* Object Oriented CAN example for Teensy 3.6 with Dual CAN buses
* By Collin Kidder. Based upon the work of Pawelsky and Teachop
* Both buses are set to 500k to show things with a faster bus.
* The reception of frames in this example is done via callbacks
* to an object rather than polling. Frames are delivered as they come in.
#include <FlexCAN.h>
class ExampleClass : public CANListener
public:
void printFrame(CAN_message_t &frame, int mailbox);
bool frameHandler(CAN_message_t &frame, int mailbox, uint8_t controller); //overrides the parent version so we can actually do something
void ExampleClass::printFrame(CAN_message_t &frame, int mailbox)
Serial.print("ID: ");
Serial.print(frame.id, HEX);
Serial.print(" Data: ");
for (int c = 0; c < frame.len; c++)
Serial.print(frame.buf[c], HEX);
Serial.write(' ');
Serial.write('\r');
Serial.write('\n');
bool ExampleClass::frameHandler(CAN_message_t &frame, int mailbox, uint8_t controller)
printFrame(frame, mailbox);
return true;
ExampleClass exampleClass;
void setup(void)
Serial.println(F("Hello Teensy Single CAN Receiving Example With Objects."));
Can0.begin(500000);
//if using enable pins on a transceiver they need to be set on
pinMode(2, OUTPUT);
digitalWrite(2, HIGH);
Can0.attachObj(&exampleClass);
exampleClass.attachGeneralHandler();
void loop(void)
Serial.write('.');
