Beware! T4x RTC power consumption
More on getting the standby (xtal RTC only) current down, and a question (anybody listening to this thread? :)
I'm listening. It needs to be noted that the recommended batteries are 3V lithium coin cell, not a 3.6V lithium, different chemistry and voltage.
Yep - just a thing to watch out for, and a solution. Rechargeable lithiums also go to 4V or so while charging, so that's something to regulate down for longest battery life. The big surprise is that the consumption goes UP when you turn the power on, if you supply at least close to 3.3V Batt, as the processor consumes more and the T4 board's diodes don't make a hard switch.
I'm listening but this is part of the discussion above my pay grade. Because of the current draw, I re-implemented an older circuit of mine for Push On - Hold Off, and am now using a separate RTC as noted earlier in this thread. I'd like to use the onOff and RTC of the Teensy, but the power draw was too much. Unless you find a solution!
This may be the reason it won't start with that battery on?
That keeping the RTC part alive with 3V is good to help power on in some cases noted by PJRC. But that pin like others is 3.3V limited and having higher voltage may be blocking startup with 3.3V?
Try it with a 3V battery and see if same p#25? issue occurs.
The diode I suppose does some voltage drop - but 3.6V or higher alone will kill the Teensy. And higher than 3.3V supply may disorient the electrons from 3.3V supply or some technical thing.
I'm watching as well as I'm suffering this same issue. I power up my system once every week or four. CR2032 battery - a couple of months and I no longer have an accurate date and my data file naming goes bananas. :(
Just ordered an external RTC, but that'll drive a board spin and figuring out how to get it functioning...
If I've got 12V available, is there a super low current way to power the RTC on the Teensy so the vehicle battery could power it? Can I have the 2032 and the 12V reduced voltage in parallel (diode or'd) if I unplug the 12V, I don't have to reset the clock? Or cap that'll power it for a few hours if I disconnect the 12V?
I power the RTC using a super capacitor, like this one: 1.5F 3.5v cap. I use a schottky diode between the Teensy's 3.3v output and the RTC power input to charge the cap. With a Teensy 3.2 it powers the RTC for several days. I haven't experimented with a Teensy 4.1, but I expect it to last a few hours.
From a couple of CR2032 battery data sheets, it looks like they run 3.0V or less most of their life, but for a bit at the beginning. Dropping voltage shouldn't be needed. You could measure the current consumption using a good multimeter in series with the battery. Maybe one diode drop might help, but I'm using a 1.2 AH 3.6V battery. The little .22 Ah coin cells should give you 9 months of power off time. Sure, you could use a 3.3V voltage regulator on that 12V supply and two diodes to combine with the battery for the RTC power. I'm considering a rechargable battery and charging circuit also.
This issue is probably driving me to an external I2C RTC - RV-3028-C7 is what I'm planning. My device will be in the field where CR2032's last years... (Think similar to your computer BIOS...)
I'm assuming I can reuse D1 for D2 and only need one BAT54 and build that part of the circuit accordingly since I won't need any low power operation. I'm assuming that the 2 .22uF caps (C17 and C18) and the 10uF (C31) help with the power sequencing. Be great to get rid of the BAT54 and caps altogether, but I'm not that smart on microcontroller circuit design yet. Can I?
All this is moot if there's a fix for the RTC current drain.
Yes, the processor never sees 3.6 V, there's >0.5V through the diode on the Teensy board.
I stopped working on getting out of SNVS mode and settled for the 27 uA or so standby consumption. If I read the data BOOK correctly, the only way to wake up from SNVS is to use a timer. But I'd need that to be once or twice a second so as to not excessively delay power-on startup. Then first thing, a tiny bit of code puts it back to SNVS sleep if power is down. But I don't think the T4.1 will boot quickly enough to do that. This monster may have hardware support that does just that, but I don't know enough to find the way. Or perhaps wake up on pin voltage?
I have recently run into this problem too. What I have found is among the 5 teensy 4.0's I have, the power consumption for the rtc varies wildly. This is measured with no external components for 5 different teensy 4.0's: 2x 92uA, 84uA, 46uA, 27uA @ 3.0V. Measured before and after a blank sketch upload (aka firmware update). The firmware update nor sketch did not change the measurement. I guess this is a production/hardware issue...?
Are all pins either OUTPUT or INPUT_PULLUP as required to minimize pad power drain? Floating inputs can drain current.
I assumed that GPIO pins are not even set nor part of the power off RTC circuit...?
MarkT, Aduen, if the +5 input is off, and only the RTC system is powered, do the pin states matter at all? Assumed the pin drivers get their power from a main supply, right?
Hi @blahfoo,
we're suffering from the same problems.
We're using Teensy 4.1 on sounding rocket experiments (DLR MAPHEUS). So, when the payload is at the tower and "radio silence" is active (motor arming, etc.) we need a backup for some of the RTCs. First: we've to use LiSOCl2 as LiMnO2 coin cells suffer from out-gassing issues. And no, the Teensy _does not_ die from the 3,6V, repeatedly, some dozen Teensy 4.1. But the power drain trough Vbatt while the device is powered is an issue (flight sim, test countdown(s), hot countdown(s)). But we're probably going to solve this in hardware (capacitor + FET).
Regarding the pure standby current: did you try to set IOMUXC_SNVS_SW_PAD_CTL_PAD_PMIC_STBY_REQ = 0;? Does that make any measurable change? (see IMXRT1060RM_rev3.pdf page 380) As you did a lot of measurements with your boards I hope you might see a change that's comparable to the previous values.
Best, Christian
On why T4 and RTC coin cell batteries (CR2032, CR2012 etc) give us months but not >>3 months: is this a software bug / omission after all? Reading the many many register settings in this NXP 2023 Application note, and not getting many hits when searching T4 source codes for usage of e.g. SNVS_LPCR_TOP and the likes, it seems plausible to me that there's simply no provision for a decent transition from powered on normally (say 5V on T4 VIN) to the lowest SNVS VBAT power mode after that 5V power supply disappears. Say after unplugging USB. Quite well possible that one needs to catch an interrupt after VDD drops too low (brown out event maybe?) and then disable in software many many peripherals like SPI, ENET, FlexRAM, and only then write this SNVS_LPCR_TOP bit so that the remaining current drawn from VBAT is as per the datasheet, just a few uA. Or maybe one has to check VDD with an ADC just like temperature is checked, and then observe a drop, decide that main power is disappearing, and take appropriate actions??
On why T4 and RTC coin cell batteries (CR2032, CR2012 etc) give us months but not ... is as per the datasheet, just a few uA.
? As noted in the original post the data sheet says .02mA which is 20uA, not a few uA. Even if I could get 20uA that would be 90 instead of 50 days, still useless for my application.
I also went for separate RTC chips when a battery backed RTC is needed by the application. But I'm just wondering if better software in a Teensy 4 could get us lower VBAT drain in general.
Because:
if I power up a T4 with only VBAT, i see 43 uA when VBAT is 3V.
if I then plug in USB with 5V, it drops to below 1 uA.
if I hold ONOFF pin low for many seconds, it goes up to 36 uA after going 'OFF' and releasing the pin.
while pulling ONOFF pin low, without 5V supply but with VBAT at 3V, the current is 20 uA higher.
The datasheet IMXRT1060CEC says the maximum in SNVS would be 20 uA.
This application note https://www.nxp.com/docs/en/application-note/AN12245.pdf says that 17 uA (or 15 uA) is what is measured in SNVS mode on what I'd say would be comparable hardware.
That makes me believe that with a T4 there is unexplored territory that potentially doubles coin cell battery lifetime on VBAT.
As in setting registers that disable stuff that remains enabled / powered on. Or disabling pullups, pulldowns. Maybe something in config fuses.
