Using the Teensy pass through sketch example to simplify, I am adjusting the line-out volume from the Audio Shield to an amp. I'm using the sgtl5000_1.lineOutLevel(left,right) command but the range of control, although it works, seems limited (for example I cannot approach zero output). My understanding is that the parameters for left/right are 13 through 31. Please, what am I doing wrong???
CSS:
* A simple hardware test which receives audio from the audio shield
* Line-In pins and send it to the Line-Out pins and headphone jack.
* This example code is in the public domain.
#include <SerialFlash.h>
AudioInputI2S i2s1; //xy=200,69
AudioOutputI2S i2s2; //xy=365,94
AudioConnection patchCord1(i2s1, 0, i2s2, 0);
AudioConnection patchCord2(i2s1, 1, i2s2, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=302,184
// Audio connections require memory to work. For more
AudioMemory(12);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
sgtl5000_1.lineOutLevel(31, 31);
elapsedMillis volmsec=0;
// every 50 ms, adjust the volume
if (volmsec > 50) {
float vol = analogRead(15);
vol = vol / 1023.0;
//audioShield.volume(vol); // <-- uncomment if you have the optional
volmsec = 0; // volume pot on your audio shield
//lineOutLevel(22, 22);
