Hello. I am working on building a drum machine with my teensy 4.1. I will be using Adafruit's Neotrellis for the drum sequencer and I set it up and it all works well with the examples on the arduino IDE. I will be using the audio board so I cant use my sda and scl 0 outputs, so I need to use the Wire1 pins 16 and 17. I have used the scanner examples and my teensy is able to detect the neotrellis
this is the neotrellis connected to wire1 14:18:24.334 -> Scanning Wire1...14:18:24.363 -> Device found at address 0x2E (MCP44XX ePot)14:18:24.363 -> done
Can anyone please help me? I am not the best at programming but I do not see what else I can do.
C++:
/* This example shows a more complex LED pattern
using a NeoTrellis board.
Note that due to memory requirements this example
will not work on boards with very limited memory such
as the Adafruit Metro (with ATMega328p)
#include "Adafruit_NeoTrellis.h"
Adafruit_NeoTrellis trellis;
#define MAX_RIPPLES 16
#define FALLOFF_TIME 30
#define FALLOFF (0xFF/FALLOFF_TIME)
#define NUM_POINTS 8
#define RIPPLE_RATE .4
#define INT_PIN 10 // Change this to the pin connected to your interrupt
#define MATRIX_POINT(x,y) ((y)*4+(x))
uint32_t colors[] = {
0xFF0000, 0x00FF00, 0x0000FF,
0xFF00FF, 0x00FFFF, 0xFFFFFF
union color {
struct {
uint8_t blue:8;
uint8_t green:8;
uint8_t red:8;
} bit;
uint32_t reg;
color matrix[4][4];
struct point {
float x;
float y;
struct ripple {
int8_t center;
uint32_t t;
color c;
point points[NUM_POINTS];
static struct ripple ripples[MAX_RIPPLES];
//define a callback for key presses
TrellisCallback blink(keyEvent evt){
for(int i=0; i<MAX_RIPPLES; i++){
if(ripples[i].center == -1){
//create a new ripple here
ripples[i].center = evt.bit.NUM;
ripples[i].t = 0;
for(int j=0; j<NUM_POINTS; j++){
ripples[i].points[j].x = NEO_TRELLIS_X(evt.bit.NUM);
ripples[i].points[j].y = NEO_TRELLIS_Y(evt.bit.NUM);
ripples[i].c.reg = colors[random(sizeof(colors)/sizeof(uint32_t))];
return 0;
//while(!Serial);
pinMode(INT_PIN, INPUT_PULLUP); // Use INPUT_PULLUP for Teensy's internal pull-up resistor
randomSeed(analogRead(0));
if(!trellis.begin(0x2E, Wire1)){
Serial.println("could not start trellis");
while(1) delay(1);
else{
Serial.println("trellis started");
ripples[i].center = -1;
//activate all keys and set callbacks
for(int i=0; i<NEO_TRELLIS_NUM_KEYS; i++){
trellis.activateKey(i, SEESAW_KEYPAD_EDGE_RISING);
trellis.registerCallback(i, blink);
//do a little animation to show we're on
for(uint16_t i=0; i<trellis.pixels.numPixels(); i++) {
trellis.pixels.setPixelColor(i, 0x0000FF);
trellis.pixels.show();
delay(50);
trellis.pixels.setPixelColor(i, 0x000000);
delay(50);
void processRipples(){
for(int x=0; x<4; x++){
for(int y=0; y<4; y++)
matrix[x][y].reg = 0;
bool update = false;
if(ripples[i].center > -1){
update = true;
//push all points out from the center
point *p = ripples[i].points;
p[0].x += RIPPLE_RATE;
p[1].x += RIPPLE_RATE/2;
p[1].y += RIPPLE_RATE/2;
p[2].y += RIPPLE_RATE;
p[3].x -= RIPPLE_RATE/2;
p[3].y += RIPPLE_RATE/2;
p[4].x -= RIPPLE_RATE;
p[5].x -= RIPPLE_RATE/2;
p[5].y -= RIPPLE_RATE/2;
p[6].y -= RIPPLE_RATE;
p[7].x += RIPPLE_RATE/2;
p[7].y -= RIPPLE_RATE/2;
int x = round(p[j].x);
int y = round(p[j].y);
if(x < 4 && x >= 0 && y < 4 && y >= 0){
byte red = min(255, matrix[x][y].bit.red + ripples[i].c.bit.red);
byte green = min(255, matrix[x][y].bit.green + ripples[i].c.bit.green);
byte blue = min(255, matrix[x][y].bit.blue + ripples[i].c.bit.blue);
matrix[x][y].bit.red = red;
matrix[x][y].bit.green = green;
matrix[x][y].bit.blue = blue;
ripples[i].t++;
if(ripples[i].t >= FALLOFF_TIME) ripples[i].center = -1;
if(update){
trellis.pixels.setPixelColor(MATRIX_POINT(x,y), matrix[x][y].reg);
if(!digitalRead(INT_PIN)){
trellis.read(false);
processRipples();
delay(20);
