audio DAC PCM1502 output level
emmanuel63
Hello,
I use a a pcm1502 audio doc. It works very well but the line output level is very high.
With a full scale sine at 1 kHz, I get a 6V peak to peak output level.
Is it normal ?
My setup :
Teensy 4.0
VCC = Vin
3.3v = N.C.
GND = GND
FLT = GND
DMP = GND
SCL = GND
BCK = BCLK1 (21)
DIN = OUT1A (7)
LCK = LCRLK (20)
FMT = GND
XMT = 3.3V (HIGH)
my test code (I use the 2nd IS2 bus)
#include <SerialFlash.h>
AudioSynthWaveformModulated waveformMod1;   //xy=453.5,358
AudioOutputI2S2           i2s2_1;           //xy=752.5000076293945,358.7500047683716
AudioConnection          patchCord1(waveformMod1, 0, i2s2_1, 0);
AudioConnection          patchCord2(waveformMod1, 0, i2s2_1, 1);
  AudioMemory(15);
  waveformMod1.begin(1, 1000, WAVEFORM_SINE);
Is it normal ?
Yes, it is. PCM5102A board, powered with 5Vdc, connected to a Teensy 3.2. The PCM5102A chip has a charge pump internally to realize an output voltage of 2.1Vrms.
Paul
Ok, from the datasheet the max output is 2.1V rms, which is about 3V which will be 6V peak to peak. Yes, it's normal.
This board has 3pcs 5V-to-3V3 regulators on it. The AVDD, CPVDD and DVDD pins of the chip have their own supply.
Paul
