I have been experimenting with adding USB Type for Dual Serial, 192K Audio. Alas none of the forums or messages have worked.
After I emailed Paul, TeensyDuino 1.60.0 was released.
Turns out that is a a game changer. Using the methodology in the Github below and using TeensyDuino 1.60.0 I was able to compile and run the usb_audio.ino
test sketch from the project below.
There has been a Github project ( https://github.com/laiudm/laiudm-Teensy4-192k-USB-Audio/ ) that has worked in the past for those adding USB type's.
But I have not been able to get the BETA Code to work under Arduino 2.3.7( or Beta 2.3.8 ) and the TeensyDuino 1.5.9 ( or Beta 1.60.x)
But with release of the Production version of TeensyDuino 1.60.0, I was able to add Dual Serial, 192K Audio successfully !!!!!!
I was able to compile and run the usb_audio.ino test sketch from the above Github. That is something I have been unable to do in the past.
I had to uninstall and reinstall since I have had the TeensyDuino Beta installed.
My process has with the new 1.60.0 release, was to :
1. Update my Arduino 2.3.7 with TeensyDuino 1.60.0
2. Opened the usb_audio.ino ( just to preload the IDE so the when I open it later it opens the test sketch)
3. Shutdown Arduino
4. Using the Boards.local.txt from the Github , add the last 3 lines to the boards.txt in the 1.6.0/avr/bards.txt.
I choose to insert the lines between the Dual Serial and the Triple Serial definitions in the boards.txt
# Solution for Arduino IDE 2.0 recognizing changes to this file:
# WAS https://github.com/laiudm/laiudm-Teensy4-192k-USB-Audio
teensy41.menu.usb.serialserialaudio=Serial + Serial + 192k Audio
teensy41.menu.usb.serialserialaudio.build.usbtype=USB_AUDIO192K_SERIAL_SERIAL
teensy41.menu.usb.serialserialaudio.upload_port.usbtype=USB_AUDIO192K_SERIAL_SERIAL
5. Edited the usb.desc.h to include the definition for USB Type Dual Serial + 192K Audio using the Github Example.
#elif defined(USB_AUDIO192K_SERIAL_SERIAL)
#define AUDIO_SAMPLE_RATE_EXACT 192000.0f
#define VENDOR_ID 0x16C0
#define PRODUCT_ID 0x0498
#define MANUFACTURER_NAME {'T','e','e','n','s','y','d','u','i','n','o'}
#define MANUFACTURER_NAME_LEN 11
#define PRODUCT_NAME {'1','9','2','k',' ','A','u','d','i','o','/','2','x','S','e','r','i','a','l'}
#define PRODUCT_NAME_LEN 19
#define EP0_SIZE 64
#define NUM_ENDPOINTS 7 // 5 for 2 serial, + 2 for audio
#define NUM_INTERFACE 7 // 4 for 2 serial, + 3 for audio
#define CDC_IAD_DESCRIPTOR 1
#define CDC_STATUS_INTERFACE 0
#define CDC_DATA_INTERFACE 1 // Serial
#define CDC_ACM_ENDPOINT 2
#define CDC_RX_ENDPOINT 3
#define CDC_TX_ENDPOINT 3
#define CDC_ACM_SIZE 16
#define CDC_RX_SIZE_480 512
#define CDC_TX_SIZE_480 512
#define CDC_RX_SIZE_12 64
#define CDC_TX_SIZE_12 64
#define CDC2_STATUS_INTERFACE 2 // SerialUSB1
#define CDC2_DATA_INTERFACE 3
#define CDC2_ACM_ENDPOINT 4
#define CDC2_RX_ENDPOINT 5
#define CDC2_TX_ENDPOINT 5
#define AUDIO_INTERFACE 4 // Audio (uses 3 consecutive interfaces)
#define AUDIO_TX_ENDPOINT 6
#define AUDIO_TX_SIZE ((int)((AUDIO_SAMPLE_RATE_EXACT + 900) / 1000) * 4)
#define AUDIO_RX_ENDPOINT 6
#define AUDIO_RX_SIZE AUDIO_TX_SIZE
#define AUDIO_SYNC_ENDPOINT 7
#define ENDPOINT2_CONFIG ENDPOINT_RECEIVE_UNUSED + ENDPOINT_TRANSMIT_INTERRUPT
#define ENDPOINT3_CONFIG ENDPOINT_RECEIVE_BULK + ENDPOINT_TRANSMIT_BULK
#define ENDPOINT4_CONFIG ENDPOINT_RECEIVE_UNUSED + ENDPOINT_TRANSMIT_INTERRUPT
#define ENDPOINT5_CONFIG ENDPOINT_RECEIVE_BULK + ENDPOINT_TRANSMIT_BULK
#define ENDPOINT6_CONFIG ENDPOINT_RECEIVE_ISOCHRONOUS + ENDPOINT_TRANSMIT_ISOCHRONOUS
#define ENDPOINT7_CONFIG ENDPOINT_RECEIVE_UNUSED + ENDPOINT_TRANSMIT_ISOCHRONOUS
6. Started Arduino 2.3.7
7. Reload Board Data.
8. Load "usb_audio.ino" Sketch If the Arduino Sketch "usb_audio.ino" from the Github above is not opened.
9. Set compliler options, Board "Teensy 4.1", Speed "528Mhz" and USB TYPE "Serial + Serial + 192K Audio"
10. Compile the "usb_audio.ino"
11. Upload the compiled "usb_audio.ino" sketch and run it.
I just plugged in a spare Teensy 4.1 and ran it.
Serial Monitor reported
usb audio tests at 192000sps
Usage/Max: oscillator CPU = 0.47/0.49, all CPU = 1.07/1.07, Int16 Mem = 2/2,
The second USB serial port is also working
I am looking forward to additional testing to further validate the methodology for the correct implementation.
3. Shutdown Arduino
#define EP0_SIZE 64
