Hi everyone,
I received my Teensy Audio Board yesterday and immediately solder the (optional) mic and volume knob.
This morning I start to work with it mounted on a Teensy 3.6. Strangely, on top of the music (from the MicroSD card), there’s a rapid note parasite, like a synth sound, the same note repeating forever. When I turn down the music’s volume at 0, the “parasite” is not affected and doesn’t stop.
It is related to the MicroSD card control. For example, when I load the Hardware_Test script (Tutorial Part_1_02), there’s no parasite. It’s just and only in scripts where MicroSD card is involved. I tried using different MicroSD card and also the Teensy’s onboard MicroSD connector (selected in the script) and it’s the same parasite again.
(If it can help, I can upload a recording of that “parasite”?)
I thought that maybe it’s the Teensy’s CPU speed, I don’t know. For now, it’s 180MHz.
Did you ever encounter that kind of issue?
Thanks for your help!
