defragster
Senior Member+
Probably as Defragster mentioned and as I mentioned up above and in https://github.com/arduino/arduino-ide/issues/1039
The IDE on first run downloads several libraries into the <sketcheds>/libraries folders including SD.
And if that version has examples it would probably show up in the early section of the examples...
@KurtE - Cool - indeed, that does seem to match your post #196:
SD.h - They install SD library within <sketches>/libraries/SD ... Not compatible with our stuff. I tried to build something and it failed. I then deleted that directory, tried to build, and it still tried to use that SD directory and then erred saying file did not exist, instead of grabbing the one that TD installed which I nicely told me it did not use:
Missed reading that as such, but had seen the sketchbook issue recently when a private lib took precedence.
Wow - this is a complex process replication the old 1.x IDE to add features ... good work discovering/documenting Kurt
