Hi Cor,
Some first tests this morning,using the precompiled hex, nothing fancy: fingers brushing and keys jangling... no bats at hand in my office
No major problems, except for the one below, but which might be my fault anyways...
All the rest looks perfectly fine and is working as designed.
All in all a very nice upgrade, thanks !
Now for my little problem, which probably isn't one.
My current settings:
Sample rate : 192k
SR rec : 384k (same value for Auto record)
SR play : Direct
On playback with these settings I experience extreme slowness, in screen refresh, and sound playback, with interruptions of sound.
This happens with SRate Direct only. When I switch to SR 48 or lower, playback is perfectly fine.
This does not happen with Edwin's sample files, that are also on my SD card and for which SR is 192K only.
If I take SR rec down to 192K, the problem disappears completely.
No slowness for SR values of 234 ,281 , 352... only for 384K, which leads me to...
...the fact that I'm currently using a Sandisk card that is NOT a class 10 (I broke the one I had while working on the enclosure
) and I'm beginning to think that it's all caused simply by poor reading speeds of my current card...
If you think this is the source of the problem, please ignore...
On a side note: while in playback, if I use left enc to change the file, the playback doesn't switch to the new file, as it did before (I think), and I have to press left button twice to playback the new file.
More as soon as those damned bats decide to come out and play again
Regards,
Thierry
