Im little new to Teensy 3.1 and i have started to use Teensy 3.1 with Arduino_o_phone code. I have tested Arduino_o_phone from Adafruit and it compiles with Arduino UNO without problem but...
When i compile Arduino_o_phone with Teensy 3.1 i get this error
Build options changed, rebuilding all
In file included from arduin_o_phone.ino:20:0:
..../arduino-1.6.5/hardware/teensy/avr/libraries/ILI9341_t3/ILI9341_t3.h:40:0: warning: "ILI9341_RDIMGFMT" redefined [enabled by default]
#define ILI9341_RDIMGFMT 0x0D
In file included from arduin_o_phone.ino:19:0:
.../arduino-1.6.5/hardware/teensy/avr/libraries/Adafruit_ILI9341/Adafruit_ILI9341.h:45:0: note: this is the location of the previous definition
#define ILI9341_RDIMGFMT 0x0A
arduin_o_phone:81: error: 'ILI9341_DARKGREEN' was not declared in this scope
arduin_o_phone:81: error: 'ILI9341_DARKGREY' was not declared in this scope
arduin_o_phone:85: error: 'ILI9341_PINK' was not declared in this scope
arduin_o_phone:86: error: 'Adafruit_GFX_Button' does not name a type
arduin_o_phone.ino: In function 'void setup()':
arduin_o_phone:123: error: 'buttons' was not declared in this scope
arduin_o_phone.ino: In function 'void loop()':
arduin_o_phone:178: error: 'buttons' was not declared in this scope
arduin_o_phone:188: error: 'buttons' was not declared in this scope
arduin_o_phone:193: error: 'buttons' was not declared in this scope
Multiple libraries were found for "Adafruit_GFX.h"
Used: .../arduino-1.6.5/hardware/teensy/avr/libraries/Adafruit_GFX
Not used: .../Arduino/libraries/Adafruit-GFX-Library-master
My code:
does:
* can make calls on the speaker & mic
todo:
* status notification updates in loop()
* dim screen when no touches in 1 minute
* receive calls
* receive texts
* candy crush
#include <Wire.h> // this is needed even tho we aren't using it
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
#include <ILI9341_t3.h>
#include <Adafruit_STMPE610.h>
#include <SoftwareSerial.h>
#include <HardwareSerial.h>
#include "Adafruit_FONA.h"
#define FONA_RX 2
#define FONA_TX 3
#define FONA_RST 4
//#define HWSERIAL Serial1
//HardwareSerial fonaSS = Serial1; // replaces SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
// For the Adafruit TFT shield, these are the default.
#define TFT_DC 9
#define TFT_CS 10
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
//Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
// The STMPE610 uses hardware SPI on the shield, and #8
#define STMPE_CS 8
Adafruit_STMPE610 ts = Adafruit_STMPE610(STMPE_CS);
// This is calibration data for the raw touch data to the screen coordinates
#define TS_MINX 150
#define TS_MINY 130
#define TS_MAXX 3800
#define TS_MAXY 4000
/******************* UI details */
#define BUTTON_X 40
#define BUTTON_Y 100
#define BUTTON_W 60
#define BUTTON_H 30
#define BUTTON_SPACING_X 20
#define BUTTON_SPACING_Y 20
#define BUTTON_TEXTSIZE 2
// text box where numbers go
#define TEXT_X 10
#define TEXT_Y 10
#define TEXT_W 220
#define TEXT_H 50
#define TEXT_TSIZE 3
#define TEXT_TCOLOR ILI9341_WHITE
// the data (phone #) we store in the textfield
#define TEXT_LEN 12
char textfield[TEXT_LEN+1] = "";
uint8_t textfield_i=0;
// We have a status line for like, is FONA working
#define STATUS_X 10
#define STATUS_Y 65
/* create 15 buttons, in classic candybar phone style */
char buttonlabels[15][5] = {"Call", "Clr", "End", "1", "2", "3", "4", "5", "6", "7", "8", "9", "*", "0", "#" };
uint16_t buttoncolors[15] = {ILI9341_DARKGREEN, ILI9341_DARKGREY, ILI9341_RED,
ILI9341_BLUE, ILI9341_BLUE, ILI9341_BLUE,
ILI9341_PINK, ILI9341_BLUE, ILI9341_PINK};
Adafruit_GFX_Button buttons[15];
// Print something in the mini status bar with either flashstring
void status(const __FlashStringHelper *msg) {
tft.fillRect(STATUS_X, STATUS_Y, 240, 8, ILI9341_BLACK);
tft.setCursor(STATUS_X, STATUS_Y);
tft.setTextColor(ILI9341_WHITE);
tft.setTextSize(1);
tft.print(msg);
// or charstring
void status(char *msg) {
tft.setTextSize(1);
tft.print(msg);
Serial.println("Arduin-o-Phone!");
// clear the screen
tft.begin();
// eep touchscreen not found?
if (!ts.begin()) {
Serial.println("Couldn't start touchscreen controller");
while (1);
Serial.println("Touchscreen started");
// create buttons
for (uint8_t row=0; row<5; row++) {
for (uint8_t col=0; col<3; col++) {
buttons[col + row*3].initButton(&tft, BUTTON_X+col*(BUTTON_W+BUTTON_SPACING_X),
BUTTON_Y+row*(BUTTON_H+BUTTON_SPACING_Y), // x, y, w, h, outline, fill, text
BUTTON_W, BUTTON_H, ILI9341_WHITE, buttoncolors[col+row*3], ILI9341_WHITE,
buttonlabels[col + row*3], BUTTON_TEXTSIZE);
buttons[col + row*3].drawButton();
// create 'text field'
tft.drawRect(TEXT_X, TEXT_Y, TEXT_W, TEXT_H, ILI9341_WHITE);
status(F("Checking for FONA..."));
// Check FONA is there
fonaSS.begin(4800); // if you're using software serial
// See if the FONA is responding
if (! fona.begin(fonaSS)) { // can also try fona.begin(Serial1)
status(F("Couldn't find FONA
while (1);
status(F("FONA is OK!"));
// Check we connect to the network
while (fona.getNetworkStatus() != 1) {
status(F("Looking for service..."));
status(F("Connected to network!"));
// set to external mic & headphone
fona.setAudio(FONA_EXTAUDIO);
void loop(void) {
TS_Point p;
if (ts.bufferSize()) {
p = ts.getPoint();
// this is our way of tracking touch 'release'!
p.x = p.y = p.z = -1;
// Scale from ~0->4000 to tft.width using the calibration #'s
if (p.z != -1) {
p.x = map(p.x, TS_MINX, TS_MAXX, 0, tft.width());
p.y = map(p.y, TS_MINY, TS_MAXY, 0, tft.height());
Serial.print("("); Serial.print(p.x); Serial.print(", ");
Serial.print(p.y); Serial.print(", ");
Serial.print(p.z); Serial.println(") ");
// go thru all the buttons, checking if they were pressed
for (uint8_t b=0; b<15; b++) {
if (buttons.contains(p.x, p.y)) {
//Serial.print("Pressing: "); Serial.println(b);
buttons.press(true); // tell the button it is pressed
buttons.press(false); // tell the button it is NOT pressed
// now we can ask the buttons if their state has changed
if (buttons.justReleased()) {
// Serial.print("Released: "); Serial.println(b);
buttons.drawButton(); // draw normal
if (buttons.justPressed()) {
buttons.drawButton(true); // draw invert!
// if a numberpad button, append the relevant # to the textfield
if (b >= 3) {
if (textfield_i < TEXT_LEN) {
textfield[textfield_i] = buttonlabels[0];
textfield_i++;
textfield[textfield_i] = 0; // zero terminate
fona.playDTMF(buttonlabels[0]);
// clr button! delete char
if (b == 1) {
if (textfield > 0) {
textfield_i--;
textfield[textfield_i] = ' ';
// update the current text field
Serial.println(textfield);
tft.setCursor(TEXT_X + 2, TEXT_Y+10);
tft.setTextColor(TEXT_TCOLOR, ILI9341_BLACK);
tft.setTextSize(TEXT_TSIZE);
tft.print(textfield);
// its always OK to just hang up
if (b == 2) {
status(F("Hanging up"));
fona.hangUp();
// we dont really check that the text field makes sense
// just try to call
if (b == 0) {
status(F("Calling"));
Serial.print("Calling "); Serial.print(textfield);
fona.callPhone(textfield);
delay(100); // UI debouncing
I would be werry nice to give some guidens
Best regards
Toxic
My code:
does:
todo:
* receive calls
* receive texts
* candy crush
#define FONA_RX 2
#define FONA_TX 3
#define FONA_RST 4
#define TFT_DC 9
#define TFT_CS 10
#define STMPE_CS 8
#define TS_MINX 150
#define TS_MINY 130
#define BUTTON_X 40
#define BUTTON_W 60
#define BUTTON_H 30
#define TEXT_X 10
#define TEXT_Y 10
#define TEXT_W 220
#define TEXT_H 50
#define TEXT_LEN 12
#define STATUS_X 10
#define STATUS_Y 65
tft.setTextSize(1);
tft.print(msg);
// or charstring
tft.setTextSize(1);
tft.print(msg);
// clear the screen
tft.begin();
if (!ts.begin()) {
while (1);
// create buttons
while (1);
void loop(void) {
TS_Point p;
p = ts.getPoint();
if (p.z != -1) {
if (b >= 3) {
textfield_i++;
if (b == 1) {
textfield_i--;
if (b == 2) {
fona.hangUp();
// just try to call
if (b == 0) {
Best regards
Toxic
