//const int myInput = AUDIO_INPUT_LINEIN;
const int myInput = AUDIO_INPUT_MIC;
// each filter requires a set up parameters
int myFilterParameters[] = { // notch, Fc=2175 Hz
896456695, -1707514503, 896456695, 1707514503, -719171567, 0, 0, 0};
// Create the Audio components. These should be created in the
// order data flows, inputs/sources -> processing -> outputs
AudioInputI2S audioInput; // audio shield: mic or line-in
AudioFilterBiquad myFilter(myFilterParameters);
AudioOutputI2S audioOutput; // audio shield: headphones & line-out
// Create Audio connections between the components
AudioConnection c1(audioInput, 0, audioOutput, 0);
AudioConnection c2(audioInput, 0, myFilter, 0);
AudioConnection c3(myFilter, 0, audioOutput, 1);
// Create an object to control the audio shield.
// Audio connections require memory to work. For more
AudioMemory(12);
// Enable the audio shield and set the output volume.
audioShield.enable();
audioShield.inputSelect(myInput);
audioShield.volume(60);
elapsedMillis volmsec=0;
// every 50 ms, adjust the volume
if (volmsec > 50) {
float vol = analogRead(15);
vol = vol / 10.24;
audioShield.volume(vol);
volmsec = 0;
