madzo0omadz
Hello guys,
I am very fascinated by the ease of use and power of Teensy so I am working on miniturizing the board for one of the projects and still using the same arduino interface and libraries. I got the board to miniturize but the processor is too big (8 mm x 8 mm) for my earphones application. I have been researching different packages by the same manufacturer same ArmCortex M4 series but my knowledge can't be helpful to verify this is going to work. What is a good processor, package that is compatible with the Teensy 3.2 hardware and everything else, including the Quad-Audio, double Audio board hack?
I found the manufacturer NXP giving a few package options, even higher performances but I'm not sure if this will work with the Teensy.
Here is the data sheet:
http://www.mouser.com/ds/2/302/K20P144M100SF2V2-782165.pdf
Here is what I chose, hoping someone would confirm:
MK20DX128VMP5
http://www.mouser.com/ProductDetail...=sGAEpiMZZMuoKKEcg8mMKOxmbOarwo5TdoCOBSTmjpI=
Thank you in advance.
AI
MK20DX128VMP5
AI
