Hey there!
For the synthesizer I'm building I use the PWM output of the teensy 3.1 to control the frequency of a low pass filter.
The documentation of the PWM output, however, states that the Signal range is approximately 1.55 Vp-p.
I want to increase this range, to get a better filter range.
What is a good way to do this?
By modifying the AudioOutputPWM object so the range becomes around 3.3 Vp-p?
Or would an opamp-gain circuit do a better job?
so the signal is scaled with a gain around 2.
I already tried the latter, but I didn't have good results yet.
thanks in advance!
Roel
thanks in advance!
Roel
