Attached is a first draft of implementing a USBHost driver for an Ant+ USB stick on the Teensy 3.6, for the Ant+ network protocol. Ant-FS (file transfers) is not implemented, yet, in the library though the framework is there for someone else to investigate, I have no need of it.
(Ant+ is a low energy Wifi networking protocol, originally and specifically targeting sports sensors, such as a heart rate monitor, bike speed sensor, etc..)
View attachment antplus_usb_05042017.zip
Notes:
Driver has been simultaneously tested with two devices:; that is, one device per channel; A heart rate monitor chest strap, and a combined bike sensor - speed and cadence, as can be observed in the debug output below.
In this draft, please compile with the included USBHost_t36. There are two small but required modifications: QTD_LENGTH() added to USBHost_t36.h and PERIODIC_LIST_SIZE must be set to 8, otherwise default library should be fine.
This is an initial draft so feedback is more than welcomed.
Using the included example, antplus.ino, should produced something below:
Notes:
with HRM enabled only
Ant+ USB
@ start up mesg reason: 0x0
[0] * network key accepted
[0] * channel assign accepted
[0] * channel mesg period accepted
[0] * search timeout period accepted
[0] * radio freq accepted
[0] * search waveform accepted
[0] * set channel id accepted
[0] * open channel accepted
Channel 0 status: STATUS SEARCHING CHANNEL
@ version: 'AJK1.04RAF'
@ capabilities:
Max ANT Channels: 8
Max ANT Networks: 3
Std. option: 0x0
Advanced: 0xBA
Advanced2: 0x36
[1] * channel assign accepted
Channel 1 status: STATUS ASSIGNED CHANNEL
[1] * channel mesg period accepted
[1] * search timeout period accepted
[1] * radio freq accepted
[1] * search waveform accepted
[1] * set channel id accepted
[1] * open channel accepted
Channel 1 status: STATUS SEARCHING CHANNEL
@ capabilities:
Max ANT Channels: 8
Max ANT Networks: 3
Std. option: 0x0
Advanced: 0xBA
Advanced2: 0x36
@ capabilities:
Max ANT Channels: 8
Max ANT Networks: 3
Std. option: 0x0
Advanced: 0xBA
Advanced2: 0x36
HRM: sequence:208, interval:6672ms, bpm:46
Channel 0 status: STATUS TRACKING_CHANNEL
Device found on channel 0: deviceId:26434, deviceType:120, transType:1
HRM: sequence:209, interval:1318ms, bpm:47
HRM: sequence:210, interval:1147ms, bpm:48
HRM: sequence:211, interval:954ms, bpm:48
HRM: sequence:212, interval:1004ms, bpm:49
HRM: sequence:213, interval:1392ms, bpm:49
HRM: sequence:214, interval:1378ms, bpm:48
HRM: sequence:215, interval:1216ms, bpm:49
HRM: sequence:216, interval:1194ms, bpm:49
HRM: sequence:217, interval:1162ms, bpm:49
HRM: sequence:218, interval:1183ms, bpm:49
HRM: sequence:219, interval:1236ms, bpm:49
HRM: sequence:220, interval:1251ms, bpm:49
HRM: sequence:221, interval:1288ms, bpm:48
HRM: sequence:222, interval:1208ms, bpm:48
HRM: sequence:223, interval:1208ms, bpm:49
HRM: sequence:224, interval:1190ms, bpm:49
HRM: sequence:225, interval:1179ms, bpm:49
HRM: sequence:226, interval:1178ms, bpm:49
HRM: sequence:227, interval:1201ms, bpm:49
HRM: sequence:228, interval:1135ms, bpm:49
HRM: sequence:229, interval:1134ms, bpm:50
HRM: sequence:230, interval:1126ms, bpm:50
HRM: sequence:231, interval:1147ms, bpm:50
HRM: sequence:232, interval:1140ms, bpm:51
HRM: sequence:233, interval:1074ms, bpm:51
HRM: sequence:234, interval:1098ms, bpm:51
HRM: sequence:235, interval:1092ms, bpm:52
HRM: sequence:236, interval:1047ms, bpm:52
HRM: sequence:237, interval:1058ms, bpm:53
HRM: sequence:238, interval:1055ms, bpm:53
HRM: sequence:239, interval:1032ms, bpm:54
HRM: sequence:240, interval:1048ms, bpm:54
HRM: sequence:241, interval:1057ms, bpm:55
HRM: sequence:242, interval:1051ms, bpm:55
HRM: sequence:243, interval:1044ms, bpm:55
HRM: sequence:244, interval:1059ms, bpm:55
HRM: sequence:245, interval:1066ms, bpm:55
HRM: sequence:246, interval:1052ms, bpm:55
HRM: sequence:247, interval:1090ms, bpm:55
HRM: sequence:248, interval:1113ms, bpm:55
HRM: sequence:249, interval:1111ms, bpm:55
HRM: sequence:250, interval:1089ms, bpm:55
HRM: sequence:251, interval:1099ms, bpm:55
HRM: sequence:252, interval:1087ms, bpm:55
HRM: sequence:253, interval:1053ms, bpm:55
HRM: sequence:254, interval:1083ms, bpm:55
HRM: sequence:255, interval:1127ms, bpm:55
HRM: sequence:0, interval:1093ms, bpm:55
HRM: sequence:1, interval:1109ms, bpm:54
HRM: sequence:2, interval:1096ms, bpm:54
HRM: sequence:3, interval:1070ms, bpm:55
HRM: sequence:4, interval:1074ms, bpm:55
HRM: sequence:5, interval:1088ms, bpm:55
HRM: sequence:6, interval:1114ms, bpm:54
HRM: sequence:7, interval:1079ms, bpm:55
HRM: sequence:8, interval:1104ms, bpm:54
HRM: sequence:9, interval:1098ms, bpm:54
HRM: sequence:10, interval:1063ms, bpm:55
HRM: sequence:11, interval:1062ms, bpm:55
HRM: sequence:12, interval:1074ms, bpm:55
HRM: sequence:13, interval:1084ms, bpm:55
HRM: sequence:14, interval:1070ms, bpm:55
HRM: sequence:15, interval:1108ms, bpm:55
HRM: sequence:16, interval:1107ms, bpm:55
HRM: sequence:17, interval:1067ms, bpm:55
HRM: sequence:18, interval:1071ms, bpm:55
HRM: sequence:19, interval:1042ms, bpm:55
HRM: sequence:20, interval:1037ms, bpm:55
HRM: sequence:21, interval:1034ms, bpm:56
HRM: sequence:22, interval:1079ms, bpm:56
HRM: sequence:23, interval:1085ms, bpm:56
HRM: sequence:24, interval:1107ms, bpm:55
etc..
with HRM and a combined speed and cadence sensor enabled
(i'm manually spinning the cranks to generate sensor pickup)
Ant+ USB
@ capabilities:
Max ANT Channels: 8
Max ANT Networks: 3
Std. option: 0x0
Advanced: 0xBA
Advanced2: 0x36
HRM: sequence:166, interval:37073ms, bpm:64
@ capabilities:
Max ANT Channels: 8
Max ANT Networks: 3
Std. option: 0x0
Advanced: 0xBA
Advanced2: 0x36
HRM: sequence:167, interval:1105ms, bpm:63
@ capabilities:
Max ANT Channels: 8
Max ANT Networks: 3
Std. option: 0x0
Advanced: 0xBA
Advanced2: 0x36
@ capabilities:
Max ANT Channels: 8
Max ANT Networks: 3
Std. option: 0x0
Advanced: 0xBA
Advanced2: 0x36
SPDCAD: speed: 614.52km/h, cadence: 27676rpm, total distance: 114.55km
Channel 1 status: STATUS TRACKING_CHANNEL
Device found on channel 1: deviceId:23513, deviceType:121, transType:1
HRM: sequence:168, interval:1080ms, bpm:62
HRM: sequence:169, interval:1123ms, bpm:61
HRM: sequence:170, interval:1074ms, bpm:60
HRM: sequence:171, interval:1037ms, bpm:60
HRM: sequence:172, interval:875ms, bpm:60
HRM: sequence:173, interval:842ms, bpm:60
HRM: sequence:174, interval:808ms, bpm:61
SPDCAD: speed: 0.00km/h, cadence: 1rpm, total distance: 114.55km
HRM: sequence:175, interval:759ms, bpm:63
SPDCAD: speed: 0.00km/h, cadence: 349rpm, total distance: 114.55km
HRM: sequence:176, interval:738ms, bpm:66
HRM: sequence:177, interval:718ms, bpm:68
HRM: sequence:178, interval:715ms, bpm:70
SPDCAD: speed: 0.23km/h, cadence: 27rpm, total distance: 114.55km
SPDCAD: speed: 22.28km/h, cadence: 0rpm, total distance: 114.56km
HRM: sequence:179, interval:696ms, bpm:72
SPDCAD: speed: 24.83km/h, cadence: 86rpm, total distance: 114.56km
SPDCAD: speed: 24.36km/h, cadence: 0rpm, total distance: 114.56km
HRM: sequence:180, interval:673ms, bpm:74
SPDCAD: speed: 24.21km/h, cadence: 0rpm, total distance: 114.56km
SPDCAD: speed: 23.92km/h, cadence: 0rpm, total distance: 114.56km
HRM: sequence:181, interval:682ms, bpm:75
SPDCAD: speed: 23.77km/h, cadence: 0rpm, total distance: 114.57km
SPDCAD: speed: 23.56km/h, cadence: 0rpm, total distance: 114.57km
SPDCAD: speed: 23.35km/h, cadence: 0rpm, total distance: 114.57km
HRM: sequence:182, interval:668ms, bpm:77
SPDCAD: speed: 23.14km/h, cadence: 0rpm, total distance: 114.57km
HRM: sequence:183, interval:653ms, bpm:79
SPDCAD: speed: 22.94km/h, cadence: 0rpm, total distance: 114.57km
SPDCAD: speed: 22.80km/h, cadence: 21rpm, total distance: 114.57km
HRM: sequence:184, interval:663ms, bpm:80
SPDCAD: speed: 22.54km/h, cadence: 0rpm, total distance: 114.58km
SPDCAD: speed: 22.28km/h, cadence: 0rpm, total distance: 114.58km
HRM: sequence:185, interval:672ms, bpm:81
SPDCAD: speed: 22.16km/h, cadence: 0rpm, total distance: 114.58km
SPDCAD: speed: 21.97km/h, cadence: 0rpm, total distance: 114.58km
HRM: sequence:186, interval:679ms, bpm:82
SPDCAD: speed: 21.72km/h, cadence: 0rpm, total distance: 114.58km
SPDCAD: speed: 21.49km/h, cadence: 0rpm, total distance: 114.59km
HRM: sequence:187, interval:683ms, bpm:83
SPDCAD: speed: 21.31km/h, cadence: 0rpm, total distance: 114.59km
SPDCAD: speed: 21.08km/h, cadence: 0rpm, total distance: 114.59km
HRM: sequence:188, interval:689ms, bpm:83
SPDCAD: speed: 20.91km/h, cadence: 0rpm, total distance: 114.59km
SPDCAD: speed: 20.74km/h, cadence: 0rpm, total distance: 114.60km
HRM: sequence:189, interval:692ms, bpm:84
SPDCAD: speed: 20.47km/h, cadence: 0rpm, total distance: 114.60km
SPDCAD: speed: 0.00km/h, cadence: 14rpm, total distance: 114.60km
SPDCAD: speed: 20.53km/h, cadence: 0rpm, total distance: 114.60km
HRM: sequence:190, interval:683ms, bpm:84
SPDCAD: speed: 21.60km/h, cadence: 0rpm, total distance: 114.60km
HRM: sequence:191, interval:709ms, bpm:84
SPDCAD: speed: 21.49km/h, cadence: 62rpm, total distance: 114.60km
SPDCAD: speed: 22.94km/h, cadence: 0rpm, total distance: 114.61km
SPDCAD: speed: 23.92km/h, cadence: 0rpm, total distance: 114.61km
HRM: sequence:192, interval:705ms, bpm:84
SPDCAD: speed: 23.70km/h, cadence: 66rpm, total distance: 114.61km
SPDCAD: speed: 24.52km/h, cadence: 0rpm, total distance: 114.61km
HRM: sequence:193, interval:750ms, bpm:84
SPDCAD: speed: 24.67km/h, cadence: 0rpm, total distance: 114.61km
SPDCAD: speed: 24.44km/h, cadence: 69rpm, total distance: 114.61km
HRM: sequence:194, interval:756ms, bpm:83
SPDCAD: speed: 24.83km/h, cadence: 0rpm, total distance: 114.62km
SPDCAD: speed: 24.75km/h, cadence: 69rpm, total distance: 114.62km
HRM: sequence:195, interval:756ms, bpm:83
SPDCAD: speed: 25.23km/h, cadence: 0rpm, total distance: 114.62km
SPDCAD: speed: 25.15km/h, cadence: 0rpm, total distance: 114.62km
SPDCAD: speed: 24.99km/h, cadence: 55rpm, total distance: 114.63km
HRM: sequence:196, interval:768ms, bpm:82
SPDCAD: speed: 25.15km/h, cadence: 0rpm, total distance: 114.63km
SPDCAD: speed: 25.23km/h, cadence: 0rpm, total distance: 114.63km
SPDCAD: speed: 0.00km/h, cadence: 69rpm, total distance: 114.63km
HRM: sequence:197, interval:724ms, bpm:82
SPDCAD: speed: 24.99km/h, cadence: 0rpm, total distance: 114.63km
SPDCAD: speed: 24.75km/h, cadence: 0rpm, total distance: 114.64km
HRM: sequence:198, interval:732ms, bpm:82
SPDCAD: speed: 24.67km/h, cadence: 0rpm, total distance: 114.64km
SPDCAD: speed: 24.44km/h, cadence: 63rpm, total distance: 114.64km
HRM: sequence:199, interval:705ms, bpm:82
SPDCAD: speed: 24.21km/h, cadence: 0rpm, total distance: 114.64km
SPDCAD: speed: 24.06km/h, cadence: 0rpm, total distance: 114.64km
SPDCAD: speed: 23.92km/h, cadence: 68rpm, total distance: 114.64km
HRM: sequence:200, interval:706ms, bpm:82
SPDCAD: speed: 24.36km/h, cadence: 0rpm, total distance: 114.65km
SPDCAD: speed: 24.14km/h, cadence: 0rpm, total distance: 114.65km
HRM: sequence:201, interval:708ms, bpm:83
SPDCAD: speed: 23.92km/h, cadence: 0rpm, total distance: 114.65km
SPDCAD: speed: 23.77km/h, cadence: 0rpm, total distance: 114.65km
HRM: sequence:202, interval:690ms, bpm:83
SPDCAD: speed: 23.56km/h, cadence: 0rpm, total distance: 114.65km
SPDCAD: speed: 23.42km/h, cadence: 29rpm, total distance: 114.66km
SPDCAD: speed: 23.70km/h, cadence: 0rpm, total distance: 114.66km
HRM: sequence:203, interval:673ms, bpm:84
SPDCAD: speed: 23.63km/h, cadence: 0rpm, total distance: 114.66km
HRM: sequence:204, interval:677ms, bpm:84
SPDCAD: speed: 23.56km/h, cadence: 62rpm, total distance: 114.66km
SPDCAD: speed: 23.14km/h, cadence: 0rpm, total distance: 114.67km
HRM: sequence:205, interval:671ms, bpm:85
SPDCAD: speed: 22.94km/h, cadence: 0rpm, total distance: 114.67km
SPDCAD: speed: 21.25km/h, cadence: 0rpm, total distance: 114.67km
HRM: sequence:206, interval:667ms, bpm:85
HRM: sequence:207, interval:678ms, bpm:86
HRM: sequence:208, interval:674ms, bpm:86
SPDCAD: speed: 0.00km/h, cadence: 20rpm, total distance: 114.67km
HRM: sequence:209, interval:647ms, bpm:87
HRM: sequence:210, interval:657ms, bpm:87
HRM: sequence:211, interval:668ms, bpm:88
SPDCAD: speed: 1.98km/h, cadence: 0rpm, total distance: 114.67km
HRM: sequence:212, interval:645ms, bpm:88
HRM: sequence:213, interval:640ms, bpm:89
HRM: sequence:214, interval:643ms, bpm:89
HRM: sequence:215, interval:656ms, bpm:89
HRM: sequence:216, interval:644ms, bpm:90
HRM: sequence:217, interval:474ms, bpm:90
HRM: sequence:218, interval:833ms, bpm:90
HRM: sequence:219, interval:634ms, bpm:90
HRM: sequence:220, interval:613ms, bpm:91
HRM: sequence:221, interval:617ms, bpm:92
HRM: sequence:222, interval:603ms, bpm:93
HRM: sequence:223, interval:632ms, bpm:93
HRM: sequence:224, interval:853ms, bpm:93
HRM: sequence:225, interval:907ms, bpm:93
HRM: sequence:226, interval:894ms, bpm:90
HRM: sequence:227, interval:816ms, bpm:88
HRM: sequence:228, interval:897ms, bpm:85
HRM: sequence:229, interval:899ms, bpm:83
HRM: sequence:230, interval:837ms, bpm:81
HRM: sequence:231, interval:895ms, bpm:79
HRM: sequence:232, interval:908ms, bpm:78
HRM: sequence:233, interval:901ms, bpm:76
HRM: sequence:234, interval:911ms, bpm:75
HRM: sequence:235, interval:950ms, bpm:73
HRM: sequence:236, interval:943ms, bpm:72
HRM: sequence:237, interval:928ms, bpm:71
