver_set_chip_select_pin() which is available on the driver interface but maybe we should support Varargs on the init() to take all the pins depending on the PHY. This is a minor work put best in the hands of you as it changes things outside the driver folder.
Also I created a #define QNETHERNET_INTERNAL_DRIVER_TEENSYMM guard on my additional driver file driver_teensymm.c and driver_teensymm.h.
Then in lwip_driver.h the driver selection was extended to:
C:
// Select a driver
#if defined(QNETHERNET_DRIVER_W5500)
#include "drivers/driver_w5500.h"
#define QNETHERNET_INTERNAL_DRIVER_W5500
#elif defined(ARDUINO_TEENSY41)
#include "drivers/driver_teensy41.h"
#define QNETHERNET_INTERNAL_DRIVER_TEENSY41
#elif defined(ARDUINO_TEENSY_MICROMOD)
#include "drivers/driver_teensymm.h"
#else
#include "drivers/driver_unsupported.h"
#define QNETHERNET_INTERNAL_DRIVER_UNSUPPORTED
#endif  // Driver selection
When I have a clear guideance on how to manage the additional user pins, I can push my code.
I need to use:
C:
C:
why?!
C:
// Select a driver
#else
Hey, nice work! This Teensy MM driver, is it something you can share?
I need to use:
C:
C:
why?!
C:
// Select a driver
#else
Hi, really great work.
I would also love to get this working on my MM board. Could you kindly share it?
I solved it on my own and here is the code for it but there is a BUT.
In my case I have a custom board that I needed to change the RST and INT pins on, so that's what I did in a custom driver file.
You'll have to do the same or wait for someone to drop you the Micromod files.
But this is at least a little step in the right direction:
In the QNethernet folder, go to src/drivers/ folder, in there you have .cpp and .h files for different boards. Basically copy one set of those and then customize to your needs. Then go to src/driver_select.h, this is the file that includes the drivers. In here you need to modify a little to include your driver file.
Here is my driver, but once again, my only changes are to set custom RST and INT pins.
driver_teensy_custom.cpp
// SPDX-FileCopyrightText: (c) 2021-2024 Shawn Silverman <shawn@pobox.com>
// SPDX-License-Identifier: AGPL-3.0-or-later
// driver_teensy41.c contains the Teensy 4.1 Ethernet interface implementation.
// Based on code from manitou48 and others:
// https://github.com/PaulStoffregen/teensy41_ethernet
// This file is part of the QNEthernet library.
// CUSTOM DRIVER FOR CUSTOM "TEENSY" BASED BOARDS USING OTHER INT AND RST PINS
// MODIFIED BY DOGBONE06 @ PJRC FORUM
#include "lwip_driver.h"
#if defined(BEEFCAKE)
// C includes
#include <stdalign.h>
#include <stdatomic.h>
#include <string.h>
#include <avr/pgmspace.h>
#include <core_pins.h>
#include <imxrt.h>
#include "lwip/arch.h"
#include "lwip/err.h"
#include "lwip/stats.h"
// https://forum.pjrc.com/threads/60532-Teensy-4-1-Beta-Test?p=237096&viewfull=1#post237096
// https://github.com/PaulStoffregen/teensy41_ethernet/blob/master/teensy41_ethernet.ino
// [PHY Datasheet](https://www.pjrc.com/teensy/dp83825i.pdf)
// [i.MX RT1062 Manual](https://www.pjrc.com/teensy/IMXRT1060RM_rev3.pdf)
//  Defines
#define GPIO_PAD_OUTPUT (0                         \
    /* HYS_0_Hysteresis_Disabled */                \
    /* PUS_0_100K_Ohm_Pull_Down */                 \
    /* PUE_0_Keeper */                             \
    /* PKE_0_Pull_Keeper_Disabled */               \
    /* ODE_0_Open_Drain_Disabled */                \
    | IOMUXC_PAD_SPEED(0)  /* SPEED_0_low_50MHz */ \
    | IOMUXC_PAD_DSE(7)    /* DSE_7_R0_7 */        \
    /* SRE_0_Slow_Slew_Rate */)
    // HYS:0 PUS:00 PUE:0 PKE:0 ODE:0 000 SPEED:00 DSE:111 00 SRE:0
    // 0x0038
#define GPIO_MUX 5
    // SION:0 MUX_MODE:0101
    // ALT5 (GPIO)
// Stronger pull-up for the straps, but even this might not be strong enough.
#define STRAP_PAD_PULLUP (0                                \
    | IOMUXC_PAD_PUS(3)    /* PUS_3_22K_Ohm_Pull_Up */     \
    | IOMUXC_PAD_PUE       /* PUE_1_Pull */                \
    | IOMUXC_PAD_PKE       /* PKE_1_Pull_Keeper_Enabled */ \
    | IOMUXC_PAD_DSE(5)    /* DSE_5_R0_5 */                \
    /* SRE_0_Slow_Slew_Rate */                             \
    // HYS:0 PUS:11 PUE:1 PKE:1 ODE:0 000 SPEED:00 DSE:101 00 SRE:0
    // 0xF028
#define MDIO_PAD_PULLUP (0                                 \
    | IOMUXC_PAD_ODE       /* ODE_1_Open_Drain_Enabled */  \
    | IOMUXC_PAD_SRE       /* SRE_1_Fast_Slew_Rate */      \
    // HYS:0 PUS:11 PUE:1 PKE:1 ODE:1 000 SPEED:00 DSE:101 00 SRE:1
    // 0xF829
    // PHY docs suggest up to 2.2kohms, but this is what we got. It has an
    // internal 10k. It should cover what we need, including 20% error.
    // MDIO requires a 1.5k to 10k pull-up.
#define MDIO_MUX 0
    // SION:0 MUX_MODE:0000
    // ALT0
#define RMII_PAD_PULLDOWN (0                               \
    | IOMUXC_PAD_PUS(0)    /* PUS_0_100K_Ohm_Pull_Down */  \
    | IOMUXC_PAD_SPEED(3)  /* SPEED_3_max_200MHz */        \
    // HYS:0 PUS:00 PUE:1 PKE:1 ODE:0 000 SPEED:11 DSE:101 00 SRE:1
    // 0x30E9
#define RMII_PAD_PULLUP (0                                 \
    | IOMUXC_PAD_PUS(2)    /* PUS_2_100K_Ohm_Pull_Up */    \
    // HYS:0 PUS:10 PUE:1 PKE:1 ODE:0 000 SPEED:11 DSE:101 00 SRE:1
    // 0xB0E9
#define RMII_PAD_SIGNAL (0                            \
    | IOMUXC_PAD_DSE(6)    /* DSE_6_R0_6 */           \
    // HYS:0 PUS:00 PUE:0 PKE:0 ODE:0 000 SPEED:11 DSE:101 00 SRE:1
    // 0x00E9
#define RMII_PAD_CLOCK (0                             \
    // HYS:0 PUS:00 PUE:0 PKE:0 ODE:0 000 SPEED:00 DSE:110 00 SRE:1
    // 0x0031
#define RMII_MUX_CLOCK (6 | 0x10)
      // SION:1 MUX_MODE:0110
      // ALT6
#define RMII_MUX 3
    // SION:0 MUX_MODE:0011
    // ALT3
#define RX_SIZE 5
#define TX_SIZE 5
#define IRQ_PRIORITY 64
// Buffer size for transferring to and from the Ethernet MAC. The frame size is
// either 1518 or 1522, assuming a 1500-byte payload, depending on whether VLAN
// support is desired. VLAN support requires an extra 4 bytes. The ARM cache
// management functions require 32-bit alignment, but the ENETx_MRBR max.
// receive buffer size register says that the RX buffer size must be a multiple
// of 64 and >= 256.
// [1518 or 1522 made into a multiple of 32 for ARM cache flush sizing and a
// multiple of 64 for ENETx_MRBR.]
// NOTE: BUF_SIZE will be 1536 whether we use 1518 or 1522 (plus ETH_PAD_SIZE)
// * Padding(2)
// * Destination(6) + Source(6) + VLAN tag(2) + VLAN info(2) + Length/Type(2) +
//   Payload(1500) + FCS(4)
#define BUF_SIZE (((ETH_PAD_SIZE + 6 + 6 + 2 + 2 + 2 + 1500 + 4) + 63) & ~63)
#if !QNETHERNET_BUFFERS_IN_RAM1
#define MULTIPLE_OF_32(x) (((x) + 31) & ~31)
#define BUFFER_DMAMEM DMAMEM
#else
#endif  // !QNETHERNET_BUFFERS_IN_RAM1
//  Types
// Defines the control and status region of the receive buffer descriptor.
typedef enum _enet_rx_bd_control_status {
  kEnetRxBdEmpty           = 0x8000U,  // Empty bit
  kEnetRxBdRxSoftOwner1    = 0x4000U,  // Receive software ownership
  kEnetRxBdWrap            = 0x2000U,  // Wrap buffer descriptor
  kEnetRxBdRxSoftOwner2    = 0x1000U,  // Receive software ownership
  kEnetRxBdLast            = 0x0800U,  // Last BD in the frame (L bit)
  kEnetRxBdMiss            = 0x0100U,  // Miss; in promiscuous mode; needs L
  kEnetRxBdBroadcast       = 0x0080U,  // Broadcast
  kEnetRxBdMulticast       = 0x0040U,  // Multicast
  kEnetRxBdLengthViolation = 0x0020U,  // Receive length violation; needs L
  kEnetRxBdNonOctet        = 0x0010U,  // Receive non-octet aligned frame; needs L
  kEnetRxBdCrc             = 0x0004U,  // Receive CRC or frame error; needs L
  kEnetRxBdOverrun         = 0x0002U,  // Receive FIFO overrun; needs L
  kEnetRxBdTrunc           = 0x0001U   // Frame is truncated
} enet_rx_bd_control_status_t;
// Defines the control extended region1 of the receive buffer descriptor.
typedef enum _enet_rx_bd_control_extend0 {
  kEnetRxBdIpHeaderChecksumErr = 0x0020U,  // IP header checksum error; needs L
  kEnetRxBdProtocolChecksumErr = 0x0010U,  // Protocol checksum error; needs L
  kEnetRxBdVlan                = 0x0004U,  // VLAN; needs L
  kEnetRxBdIpv6                = 0x0002U,  // Ipv6 frame; needs L
  kEnetRxBdIpv4Fragment        = 0x0001U,  // Ipv4 fragment; needs L
} enet_rx_bd_control_extend0_t;
// Defines the control extended region2 of the receive buffer descriptor.
typedef enum _enet_rx_bd_control_extend1 {
  kEnetRxBdMacErr    = 0x8000U,  // MAC error; needs L
  kEnetRxBdPhyErr    = 0x0400U,  // PHY error; needs L
  kEnetRxBdCollision = 0x0200U,  // Collision; needs L
  kEnetRxBdUnicast   = 0x0100U,  // Unicast frame; valid even if L is not set
  kEnetRxBdInterrupt = 0x0080U,  // Generate RXB/RXF interrupt
} enet_rx_bd_control_extend1_t;
// Defines the control status of the transmit buffer descriptor.
typedef enum _enet_tx_bd_control_status {
  kEnetTxBdReady        = 0x8000U,  // Ready bit
  kEnetTxBdTxSoftOwner1 = 0x4000U,  // Transmit software ownership
  kEnetTxBdWrap         = 0x2000U,  // Wrap buffer descriptor
  kEnetTxBdTxSoftOwner2 = 0x1000U,  // Transmit software ownership
  kEnetTxBdLast         = 0x0800U,  // Last BD in the frame (L bit)
  kEnetTxBdTransmitCrc  = 0x0400U,  // Transmit CRC; needs L
} enet_tx_bd_control_status_t;
// Defines the control extended region1 of the transmit buffer descriptor.
typedef enum _enet_tx_bd_control_extend0 {
  kEnetTxBdTxErr              = 0x8000U,  // Transmit error; needs L
  kEnetTxBdTxUnderflowErr     = 0x2000U,  // Underflow error; needs L
  kEnetTxBdExcessCollisionErr = 0x1000U,  // Excess collision error; needs L
  kEnetTxBdTxFrameErr         = 0x0800U,  // Frame with error; needs L
  kEnetTxBdLatecollisionErr   = 0x0400U,  // Late collision error; needs L
  kEnetTxBdOverflowErr        = 0x0200U,  // Overflow error; needs L
  kEnetTxTimestampErr         = 0x0100U,  // Timestamp error; needs L
} enet_tx_bd_control_extend0_t;
// Defines the control extended region2 of the transmit buffer descriptor.
typedef enum _enet_tx_bd_control_extend1 {
  kEnetTxBdTxInterrupt   = 0x4000U,  // Transmit interrupt; all BDs
  kEnetTxBdTimestamp     = 0x2000U,  // Transmit timestamp flag; all BDs
  kEnetTxBdProtChecksum  = 0x1000U,  // Insert protocol specific checksum; all BDs
  kEnetTxBdIpHdrChecksum = 0x0800U,  // Insert IP header checksum; all BDs
} enet_tx_bd_control_extend1_t;
typedef struct {
  uint16_t length;
  uint16_t status;
  void     *buffer;
  uint16_t extend0;
  uint16_t extend1;
  uint16_t checksum;
  uint8_t  prototype;
  uint8_t  headerlen;
  uint16_t unused0;
  uint16_t extend2;
  uint32_t timestamp;
  uint16_t unused1;
  uint16_t unused2;
  uint16_t unused3;
  uint16_t unused4;
} enetbufferdesc_t;
typedef enum _enet_init_states {
  kInitStateStart,           // Unknown hardware
  kInitStateNoHardware,      // No PHY
  kInitStateHasHardware,     // Has PHY
  kInitStatePHYInitialized,  // PHY's been initialized
  kInitStateInitialized,     // PHY and MAC have been initialized
} enet_init_states_t;
//  Internal Variables
// Ethernet buffers
alignas(64) static enetbufferdesc_t s_rxRing[RX_SIZE];
alignas(64) static enetbufferdesc_t s_txRing[TX_SIZE];
alignas(64) static uint8_t s_rxBufs[RX_SIZE * BUF_SIZE] BUFFER_DMAMEM;
alignas(64) static uint8_t s_txBufs[TX_SIZE * BUF_SIZE] BUFFER_DMAMEM;
static volatile enetbufferdesc_t *s_pRxBD = &s_rxRing[0];
static volatile enetbufferdesc_t *s_pTxBD = &s_txRing[0];
// Misc. internal state
static atomic_flag s_rxNotAvail       = ATOMIC_FLAG_INIT;
static enet_init_states_t s_initState = kInitStateStart;
// PHY status, polled
static int s_checkLinkStatusState = 0;
static bool s_linkSpeed10Not100 = false;
static bool s_linkIsFullDuplex  = false;
static bool s_linkIsCrossover   = false;
// Forward declarations
static void enet_isr(void);
//  PHY I/O
// PHY register definitions
#define PHY_REGCR  0x0D
#define PHY_ADDAR  0x0E
#define PHY_LEDCR  0x18
#define PHY_RCSR   0x17
#define PHY_BMSR   0x01
#define PHY_PHYSTS 0x10
#define PHY_BMCR   0x00
#define PHY_ANAR   0x04
#define PHY_PHYCR  0x19
#define PHY_LEDCR_BLINK_RATE_20Hz (0 << 9)
#define PHY_LEDCR_BLINK_RATE_10Hz (1 << 9)
#define PHY_LEDCR_BLINK_RATE_5Hz  (2 << 9)
#define PHY_LEDCR_BLINK_RATE_2Hz  (3 << 9)
#define PHY_LEDCR_LED_LINK_POLARITY_ACTIVE_HIGH (1 << 7)
#define PHY_LEDCR_VALUE (PHY_LEDCR_BLINK_RATE_10Hz | \
                         PHY_LEDCR_LED_LINK_POLARITY_ACTIVE_HIGH)
#define PHY_RCSR_RMII_CLOCK_SELECT_50MHz               (1 << 7)
#define PHY_RCSR_RECEIVE_ELASTICITY_BUFFER_SIZE_14_BIT (0 << 0)
#define PHY_RCSR_RECEIVE_ELASTICITY_BUFFER_SIZE_2_BIT  (1 << 0)
#define PHY_RCSR_RECEIVE_ELASTICITY_BUFFER_SIZE_6_BIT  (2 << 0)
#define PHY_RCSR_RECEIVE_ELASTICITY_BUFFER_SIZE_10_BIT (3 << 0)
#define PHY_RCSR_VALUE (PHY_RCSR_RMII_CLOCK_SELECT_50MHz | \
                        PHY_RCSR_RECEIVE_ELASTICITY_BUFFER_SIZE_2_BIT)
#define PHY_BMSR_LINK_STATUS (1 << 2)  /* 0: No link, 1: Valid link */
#define PHY_PHYSTS_LINK_STATUS   (1 <<  0)  /* 0: No link, 1: Valid link */
#define PHY_PHYSTS_SPEED_STATUS  (1 <<  1)  /* 0: 100Mbps, 1: 10Mbps */
#define PHY_PHYSTS_DUPLEX_STATUS (1 <<  2)  /* 0: Half-Duplex, 1: Full-Duplex */
#define PHY_PHYSTS_MDI_MDIX_MODE (1 << 14)  /* 0: Normal, 1: Swapped */
// Reads a PHY register (using MDIO & MDC signals) and returns whether
// continuation is needed (not complete). If continuation is needed, then this
// should be called again with 'cont' set to true. If this is the first call,
// then 'cont' should be set to false.
static bool mdio_read_nonblocking(uint16_t regaddr, uint16_t data[static 1],
                                  bool cont) {
  if (!cont) {
    ENET_EIR = ENET_EIR_MII;  // Clear status
    ENET_MMFR = ENET_MMFR_ST(1) | ENET_MMFR_OP(2) | ENET_MMFR_PA(0/*phyaddr*/) |
                ENET_MMFR_RA(regaddr) | ENET_MMFR_TA(2);
  if ((ENET_EIR & ENET_EIR_MII) == 0) {  // Waiting takes on the order of 8.8-8.9us
    return true;
  *data = ENET_MMFR_DATA(ENET_MMFR);
  // printf("mdio read (%04xh): %04xh\r\n", regaddr, data);
  return false;
// Blocking MDIO read.
uint16_t mdio_read(uint16_t regaddr) {
  uint16_t data;
  bool doCont = false;
  do {
    doCont = mdio_read_nonblocking(regaddr, &data, doCont);
  } while (doCont);
  return data;
// Writes a PHY register (using MDIO & MDC signals) and returns whether
static bool mdio_write_nonblocking(uint16_t regaddr, uint16_t data, bool cont) {
  if (!cont) {
    ENET_MMFR = ENET_MMFR_ST(1) | ENET_MMFR_OP(1) | ENET_MMFR_PA(0/*phyaddr*/) |
                ENET_MMFR_RA(regaddr) | ENET_MMFR_TA(2) |
                ENET_MMFR_DATA(data);
    return true;
  // printhex("mdio write (%04xh): %04xh\r\n", regaddr, data);
  return false;
// Blocking MDIO write.
void mdio_write(uint16_t regaddr, uint16_t data) {
  do {
    doCont = mdio_write_nonblocking(regaddr, data, doCont);
  } while (doCont);
//  Low-Level
// Enables the Ethernet-related clocks. See also disable_enet_clocks().
FLASHMEM static void enable_enet_clocks(void) {
  // Enable the Ethernet clock
  CCM_CCGR1 |= CCM_CCGR1_ENET(CCM_CCGR_ON);
  // Configure PLL6 for 50 MHz (page 1112)
  CCM_ANALOG_PLL_ENET_SET = CCM_ANALOG_PLL_ENET_BYPASS;
  CCM_ANALOG_PLL_ENET_CLR = 0
                            | CCM_ANALOG_PLL_ENET_BYPASS_CLK_SRC(3)
                            | CCM_ANALOG_PLL_ENET_ENET2_DIV_SELECT(3)
                            | CCM_ANALOG_PLL_ENET_DIV_SELECT(3)
  CCM_ANALOG_PLL_ENET_SET = 0
                            // | CCM_ANALOG_PLL_ENET_ENET2_REF_EN
                            // | CCM_ANALOG_PLL_ENET_ENET2_DIV_SELECT(1)
  CCM_ANALOG_PLL_ENET_CLR = CCM_ANALOG_PLL_ENET_POWERDOWN;
  while ((CCM_ANALOG_PLL_ENET & CCM_ANALOG_PLL_ENET_LOCK) == 0) {
    // Wait for PLL lock
  // printf("PLL6 = %08" PRIX32 "h (should be 80202001h)\n", CCM_ANALOG_PLL_ENET);
  // Configure REFCLK to be driven as output by PLL6 (page 325)
         IOMUXC_GPR_GPR1_ENET1_CLK_SEL | IOMUXC_GPR_GPR1_ENET_IPG_CLK_S_EN,
         IOMUXC_GPR_GPR1_ENET1_TX_CLK_DIR);
// Disables everything enabled with enable_enet_clocks().
FLASHMEM static void disable_enet_clocks(void) {
  // Configure REFCLK
  CLRSET(IOMUXC_GPR_GPR1, IOMUXC_GPR_GPR1_ENET1_TX_CLK_DIR, 0);
  // Stop the PLL (first bypassing)
  CCM_ANALOG_PLL_ENET = 0
                        | CCM_ANALOG_PLL_ENET_BYPASS         // Reset to default
  // Disable the clock for ENET
  CCM_CCGR1 &= ~CCM_CCGR1_ENET(CCM_CCGR_ON);
// Configures all the pins necessary for communicating with the PHY.
FLASHMEM static void configure_phy_pins(void) {
  // Configure strap pins
  // Note: The pull-up may not be strong enough
  // Note: All the strap pins have an internal pull-down of 9kohm +/-25%
  // Table 8. PHY Address Strap Table (page 39)
  IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_04 = RMII_PAD_PULLDOWN;  // PhyAdd[0] = 0 (RX_D0, pin 18) (page 723)
  IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_06 = RMII_PAD_PULLDOWN;  // PhyAdd[1] = 0 (CRS_DV, pin 20) (page 726)
  // Table 9. RMII MAC Mode Strap Table (page 39)
  IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_05 = STRAP_PAD_PULLUP;   // UP; Master/Slave = RMII Slave Mode (RX_D1, pin 17) (page 724)
  // Not connected: 50MHzOut/LED2 (pin 2, pull-down): RX_DV_En: Pin 20 is configured as CRS_DV
  // Table 10. Auto_Neg Strap Table (page 39)
  IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_11 = RMII_PAD_PULLDOWN;  // Auto MDIX Enable (RX_ER, pin 22) (page 734)
  // Not connected to a processor pin: LED0 (pin 4, pull-down): ANeg_Dis: Auto Negotiation Enable
  // Configure PHY-connected Reset and Power pins as outputs
  // PHY spec. page 3
  // Note: Teensyduino already configures GPIO2 as its fast counterpart, GPIO1
  IOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_05 = GPIO_PAD_OUTPUT;  // INTR/PWRDN, pin 3 (page 714)
  IOMUXC_SW_PAD_CTL_PAD_GPIO_AD_B1_04 = GPIO_PAD_OUTPUT;  // RST_N, pin 5 (page 713)
  IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_05 = GPIO_MUX;  // Power (INT, pin 3) (GPIO2_IO15, page 519)
  IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_04 = GPIO_MUX;  // Reset (RST, pin 5) (GPIO2_IO14, page 518)
  GPIO1_GDIR |= (1 << 21) | (1 << 20);
  GPIO1_DR_CLEAR = (1 << 21);  // Power down
  GPIO1_DR_SET   = (1 << 20);  // Start with reset de-asserted so that it can be
                               // asserted for a specific duration
  // Configure the MDIO and MDC pins
  IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_15 = MDIO_PAD_PULLUP;  // MDIO
  IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_14 = RMII_PAD_PULLUP;  // MDC
  IOMUXC_SW_MUX_CTL_PAD_GPIO_B1_15 = MDIO_MUX;  // MDIO pin 15 (ENET_MDIO of enet, page 535)
  IOMUXC_SW_MUX_CTL_PAD_GPIO_B1_14 = MDIO_MUX;  // MDC pin 16 (ENET_MDC of enet, page 534)
  IOMUXC_ENET_MDIO_SELECT_INPUT = 2;  // GPIO_B1_15_ALT0 (page 791)
      // DAISY:10
// Configures all the RMII pins. This should be called after initializing
// the PHY.
FLASHMEM static void configure_rmii_pins(void) {
  // The NXP SDK and original Teensy 4.1 example code use pull-ups
  IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_04 = RMII_PAD_PULLUP;  // Reset this (RXD0)
  IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_05 = RMII_PAD_PULLUP;  // Reset this (RXD1)
  IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_06 = RMII_PAD_PULLUP;  // Reset this (RXEN)
  IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_11 = RMII_PAD_PULLUP;  // Reset this (RXER)
  IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_07 = RMII_PAD_PULLUP;  // TXD0 (PHY has internal pull-down)
  IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_08 = RMII_PAD_PULLUP;  // TXD1 (PHY has internal pull-down)
  IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_09 = RMII_PAD_PULLUP;  // TXEN (PHY has internal pull-down)
  IOMUXC_SW_MUX_CTL_PAD_GPIO_B1_04 = RMII_MUX;  // RXD0 pin 18 (ENET_RX_DATA00 of enet, page 524)
  IOMUXC_SW_MUX_CTL_PAD_GPIO_B1_05 = RMII_MUX;  // RXD1 pin 17 (ENET_RX_DATA01 of enet, page 525)
  IOMUXC_SW_MUX_CTL_PAD_GPIO_B1_11 = RMII_MUX;  // RXER pin 22 (ENET_RX_ER of enet, page 531)
  IOMUXC_SW_MUX_CTL_PAD_GPIO_B1_06 = RMII_MUX;  // RXEN pin 20 (ENET_RX_EN of enet, page 526)
  IOMUXC_SW_MUX_CTL_PAD_GPIO_B1_09 = RMII_MUX;  // TXEN pin  1 (ENET_TX_EN of enet, page 529)
  IOMUXC_SW_MUX_CTL_PAD_GPIO_B1_07 = RMII_MUX;  // TXD0 pin 23 (ENET_TX_DATA00 of enet, page 527)
  IOMUXC_SW_MUX_CTL_PAD_GPIO_B1_08 = RMII_MUX;  // TXD1 pin 24 (ENET_TX_DATA01 of enet, page 528)
  IOMUXC_ENET_IPG_CLK_RMII_SELECT_INPUT = 1;  // GPIO_B1_10_ALT6 (page 791)
      // DAISY:1
  IOMUXC_ENET0_RXDATA_SELECT_INPUT = 1;  // GPIO_B1_04_ALT3 (page 792)
  IOMUXC_ENET1_RXDATA_SELECT_INPUT = 1;  // GPIO_B1_05_ALT3 (page 793)
  IOMUXC_ENET_RXEN_SELECT_INPUT    = 1;  // GPIO_B1_06_ALT3 (page 794)
  IOMUXC_ENET_RXERR_SELECT_INPUT   = 1;  // GPIO_B1_11_ALT3 (page 795)
// Initialization and check for hardware. This does nothing if the init state
// isn't at START or HAS_HARDWARE. After this function returns, the init state
// will either be NO_HARDWARE or PHY_INITIALIZED, unless it wasn't START or
// HAS_HARDWARE when called.
FLASHMEM static void init_phy(void) {
  if (s_initState != kInitStateStart && s_initState != kInitStateHasHardware) {
    return;
  enable_enet_clocks();
  configure_phy_pins();
  // Note: Ensure the clock is present at the PHY (XI) at power up
  IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_10 = RMII_PAD_CLOCK;
  IOMUXC_SW_MUX_CTL_PAD_GPIO_B1_10 = RMII_MUX_CLOCK;  // REFCLK (XI) pin 13 (ENET_REF_CLK of enet, page 530)
  ENET_MSCR = ENET_MSCR_MII_SPEED(9);  // Internal module clock frequency = 50MHz
  GPIO1_DR_SET   = (1 << 21);  // Power on
  delay(50);                   // Just in case; unsure if needed
  GPIO1_DR_CLEAR = (1 << 20);  // Reset
  delayMicroseconds(25);       // T1: RESET PULSE Width: Miminum Reset pulse width to be able to reset (w/o 25 debouncing caps)
  GPIO1_DR_SET   = (1 << 20);  // Take out of reset
  delay(2);                    // T2: Reset to SMI ready: Post reset stabilization time prior to MDC preamble for register access
  // LEDCR offset 0x18, set LED_Link_Polarity and Blink_rate, pg 62
  // LED shows link status, active high, 10Hz
  mdio_write(PHY_LEDCR, PHY_LEDCR_VALUE);
  // Check for PHY presence
  if (mdio_read(PHY_LEDCR) != PHY_LEDCR_VALUE) {
    // Undo some pin configuration, for posterity
    GPIO1_GDIR &= ~((1 << 21) | (1 << 20));
    disable_enet_clocks();
    s_initState = kInitStateNoHardware;
    return;
  // Configure the PHY registers
  // The strap pull-ups may not have been strong enough, so ensure those values
  // are set properly too
  // Right now, it's just the 50MHz clock select for RMII slave mode
  // mdio_write(PHY_BMCR, 0x3100);  // 13: Speed_Selection: 1=100Mbps
  //                                // 12: Negotiation_Enable: 1=enabled
  //                                //  8: Duplex_Mode: 1=Full-Duplex
  // mdio_write(PHY_ANAR, 0x01E1);  // 8: 100Base-TX_Full-Duplex: 1=advertise
  //                                // 7: 100Base-TX_Half-Duplex: 1=advertise
  //                                // 6: 10Base-T_Full-Duplex: 1=advertise
  //                                // 5: 10Base-T_Half-Duplex: 1=advertise
  //                                // 4-0: Selector_Field: IEEE802.3u
  // printf("RCSR = %04" PRIx16 "h\r\n", mdio_read(PHY_RCSR));
  mdio_write(PHY_RCSR, 0x0081);  // 7: RMII_Clock_Select: 1=50MHz (non-default)
                                 // 1-0: Receive_Elasticity_Buffer_Size: 1=2 bit tolerance (up to 2400 byte packets)
  // mdio_write(PHY_PHYCR, 0x8000);  // 15: Auto_MDI/X_Enable: 1=enable
  s_initState = kInitStatePHYInitialized;
// Low-level input function that transforms a received frame into an lwIP pbuf.
// This returns a newly-allocated pbuf, or NULL if there was a frame error or
// allocation error.
static struct pbuf *low_level_input(volatile enetbufferdesc_t *pBD) {
  const u16_t err_mask = kEnetRxBdTrunc    |
                         kEnetRxBdOverrun  |
                         kEnetRxBdCrc      |
                         kEnetRxBdNonOctet |
                         kEnetRxBdLengthViolation;
  struct pbuf *p = NULL;
  // Determine if a frame has been received
  if (pBD->status & err_mask) {
#if LINK_STATS
    // Either truncated or others
    if (pBD->status & kEnetRxBdTrunc) {
      LINK_STATS_INC(link.lenerr);
    } else if (pBD->status & kEnetRxBdLast) {
      // The others are only valid if the 'L' bit is set
      if (pBD->status & kEnetRxBdOverrun) {
        LINK_STATS_INC(link.err);
      } else {  // Either overrun and others zero, or others
        if (pBD->status & kEnetRxBdNonOctet) {
        } else if (pBD->status & kEnetRxBdCrc) {  // Non-octet or CRC
          LINK_STATS_INC(link.chkerr);
        if (pBD->status & kEnetRxBdLengthViolation) {
    LINK_STATS_INC(link.drop);
#endif  // LINK_STATS
    LINK_STATS_INC(link.recv);
    p = pbuf_alloc(PBUF_RAW, pBD->length, PBUF_POOL);
    if (p) {
      arm_dcache_delete(pBD->buffer, MULTIPLE_OF_32(p->tot_len));
      pbuf_take(p, pBD->buffer, p->tot_len);
      LINK_STATS_INC(link.memerr);
  // Set rx bd empty
  pBD->status = (pBD->status & kEnetRxBdWrap) | kEnetRxBdEmpty;
  ENET_RDAR = ENET_RDAR_RDAR;
  return p;
// Acquires a buffer descriptor. Meant to be used with update_bufdesc().
// This returns NULL if there is no TX buffer available.
static inline volatile enetbufferdesc_t *get_bufdesc(void) {
  volatile enetbufferdesc_t *pBD = s_pTxBD;
  if ((pBD->status & kEnetTxBdReady) != 0) {
    return NULL;
  return pBD;
// Updates a buffer descriptor. Meant to be used with get_bufdesc().
static inline void update_bufdesc(volatile enetbufferdesc_t *pBD,
                                  uint16_t len) {
  pBD->length = len;
  pBD->status = (pBD->status & kEnetTxBdWrap) |
                kEnetTxBdTransmitCrc          |
                kEnetTxBdLast                 |
                kEnetTxBdReady;
  ENET_TDAR = ENET_TDAR_TDAR;
  if (pBD->status & kEnetTxBdWrap) {
    s_pTxBD++;
  LINK_STATS_INC(link.xmit);
// Finds the next non-empty BD.
static inline volatile enetbufferdesc_t *rxbd_next(void) {
  volatile enetbufferdesc_t *pBD = s_pRxBD;
  while (pBD->status & kEnetRxBdEmpty) {
    if (pBD->status & kEnetRxBdWrap) {
      pBD = &s_rxRing[0];
      pBD++;
    if (pBD == s_pRxBD) {
      return NULL;
  if (s_pRxBD->status & kEnetRxBdWrap) {
    s_pRxBD++;
  return pBD;
// The Ethernet ISR.
static void enet_isr(void) {
  if ((ENET_EIR & ENET_EIR_RXF) != 0) {
    ENET_EIR = ENET_EIR_RXF;
    atomic_flag_clear(&s_rxNotAvail);
// Checks the link status and returns zero if complete and a state value if
// not complete. The return value should be used in the next call to
// this function.
static inline int check_link_status(struct netif *netif, int state) {
  static uint16_t bmsr;
  static uint16_t physts;
  static uint8_t is_link_up;
  if (s_initState != kInitStateInitialized) {
    return 0;
  // Note: PHY_PHYSTS doesn't seem to contain the live link information unless
  //       BMSR is read too
  switch (state) {
    case 0:
      // Fallthrough
    case 1:
      if (mdio_read_nonblocking(PHY_BMSR, &bmsr, state == 1)) {
        return 1;
      is_link_up = ((bmsr & PHY_BMSR_LINK_STATUS) != 0);
      if (!is_link_up) {
      // Fallthrough
    case 2:
      if (mdio_read_nonblocking(PHY_PHYSTS, &physts, state == 2)) {
        return 2;
    default:
  if (netif_is_link_up(netif) != is_link_up) {
    if (is_link_up) {
      s_linkSpeed10Not100 = ((physts & PHY_PHYSTS_SPEED_STATUS) != 0);
      s_linkIsFullDuplex  = ((physts & PHY_PHYSTS_DUPLEX_STATUS) != 0);
      s_linkIsCrossover   = ((physts & PHY_PHYSTS_MDI_MDIX_MODE) != 0);
      netif_set_link_up(netif);
      netif_set_link_down(netif);
  return 0;
//  Driver Interface
FLASHMEM void driver_get_capabilities(struct DriverCapabilities *dc) {
  dc->isMACSettable              = true;
  dc->isLinkStateDetectable      = true;
  dc->isLinkSpeedDetectable      = true;
  dc->isLinkSpeedSettable        = false;
  dc->isLinkFullDuplexDetectable = true;
  dc->isLinkFullDuplexSettable   = false;
  dc->isLinkCrossoverDetectable  = true;
bool driver_is_unknown(void) {
  return s_initState == kInitStateStart;
void qnethernet_hal_get_system_mac_address(uint8_t mac[ETH_HWADDR_LEN]);
void driver_get_system_mac(uint8_t mac[ETH_HWADDR_LEN]) {
  qnethernet_hal_get_system_mac_address(mac);
bool driver_get_mac(uint8_t mac[ETH_HWADDR_LEN]) {
  // Don't do anything if the Ethernet clock isn't running because register
  // access will freeze the machine
  if ((CCM_CCGR1 & CCM_CCGR1_ENET(CCM_CCGR_ON)) == 0) {
    return false;
  uint32_t r = ENET_PALR;
  mac[0] = r >> 24;
  mac[1] = r >> 16;
  mac[2] = r >> 8;
  mac[3] = r;
  r = ENET_PAUR;
  mac[4] = r >> 24;
  mac[5] = r >> 16;
  return true;
bool driver_set_mac(const uint8_t mac[ETH_HWADDR_LEN]) {
    return false;
  __disable_irq();  // TODO: Not sure if disabling interrupts is really needed
  ENET_PALR = (mac[0] << 24) | (mac[1] << 16) | (mac[2] << 8) | mac[3];
  ENET_PAUR = (mac[4] << 24) | (mac[5] << 16) | 0x8808;
  __enable_irq();
  return true;
bool driver_has_hardware(void) {
  switch (s_initState) {
    case kInitStateHasHardware:
    case kInitStatePHYInitialized:
    case kInitStateInitialized:
      return true;
    case kInitStateNoHardware:
      return false;
    default:
  init_phy();
  return (s_initState != kInitStateNoHardware);
FLASHMEM void driver_set_chip_select_pin(int pin) {
  LWIP_UNUSED_ARG(pin);
// Initializes the PHY and Ethernet interface. This sets the init state and
// returns whether the initialization was successful.
FLASHMEM bool driver_init(void) {
  if (s_initState == kInitStateInitialized) {
    return true;
  init_phy();
  if (s_initState != kInitStatePHYInitialized) {
    return false;
  // Configure pins
  // TODO: What should these actually be? Why pull-ups? Note that the reference code uses pull-ups.
  // Note: The original code left RXD0, RXEN, and RXER with PULLDOWN
  configure_rmii_pins();
  memset(s_rxRing, 0, sizeof(s_rxRing));
  memset(s_txRing, 0, sizeof(s_txRing));
  for (int i = 0; i < RX_SIZE; i++) {
    s_rxRing[i].buffer  = &s_rxBufs[i * BUF_SIZE];
    s_rxRing[i].status  = kEnetRxBdEmpty;
    s_rxRing[i].extend1 = kEnetRxBdInterrupt;
  // The last buffer descriptor should be set with the wrap flag
  s_rxRing[RX_SIZE - 1].status |= kEnetRxBdWrap;
  for (int i = 0; i < TX_SIZE; i++) {
    s_txRing[i].buffer  = &s_txBufs[i * BUF_SIZE];
    s_txRing[i].status  = kEnetTxBdTransmitCrc;
    s_txRing[i].extend1 = kEnetTxBdTxInterrupt  |
                          kEnetTxBdProtChecksum |
                          kEnetTxBdIpHdrChecksum;
  s_txRing[TX_SIZE - 1].status |= kEnetTxBdWrap;
  ENET_EIMR = 0;  // This also deasserts all interrupts
  ENET_RCR = 0
             | ENET_RCR_NLC        // Payload length is checked
             | ENET_RCR_MAX_FL(MAX_FRAME_LEN)
             | ENET_RCR_CFEN       // Discard non-pause MAC control frames
             | ENET_RCR_CRCFWD     // CRC is stripped (ignored if PADEN)
             | ENET_RCR_PADEN      // Padding is removed
             | ENET_RCR_RMII_MODE
             | ENET_RCR_FCE        // Flow control enable
#if QNETHERNET_ENABLE_PROMISCUOUS_MODE
             | ENET_RCR_PROM       // Promiscuous mode
#endif  // QNETHERNET_ENABLE_PROMISCUOUS_MODE
             | ENET_RCR_MII_MODE;
  ENET_TCR = 0
             | ENET_TCR_ADDINS     // Overwrite with programmed MAC address
             | ENET_TCR_ADDSEL(0)
             // | ENET_TCR_RFC_PAUSE
             // | ENET_TCR_TFC_PAUSE
             | ENET_TCR_FDEN         // Enable full-duplex
  ENET_TACC = 0
#if CHECKSUM_GEN_UDP == 0 || CHECKSUM_GEN_TCP == 0 || CHECKSUM_GEN_ICMP == 0
      | ENET_TACC_PROCHK  // Insert protocol checksum
#endif  // not(Generate all checksums)
#if CHECKSUM_GEN_IP == 0
      | ENET_TACC_IPCHK   // Insert IP header checksum
#endif  // CHECKSUM_GEN_IP == 0
#if ETH_PAD_SIZE == 2
      | ENET_TACC_SHIFT16
#endif  // ETH_PAD_SIZE == 2
  ENET_RACC = 0
      | ENET_RACC_SHIFT16
      | ENET_RACC_LINEDIS  // Discard bad frames
#if CHECKSUM_CHECK_UDP == 0 && \
    CHECKSUM_CHECK_TCP == 0 && \
    CHECKSUM_CHECK_ICMP == 0
      | ENET_RACC_PRODIS   // Discard frames with incorrect protocol checksum
                           // Requires RSFL == 0
#endif  // not(Check any checksums)
#if CHECKSUM_CHECK_IP == 0
      | ENET_RACC_IPDIS    // Discard frames with incorrect IPv4 header checksum
#endif  // CHECKSUM_CHECK_IP == 0
      | ENET_RACC_PADREM
  ENET_TFWR = ENET_TFWR_STRFWD;
  ENET_RSFL = 0;
  ENET_RDSR = (uint32_t)s_rxRing;
  ENET_TDSR = (uint32_t)s_txRing;
  ENET_MRBR = BUF_SIZE;
  ENET_RXIC = 0;
  ENET_TXIC = 0;
  // ENET_PALR = (mac[0] << 24) | (mac[1] << 16) | (mac[2] << 8) | mac[3];
  // ENET_PAUR = (mac[4] << 24) | (mac[5] << 16) | 0x8808;
  ENET_OPD = 0x10014;
  ENET_RSEM = 0;
  ENET_MIBC = 0;
  ENET_IAUR = 0;
  ENET_IALR = 0;
  ENET_GAUR = 0;
  ENET_GALR = 0;
  ENET_EIMR = ENET_EIMR_RXF;
  attachInterruptVector(IRQ_ENET, &enet_isr);
  NVIC_ENABLE_IRQ(IRQ_ENET);
  // Last few things to do
  ENET_EIR = 0x7fff8000;  // Clear any pending interrupts before setting ETHEREN
  atomic_flag_test_and_set(&s_rxNotAvail);
  // Last, enable the Ethernet MAC
  ENET_ECR = 0x70000000 | ENET_ECR_DBSWP | ENET_ECR_EN1588 | ENET_ECR_ETHEREN;
  // Indicate there are empty RX buffers and available ready TX buffers
  // PHY soft reset
  // mdio_write(PHY_BMCR, 1 << 15);
  s_initState = kInitStateInitialized;
  return true;
void unused_interrupt_vector(void);  // startup.c
FLASHMEM void driver_deinit(void) {
  // Something about stopping Ethernet and the PHY kills performance if Ethernet
  // is restarted after calling end(), so gate the following two blocks with a
  // macro for now
#if QNETHERNET_INTERNAL_END_STOPS_ALL
    NVIC_DISABLE_IRQ(IRQ_ENET);
    attachInterruptVector(IRQ_ENET, &unused_interrupt_vector);
    ENET_EIMR = 0;  // Disable interrupts
    // Gracefully stop any transmission before disabling the Ethernet MAC
    ENET_EIR = ENET_EIR_GRA;  // Clear status
    ENET_TCR |= ENET_TCR_GTS;
    while ((ENET_EIR & ENET_EIR_GRA) == 0) {
      // Wait until it's gracefully stopped
    // Disable the Ethernet MAC
    // Note: All interrupts are cleared when Ethernet is reinitialized,
    //       so nothing will be pending
    ENET_ECR = 0x70000000;
  if (s_initState == kInitStatePHYInitialized) {
    // Power down the PHY and enable reset
    GPIO1_DR_CLEAR = (1 << 21) | (1 << 20);
    s_initState = kInitStateHasHardware;
#endif  // QNETHERNET_INTERNAL_END_STOPS_ALL
struct pbuf *driver_proc_input(struct netif *netif, int counter) {
  // Finish any pending link status check
  if (s_checkLinkStatusState != 0) {
    s_checkLinkStatusState = check_link_status(netif, s_checkLinkStatusState);
  if (counter == 0) {
    if (atomic_flag_test_and_set(&s_rxNotAvail)) {
      return NULL;
  } else if (counter >= RX_SIZE * 2) {
    return NULL;
  // Get the next chunk of input data
  volatile enetbufferdesc_t *pBD = rxbd_next();
  if (pBD == NULL) {
    return NULL;
  return low_level_input(pBD);
void driver_poll(struct netif *netif) {
int driver_link_speed(void) {
  return s_linkSpeed10Not100 ? 10 : 100;
bool driver_link_set_speed(int speed) {
  LWIP_UNUSED_ARG(speed);
  return false;
bool driver_link_is_full_duplex(void) {
  return s_linkIsFullDuplex;
bool driver_link_set_full_duplex(bool flag) {
  LWIP_UNUSED_ARG(flag);
  return false;
bool driver_link_is_crossover(void) {
  return s_linkIsCrossover;
// Outputs data from the MAC.
err_t driver_output(struct pbuf *p) {
  // Note: The pbuf already contains the padding (ETH_PAD_SIZE)
  volatile enetbufferdesc_t *pBD = get_bufdesc();
  if (pBD == NULL) {
    return ERR_WOULDBLOCK;  // Could also use ERR_MEM, but this lets things like
                            // UDP senders know to retry
  uint16_t copied = pbuf_copy_partial(p, pBD->buffer, p->tot_len, 0);
  if (copied == 0) {
    return ERR_BUF;
  arm_dcache_flush_delete(pBD->buffer, MULTIPLE_OF_32(copied));
  update_bufdesc(pBD, copied);
  return ERR_OK;
#if QNETHERNET_ENABLE_RAW_FRAME_SUPPORT
bool driver_output_frame(const uint8_t *frame, size_t len) {
    return false;
  if (pBD == NULL) {
    return false;
  memcpy((uint8_t *)pBD->buffer + ETH_PAD_SIZE, frame, len);
  arm_dcache_flush_delete(pBD->buffer, MULTIPLE_OF_32(len + ETH_PAD_SIZE));
  update_bufdesc(pBD, len + ETH_PAD_SIZE);
  return true;
#endif  // QNETHERNET_ENABLE_RAW_FRAME_SUPPORT
//  MAC Address Filtering
#if !QNETHERNET_ENABLE_PROMISCUOUS_MODE
// CRC-32 routine for computing the 4-byte FCS for multicast lookup.
static uint32_t crc32(uint32_t crc, const uint8_t *data, size_t len) {
  // https://create.stephan-brumme.com/crc32/#fastest-bitwise-crc32
  crc = ~crc;
  while (len--) {
    crc ^= *(data++);
    for (int j = 0; j < 8; j++) {
      crc = (crc >> 1) ^ (-(crc & 0x01) & 0xEDB88320);
  return crc;
bool driver_set_incoming_mac_address_allowed(const uint8_t mac[ETH_HWADDR_LEN],
                                             bool allow) {
  // Don't release bits that have had a collision. Track these here.
  static uint32_t collisionGALR = 0;
  static uint32_t collisionGAUR = 0;
  static uint32_t collisionIALR = 0;
  static uint32_t collisionIAUR = 0;
  if (mac == NULL) {
    return false;
  uint32_t crc = (crc32(0, mac, ETH_HWADDR_LEN) >> 26) & 0x3f;
  uint32_t value = 1 << (crc & 0x1f);
  // Choose which locations
  const bool isGroup = (mac[0] & 0x01) != 0;
  volatile uint32_t *reg;
  uint32_t *collision;
  if (crc < 0x20) {
    if (isGroup) {
      reg = &ENET_GALR;
      collision = &collisionGALR;
      reg = &ENET_IALR;
      collision = &collisionIALR;
    if (isGroup) {  // Group
      reg = &ENET_GAUR;
      collision = &collisionGAUR;
      reg = &ENET_IAUR;
      collision = &collisionIAUR;
  if (allow) {
    if ((*reg & value) != 0) {
      *collision |= value;
      *reg |= value;
    // Keep collided bits set
    *reg &= ~value | *collision;
    return ((*collision & value) == 0);  // False if can't remove
  return true;
#endif  // !QNETHERNET_ENABLE_PROMISCUOUS_MODE
#endif  // QNETHERNET_INTERNAL_DRIVER_TEENSY41
driver_teensy_custom.h (This one is untouched)
// driver_teensy41.h defines Teensy 4.1-specific things.
#pragma once
#define MTU           1500
#define MAX_FRAME_LEN 1522
// lwIP options
// ARP options
#define ETH_PAD_SIZE 2  /* 0 */
// Checksum options
#define CHECKSUM_GEN_IP      0  /* 1 */
#define CHECKSUM_GEN_UDP     0  /* 1 */
#define CHECKSUM_GEN_TCP     0  /* 1 */
#define CHECKSUM_GEN_ICMP    0  /* 1 */
// #define CHECKSUM_GEN_ICMP6   1
#define CHECKSUM_CHECK_IP    0  /* 1 */
#define CHECKSUM_CHECK_UDP   0  /* 1 */
#define CHECKSUM_CHECK_TCP   0  /* 1 */
#define CHECKSUM_CHECK_ICMP  0  /* 1 */
// #define CHECKSUM_CHECK_ICMP6 1
// C includes
#include <string.h>
#include <imxrt.h>
//  Defines
    // 0x0038
#define GPIO_MUX 5
    // ALT5 (GPIO)
    // 0xF028
    // 0xF829
#define MDIO_MUX 0
    // ALT0
    // 0x30E9
    // 0xB0E9
    // 0x00E9
    // 0x0031
      // ALT6
#define RMII_MUX 3
    // ALT3
#define RX_SIZE 5
#define TX_SIZE 5
// * Padding(2)
#else
//  Types
typedef struct {
  uint16_t length;
  uint16_t status;
  void     *buffer;
  uint16_t extend0;
  uint16_t extend1;
  uint16_t checksum;
  uint8_t  prototype;
  uint8_t  headerlen;
  uint16_t unused0;
  uint16_t extend2;
  uint32_t timestamp;
  uint16_t unused1;
  uint16_t unused2;
  uint16_t unused3;
  uint16_t unused4;
} enetbufferdesc_t;
// Ethernet buffers
//  PHY I/O
                                  bool cont) {
  if (!cont) {
    return true;
  return false;
  uint16_t data;
  do {
  } while (doCont);
  return data;
  if (!cont) {
    return true;
  return false;
  do {
  } while (doCont);
//  Low-Level
  // Configure REFCLK
  // PHY spec. page 3
      // DAISY:10
// the PHY.
      // DAISY:1
    return;
    return;
                         kEnetRxBdOverrun  |
                         kEnetRxBdCrc      |
                         kEnetRxBdNonOctet |
#if LINK_STATS
    if (p) {
  // Set rx bd empty
  return p;
    return NULL;
  return pBD;
                                  uint16_t len) {
  pBD->length = len;
                kEnetTxBdLast                 |
                kEnetTxBdReady;
    s_pTxBD++;
      pBD = &s_rxRing[0];
      pBD++;
      return NULL;
    s_pRxBD++;
  return pBD;
// this function.
    return 0;
  //       BMSR is read too
  switch (state) {
    case 0:
      // Fallthrough
    case 1:
        return 1;
      if (!is_link_up) {
      // Fallthrough
    case 2:
        return 2;
    default:
    if (is_link_up) {
  return 0;
//  Driver Interface
    return false;
  mac[0] = r >> 24;
  mac[1] = r >> 16;
  mac[2] = r >> 8;
  mac[3] = r;
  r = ENET_PAUR;
  mac[4] = r >> 24;
  mac[5] = r >> 16;
  return true;
    return false;
  __enable_irq();
  return true;
      return true;
      return false;
    default:
  init_phy();
    return true;
  init_phy();
    return false;
  // Configure pins
  ENET_RCR = 0
             | ENET_RCR_RMII_MODE
             | ENET_RCR_MII_MODE;
  ENET_TCR = 0
             | ENET_TCR_ADDSEL(0)
  ENET_TACC = 0
      | ENET_TACC_SHIFT16
  ENET_RACC = 0
      | ENET_RACC_SHIFT16
      | ENET_RACC_PADREM
  ENET_RSFL = 0;
  ENET_RXIC = 0;
  ENET_TXIC = 0;
  ENET_OPD = 0x10014;
  ENET_RSEM = 0;
  ENET_MIBC = 0;
  ENET_IAUR = 0;
  ENET_IALR = 0;
  ENET_GAUR = 0;
  ENET_GALR = 0;
  // PHY soft reset
  return true;
  // macro for now
  if (counter == 0) {
      return NULL;
    return NULL;
  if (pBD == NULL) {
    return NULL;
  return false;
  return false;
  if (pBD == NULL) {
  if (copied == 0) {
    return ERR_BUF;
  return ERR_OK;
    return false;
  if (pBD == NULL) {
    return false;
  return true;
  crc = ~crc;
  while (len--) {
    crc ^= *(data++);
  return crc;
                                             bool allow) {
  if (mac == NULL) {
    return false;
  if (crc < 0x20) {
    if (isGroup) {
      reg = &ENET_GALR;
      reg = &ENET_IALR;
      reg = &ENET_GAUR;
      reg = &ENET_IAUR;
  if (allow) {
      *reg |= value;
  return true;
#pragma once
#define MTU           1500
// lwIP options
// ARP options
// Checksum options
I will look into everything carefully.
Thank you very much for sharing this with me.
you guys are aware of this discussion on the QNEthernet github, right? It's where I shared to story and lastest code. Hope somebody can pick it up and create a PR.
Well anyway, I'm glad we have ENET2 working on MM.
I could integrate it into the library (subject to my time), if anyone could provide some test hardware.
Today I ordered this PCB, basically my old MicroMod breakout with LAN8720A ethernet added.
If it actually works, I'll send one to Shawn and publish the files. Will likely have a couple leftovers, if anyone wants them.
Good news. The PCB arrived and it works!
Basic ping test code:
#include "IPAddress.h"
// set this to an unused IP number for your network
IPAddress myaddress(192, 168, 194, 67);
#define MACADDR1 0x04E9E5
#define MACADDR2 0x000001
// This test program prints a *lot* of info to the Arduino Serial Monitor
// Ping response time is approx 0.45 ms with 600 MHz clock, due to all the
// time spent printing.  To get a realistic idea of ping time, you would
// need to delete or comment out all the Serial print stuff.
#define EXTDESC
typedef struct {
    uint16_t length;
    uint16_t flags;
    void *buffer;
#ifdef EXTDESC
    uint32_t moreflags;
    uint16_t checksum;
    uint16_t header;
    uint32_t dmadone;
    uint32_t timestamp;
    uint32_t unused1;
    uint32_t unused2;
} enetbufferdesc_t;
#define RXSIZE 12
#define TXSIZE 10
static enetbufferdesc_t rx_ring[RXSIZE] __attribute__ ((aligned(64)));
static enetbufferdesc_t tx_ring[TXSIZE] __attribute__ ((aligned(64)));
uint32_t rxbufs[RXSIZE*128] __attribute__ ((aligned(32)));
uint32_t txbufs[TXSIZE*128] __attribute__ ((aligned(32)));
#define RMII_PAD_INPUT_PULLDOWN 0x30E9
#define RMII_PAD_INPUT_PULLUP   0xB0E9
#define RMII_PAD_CLOCK          0x0031
// initialize the ethernet hardware
    while (!Serial) ; // wait
    Serial.println("Ethernet on MicroMod Testing");
    Serial.println("https://forum.pjrc.com/threads/67643");
    Serial.println("------------------------------------\n");
    // configure pins
#if 0
    // LAN8720A test PCB has reset from CAT811T chip, no power enable signal
    IOMUXC_SW_MUX_CTL_PAD_GPIO_B0_14 = 5; // Reset   B0_14 Alt5 GPIO7.15
    IOMUXC_SW_MUX_CTL_PAD_GPIO_B0_15 = 5; // Power   B0_15 Alt5 GPIO7.14
    GPIO7_GDIR |= (1<<14) | (1<<15);
    GPIO7_DR_SET = (1<<15);   // power on
    GPIO7_DR_CLEAR = (1<<14); // reset PHY chip
#if 0
    // LAN8720A test PCB has 10K pullup resistors to configure PHY mode
    IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_04 = RMII_PAD_INPUT_PULLDOWN; // PhyAdd[0] = 0
    IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_06 = RMII_PAD_INPUT_PULLDOWN; // PhyAdd[1] = 1
    IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_05 = RMII_PAD_INPUT_PULLUP;   // Master/Slave = slave mode
    IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_11 = RMII_PAD_INPUT_PULLDOWN; // Auto MDIX Enable
    IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_07 = RMII_PAD_INPUT_PULLUP;
    IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_08 = RMII_PAD_INPUT_PULLUP;
    IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_09 = RMII_PAD_INPUT_PULLUP;
    IOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_04 = 8; // RXD1    SD_B0_04 Alt8, pg 540
    IOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_03 = 8; // RXD0    SD_B0_03 Alt8, pg 539
    IOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_01 = 9 | 0x10; // REFCLK  SD_B0_01 Alt9, pg 537
    IOMUXC_SW_MUX_CTL_PAD_GPIO_B1_00 = 8;    // RXER    B1_00 (pin 8) Alt8, pg 520
    IOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_05 = 8; // RXEN    SD_B0_05 Alt8, pg 541
    IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_32 = 8;   // TXEN    EMC_32 Alt8, pg 458
    IOMUXC_SW_MUX_CTL_PAD_GPIO_B0_12 = 8;    // TXD0    B0_12 Alt8, pg 516
    IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_31 = 8; // TXD1    EMC_31 Alt8, pg 457
#if 0
    // use bitbang for MDIO, because B0_01 is pin 12 normally used for SPI
    IOMUXC_SW_MUX_CTL_PAD_GPIO_B0_01 = 8; // MDIO    B0_01 Alt8, pg 505
    IOMUXC_SW_MUX_CTL_PAD_GPIO_B0_00 = 8; // MDC     B0_00 Alt0, pg 504
    IOMUXC_ENET2_IPG_CLK_RMII_SELECT_INPUT = 1; // SD_B0_01 ALT9, page 914
    IOMUXC_ENET2_IPP_IND_MAC0_RXDATA_SELECT_INPUT_0 = 1; // SD_B0_03 ALT8, page 916
    IOMUXC_ENET2_IPP_IND_MAC0_RXDATA_SELECT_INPUT_1 = 1; // SD_B0_04 ALT8, page 916
    IOMUXC_ENET2_IPP_IND_MAC0_RXEN_SELECT_INPUT = 1; // SD_B0_05 ALT8, page 917
    IOMUXC_ENET2_IPP_IND_MAC0_RXERR_SELECT_INPUT = 2; // B1_00 ALT8, page 918
    IOMUXC_ENET2_IPP_IND_MAC0_TXCLK_SELECT_INPUT = 1; // SD_B0_01 ALT8, page 920
    delayMicroseconds(2);
    //GPIO7_DR_SET = (1<<14); // start PHY chip
    delayMicroseconds(5);
#if 0
    while (1) {
        mdio_write(0, 0x18, 0x492); // force LED on
        mdio_write(0, 0x18, 0x490); // force LED off
#if 0
    Serial.printf("RCSR:%04X, LEDCR:%04X, PHYCR %04X\n",
        mdio_read(0, 0x17), mdio_read(0, 0x18), mdio_read(0, 0x19));
    // LEDCR offset 0x18, set LED_Link_Polarity, pg 62
    //mdio_write(0, 0x18, 0x0280); // LED shows link status, active high
    // RCSR offset 0x17, set RMII_Clock_Select, pg 61
    //mdio_write(0, 0x17, 0x0081); // config for 50 MHz clock input
    // ENET_EIR    2174    Interrupt Event Register
    // ENET_EIMR    2177    Interrupt Mask Register
    // ENET_RDAR    2180    Receive Descriptor Active Register
    // ENET_TDAR    2181    Transmit Descriptor Active Register
    // ENET_ECR    2181    Ethernet Control Register
    // ENET_RCR    2187    Receive Control Register
    // ENET_TCR    2190    Transmit Control Register
    // ENET_PALR/UR    2192    Physical Address
    // ENET_RDSR    2199    Receive Descriptor Ring Start
    // ENET_TDSR    2199    Transmit Buffer Descriptor Ring
    // ENET_MRBR    2200    Maximum Receive Buffer Size
    //        2278    receive buffer descriptor
    //        2281    transmit buffer descriptor
    print("enetbufferdesc_t size = ", sizeof(enetbufferdesc_t));
    print("rx_ring size = ", sizeof(rx_ring));
    memset(rx_ring, 0, sizeof(rx_ring));
    memset(tx_ring, 0, sizeof(tx_ring));
    for (int i=0; i < RXSIZE; i++) {
        rx_ring[i].flags = 0x8000; // empty flag
        #ifdef EXTDESC
        rx_ring[i].moreflags = 0x00800000; // INT flag
        rx_ring[i].buffer = rxbufs + i * 128;
    rx_ring[RXSIZE-1].flags = 0xA000; // empty & wrap flags
    for (int i=0; i < TXSIZE; i++) {
        tx_ring[i].buffer = txbufs + i * 128;
        #ifdef EXTDESC
        tx_ring[i].moreflags = 0x40000000; // INT flag
    tx_ring[TXSIZE-1].flags = 0x2000; // wrap flag
    //ENET_ECR |= ENET_ECR_RESET;
    ENET2_EIMR = 0;
    ENET2_MSCR = ENET_MSCR_MII_SPEED(9);  // 12 is fastest which seems to work
#if 1
    ENET2_RCR = ENET_RCR_NLC | ENET_RCR_MAX_FL(1522) | /* ENET_RCR_CFEN | */
        ENET_RCR_CRCFWD | ENET_RCR_PADEN | ENET_RCR_RMII_MODE |
        ///* ENET_RCR_FCE | ENET_RCR_PROM | */ ENET_RCR_MII_MODE;
        ENET_RCR_PROM | ENET_RCR_MII_MODE;
    ENET2_TCR = ENET_TCR_ADDINS | /* ENET_TCR_RFC_PAUSE | ENET_TCR_TFC_PAUSE | */
        ENET_TCR_FDEN;
#else
    ENET_RCR = ENET_RCR_MAX_FL(1518) | ENET_RCR_RMII_MODE | ENET_RCR_MII_MODE
        | ENET_RCR_PROM;
    ENET_TCR = ENET_TCR_FDEN;
    ENET2_RXIC = 0;
    ENET2_TXIC = 0;
    ENET2_PALR = (MACADDR1 << 8) | ((MACADDR2 >> 16) & 255);
    ENET2_PAUR = ((MACADDR2 << 16) & 0xFFFF0000) | 0x8808;
    ENET2_OPD = 0x10014;
    ENET2_IAUR = 0;
    ENET2_IALR = 0;
    ENET2_GAUR = 0;
    ENET2_GALR = 0;
    ENET2_RDSR = (uint32_t)rx_ring;
    ENET2_TDSR = (uint32_t)tx_ring;
    ENET2_MRBR = 512;
    ENET2_TACC = ENET_TACC_SHIFT16;
    //ENET2_TACC = ENET_TACC_SHIFT16 | ENET_TACC_IPCHK | ENET_TACC_PROCHK;
    ENET2_RACC = ENET_RACC_SHIFT16;
    //ENET2_RSEM = 0;
    //ENET2_RAEM = 16;
    //ENET2_RAFL = 16;
    //ENET2_TSEM = 16;
    //ENET2_TAEM = 16;
    ENET2_MIBC = 0;
    Serial.printf("MIBC=%08X\n", ENET2_MIBC);
    Serial.printf("ECR=%08X\n", ENET2_ECR);
    //ENET_ECR = 0x70000000 | ENET_ECR_DBSWP | ENET_ECR_EN1588 | ENET_ECR_ETHEREN;
#ifdef EXTDESC
    ENET2_ECR |= ENET_ECR_DBSWP | ENET_ECR_EN1588 | ENET_ECR_ETHEREN;
#else
    ENET2_ECR |= ENET_ECR_DBSWP | ENET_ECR_ETHEREN;
    //ENET2_ECR = 0xF0000000 | ENET_ECR_DBSWP | ENET_ECR_EN1588 | ENET_ECR_ETHEREN;
    ENET2_RDAR = ENET_RDAR_RDAR;
    ENET2_TDAR = ENET_TDAR_TDAR;
    printhex("MDIO PHY ID2 (LAN8720A is 0007, DP83825I is 2000): ", mdio_read(0, 2));
    printhex("MDIO PHY ID3 (LAN8720A is C0F?, DP83825I is A140): ", mdio_read(0, 3));
    delay(2500);
    printhex("BMCR: ", mdio_read(0, 0));
    printhex("BMSR: ", mdio_read(0, 1));
elapsedMillis msec;
// watch for data to arrive
    static uint32_t rx_packet_count=0;
    static int rxnum=0;
    volatile enetbufferdesc_t *buf;
    buf = rx_ring + rxnum;
    if ((buf->flags & 0x8000) == 0) {
        incoming(buf->buffer, buf->length);
        if (rxnum < RXSIZE-1) {
            buf->flags = 0x8000;
            rxnum++;
            buf->flags = 0xA000;
            rxnum = 0;
    if (!(ENET2_RDAR & ENET_RDAR_RDAR)) {
        print("receiver not active\n");
    uint32_t n = ENET2_RMON_R_PACKETS;
    if (n != rx_packet_count) {
        rx_packet_count = n;
        Serial.printf("rx packets: %u\n", n);
    if (msec > 1000) {
        msec = 0;
        Serial.printf("EIR=%08X, len=%d, R=%X\n", ENET2_EIR, rx_ring[0].length, ENET2_RMON_R_OCTETS);
    // TODO: if too many packets arrive too quickly, which is
    // a distinct possibility when we spend so much time printing
    // to the serial monitor, ENET_RDAR_RDAR can be cleared if
    // the receive ring buffer fills up.  After we free up space,
    // ENET_RDAR_RDAR needs to be set again to restart reception
    // of incoming packets.
// when we get data, try to parse it
void incoming(void *packet, unsigned int len)
    const uint8_t *p8;
    const uint16_t *p16;
    const uint32_t *p32;
    IPAddress src, dst;
    uint16_t type;
    print("data, len=", len);
    p8 = (const uint8_t *)packet + 2;
    p16 = (const uint16_t *)p8;
    p32 = (const uint32_t *)packet;
    type = p16[6];
    if (type == 0x0008) {
        src = p32[7];
        dst = p32[8];
        Serial.print("IPv4 Packet, src=");
        Serial.print(src);
        Serial.print(", dst=");
        Serial.print(dst);
        printpacket(p8, len - 2);
        if (p8[23] == 1 && dst == myaddress) {
            Serial.println("  Protocol is ICMP:");
            if (p8[34] == 8) {
                print("  echo request:");
                uint16_t id = __builtin_bswap16(p16[19]);
                uint16_t seqnum = __builtin_bswap16(p16[20]);
                printhex("   id = ", id);
                print("   sequence number = ", seqnum);
                ping_reply((uint32_t *)packet, len);
    } else if (type == 0x0608) {
        Serial.println("ARP Packet:");
        if (p32[4] == 0x00080100 && p32[5] == 0x01000406) {
            // request is for IPv4 address of ethernet mac
            IPAddress from((p16[15] << 16) | p16[14]);
            IPAddress to(p32[10]);
            Serial.print("  Who is ");
            Serial.print(to);
            Serial.print(" from ");
            Serial.print(from);
            Serial.print(" (");
            printmac(p8 + 22);
            Serial.println(")");
            if (to == myaddress) {
                arp_reply(p8+22, from);
// compose an answer to ARP requests
void arp_reply(const uint8_t *mac, IPAddress &ip)
    uint32_t packet[11]; // 42 bytes needed + 2 pad
    uint8_t *p = (uint8_t *)packet + 2;
    packet[0] = 0;       // first 2 bytes are padding
    memcpy(p, mac, 6);
    memset(p + 6, 0, 6); // hardware automatically adds our mac addr
    //p[6] = (MACADDR1 >> 16) & 255;
    //p[7] = (MACADDR1 >> 8) & 255;
    //p[8] = (MACADDR1) & 255;
    //p[9] = (MACADDR2 >> 16) & 255; // this is how to do it the hard way
    //p[10] = (MACADDR2 >> 8) & 255;
    //p[11] = (MACADDR2) & 255;
    p[12] = 8;
    p[13] = 6;  // arp protocol
    packet[4] = 0x00080100; // IPv4 on ethernet
    packet[5] = 0x02000406; // reply, ip 4 byte, macaddr 6 bytes
    packet[6] = (__builtin_bswap32(MACADDR1) >> 8) | ((MACADDR2 << 8) & 0xFF000000);
    packet[7] = __builtin_bswap16(MACADDR2 & 0xFFFF) | ((uint32_t)myaddress << 16);
    packet[8] = (((uint32_t)myaddress & 0xFFFF0000) >> 16) | (mac[0] << 16) | (mac[1] << 24);
    packet[9] = (mac[5] << 24) | (mac[4] << 16) | (mac[3] << 8) | mac[2];
    packet[10] = (uint32_t)ip;
    Serial.println("ARP Reply:");
    printpacket(p, 42);
    outgoing(packet, 44);
// compose an reply to pings
void ping_reply(const uint32_t *recv, unsigned int len)
    uint32_t packet[32];
    uint8_t *p8 = (uint8_t *)packet + 2;
    if (len > sizeof(packet)) return;
    memcpy(packet, recv, len);
    memcpy(p8, p8 + 6, 6); // send to the mac address we received
    packet[8] = packet[7]; // send to the IP number we received
    packet[7] = (uint32_t)myaddress;
    p8[34] = 0;            // type = echo reply
    // TODO: checksums in IP and ICMP headers - is the hardware
    // really inserting correct checksums automatically?
    printpacket((uint8_t *)packet + 2, len - 2);
    outgoing(packet, len);
// transmit a packet
void outgoing(void *packet, unsigned int len)
    static int txnum=0;
    uint16_t flags;
    buf = tx_ring + txnum;
    flags = buf->flags;
    if ((flags & 0x8000) == 0) {
        print("tx, num=", txnum);
        buf->length = len;
        memcpy(buf->buffer, packet, len);
        buf->flags = flags | 0x8C00;
        if (txnum < TXSIZE-1) {
            txnum++;
            txnum = 0;
// read a PHY register (using MDIO & MDC signals)
uint16_t mdio_read(int phyaddr, int regaddr)
    // TODO: bitbang MDIO
    return 0;
// write a PHY register (using MDIO & MDC signals)
void mdio_write(int phyaddr, int regaddr, uint16_t data)
// misc print functions, for lots of info in the serial monitor.
// this stuff probably slows things down and would need to go
// for any hope of keeping up with full ethernet data rate!
void print(const char *s)
    Serial.println(s);
void print(const char *s, int num)
    Serial.print(s);
    Serial.println(num);
void printhex(const char *s, int num)
    Serial.print(s);
    Serial.println(num, HEX);
void printmac(const uint8_t *data)
    Serial.printf("%02X:%02X:%02X:%02X:%02X:%02X",
        data[0], data[1], data[2], data[3], data[4], data[5]);
void printpacket(const uint8_t *data, unsigned int len)
#if 1
    unsigned int i;
    for (i=0; i < len; i++) {
        Serial.printf(" %02X", *data++);
        if ((i & 15) == 15) Serial.println();
Here are the PCB files and placement, if anyone wants to make this board or just dive into the minor detail like which parts were used.
The Ethernet PHY chip is LAN8720A.
  • micromod_ethernet_jlc.zip
Wow Paul sounds like you are beginning to have fun again :)
