I'm using the new Audio library from Paul to sample from an analog pin and perform an FFT. It works great, and is far simpler (and I imagine vastly more CPU efficient) that my original efforts of simply looping with analogRead().
I'm curious though at what frequency does it sample at, and can I change this?
Also for anyone else doing similar things it seems to have a low volume cutoff, where below a certain volume level all the outputs read 0. I've had look in input_adc.cpp, and there are two lines:
I'm using a mic/opamp breakout board from Adafruit, which outputs from 0 to V (where V is the input it's powered with, i.e in my case 3.3v) with a dc bias at V/2, and so for me swapping these lines around to range from 0-3.3 made it much more sensitive.
Thanks!
Mark
analogReference(INTERNAL); // range 0 to 1.2 volts
//analogReference(DEFAULT); // range 0 to 3.3 volts
Thanks!
Mark
