Hi
So i have two more questions.
I'm running out of buttons so my question is if i probably can add more functionalities to it by detecting the duration of the press. So a single press is function one and a long press calls function two. Did anyone tried to add this. I see some troubles comming because a long press can combine with a short press because i'm looking for the falling edge etc. probably also issues i didn't think off.
The second thing whats the easiest way to make a vu meter led strip with a teensy 3.2 with a microphone or wathever needed (but no sound signal through teensy). Is there a "extension" available which will allow me tho do that with a teensy which already has a Octows2811 shield and 5 Additional pins occupied?
regards Severin
by the way thanks for the previous help the buttons are working now
regards Severin
