gruvin
BUG: Teensyduino v1.3.1-beta3 :: PlaySdRaw on Teensy 3.6 crashes
Howdy
Background
I recently backed the Teensy 3.5/6 campaign, as my first foray into the Teensy world. I have 2x Teensy 3.6 boards and later, a Teensy 3.2. All very cool, especially the great library code! A great deal of work must have gone in to all this. Wow! Loving it.
Today, I've been playing around with the audio library, following the video tutorial (more or less) though using DAC outputs on the '3.6, instead of the codec chip on the shield I don't have.
BUG REPORT
Context
OS X Mavericks, Arduino IDE 1.6.12, Teensyduino v1.3.1-beta3
Discovery
Everything worked amazingly well (it's super cool
... up until I got to playSdRaw() (not part of the tutorial). (playSdWav() works fine, though it's a little slower.) OK, so details ...
First, here's the sketch source I'm working with ...
Sketch Notes
As the source suggests, the wiring set-up is pretty straight forward. I have the Teensy 3.6 connected to a USB port. I have wires with touch plates connected to pins 15 through (15+NUM_TOUCHES), inclusive. These are read using readTouch(). The for loop etc is simply a roll-my-own debounce and single-shot (non-repeating if touch pad continuously touched). All of that was working fine with playMem() and playSdWav().
The Bug
Using playSdRawN(), I can tap away on any single pad and everything seems fine. However, if I tap any other pad before the previous pad's sample has fully completed playing, CRASH.
In other words, if say, playSdRaw1() is playing and I trigger playSdRaw2() before playSdRaw1()'s sample completes, then the system hangs, some time soon after (inside one second or so) yet not immediately. If I had to guess, I would say that an in-progress DMA operation completes, generates an interrupt and right about then is when the crash occurs.
Estimated Repeatability Factor: 98.8%
Sample files used in the above sketch are attached. These were created using SoX, as in: sox Kick.wav -e signed -b 16 Kick.raw
Oh -- the MMC card is a, "SanDisk Ultra 8GB Class 10".
Thanks a bunch.
Bryan
New Zealand.
Howdy
Background
BUG REPORT
Context
Discovery
#include <SerialFlash.h>
#include <CapacitiveSensor.h>
AudioPlaySdRaw playSdRaw4; //xy=183,336
AudioPlaySdRaw playSdRaw3; //xy=184,287
AudioPlaySdRaw playSdRaw1; //xy=185,196
AudioPlaySdRaw playSdRaw2; //xy=185,243
AudioPlaySdRaw playSdRaw7; //xy=187,502
AudioPlaySdRaw playSdRaw6; //xy=188,452
AudioPlaySdRaw playSdRaw5; //xy=196,400
AudioPlaySdRaw playSdRaw8; //xy=203,562
AudioMixer4 mixer1; //xy=353,268
AudioMixer4 mixer2; //xy=360,449
AudioMixer4 mixer3; //xy=546,359
AudioOutputAnalogStereo dacs1; //xy=702,359
AudioConnection patchCord1(playSdRaw4, 0, mixer1, 3);
AudioConnection patchCord2(playSdRaw3, 0, mixer1, 2);
AudioConnection patchCord3(playSdRaw1, 0, mixer1, 0);
AudioConnection patchCord4(playSdRaw2, 0, mixer1, 1);
AudioConnection patchCord5(playSdRaw7, 0, mixer2, 2);
AudioConnection patchCord6(playSdRaw6, 0, mixer2, 1);
AudioConnection patchCord7(playSdRaw5, 0, mixer2, 0);
AudioConnection patchCord8(playSdRaw8, 0, mixer2, 3);
AudioConnection patchCord9(mixer1, 0, mixer3, 0);
AudioConnection patchCord10(mixer2, 0, mixer3, 1);
AudioConnection patchCord11(mixer3, 0, dacs1, 0);
AudioConnection patchCord12(mixer3, 0, dacs1, 1);
#define NUM_TOUCHES 5
#define DEBOUNCE_COUNT 5
#define TOUCH_THRESHOLD 2500
typedef enum
TS_IDLE,
TS_DEBOUNCE,
TS_OFF_WAIT
} Touch_State_TypeDef;
Touch_State_TypeDef touchState[NUM_TOUCHES];
int touchCounter[NUM_TOUCHES];
AudioMemory(10);
// Configure SPI for the audio shield pins
SPI.setMOSI(7); // Audio shield has MOSI on pin 7
SPI.setSCK(14); // Audio shield has SCK on pin 14
if (!SD.begin(BUILTIN_SDCARD))
while (1)
Serial.println("No SD card access!");
mixer1.gain(0, 0.25);
mixer1.gain(1, 0.25);
mixer1.gain(2, 0.25);
mixer1.gain(3, 0.25);
mixer2.gain(0, 0.25);
mixer2.gain(1, 0.25);
mixer2.gain(2, 0.25);
mixer2.gain(3, 0.25);
mixer3.gain(0, 0.4);
mixer3.gain(1, 0.4);
mixer3.gain(2, 0.4);
mixer3.gain(3, 0.4);
for (int i=0; i<NUM_TOUCHES; i++)
switch (touchState[i])
case TS_IDLE:
touchCounter[i] = DEBOUNCE_COUNT;
touchState[i] = TS_DEBOUNCE;
case TS_DEBOUNCE:
if (touchRead(15+i) > TOUCH_THRESHOLD)
touchCounter[i]--;
if (touchCounter[i] == 0)
switch (i)
case 0:
playSdRaw1.play("SNARE.RAW");
case 1:
playSdRaw2.play("KICK.RAW");
case 2:
playSdRaw3.play("TOM1.RAW");
case 3:
playSdRaw4.play("TOM2.RAW");
case 4:
playSdRaw5.play("TOM3.RAW");
touchState[i] = TS_OFF_WAIT;
touchState[i] = TS_IDLE;
case TS_OFF_WAIT:
if (touchRead(15+i) < TOUCH_THRESHOLD)
default:
} // switch (touchState[i])
} // for
} // loop
Sketch Notes
The Bug
Thanks a bunch.
Bryan
New Zealand.
